  • szjoin
  • Laatst online: 13-08 13:53
Mijn vraag
Hoe kan ik weer co2 en fan speed tonen van mijn itho-cve module
Installatiemethode Home Assistant OS
Core 2025.9.3
Supervisor 2025.09.0
Operating System 16.2
Frontend 20250903.5
laatste mqtt broker (versie onbekend)
ChatGPT helemaal leeggetrokken:
Dit is mijn itho.yaml
29
30
31
32
33
34
35
36
# Central CO₂ from itho/ithostatus
- platform: mqtt
  name: "Itho Central CO2"
  state_topic: "itho/ithostatus"
  value_template: "{{ value_json['co2level_ppm'] }}"
  unique_id: "itho_central_co2"
  unit_of_measurement: "ppm"
  device_class: carbon_dioxide
  state_class: measurement
# Fan speed from itho/ithostatus
- platform: mqtt
  name: "Itho Fan Speed"
  value_template: "{{ value_json['fan-speed_rpm'] }}"
  unique_id: "itho_fan_speed"
  unit_of_measurement: "rpm"
# Remote CO₂ from itho/remotesinfo
- platform: mqtt
  name: "Itho Remote Woonkamer CO2"
  state_topic: "itho/remotesinfo"
  value_template: "{{ value_json['Woonkamer']['co2'] }}"
  unique_id: "itho_remote_woonkamer_co2"
# Remote PIR from itho/remotesinfo
- platform: mqtt
  name: "Itho Remote Woonkamer PIR"
  state_topic: "itho/remomqtttesinfo"
  value_template: "{{ value_json['Woonkamer']['pir'] }}"
  unique_id: "itho_remote_woonkamer_pir"
  device_class: motion
configuration.yaml ziet er zo uit:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
binary_sensor: !include_dir_merge_list binsensors/
sensor: !include_dir_merge_list sensors/
light: !include_dir_merge_list lights/
switch: !include_dir_merge_list switches/
Het probleem is dat het eerder wel werkte maar ik wilde de boel opschonen. In de loop er tijd is er net iets teveel geprobeerd en vervuild.
Er waren meerdere .yaml files die rommelig waren en omdat ik meer van yaml begreep (dacht ik) leek een opschoonactie nodig te zijn.
Home Assistant krijgt nu wel de data binnen op de mqtt bus:
Bericht 2 ontvangen op itho/remotesinfo om 08:38:
{"Woonkamer":{"timestamp":0,"lastcmd":0,"lastcmdmsg":"IthoUnknown","co2":520,"pir":1}}
QoS: 0 - Retain: true
Bericht 1 ontvangen op itho/ithostatus om 08:38:
{"temp":25.9,"hum":53.9,"ppmw":11442,"speed-status":4,"internal-fault":0,"frost-cycle":0,"filter-dirty":0,"airquality_perc":200,"airq-based-on":64,"co2level_ppm":520,"indoor-humidity_perc":53,"outdoor-humidity_perc":"not available","exhausttemp_c":"not available","supply-temp_c":"not available","indoor-temp_c":"not available","outdoor-temp_c":"not available","speed-cap":63496,"bypass-pos_perc":"not available","fan-info":"auto","exh-fan-speed_perc":4,"in-fan-speed_perc":0,"remaining-time_min":0,"post-heat_perc":"not available","pre-heat_perc":"not available","in-flow-l_sec":"not available","exh-flow-l_sec":"not available","ventilation-setpoint_perc":2,"fan-setpoint_rpm":483,"fan-speed_rpm":511,"error":0,"selection":7,"startup-counter":89,"total-operation_hours":44393,"absence_min":0,"highest-co2-concentration_ppm":"not available","highest-rh-concentration_perc":53,"relativehumidity":53.94,"temperature":25.91}
maar kan geen sensor aanmaken. Er blijven slechts 3 entiteiten bekend en dat zijn:
  • fan
  • humidity
  • temperature
Talloze aanpassingen en herstarts gedaan.
Help!
Beste antwoord (via rens-br op 19-09-2025 19:11)
  • szjoin
vele uren laten. Er lijst een breaking change geweest te zijn (bron: ChatGPT).
Ik heb nu een scriptje gemaakt voor de mqtt discovery voor alle entiteiten en co2 is opeens weer beschikbaar. Echter nu is de fanspeed nog niet terug?!
  • szjoin
Het lijkt er op dat de topics die door de mqtt add-on worden gelezen niet als entiteit worden geconverteerd. Daarom 'ziet' HA het niet. Heb vanalles opgeschoond (vraag me niet wat 'vanalles' is want ik ben uren aan het proberen geweest) en na een herinstallatie van mqtt is er geen verandering.
De .yaml files worden gelezen (dwz als ik daar expres een fout in maak dan wordt deze fout direct opgemerkt) dus dat zal toch moeten kloppen?
Een restore is nu niet meer aan de orde want dan zet ik alle andere data ook terug en dat is niet acceptabel.
  • Beste antwoord ✓
  • szjoin
  • szjoin
probleem met escapes:
value_json[\"fan-speed_rpm\"]
lijkt nu te werken.
Zo. Weekend. Einde prutsen.
  • sypie
Gaat het om deze module?
  • szjoin
Klopt. Het was een 'interessante' reis. Kan bevestigen dat alles nog steeds naar behoren werkt.
Trigger voor mij om me nogmaals te verdiepen in de HA 'onderwaterwereld' met hoe al die yaml files werken.
