PC Specs
Asus ROG Strix B650E-E | AMD 7700X | G-Skill 32GB DDR5 6000C30 M-die | 4090 FE | LG 38GN950-B 3840*1600p 160Hz | Corsair RM1000x Shift | WD Black SN850X 1TB M.2
Ik bedoel eigenlijk dat ik cd's wil kunnen omzetten naar Mp3's.
PC Specs
Haal AudioCatalyst ergens omlaag en zoek d'r op astalavista een crack voor... helemaal gratis
StatBar.nl - @GoT
Het verschil tussen theorie en praktijk is in de praktijk altijd veel groter dan in theorie.
Ben met biobak eens: gratis en goed. http://www.exactaudiocopy.de /
Deze site bevat veel informatie: http://www.r3mix.net /
Ik ben niet nieuwsgierig; ik ben alleen maar benieuwd.
De Xing encoder van Audiocatalyst zuigt aan alle kanten, daarom is ie ook zo snel
Ik zou dus _niet_ voor Audiocatalyst gaan. Je mp3's zitten vol met glitches.
MusicMatch Jukebox. Je moet wel even zoeken naar een serial, als je alle functies wilt gebruiken.
www.musicmatch.com
www.musicmatch.com
The whole is always greater than the sum of it's parts.
CDEX http://www.cdex.n3.net/
What is CDex?
CDex is a freeware application, which is able to extract audio tracks from a CD-ROM digitally, and save those files to disk as either regular WAV file or MP3 files.
Why use CDex?
Well CDex can extract the data directly from an Audio CD, which is generally called an Audio CD Ripper or a CDDA utility. Of course you can do that also by recording through your sound-card However, recording by sampling the signal with your sound card implies that the signal is first has to be converted to an analog signal by the CD-ROM, which is fed into the sound-card and digitized by the sound-card. In practically all situation the quality of the recording will be deteriorated (unless you have a CD-ROM that has a digital output of course). CDex on the other hand, is reading the digital audio data directly from the disc, which can be stored in either a WAV file or a MPEG (MP2 or MP3) sound file.
Feature List
Direct recording of multiple tracks
Read track information from cdplayer.ini file
Read track information from local/remote CDDB
Jitter correction
Indicates track progress and jitter control
Normalization of audio signal
Supports multiple drives
Conversion of external WAV files
Support for M3U and PLS play list files
Best of all, it's free
What is CDex?
Why use CDex?
Feature List
Jitter correction
