[Qbasic] Soundkaart aansturen, hoe?
  • Engineer
  • Laatst online: 04-05 00:03
[ Voor 100% gewijzigd door Engineer op 13-10-2018 17:42 ]
  • Osiris
Huh? Wat moet jij met QBasic???
Hdd heeft z'n wijdepijpenbroek aangetrokken, wat lounge aangezet en gaat heerlijk retro QB coden? :?
  • Osiris
Was vroeger wel gaaf btw, QBasic. Nog gedaan op m'n MSX I...
Maar nu ga ik Hackers verder kijken...
  • Koen_R
  • Laatst online: 15:56
Dit vond ik in de oude doos, de PLAY functie, maar dan via je Adlib Compatible soundcard.
Have Fun :)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
DefInt A-Z
DECLARE FUNCTION DetectCard% ()
DECLARE SUB SBInit ()
DECLARE SUB WriteReg (Reg%, Value%)
DECLARE SUB SBPlay (note%)
CONST false = 0, true = NOT false
Screen 0: Cls
If DetectCard = True Then
  Print "AdLib-compatible sound card detected."
Else
  Print "Unable to find/detect sound card."
  Beep
  System
End If
Print " Initalizing...";
SBInit
Print " Done."
For nt = 0 To 255
SBPlay nt
Next nt
Print
Print "  These routines only support one channel/voice of the FM chip, but"
Print "eventually I may fix them so you can have a bunch o'instruments on"
Print "at once.  I'd also like to write a replacement for SBFMDRV.COM, but"
Print "that's far off, and probably not in QB anyway.  This is too fast"
Print "compiled, so if you are going to use it in anything, add a delay."
Print "                     Enjoy!     -Brett 11 / 12 / 92"
Print
For nt = 255 To 0 Step -1
SBPlay nt
Next nt
Print "[Press any key to end]"
SLEEP
Call WriteReg(&HB0, &H0) 'Makes sure no extra sound is left playing
Function DetectCard%()
'  Purpose:   Detects an AdLib-compatible card.
'        Returns -1 (true) if detected and 0 (false) if not.
'  Variables: Nope
Call WriteReg(&H4, &H60)
Call WriteReg(&H4, &H80)
B = INP(&H388)
Call WriteReg(&H2, &HFF)
Call WriteReg(&H4, &H21)
  For x = 0 To 130
    a = INP(&H388)
  Next x
C = INP(&H388)
Success = 0
If (B And &HE0) = &H0 Then
  If (C And &HE0) = &HC0 Then
    Success = -1
  End If
End If
DetectCard% = Success
End Function
Sub SBInit()
'  Initialize the sound card
'(This is the "quick-and-dirty" method; what it's doing is zeroing out
'  all of the card's registers.  I haven't had any problems with this.)
For q = 1 To &HF5
  Call WriteReg(q, 0)
Next q
End Sub
Sub SBPlay(freq%)
'  Purpose: Plays a note
'  Variables:    freq% - Frequency (00-FF hex)
'           duration% - Duration (n seconds) (not used)
'  I'm still working on this part, it may be ugly, but it works <g>.
'  The first group of WriteRegs is the modulator, the second is the
'  carrier.
'  If you just want to know how to create your own instrument, play around
'  with the second values in the first four calls to WriteReg in each group.
'  :-)  Have fun!  - Brett
Call WriteReg(&H20, &H7)    ' Set modulator's multiple to F
Call WriteReg(&H40, &HF)    ' Set modulator's level to 40 dB
Call WriteReg(&H60, &HF0)   ' Modulator attack: quick, decay: long
Call WriteReg(&H80, &HF0)   ' Modulator sustain: medium, release: medium
Call WriteReg(&HA0, freq%)
Call WriteReg(&H23, &HF)   ' Set carrier's multiple to 0
Call WriteReg(&H43, &H0)   ' Set carrier's level to 0 dB
Call WriteReg(&H63, &HF0)  ' Carrier attack: quick, decay: long
Call WriteReg(&H83, &HFF)  ' Carrier sustain: quick, release: quick
Call WriteReg(&HB0, &H20)  ' Octave
Call WriteReg(&HE0, &H0)   ' Waveform argument for Tom..
                   ' &H00 is the default, but I felt like
                   ' dropping it in for you.. :)
' I originally had an extra argument, duration!, but for some reason
' I wanted to do the timing outside of this sub..  You can change it back
' if needs require..
'TimeUp! = TIMER + duation!
'WHILE TimeUp! > TIMER: WEND  ' Worst you can be off is .182 of a second
End Sub
Sub WriteReg(Reg%, Value%)
'  Purpose:   Writes to any of the SB/AdLib's registers
'  Variables: Reg%: Register number,
'        Value%: Value to insert in register
'         (Note: The registers are from 00-F5 (hex))
OUT &H388, Reg     '388h = address/status port, 389h = dataport
  For x = 0 To 5   ' This tells the SB what register we want to write to
    a = INP(&H388) ' After we write to the address port we must wait 3.3ms
  Next x
OUT &H389, Value   ' Send the value for the register to 389h
  For x = 0 To 34  ' Here we must also wait, this time 23ms
    a = INP(&H388)
  Next x
End Sub
SUB
line input ; "Is qbasic nog steeds boeind" $a
If $a = "ja" THEN print "Jij moet naar de dokter..!"
If $a = "nee" THEN GOTO doh
If ELSE THEN PRINT "Typ ja of nee"
doh:
COLOR 25
PRINT "Ja je hebt gelijk :) "
END
END SUB
Debug me maar :7
  • Koen_R
Afbeeldingslocatie: http://home.hccnet.nl/k.rotteveel/pds.gif
Haal dan die sub command weg :P
laat ook maar btw
  • Koen_R
kneus:
INPUT "Is qbasic nog steeds boeind? ", a$
IF LCASE$(a$) = "ja" THEN
      PRINT "Jij moet naar de dokter..!"
      END
ELSEIF LCASE$(a$) = "nee" THEN
      GOTO doh
ELSE
      GOTO kneus
END IF
doh:
COLOR 25
PRINT "Ja je hebt gelijk  "
END
PRINT " Ik veronderschuldig mij nadat ik de nieuwste versie van QB heb geinstalled."
  • Engineer
[ Voor 99% gewijzigd door Engineer op 13-10-2018 17:39 ]
  • Arjan Scholl
  • Laatst online: 12-09 11:15
Op zaterdag 05 januari 2002 23:03 schreef digimortal het volgende:
SUB
doh:
COLOR 25
END
END SUB
Debug me maar :7
Ik ben wel geen guru maar na 4 fouten te hebben verbeterd (excl die SUB) doet ie het nog niet.
  • Koen_R
Op zaterdag 05 januari 2002 23:30 schreef arjanscholl het volgende:
Zie mijn hernieuwde versie in de post daar ergens onder 8-)
Dan betekent het dus dat ik de volgende keer met een taal het vaker moet gebruiken anders word het overschreven in mijn koppie.
  • markvt
  • Laatst online: 17:17
markvt
Peppi Cola
play "abcdefg"
beep
sound 800,10
zie de help voor die functies er ff op na
van-tilburg.info -=- meka (sega emulator) - Proud MEDION fanclub member - KOPPIG VOLHOUDEN !
Ik hoor alweer vader jakob klinken :)
  • PipoDeClown
PipoDeClown
Izze Zimpell
Op zaterdag 05 januari 2002 23:29 schreef hdd het volgende:
Waar slaan die reacties op :? Ik prog vanaf m'n negende al in qbasic..
Mag ik aannemen dat je er ook een serieuze applicazie in hebt gebakken?
God weet alles, want hij is lid van de Mosad. To protect your freedom i will take that away from you. Mijn drankgebruik heeft ernstig te lijden onder mijn gezondheid.
  • Koen_R
Op zaterdag 05 januari 2002 23:36 schreef markvt het volgende:
play "abcdefg"
beep
sound 800,10
check de topictitel:
[Qbasic]Soundkaart aansturen, hoe?
  • Engineer
  • markvt
markvt
Peppi Cola
maarja pc speaker werkt op elke pc, soundkaart niet :)
  • Engineer
[ Voor 99% gewijzigd door Engineer op 13-10-2018 17:37 ]
  • markvt
markvt
Peppi Cola
Op zaterdag 05 januari 2002 23:44 schreef hdd het volgende:
Aangezien het progsel toch niet veel verder dan m'n eigen pc zal komen kan het best. Uit een soundkaart kun je btw "iets" meer bass halen ;)
k, mijn soundcard is niet SB compatible dus vandaar.
  • Arjan Scholl
Mijn versie :P
[code]CLS
INPUT "Is QBasic nog steeds boeiend? ", a$
b$ = LCASE$(a$)
DO
LOOP WHILE b$ = ""
IF b$ = "nee" THEN GOTO doh ELSE PRINT "Jij moet naar de dokter!!!": END
doh:
COLOR 25
PRINT "Ja je hebt gelijk!"
END[/code]
  • Bigs
Op zaterdag 05 januari 2002 21:05 schreef Osiris_NL het volgende:
Das knap :) Volgens mij is dat er alleen voor de PC (onder DOS)
  • Engineer
Ik word de hele tijd gescrewt met mijn ugly code :(
maar ja eigen schuld dikke bult en btw die mening was lelijk en nu veranderd
  • Bigs
Op zaterdag 05 januari 2002 23:52 schreef hdd het volgende:
Neej, kheb hier nog zo'n qbasic apparaat tussen het schroot liggen dat je op je tv kan aansluiten :)
Dat is geen QBasic.. MSX-Basic of dat TRS-80 taaltje, maar dat is behoorlijk anders hoor (moet je nog regelnummers gebruiken en ondersteunt geen functies enzo).
  • Engineer
QuickBASIC roels!!!!!
  • Mithrandir
  • Laatst online: 14-09 20:56
Op zondag 06 januari 2002 12:34 schreef Xtentic het volgende:
jep.
Ik zoek een manier om de compoort aan te sturen. MAAR ik kan niets vinden wat bruikbaar is ... Voor VB6, niet voor QB :(
Verbouwing
  • .oisyn
  • Laatst online: 00:42
.oisyn
Moderator Devschuur®
Demotivational Speaker
Op zondag 06 januari 2002 13:39 schreef DinoRaptor het volgende:
jep.
zucht
OPEN "COM1:bla bla bla" AS #1
wel heel erg RTFM hoor
  • Skinkie
  • Laatst online: 09-06-2020
Skinkie
Op naar de 500
Is er nou al een nieuwe versie van QuickBasic uit? ik "doe" het soms nog met 4.5 :)
Steun Elkaar, Kopieer Nederlands Waar!
jep.
compoort in de zin van modem ?
Op zondag 06 januari 2002 14:39 schreef Skinkie het volgende:
Nee, maar er zijn wel andere versies
Rapid-Q (voor windows/linux/hpfs programmeren in een basic taal)
PDS 7.1 (Same als QuickBASIC maar toch ietsje anders ;))
  • Osiris
Gewoon ff een vraagje hoor: Waarom programeer je in QBasic Hdd? Borland Pascal is ook DOS en daar kun je veel meer mee...
In Pascal kan ik namelijk wél de geluidskaart aansturen *D
Of vind je het gewoon leuk :?
  • Mithrandir
Op zondag 06 januari 2002 14:33 schreef OiSyN het volgende:
zucht
:o! Ik heb geen manual :) Wel 2 boeken over MSX-basic, maar daar stond 't niet in, en op internet kon ik er niets over vinden.
Verbouwing
  • Engineer
[ Voor 99% gewijzigd door Engineer op 13-10-2018 17:36 ]
  • Mithrandir
Op zondag 06 januari 2002 15:28 schreef hdd het volgende:
Qbasic kan ik zonder allemaal moeilijk gedoe met serials en daarna een uur lang laden opstarten, sim-pel :)
Plus het feit dat je overal in je vrije tijd ken proggen :)
Een uur lang laden opstarten :?
[edit]
Ik heb nu de volgende code om de compoort te openen, maar ik zou niet weten hoe ik het moet veranderen ofzo...
' Now open COM Port as selected with a 2048-byte buffer in Tx and Rx
 SELECT CASE comport
  CASE 1
   OPEN "COM1:9600,N,8,1,CD0,CS0,DS0,OP0,RS,TB2048,RB2048" FOR RANDOM AS #1
  CASE 2
   OPEN "COM2:9600,N,8,1,CD0,CS0,DS0,OP0,RS,TB2048,RB2048" FOR RANDOM AS #1
 END SELECT
Verbouwing
  • Engineer
[ Voor 99% gewijzigd door Engineer op 13-10-2018 17:35 ]
  • Arjan Scholl
Jeps...QuickBasic Extended 7.1 :) © 1990 :D
  • .oisyn
.oisyn
Op zondag 06 januari 2002 15:11 schreef DinoRaptor het volgende:
wel eens op f1 gedrukt? Daar staat het allemaal mooi in
  • Mithrandir
Op zondag 06 januari 2002 16:15 schreef OiSyN het volgende:
Welke compiler?? Ik heb zo'n freeware-ding... Daar wordt deze functie niet beschreven.
[edit]
Heb jij ICQ eigenlijk wel aan? Add me nou ff!!
[edit2]
Gevonden! QBasic.exe heb ik ook |:(
Verbouwing
  • .oisyn
.oisyn
mij adden heeft geen zin aangezien ik een hekel heb aan QB en er al 6 jaar niet meer in heb gecode :)
  • Mithrandir
Op zondag 06 januari 2002 16:45 schreef OiSyN het volgende:
Wat doe jij dan in dit topic :?
Nouja, ik heb 'm dus, maar ik snap geen bout van de baudrate ofzo. Wat is dat?
En verder staan er nog allemaal dingen als 'OPEN "COM1:300,N,8,1,CD0,DS0,OP0,RS,TB2048,RB2048" FOR RANDOM AS #1'
Verbouwing
  • .oisyn
.oisyn
dus ik mag hier niet komen als ik niet meer in qb code :?
verder weet ik niet hoe het allemaal werkt met seriele poorten in qb, maar als jij dingen als baudrate niet weet vraag ik me af wat jij in hemelsnaam wilt doen met de seriele poort (en wat het allemaal betekent staat in de manual, ik gaf alleen maar een tip dat je het daar kon vinden)
  • Mithrandir
Op zondag 06 januari 2002 17:01 schreef OiSyN het volgende:
1. dat was een grapje.
2. Eh... laat ook maar :) (m'n fans aansturen, daar wil ik zelf wat voor schrijven. *iets geknipt wat er niet inhoorde*
Verbouwing
  • .oisyn
.oisyn
Op zondag 06 januari 2002 17:19 schreef DinoRaptor het volgende:
ah ok, een :) erbij had wel handig geweest misschien ;)
2. Eh... laat ook maar :) (m'n fans aansturen, daar wil ik zelf wat voor schrijven. Een digitale baybus zegmaar :))
staan die dingen dan niet in de specs van de baybus?
/me heeft nog wel een source code + lib voor een HSC player onder dos... *D Wies geintresseerd?
