Best compatible motherboard for i5 14600k/Core 5 ultra 245
  • 253 views
  • technofilian
  • Registratie: November 2024
  • Laatst online: 14-06-2025
Hi,
I am looking for best compatible motherboard for above two processors.
Can you suggest any? I am looking for MSI Pro Z790 p WiFi. Is it a good motherboard? Any other alternative?
  • 99ruud99
  • Laatst online: 21-10 12:09
uitvoering: Gigabyte Z890I AORUS ULTRA if itx
Do you need wifi?
Which case are you going to use?
What gpu are you planning on using?
  • br00ky
  • Laatst online: 00:03
br00ky
Deze vraag hoort gewoon thuis in Suggestion/Help in building a PC. Geen aparte topics aanmaken over hetzelfde onderwerp.
