Oh ja de specs van de :NEC FE950
The MultiSync FE950 19-inch (18-inch viewable image size)
totally flat monitor delivers outstanding quality and improved
brightness and contrast over traditional CRT technology at an
affordable price.
Specifications
* Picture Tube/Display: 19" (18" viewable image size),
90° deflection, 0.25 mm - 0.27 mm (variable) grille pitch,
medium short persistence phosphor, totally flat aperture grille
CRT, multi-layered, anti-static screen coating, dark-tint screen
and OptiClear screen surface.
* Input Video Signal: ANALOG 0.7 Vp-p/75 Ohms Positive
* Sync:
Seperate sync: TTL Level
Horizontal sync: Positve/Negative
Vertical sync: Positive/Negative
Composite sync: TTL Level, Positive/Negative
* Display Colors: Analog Input: Unlimited Colors (Dependent upon
display card used)
* Synchronization Range (Automatic):
Horizontal: 31 kHz to 96 kHz
Vertical: 55 Hz to 160 Hz
* Resolutions Supported:
640 x 480 @ 60 to 160 Hz
800 x 600 @ 55 to 152 Hz
832 x 624 @ 55 to 146 Hz
1024 x 768 @ 55 to 119 Hz
1152 x 870 @ 55 to 104 Hz
1280 x 1024 @ 55 to 89 Hz
1600 x 1200 @ 55 to 76 Hz
1792 x 1344 @ 55 to 68 Hz
NOTE: Some systems may not support all modes listed.
* Recommended Resolution: 1280 x 1024 @ 85 Hz
* Active Display Area (Factory Setting):
Horizontal: 14.0 in. / 356 mm
Vertical: 10.5 in. / 267 mm
(Dependent upon signal timing used)
Active Display Area (Full Scan):
Horizontal: 14.4 in. / 366 mm
Vertical: 10.8 in. / 275 mm
* Power Supply: AC 100 - 240 V, 50/60 Hz
* Current Rating: 1.2A @ 100 - 120V / 0.6A @ 220 - 240V
* Signal Cable: Captive 15-pin mini D-SUB connector
* Dimensions:
Net: 442 mm (W) x 467 mm (H) x 447 mm (D)
Gross: 558 mm (W) x 576 mm (H) x 588 mm (D)
* Weight:
Net: 53.6 lbs. / 24.3 kg
Gross: 70.5 lbs. / 32.0 kg
* Operating Temperature: +10° C to + 35° C / +50° F to +90°
F
* Operating Humidity Range: 30% to 80%
* Operating Altitude: 0 to 10,000 Feet
* Storage Temperature: -20° C to +60° C / -4° F to +140° F
* Storage Humidity Range: 10% to 90%
* Storage Altitude: 0 to 45,000 Feet
General
* Limited Warranty: 3 Years CRT, Parts and Labor
* Power Management: IPM (Intelligent Power Manager) System, EPA
ENERGY STAR, meets NUTEK based on 2 power-saving modes
* User Controls: Power, degauss, brightness, contrast, Auto
Adjust horizontal/vertical size and position, vertical size and
position, horizontal size and position, geometry (sides in/out, sides left/right, tilt, align, rotate), AccuColor control system,
moiré canceler, basic convergence, area convergence, corner
correction, linearity, GlobalSync control, factory preset,
language, OSM position, OSM turn off, OSM lock out, IPM,
EdgeLock, refresh notifier, display mode, monitor info
* Regulatory Approvals: UL 1950, C-UL, CSA C22.2 No. 950, FCC
Rules Part 15 Class B, DHHS Rules 21 CFR, Sub Chapter J,
ISO-9241-3, MPR-II, EPA Energy Star, NUTEK, TCO 99
affordable price.
Specifications
* Sync:
display card used)
* Dimensions:
* Weight:
F
General
ding is erg goed, maar het is en blijft persoonlijk, zoals ik in een andere topic zei: "de ene vind een blonde meid leuk terwijl de ander erom moet :r"
maar ik vind het een erg geil ding.. als je hem bij computer-land haalt moet je zorgen dat je een prijslijst hebt van een pc discount van ze.. daar is de prijs namelijk lager.. prijslijst is een week geldig.. had mijn NEC voor die prijs (1175,- normaal: 1250,-)
deze topic
deze topic
dank je limp_bizkit, ik heb hem zojuist nog gezien voor Fl 1059,- dus dat is nog goedkoper dan wat jij er voor heb moeten lappen
Maar ik ben nog maar (bijna) 16 en dus speelt mijn vader ook een grote rol in dit geheel, mijn vader vind het belangrijk dat de winkel waar we hem kopen in de buurt is (omgeving woerden) omdat als er wat kapot mocht gaan hij snel naar de winkel kan, hij heeft namelijk wel eens problemen gehad met zijn toendertijd spiksplinternieuwe Compaq (
) beeldscherm en het duurde heeeel lang voordat hij een vervangend type kreeg, een 2 jaar ouder model
P.S. Mijn vader betaalt de helft!!!
Heb hem vandaag binnen van Computerland, 1220,-
Het is de FE 950 + ...weet iemand of dat "+" een nieuwe uitvoering aanduid??
Op het plaatje op de NEC site zag ik een rechthoekige monitor( de achterkant) Ik heb nu zo''n mooi gestroomlijnd rond kontje!
Maar natuurlijk gaat het om het beeld : great, mooi helder, goeie kleurendiepte en haarscherp.
Heb hem op resolutie 1152/864 staan, anders worden die buroblad icoontjes leesbrilwerk...:) en ook sommige sites zien er helaas niet uit bij hoge resolutie..
Maar spellen en beeldbewerking:P:P:P:P
xMouse
jmw computers, gezien in de computer totaal van deze maand, volgens mij is hun website www.jmw.nl , kan ook com zijn.Op zaterdag 07 april 2001 22:09 schreef Der_General het volgende:
he arnoman waar heb jij hem voor 1049 gezien. Ben ik naar benieuwd.
Het is trouwens 1059 en niet 1049
Ja ik zag het net ook pas, in de computer totaal stond er raar genoeg niks over dat het excl. btw was maar op hun site destemeerOp maandag 09 april 2001 10:20 schreef Der_General het volgende:
Jammerhet zijn allemaal prijzen ex-BTW, boehoehoe, sniksnik.
The desire to know is natural to all good people!
