Eizo 19" FlexScan T761
CRT Size 50 cm (19 inch) class, 90° deflection Tension Mask
CRT Phosphor Pitch Center: 0.24 mm, Edges: 0.25 mm (Aperture Grill)
CRT Surface Treatment Super ErgoCoat®
Scanning Frequency H: 30 - 115 kHz V: 50 - 160 Hz
Input Signals RGB Analog
Input Terminal D-Sub mini 15 pin and BNC x 5 (switchable)
Active Display Size 362 mm (H) x 271 mm (V) (Diagonal: 452 mm)
Recommended Resolution 1280 dots x 1024 lines flicker-free at 107 Hz (max) (1600 dots x 1200 lines at 92 Hz addressable)
Screen Control ScreenManager®, ScreenManager Pro for USB, One Touch Auto Adjustment Function (Auto-Sizing)
Power Management System VESA DPMS
Power Consumption 130 watts
Power Save Mode 1 Less than 10 watts
Power Save Mode 2 (Off) Less than 3 watts
Plug & Play1 DDC 2B
Dimensions 452 mm (W) x 455 mm (H) x 478 mm (D)
Net Weight 28.0 kg
Certifications and Standards TCO''99, TÜV ECO Circle 2000, TÜV/Ergonomics, TÜV/GS, c-Tick, CE, CB, UL 1950, CSA C22.2 No.950, FCC-B, Canadian ICES-003-B, TUV/S, VCCI-B, EPA ENERGY STAR® Program, Energy 2000
USB Standard2 USB Standard Rev. 1.1 Compliance
USB Ports 1 Upstream port (for computer or another hub) 4 Downstream ports (for peripherals)
Of:
Eizo 19" F730:
CRT Size 50 cm (19 inch) class, 90° deflection Invar Shadow Mask
CRT Phosphor Pitch 0.26 mm/0.22 mm (horizontal)
CRT Surface Treatment SuperErgoCoat®
Active Display Size 363 mm (H) x 271 mm (V) (Diagonal: 453 mm)
Screen Control ScreenManager® & ScreenManager Pro, One Touch Auto Adjustment Function (Auto-Sizing)
Power Consumption 120 watts
Plug & Play1 DDC 1/2B
Net Weight 22.8 kg
Certifications and Standards TCO''99, TÜV/Ergonomics, TÜV/GS, CE, CB, UL 1950, CSA C22.2 No.950, FCC-B, Canadian ICES-003-B, TUV/S, VCCI-B, EPA ENERGY STAR® Program, Energy 2000
Kijk, dat vind ik nou "lekker"
