sorry dat dit in het engels is heb het meerde forums gebruik
  • 625 views
  • Threshis
  • Registratie: Augustus 2024
  • Laatst online: 23-08-2024
I build a budget gaming PC about 2.5 months ago. my rig:
CPU: R5 5600x PBO OFF
GRAPHICS CARD: RTX 4060
M.2 SSD: WD Blue SN580
MOBO: Gigabyte A520M K V2 (I know not the best mobo but for the hard budget i was on i thought it would be good)
PSU: Be Quiet! System Power 10 550W Bronze rated.
What ive done:
CPU stress test: Cinebench (no overheating)
GPU stress test: 3D mark, Furmark. (no overheating)
OCC power test: 10 minutes: no errors no overheating no crash.
Updated / downgraded drivers to see if any problems went way.
and lots and lots more.
since i build the pc ive had problems with stutters. i figured the stutters were a problem with the games i played: Elder scrolls online, Sekiro, Elden ring. Eso is notorius for stuttering so i cant test in that game. Sekiro had some "loading stutters" other people have them too when transitioning into a new area. Elden ring was really really bad until i fixed something bugged with the game. but now its getting worse the stutters. in elden ring i drop like 10 fps randomly. in tekken 8 there is something called fight lounge with a lot of people there and every time it loads a set of people it stutters like crazy. in the witcher 3 i keep having stutters when fighting enemies (happened in elden ring too for the first time today) i dont know if im going crazy or if there is actually something wrong. i would love some help. a note about the PSU: it does have a high pitch noise coming from it even when the PC is off. but testing power with OCCT resulted in no errors crashes or volt rails being low or anything. in HWINFO i do have a problem with power reporting deviation which dropped all the way to 80%
  • Nopheros
  • Laatst online: 08:45
How much cpu/memory usage when running a game with stuttering?
Did you check how much power your hardware needs? 550 seems low.
[ Voor 43% gewijzigd door Nopheros op 22-08-2024 23:34 ]
  • Boudewijn
Boudewijn
omdat het kan
Zijn wij in jouw gedachten een afhaalchinees ofzo? Jij hebt een vraag/probleem maar wil er niet de moeite in steken om je vraag in het Nederlands te stellen?
Daarnaast is je post echt lastig leesbaar door gebrek aan interpunctie en niet toepassen van grammaticale regels.
[ Voor 3% gewijzigd door Boudewijn op 22-08-2024 23:37 ]
  • pnczbr
  • Registratie: Mei 2024
  • Laatst online: 22-04 11:49
Boudewijn schreef op donderdag 22 augustus 2024 @ 23:36:
Doe even relaxed dan op dit late tijdstip 8)7
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Yeah, det is not how it wurks here. Translate maar effe to dutch en probeer 't dan opnieuw met een topictitel die de lading dekt. Neem voordat je dat doet even onze quickstart snelstart door ;)
Je eigen tweaker.me redirect
Over mij
