[BC3] Debian ik krijg KDE niet er op
Ik heb een cd met KDE 2.1 er op die ik heb toegevoegd aan mijn sources.list. Ik heb met dselect door de pakketen
gebladerd. En task-kde gevonden. Dus doe ik apt-get install task-kde krijg ik een fout melding. Hij heeft het over
umet dependency''s Er wordt nog wel een oplossing aangedragen.
Ik moet apt-get -f install doen. Dan vraag hij om mijn potato cd''s (binary 1,2) en installeert een aantal lib''s van die
cd''s. Daarna probeer ik KDE weer te installeren met
apt-get install task-kde dan krijg ik dit wat hier onder staat. Wat doe ik fout?
Reading Package Lists...
Building Dependency Tree...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
task-kde: Depends: kdebase but it is not going to be installed
Depends: kdebase-libs but it is not going to be installe
Depends: konqueror but it is not going to be installed
Depends: konsole but it is not going to be installed
Depends: kuser but it is not going to be installed
Depends: ksysv but it is not going to be installed
Depends: kcron but it is not going to be installed
Depends: kpackage but it is not going to be installed
Depends: ksysctrl but it is not going to be installed
Depends: secpolicy but it is not going to be installed
Depends: kghostview but it is not going to be installed
Depends: kview but it is not going to be installed
Depends: kmail but it is not going to be installed
Depends: korn but it is not going to be installed
Depends: korganizer but it is not going to be installed
Depends: abbrowser but it is not going to be installed
Depends: ark but it is not going to be installed
Depends: kab but it is not going to be installed
Depends: karm but it is not going to be installed
Depends: kcalc but it is not going to be installed
Depends: kcharselect but it is not going to be installed
Depends: kdepasswd but it is not going to be installed
Depends: kdf but it is not going to be installed
Depends: kedit but it is not going to be installed
Depends: kfind but it is not going to be installed
Depends: khexedit but it is not going to be installed
Depends: kjots but it is not going to be installed
Depends: knotes but it is not going to be installed
Depends: kpm but it is not going to be installed
Depends: ktimemon but it is not going to be installed
Depends: koffice-libs but it is not installable
Depends: kchart but it is not installable
Depends: kword but it is not installable
Depends: kspread but it is not installable
Depends: killustrator but it is not installable
Depends: kpresenter but it is not installable
Depends: kformula but it is not installable
Depends: koshell but it is not installable
Depends: kivio but it is not installable
Depends: pixie but it is not going to be installed
Depends: kpaint but it is not going to be installed
Depends: kiconedit but it is not going to be installed
  • Valium
  • Laatst online: 23:37
Valium
- rustig maar -
De foutmelding lijkt mij best wel duidelijk. Leten we er eens stap voor stap doorheen lopen. Dat gedoe met unmet dependencies en apt-get -f instell. Dat betekent dat je een prgramma hebgt zitten installeren zonder eerst de programma''s / bibliotheken te installeren die dat programma nodig heeft. Oftewel, je systeem was al brak voordat je KDE ging proberen te installeren. Dat heb je blijkbaar verholpen.
Je gaat vervolgens task-kde installeren. Die geeft als foutmelding dat hij programma''s nodig heeft die niet geinstalleerd gaan worden. Dat is een vage eigenschap met apt-get. Sommige "unstable" pakketten worden niet correct herkend door apt. De reden?? Geen idee. De oplossing? Alle pakketten die apt zegt nodig te hebben noemen. Voor jou wordt dit dus een enorme waslijst. "apt-get install kdebase kdebase-libs konqueror konsole ..." Wat je ook kunt doen in plaats van het hele KDE gebeuren in een keer installeren, is om KDE in stapjes te installeren. Dus eerst kde-lib base en konqueror. Dan heb je in ieder geval wel de belangrijkste onderdelen te pakken. Om je te helpen bij het kiezen, selecteren en installeren van pakketten kun je ook gnome-apt eens proberen.
Succes!!
apt-get install task-kde <alle pakjes gescheiden met een spatie>
Dat werkte bij mij wel.
  • balk
  • Laatst online: 07:52
welke kde regel heb je in /etc/apt/sources.list? eentje van kde.debian.net? Ik heb laatst ook de debs via testing binnen gelepeld maar die zijn brak.
Op zaterdag 31 maart 2001 15:28 schreef balk het volgende:
Ik heb de cd bij tienpiek.net bestelt.
Ik bent er nu ook al achter wat hij mist.
libsasl7
libsslo96
  • balk
even zoeken naar apt-cdrom in de GoT knowledge databank
Bijvoorbeeld deze
