Victron MESS - Mijn ESS
Pagina: 1 2 Laatste
  • MJ de Bruijn
  • Registratie: November 2016
  • Laatst online: 08:59
Deel 3 van de Flow "Targets"
In verband met de gelimiteerde ruimte in een post is de JavaScript tekst van functie "Calculate Targets" hier separaat opgenomen.
Kopieer deze tekst en plak die in de functie "Calculate Targets"in de Node Red Flow.
Deel twee staat in de volgende post.
// Function Calculate Targets
const TraceOn = false;
const Now = new Date()
const NowHour = Now.getHours();
const NowMinutes = Now.getMinutes();
const NowInSeconds = Math.floor(Now.getTime() / 1000);
let NowTime = ("0" + Now.getHours()).slice(-2) + ":"
+ ("0" + Now.getMinutes()).slice(-2) + ":"
+ ("0" + Now.getSeconds()).slice(-2)
const Batt_Capacity_Wh = Math.floor(3 * 5.12 * 1000); // three batteries
const SoC_Full_Perc = 98; // when Battery is realistically full
const Grid_Setpoint_W_Limit = 10000;
const Solar_Charge_Perc = 98; // max perc to use for charging
// Sell only if price difference > n.n Ct
const Sell_Price_Limit_Ct = 3.0;
const Conversion_Loss_Factor = 0.9; // conversion losses
// Variables to read from Global
var SoC_Min_Manual_Perc = null;
var Grid_Setpoint_Manual_W = null;
var DayAhead_PriceArray_Ct = null;
var Consump_Forecast_Wh = null;
var Solar_Forecast = null;
var Solar_Forecast_Modified = null;
var Solar_Sunrise = null;
var Solar_Sunset = null;
var DebugText = "";
var ErrorText = "";
var Solar_Today_Wh = 0;
var Solar_Remain_Wh = 0;
var Solar_Remain_Zero_Price_Wh = 0;
var Solar_Remain_VeryLow_Price_Wh = 0;
var Solar_Remain_Low_Price_Wh = 0;
var Solar_Remain_Rest_Price_Wh = 0;
var Solar_Tomorrow_Wh = 0;
var Sunrise_Hour = -1;
var Sunset_Hour = -1;
var Solar_To_Batt_Perc = 0;
var Batt_Forecast_Wh = [];
var Batt_Full_Wh = 0;
var Batt_Min_Manual_Wh = 0;
var Batt_Min_Bottom_Wh = 0;
var Batt_Now_Wh = 0;
var Batt_Free_Wh = 0;
var Batt_Max_Current_Grid_A = 0;
var Batt_Max_Current_Solar_A = 0;
var Batt_Charger_Only_Target = false;
var Energy_from_Grid_Needed_Wh = 0;
var Energy_to_Sell_Wh = 0; // when negative price comes
var Energy_for_Discharge_W = 0;
var Forecast_Horizon_Hour = 0;
var Next_High_Sell_Hour = -1;
var Next_High_Sell_Price_Ct = 0;
var Next_Cheap_Charge_Hour = -1;
var Next_Cheap_Charge_Price_Ct = 999999;
var SoC_Min_Bottom_Perc = 0;
var SoC_Min_Target_Perc = 0;
var Grid_Setpoint_Unload_W = 0;
var Grid_Setpoint_Target_W = 0;
var Max_Inverter_Power_Target_W = 0;
var Charge_Disable_Target = 0; // 1 = disabled; 0 = charging enabled
var Solar_Charger_Target = 1; // 1 = ON; 4 OFF
var Relay_2_Target = 0; // 1 = ON; 0 = Off
var msg_DayAhead_Rule = null;
var msg_Batt_Max_Current_Target_A = null;
var msg_SoC_Min_Target_Perc = null;
var msg_Grid_Setpoint_Target_W = null;
var msg_Max_Inverter_Power_Target_W = null;
var msg_Charge_Disable_Target = null;
var msg_Solar_Charger_Target = null;
var msg_Relay_2_Target = null;
function AddDebug(NewText)
DebugText += NewText;
} // AddDebug
function Not(p_Boolean)
return !p_Boolean;
function HourAsText(H)
if (Number(H) <= 23) {
return Number(H).toString();
else {
return "+" + (Number(H)-24).toString();
} // HourAsText
function MinutesRemainFactor() {
return (60 - NowMinutes) / 60;
function WhAskWhText(Wh)
if (Wh > 1000) {
return (Round(Wh/100)/10).toString() + " kWh";
else {
return Round(Wh).toString() + " Wh";
} // WhAskWhText
function kWhToWh(x)
return Round(x * 1000);
} // kWhToWh
function Round(x, dec)
if (dec == null)
{ return Math.round(x) }
else if (dec == 0)
else if (dec == 1)
{ return Math.round(x*10) / 10 }
else if (dec == 2)
{ return Math.round(x*100) / 100 }
} // Round
function IsInArrayOfPairs(p_ArrayOfPairs, p_SearchHours)
{ // See if any of the items within array p_SearchHours
// are in array p_ArrayOfPairs{hour, value]
let Result = false;
for (let i = 0; i < p_SearchHours.length; i++) {
for ( let j = 0; j < p_ArrayOfPairs.length; j++)
if ( p_ArrayOfPairs[j][0] == p_SearchHours[i] )
Result = true;
break;
} // Item was found
} // for j
if (Result) break;
} // all items
return Result; // not found
} // IsInArrayOfPairs
function ClearContext()
// Clear other reference-values
context.Last_DESS_Mode = -1;
context.Last_Solar_Sunrise = "";
context.Last_Solar_Sunset = "";
context.Last_Solar_Today_Wh = 0;
context.Last_Solar_Remain_Wh = 0;
context.Last_Solar_Tomorrow_Wh = 0;
context.Last_Batt_Forecast_Wh = -1;
context.Last_SoC_Min_Manual_Perc = -1;
context.Last_SoC_Now_Perc = -1;
context.Last_Batt_High_Value = -1;
context.Last_Batt_Low_Value = -1;
context.Last_Forecast_Horizon_Hour = -1;
context.Last_Next_High_Sell_Hour = -1;
context.Last_Next_Cheap_Charge_Hour = -1;
context.Last_Energy_from_Grid_to_Stay_Above_Minimum_Wh = -100;
context.Last_Energy_from_Grid_to_Full_at_Sunset_Today_Wh = -1;
context.Last_Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh = -1;
context.Last_Energy_to_Sell_Wh = -1;
context.Last_SoC_Min_Target_Perc = -1;
context.Last_Batt_Max_Current_Grid_A = -2;
context.Last_Batt_Max_Current_Solar_A = -2;
context.Last_Batt_Max_Current_Target_A = -2;
context.last_Max_Inverter_Power_Target_W = -2;
context.Last_Batt_Charger_Only_Target = false;
context.Last_Grid_Setpoint_Target_W = -2;
context.Last_Charge_Disable_Target = -1;
context.Last_Solar_Charger_Target = -1;
context.Last_Relay_2_Target = -1;
context.Last_DayAheadRule = "";
} // ClearContext
function Verify_External_Data()
let ErrText = "";
let Result = true;
if (context.Energy_from_Solar_Now_W == null)
{ ErrText += "context.Energy_from_Solar_Now_W \r";
Result = false;
// From Flow DayAhead
if (context.HighPriceArray == null)
{ ErrText += "context.HighPriceArray \r";
Result = false;
if (context.LowPriceArray == null)
{ ErrText += "context.LowPriceArray \r";
Result = false;
if (context.VeryLowPriceArray == null)
{ ErrText += "context.VeryLowPriceArray \r";
Result = false;
if (context.ZeroPriceArray == null)
{ ErrText += "context.ZeroPriceArray \r";
Result = false;
if (context.NegativePriceArray == null)
{ ErrText += "context.NegativePriceArray \r";
Result = false;
// Victron States
if (context.DESS_Mode == null)
{ ErrText += "context.DESS_Mode \r";
Result = false;
if (context.SoC_Now_Perc == null)
{ ErrText += "context.SoC_Now_Perc \r";
Result = false;
if (context.SoC_Min_Venus == null)
{ ErrText += "context.SoC_Min_Venus \r";
Result = false;
if (context.Max_Charge_Voltage_V == null)
{ ErrText += "context.Max_Charge_Voltage_V \r";
Result = false;
if (context.Max_Charge_Current_A == null)
{ ErrText += "context.Max_Charge_Current_A \r";
Result = false;
if (context.Grid_Setpoint_W == null)
{ ErrText += "context.Grid_Setpoint_W \r";
Result = false;
if (context.Charge_Disable == null)
{ ErrText += "context.Charge_Disable \r";
Result = false;
if (context.Solar_Charger == null)
{ ErrText += "context.Solar_Charger \r";
Result = false;
if (context.Relay_2 == null)
{ ErrText += "context.Relay_2 \r";
Result = false;
if (context.Grid_to_Batt_Limit_A == null)
{ ErrText += "Grid_to_Batt_Limit_A \r";
Result = false;
if (Grid_Setpoint_Manual_W != null)
{ ErrText += "Grid_Setpoint_Manual_W \r";
Result = false;
if (Solar_Forecast != null)
{ ErrText += "Solar_Forecast \r";
Result = false;
if (Solar_Sunrise != null)
{ ErrText += "Solar_Sunrise \r";
Result = false;
if (Solar_Sunset != null)
{ ErrText += "Solar_Sunset \r";
Result = false;
if (context.Max_Inverter_Power_W == null)
{ ErrText += "Max_Inverter_Power_W \r";
Result = false;
if (ErrText > "")
{ node.warn("Missing Data: \r" + ErrText);
return Result;
} // Verify_External_Data
function GlobalGetAll()
let Result = true;
// Get general settings
SoC_Min_Manual_Perc = global.get("Victron_MESS.Manual.SoC_Min_Perc");
if (SoC_Min_Manual_Perc == null) {
node.warn("Victron_MESS.Manual.SoC_Min_Perc: null");
Result = false;
SoC_Min_Bottom_Perc = Math.min(15, SoC_Min_Manual_Perc);
Grid_Setpoint_Manual_W = global.get("Victron_MESS.Manual.Grid_Setpoint");
if (Grid_Setpoint_Manual_W == null) {
node.warn("Victron_MESS.Manual.Grid_Setpoint: null");
Result = false;
Consump_Forecast_Wh = global.get("Victron_MESS.Consump.Forecast");
if (Consump_Forecast_Wh == null) {
ErrorText += "Victron_MESS.Consump.Forecast: null" + "\r";
Result = false;
Solar_Forecast = global.get("Victron_MESS.Solar.Forecast.All");
if (Solar_Forecast == null) {
ErrorText += "Victron_MESS.Solar.Forecast.All: null" + "\r";
Result = false;
Solar_Forecast_Modified = global.get("Victron_MESS.Solar.Forecast.Modified");
if (Solar_Forecast_Modified == null) {
ErrorText += "Victron_MESS.Solar.Forecast.Modified: null" + "\r";
Result = false;
Solar_Sunrise = global.get("Victron_MESS.Solar.Sunrise");
if (Solar_Sunrise == null) {
ErrorText += "Victron_MESS.Solar.Sunrise: null" + "\r";
Result = false;
Solar_Sunset = global.get("Victron_MESS.Solar.Sunset");
if (Solar_Sunset == null) {
ErrorText += "Victron_MESS.Solar.Sunset: null" + "\r";
Result = false;
DayAhead_PriceArray_Ct = global.get("Victron_MESS.DayAhead.PriceArray_Ct");
if (DayAhead_PriceArray_Ct == null) {
ErrorText += "Victron_MESS.DayAhead.PriceArray_Ct: null" + "\r";
Result = false;
if (ErrorText > "")
{ node.warn("GlobalGetAll: " + ErrorText);
return Result;
} // GlobalGetAll
function SolarSetSunriseAndSunsetHours()
// Find Sunrise and Sunset
if (TraceOn) node.warn("SolarSetSunriseAndSunsetHours...");
Sunrise_Hour = Number(Solar_Sunrise.substring(0,2)) + 1;
Sunset_Hour = Number(Solar_Sunset.substring(0,2));
if ( (context.Last_Solar_Sunrise != Solar_Sunrise)
|| (context.Last_Solar_Sunset != Solar_Sunset) )
AddDebug("Daylight: "
+ Solar_Sunrise + " - " + Solar_Sunset + "\r");
context.Last_Solar_Sunrise = Solar_Sunrise;
context.Last_Solar_Sunset = Solar_Sunset;
} // SolarSetSunriseAndSunsetHours
function SolarMakeForecasts()
// Calculate Solar Forecast per Hour
if (TraceOn) node.warn("SolarMakeForecasts...");
for (let H = 0; H <= 23; H++) {
Solar_Today_Wh += Solar_Forecast_Modified[H];
// Add Remainder of current Hour
Solar_Remain_Wh +=
Round(Solar_Forecast_Modified[NowHour] * MinutesRemainFactor());
// Startvalue(s)
if ( IsZeroPrice(NowHour) ) {
Solar_Remain_Zero_Price_Wh = Solar_Remain_Wh;
else if ( IsVeryLowPrice(NowHour) ) {
Solar_Remain_VeryLow_Price_Wh = Solar_Remain_Wh;
else if ( IsAnyLowPrice(NowHour) ) {
Solar_Remain_Low_Price_Wh = Solar_Remain_Wh;
else {
Solar_Remain_Rest_Price_Wh = Solar_Remain_Wh;
for (let H = NowHour+1; H <= 23; H++) {
Solar_Remain_Wh += Solar_Forecast_Modified[H];
// what part of Solar has low price
if ( IsZeroPrice(H) ) {
Solar_Remain_Zero_Price_Wh += Solar_Forecast_Modified[H];
else if ( IsVeryLowPrice(H) ) {
Solar_Remain_VeryLow_Price_Wh += Solar_Forecast_Modified[H];
else if ( IsAnyLowPrice(H) ) {
Solar_Remain_Low_Price_Wh += Solar_Forecast_Modified[H];
else {
Solar_Remain_Rest_Price_Wh += Solar_Forecast_Modified[H];
} // Next Hour until midnight
if ( (Round(context.Last_Solar_Today_Wh / 100)
!= Round(Solar_Today_Wh / 100))
|| (Round(context.Last_Solar_Remain_Wh / 100)
!= Round(Solar_Remain_Wh / 100) ) )
AddDebug("Solar:");
if (Solar_Remain_Zero_Price_Wh > 0)
AddDebug(" zero: ");
AddDebug(WhAskWhText(Solar_Remain_Zero_Price_Wh));
if (Solar_Remain_VeryLow_Price_Wh > 0)
AddDebug(" very_low: ");
AddDebug(WhAskWhText(Solar_Remain_VeryLow_Price_Wh));
if (Solar_Remain_Low_Price_Wh > 0)
AddDebug(" low: ");
AddDebug(WhAskWhText(Solar_Remain_Low_Price_Wh));
if (Solar_Remain_Rest_Price_Wh > 0)
AddDebug(" rest: ");
AddDebug(WhAskWhText(Solar_Remain_Rest_Price_Wh));
AddDebug(" / ");
AddDebug(WhAskWhText(Solar_Today_Wh) + "\r");
context.Last_Solar_Today_Wh = Solar_Today_Wh;
context.Last_Solar_Remain_Wh = Solar_Remain_Wh;
for (let H = 24; H < Solar_Forecast.length; H++)
Solar_Tomorrow_Wh += Solar_Forecast_Modified[H];
if ( Round(context.Last_Solar_Tomorrow_Wh / 100)
!= Round(Solar_Tomorrow_Wh / 100) )
AddDebug("Solar Tomorrow: ");
AddDebug(WhAskWhText(Solar_Tomorrow_Wh));
AddDebug("\r");
context.Last_Solar_Tomorrow_Wh = Solar_Tomorrow_Wh;
} // SolarMakeForecasts
function BatteryCalculateLevels()
// Calculate Expected Battery energy-levels
// without charging from Grid
if (TraceOn) node.warn("BatteryCalculateLevels...");
Batt_Full_Wh =
Round(Batt_Capacity_Wh * SoC_Full_Perc / 100);
Batt_Now_Wh =
Round(Batt_Capacity_Wh * context.SoC_Now_Perc / 100);
Batt_Free_Wh = Batt_Full_Wh - Batt_Now_Wh;
Round(Batt_Capacity_Wh * SoC_Min_Manual_Perc / 100);
Round(Batt_Capacity_Wh * SoC_Min_Bottom_Perc / 100);
for (let H = 0; H < Solar_Forecast_Modified.length; H++) {
Batt_Forecast_Wh[H] = 0; // initialise
Batt_Forecast_Wh[NowHour] =
Math.min(Batt_Full_Wh, // full is full
Round( Batt_Now_Wh
+ Solar_Forecast_Modified[NowHour] * MinutesRemainFactor()
- Consump_Forecast_Wh[NowHour] * MinutesRemainFactor()
for (let H = NowHour+1; H < Solar_Forecast_Modified.length; H++)
if (H <= 23) { // today, modified Solar
Round(Batt_Forecast_Wh[H-1]
+ Solar_Forecast_Modified[H]
- Consump_Forecast_Wh[H] ) );
else { // tomorrow, forecast Solar
+ Solar_Forecast[H]
} // calculate Battery Forecast per Hour
global.set("Victron_MESS.Battery.Forecast", Batt_Forecast_Wh);
let Batt_Low_Value = Batt_Forecast_Wh[NowHour];
let Batt_Low_Hour = Batt_Forecast_Wh.length;
let Batt_Low_Hour_Text = "";
let Batt_High_Value = Batt_Forecast_Wh[NowHour];
let Batt_High_Hour = Batt_Forecast_Wh.length;
let Batt_High_Hour_Text = "";
for (let H = Batt_Forecast_Wh.length; H >= NowHour; H--)
if (Batt_Forecast_Wh[H] <= Batt_Low_Value)
Batt_Low_Value = Batt_Forecast_Wh[H];
Batt_Low_Hour = H; // end of this hour
if (Batt_Forecast_Wh[H] >= Batt_High_Value)
Batt_High_Value = Batt_Forecast_Wh[H];
Batt_High_Hour = H; // end of this hour
Batt_Low_Hour_Text = HourAsText(Batt_Low_Hour) + ":59: ";
Batt_High_Hour_Text = HourAsText(Batt_High_Hour) + ":59: ";
if (context.Last_SoC_Min_Manual_Perc != SoC_Min_Manual_Perc)
AddDebug("Batt_Capacity: ");
AddDebug(WhAskWhText(Batt_Capacity_Wh) + "\r");
AddDebug("SoC_Perc_Min_Manual: ");
AddDebug(SoC_Min_Manual_Perc + "% (");
AddDebug(WhAskWhText(Batt_Min_Manual_Wh) + ")\r");
AddDebug("SoC_Perc_Min_Bottom: ");
AddDebug(SoC_Min_Bottom_Perc + "% (");
AddDebug(WhAskWhText(Batt_Min_Bottom_Wh) + ")\r");
context.Last_SoC_Min_Manual_Perc = SoC_Min_Manual_Perc;
if ( context.Last_SoC_Now_Perc != context.SoC_Now_Perc )
AddDebug("SoC_Perc_Now: ");
AddDebug(context.SoC_Now_Perc + "% (");
AddDebug(WhAskWhText(Batt_Now_Wh) + ")\r");
context.Last_SoC_Now_Perc = context.SoC_Now_Perc;
if ( Round(context.Last_Batt_Low_Value / 100)
!= Round(Batt_Low_Value / 100) )
AddDebug("Forecast_Low at ");
AddDebug(Batt_Low_Hour_Text);
AddDebug(WhAskWhText(Batt_Low_Value) + " (");
AddDebug(Round(Batt_Low_Value / Batt_Capacity_Wh * 100) + "%)" + "\r");
context.Last_Batt_Low_Value = Batt_Low_Value;
if ( Round(context.Last_Batt_High_Value / 100)
!= Round(Batt_High_Value / 100))
AddDebug("Forecast_High at ");
AddDebug(Batt_High_Hour_Text);
AddDebug(WhAskWhText(Batt_High_Value) + " (");
AddDebug(Round(Batt_High_Value / Batt_Capacity_Wh * 100) + "%)" + "\r");
context.Last_Batt_High_Value = Batt_High_Value;
// Find Hour 'Horizon' that Battery can stay above
// Minimum without charging from Grid
// This is the last Hour that can be used to find
// High and Low Hours
for (let H = NowHour; H < Solar_Forecast_Modified.length; H++)
if (Batt_Forecast_Wh[H] < Batt_Min_Bottom_Wh)
{ break}
Forecast_Horizon_Hour = H;
if (context.Last_Forecast_Horizon_Hour != Forecast_Horizon_Hour)
AddDebug("Forecast_Horizon: ");
AddDebug(HourAsText(Forecast_Horizon_Hour));
AddDebug(" hr \r");
context.Last_Forecast_Horizon_Hour = Forecast_Horizon_Hour;
} // BatteryCalculateLevels
function CalculateEnergyToFullSoC()
// What energy is needed from Grid to full SoC
// today at Sunset or possibly tomorrow
// this is usefull during daytime until sunset
if (TraceOn) node.warn("CalculateEnergyToFullSoC...");
let Energy_from_Grid_to_Full_at_Sunset_Today_Wh = 0;
let Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh = 0;
let Energy_from_Grid_to_Stay_Above_Minimum_Wh = 0;
// See what charging is minimal needed to stay above minimum SoC
// This is probably usefull during the night, until sunrise.
let Batt_Level_Wh = Batt_Now_Wh;
Batt_Level_Wh =
Math.min(Batt_Level_Wh,
Round(Batt_Now_Wh
let Next_Minimum_Hour = 0
for (Next_Minimum_Hour = NowHour+1;
Next_Minimum_Hour <= Forecast_Horizon_Hour;
Next_Minimum_Hour++)
Batt_Level_Wh =
Round(Batt_Level_Wh
+ Solar_Forecast_Modified[Next_Minimum_Hour]
- Consump_Forecast_Wh[Next_Minimum_Hour]
if (Solar_Forecast_Modified[Next_Minimum_Hour]
> Consump_Forecast_Wh[Next_Minimum_Hour])
break;
Math.max(0, Batt_Min_Manual_Wh - Batt_Level_Wh);
if ( Round(context.Last_Energy_from_Grid_to_Stay_Above_Minimum_Wh / 100)
!= Round(Energy_from_Grid_to_Stay_Above_Minimum_Wh / 100) )
AddDebug("Grid: Stay Above Minimum: "
+ WhAskWhText(Energy_from_Grid_to_Stay_Above_Minimum_Wh) + "\r");
= Energy_from_Grid_to_Stay_Above_Minimum_Wh;
Energy_from_Grid_to_Full_at_Sunset_Today_Wh = Batt_Full_Wh;
for (let H = NowHour; H < Sunset_Hour; H++) {
Math.min(Energy_from_Grid_to_Full_at_Sunset_Today_Wh,
Batt_Full_Wh - Batt_Forecast_Wh[H]);
Math.max(0, Energy_from_Grid_to_Full_at_Sunset_Today_Wh);
if (context.Last_Energy_from_Grid_to_Full_at_Sunset_Today_Wh
!= Energy_from_Grid_to_Full_at_Sunset_Today_Wh)
AddDebug("Grid: Full at Sunset Today: "
+ WhAskWhText(Energy_from_Grid_to_Full_at_Sunset_Today_Wh) + "\r");
Energy_from_Grid_to_Full_at_Sunset_Today_Wh;
Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh = Batt_Full_Wh;
for (let H = NowHour; H < Sunset_Hour+24; H++) {
Math.min(Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh,
Math.max(0, Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh);
if (context.Last_Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh
!= Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh)
AddDebug("Grid: Full at Sunset Tomorrow: "
+ WhAskWhText(Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh) + "\r");
Energy_from_Grid_to_Full_at_Sunset_Tomorrow_Wh;
Math.max(Energy_from_Grid_to_Stay_Above_Minimum_Wh,
} // CalculateEnergyToFullSoC
function IsNegativePrice(p_Hour)
return ( IsInArrayOfPairs(context.NegativePriceArray, [p_Hour]) )
} // IsNegativePrice
function IsZeroPrice(p_Hour)
return ( IsInArrayOfPairs(context.ZeroPriceArray, [p_Hour]) )
} // IsZeroPrice
function IsVeryLowPrice(p_Hour)
return ( IsInArrayOfPairs(context.VeryLowPriceArray, [p_Hour]) )
} // IsVeryLowPrice
function IsAnyLowPrice(p_Hour)
let Result = false;
if (IsVeryLowPrice(p_Hour) )
{ Result = true }
else if (IsZeroPrice(p_Hour) )
{ Result = true }
else if (IsNegativePrice(p_Hour) )
{ Result = true }
else if ( IsInArrayOfPairs(context.LowPriceArray, [p_Hour]) )
{ Result = true }
return Result;
} // IsAnyLowPrice
function IsHighPrice(p_Hour)
return ( IsInArrayOfPairs(context.HighPriceArray, [p_Hour]) )
} // IsHighPrice
function NegativePriceHourByIdx(p_Idx)
let Result = -1;
if (context.NegativePriceArray[p_Idx] != null)
Result = context.NegativePriceArray[p_Idx][0];
return Result;
function NegativePriceIdxByHour(p_Hour)
let Result = -1;
for (let H = 0; H < context.NegativePriceArray.length; H++)
if (context.NegativePriceArray[H][0] == p_Hour)
Result = H;
break;
return Result;
} // NegativePriceIdxByHour
function ZeroPriceHourByIdx(p_Idx)
let Result = -1;
if (context.ZeroPriceArray[p_Idx] != null)
Result = context.ZeroPriceArray[p_Idx][0];
return Result;
function ZeroPriceIdxByHour(p_Hour)
let Result = -1;
for (let H = 0; H < context.ZeroPriceArray.length; H++)
if (context.ZeroPriceArray[H][0] == p_Hour)
Result = H;
break;
return Result;
} // ZeroPriceIdxByHour
function LowPriceHourByIdx(p_Idx)
let Result = -1;
if (context.LowPriceArray[p_Idx] != null)
Result = context.LowPriceArray[p_Idx][0];
return Result;
function LowPriceIdxByHour(p_Hour)
let Result = -1;
for (let H = 0; H < context.LowPriceArray.length; H++)
if (context.LowPriceArray[H][0] == p_Hour)
Result = H;
break;
return Result;
} // LowPriceIdxByHour
function VeryLowPriceHourByIdx(p_Idx)
let Result = -1;
if (context.VeryLowPriceArray[p_Idx] != null)
Result = context.VeryLowPriceArray[p_Idx][0];
return Result;
function VeryLowPriceIdxByHour(p_Hour)
let Result = -1;
for (let H = 0; H < context.VeryLowPriceArray.length; H++)
if (context.VeryLowPriceArray[H][0] == p_Hour)
Result = H;
break;
return Result;
} // VeryLowPriceIdxByHour
function FindCheapChargeHour()
if (TraceOn) node.warn("FindCheapChargeHour...");
for (let H = NowHour; H <= Forecast_Horizon_Hour; H++)
if ( IsNegativePrice(H) )
Next_Cheap_Charge_Hour = H;
DayAhead_PriceArray_Ct[Next_Cheap_Charge_Hour];
break;
else if ( IsZeroPrice(H) )
break;
break;
else if (DayAhead_PriceArray_Ct[H]
< Next_Cheap_Charge_Price_Ct)
} // try all hours
// See if two, resp. three or more hours are needed to charge
// possible start one hour earlier with charging
if ( (context.SoC_Now_Perc < 70)
&& (Next_Cheap_Charge_Hour > NowHour)
&& (context.NegativePriceArray.length <= 1)
&& (context.ZeroPriceArray.length <= 1)
&& (context.VeryLowPriceArray.length <= 1)
&& (IsAnyLowPrice(Next_Cheap_Charge_Hour-1) )
Next_Cheap_Charge_Hour -= 1; // one hour earlier
if ( (context.SoC_Now_Perc < 40)
&& (context.NegativePriceArray.length <= 2)
&& (context.ZeroPriceArray.length <= 2)
&& (context.VeryLowPriceArray.length <= 2)
Next_Cheap_Charge_Hour -= 1; // another hour earlier
if (context.Last_Next_Cheap_Charge_Hour != Next_Cheap_Charge_Hour)
AddDebug("Next_Cheap_Charge_Hour: ");
AddDebug(HourAsText(Next_Cheap_Charge_Hour));
AddDebug(" = ");
AddDebug(Next_Cheap_Charge_Price_Ct + " ct");
AddDebug("\r");
context.Last_Next_Cheap_Charge_Hour = Next_Cheap_Charge_Hour;
} // FindCheapChargeHour
function FindHighSellHour()
if (TraceOn) node.warn("FindHighSellHour...");
for (let H = NowHour; H < Next_Cheap_Charge_Hour; H++)
if (DayAhead_PriceArray_Ct[H] * Conversion_Loss_Factor >
( Next_Cheap_Charge_Price_Ct / Conversion_Loss_Factor
+ Sell_Price_Limit_Ct)
if (DayAhead_PriceArray_Ct[H] > Next_High_Sell_Price_Ct)
Next_High_Sell_Hour = H;
Next_High_Sell_Price_Ct = DayAhead_PriceArray_Ct[H];
if (context.Last_Next_High_Sell_Hour != Next_High_Sell_Hour)
AddDebug("Next_High_Sell_Hour: ");
AddDebug(HourAsText(Next_High_Sell_Hour) + " hr = ");
AddDebug(Next_High_Sell_Price_Ct);
AddDebug(" ct\r");
context.Last_Next_High_Sell_Hour = Next_High_Sell_Hour;
} // FindHighSellHour
function FindEnergyToSell()
// best, discharge at high prices, but not to much
if (TraceOn) node.warn("FindEnergyToSell...");
// This is now available
Energy_to_Sell_Wh =
Batt_Capacity_Wh * context.SoC_Now_Perc / 100;
// a minimum should remain
Energy_to_Sell_Wh -=
Math.floor(Batt_Full_Wh * SoC_Min_Manual_Perc / 100);
// Minus Consumption plus Solar
if (Next_Cheap_Charge_Hour > NowHour)
// This hour proportionally
// Changes in the next hours
for (let H = NowHour+1; H < Next_Cheap_Charge_Hour; H++)
Energy_to_Sell_Wh =
Math.min(Energy_to_Sell_Wh,
Energy_to_Sell_Wh
+ Solar_Forecast_Modified[H]);
// before Solar is ready, consumption comes first
Energy_to_Sell_Wh -= Consump_Forecast_Wh[Next_Cheap_Charge_Hour];
// Value can't be negative
Energy_to_Sell_Wh =
Math.max(0, Energy_to_Sell_Wh);
// node.warn(Energy_to_Sell_Wh);
if (context.Last_Energy_to_Sell_Wh != Energy_to_Sell_Wh)
AddDebug("Energy Available to Sell: ");
AddDebug(WhAskWhText(Energy_to_Sell_Wh) + "\r");
context.Last_Energy_to_Sell_Wh = Energy_to_Sell_Wh;
} // if there comes a Low Charge Hour
} // FindEnergyToSell
function NegativePriceComes()
if (TraceOn) node.warn("NegativePriceComes...");
let Result = false;
if ( IsNegativePrice(NowHour) )
Result = false;
else if (IsInArrayOfPairs(context.NegativePriceArray,
[ NowHour+1, NowHour+2, NowHour+3, NowHour+4,
NowHour+5, NowHour+6, NowHour+7, NowHour+8,
NowHour+9, NowHour+10, NowHour+11, NowHour+12] )
Result = true;
return Result
} // NegativePriceComes
function ZeroPriceComes()
if (TraceOn) node.warn("ZeroPriceComes...");
let Result = false;
Result = false;
else if (IsInArrayOfPairs(context.ZeroPriceArray,
Result = true;
return Result
} // ZeroPriceComes
function VeryLowPriceComes()
if (TraceOn) node.warn("VeryLowPriceComes...");
let Result = false;
Result = false;
else if (IsInArrayOfPairs(context.VeryLowPriceArray,
Result = true;
return Result
} // VeryLowPriceComes
function SetSolarAvailable()
if (TraceOn) node.warn("SetSolarAvailable...");
let Result = false;
DayAheadRule = "\rSolar";
if (context.Energy_from_Solar_Now_W > 0)
Solar_To_Batt_Perc = Solar_Charge_Perc; // max perc to use for charging
+ Solar_Remain_VeryLow_Price_Wh
+ Solar_Remain_Low_Price_Wh > Batt_Free_Wh)
{ // Low Price Solar is enough for charging
if ( Not(IsAnyLowPrice(NowHour)) )
{ // Now is NOT a low price
Solar_To_Batt_Perc = 2; // use only x% of Solar
} // if Solar Low Price is enough
DayAheadRule += ", use " + Solar_To_Batt_Perc + "%";
Result = true;
} // if Solar available
Round( Solar_To_Batt_Perc / 100
* context.Energy_from_Solar_Now_W
/ context.Max_Charge_Voltage_V);
DayAheadRule += " Remain: " + WhAskWhText(Solar_Remain_Wh);
DayAheadRule += ", +:" + WhAskWhText(Solar_Tomorrow_Wh);
DayAheadRule += ".";
if (TraceOn) node.warn("SetSolarAvailable: " + Result);
return Result;
} // SetSolarAvailable
function TryRule_DESS()
if (TraceOn) node.warn("TryRule_DESS...");
let Result = false;
if (context.DESS_Mode != 0)
DayAheadRule += " DESS Mode " + context.DESS_Mode + ".";
SoC_Min_Target_Perc = SoC_Min_Manual_Perc;
// Batt_Max_Current_Grid_A = -1;
// Batt_Max_Current_Solar_A = 0;
Result = true;
if (TraceOn) node.warn("TryRule_DESS: " + Result);
return Result;
} // TryRule_DESS
function TryRule_FinishLowSoCCharging()
if (TraceOn) node.warn("TryRule_FinishLowSoCCharging...");
let Result = false;
if (NowInSeconds < context.Batt_Grid_End_Time)
DayAheadRule += " Finish Low SoC Charging.";
SoC_Min_Target_Perc = SoC_Min_Bottom_Perc;
Result = true;
} // Finish Low SoC Charging
if (TraceOn) node.warn("TryRule_FinishLowSoCCharging: " + Result);
return Result;
} // TryRule_FinishLowSoCCharging
function TryRule_SoCBelowBottom()
if (TraceOn) node.warn("TryRule_SoCBelowBottom...");
let Result = false;
// SoC is below ultimate minimum
if (context.SoC_Now_Perc < SoC_Min_Bottom_Perc)
DayAheadRule += " SoC much to low ("
+ context.SoC_Now_Perc + "<" + SoC_Min_Bottom_Perc + ").";
// Charge at least 5 minutes
context.Batt_Grid_End_Time = NowInSeconds + 300;
DayAheadRule += " Charge from Grid.";
Result = true;
} // SoC is below ultimate minimum
if (TraceOn) node.warn("TryRule_SoCBelowBottom: " + Result);
return Result;
} // TryRule_SoCBelowBottom
function TryRule_SellHighPrice()
if (TraceOn) node.warn("TryRule_SellHighPrice...");
let Result = false;
// possible discharge for high price
// and charge later for low price
if ( (NowHour == Next_High_Sell_Hour)
&& (Energy_to_Sell_Wh > 0)
DayAheadRule += " High Sell Hour.";
// do not charge
DayAheadRule += " Sell ";
DayAheadRule += WhAskWhText(Energy_to_Sell_Wh);
DayAheadRule += " at ";
DayAheadRule += Round(DayAhead_PriceArray_Ct[NowHour], 1);
DayAheadRule += " ct. ";
DayAheadRule += " Re-charge after ";
DayAheadRule += HourAsText(Next_Cheap_Charge_Hour);
DayAheadRule += " hr. ";
DayAheadRule += Round(Next_Cheap_Charge_Price_Ct, 1);
-Math.max(200,
Math.min(Grid_Setpoint_W_Limit,
Round(Energy_to_Sell_Wh / MinutesRemainFactor() )
); // note the minus-sign: negative value
Result = true;
} // Discharge at High price for later Charge at Low price
if (TraceOn) node.warn("TryRule_SellHighPrice: " + Result);
return Result;
} // TryRule_SellHighPrice
[ Voor 220% gewijzigd door MJ de Bruijn op 14-05-2024 14:26 ]
Een mens leert van zijn fouten. Ik heb in mijn leven heel veel geleerd.
  • MJ de Bruijn
Deel 4 van de Flow "Targets"
In verband met de gelimiteerde ruimte in een post is de JavaScript tekst van functie "Calculate Targets" hier separaat opgenomen. Deel een staat in de voorgaande post.
Dit is het tweede deel.
function TryRule_NegativePriceWait()
if (TraceOn) node.warn("TryRule_NegativePriceWait...");
let Result = false;
// Wait for negative price
if ( NegativePriceComes() )
if (context.NegativePriceArray.length >= 3)
DayAheadRule += " Wait for negative-negative-negative price.";
Result = true;
else if ( (context.NegativePriceArray.length == 2)
&& (context.SoC_Now_Perc >= 40)
DayAheadRule += " Wait for negative-negative price.";
Result = true;
&& (NegativePriceHourByIdx(0) < ZeroPriceHourByIdx(0) )
&& (NegativePriceHourByIdx(1) < ZeroPriceHourByIdx(0) )
DayAheadRule += " Wait for negative-negative-zero price.";
Result = true;
&& (NegativePriceHourByIdx(0) > ZeroPriceHourByIdx(0) )
&& (NegativePriceHourByIdx(1) > ZeroPriceHourByIdx(0) )
DayAheadRule += " Wait for zero-negative-negative price.";
Result = true;
&& (NegativePriceHourByIdx(0) < VeryLowPriceHourByIdx(0) )
&& (NegativePriceHourByIdx(1) < VeryLowPriceHourByIdx(0) )
DayAheadRule += " Wait for negative-negative-very_low price.";
Result = true;
&& (NegativePriceHourByIdx(0) < LowPriceHourByIdx(0) )
&& (NegativePriceHourByIdx(1) < LowPriceHourByIdx(0) )
DayAheadRule += " Wait for negative-negative-low price.";
Result = true;
else if ( (context.NegativePriceArray.length == 1)
&& (context.SoC_Now_Perc >= 70)
DayAheadRule += " Wait for negative price.";
Result = true;
&& (NegativePriceHourByIdx(0) < ZeroPriceHourByIdx(1) )
DayAheadRule += " Wait for negative-zero-zero price.";
Result = true;
&& (NegativePriceHourByIdx(0) < VeryLowPriceHourByIdx(1) )
DayAheadRule += " Wait for negative-very_low-very_low price.";
Result = true;
&& (NegativePriceHourByIdx(0) < LowPriceHourByIdx(1) )
DayAheadRule += " Wait for negative-low-low price.";
Result = true;
DayAheadRule += " Wait for negative-zero-very_low price.";
Result = true;
DayAheadRule += " Wait for negative-zero-low price.";
Result = true;
DayAheadRule += " Wait for negative-very_low-low price.";
Result = true;
else
DayAheadRule += " Negative prices alone are not enough.";
if (Result)
} // Wait for negative prices
if (TraceOn) node.warn("TryRule_NegativePriceWait: " + Result);
return Result;
} // TryRule_NegativePriceWait
function TryRule_NegativePriceNow()
if (TraceOn) node.warn("TryRule_NegativePriceNow...");
let Result = false
SoC_Min_Target_Perc = SoC_Full_Perc;
// Charge only in the hours with most negative prices
// for the highest revenues
if (NegativePriceIdxByHour(NowHour) == 0)
{ // Lowest hour, always charge
DayAheadRule += " Most Negative Price: Charge.";
else if ( (NegativePriceIdxByHour(NowHour) == 1)
&& (context.SoC_Now_Perc < 70)
{ // need at least two charge-hours, so start
DayAheadRule += " Second Negative Price: Charge.";
else if ( (NegativePriceIdxByHour(NowHour) == 2)
&& (context.SoC_Now_Perc < 40)
DayAheadRule += " Third Negative Price: Charge.";
else if ( Not(IsInArrayOfPairs(context.NegativePriceArray,
[NowHour+1, NowHour+2, NowHour+3] ) )
DayAheadRule += " Any Negative Price: Charge.";
else
DayAheadRule += " Negative Price: Wait for lower price.";
Batt_Charger_Only_Target = true;
Solar_Charger_Target = 4; // OFF
Relay_2_Target = 1; // Relay ON = PV Off
Result = true;
} // Price is Negative now
if (TraceOn) node.warn("TryRule_NegativePriceNow: " + Result);
return Result;
} // TryRule_NegativePriceNow
function TryRule_ZeroPriceWait()
if (TraceOn) node.warn("TryRule_ZeroPriceWait...");
let Result = false;
if ( ZeroPriceComes() )
if (Solar_Remain_Zero_Price_Wh > Batt_Free_Wh)
DayAheadRule += " Wait for Solar at zero price.";
Result = true;
else if (context.ZeroPriceArray.length >= 3)
DayAheadRule += " Wait for zero-zero-zero price.";
Result = true;
else if ( (context.ZeroPriceArray.length == 2)
DayAheadRule += " Wait for zero-zero price.";
Result = true;
&& (ZeroPriceHourByIdx(0) < VeryLowPriceHourByIdx(0) )
&& (ZeroPriceHourByIdx(1) < VeryLowPriceHourByIdx(0) )
DayAheadRule += " Wait for zero-zero-very_low price.";
Result = true;
&& (ZeroPriceHourByIdx(0) < LowPriceHourByIdx(0) )
&& (ZeroPriceHourByIdx(1) < LowPriceHourByIdx(0) )
DayAheadRule += " Wait for zero-zero-low price.";
Result = true;
else if ( (context.ZeroPriceArray.length == 1)
&& (context.SoC_Now_Perc >= 70) )
DayAheadRule += " Wait for zero price.";
Result = true;
&& (ZeroPriceHourByIdx(0) < VeryLowPriceHourByIdx(1) )
DayAheadRule += " Wait for zero-very_low-very_low price.";
Result = true;
&& (ZeroPriceHourByIdx(0) < LowPriceHourByIdx(1) )
DayAheadRule += " Wait for zero-low-low price.";
Result = true;
DayAheadRule += " Wait for zero-very_low-low price.";
Result = true;
else
DayAheadRule += " Zero prices are not enough.";
if (Result)
} // Wait for zero prices
if (TraceOn) node.warn("TryRule_ZeroPriceWait: " + Result);
return Result;
} // TryRule_ZeroPriceWait
function TryRule_ZeroPriceNow()
if (TraceOn) node.warn("TryRule_ZeroPriceNow...");
let Result = false;
if (ZeroPriceIdxByHour(NowHour) == 0)
DayAheadRule += " Zero Price.";
Result = true;
else if (Solar_Remain_Zero_Price_Wh > Batt_Free_Wh)
DayAheadRule += " Zero price: Solar is enough.";
Result = true;
else if ( (ZeroPriceIdxByHour(NowHour) == 1)
DayAheadRule += " Zero-zero Price: Solar not enough.";
Result = true;
else if ( (ZeroPriceIdxByHour(NowHour) == 2)
DayAheadRule += " Zero-zero-zero Price: Solar not enough.";
Result = true;
else if ( Not(IsInArrayOfPairs(context.ZeroPriceArray,
DayAheadRule += " Charge: Any Zero Price.";
Result = true;
else
DayAheadRule += " Wait for other zero prices.";
Result = true;
} // Zero price now
if (TraceOn) node.warn("TryRule_ZeroPriceNow: " + Result);
return Result;
} // TryRule_ZeroPriceNow
function TryRule_VeryLowPriceWait()
if (TraceOn) node.warn("TryRule_VeryLowPriceWait...");
let Result = false;
if ( VeryLowPriceComes() )
+ Solar_Remain_VeryLow_Price_Wh > Batt_Free_Wh)
DayAheadRule += " Wait for Solar at very_low price.";
Result = true;
if (context.VeryLowPriceArray.length >= 3)
DayAheadRule += " Wait for very_low-very_low-very_low price.";
Result = true;
if ( (context.VeryLowPriceArray.length == 2)
DayAheadRule += " Wait for very_low-very_low price.";
Result = true;
&& (VeryLowPriceHourByIdx(0) < LowPriceHourByIdx(0) )
&& (VeryLowPriceHourByIdx(1) < LowPriceHourByIdx(0) )
DayAheadRule += " Wait for very_low-very_low-low price.";
Result = true;
if ( (context.VeryLowPriceArray.length == 1)
DayAheadRule += " Wait for very_low price.";
Result = true;
&& (VeryLowPriceHourByIdx(0) < LowPriceHourByIdx(1) )
DayAheadRule += " Wait for very_low-low-low price.";
Result = true;
if (Result)
} // Wait for very_low price
if (TraceOn) node.warn("TryRule_VeryLowPriceWait: " + Result);
return Result;
} // TryRule_VeryLowPriceWait
function TryRule_VeryLowPriceNow()
if (TraceOn) node.warn("TryRule_VeryLowPriceNow...");
let Result = false;
DayAheadRule += " Price is very_low.";
if (VeryLowPriceIdxByHour(NowHour) == 0)
DayAheadRule += " Very_low price: Solar is enough.";
else
DayAheadRule += " Very_low Price: Solar not enough.";
Result = true;
else if ( (VeryLowPriceIdxByHour(NowHour) == 1)
DayAheadRule += " Very_low-Very_low price: Solar is enough.";
else
DayAheadRule += " Very_low-Very_low Price: Solar not enough.";
Result = true;
else if ( (VeryLowPriceIdxByHour(NowHour) == 2)
DayAheadRule += " Very_low-Very_low-Very_low price: Solar is enough.";
else
DayAheadRule += " Very_low-Very_low-Very_low Price: Solar not enough.";
Result = true;
else if ( Not(IsInArrayOfPairs(context.VeryLowPriceArray,
DayAheadRule += " Charge: Any Very_low Price.";
Result = true;
else
DayAheadRule += " Wait for other Very_Low prices.";
Result = true;
} // very_low price now
if (TraceOn) node.warn("TryRule_VeryLowPriceNow: " + Result);
return Result;
} // TryRule_VeryLowPriceNow
function TryRule_LowPriceNow()
if (TraceOn) node.warn("TryRule_LowPriceNow...");
let Result = false;
Math.max(4,
Round(Energy_from_Grid_Needed_Wh / context.Max_Charge_Voltage_V)
if (LowPriceIdxByHour(NowHour) == 0)
> Batt_Free_Wh)
DayAheadRule += " Low price: Solar is enough.";
else
DayAheadRule += " Low Price: Solar not enough.";
Result = true;
else if ( (LowPriceIdxByHour(NowHour) == 1)
> Batt_Free_Wh)
DayAheadRule += " Low-Low price: Solar is enough.";
else
DayAheadRule += " Low-Low Price: Solar not enough.";
Result = true;
else if ( (LowPriceIdxByHour(NowHour) == 2)
> Batt_Free_Wh)
DayAheadRule += "Low-Low-Low price: Solar is enough.";
else
DayAheadRule += " Low-Low-Low Price: Solar not enough.";
Result = true;
else if ( Not(IsInArrayOfPairs(context.LowPriceArray,
DayAheadRule += " Charge: Any Low Price.";
Result = true;
else
DayAheadRule += " Low Price: Wait for other Low prices.";
Result = true;
} // Low price now
if (TraceOn) node.warn("TryRule_LowPriceNow: " + Result);
return Result;
} // TryRule_LowPriceNow
function TryRule_HighPriceNow()
if (TraceOn) node.warn("TryRule_HighPriceNow...");
let Result = false;
if ( IsHighPrice(NowHour) )
DayAheadRule += " High Price.";
Result = true;
} // Price is High
if (TraceOn) node.warn("TryRule_HighPriceNow: " + Result);
return Result;
} // TryRule_HighPriceNow
function TryRule_SoCBelowMinimum()
if (TraceOn) node.warn("TryRule_SoCBelowMinimum...");
let Result = false;
if (context.SoC_Now_Perc < SoC_Min_Manual_Perc)
{ // SoC is below Manual minimum
DayAheadRule += " SoC to low ("
+ context.SoC_Now_Perc + "<" + SoC_Min_Manual_Perc + "),";
Result = true;
} // SoC is below minimum
if (TraceOn) node.warn("TryRule_SoCBelowMinimum: " + Result);
return Result;
} // TryRule_SoCBelowMinimum
// function TryRule_SolarIsEnough()
// let Result = false;
// Solar is Enough, use balance
// if (Energy_from_Grid_to_Full_at_Sunset_Today_Wh <= 0)
// DayAheadRule += " Solar to Sunset is enough.";
// Batt_Max_Current_Grid_A = 0;
// Result = true;
// } // Solar is Enough
// if (TraceOn) node.warn("TryRule_SolarIsEnough: " + Result);
// return Result;
// } // TryRule_SolarIsEnough
function TryRule_BetterPriceLater()
if (TraceOn) node.warn("TryRule_BetterPriceLater...");
let Result = false;
// if low prices come (not negetive, zero or very_low)
// and current price is (relatively) high
if ( (NowHour < Next_Cheap_Charge_Hour)
&& (DayAhead_PriceArray_Ct[NowHour]
> Next_Cheap_Charge_Price_Ct + Sell_Price_Limit_Ct)
&& (Energy_from_Grid_Needed_Wh == 0)
DayAheadRule += " Charge at or after "
+ HourAsText(Next_Cheap_Charge_Hour)
+ " hr.";
Result = true;
if (TraceOn) node.warn("TryRule_BetterPriceLater: " + Result);
return Result;
} // TryRule_BetterPriceLater
function TryRule_NoSpecialPrice()
if (TraceOn) node.warn("TryRule_NoSpecialPrice...");
let Result = false;
// Default = no special price = Always True
{ // default keep minimal SoC
DayAheadRule += " No special Price.";
// Not higher than SoC_Min_Manual_Perc
// But lower is allowed when Solar energy is enough
// But not lower then SoC_Min_Bottom_Perc
Batt_Max_Current_Grid_A = 0; // but not from Grid
Result = true;
} // No special price
if (TraceOn) node.warn("TryRule_NoSpecialPrice: " + Result);
return Result;
} // TryRule_NoSpecialPrice
function TryAllRules()
// Set Default Values
if (TraceOn) node.warn("TryAllRules: Start");
Math.min(SoC_Min_Manual_Perc,
Math.max(context.SoC_Now_Perc, SoC_Min_Bottom_Perc)
// Default is max charge
Batt_Max_Current_Grid_A = context.Grid_to_Batt_Limit_A;
if ( TryRule_DESS() ) {}
else if ( TryRule_FinishLowSoCCharging() ) {}
else if ( TryRule_SoCBelowBottom() ) {}
else if ( TryRule_SellHighPrice() ) {}
else if ( TryRule_NegativePriceWait() ) {}
else if ( TryRule_NegativePriceNow() ) {}
else if ( TryRule_ZeroPriceWait() ) {}
else if ( TryRule_ZeroPriceNow() ) {}
else if ( TryRule_VeryLowPriceWait() ) {}
else if ( TryRule_VeryLowPriceNow() ) {}
else if ( TryRule_LowPriceNow() ) {}
else if ( TryRule_HighPriceNow() ) {}
else if ( TryRule_SoCBelowMinimum() ) {}
// else if ( TryRule_SolarIsEnough() ) {}
else if ( TryRule_BetterPriceLater() ) {}
else if ( TryRule_NoSpecialPrice() ) {}
// Now all Rules are evaluated
if (TraceOn) node.warn("Batt_Max_Current_Grid_A: " + Batt_Max_Current_Grid_A);
if (TraceOn) node.warn("Batt_Max_Current_Solar_A: " + Batt_Max_Current_Solar_A);
if ( Batt_Max_Current_Grid_A == 0 )
DayAheadRule += " No Grid charge.";
if ( Batt_Max_Current_Solar_A == 0 )
DayAheadRule += " No Solar charge.";
// Maximum speed to charge battery
context.Batt_Max_Current_Target_A =
Math.min(context.Grid_to_Batt_Limit_A,
Batt_Max_Current_Grid_A + Batt_Max_Current_Solar_A);
if (context.Max_Inverter_Power_W != null)
Max_Inverter_Power_Target_W = context.Max_Inverter_Power_W;
if (Grid_Setpoint_Unload_W == 0)
{ Grid_Setpoint_Target_W = Grid_Setpoint_Manual_W;
else
Grid_Setpoint_Unload_W + context.Energy_from_Solar_Now_W;
DayAheadRule = DayAheadRule.trim(); // remove spaces
if (context.Last_SoC_Min_Target_Perc != SoC_Min_Target_Perc)
AddDebug("SoC_Min_Target_Perc: " + SoC_Min_Target_Perc + "%\r");
context.Last_SoC_Min_Target_Perc = SoC_Min_Target_Perc;
if (context.Last_Grid_Setpoint_Target_W != Grid_Setpoint_Target_W)
AddDebug("Grid_Setpoint_Target_W: " + Grid_Setpoint_Target_W + " W\r");
context.Last_Grid_Setpoint_Target_W = Grid_Setpoint_Target_W;
if (context.Last_Max_Inverter_Power_Target_W != Max_Inverter_Power_Target_W)
AddDebug("Max_Inverter_Power_Target_W: " + Max_Inverter_Power_Target_W + " W\r");
context.Last_Max_Inverter_Power_Target_W = Max_Inverter_Power_Target_W;
if (context.Last_DayAheadRule != DayAheadRule)
AddDebug(DayAheadRule + "\r");
context.Last_DayAheadRule = DayAheadRule;
if (context.Last_Batt_Max_Current_Grid_A != Batt_Max_Current_Grid_A)
AddDebug("Batt_Max_Current_Grid_A: ");
AddDebug(Batt_Max_Current_Grid_A + " A\r");
context.Last_Batt_Max_Current_Grid_A = Batt_Max_Current_Grid_A;
if (context.Last_Batt_Max_Current_Solar_A != Batt_Max_Current_Solar_A)
AddDebug("Batt_Max_Current_Solar_A: ");
AddDebug(Batt_Max_Current_Solar_A + " A\r");
context.Last_Batt_Max_Current_Solar_A = Batt_Max_Current_Solar_A;
if (context.Last_Batt_Max_Current_Target_A != context.Batt_Max_Current_Target_A)
AddDebug("Batt_Max_Current_Target_A: ");
AddDebug(context.Batt_Max_Current_Target_A + " A\r");
context.Last_Batt_Max_Current_Target_A = context.Batt_Max_Current_Target_A;
if (context.Last_Charge_Disable_Target != Charge_Disable_Target)
// AddDebug("Charge Disable: ");
// AddDebug(Charge_Disable_Target + "\r");
context.Last_Charge_Disable_Target = Charge_Disable_Target;
if (context.Last_Batt_Charger_Only_Target != Batt_Charger_Only_Target)
AddDebug("Batt_Charger_Only_Target: ");
AddDebug(Batt_Charger_Only_Target + "\r");
context.Last_Batt_Charger_Only_Target = Batt_Charger_Only_Target;
if (context.Last_Solar_Charger_Target != Solar_Charger_Target)
AddDebug("Solar Charger: ");
if (Solar_Charger_Target == 1) {
AddDebug("On\r");
else {
AddDebug("Off\r");
context.Last_Solar_Charger_Target = Solar_Charger_Target;
if (context.Last_Relay_2_Target != Relay_2_Target)
AddDebug("Relay 2: ");
if (Relay_2_Target == 1) {
AddDebug("Relay On = Solar Off\r");
else {
AddDebug("Relay Off = Solar On\r");
context.Last_Relay_2_Target = Relay_2_Target;
} // TryAllRules
function CreateReturnMessages()
msg_DayAhead_Rule =
{ topic: "DayAhead_Rule", payload: DayAheadRule };
if (context.Batt_Max_Current_Target_A != context.Max_Charge_Current_A) {
{ topic: "Batt_Max_Current_Target_A",
payload: context.Batt_Max_Current_Target_A };
if (SoC_Min_Target_Perc != context.SoC_Min_Venus) {
{ topic: "SoC_Min_Target_Perc", payload: SoC_Min_Target_Perc };
if (Grid_Setpoint_Target_W != context.Grid_Setpoint) {
{ topic: "Grid_Setpoint_Target_W", payload: Grid_Setpoint_Target_W };
if (Max_Inverter_Power_Target_W != context.Max_Inverter_Power_W) {
{ topic: "Max_Inverter_Power_Target_W",
payload: Max_Inverter_Power_Target_W };
if (Charge_Disable_Target != context.Charge_Disable) {
// msg_Charge_Disable_Target =
// { topic: "Charge_Disable_Target", payload: Charge_Disable_Target };
if (Solar_Charger_Target != context.Solar_Charger) {
{ topic: "Solar_Charger_Target", payload: Solar_Charger_Target };
if (Relay_2_Target != context.Relay_2) {
{ topic: "Relay_2_Target", payload: Relay_2_Target };
} // CreateReturnMessages
// S T A R T O F T H E P R O G R A M
switch (msg.topic) {
case "RunNow":
context.RunNow = true;
msg = null;
break;
case "DESS Mode":
context.DESS_Mode = msg.payload;
msg = null;
break;
case "Energy_from_Solar_Now_W":
// Energy Surplus = Solar minus consumption
context.Energy_from_Solar_Now_W = msg.payload;
msg = null;
break;
case "NegativePriceArray":
context.NegativePriceArray = msg.payload;
msg = null;
break;
case "ZeroPriceArray":
context.ZeroPriceArray = msg.payload;
msg = null;
break;
case "VeryLowPriceArray":
// near zero
context.VeryLowPriceArray = msg.payload;
msg = null;
break;
case "LowPriceArray":
context.LowPriceArray = msg.payload;
msg = null;
break;
case "HighPriceArray":
context.HighPriceArray = msg.payload;
// node.warn("High Price: " + context.HighPriceArray);
msg = null;
break;
case "DayAhead_Hours":
// ignore;
msg = null;
break;
case "Price_State":
// ignore;
msg = null;
break;
case "SoC_Now":
context.SoC_Now_Perc = msg.payload;
msg = null;
break;
case "SoC_Min_Venus":
context.SoC_Min_Venus = msg.payload;
msg = null;
break;
case "Max_Charge_Current_A":
context.Max_Charge_Current_A = msg.payload;
msg = null;
break;
case "Max_Charge_Voltage_V":
context.Max_Charge_Voltage_V = msg.payload;
msg = null;
break;
case "Grid_Setpoint_W":
context.Grid_Setpoint_W = msg.payload;
msg = null;
break;
case "Charge_Disabled":
context.Charge_Disable = msg.payload;
msg = null;
break;
case "Solar_Charger":
context.Solar_Charger = msg.payload;
msg = null;
break;
case "Max_Inverter_Power_W":
context.Max_Inverter_Power_W = msg.payload;
msg = null;
break;
case "Relay_2":
context.Relay_2 = msg.payload;
msg = null;
break;
case "Grid_to_Batt_Limit":
// From EV Charger Monitor
context.Grid_to_Batt_Limit_A = msg.payload;
msg = null;
break;
case "Debug":
context.DebugOn = Not(context.DebugOn);
node.warn("DebugOn: " + context.DebugOn);
ClearContext();
msg = null;
break;
default:
node.error("Unknown Topic: " + msg.topic
+ " Payload: " + msg.payload);
} // switch for input all variables
let External_Data_OK = false;
if (context.RunNow == true)
if (Verify_External_Data() == true)
External_Data_OK = true;
// node.warn("Verify_External_Data") ;
if ( (External_Data_OK) && (context.RunNow == true) )
context.RunNow = false; // don't repeat until next launch
if (context.Last_DESS_Mode != context.DESS_Mode)
AddDebug(
"DESS_Mode: " + context.DESS_Mode + ".\r");
context.Last_DESS_Mode = context.DESS_Mode;
if ( Not(GlobalGetAll() ) )
node.warn("GlobalGetAll: Fatal Error")
return;
SolarSetSunriseAndSunsetHours();
SolarMakeForecasts();
BatteryCalculateLevels();
CalculateEnergyToFullSoC();
FindCheapChargeHour();
FindHighSellHour();
FindEnergyToSell();
SetSolarAvailable();
TryAllRules();
CreateReturnMessages();
if (ErrorText > "") {
node.warn(ErrorText);
if ( context.DebugOn && (DebugText > "") )
{ node.warn(DebugText);
node.status({fill:"green",shape:"dot",
text: "@ " + NowTime + ": "
+ "Min.SoC: " + SoC_Min_Target_Perc + "%; "
+ Batt_Max_Current_Grid_A + " + "
+ Batt_Max_Current_Solar_A + " Amp ("
+ Solar_To_Batt_Perc + "%)"}
node.send(msg_DayAhead_Rule);
node.send(msg_Batt_Max_Current_Target_A);
node.send(msg_SoC_Min_Target_Perc);
node.send(msg_Grid_Setpoint_Target_W);
node.send(msg_Max_Inverter_Power_Target_W);
node.send(msg_Charge_Disable_Target);
node.send(msg_Solar_Charger_Target);
node.send(msg_Relay_2_Target);
node.done();
return [ msg_DayAhead_Rule,
msg_Batt_Max_Current_Target_A,
msg_SoC_Min_Target_Perc,
msg_Grid_Setpoint_Target_W,
msg_Max_Inverter_Power_Target_W,
msg_Charge_Disable_Target,
msg_Solar_Charger_Target,
msg_Relay_2_Target ];
} // if context.RunNow
[ Voor 220% gewijzigd door MJ de Bruijn op 14-05-2024 14:27 ]
  • MJ de Bruijn
Flow "Auto Laadstation"
Dit is de definitie van de Flow "Auto Laadstation". Kopieer de onderstaande tekst en kies in Nod Red "Import Nodes". Plak dan deze tekst en kies voor import.
"id": "53e88ae831d5e7b7",
"type": "tab",
"label": "Auto Laadstation",
"disabled": false,
"info": "",
"env": []
"id": "577a3ad05f3e60ec",
"type": "function",
"z": "53e88ae831d5e7b7",
"name": "Calc EV Charge Settings",
"func": "// zie seperate post voor JavaScript tekst
"outputs": 1,
"timeout": "4",
"noerr": 0,
"initialize": "// Code added here will be run once\n// whenever the node is started.\n\ncontext = context || {};\n\nif (context.TraceOn == null) {\n context.TraceOn = false;\n}\nif (context.Init_OK == null) {\n context.Init_OK = false;\n}\nif (context.Last_High_Amp == null) {\n context.Last_High_Amp = 16;\n}\nif (context.Decrease_High_Amp_Secs == null) {\n context.Decrease_High_Amp_Secs = 0;\n}\nif (context.Grid_to_Batt_Limit_A == null) {\n context.Grid_to_Batt_Limit_A = 20;\n}\nif (context.EV_Charger_Mode_Manual == null) {\n context.EV_Charger_Mode_Manual = 5; // do not use\n}\nif (context.EV_Charger_Start_Hour == null) {\n context.EV_Charger_Start_Hour = 0; // do not use\n}\nif (context.EV_Charger_Last_Hour == null) {\n context.EV_Charger_Last_Hour = 0; // do not use\n}\n",
"finalize": "",
"libs": [],
"x": 498,
"y": 512,
"wires": [
"8f73b7a7763e4bb2",
"d49191f2050d5542",
"cbf014efb00447eb",
"18c9911d47af1b56",
"c409eb6b1bdadb34"
"id": "6bbec36f65e5700c",
"type": "victron-output-evcharger",
"service": "com.victronenergy.evcharger/40",
"path": "/StartStop",
"serviceObj": {
"name": "Auto Laadstation"
"pathObj": {
"type": "enum",
"name": "Start/stop charging (manual mode)",
"enum": {
"0": "Stop",
"1": "Start"
"writable": true
"initial": "",
"name": "Start/Stop Laden",
"onlyChanges": false,
"x": 826,
"y": 688,
"wires": []
"id": "8fa055112801a40b",
"type": "inject",
"name": "0 = Stop",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Start_Stop",
"payload": "0",
"payloadType": "num",
"x": 92,
"y": 688,
"wires": [
"d49191f2050d5542"
"id": "882e0491f3b10850",
"type": "inject",
"name": "1 = Start",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"payload": "1",
"x": 92,
"y": 720,
"wires": [
"d49191f2050d5542"
"id": "2efea18fdcdb179f",
"path": "/SetCurrent",
"serviceObj": {
"pathObj": {
"type": "float",
"name": "Set charge current (manual mode) (A)",
"writable": true
"name": "Set Max Charge (Manual)",
"x": 858,
"y": 848,
"wires": []
"id": "f76cdf144fb4fd56",
"path": "/Mode",
"serviceObj": {
"pathObj": {
"path": "/Mode",
"type": "enum",
"name": "Mode",
"enum": {
"0": "Manual",
"1": "Auto",
"2": "Schedule"
"writable": true
"initial": "",
"name": "",
"x": 850,
"y": 624,
"wires": []
"id": "df8284662e2f66d7",
"type": "inject",
"name": "0 = Manual",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "EV_Mode",
"payload": "0",
"x": 92,
"y": 576,
"wires": [
"8f73b7a7763e4bb2"
"id": "924499edb3111f7c",
"type": "inject",
"name": "1 = Auto",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "EV_Mode",
"payload": "1",
"x": 92,
"y": 608,
"wires": [
"8f73b7a7763e4bb2"
"id": "48ed1dcd2e8567f5",
"type": "inject",
"name": "2 = Scheduled",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "EV_Mode",
"payload": "2",
"x": 102,
"y": 640,
"wires": [
"8f73b7a7763e4bb2"
"id": "70a90cf4cbb79aaa",
"type": "victron-input-evcharger",
"path": "/Mode",
"serviceObj": {
"pathObj": {
"path": "/Mode",
"type": "enum",
"name": "Mode",
"enum": {
"0": "Manual",
"1": "Auto",
"2": "Schedule"
"initial": "",
"name": "EV_Mode",
"onlyChanges": true,
"x": 92,
"y": 272,
"wires": [
"1891f28aeacc992f",
"577a3ad05f3e60ec"
"id": "16ff0c8b09b22777",
"path": "/MaxCurrent",
"serviceObj": {
"pathObj": {
"type": "float",
"name": "Maximum charge current (A)",
"writable": true
"name": "Set Max Charge",
"x": 828,
"y": 800,
"wires": []
"id": "9f1298dbce082bdd",
"serviceObj": {
"pathObj": {
"type": "float",
"name": "EV_Max_Charge_Auto_A",
"roundValues": "no",
"x": 142,
"y": 176,
"wires": [
"577a3ad05f3e60ec",
"9b417a3f76ef2489"
"id": "466113809d167f66",
"serviceObj": {
"pathObj": {
"type": "float",
"name": "EV_Max_Charge_Manual_A",
"x": 152,
"y": 224,
"wires": [
"577a3ad05f3e60ec",
"ecadfdf5a6f0632c"
"id": "1b252e016235d67f",
"serviceObj": {
"pathObj": {
"type": "enum",
"enum": {
"0": "Stop",
"1": "Start"
"initial": "",
"name": "EV_Start_Stop",
"x": 112,
"y": 320,
"wires": [
"52d61f34b1f5c90a",
"577a3ad05f3e60ec"
"id": "52d61f34b1f5c90a",
"type": "change",
"name": "",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "0",
"fromt": "num",
"to": "EV Start-Stop 0: Stop",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "1",
"fromt": "num",
"to": "EV Start-Stop 1: Start",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 336,
"y": 320,
"wires": [
"2ea293265c6f5b1b"
"id": "1891f28aeacc992f",
"type": "change",
"name": "",
"rules": [
"t": "change",
"p": "payload",
"pt": "msg",
"from": "0",
"fromt": "num",
"to": "EV Mode 0: Manual",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "1",
"fromt": "num",
"to": "EV Mode 1: Auto",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "2",
"fromt": "num",
"to": "EV Mode 2: Scheduled",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 336,
"y": 272,
"wires": [
"f3b2fbf9e1a8af84"
"id": "f344b378ace11420",
"path": "/Status",
"serviceObj": {
"pathObj": {
"path": "/Status",
"type": "enum",
"name": "Status",
"enum": {
"0": "Disconnected",
"1": "Connected",
"2": "Charging",
"3": "Charged",
"4": "Waiting for sun",
"5": "Waiting for RFID",
"6": "Waiting for start",
"7": "Low SOC",
"8": "Ground fault",
"9": "Welded contacts",
"10": "CP Input shorted",
"11": "Residual current detected",
"12": "Under voltage detected",
"13": "Overvoltage detected",
"14": "Overheating detected"
"initial": "",
"name": "EV_Status",
"x": 92,
"y": 368,
"wires": [
"ccd379b940f13ae5",
"577a3ad05f3e60ec"
"id": "ccd379b940f13ae5",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "EV_State_Text",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "0",
"fromt": "num",
"to": "EV State 0: Disconnected",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "1",
"fromt": "num",
"to": "EV State 1: Connected",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "2",
"fromt": "num",
"to": "EV State 2: Charging",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "3",
"fromt": "num",
"to": "EV State 3: Charged",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "4",
"fromt": "num",
"to": "EV State 4: Waiting for Sun",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "5",
"fromt": "num",
"to": "EV State 5: Waiting for RFID",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "6",
"fromt": "num",
"to": "EV State 6: Waiting for Start",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "7",
"fromt": "num",
"to": "EV State 7: Low SoC",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "8",
"fromt": "num",
"to": "EV State 8: Ground Fault",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "9",
"fromt": "num",
"to": "EV State 9: Welded Contacts",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "10",
"fromt": "num",
"to": "EV State 10: CP input Shorted",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "11",
"fromt": "num",
"to": "EV State 11 Residual Current Detected",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "12",
"fromt": "num",
"to": "EV State 12: Under Voltage Detected",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "13",
"fromt": "num",
"to": "EV State 13: Overvoltage Detected",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "14",
"fromt": "num",
"to": "EV State 14: Overheating Detected",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "21",
"fromt": "num",
"to": "EV State 21: Start Charge",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "22",
"fromt": "num",
"to": "EV State 22: Switch to 3 Phase",
"tot": "str"
"t": "change",
"p": "payload",
"pt": "msg",
"from": "23",
"fromt": "num",
"to": "EV State 23: Switch to 1 Phase",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 336,
"y": 368,
"wires": [
"27c233afc2021866",
"577a3ad05f3e60ec"
"id": "9ca9154dc9817c55",
"type": "api-call-service",
"name": "Send Auto Laadstation Log",
"server": "289362b880855228",
"version": 5,
"debugenabled": false,
"domain": "input_text",
"service": "set_value",
"areaId": [],
"deviceId": [],
"entityId": [
"input_text.helper_auto_laadstation_log"
"data": "{\"value\":\"{{payload}}\"}",
"dataType": "json",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "all",
"x": 808,
"y": 432,
"wires": [
"id": "f616608bfad32014",
"type": "delay",
"name": "1 sec",
"pauseType": "delay",
"timeout": "1",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 850,
"y": 320,
"wires": [
"d11094c1fd76e0b7"
"id": "11e3d6aeacb051e3",
"type": "delay",
"name": "2 sec",
"timeout": "2",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 850,
"y": 368,
"wires": [
"d11094c1fd76e0b7"
"id": "51591f5a7beac8c0",
"type": "inject",
"name": "Trace",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Trace",
"payload": "",
"payloadType": "date",
"x": 82,
"y": 432,
"wires": [
"577a3ad05f3e60ec"
"id": "d12076100afdf928",
"type": "inject",
"name": "Every 1 sec",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "1",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "CountDown",
"payload": "",
"x": 102,
"y": 480,
"wires": [
"577a3ad05f3e60ec"
"id": "959570f4906ad682",
"type": "victron-input-gridmeter",
"service": "com.victronenergy.grid/33",
"path": "/Ac/L1/Current",
"serviceObj": {
"name": "ET340 (Grid)"
"pathObj": {
"type": "float",
"name": "L1 Current (A)"
"name": "ET340_L1_A",
"roundValues": "1",
"x": 102,
"y": 32,
"wires": [
"577a3ad05f3e60ec"
"id": "c75fa29f74af606f",
"path": "/Ac/L2/Current",
"serviceObj": {
"pathObj": {
"type": "float",
"name": "L2 Current (A)"
"name": "ET340_L2_A",
"roundValues": "1",
"x": 102,
"y": 80,
"wires": [
"577a3ad05f3e60ec"
"id": "895d44ae8ca812e6",
"path": "/Ac/L3/Current",
"serviceObj": {
"pathObj": {
"type": "float",
"name": "L3 Current (A)"
"name": "ET340_L3_A",
"roundValues": "1",
"x": 102,
"y": 128,
"wires": [
"577a3ad05f3e60ec"
"id": "9b417a3f76ef2489",
"type": "function",
"name": "Text: Max Charge Auto",
"func": "\nconst Now = new Date()\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n + (\"0\" + Now.getSeconds()).slice(-2)\n ;\n\nmsg.payload = \"Max Charge Auto: \" + msg.payload;\n\nnode.status( {fill:\"green\", shape:\"dot\",\n text: \"@ \" + NowTime + \": \"\n + msg.payload }\n );\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 580,
"y": 176,
"wires": [
"d11094c1fd76e0b7"
"id": "ecadfdf5a6f0632c",
"type": "function",
"name": "Text: Max Charge Manual",
"func": "const Now = new Date()\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n + (\"0\" + Now.getSeconds()).slice(-2)\n ;\n\nmsg.payload = \"Max Charge Manual: \" + msg.payload;\n\nnode.status( {fill:\"green\", shape:\"dot\",\n text: \"@ \" + NowTime + \": \"\n + msg.payload }\n );\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 590,
"y": 224,
"wires": [
"d11094c1fd76e0b7"
"id": "77b005bfc989bf6d",
"type": "delay",
"name": "1 / 5 sec",
"pauseType": "rate",
"timeout": "5",
"rate": "1",
"nbRateUnits": "5",
"randomFirst": "1",
"randomLast": "5",
"drop": true,
"allowrate": false,
"outputs": 1,
"x": 420,
"y": 800,
"wires": [
"852ef9770db62f68"
"id": "68dcdba7ce8b755b",
"type": "delay",
"timeout": "5",
"rate": "1",
"nbRateUnits": "5",
"randomFirst": "1",
"randomLast": "5",
"drop": true,
"allowrate": false,
"outputs": 1,
"x": 420,
"y": 848,
"wires": [
"b01f74db127b197b"
"id": "130361d2a781f4ce",
"type": "delay",
"timeout": "5",
"rate": "1",
"nbRateUnits": "5",
"randomFirst": "1",
"randomLast": "5",
"drop": true,
"allowrate": false,
"outputs": 1,
"x": 532,
"y": 752,
"wires": [
"d20d66cd01b4b089"
"id": "2c2910b4aa31179b",
"type": "switch",
"name": "0: Top; 1: Bottom",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 346,
"y": 736,
"wires": [
"d20d66cd01b4b089"
"130361d2a781f4ce"
"id": "26931988f2071217",
"type": "link in",
"name": "Input Main Function",
"links": [
"8ad9f2f536daf1e6",
"17276b34e9455aa1",
"fc96c666b23d0d8f",
"68c5e868d4e6b72b",
"b89c0cd495228bba",
"e60f001cc00b9d26",
"b6ab4d914b409b9d",
"f1fd0325f7053e8b",
"d927837c63bfe828",
"0378ceeb26afb426",
"e6816c6deacdaee7",
"3377df15d16d89ed"
"x": 225,
"y": 512,
"wires": [
"577a3ad05f3e60ec"
"id": "245e3ce4e79461c7",
"type": "link out",
"name": "Batt Overload Limit",
"mode": "link",
"links": [
"8803291847335701"
"x": 763,
"y": 896,
"wires": []
"id": "35920f4deb1cd5a7",
"type": "delay",
"timeout": "5",
"rate": "1",
"nbRateUnits": "5",
"randomFirst": "1",
"randomLast": "5",
"drop": true,
"allowrate": false,
"outputs": 1,
"x": 420,
"y": 896,
"wires": [
"031389518085793c"
"id": "47172df1ed606009",
"type": "delay",
"timeout": "5",
"rate": "1",
"nbRateUnits": "5",
"randomFirst": "1",
"randomLast": "5",
"drop": true,
"allowrate": false,
"outputs": 1,
"x": 324,
"y": 624,
"wires": [
"937ebb098c3fdc93"
"id": "8f73b7a7763e4bb2",
"type": "switch",
"name": "EV_Mode",
"property": "topic",
"rules": [
"t": "eq",
"v": "EV_Mode",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 316,
"y": 576,
"wires": [
"47172df1ed606009"
"id": "d49191f2050d5542",
"type": "switch",
"name": "Start_Stop",
"rules": [
"t": "eq",
"v": "Start_Stop",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 326,
"y": 688,
"wires": [
"2c2910b4aa31179b"
"id": "cbf014efb00447eb",
"type": "switch",
"name": "Max_Charge",
"rules": [
"t": "eq",
"v": "Max_Charge",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 178,
"y": 800,
"wires": [
"77b005bfc989bf6d"
"id": "c409eb6b1bdadb34",
"type": "switch",
"name": "Grid_to_Batt_Limit",
"rules": [
"t": "eq",
"v": "Grid_to_Batt_Limit",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 198,
"y": 896,
"wires": [
"35920f4deb1cd5a7"
"id": "18c9911d47af1b56",
"type": "switch",
"name": "Max_Charge_Manual",
"rules": [
"t": "eq",
"v": "Max_Charge_Manual",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 208,
"y": 848,
"wires": [
"68dcdba7ce8b755b"
"id": "f3b2fbf9e1a8af84",
"type": "function",
"name": "Show Payload",
"func": "const Now = new Date()\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n + (\"0\" + Now.getSeconds()).slice(-2)\n ;\n\nnode.status( {fill:\"green\", shape:\"dot\",\n text: \"@ \" + NowTime + \": \"\n + msg.payload }\n );\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 560,
"y": 272,
"wires": [
"d11094c1fd76e0b7"
"id": "2ea293265c6f5b1b",
"type": "function",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 560,
"y": 320,
"wires": [
"f616608bfad32014"
"id": "27c233afc2021866",
"type": "function",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 560,
"y": 368,
"wires": [
"11e3d6aeacb051e3"
"id": "937ebb098c3fdc93",
"type": "function",
"func": "const Now = new Date()\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n + (\"0\" + Now.getSeconds()).slice(-2)\n ;\n\nnode.status( {fill:\"green\", shape:\"dot\",\n text: \"@ \" + NowTime + \": \"\n + msg.topic + \": \" + msg.payload }\n );\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 608,
"y": 624,
"wires": [
"f76cdf144fb4fd56"
"id": "d20d66cd01b4b089",
"type": "function",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 608,
"y": 688,
"wires": [
"6bbec36f65e5700c"
"id": "852ef9770db62f68",
"type": "function",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 604,
"y": 800,
"wires": [
"16ff0c8b09b22777"
"id": "b01f74db127b197b",
"type": "function",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 604,
"y": 848,
"wires": [
"2efea18fdcdb179f"
"id": "031389518085793c",
"type": "function",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 604,
"y": 896,
"wires": [
"245e3ce4e79461c7"
"id": "d11094c1fd76e0b7",
"type": "rbe",
"name": "Real Changes",
"func": "rbei",
"gap": "",
"start": "",
"inout": "out",
"septopics": true,
"topi": "topic",
"x": 560,
"y": 432,
"wires": [
"9ca9154dc9817c55"
"id": "289362b880855228",
"type": "server",
"name": "Home Assistant Api",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": ": ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "default",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": false
Afbeeldingslocatie: https://tweakers.net/i/foex9tHgafIrFGmCU2VH0UnQGlw=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/sQJLwyb0ouZjqCTkJcNUnoxi.jpg?f=user_large
[ Voor 214% gewijzigd door MJ de Bruijn op 14-05-2024 15:12 ]
  • MJ de Bruijn
  • Registratie: November 2016
  • Laatst online: 08:59
JavaScript van de functie "Calc EV Charge Settings" in Flow "Auto Laadstation"
Wanneer de Flow "Auto Laadstation" is gemaakt (zie hierboven), open dan functie "Calc EV Charge Settings". Plak de onderstaande tekst.
// This function monitors the Currents throught the
// ET340 electricity meter.
// These are the Critical and non-critical currents
// plus the Battery charge currents.
// At start, there is a "Dummy" Value of 20 Amps.
// This will decrease slowly to allow the real values
// of three phases L1, L2 and L3 to settle, so
// there is no risk of missing a high value.
// Depending on the used power, represented by this
// High Value, the available resting Power (or Amps)
// for the EV will be calculated.
let NowHour = Now.getHours();
let NowTime = ("0" + Now.getHours()).slice(-2) + ":"
+ ("0" + Now.getMinutes()).slice(-2) + ":"
+ ("0" + Now.getSeconds()).slice(-2)
var CurTimeInSecs = Math.floor(Date.now() / 1000);
var New_High_Amp = 0;
var Max_Amp_Allowed = 25;
var EV_Is_Ready = false;
var Power_Limit = 3 * 6 * 230;
var Power_Available = 0;
// the available power must be more than 3 phase, 6 Amp, 230 Volt
// = 4140 Watt for several minutes
if (context.Decrease_High_Amp_Secs == 0) {
// start countdown in 3 secs
context.Decrease_High_Amp_Secs = CurTimeInSecs + 3;
case "Trace":
context.TraceOn = !context.TraceOn;
node.warn("Trace: " + context.TraceOn);
msg = null;
break;
case "CountDown":
// run at least every 1 second
msg = null;
break;
case "EV_Mode":
context.EV_Mode = msg.payload;
msg = null;
break;
case "EV_Status":
context.EV_Status = msg.payload;
msg = null;
break;
case "EV_State_Text":
context.EV_Status_Text = msg.payload;
msg = null;
break;
case "ET340_L1_A":
context.ET340_L1_A = msg.payload;
msg = null;
break;
case "ET340_L2_A":
context.ET340_L2_A = msg.payload;
msg = null;
break;
case "ET340_L3_A":
context.ET340_L3_A = msg.payload;
msg = null;3
break;
case "EV_Start_Stop":
context.EV_Start_Stop = msg.payload;
if (context.EV_Start_Stop_Targ == null) {
context.EV_Start_Stop_Targ = context.EV_Start_Stop;
msg = null;
break;
case "EV_Max_Charge_Auto_A":
context.EV_Max_Charge_Auto_A = msg.payload;
if (context.EV_Max_Charge_Auto_Targ_A == null) {
context.EV_Max_Charge_Auto_Targ_A = context.EV_Max_Charge_Auto_A;
msg = null;
break;
case "EV_Max_Charge_Manual_A":
context.EV_Max_Charge_Manual_A = msg.payload;
if (context.EV_Max_Charge_Manual_Targ_A == null) {
context.EV_Max_Charge_Manual_Targ_A = context.EV_Max_Charge_Manual_A;
msg = null;
break;
case "Price_State":
context.Price_State = msg.payload;
msg = null;3
break;
default:
node.warn("Unknown Topic: " + msg.topic + " Payload: " + msg.payload);
msg = null;
break;
if ( (context.ET340_L1_A != null)
&& (context.ET340_L2_A != null)
&& (context.ET340_L3_A != null)
&& (context.EV_Mode != null)
&& (context.EV_Status != null)
&& (context.EV_Status_Text != null)
&& (context.EV_Start_Stop != null)
&& (context.EV_Start_Stop_Targ != null)
&& (context.EV_Max_Charge_Auto_A != null)
&& (context.EV_Max_Charge_Auto_Targ_A != null)
&& (context.EV_Max_Charge_Manual_A != null)
&& (context.EV_Max_Charge_Manual_Targ_A != null)
&& (context.Price_State != null)
context.Init_OK = true;
if (context.Init_OK) {
if (context.TraceOn) { node.warn("EV_Status: " + context.EV_Status) }
global.get("Victron_MESS.EV_Charger.Target_Mode").substring(0, 1);
node.warn("Charger_Mode_Manual: " + context.EV_Charger_Mode_Manual)
global.get("Victron_MESS.EV_Charger.Start_Hour");
node.warn("Charger_Start_Hour: " + context.EV_Charger_Start_Hour)
global.get("Victron_MESS.EV_Charger.Last_Hour");
node.warn("Charger_Last_Hour: " + context.EV_Charger_Last_Hour)
if (context.EV_Charger_Mode_Manual == "0") // manual
{ context.EV_Mode_Target = 0 }
else if (context.EV_Charger_Mode_Manual == "1") // auto
{ context.EV_Mode_Target = 1 }
else if (context.EV_Charger_Mode_Manual == "2") // scheduled
{ context.EV_Mode_Target = 2 }
else if (context.EV_Charger_Mode_Manual == "3") // Scheduler (HA)
else if (context.EV_Charger_Mode_Manual == "4") // Optimized (Node Red)
else if (context.EV_Charger_Mode_Manual == "5") // Do not use manual.
{ context.EV_Mode_Target = context.EV_Mode }
EV_Is_Ready = ( (context.EV_Status == 1) // connected
|| (context.EV_Status == 2) // charging
|| (context.EV_Status == 3) // charged
|| (context.EV_Status == 4) // waiting for sun
|| (context.EV_Status == 5) // waiting for RFID
|| (context.EV_Status == 6) // waiting for start
|| (context.EV_Status == 21) // starting
if (context.TraceOn) { node.warn("EV_Is_Ready: " + EV_Is_Ready) }
New_High_Amp = Math.max(Math.max(context.ET340_L1_A, 0),
Math.max(context.ET340_L2_A, 0),
Math.max(context.ET340_L3_A, 0),
context.Last_High_Amp);
// don't show normal countdown, only later changes
if (New_High_Amp != context.Last_High_Amp) {
node.warn("High_Amp: " + New_High_Amp);
Math.max(context.Last_High_Amp, New_High_Amp);
node.warn("Last_High_Amp: " + context.Last_High_Amp);
// after every x seconds
// decrease Last_High_Amp with 0,1 Amp.
// slowly, to avoid sudden power peaks
if (CurTimeInSecs > context.Decrease_High_Amp_Secs)
Math.round(10*context.Last_High_Amp - 1) / 10;
context.Decrease_High_Amp_Secs = CurTimeInSecs;
if (context.EV_Mode == 0 )
{ // Manual
context.EV_Max_Charge_Auto_Targ_A = 16;
context.EV_Max_Charge_Manual_Targ_A = 16;
// In all cases, avoid High currents
Math.max(
Math.min(16,
Math.trunc(Max_Amp_Allowed - Math.ceil(context.Last_High_Amp))
// context.EV_Max_Charge_Auto_Targ_A
, 0);
Math.max(
Math.min(16,
Math.round(Max_Amp_Allowed - context.Last_High_Amp)
, 0);
if ( (context.EV_Status == 2) // charging
{ // charging
if (New_High_Amp < 8) {
context.Grid_to_Batt_Limit_A = 120;
else if (New_High_Amp < 9) {
if ( (context.Grid_to_Batt_Limit_A < 100)
|| (context.Grid_to_Batt_Limit_A > 120) )
{ context.Grid_to_Batt_Limit_A = 110 }
else if (New_High_Amp < 10) {
if ( (context.Grid_to_Batt_Limit_A < 90)
|| (context.Grid_to_Batt_Limit_A > 110) )
{ context.Grid_to_Batt_Limit_A = 100 }
else if (New_High_Amp < 11) {
if ( (context.Grid_to_Batt_Limit_A < 80)
|| (context.Grid_to_Batt_Limit_A > 100) )
{ context.Grid_to_Batt_Limit_A = 90 }
else if (New_High_Amp < 12) {
if ( (context.Grid_to_Batt_Limit_A < 70)
|| (context.Grid_to_Batt_Limit_A > 90) )
{ context.Grid_to_Batt_Limit_A = 80 }
else if (New_High_Amp < 13) {
if ( (context.Grid_to_Batt_Limit_A < 60)
|| (context.Grid_to_Batt_Limit_A > 80) )
{ context.Grid_to_Batt_Limit_A = 70 }
else if (New_High_Amp < 14) {
if ( (context.Grid_to_Batt_Limit_A < 50)
|| (context.Grid_to_Batt_Limit_A > 70) )
{ context.Grid_to_Batt_Limit_A = 60 }
else if (New_High_Amp < 15) {
if ( (context.Grid_to_Batt_Limit_A < 40)
|| (context.Grid_to_Batt_Limit_A > 60) )
{ context.Grid_to_Batt_Limit_A = 50 }
else if (New_High_Amp < 16) {
if ( (context.Grid_to_Batt_Limit_A < 30)
|| (context.Grid_to_Batt_Limit_A > 50) )
{ context.Grid_to_Batt_Limit_A = 40 }
else {
if ( (context.Grid_to_Batt_Limit_A < 20)
|| (context.Grid_to_Batt_Limit_A > 40) )
{ context.Grid_to_Batt_Limit_A = 30 }
} // if charging
node.warn("EV_Max_Charge_Manual_Targ_A: " + context.EV_Max_Charge_Manual_Targ_A);
node.warn("EV_Max_Charge_Auto_Targ_A: " + context.EV_Max_Charge_Auto_Targ_A);
node.warn("Grid_to_Batt_Limit_A: " + context.Grid_to_Batt_Limit_A);
if (context.EV_Max_Charge_Manual_Targ_A < 6) {
context.EV_Start_Stop_Targ = 0;
context.EV_Max_Charge_Auto_Targ_A = 10; // minimum allowed value
context.EV_Max_Charge_Manual_Targ_A = 6; // minimum allowed value
else if (context.EV_Max_Charge_Auto_Targ_A < 6) {
else if ( (EV_Is_Ready)
&& (context.EV_Charger_Mode_Manual == "3") ) // HA Schedule
if ( (NowHour >= context.EV_Charger_Start_Hour)
&& (NowHour <= context.EV_Charger_Last_Hour)
{ // turn on
context.EV_Start_Stop_Targ = 1;
else
{ // turn off
{ node.warn("Start_Stop: " + context.EV_Start_Stop_Targ)
&& (context.EV_Charger_Mode_Manual == "4") ) // Optimized
if ( (context.Price_State == "Negative")
|| (context.Price_State == "Zero")
|| (context.Price_State == "Very Low")
|| (context.Price_State == "Low")
{ // turn on
else
{ // turn off
{ node.warn("Price_State: " + context.Price_State
+ "; Start_Stop: " + context.EV_Start_Stop_Targ)
else
context.EV_Start_Stop_Targ = context.EV_Start_Stop; // unchanged
if (context.EV_Mode_Target != context.EV_Mode) {
msg_EV_Mode =
{ topic: "EV_Mode",
payload: context.EV_Mode_Target};
else {
msg_EV_Mode = null;
if (context.EV_Start_Stop_Targ !=
context.EV_Start_Stop) {
msg_Start_Stop =
{ topic: "Start_Stop",
payload: context.EV_Start_Stop_Targ};
else {
// node.warn("context.EV_Start_Stop_Targ: null" );
msg_Start_Stop = null;
if (context.EV_Max_Charge_Auto_Targ_A !=
context.EV_Max_Charge_Auto_A) {
msg_Max_Charge =
{ topic: "Max_Charge",
payload: context.EV_Max_Charge_Auto_Targ_A };
else {
msg_Max_Charge = null;
if (context.EV_Max_Charge_Manual_Targ_A !=
context.EV_Max_Charge_Manual_A) {
msg_Max_Charge_Manual =
{ topic: "Max_Charge_Manual",
payload: context.EV_Max_Charge_Manual_Targ_A};
else {
msg_Max_Charge_Manual = null;
msg_Grid_to_Batt_Limit =
{ topic: "Grid_to_Batt_Limit",
payload: context.Grid_to_Batt_Limit_A};
node.status( {fill:"green", shape:"dot",
+ context.EV_Status_Text + "; "
+ "High: " + context.Last_High_Amp + " Amp, "
+ "Charge: " + context.EV_Max_Charge_Auto_Targ_A + " Amp"}
node.send(msg_EV_Mode);
node.send(msg_Start_Stop);
node.send(msg_Max_Charge);
node.send(msg_Max_Charge_Manual);
node.send(msg_Grid_to_Batt_Limit);
node.done();
// if (EV_Is_Ready) {
// return [ msg_EV_Mode,
// msg_Start_Stop,
// msg_Max_Charge,
// msg_Max_Charge_Manual,
// msg_Grid_to_Batt_Limit ]
} // if Init_OK
[ Voor 255% gewijzigd door MJ de Bruijn op 14-05-2024 14:32 ]
  • MJ de Bruijn
Dit is de volledige Flow "Home Assistant"
Dit is de definitie van de Flow "Home Assistant". Kopieer de onderstaande tekst en kies in Nod Red "Import Nodes". Plak dan deze tekst en kies voor import.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
791
792
793
794
795
796
797
798
799
800
801
802
803
804
805
806
807
808
809
810
811
812
813
814
815
816
817
818
819
820
821
822
823
824
825
826
827
828
829
830
831
832
833
834
835
836
837
838
839
840
841
842
843
844
845
846
847
848
849
850
851
852
853
854
855
856
857
858
859
860
861
862
863
864
865
866
867
868
869
870
871
872
873
874
875
876
877
878
879
880
881
882
883
884
885
886
887
888
889
890
891
892
893
894
895
896
897
898
899
900
901
902
903
904
905
906
907
908
909
910
911
912
913
914
915
916
917
918
919
920
921
922
923
924
925
926
927
928
929
930
931
932
933
934
935
936
937
938
939
940
941
942
943
944
945
946
947
948
949
950
951
952
953
954
955
956
957
958
959
960
961
962
963
964
965
966
967
968
969
970
971
972
973
974
975
976
977
978
979
980
981
982
983
984
985
986
987
988
989
990
991
992
993
994
995
996
997
998
999
1000
1001
1002
1003
1004
1005
1006
1007
1008
1009
1010
1011
1012
1013
1014
1015
1016
1017
1018
1019
1020
1021
1022
1023
1024
1025
1026
1027
1028
1029
1030
1031
1032
1033
1034
1035
1036
1037
1038
1039
1040
1041
1042
1043
1044
1045
1046
1047
1048
1049
1050
1051
1052
1053
1054
1055
1056
1057
1058
1059
1060
1061
1062
1063
1064
1065
1066
        "id": "6ffb7df5f8d96f1a",
        "type": "tab",
        "label": "Home Assistant",
        "disabled": false,
        "info": "",
        "env": []
        "id": "b9e555505db0c195",
        "type": "victron-input-custom",
        "z": "6ffb7df5f8d96f1a",
        "service": "com.victronenergy.settings",
        "path": "/Settings/DynamicEss/Mode",
        "serviceObj": {
            "name": "com.victronenergy.settings"
        "pathObj": {
            "name": "/Settings/DynamicEss/Mode",
            "type": "number"
        "name": "DESS Mode",
        "roundValues": "0",
        "x": 198,
        "y": 32,
        "wires": [
                "82f3a5ff3ee9a153"
        "id": "871a1fa47acdfeca",
        "name": "Send DESS Mode",
        "version": 5,
        "domain": "input_number",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "input_number.helper_dess_mode"
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "x": 662,
        "y": 80,
        "wires": [
                "844c7311f8f421fb"
        "id": "844c7311f8f421fb",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 874,
        "y": 80,
        "wires": []
        "id": "25d11d67fe68d5cb",
        "type": "api-current-state",
        "name": "Get Target DESS Mode",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "input_select.helper_set_target_dess_mode",
        "state_type": "str",
        "blockInputOverrides": false,
                "value": "",
                "valueType": "entityState"
                "value": "DESS_Mode",
                "valueType": "str"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 458,
        "y": 160,
        "wires": [
                "7c2d18692aa1bed1"
        "id": "9c1423e0dd521756",
        "type": "inject",
        "name": "Every 8 secs",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "8",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 204,
        "y": 160,
        "wires": [
                "3ece2abbca2d3163",
                "25d11d67fe68d5cb"
        "id": "b7bb20f11fc2f861",
        "type": "victron-output-custom",
        "serviceObj": {
        "pathObj": {
            "type": "number"
        "name": "Set DESS Mode",
        "x": 720,
        "y": 304,
        "wires": []
        "id": "ddfbf3bee58c04f8",
        "type": "rbe",
        "name": "Only Changes",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 432,
        "y": 256,
        "wires": [
                "b0920db8c9633aee",
                "1eec9131727da66b"
        "id": "b0920db8c9633aee",
        "type": "change",
        "name": "",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "0: Off",
                "fromt": "str",
                "to": "0",
                "tot": "num"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "1: Auto",
                "fromt": "str",
                "to": "1",
                "tot": "num"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "2: Buy",
                "fromt": "str",
                "to": "2",
                "tot": "num"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "3: Sell",
                "fromt": "str",
                "to": "3",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 432,
        "y": 304,
        "wires": [
                "b7bb20f11fc2f861"
        "id": "2a3f322e14d84e39",
        "name": "Get SoC Min Manual",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_select.helper_set_soc_min_manual",
        "state_type": "num",
                "value": "",
                "value": "SoC_Min_Manual",
                "valueType": "str"
        "for": "0",
        "forType": "num",
        "x": 452,
        "y": 352,
        "wires": [
                "5b62222534168e1d"
        "id": "74751d57aa8416a0",
        "name": "Get Grid Setpoint Manual",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_select.helper_set_grid_setpoint_manual",
                "value": "",
                "value": "Grid_Setpoint_Manual",
                "valueType": "str"
        "for": "0",
        "forType": "num",
        "x": 462,
        "y": 496,
        "wires": [
                "2480c449d9716e60"
        "id": "f260543bfbdde534",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 188,
        "y": 496,
        "wires": [
                "74751d57aa8416a0",
                "a7e0db73832a5cbb"
        "id": "3ece2abbca2d3163",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 188,
        "y": 352,
        "wires": [
                "2a3f322e14d84e39",
                "f260543bfbdde534"
        "id": "1eec9131727da66b",
        "type": "debug",
        "name": "Dess Mode",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 714,
        "y": 256,
        "wires": []
        "id": "82f3a5ff3ee9a153",
        "type": "delay",
        "name": "",
        "timeout": "10",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 192,
        "y": 80,
        "wires": [
                "e3ab7c99eb67e29b"
        "id": "80c48da61dd9a224",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 724,
        "y": 544,
        "wires": [
                "5350a5134998b105"
        "id": "f49255091c284006",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 724,
        "y": 400,
        "wires": [
                "8b3c1e441c7c9f5b"
        "id": "30ee8cecfcfc54ae",
        "type": "catch",
        "d": true,
        "name": "",
        "scope": null,
        "uncaught": false,
        "x": 148,
        "y": 1104,
        "wires": [
                "c68dbf16e11e1f59"
        "id": "c68dbf16e11e1f59",
        "type": "debug",
        "name": "Catch All",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 156,
        "y": 1168,
        "wires": []
        "id": "5b62222534168e1d",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 432,
        "y": 400,
        "wires": [
                "f49255091c284006"
        "id": "2480c449d9716e60",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 432,
        "y": 544,
        "wires": [
                "80c48da61dd9a224"
        "id": "7c2d18692aa1bed1",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 432,
        "y": 208,
        "wires": [
                "ddfbf3bee58c04f8"
        "id": "e3ab7c99eb67e29b",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 428,
        "y": 80,
        "wires": [
                "871a1fa47acdfeca"
        "id": "7fd873ed597be391",
        "name": "Get EV Charger Mode",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_select.helper_set_ev_charger_mode",
                "value": "",
                "value": "EV_Charger_Mode",
                "valueType": "str"
        "for": "0",
        "forType": "num",
        "x": 452,
        "y": 640,
        "wires": [
                "64bbb78228dcf475"
        "id": "a7e0db73832a5cbb",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 188,
        "y": 640,
        "wires": [
                "7fd873ed597be391",
                "e8dad13d5830f775"
        "id": "64bbb78228dcf475",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 432,
        "y": 688,
        "wires": [
                "f0d3787a7042911b"
        "id": "f0d3787a7042911b",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 724,
        "y": 688,
        "wires": [
                "70c9defc6dd57e24"
        "id": "70c9defc6dd57e24",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.EV_Charger.Target_Mode",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 542,
        "y": 736,
        "wires": [
        "id": "5350a5134998b105",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Manual.Grid_Setpoint",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 532,
        "y": 592,
        "wires": [
        "id": "8b3c1e441c7c9f5b",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Manual.SoC_Min_Perc",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 532,
        "y": 448,
        "wires": [
        "id": "517fd4c22e8b1a48",
        "name": "Get EV Charger Start_Hour",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.helper_set_ev_charger_start_hour",
                "value": "",
                "value": "EV_Charger_Start_Hour",
                "valueType": "str"
        "for": "0",
        "forType": "num",
        "x": 472,
        "y": 784,
        "wires": [
                "63d5058a1ebccda0"
        "id": "e8dad13d5830f775",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 188,
        "y": 784,
        "wires": [
                "517fd4c22e8b1a48",
                "aac958992a766015"
        "id": "63d5058a1ebccda0",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 432,
        "y": 832,
        "wires": [
                "7c2880b04d0d97d3"
        "id": "7c2880b04d0d97d3",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 724,
        "y": 832,
        "wires": [
                "4084d4ad2462fca4"
        "id": "4084d4ad2462fca4",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.EV_Charger.Start_Hour",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 542,
        "y": 880,
        "wires": [
        "id": "1613f20b17d1c741",
        "name": "Get EV Charger Last_Hour",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.helper_set_ev_charger_last_hour",
                "value": "",
                "value": "EV_Charger_Last_Hour",
                "valueType": "str"
        "for": "0",
        "forType": "num",
        "x": 472,
        "y": 928,
        "wires": [
                "9ef7aaf7c9be5cbb"
        "id": "aac958992a766015",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 188,
        "y": 928,
        "wires": [
                "1613f20b17d1c741"
        "id": "9ef7aaf7c9be5cbb",
        "type": "function",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 432,
        "y": 976,
        "wires": [
                "52a3c1d8cd94a5f0"
        "id": "52a3c1d8cd94a5f0",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 724,
        "y": 976,
        "wires": [
                "65e1b17b04fe96a7"
        "id": "65e1b17b04fe96a7",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.EV_Charger.Last_Hour",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 532,
        "y": 1024,
        "wires": [
        "type": "server",
        "version": 5,
        "addon": false,
        "cacheJson": true,
        "heartbeat": false,
Afbeeldingslocatie: https://tweakers.net/i/WHwiY-tTj-z_5mBjcR7oeHTw28k=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/LnDDmR9xBaAgyKCelfmKNv9E.jpg?f=user_large
[ Voor 214% gewijzigd door MJ de Bruijn op 14-05-2024 15:13 ]
Een mens leert van zijn fouten. Ik heb in mijn leven heel veel geleerd.
  • MJ de Bruijn
Gereserveerd.
[ Voor 183% gewijzigd door MJ de Bruijn op 14-05-2024 14:51 ]
  • V_ger
  • Laatst online: 16:26
Zo te zien mooi stukje huisvlijt. Ik ben benieuwd naar het verschil in gedrag tov van DESS. Ik gebruik zelf DESS ook niet, met name om rare laad/ontlaad beslissingen (toch iig in het begin) en de extreme focus op de SOC ipv de prijs.
Hoe gaat jouw systeem om met een niet ondersteunde EV die ik inplug of een warmtepomp die WW gaat maken?
Ik regel het nu semi automatisch.
- Kale prijs < 0 PV beperken om invloeden te vermijden (ik kan niet altijd al mijn vermogen in de accus kwijt)
- Prijs inclusief belasting <0 PV uit en inkopen.
- EV eigenlijk altijd laden vanuit het net. Ik maak zelf een schedule aan voor de goedkope uren op de dagen dat ik wil laden. Als EV charger actief dan Victron gris set-point gelijk aan laadpaal vermogen.
- Ik tune zelf een beetje mijn prijs waarboven ik verkoop zodat ik nu sochtends een lege accu heb. In de winter vaak andersom. Maar het is wel elke dag werk om te kijken hoeveel uur ik kan ontladen. Dus niet ideaal.
Ivm geluid beperk ik savonds de max inverter power en laadstroom.
[ Voor 50% gewijzigd door V_ger op 14-05-2024 16:33 ]
ZP, Gasloos sinds 2017, Nibe F1155, 12.4kWp 30° O/W + 4.4kWp 0° + 3.7kWp 90° W, 3x Victron MP2-5000 + 60 kWh
  • MJ de Bruijn
V_ger schreef op dinsdag 14 mei 2024 @ 16:27:
Het belangrijkste verschil is dat het MESS iedere tien seconden opnieuw een strategie berekent. Daarmee wordt direct ingespeeld op verschillen met zonne-prognose en consumptie-prognose.
Het systeem kan, afhankelijk van de actuele SoC, eerder of juist later beginnen met laden van het Grid of ontladen voor verkoop. Als een strategie reeds begonnen is kan deze worden aangepast als het weer verandert.
Bij ontladen voor verkoop houdt het systeem rekening met te verwachten eigen gebruik. Als dit - in de loop van een nacht - meevalt zal een eventueel surplus bij een eerstvolgende gelegenheid alsnog worden verkocht.
Bij laden bij negatieve prijzen of nul-prijzen zal het systeem wachten tot de meest negatieve uren. Eventuele zon in de ochtend wordt eerst nog aan het grid geleverd tegen vergoeding. Maar, als de zonne-opbrengst tegenvalt ten opzichte van de prognose zal het laden worden aangepast.
Voor mij is de samenwerking met de EV lader heel belangrijk om EV en Victron gelijktijdig optimaal te kunnen laden. Ik zie regelmatig 3 x 24 Amp op de meter. Dat is het ingestelde maximum.
In principe zou het zo met een ander systeem kunnen samenwerken, mits dat systeem maar real-time kan worden aangestuurd om met een lager maximum te laden.
Naar mijn idee zou hier hetzelfde gelden. Wel moeten de verbruiks-gegevens real-time kunnen worden ingelezen. Afhankelijk van de warmtepomp kun je óf dat systeem bijsturen óf het Victron systeem bijsturen, of beide.
  • V_ger
Je draait het op de cerbo? Hoe is de cpu belasting? Die is hier namelijk al best hoog met 3x serial battery...
  • MJ de Bruijn
V_ger schreef op dinsdag 14 mei 2024 @ 16:44:
Ik heb daar niet eerder naar gekeken. Waar lees jij dat af?
  • V_ger
Ik merk het vooral aan de melding in VRM dat realtime updates zijn uitgeschakeld ivm hoge load. Anders kan je het via de command line op de cerbo inzien via "top". Of "htop". Die laatste zal je wel nog moeten installeren.
  • Samoerai
  • Laatst online: 13-10 12:08
Misschien een domme vraag. Maar wat is het doel van jouw implementatie? Zoveel mogelijk geld proberen te verdienen, zoveel mogelijk 0 op de meter of ?
  • MJ de Bruijn
V_ger schreef op dinsdag 14 mei 2024 @ 17:06:
Ik vond het een interessante vraag.
Ik heb in Node Red een nieuwe bibliotheek geïnstalleerd: "node-red-contrib-os (node)".
Deze geeft prima informatie.
Je vraag:
CPU belasting: 4.42% (1 minuut gemiddelde); 4.24% (5 minuten gemiddelde); 3.7% (15 minuten gemiddelde).
Geheugengebruik: 39,8%.
  • MJ de Bruijn
Samoerai schreef op dinsdag 14 mei 2024 @ 17:07:
Geen domme vraag, ik krijg deze zeer regelmatig.
Mijn doel is zo "optimaal" mogelijk gebruik maken van mijn batterij-systeem.
Prioriteit 1: Backup systeem bij Grid uitval.
Prioriteit 2: Mijn zonne-energie zo efficiënt mogelijk gebruiken. Goedkoop laden, bij hoge prijzen (eerst) aan het net leveren.
Prioriteit 3: Nul op de meter.
Prioriteit 4: Handelen met energie.
Geld verdienen is niet aan de orde. Het is een dure hobby en qua tijdsbesteding zijn er veel activiteiten waar je meer verdient dan met deze dingetjes.
  • RikHa
  • Registratie: September 2022
  • Laatst online: 15-11 23:42
Ik ben onder de indruk! Petje af hoor.
23 kWp, 80 kWh, 11 kW laden, 17 kW ontladen. Victron VRM
  • Activate
  • Laatst online: 01-11 09:49
Poeh knap stukje werk!
Ben helemaal niet thuis in Node Red heb het gedownload in HA maar nooit gebruikt.
Is het ook aan te passen als je geen EV charger hebt?
Kunnen de prioriteiten ook anders ingesteld worden?
Zijn het betaalde abonnementen bij Forecast en Day ahead?
[ Voor 12% gewijzigd door Activate op 16-05-2024 15:56 ]
  • MJ de Bruijn
Dank. Dat vind ik leuk om te horen.
Als je al bekend bent met 'iets' van programmeren is Node Red slechts een andere variant. Het is voornamelijk invoer en uitvoer voor de 'echte' logica die je in JavaScript functies plaatst.
Jazeker. Als de auto niet is aangesloten doet deze 'flow' ook niets.
Ja, dat kan door wijzigingen in het 'brein' programma. Dit is niet zo maar instelbaar omdat ik een bepaald doel voor ogen had.
Maar, bijvoorbeeld de grens wanneer tarieven 'laag' zijn of 'hoog' zijn is simpel in de stellen. Ook het prijsverschil tussen verkoop en inkoop om te handelen is in te stellen.
Die zijn kosteloos.
  • Activate
Klinkt interessant.
Ik heb dus ook een deel op Oost West en 8 panelen op bijna zuid...
Ik zie er nog tegenop om het allemaal te integreren, maar het is zeker interessant!
Hier alles op 1 Fase met een SEH 5000 en een Cerbo MkII en een Multiplus 5000 en een accu van 15 Kwh
Ik zou de prioriteiten voor mij iets anders zetten , heb de afgelopen 2 jaar nog geen geen griduitval gehad, dus voor mij iets minder interessant, en 3 en 4 zou ik willen omdraaien.
[ Voor 46% gewijzigd door Activate op 16-05-2024 23:37 ]
  • antoine sellies
  • Laatst online: 04-05-2025
Goedenavond,
Iemand en goedkope website voor een zelfbouw set
Alle info is welkom
  • SHIFTER [NL]
  • Laatst online: 28-10 21:28
Heel gaaf om te zien wat je gemaakt hebt!! _/-\o_
Ben druk bezig met het bouwen (hardware kant) aan mij eigen ESS systeem. Dit zal zeker als inspiratie dienen zodra ik met de software kant bezig ga.
3x Victron MP2-5000 | 52.5 kWh thuisaccu | 9.600 Wp Zonnepanelen | Gasloos | WP Boiler | Lucht-Lucht WP
  • Niek_
  • Laatst online: 11:17
Ik ga mij hier toch maar eens in verdiepen. Enige onafhankelijkheid van bijvoorbeeld het laden van energieprijzen vanuit 1 bron of aansturing van DESS is wellicht handig gezien het functioneren van de afgelopen dagen :)
Dan gelijk aan de slag met een andere ergernis, de laadpaal die geen vermogen krijgt als de Multiplussen maximaal aan het laden zijn omdat loadbalancing dan aangeeft dat er onvoldoende ruimte op de hoofdzekering is. Als ik in de Cerbo kan aangeven dat de laadpaal ingeplugd is en vermogen vraagt dan kan die de Multiplussen wat minder hard laten laden zodat er voldoende ruimte op de hoofdzekeringen is om het laden van de auto te starten. Dat moet als ik dit zo allemaal lees ook in Node Red kunnen.
  • MJ de Bruijn
Leuk als je er iets aan zou hebben.
Ik heb inmiddels nog wel aanpassingen gedaan, dus als je een specifiek element aanpakt, laat het even weten. Dan plaats ik een actuele stand.
Ook het MESS is afhankelijk van externe bronnen voor Solar en prijzen. Ik heb wel een e-mail waarschuwing toegevoegd als deze niet op tijd worden ontvangen.
Voor de prijzen kun je dan de volgende dag met de hand invullen of (iets makkelijker) uit een menu van Home Assistant kiezen.
Voor Solar werk ik aan een back-up via een Australische website. Dat is nog niet af.
  • MJ de Bruijn
Voor wat betreft de aansturing van het laden van je auto... dit onderdeel kun je waarschijnlijk ook apart implementeren. Ik zie geen reden waarom dit niet ook met DESS zou kunnen samenwerken.
Je moet wel het verbruik van je laadstation kunnen uitlezen én instellen.
  • Edwin de Jonge
  • Laatst online: 09-08 11:49
Leuk dat je kennis en kunde wil delen. Ik zit zelf ook met een solaredge installatie en een 3 fase aansluiting. Hoe heb je de ET340 aangesloten. Kan je deze direct via de RS485 Modbus-poort aansluiten op de omvormer? Zou je het zignee gedeelte ook kunnen gebruiken indien de omvormer ook zigbee heeft.
  • MJ de Bruijn
Edwin de Jonge schreef op woensdag 18 september 2024 @ 10:29:
Ik heb de kabel van de SolarEdge aangesloten op de ingang van de ET340 en de uitgang van de ET340 naar de verdeler in de groepenkast.
Is dat wat je bedoelt?
Ik heb de RS485 kabel van de ET340 aangesloten op een Cerbo. Ik heb geen koppeling tussen SolarEdge en de Cerbo.
Zou je het zigbee gedeelte ook kunnen gebruiken indien de omvormer ook zigbee heeft.
Ik weet wat Zigbee is, maar ik heb geen kennis over zo'n koppeling.
Ik zou zelf nooit voor een "extra" protocol kiezen of voor een andere draadloze oplossing.
  • Eric_van_Rijn
  • Registratie: December 2024
  • Laatst online: 22-12-2024
Heel knap stukje werk. Ik heb met een simpele DESS aan de gang gekregen.
Ben me nu langzaam in de NoteRed wereld aan het verdiepen, leer veel val je omschrijvingen
  • Kecin
Kecin
Je keek.
Super opzet. Ik zie in de TS staan dat er minimaal 3 batterijen gebruikt moeten worden. Mijn samenstelling zou een systeem van 3 Fase Multiplussen zijn en 2 batterijen voor een totaal van 32,2 kWh. Gezien die allemaal op dezelfde dc rail zitten ga ik ervanuit dat het enige probleem waar ik tegen aan zou lopen het maximale opladen en ontladen zal zijn?
🔥WTP: Mitsubishi Ecodan (ERST30F-VM2EE -PUZ-SWM120YAA) 🔋 Victron Multi RS Solar, 64.4kWh accu ☀️SE 5.400WP noord, 11,155WP zuid 🚗Onderweg; Tesla Model Y '26, Fiat 500E 42kWh
  • MJ de Bruijn
Kecin schreef op zaterdag 21 december 2024 @ 08:33:
Zo te zien vraag je me of ik het met je eens ben.
Daarvoor geef je veel te weinig informatie.
Welk type multiplus? Wat voor dc rail? Lynx? Wat voor batterijen? Twee stuks voor 32 kWh? Dat is knap.
Stel je vraag beter in "het grote Victron ontwerp topic".
  • Cereal
  • Laatst online: 16-11 09:19
Hey @MJ de Bruijn , ik ben m'n eerste stapjes op NodeRed gebied aan het zetten, heb ook geen andere programmeer ervaring.
Ik wil je EV implementatie overnemen, ik heb NodeRed op Cerbo GX draaien, doel is om de auto altijd vanuit het net te laten laden. Op HA is m'n Victron plugin kapot gegaan, zou het graag op de cerbo draaien.
Victron EV charger zit op AC Out, net als de rest van m'n huis.
Ik krijg een foutmelding bij het copy-pasten van je NodeRed flow:
Afbeeldingslocatie: https://tweakers.net/i/QQHfDmkGn8BmDnFJBmT0VsY8n2o=/800x/filters:strip_exif()/f/image/Ko9vIrhocStBmo17uKFVGHqW.png?f=fotoalbum_large
Dus ik loop gelijk vast :), help..
  • MJ de Bruijn
Hallo Cereal,
Leuk dat je dit ontwerp wilt nabouwen / kopiëren,
Helaas voegt de browser opmaak-codes tussen om de tekst leesbaar te maken. In de originele JSON zijn veel minder regel-eindes aanwezig.
De fout die je aantreft komt mogelijk doordat ik de Javascript-tekst van de functie "Calc EV-Charge Settings" separaat heb geplaatst. Dit was nodig door de maximale toegestane lengte van items in het forum.
In je scherm-afdruk zie je de tekst "// zie separate post voor JavaScript tekst" en dan een blanco regel.
Verwijder die blanco regel en zorg dat de afsluitende dubbele quote direct achter het woord "tekst" komt te staan. Probeer het dan nog een keer.
Als dit werkt moet je de functie-node openen en de tekst van het bijbehorende item plakken.
Helaas kunnen opmaak-codes van de website of de browser dit soms moeilijk maken.
Je zult ook tegen hobbels aanlopen dat entities bij jou verschillen van die bij mij.
Je moet dus meerdere nodes aanpassen.
Succes! Ik ben benieuwd...
  • MJ de Bruijn
Nog iets...
Je schrijft dat je nieuw bent met Node Red en geen programmeer-ervaring hebt.
Dan is "deze" toepassing best een kluif (understatement).
Om meer te leren van programmeren in Node Red zou je de volgende bijdrage kunnen volgen:
Victron, Monitoring, Waarschuwingen en Alarmen
Dat is iets anders dan je nu wilt bereiken, maar diverse technieken komen daar aan de orde.
  • Cereal
Dank, met ChatGPT heb ik al het e.e.a. aan de praat kunnen krijgen, een basis "If status is charging, then AC Powerpoint 11kw" moet me wel lukken een dezer dagen :)
Mooi topic ook over monitoring/waarschuwingen/alarmen, ik ga er de komende tijd eens lekker voor zitten.
  • blokl
  • Laatst online: 16-09 16:14
Beste @MJ de Bruijn ,
Zo te zien is het een mooi stukje werk. Ik heb ongeveer dezelfde Victron configuratie en ben ook voorstander van het zelf aansturen van de Dess omgeving.
Ik kom er alleen niet achter hoe de Homeassistant koppelingen werken. Misschien dat je dat nog eens kan uitleggen?
Met vriendelijke groet,
Leo
  • MJ de Bruijn
Ik heb de ontwikkelingen van die koppelingen niet exact gevolgd. Wel weet ik dat er "gerommeld" is met versies, forks of zo iets.
In Node Red, kies rechtsboven het "hamburger-menu". Dat zijn de drie liggende streepjes boven elkaar.
Kies dan de optie "Manage Palette".
Als je bij tabblad "Nodes" al iets van Victron hebt geïnstalleerd, verwijder dat dan eerst.
Voorts kies je bij tabblad "Install" --> zoek Victron.
Selecteer: @victronenergy/node-red-contrib-victron
Ik heb (nu) versie 1.6.11.
Kies voor install.
Als dit succesvol was zul je links de Victron Nodes aantreffen.
  • blokl
Ik heb ze opnieuw geïnstalleerd, maar kom nog niet echt verder.
Ik zie een "victron energie client" maar voor de rest krijg ik "Unable to access the service endpoint:/endpoint/victron/services/?????"
Dus ik denk dat ik nog wat mis?
  • MJ de Bruijn
blokl schreef op maandag 17 maart 2025 @ 16:38:
Geef svp aan waar je de "Victron Energie Client" ziet. Ik herken dit niet.
Maak een schermafdruk.
Ook de "Unable to access the service endpoint:/endpoint/victron/services/?????"
herken ik niet van eigen ervaring.
Beschrijf stap voor stap wat je voorafgaand doet en maak weer schermafdrukken.
  • blokl
I intalled the node red module you mentioned. If this is the only one I needed then is only the next screen view important.
You don’t make a connection from home assistant to th Victron with a modbus or something or the module from hac?
Regards,
Leo
Afbeeldingslocatie: https://tweakers.net/i/v0nmgcCDNiqZOZESUHDCy8zzn6g=/800x/filters:strip_icc():strip_exif()/f/image/05bw6pDQqmwoly4fqSYEwofe.jpg?f=fotoalbum_large
[ Voor 234% gewijzigd door teacher op 13-10-2025 13:26 ]
  • MJ de Bruijn
blokl schreef op dinsdag 18 maart 2025 @ 21:56:
I don't have a DC source available, so I can't reproduce your Node.
Please try.
In Node Red, open the config tab in the right upper corner. The steering-wheel symbol.
Under 'On All Flows', do you (still) see the 'Victron Energy Client' Config-Node?
Are both options activated?
I don't use Modbus, however, this might be working somewhere on the background.
You say, the only Node you need is the DC source Node. Perhaps, this is not available and/or configured in your Victron setup.
Please try (for example) the VE.Bus System Node for reading.
Select any relevant option of you choosing. Send the output to a debug Node.
If this works, Node Red does communicate. Perhaps you have to experiment with your DC configuration in Victron.
If this doesn't work, then I don't know either.
  • blokl
Can you publish you node red tab from home assistant?
I think it wil help me a lot
Thx
  • MJ de Bruijn
Perhaps I do understand now what your situation is.
Are you working within Home Assistant with Node Red?
I assumed you were working with Node Red from within the Victron environment itself.
From Home Assistant you cannot reach the Victron system.
You have to install Node Red in the Cerbo of your Victron.
Is this your situation?
  • John245
  • Registratie: Januari 2020
(overleden)
MJ de Bruijn schreef op woensdag 19 maart 2025 @ 15:55:
@blokl In case you don't want to use the preferred method you have to follow the manual install.
https://flows.nodered.org.../node-red-contrib-victron
  • blokl
I have installed Node Red in the Cerbo and in HomeAssistant.
I asumed your setup is to send and receive data from the Cerbo to Node Red in HomeAssistant.
So now I untherstand your Node Red dashboard is also on the Cerbo?
  • MJ de Bruijn
blokl schreef op woensdag 19 maart 2025 @ 17:02:
Yes indeed!
A lot of misunderstanding, but, in the end, the matter became clear.
I hope you will be more succesful when you try working in Node Red on the Cerbo.
Good luck.
  • sennevb
  • Laatst online: 10-03 20:02
Ik ben bezig met mijn installatie ook samen te stellen.
Ik wou DESS gaan gebruiken, heeft jou MESS een beter rendement omdat hij beter inspeelt op veranderingen?
Zoja, wat is je geschatte rendementswinst?
Ik wil er wel mee gaan grasduinen, maar als het teveel geklooi is voor maar 1% meer rendement ga ik dat natuurlijk niet op mijn nek halen
Alvast dank voor je reactie @MJ de Bruijn
  • MJ de Bruijn
sennevb schreef op maandag 7 april 2025 @ 19:29:
Ik heb geen idee over het verschil in rendement.
Er is wel een verschil in uitgangspunt.
DESS zoekt (voor zover ik weet) het hoogste financiële rendement, ook als de batterij leeg raakt of leeg blijft.
MESS probeert iedere dag de batterij volledig vol te laden, liefst door zon, anders door Grid, per saldo zo goedkoop mogelijk. Daarnaast zoekt MESS naar opties om iets te verdienen.
En over "op je nek halen": het DESS is klaar en doet alles.
Mijn MESS is een eigen bouw en kan alleen maar als inspiratie dienen voor iemand die ook zelf iets wil bouwen.
  • sennevb
thanks voor de toelichting! ik wil eigenlijk een combi van de 2: in de zomer is er overschot, deze dan verkopen aan de hoogst mogelijke prijs. in de winter is er tekort of geen zon, dan laden aan de laagst mogelijke prijs.
Ik bekijk het even!
  • luigi87
  • Laatst online: 15-11 16:38
luigi87
Domotica Fanaticus
Je hebt van je beschrijving wel werk gemaakt.
Top _/-\o_
Ik ga hier eens de tijd voor nemen, jouw uitgangpunten zijn gelijk aan die van mij.
Dus ga veel van je overnemen en leren ;)
- leeg -
  • SHIFTER [NL]
Heel interessant dit! Wil hier ook eens mee gaan stoeien.
Zou je de laatste stand JSON van jouw Node-Red kunnen delen?
  • MJ de Bruijn
SHIFTER [NL] schreef op maandag 13 oktober 2025 @ 13:09:
Dat gaat niet heel gemakkelijk.
Het geheel bestaat uit meerdere tabbladen. Ieder tabblad bevat de logica voor een bepaald aspect, initialisaties, entiteit-statussen, solar, dayahead-prijzen, de 'planning', auto-laadstation met overbelasting-bescherming etc.
Een JSON van een tabblad is veel te groot om in een tweakers-post te passen. Daarom heb ik eerder alles in stukjes gebroken. En verder ligt alles nu 'overhoop' omdat ik aan het aanpassen ben van uur-prijzen naar kwartier-prijzen.
Kortom, zomaar even delen is niet aan de orde.
Maar, als je aangeeft welk aspect je wilt aanpakken, dan kan ik zien wat ik daarvoor geschikt kan maken.
  • gerwin16
  • Laatst online: 18-03 21:56
Dank voor het delen van jouw Victron MESS setup.
Ik ben bezig met mijn eigen MESS implementatie met inspiratie bron jouw Victron MESS setup. Ik heb het nu draaiende, maar was benieuwd wat jij ondertussen nog aangepast hebt aan de setup. Zou je dat kunnen delen?
  • MJ de Bruijn
gerwin16 schreef op donderdag 27 november 2025 @ 21:55:
Leuk dat je iets hebt aan mijn beschrijving van Mijn ESS (MESS).
Er is inmiddels een heleboel aan gewijzigd en ik ben daar nog niet klaar mee.
Het belangrijkste is de overschakeling van uur-prijzen naar kwartier-prijzen. Dit vergt een heel andere benadering hoe je naar (prijzen in) de toekomst kijkt.
Als ik dit gereed heb, ben ik voornemens om een beschrijving te maken van de nieuwe methodieken.
Nog even geduld graag.
  • SHIFTER [NL]
Ben heel benieuwd! Ben ook nog bezig met het opzetten van een systeem aan de hand van jouw voorbeeld :D
  • MJ de Bruijn
Kwartierprijzen
Sinds 1 oktober 2025 berekenen dynamische energie-leveranciers hun prijzen per kwartier in plaats van per uur. Dit heeft grote invloed op de planning van laden, ontladen, actief verkopen, extra inkopen etc.
In principe zijn er voor het instellen van de Vistron vier opties:
1. Gebruik maken van de balans van zonne-energie.
2. Batterij laten slapen.
3. Actief/geforceerd verkopen.
4. Laden/inkopen van Grid.
Dit is het standaard gedrag van ESS. De batterij wordt opgeladen als er overschot aan zonne-energie is en de energie uit de batterij wordt gebruikt als er niet voldoende zonne-energie is, typisch 's nachts. Dit zal typisch in de zomer van toepassing zijn. De SoC (State-of-charge) van de batterij zal fluctueren tussen vol en (bijna) leeg.
Als de elektriciteitsprijs langer achtereen (ongeveer) gelijk is, is het niet zinvol om de batterij te gebruiken. De conversie-verliezen van laden en ontladen zullen dan groter zijn dan de kleine verschillen tussen prijzen in opvolgende perioden. In zo'n geval is het beter om de batterij te laten 'slapen' en het Grid rechtstreeks te gebruiken.
Indien de capaciteit van de batterij het toelaat kun je een overschot aan energie terugleveren aan het stroomnet. Bij een dynamisch contract krijg je dan in principe de actuele stroomprijs terugbetaald, vooralsnog inclusief belasting. Wanneer je dan later de batterij weer oplaadt met een lager tarief kun je aldus enige winst behalen. Hierbij moet je wel rekening houden met conversie verliezen van circa 20 tot 30%.
Als een periode van hoog tarief nadert en de batterij is (nog) niet vol kun je de batterij extra vullen vanaf het Grid. Dit kan zinvol zijn als het aankomende verkoop-tarief hoog genoeg is en de batterij ruimte heeft om extra voorraad op te slaan. Ook hier is relevant dat het verschil tussen nu inkopen en later verkopen groot genoeg is om, rekening houdend met conversie-verliezen, nog enige winst te halen.
Een andere reden om (extra) van het Grid te laden is om (typisch in de winterperiode) de batterij dagelijks tot 100% te laden.
Bij uurtarieven was het relatief eenvoudig om een keuze te maken uit deze opties. Je hoefde slechts het tarief van het eerstvolgende uur of daarop volgende uur te bezien om een keuze te maken uit deze opties.
Bij kwartiertarieven moet je - in aantallen - veel meer opties bezien. Ieder kwartier krijgt een eigen keuze van laden/ontladen/slapen etc. Om vast te stellen of een optie rendabel is moet je een groot aantal kwartieren in de toekomst in beschouwing nemen. Een verkoop-kwartier (hoge prijs) wordt daarbij gekoppeld aan een compensatie-kwartier (lage prijs). Daarbij moet je opletten dat je een 'compensatie-kwartier' niet dubbel toekent aan twee of meer verkoop-kwartieren.
  • MJ de Bruijn
Tibber en de Tibber Api
Net zoals ENTSO-E biedt Tibber een optie om de tarieven automatisch op te halen. Dit gaat met een API, een Application Program Interface.
In Node Red van Victron kun je een uitbreiding installeren.
• Klik rechtsboven op het 'hamburger' menu, zo worden de drie liggende streepjes genoemd.
• Kies de optie Manage Palette. Alternatief, toets <alt> + <p>.
• Er verschijnt een scherm User Settings. Kies het tabblad Install en zoek naar Tibber.
• Selecteer node-red-contrib-tibber-api en klik op de keuze Install.
In het palette-menu links zijn nu de Tibber API Nodes beschikbaar.
Afbeeldingslocatie: https://tweakers.net/i/9FGTlJOIonFcQCqVB2ba8m1fkMU=/fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():strip_exif()/f/image/5EXe0t38n6kk190jgz7uViU1.jpg?f=user_large
Ik gebruik alleen de Tibber - data node. Wanneer je deze kiest moet je eerst je toegang tot Tibber instellen.
Twee zaken zijn van belang: Je Home ID en een Access Token. Deze kun je ophalen met je Tibber account.
Lees allereerst https://developer.tibber.com/docs/guides/calling-api
Daar staat een verwijzing naar de site voor het aanvragen van een token.
Wanneer je inlogt wordt jouw persoonlijke Access Token getoond. Kopieer deze en bewaar deze op een geschikte (veilige!) plaats zodat je deze later kunt vinden en kopiëren.
Afbeeldingslocatie: https://tweakers.net/i/dHG5tML9oV9UAkLwBDE5w7EEo6g=/800x/filters:strip_icc():strip_exif()/f/image/hD2qhSCsDTNG70OxVEAwEond.jpg?f=fotoalbum_large
Je Home ID kun je eveneens online opzoeken via https://developer.tibber.com/explorer
Afbeeldingslocatie: https://tweakers.net/i/eoKpizDynCKO5XMazTtI0G8ELhA=/800x/filters:strip_icc():strip_exif()/f/image/TwYhrFRH6rB2tqckfqZOLl2A.jpg?f=fotoalbum_large
1. Ga naar de genoemde website en login met je Tibber account-gegevens.
2. Bij de optie Load an example kies
3. Homes
4. In het query-voorbeeld links, voeg een regel toe met de identifier id
5. Klik op de paarse knop
6. In het resultaat verschijnt de Home id.
Kopieer deze en bewaar deze op een geschikte (veilige) plaats.
Je kunt nu een eenvoudige test-flow maken:
Afbeeldingslocatie: https://tweakers.net/i/hmVcT3HYMbHXmU-YzARUhXuDMEo=/800x/filters:strip_exif()/f/image/SjSKHtDASwheNOHkw2PZiMmn.png?f=fotoalbum_large
Ik gebruik hiervoor een tibber - data node:
Afbeeldingslocatie: https://tweakers.net/i/0j8HZqNH_O1ANir9OZMQkf3yw-E=/fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():strip_exif()/f/image/xyXKYMgl7K6SmoYxvJ4HY6E1.jpg?f=user_large
Via deze node moet je de configuratie node instellen:
Afbeeldingslocatie: https://tweakers.net/i/DZfXVkq5MH5lk4NDW-HOVZ4LuWs=/fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():strip_exif()/f/image/LVa9gHDSLzQ5yEysbeMGbrCk.jpg?f=user_large
Als dit succesvol is gelukt kun je via de Trigger node de API aanroepen.
Als het goed is verschijnt dan in het debug-scherm rechts je eerste resultaat.
Afbeeldingslocatie: https://tweakers.net/i/QaJx4Vp5vbCXMmtmQ3R9xC3yhIg=/x800/filters:strip_icc():strip_exif()/f/image/a6a7OroQ1039yVU6Onz3iY7f.jpg?f=fotoalbum_large
In een volgende bijdrage zal ik beschrijven hoe je de gegevens dagelijks kunt ophalen.
  • MJ de Bruijn
Tibber - Dagelijks Ophalen Kwartierprijzen
Ik ben overgestapt naar een dynamisch elektriciteits-contract bij Tibber. Daarmee heb ik ook toegang tot de API met de dagelijkse prijzen van Tibber. Zie: Tibber en de Tibber Api
Alle gegevens van het MESS programma, en dus ook de Tibber data, worden bewaard in een geheugengebied Context Data --> Global
Afbeeldingslocatie: https://tweakers.net/i/HJ8MbxIeymuS12KOUZlLaQ0ZRVw=/x800/filters:strip_icc():strip_exif()/f/image/VjlA6BB7yEImosuOrHlZVKIc.jpg?f=fotoalbum_large
Om de gegevens van Tibber periodiek op te halen heb ik een Node Red Flow gemaakt.
Afbeeldingslocatie: https://tweakers.net/i/afhDKSNA3bsVFP--ZWetga-8YUQ=/x800/filters:strip_icc():strip_exif()/f/image/D9RHerghVVUWbkaIY6uHa37I.jpg?f=fotoalbum_large
Omdat het aantal nodes vrij groot is zal ik niet van iedere node een schermafdruk plaatsen maar alleen de tekstuele inhoud vermelden. Ik volg de Flow-afbeelding van boven naar onder.
Change NodeDelete All TibberIedere nacht om tien minuten na middernacht verwijder ik alle aanwezige gegevens. De tien minuten 'wachttijd' zijn bedoeld om eventuele drukte bij Tibber te laten passeren om de kans op timeouts te verminderen. Ik gebruik hiervoor een cron-job, maar ook een Inject node zou volstaan.
Delete
global.Victron_MESS.LastRun.Tibber
Delete
global.Victron_MESS.Tibber
Set
global.Victron_MESS.LastRun.Tibber.Delete
to the value J:_expression
$moment().format("YYYY-MM-DD HH:mm:ss")
Switch NodeIf Tibber.Today_QH is NULL or notDe afkorting QH staat voor Quarter Hour, ofwel kwartier. Deze afkorting wordt in veel namen gebruikt.
... Propertyglobal.Victron_MESS.Tibber.Today_QH
is Null--> 1Voor een toelichting op het gebruik van de Watchdog zie: Waakhond in "Het grote Victron Node Red topic"
otherwise--> 2
SubflowShow Topiczie Show Topic en Show Payload in "Het grote Victron Node Red topic"
Tibber-data NodeGet Tibber Today-QH
API EndpointTibber Config Node
NameGet Tibber Today_QH
QuerygetTodaysEnergyPrices(himeID)
Home IDje privé Home IDVoor het verkrijgen van de juiste Home ID, zie: Tibber en de Tibber Api
Energy ResolutionQUARTER_HOURLY
Last Count10
Change NodeSet Tibber Today_QHDe opgehaalde gegevens worden bewaard in de context Global geheugenruimte
Set
msg.topic
"Today_QH: " & $string($count($.payload)) & " items"
Set
to the value
msg.payload
V Deep copy value
Set
global.Victron_MESS.LastRun.Tibber.Today_QH
$moment().format("YYYY-MM-DD HH:mm:ss") & ": " & $string($count($.payload)) & " items"
Switch NodeIf Tibber.Today has responseMessageIndien er bij Tibber iets fout gaat bevat het retour-bericht een item 'responseMessage'
... Propertyglobal.Victron_MESS.Tibber.Today_QH.responseMessageDe controle vindt plaats op de opgeslagen kopie van het retour-bericht.
is not Null--> 1Een fout wordt in de pauze stand gezet omdat een volgende poging mogelijk wel succesvol is. Voor een toelichting op het gebruik van de Watchdog zie: Waakhond in "Het grote Victron Node Red topic"
otherwise--> 2
Switch NodeCount Today_QH 96 or notIn principe stuurt Tibber een lijst met 96 items terug. 24 uur met ieder 4 kwartier-prijzen. Echter, bij wisseling van zomertijd naar wintertijd en omgekeerd kan het aantal items ook 92 of 100 zijn.
... Property$count($.payload)
is between
92Bij een correct aantal elementen zal de verwerking verder gaan. Indien het aantal elementen niet juist is wordt een foutmelding-procedure gestart.
and
100 --> 1
otherwise--> 2
Change NodeDelete Tibber.Tomorrow_QHIndien de gegevens van de actuele dag correct zijn opgehaald worden de (eventueel nog aanwezige) gegevens van de volgende dag verwijderd.
Delete
global.Victron_MESS.Tibber.Tomorrow_QH
Change NodeDelete DayAhead AllOok de tabellen met alle planningen gebaseerd op DayAhead-tarieven moeten worden verwijderd.
Set
msg.topic
to the value
Delete DayAhead ALL
Delete
global.Victron_MESS.DayAHead
Delete
global.Victron_MESS.LastRun.DayAhead
Set
Switch Node15:00-23:00 / NOTOmdat de gegevens van de volgende dag pas na 15:00 uur beschikbaar zijn moeten deze ook pas na 15:00 worden opgehaald. Als de tijd eerder is vervolgt de verwerking zonder het ophalen van de volgende dag gegevens.
JSONata exp J:(
$nowHour := $moment().format("HHmm");
$nowHour >= "1500" and $nowHour <= "2301"
--> 1
otherwise--> 2
Change NodeRead Global Tomorrow_QHAllereerst wordt bezien of de gegevens van de volgende dag al beschikbaar zijn. Zo ja, dan worden deze in de payload geplaatst voor verdere verwerking.
Set
msg.payload
to the value
V Deep copy value
Switch NodeIf NULL or notAls de gegevens van de volgende dag er niet zijn (NULL) gaat de verwerking naar het ophalen. Als de gegevens er wel zijn (otherwise) wordt gecontroleerd op de gegevens bruikbaar zijn.
... Propertyglobal.Victron_MESS.Tibber.Tomorrow_QH
otherwise--> 2
Switch NodeIf has responseMessageIndien er bij Tibber iets fout gaat bevat het retour-bericht een item 'responseMessage'
... Propertyglobal.Victron_MESS.Tibber.Tomorrow_QH.responseMessageDe controle vindt plaats op de opgeslagen kopie van het retour-bericht.
otherwise--> 2
Switch NodeCount 96 or notIn principe stuurt Tibber een lijst met 96 items terug. 24 uur met ieder 4 kwartier-prijzen. Echter, bij wisseling van zomertijd naar wintertijd en omgekeerd kan het aantal items ook 92 of 100 zijn.
is between
and
100 --> 1
otherwise--> 2
Tibber-data NodeGet Tibber Tomorrow-QH
NameGet Tibber Tomorrow_QH
Last Count10
Change NodeSet Tibber Tomorrow_QHDe opgehaalde gegevens worden bewaard in de context Global geheugenruimte
Set
msg.topic
"Tomorrow_QH: " & $string($count($.payload)) & " items"
Set
to the value
msg.payload
V Deep copy value
Set
global.Victron_MESS.LastRun.Tibber.Tomorrow_QH
Switch NodeIf Tibber.Tomorrow has responseMessageIndien er bij Tibber iets fout gaat bevat het retour-bericht een item 'responseMessage'
otherwise--> 2
Switch NodeCount Tomorrow_QH 96 or notIn principe stuurt Tibber een lijst met 96 items terug. 24 uur met ieder 4 kwartier-prijzen. Echter, bij wisseling van zomertijd naar wintertijd en omgekeerd kan het aantal items ook 92 of 100 zijn.
is between
and
100 --> 1
otherwise--> 2
Change NodeDelete DayAhead AllDe tabellen met alle planningen gebaseerd op DayAhead-tarieven moeten worden verwijderd. Deze moeten opnieuw worden gemaakt op basis van de nu aanwezige gegevens van de actuele en de volgende dag.
Delete
Delete
Set
Switch Nodeif DayAHead.QH_CT is NULLDe controle of de DayAhead gegevens er (al) zijn wordt niet alleen uitgevoerd na het ophalen van Tibber data maar ook iedere minuut.
Als de DayAhead Tabellen er niet zijn gaat de verwerking verder met de functie Generate QH_ct.
Als de DayAhead gegevens meer dan een uur niet beschiklbaar zijn zal de Watchdog dit rapporteren.
... Propertyglobal.Victron_MESS.DayAhead.QH_Ct
is null--> 1
otherwise--> 2
Inject NodeDebug OnDe Inject Nodes Debug On en Debug Off kunnen gebruikt worden voor debug-doeleinden.
msg.debugtrue
Inject NodeDebug Off
msg.debugfalse
functieGenerate QH_Ct
Deze functie leest de Tibber data van de actuele dag en de volgende dag (indien beschikbaar) uit de Context Global geheugenruimte.
Er wordt een tabel gemaakt (QH_Ct) met 192 waarden 'prijs per kwartier'. Ook wordt een tabel (QH_Level) gemaakt met de beoordeling (door Tibber) of de prijs low, normal, expensive of very expensive is.
Ook deze tabellen worden bewaard in de context Global geheugenruimte onder de groep 'DayAhead'.
Zie de programma-code onderaan.
SubflowTopic to LastRunDe werking van deze functie zal ik t.z.t. beschrijven in "het Grote Victron Node Red topic".
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
// Generate tibber Array
context = context || {};
GetNowTime = global.get("Victron_MESS.Functions.GetNowTime");
GetTomorrow = global.get("Victron_MESS.Functions.GetTomorrow");
let NowTime = GetNowTime("NowTime");
let NowHour = GetNowTime("NowHour");
let NowQH = GetNowTime("NowQH");
let Nowyyyymmdd = GetNowTime("yyyymmdd");
let Tomorrowyyyymmdd = GetTomorrow("yyyymmdd");
if (context.Debug == null)
    context.Debug = false;
if (msg.debug != null)
    context.Debug = msg.debug;
    node.warn("Debug: " + context.Debug);
    node.status( {fill: "blue",
              shape:"dot",
              text: "@ " + NowTime + "; Debug "
                + context.Debug }
    return null;
Round = global.get("Victron_MESS.Functions.Round");
TimestampTo_QH =
   global.get("Victron_MESS.Functions.TimestampTo_QH");
if (context.Last_QH_Ct == null)
    context.Last_QH_Ct = [];
var QH_Ct= [];
var QH_Level= [];
let msg_QH_Ct = null;
var StatusColor = 'red';
var TibberPriceArray = "";
for (D=0; D<2; D++) // two days
    if (D == 0)
        TibberPriceArray = global.get( "Victron_MESS.Tibber.Today_QH");
        if (context.Debug) { node.warn(TibberPriceArray) }
        if ( (TibberPriceArray == "")
          || (TibberPriceArray == null) )
            node.warn("Today_QH is NULL")
        for (let i = 0; i < 96; i++)
            QH_Ct[i] = -99;
            QH_Level[i] = "unknown";
    else
        TibberPriceArray = global.get( "Victron_MESS.Tibber.Tomorrow_QH");
            if (NowHour >= 15)
                node.warn("Tomorrow_QH is NULL")
        for (let i = 96; i<192; i++)
            QH_Ct[i] = -99;
    if ( (TibberPriceArray != "")
      && (TibberPriceArray != null) )
        if (context.Debug)
            node.warn("Process: Day: " + D
            + " Length: " + TibberPriceArray.length);
        for (let i=0; i<TibberPriceArray.length; i++)
            let total = TibberPriceArray[i].total;
            let energy = TibberPriceArray[i].energy;
            let tax = TibberPriceArray[i].tax;
            let level = (TibberPriceArray[i].level).toLowerCase();
            let EnergyCt =
              Math.round( energy*1000 + 0.5 ) / 10;
            let startsAt = TibberPriceArray[i].startsAt;
            // node.warn(startsAt);
            let PriceTimeStamp = new Date(startsAt);
            let Priceyyyymmdd = PriceTimeStamp.getFullYear()
                 + ("0" + (PriceTimeStamp.getMonth() + 1)).slice(-2)
                 + ("0" + PriceTimeStamp.getDate()).slice(-2) ;
            // node.warn(Priceyyyymmdd);
            let Price_QH = TimestampTo_QH(startsAt);
            // node.warn(Price_QH);
            if (Priceyyyymmdd == Nowyyyymmdd)
                QH_Ct[Price_QH] = EnergyCt;
                QH_Level[Price_QH] = level;
            else if (Priceyyyymmdd == Tomorrowyyyymmdd)
                QH_Ct[Price_QH + 96] = EnergyCt;
                QH_Level[Price_QH + 96] = level;
            else
                node.warn("Unknown Date: " + Priceyyyymmdd);
        } // for TibberPriceArray length
        StatusColor = 'green';
    }// if TibberPriceArray exists
} // for two days
if (context.Debug) { node.warn(QH_Ct) }
global.set( "Victron_MESS.DayAhead.QH_Ct"); // remove
global.set( "Victron_MESS.DayAhead.QH_Ct",  QH_Ct);
global.set( "Victron_MESS.DayAhead.QH_Level"); // remove
global.set( "Victron_MESS.DayAhead.QH_Level",  QH_Level);
msg_QH_Ct =
  { topic: "DayAhead.QH_Ct",
    payload: QH_Ct }
node.status( {fill:StatusColor,
              shape:"dot",
              text: "@ " + NowTime + ": "
                + QH_Ct[Number(NowQH)] + " ct; "
                + QH_Ct.length + " elements." }
return  msg_QH_Ct;
[ Voor 255% gewijzigd door MJ de Bruijn op 30-11-2025 15:04 ]
  • MJ de Bruijn
  • Registratie: November 2016
  • Laatst online: 08:59
Dit is de Flow "Tibber - Dagelijks gegevens ophalen":
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
791
792
793
794
795
796
797
798
799
800
801
802
803
804
805
806
807
808
809
810
811
812
813
814
815
816
817
818
819
820
821
822
823
824
825
826
827
828
829
830
831
832
833
834
835
836
837
838
839
840
841
842
843
844
845
846
847
848
849
850
851
852
853
854
855
856
857
858
859
860
861
862
863
864
865
866
867
868
869
870
871
872
873
874
875
876
877
878
879
880
881
882
883
884
885
886
887
888
889
890
891
892
893
894
895
896
897
898
899
900
901
902
903
904
905
906
907
908
909
910
911
912
913
914
915
916
917
918
919
920
921
922
923
924
925
926
927
928
929
930
931
932
933
934
935
936
937
938
939
940
941
942
943
944
945
946
947
948
949
950
951
952
953
954
955
956
957
958
959
960
961
962
963
964
965
966
967
968
969
970
971
972
973
974
975
976
977
978
979
980
981
982
983
984
985
986
987
988
989
990
991
992
993
994
995
996
997
998
999
1000
1001
1002
1003
1004
1005
1006
1007
1008
1009
1010
1011
1012
1013
1014
1015
1016
1017
1018
1019
1020
1021
1022
1023
1024
1025
1026
1027
1028
1029
1030
1031
1032
1033
1034
1035
1036
1037
1038
1039
1040
1041
1042
1043
1044
1045
1046
1047
1048
1049
1050
1051
1052
1053
1054
1055
1056
1057
1058
1059
1060
1061
1062
1063
1064
1065
1066
1067
1068
1069
1070
1071
1072
1073
1074
1075
1076
1077
1078
1079
1080
1081
1082
1083
1084
1085
1086
1087
1088
1089
1090
1091
1092
1093
1094
1095
1096
1097
1098
1099
1100
1101
1102
1103
1104
1105
1106
1107
1108
1109
1110
1111
1112
1113
1114
1115
1116
1117
1118
1119
1120
1121
1122
1123
1124
1125
1126
1127
1128
1129
1130
1131
1132
1133
1134
1135
1136
1137
1138
1139
1140
1141
1142
1143
1144
1145
1146
1147
1148
1149
1150
1151
1152
1153
1154
1155
1156
1157
1158
1159
1160
1161
1162
1163
1164
1165
1166
1167
1168
1169
1170
1171
1172
1173
1174
1175
1176
1177
1178
1179
1180
1181
1182
1183
1184
1185
1186
1187
1188
1189
1190
1191
1192
1193
1194
1195
1196
1197
1198
1199
1200
1201
1202
1203
1204
1205
1206
1207
1208
1209
1210
1211
1212
1213
1214
1215
1216
1217
1218
1219
1220
1221
1222
1223
1224
1225
1226
1227
1228
1229
1230
1231
1232
1233
1234
1235
1236
1237
1238
1239
1240
1241
1242
1243
1244
1245
1246
1247
1248
1249
1250
1251
1252
1253
1254
1255
1256
1257
1258
1259
1260
1261
1262
1263
1264
1265
1266
1267
1268
1269
1270
1271
1272
1273
1274
1275
1276
1277
1278
1279
1280
1281
1282
1283
1284
1285
1286
1287
1288
1289
1290
1291
1292
1293
1294
1295
1296
1297
1298
1299
1300
1301
1302
1303
1304
1305
1306
1307
1308
1309
1310
1311
1312
1313
1314
1315
1316
1317
1318
1319
1320
1321
1322
1323
1324
1325
1326
1327
1328
1329
1330
1331
1332
1333
1334
1335
1336
1337
1338
1339
1340
1341
1342
1343
1344
1345
1346
1347
1348
1349
1350
1351
1352
1353
1354
1355
1356
1357
1358
1359
1360
1361
1362
1363
1364
1365
1366
1367
1368
1369
1370
1371
1372
1373
1374
1375
1376
1377
1378
1379
1380
1381
1382
1383
1384
1385
1386
1387
1388
1389
1390
1391
1392
1393
1394
1395
1396
1397
1398
1399
1400
1401
1402
1403
1404
1405
1406
1407
1408
1409
1410
1411
1412
1413
1414
1415
1416
1417
1418
1419
1420
1421
1422
1423
1424
1425
1426
1427
1428
1429
1430
1431
1432
1433
1434
1435
1436
1437
1438
1439
1440
1441
1442
1443
1444
1445
1446
1447
1448
1449
1450
1451
1452
1453
1454
1455
1456
1457
1458
1459
1460
1461
1462
1463
1464
1465
1466
1467
1468
1469
1470
1471
1472
1473
1474
1475
1476
1477
1478
1479
1480
1481
1482
1483
1484
1485
1486
1487
1488
1489
1490
1491
1492
1493
1494
1495
1496
1497
1498
1499
1500
1501
1502
1503
1504
1505
1506
1507
1508
1509
1510
1511
1512
1513
1514
1515
1516
1517
1518
1519
1520
1521
1522
1523
1524
1525
1526
1527
1528
1529
1530
1531
1532
1533
1534
1535
1536
1537
1538
1539
1540
1541
1542
1543
1544
1545
1546
1547
1548
1549
1550
1551
1552
1553
1554
1555
1556
1557
1558
1559
1560
1561
1562
1563
1564
1565
1566
1567
1568
1569
1570
1571
1572
1573
1574
1575
1576
1577
1578
1579
1580
1581
1582
1583
1584
1585
1586
1587
1588
1589
1590
1591
1592
1593
1594
1595
1596
1597
1598
1599
1600
1601
1602
1603
1604
1605
1606
1607
1608
1609
1610
1611
1612
1613
1614
1615
1616
1617
1618
1619
1620
1621
1622
1623
1624
1625
1626
1627
1628
1629
1630
1631
1632
1633
1634
1635
1636
1637
1638
1639
1640
1641
1642
1643
1644
1645
1646
1647
1648
1649
1650
1651
1652
1653
1654
1655
1656
1657
1658
1659
1660
1661
1662
1663
1664
1665
1666
1667
1668
1669
1670
1671
1672
1673
1674
1675
1676
1677
1678
1679
1680
1681
1682
1683
1684
1685
1686
1687
1688
1689
1690
1691
1692
1693
1694
1695
1696
1697
1698
1699
1700
1701
1702
1703
1704
1705
1706
1707
1708
1709
1710
1711
1712
1713
1714
1715
1716
1717
1718
1719
1720
1721
1722
1723
1724
1725
1726
1727
1728
1729
1730
1731
1732
1733
1734
1735
1736
1737
1738
1739
1740
1741
1742
1743
1744
1745
1746
1747
1748
1749
1750
1751
1752
1753
1754
1755
1756
1757
1758
1759
1760
1761
1762
1763
1764
1765
1766
1767
1768
1769
1770
1771
1772
1773
1774
1775
1776
1777
1778
1779
1780
1781
1782
1783
1784
1785
1786
1787
1788
1789
1790
"id": "733c6535992c1d6d",
"type": "subflow",
"name": "Show Topic",
"info": "",
"category": "",
"in": [
"x": 44,
"y": 48,
"wires": [
"id": "25113dfa4aa29d6a"
"out": [
"x": 300,
"y": 48,
"wires": [
"id": "25113dfa4aa29d6a",
"port": 0
"env": [],
"meta": {},
"color": "#DDAA99",
"status": {
"x": 300,
"y": 96,
"wires": [
"port": 1
"type": "function",
"z": "733c6535992c1d6d",
"func": "const Now = new Date();\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n                + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n                + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\nmsgState = { topic:'state', \n             payload: \"@ \" + NowTime + \": \"+ msg.topic,\n             shape: \"dot\",\n             color: \"grey\"\n};\n\nnode.send( [msg, msgState] );\n\nnode.done;",
"outputs": 2,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 166,
"y": 64,
"wires": [
"id": "9cde34175a911c36",
"type": "subflow",
"name": "Topic to LastRun",
"info": "",
"category": "",
"in": [
"x": 68,
"y": 48,
"wires": [
"id": "6af0ad5c06a89f8b"
"out": [
"x": 420,
"y": 32,
"wires": [
"id": "6af0ad5c06a89f8b",
"port": 0
"env": [],
"meta": {},
"color": "#DDAA99",
"status": {
"x": 420,
"y": 96,
"wires": [
"port": 1
"type": "function",
"z": "9cde34175a911c36",
"name": "Set LastRun for Topic",
"func": "// Function LastRun\nconst Now = new Date();\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n                + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n                + (\"0\" + Now.getSeconds()).slice(-2) ;\n\nlet CurTopc = 'Unknown'\n\nif (msg.topic == null)\n{\n    CurTopic = 'NULL';\n    node.warn(\"msg.topic is NULL; payload: \" + msg.payload )\n}\nelse if (msg.topic == undefined)\n{\n    CurTopic = 'Undefined';\n    node.warn(\"msg.topic is Undefined; payload: \" + msg.payload )\n}\nelse\n{\n    CurTopic = msg.topic;\n    CurTopic = CurTopic.replaceAll(\" \", \"-\");\n\n    global.set (\"Victron_MESS.LastRun.\" + CurTopic) // remove\n    global.set (\"Victron_MESS.LastRun.\" + CurTopic, NowTime)\n\n}\n\n\nmsgState = { topic:'state', \n             payload: NowTime + \": \" + CurTopic,\n             shape: \"dot\",\n             color: \"grey\"\n            };\n\nnode.send( [msg, msgState] );\n\nnode.done;\n",
"outputs": 2,
"timeout": "2",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 236,
"y": 48,
"wires": [
"id": "4eeabf29980b7298",
"type": "tab",
"label": "Tibber",
"disabled": false,
"info": "",
"env": []
"id": "882789e0e67415a7",
"type": "switch",
"z": "4eeabf29980b7298",
"name": "If Tibber.Today_QH is NULL or not",
"property": "Victron_MESS.Tibber.Today_QH",
"propertyType": "global",
"rules": [
"t": "null"
"t": "else"
"checkall": "false",
"repair": false,
"outputs": 2,
"x": 396,
"y": 96,
"wires": [
"e93de54cbd0ac9c3"
"a151b437ad35e16e",
"e9b4d5c6f2cbfeb9",
"1032e8031a43541c"
"id": "aa313e63a8bb1c6a",
"type": "cronplus",
"name": "at 00:00:10",
"outputField": "payload",
"timeZone": "",
"storeName": "",
"commandResponseMsgOutput": "output1",
"defaultLocation": "",
"defaultLocationType": "default",
"outputs": 1,
"options": [
"name": "schedule1",
"topic": "Every Day",
"payloadType": "default",
"payload": "",
"expressionType": "cron",
"expression": "10 0 0 * * *",
"location": "",
"offset": "0",
"solarType": "all",
"solarEvents": "sunrise,sunset"
"x": 106,
"y": 32,
"wires": [
"f9a338d40380b241"
"id": "570681eea8f4b93e",
"type": "inject",
"name": "1 min",
"props": [
"p": "topic",
"vt": "str"
"p": "payload"
"repeat": "60",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Check Tibber (1 min)",
"payload": "( $moment().format(\"YYYY-MM-DD HH:mm:ss\") )",
"payloadType": "jsonata",
"x": 86,
"y": 96,
"wires": [
"882789e0e67415a7"
"id": "895fc654aef9f73f",
"type": "link out",
"name": "link to Process QuarterHours",
"mode": "link",
"links": [
"babb971fbf7f5d5b",
"cf8ea5bc65a7f867"
"x": 505,
"y": 1664,
"wires": []
"id": "f9a338d40380b241",
"type": "change",
"name": "Delete All Tibber",
"rules": [
"t": "delete",
"p": "Victron_MESS.LastRun.Tibber",
"pt": "global"
"t": "delete",
"p": "Victron_MESS.Tibber",
"pt": "global"
"t": "set",
"p": "Victron_MESS.LastRun.Tibber.Delete",
"pt": "global",
"to": "$moment().format(\"YYYY-MM-DD HH:mm:ss\")",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 336,
"y": 32,
"wires": [
"882789e0e67415a7"
"id": "f8a97df91041a3ef",
"type": "link out",
"name": "To Watchdog",
"mode": "link",
"links": [
"19d1f71e8a5c0f9e",
"72aba6706bd5614f"
"x": 849,
"y": 144,
"wires": []
"id": "e9b4d5c6f2cbfeb9",
"type": "trigger",
"name": "Watchdog 65 min",
"op1": "",
"op2": "Tibber Today_QH is NULL",
"op1type": "nul",
"op2type": "str",
"duration": "65",
"extend": false,
"overrideDelay": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 2,
"x": 714,
"y": 144,
"wires": [
"f8a97df91041a3ef"
"id": "a151b437ad35e16e",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "reset",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 704,
"y": 96,
"wires": [
"e9b4d5c6f2cbfeb9"
"id": "2032dc89208a2634",
"type": "tibber-data",
"name": "Get Tibber Today_QH",
"active": true,
"apiEndpointRef": "980a5e303861268d",
"queryName": "getTodaysEnergyPrices",
"homeId": "04abbeae-a220-4c3b-854d-2452f154a1e6",
"energyResolution": "QUARTER_HOURLY",
"lastCount": 10,
"x": 356,
"y": 192,
"wires": [
"a7ed06b1f43a7564"
"id": "01bf41a25fa7a075",
"type": "function",
"name": "Generate QH_Ct",
"func": "// Generate tibber Array\n\ncontext = context || {};\n\nGetNowTime = global.get(\"Victron_MESS.Functions.GetNowTime\");\nGetTomorrow = global.get(\"Victron_MESS.Functions.GetTomorrow\");\nlet NowTime = GetNowTime(\"NowTime\"); \nlet NowHour = GetNowTime(\"NowHour\"); \nlet NowQH = GetNowTime(\"NowQH\"); \nlet Nowyyyymmdd = GetNowTime(\"yyyymmdd\");\nlet Tomorrowyyyymmdd = GetTomorrow(\"yyyymmdd\");\n\nif (context.Debug == null)\n{\n    context.Debug = false;\n}\n\nif (msg.debug != null)\n{\n    context.Debug = msg.debug;\n    node.warn(\"Debug: \" + context.Debug);\n    \n    node.status( {fill: \"blue\",\n              shape:\"dot\",\n              text: \"@ \" + NowTime + \"; Debug \"\n                + context.Debug }\n        );\n    \n    return null;\n}\n\nRound = global.get(\"Victron_MESS.Functions.Round\");\n\nTimestampTo_QH = \n   global.get(\"Victron_MESS.Functions.TimestampTo_QH\");\n\nif (context.Last_QH_Ct == null)\n{\n    context.Last_QH_Ct = [];\n}\n\nvar QH_Ct= [];\nvar QH_Level= [];\n\nlet msg_QH_Ct = null;\n\nvar StatusColor = 'red';\n\nvar TibberPriceArray = \"\";\n\nfor (D=0; D<2; D++) // two days\n{\n    if (D == 0)\n    {\n        TibberPriceArray = global.get( \"Victron_MESS.Tibber.Today_QH\");\n        \n        if (context.Debug) { node.warn(TibberPriceArray) }\n        \n        if ( (TibberPriceArray == \"\")\n          || (TibberPriceArray == null) )\n        {\n            node.warn(\"Today_QH is NULL\")\n        }\n\n        for (let i = 0; i < 96; i++)\n        {\n            QH_Ct[i] = -99;\n            QH_Level[i] = \"unknown\";\n        }\n\n    }\n    else\n    {\n        TibberPriceArray = global.get( \"Victron_MESS.Tibber.Tomorrow_QH\");\n\n        if (context.Debug) { node.warn(TibberPriceArray) }\n\n        if ( (TibberPriceArray == \"\")\n          || (TibberPriceArray == null) )\n        {\n            if (NowHour >= 15)\n            {\n                node.warn(\"Tomorrow_QH is NULL\")\n            }\n        }\n        \n        for (let i = 96; i<192; i++)\n        {\n            QH_Ct[i] = -99;\n            QH_Level[i] = \"unknown\";\n        }\n        \n    }\n\n    if ( (TibberPriceArray != \"\")\n      && (TibberPriceArray != null) )\n    {\n        if (context.Debug)\n        {\n            node.warn(\"Process: Day: \" + D\n            + \" Length: \" + TibberPriceArray.length);\n        }\n        \n        for (let i=0; i<TibberPriceArray.length; i++)\n        {\n            let total = TibberPriceArray[i].total;\n            let energy = TibberPriceArray[i].energy;\n            let tax = TibberPriceArray[i].tax;\n            let level = (TibberPriceArray[i].level).toLowerCase();\n            \n            let EnergyCt = \n              Math.round( energy*1000 + 0.5 ) / 10;\n            \n            let startsAt = TibberPriceArray[i].startsAt;\n            // node.warn(startsAt);\n            let PriceTimeStamp = new Date(startsAt);\n            \n            let Priceyyyymmdd = PriceTimeStamp.getFullYear()\n                 + (\"0\" + (PriceTimeStamp.getMonth() + 1)).slice(-2)\n                 + (\"0\" + PriceTimeStamp.getDate()).slice(-2) ;       \n\n            // node.warn(Priceyyyymmdd);\n\n            let Price_QH = TimestampTo_QH(startsAt);\n            // node.warn(Price_QH);\n\n            if (Priceyyyymmdd == Nowyyyymmdd)\n            {\n                QH_Ct[Price_QH] = EnergyCt;\n                QH_Level[Price_QH] = level;\n            }\n            else if (Priceyyyymmdd == Tomorrowyyyymmdd)\n            {\n                QH_Ct[Price_QH + 96] = EnergyCt;\n                QH_Level[Price_QH + 96] = level;\n            }\n            else\n            {\n                node.warn(\"Unknown Date: \" + Priceyyyymmdd);\n            }\n            \n        } // for TibberPriceArray length\n        \n        StatusColor = 'green';\n        \n    }// if TibberPriceArray exists\n} // for two days\n\nif (context.Debug) { node.warn(QH_Ct) }\n\nglobal.set( \"Victron_MESS.DayAhead.QH_Ct\"); // remove\nglobal.set( \"Victron_MESS.DayAhead.QH_Ct\",  QH_Ct);\n\nglobal.set( \"Victron_MESS.DayAhead.QH_Level\"); // remove\nglobal.set( \"Victron_MESS.DayAhead.QH_Level\",  QH_Level);\n\nmsg_QH_Ct = \n  { topic: \"DayAhead.QH_Ct\", \n    payload: QH_Ct }\n\nnode.status( {fill:StatusColor,\n              shape:\"dot\",\n              text: \"@ \" + NowTime + \": \"\n                + QH_Ct[Number(NowQH)] + \" ct; \"  \n                + QH_Ct.length + \" elements.\" }\n        );\n\nreturn  msg_QH_Ct;\n",
"outputs": 1,
"timeout": "4",
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 342,
"y": 1536,
"wires": [
"81ef4a7809c69874",
"ebbd7666a79ace40"
"id": "a7ed06b1f43a7564",
"type": "change",
"name": "Set Tibber Today_QH",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "\"Today_QH: \" & $string($count($.payload)) & \" items\"",
"tot": "jsonata"
"t": "set",
"p": "Victron_MESS.Tibber.Today_QH",
"pt": "global",
"to": "payload",
"tot": "msg",
"dc": true
"t": "set",
"p": "Victron_MESS.LastRun.Tibber.Today_QH",
"pt": "global",
"to": "$moment().format(\"YYYY-MM-DD HH:mm:ss\")\t& \": \" &\t$string($count($.payload)) & \" items\"",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 356,
"y": 240,
"wires": [
"471087d1994f0123"
"id": "b17cd1af2c80472a",
"name": "Get Tibber Tomorrow_QH",
"active": true,
"queryName": "getTomorrowsEnergyPrices",
"lastCount": 10,
"x": 362,
"y": 944,
"wires": [
"0b0b11736c0a9612"
"id": "0b0b11736c0a9612",
"type": "change",
"name": "Set Tibber Tomorrow_QH",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "\"Tomorrow_QH: \" & $string($count($.payload)) & \" items\"",
"tot": "jsonata"
"t": "set",
"p": "Victron_MESS.Tibber.Tomorrow_QH",
"pt": "global",
"to": "payload",
"tot": "msg",
"dc": true
"t": "set",
"p": "Victron_MESS.LastRun.Tibber.Tomorrow_QH",
"pt": "global",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 362,
"y": 992,
"wires": [
"6f7c6c90fd379093"
"id": "2bef3fcceac875e2",
"type": "switch",
"name": "If NULL or not",
"property": "Victron_MESS.Tibber.Tomorrow_QH",
"rules": [
"t": "null"
"t": "else"
"repair": false,
"outputs": 2,
"x": 332,
"y": 752,
"wires": [
"44a56aa4c537a4d7",
"26acc274e13a9f15"
"342ae1217d089260",
"7b8edf7a95288622"
"id": "ebbd7666a79ace40",
"type": "subflow:9cde34175a911c36",
"name": "",
"x": 342,
"y": 1664,
"wires": [
"895fc654aef9f73f"
"id": "9b9c846297f10c84",
"type": "switch",
"name": "If DayAhead.QH_Ct is NULL",
"property": "Victron_MESS.DayAhead.QH_Ct",
"rules": [
"t": "null"
"t": "else"
"repair": false,
"outputs": 2,
"x": 372,
"y": 1408,
"wires": [
"01bf41a25fa7a075",
"dcd0590bd6a69b39"
"45cf9791b1c3a3e2"
"id": "01c5c4a8be8ba8d1",
"type": "change",
"name": "Delete Tibber.Tomorrow_QH",
"rules": [
"t": "delete",
"pt": "global"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 376,
"y": 496,
"wires": [
"306325a6966a9fac"
"id": "b3f69f3daddce9db",
"type": "link out",
"mode": "link",
"links": [
"19d1f71e8a5c0f9e",
"72aba6706bd5614f"
"x": 813,
"y": 736,
"wires": []
"id": "44a56aa4c537a4d7",
"type": "trigger",
"name": "Watchdog",
"op1": "",
"op2": "Tibber Tomorrow_QH is NULL",
"op1type": "nul",
"op2type": "str",
"duration": "65",
"extend": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 2,
"x": 680,
"y": 736,
"wires": [
"b3f69f3daddce9db"
"id": "342ae1217d089260",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "reset",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 704,
"y": 784,
"wires": [
"44a56aa4c537a4d7"
"id": "81ef4a7809c69874",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "reset",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 700,
"y": 1536,
"wires": [
"dcd0590bd6a69b39"
"id": "dcd0590bd6a69b39",
"type": "trigger",
"op1": "",
"op2": "DayAhead.QH_Ct is NULL",
"op1type": "nul",
"op2type": "str",
"duration": "65",
"extend": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 2,
"x": 710,
"y": 1408,
"wires": [
"90f3ae770c6e9a1f"
"id": "90f3ae770c6e9a1f",
"type": "link out",
"name": "From Watchdog",
"mode": "link",
"links": [
"19d1f71e8a5c0f9e",
"72aba6706bd5614f"
"x": 843,
"y": 1408,
"wires": []
"id": "0bfcb2ce29848aa1",
"type": "switch",
"name": "15:00-23:00 / NOT",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "jsonata_exp",
"v": "(\t    $nowHour := $moment().format(\"HHmm\");\t    $nowHour >= \"1500\" and $nowHour <= \"2301\"\t)\t\t",
"vt": "jsonata"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 346,
"y": 640,
"wires": [
"095ba271fd6ed19a"
"c8a06571d125db68"
"id": "947ce53e1485061d",
"type": "inject",
"name": "On Demand",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 102,
"y": 1536,
"wires": [
"01bf41a25fa7a075"
"id": "e4cc29cd6d84f9a2",
"type": "change",
"name": "Delete DayAhead ALL",
"rules": [
"t": "delete",
"p": "Victron_MESS.DayAhead",
"pt": "global"
"t": "delete",
"p": "Victron_MESS.LastRun.DayAhead",
"pt": "global"
"t": "set",
"p": "Victron_MESS.LastRun.DayAhead.Delete",
"pt": "global",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 352,
"y": 1296,
"wires": [
"92dbdc9c9d56234e"
"id": "306325a6966a9fac",
"type": "change",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Delete DayAhead ALL",
"tot": "str"
"t": "delete",
"pt": "global"
"t": "delete",
"pt": "global"
"t": "set",
"pt": "global",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 356,
"y": 544,
"wires": [
"1032e8031a43541c"
"id": "f9bb822d9b35bacc",
"type": "inject",
"name": "Debug On",
"props": [
"p": "debug",
"v": "true",
"vt": "bool"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 92,
"y": 1584,
"wires": [
"01bf41a25fa7a075"
"id": "2876f88efeca52e5",
"type": "inject",
"name": "Debug Off",
"props": [
"p": "debug",
"v": "false",
"vt": "bool"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 92,
"y": 1632,
"wires": [
"01bf41a25fa7a075"
"id": "1346cd2a2f1abadc",
"type": "inject",
"props": [
"p": "topic",
"vt": "str"
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Get Tibber Tomorrow",
"x": 102,
"y": 944,
"wires": [
"b17cd1af2c80472a"
"id": "6454b17d9435f71c",
"type": "inject",
"props": [
"p": "topic",
"vt": "str"
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Get Tibber Today",
"x": 106,
"y": 192,
"wires": [
"2032dc89208a2634"
"id": "7b8edf7a95288622",
"type": "switch",
"name": "If has responseMessage",
"property": "Victron_MESS.Tibber.Tomorrow_QH.responseMesage",
"rules": [
"t": "nnull"
"t": "else"
"repair": false,
"outputs": 2,
"x": 366,
"y": 800,
"wires": [
"26acc274e13a9f15"
"9b240a9689b3908e"
"id": "4cdb4f8f6bb00b6c",
"type": "inject",
"props": [
"p": "topic",
"vt": "str"
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Check Tibber Tomorrow",
"x": 106,
"y": 704,
"wires": [
"095ba271fd6ed19a"
"id": "4d2ffc6fbac3b794",
"type": "switch",
"name": "If Tibber.Today has responseMessage",
"property": "Victron_MESS.Tibber.Today_QH.responseMessage",
"rules": [
"t": "nnull"
"t": "else"
"repair": false,
"outputs": 2,
"x": 406,
"y": 336,
"wires": [
"587d7d592c01f5c9"
"ca5cc930e17f8210",
"e9e1c719db699afa"
"id": "13fc4fde7f9865f2",
"type": "switch",
"name": "If Tibber.Tomorrow has responseMessage",
"property": "Victron_MESS.Tibber.Tomorrow_QH.responseMessage",
"rules": [
"t": "nnull"
"t": "else"
"repair": false,
"outputs": 2,
"x": 412,
"y": 1088,
"wires": [
"87a46ddd408c4ba5"
"4ae5faf9a9b35658",
"ce9238882f0c4127"
"id": "587d7d592c01f5c9",
"type": "change",
"name": "copy Error",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Tibber Today has responseMesage",
"tot": "str"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "Victron_MESS.Tibber.Today_QH.responseMessage",
"tot": "global",
"dc": true
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 698,
"y": 288,
"wires": [
"f602df00e35b3ec5"
"id": "f602df00e35b3ec5",
"type": "trigger",
"op1": "",
"op2": "",
"op1type": "nul",
"op2type": "pay",
"duration": "65",
"extend": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 714,
"y": 384,
"wires": [
"307623ed66c90c89"
"id": "307623ed66c90c89",
"type": "link out",
"mode": "link",
"links": [
"19d1f71e8a5c0f9e",
"72aba6706bd5614f"
"x": 847,
"y": 384,
"wires": []
"id": "ca5cc930e17f8210",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "reset",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 704,
"y": 336,
"wires": [
"f602df00e35b3ec5"
"id": "87a46ddd408c4ba5",
"type": "change",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Tibber Tomorrow has responseMessage",
"tot": "str"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "Victron_MESS.Tibber.Tomorrow_QH.responseMessage",
"tot": "global",
"dc": true
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 694,
"y": 1056,
"wires": [
"5ae02d3bde767c67"
"id": "5ae02d3bde767c67",
"type": "trigger",
"op1": "",
"op2": "",
"op1type": "nul",
"op2type": "pay",
"duration": "65",
"extend": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 710,
"y": 1136,
"wires": [
"4166d4402b0b26bd"
"id": "4166d4402b0b26bd",
"type": "link out",
"mode": "link",
"links": [
"19d1f71e8a5c0f9e",
"72aba6706bd5614f"
"x": 843,
"y": 1136,
"wires": []
"id": "4ae5faf9a9b35658",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "reset",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 704,
"y": 1088,
"wires": [
"5ae02d3bde767c67"
"id": "471087d1994f0123",
"type": "subflow:733c6535992c1d6d",
"name": "",
"x": 326,
"y": 288,
"wires": [
"4d2ffc6fbac3b794"
"id": "61b7d0f57fb30c4b",
"name": "",
"x": 322,
"y": 1360,
"wires": [
"9b9c846297f10c84"
"id": "1032e8031a43541c",
"name": "",
"x": 326,
"y": 592,
"wires": [
"0bfcb2ce29848aa1"
"id": "26acc274e13a9f15",
"name": "",
"x": 322,
"y": 896,
"wires": [
"b17cd1af2c80472a"
"id": "45cf9791b1c3a3e2",
"name": "",
"x": 322,
"y": 1456,
"wires": [
"id": "fa6755e05d414017",
"type": "switch",
"name": "Count Today_QH 96 or not",
"property": "$count($.payload)",
"propertyType": "jsonata",
"rules": [
"t": "btwn",
"v": "95",
"vt": "num",
"v2": "97",
"v2t": "num"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 376,
"y": 448,
"wires": [
"01c5c4a8be8ba8d1",
"d994f23ad63208d9"
"96a35ffe4e1b0b1e"
"id": "96a35ffe4e1b0b1e",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "topic",
"tot": "msg",
"dc": true
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Tibber Today has incorrect count",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 694,
"y": 464,
"wires": [
"da6904aa0e6d4bd5"
"id": "da6904aa0e6d4bd5",
"type": "trigger",
"op1": "",
"op2": "",
"op1type": "nul",
"op2type": "pay",
"duration": "65",
"extend": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 714,
"y": 512,
"wires": [
"d8abd9416392e907"
"id": "d8abd9416392e907",
"type": "link out",
"mode": "link",
"links": [
"19d1f71e8a5c0f9e",
"72aba6706bd5614f"
"x": 847,
"y": 512,
"wires": []
"id": "d994f23ad63208d9",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "reset",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 704,
"y": 432,
"wires": [
"da6904aa0e6d4bd5"
"id": "b758967f73168f67",
"type": "link out",
"mode": "link",
"links": [
"19d1f71e8a5c0f9e",
"72aba6706bd5614f"
"x": 843,
"y": 1264,
"wires": []
"id": "ce9238882f0c4127",
"type": "switch",
"name": "Count Tomorrow_QH 96 or not",
"rules": [
"t": "btwn",
"v": "95",
"vt": "num",
"v2": "97",
"v2t": "num"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 382,
"y": 1216,
"wires": [
"e91af8f749354460",
"e4cc29cd6d84f9a2"
"139c2cd9bd530f86"
"id": "e91af8f749354460",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "reset",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 704,
"y": 1184,
"wires": [
"3bea6b699fd11ba7"
"id": "139c2cd9bd530f86",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "topic",
"tot": "msg",
"dc": true
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Tibber Tomorrow has incorrect count",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 694,
"y": 1216,
"wires": [
"3bea6b699fd11ba7"
"id": "3bea6b699fd11ba7",
"type": "trigger",
"op1": "",
"op2": "",
"op1type": "nul",
"op2type": "pay",
"duration": "65",
"extend": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 710,
"y": 1264,
"wires": [
"b758967f73168f67"
"id": "8c38ca1bc423e6d4",
"type": "link in",
"name": "Link in Check QH_Ct",
"links": [
"aea4dabe57116bad",
"c8a06571d125db68",
"92dbdc9c9d56234e"
"x": 203,
"y": 1360,
"wires": [
"61b7d0f57fb30c4b"
"id": "aea4dabe57116bad",
"type": "link out",
"name": "lLink Out goto Check QH_Ct",
"mode": "link",
"links": [
"8c38ca1bc423e6d4"
"x": 513,
"y": 848,
"wires": []
"id": "c8a06571d125db68",
"type": "link out",
"mode": "link",
"links": [
"8c38ca1bc423e6d4"
"x": 517,
"y": 640,
"wires": []
"id": "e93de54cbd0ac9c3",
"name": "",
"x": 326,
"y": 144,
"wires": [
"2032dc89208a2634"
"id": "6f7c6c90fd379093",
"name": "",
"x": 322,
"y": 1040,
"wires": [
"13fc4fde7f9865f2"
"id": "92dbdc9c9d56234e",
"type": "link out",
"mode": "link",
"links": [
"8c38ca1bc423e6d4"
"x": 523,
"y": 1296,
"wires": []
"id": "e9e1c719db699afa",
"name": "",
"x": 326,
"y": 384,
"wires": [
"fa6755e05d414017"
"id": "9b240a9689b3908e",
"type": "switch",
"name": "Count 96 or not",
"rules": [
"t": "btwn",
"v": "95",
"vt": "num",
"v2": "97",
"v2t": "num"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 336,
"y": 848,
"wires": [
"aea4dabe57116bad"
"26acc274e13a9f15"
"id": "095ba271fd6ed19a",
"type": "change",
"name": "Read Global Tomorrow_QH",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "Victron_MESS.Tibber.Tomorrow_QH",
"tot": "global",
"dc": true
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 376,
"y": 704,
"wires": [
"2bef3fcceac875e2"
"id": "980a5e303861268d",
"type": "tibber-api-endpoint",
"queryUrl": "https://api.tibber.com/v1-beta/gql",
"feedConnectionTimeout": "30",
"feedTimeout": "60",
"queryRequestTimeout": "30",
"name": "Tibber Config Node"
Een mens leert van zijn fouten. Ik heb in mijn leven heel veel geleerd.
  • MJ de Bruijn
Over de Context Global Geheugenruimte
MESS is inmiddels behoorlijk uitgebreid. Er zijn meer dan 10 tabbladen waartussen gegevens worden uitgewisseld en gedeeld.
Ik probeer zoveel mogelijk om een bepaalde functionaliteit slechts één keer in het totaal op te nemen. Voor mensen die bekend zijn met programmeren hoef ik dit niet nader toe te lichten.
Bij de start van het programma, bijvoorbeeld na een reboot, is het Context Global geheugengebied nog leeg. Daarom wordt het wegschrijven van veel gegevens met een 'At Deploy' Injectie Node geactiveerd. Voorbeelden zijn vaste waarden (parameters) zoals prijs-grenzen, batterij-capaciteit, API-sleutels, GPS-locatie etc.
Afbeeldingslocatie: https://tweakers.net/i/bV1Wlsa3aktvEFueW3X2AJfiFjE=/x800/filters:strip_icc():strip_exif()/f/image/tgBmeQyYB0GE1fKIQxrYJBK1.jpg?f=fotoalbum_large
Zie ook Flow Parameters - Diverse Parameters
Ook veel gebruikte functies worden aldus aangemaakt en in de Context Global Geheugenruimte geplaatst.
Afbeeldingslocatie: https://tweakers.net/i/TgpHMfl03o8Je_VTEYVxyCoU98A=/x800/filters:strip_icc():strip_exif()/f/image/pjkRGk4dJPK2PP1elrvek2XZ.jpg?f=fotoalbum_large
Flow Parameters - SetGlobalFunctions
Ook de State van een heleboel Victron Entiteiten 'verzamel' ik in de Context Global Geheugenruimte. In de diverse flows waar deze States gebruikt worden hoef ik deze dan alleen uit te lezen en hoef ik geen aandacht te geven aan het opvangen en verzamelen van wijzigingen.
Afbeeldingslocatie: https://tweakers.net/i/5ddPsnjUh5YQVN9ad4n_9kB1wMY=/x800/filters:strip_icc():strip_exif()/f/image/IjiS2CJZnM4I0uV0jJ08uCPX.jpg?f=fotoalbum_large
Omdat de werking van deze Flows redelijk triviaal is zal ik de stappen niet uitgebreid beschrijven.
Voor de volledigheid neem ik hierna wel de actuele stand van de Flows over om te kunnen kopiëren en Plakken.
[ Voor 6% gewijzigd door MJ de Bruijn op 01-12-2025 14:22 ]
  • MJ de Bruijn
Flow Parameters - Make Consump_Forecast_Wh
Omdat een forum bijdrage een maximum aantal tekens toestaat heb ik de 'Flow Parameters' in stukjes moeten opbreken. Dit is deel 1.
Afbeeldingslocatie: https://tweakers.net/i/SohY5kg8z8_y9r4H-Sv1hO2OQIQ=/800x/filters:strip_icc():strip_exif()/f/image/ZiZEFKgpI9g4sqthaUSK2v6u.jpg?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
        "id": "b90ba71de262da79",
        "type": "function",
        "z": "1fc0ea28e0170585",
        "name": "Make Consump_Forecast_Wh",
        "func": "// Make Consumption Forecast Array\n\nconst Now = new Date();\nlet NowMonth = Now.getMonth();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\n\nlet MonthFactor = 0;\nswitch(NowMonth) {\n    case 0:  MonthFactor = 1.25;\n             break;\n    case 1:  MonthFactor = 1.2;\n             break;\n    case 2:  MonthFactor = 1.15;\n             break;\n    case 3:  MonthFactor = 1.1;\n             break;\n    case 4:  MonthFactor = 1.05;\n             break;\n    case 5:  MonthFactor = 1;\n             break;\n    case 6:  MonthFactor = 1;\n             break;\n    case 7:  MonthFactor = 1.05;\n             break;\n    case 8:  MonthFactor = 1.1;\n             break;\n    case 9:  MonthFactor = 1.15;\n             break;\n    case 10: MonthFactor = 1.2;\n             break;\n    case 11: MonthFactor = 1.25;\n             break;\n    default: MonthFactor = 1;\n             break;\n}\n\nlet Consump_Forecast_Wh = new Array(192);\n\nfor (let i=0; i<192; i++)\n{\n    Consump_Forecast_Wh[i] = 0;\n}\n\nfor (let i=0; i<=7*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 120);\n}\nfor (let i=8*4; i<=8*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 200);\n}\n\nfor (let i=9*4; i<=11*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 150);\n}\n\nfor (let i=12*4; i<=13*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 200);\n}\n\nfor (let i=14*4; i<=16*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 150);\n}\n\nfor (let i=17*4; i<=17*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 200);\n}\n\nfor (let i=18*4; i<=19*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 250);\n}\n\nfor (let i=20*4; i<=20*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 300);\n}\n\nfor (let i=21*4; i<=21*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 250);\n}\n\nfor (let i=22*4; i<=23*4+3; i++)\n{\n    Consump_Forecast_Wh[i] = Math.round(MonthFactor * 200);\n}\n\nlet Consump_Per_Day_Wh = 0; // estimate Wh\n\nfor (let i = 0; i <= 95; i++) // next day \n{\n    Consump_Per_Day_Wh +=  Consump_Forecast_Wh[i];\n    Consump_Forecast_Wh[i+96] = Consump_Forecast_Wh[i];\n}\n\nglobal.set(\"Victron_MESS.Consump.Forecast\", Consump_Forecast_Wh);\n\nglobal.set(\"Victron_MESS.LastRun.Deploy.Consump_Forecast\"); // remove\nglobal.set(\"Victron_MESS.LastRun.Deploy.Consump_Forecast\", NowTime);\n\nnode.status( \n  { fill:\"green\", \n    shape:\"dot\",\n    text: \"@ \" + NowTime\n  } );\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 390,
        "y": 336,
        "wires": [
        "id": "80a676ec44349edb",
        "type": "change",
        "name": "",
        "rules": [
                "t": "delete",
                "p": "Victron_MESS.Consump",
                "pt": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 410,
        "y": 240,
        "wires": [
                "f6759a39081a82c7"
        "id": "21b119640c6d16db",
        "type": "cronplus",
        "name": "every month",
        "timeZone": "",
        "storeName": "",
        "outputs": 1,
        "options": [
                "topic": "topic1",
                "payload": "",
                "expression": "1 * * 1 * *",
                "location": "",
                "offset": "0",
                "solarType": "all",
        "x": 122,
        "y": 192,
        "wires": [
                "80a676ec44349edb"
        "id": "f6759a39081a82c7",
        "type": "switch",
        "name": "Consump.Forecast is NULL",
        "property": "Victron_MESS.Consump",
        "rules": [
                "t": "null"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 380,
        "y": 288,
        "wires": [
                "b90ba71de262da79"
        "id": "4cdd8409aa184b83",
        "type": "inject",
        "name": "1 min",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "60",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Check Consump Forecast",
        "x": 102,
        "y": 288,
        "wires": [
                "f6759a39081a82c7"
        "id": "e5fb79aeb0bd81e2",
        "type": "inject",
        "name": "At Deploy",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "Delete Consump Forecast",
        "x": 112,
        "y": 240,
        "wires": [
                "80a676ec44349edb"
  • MJ de Bruijn
Heel veel functie-Nodes in MESS gebruiken dezelfde berekeningen en gegevens (datums, afronden, formatteren, sorteren). Ik heb deze functionaliteiten vastgelegd in algemene 'Globale' functies. Deze Flow maakt de betreffende functies aan en plaatst deze in de Context Global Geheugenruimte.
Afbeeldingslocatie: https://tweakers.net/i/8kX0RBUXed5aAR8H8GZByO7SeII=/800x/filters:strip_icc():strip_exif()/f/image/ZvwLNCq2WvL8eZkeK1bZen0w.jpg?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
        "id": "ac3e701902b41060",
        "type": "function",
        "name": "SetGlobalFunctions",
        "func": "// Prepare Javascript functions for multiple nodes\n\nlet DebugStep = \"Start\";\nlet NewLine = \"\\n\\r\";\n    \ntry {\n\n    DebugStep = \"GetNowTime\";\n\n    const GetNowTime = (p_format) =>\n    {\n        const Now = new Date()\n        \n        if (p_format == \"NowHour\")\n        {\n            // return (\"0\" + Now.getHours()).slice(-2);\n            return Now.getHours();\n        }\n        else if ( (p_format == \"NowQuarter\")\n               || (p_format == \"NowQuarterHour\")\n               || (p_format == \"Now_QH\")\n               || (p_format == \"NowQH\")\n               )\n        {\n            return (4 * Now.getHours()\n                 + Math.floor(Now.getMinutes()/15) );\n    \n        }\n        else if (p_format == \"NowMinutes\")\n        {\n            // return (\"0\" + Now.getMinutes()).slice(-2);\n            return Now.getMinutes();\n        }\n        else if (p_format == \"NowInSeconds\")\n        {\n            return Math.floor(Now.getTime() / 1000);\n        }\n        if ( (p_format == \"uu:mm\")\n          || (p_format == \"UU:MM\") )\n        {\n            return (\"0\" + Now.getHours()).slice(-2)\n                    + \":\"\n                    + (\"0\" + Now.getMinutes() ).slice(-2);\n        }\n        else if ( (p_format == \"yyyymmdd\")\n               || (p_format == \"YYYYMMDD\") )\n        {\n            return Now.getFullYear()\n                + (\"0\" + (Now.getMonth() + 1)).slice(-2)\n                + (\"0\" + Now.getDate()).slice(-2);\n        }\n        else if ( (p_format == \"yyyy-mm-dd\")\n               || (p_format == \"YYYY-MM-DD\") )\n        {\n            return Now.getFullYear()\n                + \"-\" + (\"0\" + (Now.getMonth() + 1)).slice(-2)\n                + \"-\" + (\"0\" + Now.getDate()).slice(-2);\n        }\n        else if ( (p_format == \"uu:mm:ss\")\n               || (p_format == \"UU:MM:SS\") )\n        {\n            return (\"0\" + Now.getHours()).slice(-2) + \":\"\n                + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n                + (\"0\" + Now.getSeconds()).slice(-2) ;\n        }\n        else\n        {\n            return Now.getFullYear() + \"-\"\n                + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n                + (\"0\" + Now.getDate()).slice(-2) + \" \"\n                + (\"0\" + Now.getHours()).slice(-2) + \":\"\n                + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n                + (\"0\" + Now.getSeconds()).slice(-2) ;\n        }\n    }\n    \n    global.set(\"Victron_MESS.Functions.GetNowTime\", GetNowTime);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"GetTomorrow\";\n\n    const GetTomorrow = (p_format) =>\n    {\n        let Tomorrow = new Date();\n        Tomorrow.setDate(Tomorrow.getDate() + 1);\n    \n        if (p_format == \"yyyymmdd\")\n        {\n            return Tomorrow.getFullYear()\n                 + (\"0\" + (Tomorrow.getMonth() + 1)).slice(-2)\n                 + (\"0\" + Tomorrow.getDate()).slice(-2) ;\n        }\n        else\n        {\n            return Tomorrow.getFullYear() + \"-\"\n                 + (\"0\" + (Tomorrow.getMonth() + 1)).slice(-2) + \"-\"\n                 + (\"0\" + Tomorrow.getDate()).slice(-2) ;\n        }\n    }\n    \n    global.set(\"Victron_MESS.Functions.GetTomorrow\", GetTomorrow);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"GetYesterday\";\n\n    const GetYesterday = (p_format) =>\n    {\n        let Yesterday = new Date();\n        Yesterday.setDate(Yesterday.getDate() - 1);\n    \n        if (p_format == \"yyyymmdd\")\n        {\n            return Yesterday.getFullYear()\n                 + (\"0\" + (Yesterday.getMonth() + 1)).slice(-2)\n                 + (\"0\" + Yesterday.getDate()).slice(-2) ;\n        }\n        else\n        {\n            return Yesterday.getFullYear() + \"-\"\n                 + (\"0\" + (Yesterday.getMonth() + 1)).slice(-2) + \"-\"\n                 + (\"0\" + Yesterday.getDate()).slice(-2) ;\n        }\n    }\n    \n    global.set(\"Victron_MESS.Functions.GetYesterday\", GetYesterday);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"TimestampTo_HH_MM_SS\";\n\n    const TimestampTo_HH_MM_SS = (p_date) =>\n    {\n        const curdate = new Date(null);\n    \n        curdate.setSeconds(p_date)\n    \n        return ( (\"0\" + curdate.getHours()).slice(-2) + \":\"\n                + (\"0\" + curdate.getMinutes()).slice(-2) + \":\"\n                + (\"0\" + curdate.getSeconds()).slice(-2) \n                );\n                \n    }\n    \n    global.set(\"Victron_MESS.Functions.TimestampTo_HH_MM_SS\", \n               TimestampTo_HH_MM_SS);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"TimestampTo_QH\";\n\n    const TimestampTo_QH = (p_date) =>\n    {\n        try\n        {\n            var TempDate = new Date(p_date);\n    \n            return (4 * TempDate.getHours()\n                 + Math.floor(TempDate.getMinutes()/15) );\n        }\n        catch (error)\n        {\n            node.warn(\"Error TimestampTo_QH: \" + error);\n            return (\"\");\n        }\n    }\n    \n    global.set(\"Victron_MESS.Functions.TimestampTo_QH\", \n               TimestampTo_QH);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"QHToText\";\n\n    const QHToText = (p_QH) =>\n    {\n        const QH_Symbol = [\":00\", \":15\", \":30\", \":45\"];\n        \n        let curHour = Math.floor(p_QH/4);\n        let curQH = p_QH - 4 * curHour;\n        let Result = \"\";\n        \n        if (curHour < 24) {\n            Result += curHour.toString()\n            + QH_Symbol[curQH];\n        }\n        else {\n            Result += \"+\" + (curHour-24).toString()\n            + QH_Symbol[curQH];\n        }\n        \n        return Result;\n        \n    }\n    \n    global.set(\"Victron_MESS.Functions.QHToText\", \n               QHToText);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"Not\";\n\n    const Not = (p_Boolean) =>\n    {\n        return !p_Boolean;\n    }\n    \n    global.set(\"Victron_MESS.Functions.Not\", Not);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"CtToText\";\n\n    const CtToText = (C) =>\n    {\n        let C1= Round(C, 1);\n        return Number(C1).toFixed(1) + \"ct\";\n    } // CtToText\n    \n    global.set(\"Victron_MESS.Functions.CtToText\", CtToText);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"HourToText\";\n\n    const HourToText = (H) =>\n    {\n        if (Number(H) <= 23) {\n            return Number(H).toString();\n        }\n        else {\n            return \"+\" + (Number(H)-24).toString();\n        }\n    } // HourToText\n    \n    global.set(\"Victron_MESS.Functions.HourToText\", HourToText);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"WhToText\";\n\n    const WhToText = (p_Wh, dec) =>\n    {\n        let WhSign = Math.sign(p_Wh);\n        let WhAbs = Math.abs(p_Wh);\n        if (WhAbs >= 1000) {\n            if (dec == null) // 1 decimal\n                { return ((WhSign * Round(WhAbs/100)/10)).toFixed(1) + \"kWh\" }\n            else if (dec == 0)\n                { return ((WhSign * Round(WhAbs/1000))).toFixed(dec) + \"kWh\" }\n            else if (dec == 1)\n                { return ((WhSign * Round(WhAbs/100)/10)).toFixed(dec) + \"kWh\" }\n            else if (dec == 2)\n                { return ((WhSign * Round(WhAbs/10)/100)).toFixed(dec) + \"kWh\" }\n                \n        }\n        else {\n            return (WhSign * Round(WhAbs)).toString() + \"Wh\";\n        }\n    } // WhToText\n    \n    global.set(\"Victron_MESS.Functions.WhToText\", WhToText);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"kWhToWh\";\n\n    const kWhToWh = (x) =>\n    {\n        return Round(x * 1000);\n        \n    } // kWhToWh\n    \n    global.set(\"Victron_MESS.Functions.kWhToWh\", kWhToWh);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"Round\";\n\n    const Round = (x, dec) =>\n    {\n        let curSign = Math.sign(x);\n        let x_abs = Math.abs(x);\n        \n        if (dec == null)\n            { return curSign * Math.round(x_abs) }\n        else if (dec == 0)\n            { return curSign * Math.round(x_abs) }\n        else if (dec == 1)\n            { return curSign * Math.round(x_abs*10) / 10 }\n        else if (dec == 2)\n            { return curSign * Math.round(x_abs*100) / 100 }\n        else if (dec == 3)\n            { return curSign * Math.round(x_abs*1000) / 1000 }\n        else if (dec == -1)\n            { return curSign * Math.round(x_abs/10) * 10 }\n        else if (dec == -2)\n            { return curSign * Math.round(x_abs/100) * 100 }\n        else if (dec == -3)\n            { return curSign * Math.round(x_abs/1000) * 1000 }\n        else\n            { return curSign * Math.round(x_abs) }\n    } // Round\n    \n    global.set(\"Victron_MESS.Functions.Round\", Round);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"Price_incl_Cost\";\n\n    const Price_incl_Cost = (Net_Price, CallerName) =>\n    {\n        var DebugStep = \"Start\";\n        var NewLine = \"\\n\\r\";\n\n    try\n        {\n            DebugStep = \"Test Undefined\";\n            \n            // node.warn(typeof Net_Price);\n            if (typeof Net_Price == 'undefined')\n            {\n                node.warn(\"CallerName: \" + CallerName + NewLine\n                    + \"Price_incl_Cost; Net_Price is: \" + Net_Price);\n        \n            }\n        \n            DebugStep = \"Get Globals\";\n        \n        \tif (context.kWh_TaxCt == null) {\n        \t\tcontext.kWh_TaxCt = \n        \t\t  global.get(\"Victron_MESS.Param.kWh_TaxCt\");\n        \t\t// node.warn(\"kWh_TaxCt: \" + context.kWh_TaxCt);\n        \t\tif (context.kWh_TaxCt == null) {\n        \t\t\tnode.warn(\"Victron_MESS.Param.kWh_TaxCt: null\");\n        \t\t}\n        \t} // if context.kWh_TaxCt == null\n        \t\n        \tif (context.kWh_CostCt == null) {\n        \t\tcontext.kWh_CostCt = \n        \t\t  global.get(\"Victron_MESS.Param.kWh_CostCt\");\n        \t\t// node.warn(\"kWh_CostCt: \" + context.kWh_CostCt);\n        \t\tif (context.kWh_CostCt == null) {\n        \t\t\tnode.warn(\"Victron_MESS.Param.kWh_CostCt: null\");\n        \t\t}\n        \t} // if context.kWh_CostCt == null\n        \t\n        \tif (context.BTW_Perc == null) {\n        \t\tcontext.BTW_Perc = \n        \t\t  global.get(\"Victron_MESS.Param.BTW_Perc\");\n        \t\t// node.warn(\"BTW_Perc: \" + context.BTW_Perc);\n        \t\tif (context.BTW_Perc == null) {\n        \t\t\tnode.warn(\"Victron_MESS.Param.BTW_Perc: null\");\n        \t\t}\n        \t} // if context.BTW_Perc == null\n        \t\n        \tDebugStep = \"Calculate Result\";\n        \t\n            result = (Number(Net_Price) \n        \t          + Number(context.kWh_TaxCt)\n        \t\t\t  + Number(context.kWh_CostCt)\n        \t\t\t )\n        \t\t\t * (1 + Number(context.BTW_Perc) / 100);\n        \t\t\t \n        }\n        catch (error)\n        {\n            node.warn(\"Error in \" + \"Price_incl_Cost\" + \":\" + NewLine\n                + \"CallerName: \" + CallerName + NewLine\n                + \"Step: \" + DebugStep + NewLine\n                + \"Error: \" + error)\n        }\n    \n        return result;\n    }\n    \n    global.set(\"Victron_MESS.Functions.Price_incl_Cost\", Price_incl_Cost);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"PosInArrayOfSets\";\n    \n    const PosInArrayOfSets = (p_ArrayOfSets, p_SearchQH) =>\n    \n    {\n        let Result = -1;\n        \n        for ( let i = 0; i < p_ArrayOfSets.length; i++)\n        {\n            if ( p_ArrayOfSets[i][0] == p_SearchQH ) \n            {\n                Result = i;\n                break;\n            } // Item was found\n        } // for i\n        \n        return Result;\n        \n    } // PosInArrayOfSets\n    \n    global.set(\"Victron_MESS.Functions.PosInArrayOfSets\", PosInArrayOfSets);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"IsInArrayOfSets\";\n    \n    const IsInArrayOfSets = (p_ArrayOfSets, p_SearchQHs) =>\n    \n    { // See if any of the items within array p_SearchQHs\n      // are in array p_ArrayOfSets{hour, value]\n        let Result = false;\n        \n        for (let i = 0; i < p_SearchQHs.length; i++) {\n            for ( let j = 0; j < p_ArrayOfSets.length; j++)\n            {\n                if ( p_ArrayOfSets[j][0] == p_SearchQHs[i] ) \n                {\n                    Result = true;\n                    break;\n                } // Item was found\n            } // for j\n            if (Result) break;\n        } // all items\n        \n        return Result; // not found\n        \n    } // IsInArrayOfSets\n    \n    global.set(\"Victron_MESS.Functions.IsInArrayOfSets\", IsInArrayOfSets);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"ArrayOfSetsGetPriceByHour\";\n    \n    const ArrayOfSetsGetPriceByHour = (p_ArrayOfSets, p_SearchQH) =>\n    \n    { // Find the price of the specified hour \n      // is in array p_ArrayOfSets{hour, value]\n        let Result = null;\n        \n        for (let i = 0; i < p_ArrayOfSets.length; i++) {\n            if ( p_ArrayOfSets[i][0] == p_SearchQH ) \n            {\n                Result = p_ArrayOfSets[i][1];\n                break;\n            } // Item was found\n        } // all items\n        \n        return Result;\n        \n    } // ArrayOfSetsGetPriceByHour\n    \n    global.set(\"Victron_MESS.Functions.ArrayOfSetsGetPriceByHour\", \n                  ArrayOfSetsGetPriceByHour);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"ArrayOfSets_SortByPrice_Asc\";\n    \n    const ArrayOfSets_SortByPrice_Asc = (pair_1, pair_2) =>\n    {\n        // each param a, b contains [ hour, price ]\n        // So, argument [0] is hour, argument [1] is price\n        if ( ( (pair_1[0] <= 23) && (pair_2[0] <= 23) )\n          || ( (pair_1[0] > 23)  && (pair_2[0] > 23)  )\n           ) // same day\n        {\n          if (pair_1[1] < pair_2[1])\n          { return -1 }\n          else { return 1 }\n            \n        } \n        else if ( (pair_1[0] <= 23) && (pair_2[0] > 23) )\n        { return -1 } \n        else { return 1 } \n        \n    } // ArrayOfSets_SortByPriceFn\n    \n    global.set(\"Victron_MESS.Functions.ArrayOfSets_SortByPrice_Asc\", \n                 ArrayOfSets_SortByPrice_Asc);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"ArrayOfSets_SortByPrice_Desc\";\n    \n    const ArrayOfSets_SortByPrice_Desc = (pair_1, pair_2) =>\n    {\n        // each param a, b contains [ hour, price ]\n        // So, argument [0] is hour, argument [1] is price\n        if ( ( (pair_1[0] <= 23) && (pair_2[0] <= 23) )\n          || ( (pair_1[0] > 23)  && (pair_2[0] > 23)  )\n           ) // same day\n        {\n          if (pair_2[1] < pair_1[1])\n          { return -1 }\n          else { return 1 }\n            \n        } \n        else if ( (pair_1[0] <= 23) && (pair_2[0] > 23) )\n        { return -1 } \n        else { return 1 } \n        \n    } // ArrayOfSets_SortByPrice_Desc\n    \n    global.set(\"Victron_MESS.Functions.ArrayOfSets_SortByPrice_Desc\", \n                 ArrayOfSets_SortByPrice_Desc);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"ArrayOfSets_SortOnlyByPrice_Asc\";\n    \n    const ArrayOfSets_SortOnlyByPrice_Asc = (pair_1, pair_2) =>\n    {\n        // each param a, b contains [ hour, price ]\n        // So, argument [0] is hour, argument [1] is price\n        if (pair_1[1] < pair_2[1])\n        { return -1 }\n        else\n        { return 1 }\n    \n    } // ArrayOfSets_SortOnlyByPrice_Asc\n    \n    global.set(\"Victron_MESS.Functions.ArrayOfSets_SortOnlyByPrice_Asc\", \n                 ArrayOfSets_SortOnlyByPrice_Asc);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\n    DebugStep = \"Add_Trace\";\n    \n    const Add_Trace = (p_ID, NewText) =>\n    {\n        \n        // node.warn(NewText);\n        \n        if (p_ID == null)\n        {\n            node.warn(p_ID)\n        }\n        \n        let curTraceText = global.get(\"Trace.\" + p_ID);\n\n        if (curTraceText == null)\n        {\n            curTraceText = [\"\"];\n        }\n\n        let curTraceTextIndex = curTraceText.length - 1;\n\n        if (NewText == \"ClearTrace\")\n        {\n            curTraceText = [\"\"];\n            curTraceTextIndex = 0;\n\n        }\n\n        else if ( (curTraceText[curTraceTextIndex].length + NewText.length) > 1000)\n        {\n            curTraceTextIndex++;\n            curTraceText[curTraceTextIndex] += NewLine;\n            curTraceText[curTraceTextIndex] = NewText;\n        }\n        else\n        {\n            curTraceText[curTraceTextIndex] += NewText;\n        }\n\n        global.set(\"Trace.\" + p_ID , curTraceText);\n\n        return null;\n    \n    } // Add_Trace\n\n    global.set(\"Victron_MESS.Functions.Add_Trace\", \n                 Add_Trace);\n    \n    // - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n    \n    DebugStep = \"Finish\";\n    \n    // And use this one:\n    let NowTime = GetNowTime();\n    \n    global.set(\"Victron_MESS.LastRun.Deploy.Functions\"); // remove\n    global.set(\"Victron_MESS.LastRun.Deploy.Functions\", NowTime);\n    \n    node.status( \n      { fill:\"green\", \n        shape:\"dot\",\n        text: \"@ \" + NowTime\n      } );\n\n}\ncatch (error)\n{\n    node.warn(\"Error in \" + \"SetGlobalFunctions\" + \":\" + NewLine\n    + \"Step: \" + DebugStep + NewLine\n    + \"Error: \" + error)\n\n    node.status( \n    { fill:\"red\", \n        shape:\"dot\",\n        text: \"@ \" + NowTime + \" \"\n        + \"Step: \" + DebugStep + \"; Error: \" + error }\n    );\n    \n}\n\nreturn msg;\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 346,
        "y": 512,
        "wires": [
        "id": "1617e6b7dce07a36",
        "type": "change",
        "name": "",
        "rules": [
                "t": "delete",
                "p": "Victron_MESS.Functions",
                "pt": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 410,
        "y": 416,
        "wires": [
                "700472570d90bc88"
        "id": "700472570d90bc88",
        "type": "switch",
        "name": "Functions is NULL",
        "property": "Victron_MESS.Functions",
        "rules": [
                "t": "null"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 350,
        "y": 464,
        "wires": [
                "ac3e701902b41060"
        "id": "a1dc31488e292602",
        "type": "inject",
        "name": "1 min",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "60",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Check Functions",
        "x": 102,
        "y": 464,
        "wires": [
                "700472570d90bc88"
        "id": "ede884d4c779e08d",
        "type": "inject",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Delete Functions",
        "x": 122,
        "y": 416,
        "wires": [
                "1617e6b7dce07a36"
  • MJ de Bruijn
Flow Parameters - Diverse parameters
Omdat de instelling van parameters per setup zal verschillen geef ik hierna slechts een selectie van mijn gegevens als voorbeeld.
(Een bijkomende reden is dat de lengte van een Forum bijdrage de lengte van het totaal niet toestaat).
Deel 3.
Afbeeldingslocatie: https://tweakers.net/i/ShuROjKeA6MvJimZxyPGIupoWF4=/800x/filters:strip_icc():strip_exif()/f/image/sVWNtBdHOmxRxIsEFNsNkdYB.jpg?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
777
778
779
780
781
782
783
784
785
        "id": "f0950da7d6ff8217",
        "type": "change",
        "name": "Conversion_Loss_Factor (0.9)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.Conversion_Loss_Factor",
                "pt": "global",
                "to": "0.9",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 394,
        "y": 1216,
        "wires": [
        "id": "537a960b51cab901",
        "type": "change",
        "name": "Buy_Price_Difference_LimitCt (10)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.Buy_Price_Difference_LimitCt",
                "pt": "global",
                "to": "10",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 404,
        "y": 976,
        "wires": [
        "id": "47cdf21f872f0a11",
        "type": "change",
        "name": "PV_Turn_Off_Price_LimitCt (-15)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.PV_Turn_Off_Price_LimitCt",
                "pt": "global",
                "to": "-15",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 404,
        "y": 1168,
        "wires": [
        "id": "70a50f4186c1168a",
        "type": "change",
        "name": "VeryLowPriceThresholdCt (2)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.VeryLowPriceThresholdCt",
                "pt": "global",
                "to": "2",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 380,
        "y": 880,
        "wires": [
        "id": "7479116b1db6bdf3",
        "type": "change",
        "name": "ZeroPriceThresholdCt (0.1)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.ZeroPriceThresholdCt",
                "pt": "global",
                "to": "0.1",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 380,
        "y": 832,
        "wires": [
        "id": "efd628fc51655937",
        "type": "change",
        "name": "NegativePriceThresholdCt (-0.5)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.NegativePriceThresholdCt",
                "pt": "global",
                "to": "-0.5",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 390,
        "y": 784,
        "wires": [
        "id": "2946ee12ca65a101",
        "type": "change",
        "name": "Energy_to_Sell_Buffer_Wh (10)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.Energy_to_Sell_Buffer_Wh",
                "pt": "global",
                "to": "10",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 390,
        "y": 736,
        "wires": [
        "id": "8ee10c9a91ed118c",
        "type": "delay",
        "name": "",
        "pauseType": "delayv",
        "timeout": "1",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 1216,
        "wires": [
                "f0950da7d6ff8217",
                "21aee576d83d6976"
        "id": "752db992978083ee",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 976,
        "wires": [
                "537a960b51cab901",
                "dea649f4022b8e08"
        "id": "f259ba3bc3206215",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 1168,
        "wires": [
                "47cdf21f872f0a11",
                "8ee10c9a91ed118c"
        "id": "36b4d70a38d7013d",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 112,
        "y": 880,
        "wires": [
                "70a50f4186c1168a",
                "3ca86c5202dddb8a"
        "id": "a3f8adbd2d3d5bd1",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 112,
        "y": 832,
        "wires": [
                "7479116b1db6bdf3",
                "36b4d70a38d7013d"
        "id": "bb14770781e92314",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 112,
        "y": 784,
        "wires": [
                "efd628fc51655937",
                "a3f8adbd2d3d5bd1"
        "id": "21aee576d83d6976",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 1264,
        "wires": [
                "e89af4aee2f66aac",
                "808e7401f1e5a657"
        "id": "808e7401f1e5a657",
        "type": "change",
        "name": "Batt_Capacity_Wh (3 x 5.12 x 1000)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.Batt_Capacity_Wh",
                "pt": "global",
                "to": "15360",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 414,
        "y": 1264,
        "wires": [
        "id": "d311a4d4a273c069",
        "type": "change",
        "name": "kWh_TaxCt (10.15)",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "kWh_TaxCt",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "10.15",
                "tot": "str"
                "t": "set",
                "p": "Victron_MESS.Param.kWh_TaxCt",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 354,
        "y": 1024,
        "wires": [
                "3d55964532332309"
        "id": "dda3f009a9085fa7",
        "type": "change",
        "name": "kWh_CostCt (2.05)",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "kWh_CostCt",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "2.05",
                "tot": "str"
                "t": "set",
                "p": "Victron_MESS.Param.kWh_CostCt",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 354,
        "y": 1072,
        "wires": [
                "3d55964532332309"
        "id": "e62627e031e3d5dd",
        "type": "change",
        "name": "BTW_Perc (21)",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "BTW_Perc",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "21",
                "tot": "str"
                "t": "set",
                "p": "Victron_MESS.Param.BTW_Perc",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 344,
        "y": 1120,
        "wires": [
                "3d55964532332309"
        "id": "dea649f4022b8e08",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 1024,
        "wires": [
                "6545a2764919e29b",
                "d311a4d4a273c069"
        "id": "6545a2764919e29b",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 1072,
        "wires": [
                "c455bcedceb07a20",
                "dda3f009a9085fa7"
        "id": "c455bcedceb07a20",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 1120,
        "wires": [
                "e62627e031e3d5dd",
                "f259ba3bc3206215"
        "id": "3d55964532332309",
        "type": "function",
        "name": "Calc All Cost",
        "func": "context = context || {};\n\nGetNowTime = global.get(\"Victron_MESS.Functions.GetNowTime\");\nlet NowTime = GetNowTime();\n\nRound = global.get(\"Victron_MESS.Functions.Round\");\n\nif (msg.topic == \"kWh_TaxCt\")\n{\n    context.kWh_TaxCt = Number(msg.payload);\n    // node.warn(\"kWh_TaxCt: \" + context.kWh_TaxCt);\n    return;\n}\nelse if (msg.topic == \"kWh_CostCt\")\n{\n    context.kWh_CostCt = Number(msg.payload);\n    // node.warn(\"kWh_CostCt: \" + context.kWh_CostCt);\n    return;\n}\nelse if (msg.topic == \"BTW_Perc\")\n{\n    context.BTW_Perc = Number(msg.payload);\n    // node.warn(\"BTW_Perc: \" + context.BTW_Perc);\n}\n\nif ((context.kWh_TaxCt != null)\n&&  (context.kWh_CostCt != null)\n&&  (context.BTW_Perc != null) )\n{\n    All_CostCt = \n    Round( (context.kWh_TaxCt + context.kWh_CostCt)\n     * (1 + context.BTW_Perc/100), 2 ).toString();\n\n\n    msg.type = \"call_service\";\n    msg.domain = \"input_text\";\n    msg.service = \"set_value\";\n    msg.entity_id = \"input_number.dayahead_all_costct\";\n\n    msg.topic = \"All_CostCt\";\n    msg.payload = All_CostCt;\n    \n    global.set (\"Victron_MESS.Param.All_CostCt\") // remove\n    global.set (\"Victron_MESS.Param.All_CostCt\", All_CostCt)\n\n    node.status( \n      { fill: \"green\", \n        shape: \"dot\",\n        text: \"@ \" + NowTime + \", All Cost: \"+ msg.payload\n      } );\n    \n}\nelse\n{\n    node.status( \n      { fill: \"red\", \n        shape: \"dot\",\n        text: \"@ \" + NowTime + \"Error\"\n      } );\n      \n    msg = null;\n}\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 558,
        "y": 1120,
        "wires": [
                "7f03e8f188d4ad1c"
        "id": "7f03e8f188d4ad1c",
        "type": "link out",
        "name": "Link AllCost to Home Assistant Api",
        "mode": "link",
        "links": [
            "30a7afbf79ee7ae6"
        "x": 661,
        "y": 1120,
        "wires": []
        "id": "b7d518dd3146316f",
        "type": "change",
        "name": "Delay 50",
        "rules": [
                "t": "set",
                "p": "delay",
                "pt": "msg",
                "to": "50",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 112,
        "y": 688,
        "wires": [
                "5e39357b0d66a4bd"
        "id": "3259667b30c1f855",
        "type": "inject",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "Deploy Params",
        "x": 112,
        "y": 640,
        "wires": [
                "b7d518dd3146316f"
        "id": "5e39357b0d66a4bd",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 112,
        "y": 736,
        "wires": [
                "bb14770781e92314",
                "2946ee12ca65a101"
        "id": "c981900724b44000",
        "type": "cronplus",
        "name": "at 00:00:00",
        "timeZone": "",
        "storeName": "",
        "outputs": 1,
        "options": [
                "topic": "topic1",
                "payload": "",
                "expression": "0 0 0 * * * * ",
                "location": "",
                "offset": "0",
                "solarType": "all",
        "x": 122,
        "y": 592,
        "wires": [
                "b7d518dd3146316f"
        "id": "3e071cd9382fde27",
        "type": "change",
        "name": "Sell_Price_Difference_LimitCt (5)",
        "rules": [
                "t": "set",
                "p": "Victron_MESS.Param.Sell_Price_Difference_LimitCt",
                "pt": "global",
                "to": "5",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 404,
        "y": 928,
        "wires": [
        "id": "3ca86c5202dddb8a",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 116,
        "y": 928,
        "wires": [
                "752db992978083ee",
                "3e071cd9382fde27"
  • MJ de Bruijn
  • Registratie: November 2016
  • Laatst online: 08:59
Flow States - Calc Solar Surplus Now
Dit gedeelte monitort voortdurend of er meer zonne-energie wordt opgewekt dan verbruikt (door 'het huis').
De uitkomst wordt gebruikt bij het kiezen tussen wel of niet rechtstreeks gebruiken van het Grid.
Afbeeldingslocatie: https://tweakers.net/i/XOw8nq5sHvt7v4qxE_lFePCUgvY=/800x/filters:strip_icc():strip_exif()/f/image/kxUDQJeTKYTfxRdecsuv5T6X.jpg?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
        "id": "c07eb22635b761ff",
        "type": "victron-input-vebus",
        "z": "873bf4cb2fbee905",
        "service": "com.victronenergy.vebus/276",
        "path": "/Ac/Out/L1/P",
        "serviceObj": {
            "name": "MultiPlus-II 48/3000/35-32"
        "pathObj": {
            "type": "float",
            "name": "Output power phase 1 (W)"
        "name": "AC_OUT_L1_W",
        "onlyChanges": false,
        "x": 140,
        "y": 192,
        "wires": [
                "fc6b981413443dfd"
        "id": "3f861b9b58be2427",
        "path": "/Ac/Out/L2/P",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Output power phase 2 (W)"
        "name": "AC_OUT_L2_W",
        "x": 140,
        "y": 240,
        "wires": [
                "fc6b981413443dfd"
        "id": "24c7e101fbb5eab5",
        "path": "/Ac/Out/L3/P",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Output power phase 3 (W)"
        "name": "AC_OUT_L3_W",
        "x": 140,
        "y": 288,
        "wires": [
                "fc6b981413443dfd"
        "id": "cd32c1cf5b4f93db",
        "path": "/Ac/ActiveIn/L1/P",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Input power phase 1 (W)"
        "name": "AC_IN_L1_W",
        "roundValues": "0",
        "x": 130,
        "y": 384,
        "wires": [
                "fc6b981413443dfd"
        "id": "a74a1fe15478954b",
        "path": "/Ac/ActiveIn/L2/P",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Input power phase 2 (W)"
        "name": "AC_IN_L2_W",
        "roundValues": "0",
        "x": 130,
        "y": 432,
        "wires": [
                "fc6b981413443dfd"
        "id": "d14de3d297bde2bc",
        "path": "/Ac/ActiveIn/L3/P",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Input power phase 3 (W)"
        "name": "AC_IN_L3_W",
        "roundValues": "0",
        "x": 130,
        "y": 480,
        "wires": [
                "fc6b981413443dfd"
        "id": "bbeb63cd759c1b2b",
        "type": "victron-input-solarcharger",
        "service": "com.victronenergy.solarcharger/279",
        "path": "/Yield/Power",
        "serviceObj": {
            "name": "SmartSolar Charger MPPT 100/20 48V"
        "pathObj": {
            "type": "float",
            "name": "PV Power (W)"
        "name": "Solar_Charger_W",
        "roundValues": "0",
        "x": 150,
        "y": 336,
        "wires": [
                "fc6b981413443dfd"
        "id": "fc6b981413443dfd",
        "type": "function",
        "name": "Calc Solar Surplus Now",
        "func": "const ProgName = \"Calc Solar Surplus Now\";\n\ncontext = context || {};\n\nlet Now = new Date();\nStartTime = Math.floor(Now.getTime() / 1000);\n\nlet NewLine = \"\\n\\r\";\n\nif (context.First_StartTime == null)\n{\n    context.First_StartTime = StartTime;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nif ( !(Get_Functions() ) )\n{   \n    return null;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nfunction Get_Functions() {\n\nlet NewLine = \"\\n\\r\";\nlet FuncCount = 0;\nlet FuncNull = 0;\nlet ErrText = \"\";\nlet Result = true;\n\ntry {\n\n    FuncCount++;\n    GetNowTime = global.get(\"Victron_MESS.Functions.GetNowTime\");\n    if (GetNowTime  == null)\n    {   ErrText += \"Victron_MESS.Functions.GetNowTime\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    FuncCount++;\n    Not = global.get(\"Victron_MESS.Functions.Not\");\n    if (Not  == null)\n    {   ErrText += \"Victron_MESS.Functions.Not\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n    \n    FuncCount++;\n    Round = global.get(\"Victron_MESS.Functions.Round\");\n    if (Round  == null)\n    {   ErrText += \"Victron_MESS.Functions.Round\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    if ( !(Result) )\n    {\n        node.status(\n            {fill:\"black\",\n            shape:\"dot\",\n            text: \"Wait for Get_Functions \"\n                + \"(\" + FuncNull + \"/\" + FuncCount + \")...\"\n            }\n        );\n    }\n    \n    if (ErrText > \"\")\n    {   \n        if (context.Next_Error_Time == null)\n        {\n            context.Next_Error_Time = StartTime;\n        }\n        if (StartTime >= context.Next_Error_Time)\n        {\n            node.warn(\"Error Get_Functions:\" + NewLine + ErrText);\n            context.Next_Error_Time = StartTime + 15;\n        }\n\n        node.status({fill:\"red\", shape:\"dot\",\n                     text: ProgName + \": Error Get_Functions\" }\n                   );\n    }\n    \n} // try\ncatch (error)\n{\n    Result = false;\n    \n    node.error(\"Program: \" + ProgName + NewLine\n    + \"Step: Get_Functions\" + NewLine\n    + \"Error: \" + error)\n    \n} // catch\n\nreturn Result;\n    \n} // Get_Functions\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nlet NowTime = GetNowTime(\"uu:mm:ss\");\nlet StartInSeconds = GetNowTime(\"NowInSeconds\");\n\nvar Energy_from_Solar_Now_W = 0;\nvar Energy_to_Non_Crit_W = 0;\nvar Energy_to_Critical_W = 0;\n\nif (context.Energy_from_Solar_Total_W == null) {\n    context.Energy_from_Solar_Total_W = 0;\n}\nif (context.MsgCount == null) {\n    context.MsgCount = 0;\n}\nif (context.NextOutputTime == null) {\n    context.NextOutputTime = StartInSeconds;\n}\n\nswitch (msg.topic) {\n    \n  case \"RunNow\":\n    context.RunNow = true;\n    msg = null;\n    break;\n    \n  case \"AC_IN_L1_W\":\n    context.AC_IN_L1_W = msg.payload;  \n    msg = null;\n    break;\n    \n  case \"AC_IN_L2_W\":\n    context.AC_IN_L2_W = msg.payload;  \n    msg = null;\n    break;\n    \n  case \"AC_IN_L3_W\":\n    context.AC_IN_L3_W = msg.payload;  \n    msg = null;\n    break;\n    \n  case \"AC_OUT_L1_W\":\n    context.AC_OUT_L1_W = msg.payload;  \n    msg = null;\n    break;\n    \n  case \"AC_OUT_L2_W\":\n    context.AC_OUT_L2_W = msg.payload;  \n    msg = null;\n    break;\n    \n  case \"AC_OUT_L3_W\":\n    context.AC_OUT_L3_W = msg.payload;  \n    msg = null;\n    break;\n\n  case \"Solar_Charger_W\":\n    context.Solar_Charger_W = msg.payload;\n    msg = null;\n    break;\n    \n  case \"ET340_L1_W\":\n    context.ET340_L1_W = msg.payload;  \n    msg = null;\n    break;\n    \n  case \"ET340_L2_W\":\n    context.ET340_L2_W = msg.payload;  \n    msg = null;\n    break;\n    \n  case \"ET340_L3_W\":\n    context.ET340_L3_W = msg.payload;  \n    msg = null;\n    break;\n     \n  case \"SolarEdge_L1_W\":\n    context.SolarEdge_L1_W = msg.payload;  \n    msg = null;\n    break;\n     \n  case \"SolarEdge_L2_W\":\n    context.SolarEdge_L2_W = msg.payload;  \n    msg = null;\n    break;\n     \n  case \"SolarEdge_L3_W\":\n    context.SolarEdge_L3_W = msg.payload;  \n    msg = null;\n    break;\n     \n  default: \n      ErrorText += \"Unknown Topic: \" + msg.topic \n      + \" Payload: \" + msg.payload\n      + \"\\r\";\n      context.RunNow = true;\n      \n} // switch for input all variables\n\nif   (  (context.AC_IN_L1_W != null)\n    && (context.AC_IN_L2_W != null)\n    && (context.AC_IN_L3_W != null)\n    && (context.AC_OUT_L1_W != null)\n    && (context.AC_OUT_L2_W != null)\n    && (context.AC_OUT_L3_W != null)\n    && (context.Solar_Charger_W != null)\n    && (context.ET340_L1_W != null)\n    && (context.ET340_L2_W != null)\n    && (context.ET340_L3_W != null)\n    && (context.SolarEdge_L1_W != null)\n    && (context.SolarEdge_L2_W != null)\n    && (context.SolarEdge_L3_W != null)\n    )\n{\n\n    // if AC-OUT is positive, this is consumption,\n    // if AC-OUT is negative then PV available.\n    // Change sign to calculate with positive value\n    Energy_from_Solar_Now_W = - context.AC_OUT_L1_W\n                          - context.AC_OUT_L2_W \n                          - context.AC_OUT_L3_W;\n\n    Energy_from_Solar_Now_W += context.Solar_Charger_W;\n\n    // NOTE: SOLAREDGE VALUES ARE NEGATIVE\n\n    // Calculate Usage by critical devices\n    Energy_to_Critical_W = context.AC_OUT_L1_W \n                         + context.AC_OUT_L2_W \n                         + context.AC_OUT_L3_W\n                         + Math.abs(context.SolarEdge_L1_W) \n                         + Math.abs(context.SolarEdge_L2_W)\n                         + Math.abs(context.SolarEdge_L3_W);\n                         \n\n    Energy_to_Critical_W = Math.max(0, Energy_to_Critical_W);\n\n    // Calculate Usage by non-critical devices\n    Energy_to_Non_Crit_W = context.ET340_L1_W \n                         + context.ET340_L2_W \n                         + context.ET340_L3_W\n                         - context.AC_IN_L1_W \n                         - context.AC_IN_L2_W \n                         - context.AC_IN_L3_W;\n                         \n    Energy_to_Non_Crit_W = Math.max(0, Energy_to_Non_Crit_W);\n\n    Energy_from_Solar_Now_W -= Energy_to_Non_Crit_W;\n\n    Energy_from_Solar_Now_W = Math.max(Energy_from_Solar_Now_W, 0);\n    \n    // Summarize for later Average\n    context.Energy_from_Solar_Total_W += Energy_from_Solar_Now_W;\n    context.MsgCount += 1;\n    \n    if (StartInSeconds > context.NextOutputTime) {\n        \n        let Average = \n          Round(context.Energy_from_Solar_Total_W / \n                       Math.max(context.MsgCount, 1), -1 );\n                       \n        // reset\n        context.Energy_from_Solar_Total_W = null;\n        context.MsgCount = null;\n        context.NextOutputTime = null;\n\n        if (Average > 0) {\n            node.status( {fill:\"green\",shape:\"dot\",\n                          text: \"@ \" +  NowTime + \": \" + Average + \" W; \"\n                        + \"Critical: \" + Energy_to_Critical_W + \"; \"\n                        + \"Non-Crit: \" + Energy_to_Non_Crit_W\n            } );\n        }\n        else {\n            node.status( {fill:\"grey\",shape:\"dot\",\n                          text: \"@ \" +  NowTime + \": No Surplus; \"\n                        + \"Critical: \" + Energy_to_Critical_W + \"; \"\n                        + \"Non-Crit: \" + Energy_to_Non_Crit_W\n                          } );\n        }\n\n        // if (context.Last_Average != Average)\n        // {\n        //     context.Last_Average = Average;\n            \n            return { topic: \"Solar_Surplus\", payload: Average }\n        // }\n        \n    } // output only every few seconds\n\n} // if init OK\n\n",
        "outputs": 1,
        "timeout": "4",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 434,
        "y": 384,
        "wires": [
                "1ab0e39b023e2eca"
        "id": "ce89f82494c11431",
        "type": "victron-input-gridmeter",
        "service": "com.victronenergy.grid/33",
        "path": "/Ac/L1/Power",
        "serviceObj": {
            "name": "ET340 (Grid)"
        "pathObj": {
            "type": "float",
            "name": "L1 Power (W)"
        "name": "ET340_L1_W",
        "roundValues": "0",
        "x": 130,
        "y": 528,
        "wires": [
                "fc6b981413443dfd"
        "id": "3a379b3413cb039f",
        "path": "/Ac/L2/Power",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "L2 Power (W)"
        "name": "ET340_L2_W",
        "roundValues": "0",
        "x": 130,
        "y": 576,
        "wires": [
                "fc6b981413443dfd"
        "id": "3b17fee7be762407",
        "path": "/Ac/L3/Power",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "L3 Power (W)"
        "name": "ET340_L3_W",
        "roundValues": "0",
        "x": 130,
        "y": 624,
        "wires": [
                "fc6b981413443dfd"
        "id": "1ab0e39b023e2eca",
        "type": "link out",
        "name": "To Set State",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 611,
        "y": 384,
        "wires": []
        "id": "2f03491c31ecd365",
        "type": "victron-input-pvinverter",
        "service": "com.victronenergy.pvinverter/31",
        "serviceObj": {
            "name": "SolarEdge (ET340)"
        "pathObj": {
            "type": "float",
        "name": "SolarEdge_L1_W",
        "roundValues": "0",
        "x": 408,
        "y": 192,
        "wires": [
                "fc6b981413443dfd"
        "id": "a9ac17341615c1cb",
        "serviceObj": {
        "pathObj": {
            "type": "float",
        "name": "SolarEdge_L2_W",
        "roundValues": "0",
        "x": 408,
        "y": 240,
        "wires": [
                "fc6b981413443dfd"
        "id": "0546bb559874144a",
        "serviceObj": {
        "pathObj": {
            "type": "float",
        "name": "SolarEdge_L3_W",
        "roundValues": "0",
        "x": 408,
        "y": 288,
        "wires": [
                "fc6b981413443dfd"
[ Voor 3% gewijzigd door MJ de Bruijn op 01-12-2025 14:59 ]
  • MJ de Bruijn
Flow States - DESS en ESS
MESS houdt ook rekening met de mogelijkheid dat DESS wordt gebruikt (in plaats van MESS).
Eventuele wijzigingen van de instellingen worden ook doorgezonden aan Home Assistant (voor monitoring doeleinden).
Afbeeldingslocatie: https://tweakers.net/i/JgFuGmp4ZZHGrrGXzjruluusU1c=/800x/filters:strip_icc():strip_exif()/f/image/ObLPUdwCUPsmAF5XtumCWofi.jpg?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
        "id": "e0dfb9db0c37b271",
        "type": "subflow",
        "name": "Show",
        "info": "",
        "category": "",
        "in": [
                "x": 52,
                "y": 48,
                "wires": [
                        "id": "274fd352337bfbb9"
        "out": [
                "x": 308,
                "y": 48,
                "wires": [
                        "id": "274fd352337bfbb9",
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99",
        "status": {
            "x": 308,
            "y": 96,
            "wires": [
                    "port": 1
        "type": "function",
        "z": "e0dfb9db0c37b271",
        "name": "Show Payload",
        "func": "const Now = new Date();\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n                + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n                + (\"0\" + Now.getSeconds()).slice(-2) ;\n\nmsgState = { topic:'state', \n             payload: \"@ \" + NowTime + \": \"+ msg.topic + \": \" + msg.payload,\n             shape: \"dot\",\n             color: \"grey\"\n};\n\nnode.send( [msg, msgState] );\n\nnode.done;",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 176,
        "y": 64,
        "wires": [
        "id": "90dcbfba68b349c8",
        "type": "victron-input-custom",
        "service": "com.victronenergy.settings",
        "path": "/Settings/DynamicEss/Mode",
        "serviceObj": {
            "name": "com.victronenergy.settings"
        "pathObj": {
            "name": "/Settings/DynamicEss/Mode",
            "type": "number"
        "name": "DESS_Mode",
        "roundValues": "0",
        "x": 130,
        "y": 688,
        "wires": [
                "8e38f3b762cd85ab",
                "568cea0f90de2435"
        "id": "78eb311d83ac3b59",
        "type": "victron-input-battery",
        "service": "com.victronenergy.battery/512",
        "path": "/Soc",
        "serviceObj": {
            "name": "Totle Power"
        "pathObj": {
            "path": "/Soc",
            "type": "float",
            "name": "State of charge (%)"
        "name": "SoC_Now_Perc",
        "roundValues": "1",
        "x": 144,
        "y": 896,
        "wires": [
                "72d582578c02f0cd",
                "969699a25ab68669",
                "a676366b73611e87"
        "id": "a9394c7d423249f6",
        "type": "victron-input-ess",
        "path": "/Settings/CGwacs/BatteryLife/State",
        "serviceObj": {
            "name": "Venus settings"
        "pathObj": {
            "type": "enum",
            "name": "ESS state",
            "enum": {
                "1": "BatteryLife enabled (GUI controlled)",
                "2": "Optimized Mode /w BatteryLife: self consumption",
                "3": "Optimized Mode /w BatteryLife: self consumption, SoC exceeds 85%",
                "4": "Optimized Mode /w BatteryLife: self consumption, SoC at 100%",
                "5": "Optimized Mode /w BatteryLife: SoC below dynamic SoC limit",
                "6": "Optimized Mode /w BatteryLife: SoC has been below SoC limit for more than 24 hours. Charging the battery (5A)",
                "7": "Optimized Mode /w BatteryLife: Inverter/Charger is in sustain mode",
                "8": "Optimized Mode /w BatteryLife: recharging, SoC dropped by 5% or more below the minimum SoC",
                "9": "'Keep batteries charged' mode is enabled",
                "10": "Optimized mode w/o BatteryLife: self consumption, SoC at or above minimum SoC",
                "11": "Optimized mode w/o BatteryLife: self consumption, SoC is below minimum SoC",
                "12": "Optimized mode w/o BatteryLife: recharging, SoC dropped by 5% or more below minimum SoC"
        "initial": "",
        "name": "ESS_State",
        "x": 116,
        "y": 1088,
        "wires": [
                "c424324946c8d0df",
                "53700193147df894"
        "id": "53700193147df894",
        "type": "function",
        "name": "To Text: ESS_State",
        "func": "// Function To Text: ESS_State\n\ncontext = context || {};\n\nif (context.Last_Payload == null)\n{\n    context.Last_Payload = \"\";\n}\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\nif ( msg.topic == \"ESS_State\" )\n{\n    if (msg.payload == \"1\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Batt.Life Enabled (GUI controlled)\"\n    }\n    else if (msg.payload == \"2\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, /w Batt.Life, Self Cons.\"\n    }\n    else if (msg.payload == \"3\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, /w Batt.Life, Self Cons, SoC > 85%\"\n    }\n    else if (msg.payload == \"4\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, /w Batt.Life, Self Cons, SoC = 100%\"\n    }\n    else if (msg.payload == \"5\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, /w Batt.Life, SoC < Dyn.SoC\"\n    }\n    else if (msg.payload == \"6\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, /w Batt.Life, SoC < SoC limit (>24h), Charging\"\n    }\n    else if (msg.payload == \"7\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, /w Batt.Life, Inverter in Sustain Mode\"\n    }\n    else if (msg.payload == \"8\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, /w Batt.Life, Recharging, SoC 5% < min.SoC\"\n    }\n    else if (msg.payload == \"9\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Keep Batt.Charged\"\n    }\n    else if (msg.payload == \"10\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, w/o Batt.Life, Self Consumption, SoC >= Min.SoC\"\n    }\n    else if (msg.payload == \"11\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, w/o Batt.Life, SoC < Min.SoC'\"\n    }\n    else if (msg.payload == \"12\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Opt.Mode, w/o Batt.Life, Recharging, SoC < min.SoC-5%\"\n    }\n    else\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Unknown\"\n    }\n    msg.topic = msg.topic + \"_Text\";\n    \n\n    if (msg.payload != context.Last_Payload)\n    {\n        context.Last_Payload = msg.payload;\n        context.Last_Time = NowTime;\n        node.status( {fill:\"yellow\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n        return msg;\n    }\n    else {\n        node.status( {fill:\"green\", shape:\"dot\",\n                      text: \"@ \" + context.Last_Time + \": \"\n                      + msg.payload }\n                   );\n    }\n    \n}\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 374,
        "y": 1136,
        "wires": [
                "67639ea8dca2895e",
                "9432fb1fd2aaece1"
        "id": "72d582578c02f0cd",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 289,
        "y": 848,
        "wires": []
        "id": "67639ea8dca2895e",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 583,
        "y": 1136,
        "wires": []
        "id": "c424324946c8d0df",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 299,
        "y": 1088,
        "wires": []
        "id": "568cea0f90de2435",
        "type": "rbe",
        "name": "only changes",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "property": "payload",
        "topi": "topic",
        "x": 358,
        "y": 688,
        "wires": [
                "253b4e9f795118dc"
        "id": "969699a25ab68669",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 342,
        "y": 944,
        "wires": [
        "id": "9432fb1fd2aaece1",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 354,
        "y": 1184,
        "wires": [
                "0ebb7af534fecb1c"
        "id": "cf60cdb222be69f6",
        "path": "/Settings/CGwacs/BatteryLife/MinimumSocLimit",
        "serviceObj": {
        "pathObj": {
            "type": "integer",
            "name": "Minimum Discharge SOC (%)",
            "mode": "both"
        "initial": "",
        "name": "Min_Discharge_SoC",
        "x": 150,
        "y": 752,
        "wires": [
                "9b74cdc38a564b47"
        "id": "20bb0ad782fc5eec",
        "type": "link out",
        "name": "To Call Websocket Api",
        "mode": "link",
        "links": [
            "30a7afbf79ee7ae6"
        "x": 479,
        "y": 800,
        "wires": []
        "id": "7959bd2bb9a19cd4",
        "type": "change",
        "name": "Set API variables",
        "rules": [
                "t": "set",
                "p": "type",
                "pt": "msg",
                "to": "call_service",
                "tot": "str"
                "t": "set",
                "p": "domain",
                "pt": "msg",
                "to": "input_number",
                "tot": "str"
                "t": "set",
                "p": "service",
                "pt": "msg",
                "to": "set_value",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "input_number.helper_mess_target_soc",
                "tot": "str"
                "t": "set",
                "p": "entity_id",
                "pt": "msg",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 550,
        "y": 752,
        "wires": [
                "44ccb7601bb62ceb"
        "id": "44ccb7601bb62ceb",
        "type": "subflow:e0dfb9db0c37b271",
        "name": "",
        "x": 338,
        "y": 800,
        "wires": [
                "20bb0ad782fc5eec"
        "id": "a676366b73611e87",
        "type": "function",
        "name": "Batt SoC Full Time to State",
        "func": "// Function Batt SoC Full Time to State\n\ncontext = context || {}\n\nif (context.Last_SoC == null)\n{\n    context.Last_SoC = 0;\n}\n\nlet CurSoC = Number(msg.payload);\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\nlet Batt_SoC_Full_Time = \n    global.get(\"Victron_MESS.State.Batt_SoC_Full_Time\") || \"Unknown\";\n\nif ( (CurSoC >= 99)\n  && (CurSoC != context.Last_SoC) )\n{\n    global.set(\"Victron_MESS.State.Batt_SoC_Full_Time\",\n               NowTime);\n               \n    context.Last_SoC = CurSoC;\n\n    node.status( {fill:\"yellow\", shape:\"dot\",\n                  text: \"Batt_SoC_Full_Time: \" + NowTime }\n               );\n}\nelse \n{\n    node.status( {fill:\"green\", shape:\"dot\",\n                  text: \"Batt_SoC_Full_Time: \" + Batt_SoC_Full_Time }\n               );\n}\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 392,
        "y": 896,
        "wires": [
        "id": "0ebb7af534fecb1c",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "type",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "domain",
                "pt": "msg",
                "to": "input_text",
                "tot": "str"
                "t": "set",
                "p": "service",
                "pt": "msg",
                "to": "set_value",
                "tot": "str"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Send ESS_State as Text",
                "tot": "str"
                "t": "set",
                "p": "entity_id",
                "pt": "msg",
                "to": "input_text.helper_ess_state_as_text",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 554,
        "y": 1184,
        "wires": [
                "80d18571582bd73f"
        "id": "2bfe6d826ae7f142",
        "type": "link out",
        "mode": "link",
        "links": [
            "30a7afbf79ee7ae6"
        "x": 481,
        "y": 1232,
        "wires": []
        "id": "13431a85b02e802a",
        "type": "link out",
        "mode": "link",
        "links": [
            "30a7afbf79ee7ae6"
        "x": 673,
        "y": 688,
        "wires": []
        "id": "253b4e9f795118dc",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "type",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "domain",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "service",
                "pt": "msg",
                "to": "set_value",
                "tot": "str"
                "t": "set",
                "p": "entity_id",
                "pt": "msg",
                "to": "input_number.helper_dess_mode",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 550,
        "y": 688,
        "wires": [
                "13431a85b02e802a"
        "id": "9b74cdc38a564b47",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "topi": "topic",
        "x": 358,
        "y": 752,
        "wires": [
                "7959bd2bb9a19cd4"
        "id": "80d18571582bd73f",
        "name": "",
        "x": 338,
        "y": 1232,
        "wires": [
                "2bfe6d826ae7f142"
        "id": "8e38f3b762cd85ab",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 303,
        "y": 656,
        "wires": []
Een mens leert van zijn fouten. Ik heb in mijn leven heel veel geleerd.
  • MJ de Bruijn
Flow States - Diverse States
Heel veel entiteiten sturen iedere vijf seconden een update. De functie 'Set Payload in global.Victron_MESS.State' verwerkt deze en schrijft alleen veranderingen weg naar het Context Global Geheugengebied.
De optie 'Only Changes' van veel Nodes voldoet hier niet omdat, bijvoorbeeld bij een gedeeltelijke Deploy of het opschonen van Context Global, de basis-stand wordt gemist.
Afbeeldingslocatie: https://tweakers.net/i/SelLk4UTj48hVw9hnfgiHt_ASMQ=/800x/filters:strip_exif()/f/image/iZAsxYJhraXJpAucsZ6qPApQ.png?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
        "type": "subflow",
        "name": "Show",
        "info": "",
        "category": "",
        "in": [
                "x": 52,
                "y": 48,
                "wires": [
        "out": [
                "x": 308,
                "y": 48,
                "wires": [
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99",
        "status": {
            "x": 308,
            "y": 96,
            "wires": [
                    "port": 1
        "type": "function",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 176,
        "y": 64,
        "wires": [
        "id": "579401fa45c450f5",
        "type": "function",
        "name": "Set Payload in global.Victron_MESS.State",
        "func": "const ProgName = \"Set Payload in global.Victron_MESS.State\";\n\ncontext = context || {};\n\nlet Now = new Date();\nStartTime = Math.floor(Now.getTime() / 1000);\n\nlet NewLine = \"\\n\\r\";\n\nif (context.First_StartTime == null)\n{\n    context.First_StartTime = StartTime;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nif ( !(Get_Functions() ) )\n{   \n    return null;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nfunction Get_Functions() {\n\nlet NewLine = \"\\n\\r\";\nlet FuncCount = 0;\nlet FuncNull = 0;\nlet ErrText = \"\";\nlet Result = true;\n\ntry {\n\n    FuncCount++;\n    GetNowTime = global.get(\"Victron_MESS.Functions.GetNowTime\");\n    if (GetNowTime  == null)\n    {   ErrText += \"Victron_MESS.Functions.GetNowTime\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    FuncCount++;\n    Not = global.get(\"Victron_MESS.Functions.Not\");\n    if (Not  == null)\n    {   ErrText += \"Victron_MESS.Functions.Not\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n    \n    FuncCount++;\n    Round = global.get(\"Victron_MESS.Functions.Round\");\n    if (Round  == null)\n    {   ErrText += \"Victron_MESS.Functions.Round\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    if ( !(Result) )\n    {\n        node.status(\n            {fill:\"black\",\n            shape:\"dot\",\n            text: \"Wait for Get_Functions \"\n                + \"(\" + FuncNull + \"/\" + FuncCount + \")...\"\n            }\n        );\n    }\n    \n    if (ErrText > \"\")\n    {   \n        if (context.Next_Error_Time == null)\n        {\n            context.Next_Error_Time = StartTime;\n        }\n        if (StartTime >= context.Next_Error_Time)\n        {\n            node.warn(\"Error Get_Functions:\" + NewLine + ErrText);\n            context.Next_Error_Time = StartTime + 15;\n        }\n\n        node.status({fill:\"red\", shape:\"dot\",\n                     text: ProgName + \": Error Get_Functions\" }\n                   );\n    }\n    \n} // try\ncatch (error)\n{\n    Result = false;\n    \n    node.error(\"Program: \" + ProgName + NewLine\n    + \"Step: Get_Functions\" + NewLine\n    + \"Error: \" + error)\n    \n} // catch\n\nreturn Result;\n    \n} // Get_Functions\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\n\nif (msg.topic == \"Delete_States\") {\n    context = null;\n}\n\ncontext = context || {};\n\nif (context.Last_Payload == null)\n{\n    context.Last_Payload = [];\n}\n\nlet NowTime = GetNowTime();\n\nlet Entity_Name = \"Victron_MESS.State.\" + msg.topic;\n\nif (context.Last_Payload[msg.topic] != msg.payload)\n{\n    // Only Changes\n    // global.set(Entity_Name); // remove\n    global.set(Entity_Name, msg.payload);\n\n    // node.warn(msg.topic + \": \" + context.Last_Payload[msg.topic] + \" --> \" + msg.payload);\n    context.Last_Payload[msg.topic] = msg.payload;\n\n    node.status( {fill:\"yellow\", shape:\"dot\",\n              text: \"@ \" + NowTime + \": \"\n              + msg.topic + \": \" + msg.payload }\n           );\n\n}\nelse\n{\n    node.status( {fill:\"green\", shape:\"dot\",\n              text: \"@ \" + NowTime + \": \"\n              + msg.topic + \": \" + msg.payload }\n           );\n\n    msg = null;\n}\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "\n",
        "finalize": "",
        "libs": [],
        "x": 612,
        "y": 1600,
        "wires": [
                "ad07ebb674632a2a"
        "id": "28021ca47b0a4870",
        "path": "/Info/MaxChargeVoltage",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "CVL - Charge Voltage Limit (V)"
        "name": "Batt_Max_Charge_Voltage_V",
        "roundValues": "0",
        "x": 180,
        "y": 1408,
        "wires": [
                "579401fa45c450f5"
        "id": "c0e35d1e895caabc",
        "path": "/Settings/SystemSetup/MaxChargeCurrent",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "DVCC Charge current limit (A)",
            "mode": "both"
        "name": "Batt_Max_Charge_Current_A",
        "x": 180,
        "y": 1456,
        "wires": [
                "579401fa45c450f5"
        "id": "26de2e4dc6d12ce9",
        "path": "/Settings/CGwacs/MaxDischargePower",
        "serviceObj": {
        "pathObj": {
            "type": "integer",
            "name": "Max inverter power (W)",
            "mode": "both"
        "initial": "",
        "name": "Max_Inverter_Power_W",
        "x": 160,
        "y": 1504,
        "wires": [
                "579401fa45c450f5"
        "id": "dd894acabb8ba644",
        "type": "victron-input-system",
        "service": "com.victronenergy.system/0",
        "path": "/Control/ActiveSocLimit",
        "serviceObj": {
            "name": "Venus system"
        "pathObj": {
            "type": "integer",
            "name": "ESS active SOC limit (%)"
        "name": "SoC_Min_Venus",
        "x": 144,
        "y": 1632,
        "wires": [
                "579401fa45c450f5"
        "id": "f154e93b358f56a6",
        "path": "/Settings/CGwacs/AcPowerSetPoint",
        "serviceObj": {
        "pathObj": {
            "type": "integer",
            "name": "Grid set-point (W)",
            "mode": "both"
        "name": "Grid_Setpoint_W",
        "x": 144,
        "y": 1680,
        "wires": [
                "579401fa45c450f5"
        "id": "4b33ecd392da4748",
        "path": "/Hub4/DisableCharge",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Disable charge",
            "enum": {
                "0": "No",
                "1": "Yes"
            "mode": "both"
        "initial": "",
        "name": "Charge_Disable",
        "x": 144,
        "y": 1728,
        "wires": [
                "579401fa45c450f5"
        "id": "5728d4a769c1b906",
        "path": "/Mode",
        "serviceObj": {
        "pathObj": {
            "path": "/Mode",
            "type": "enum",
            "name": "Charger on/off",
            "enum": {
                "1": "On",
                "4": "Off"
            "mode": "both"
        "initial": "",
        "name": "Solar_Charger",
        "x": 144,
        "y": 1776,
        "wires": [
                "579401fa45c450f5"
        "id": "4ff0d8160ce166f3",
        "type": "victron-input-relay",
        "path": "/Relay/0/State",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Venus relay 1 state",
            "enum": {
                "0": "Open",
                "1": "Closed"
            "mode": "both",
            "disabled": false
        "initial": "",
        "name": "Relay_1",
        "x": 124,
        "y": 1824,
        "wires": [
                "579401fa45c450f5"
        "id": "0626f121c0a0ef27",
        "path": "/Relay/1/State",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Venus relay 2 state",
            "enum": {
                "0": "Open",
                "1": "Closed"
            "mode": "both"
        "initial": "",
        "name": "Relay_2",
        "x": 124,
        "y": 1872,
        "wires": [
                "579401fa45c450f5"
        "id": "ea17638fe24719f5",
        "path": "/Ac/L1/Current",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "L1 Current (A)"
        "name": "ET340_L1_A",
        "roundValues": "1",
        "x": 122,
        "y": 2016,
        "wires": [
                "579401fa45c450f5"
        "id": "8856e7198bec0eaa",
        "path": "/Ac/L2/Current",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "L2 Current (A)"
        "name": "ET340_L2_A",
        "roundValues": "1",
        "x": 122,
        "y": 2064,
        "wires": [
                "579401fa45c450f5"
        "id": "f151dc78d1c58f25",
        "path": "/Ac/L3/Current",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "L3 Current (A)"
        "name": "ET340_L3_A",
        "roundValues": "1",
        "x": 122,
        "y": 2112,
        "wires": [
                "579401fa45c450f5"
        "id": "eb33bc765db80d10",
        "path": "/VebusChargeState",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Charge state",
            "enum": {
                "0": "Initialising",
                "1": "Bulk",
                "2": "Absorption",
                "3": "Float",
                "4": "Storage",
                "5": "Absorb repeat",
                "6": "Forced absorb",
                "7": "Equalise",
                "8": "Bulk stopped",
                "9": "Unknown"
        "initial": "",
        "name": "Batt_Charge_State",
        "x": 150,
        "y": 1312,
        "wires": [
                "789c561d418cac34"
        "id": "789c561d418cac34",
        "type": "function",
        "name": "To Text: Batt_Charge_State",
        "func": "const ProgName = \"To Text: Charge_State\";\n\ncontext = context || {};\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\nStartTime = Math.floor(Now.getTime() / 1000);\n\nlet NewLine = \"\\n\\r\";\n\nif (context.First_StartTime == null)\n{\n    context.First_StartTime = StartTime;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nif ( !(Get_Functions() ) )\n{   \n    return null;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nfunction Get_Functions() {\n\nlet NewLine = \"\\n\\r\";\nlet FuncCount = 0;\nlet FuncNull = 0;\nlet ErrText = \"\";\nlet Result = true;\n\ntry {\n\n    FuncCount++;\n    GetNowTime = global.get(\"Victron_MESS.Functions.GetNowTime\");\n    if (GetNowTime  == null)\n    {   ErrText += \"Victron_MESS.Functions.GetNowTime\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    FuncCount++;\n    Not = global.get(\"Victron_MESS.Functions.Not\");\n    if (Not  == null)\n    {   ErrText += \"Victron_MESS.Functions.Not\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n    \n    FuncCount++;\n    Round = global.get(\"Victron_MESS.Functions.Round\");\n    if (Round  == null)\n    {   ErrText += \"Victron_MESS.Functions.Round\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    if ( !(Result) )\n    {\n        node.status(\n            {fill:\"black\",\n            shape:\"dot\",\n            text: \"Wait for Get_Functions \"\n                + \"(\" + FuncNull + \"/\" + FuncCount + \")...\"\n            }\n        );\n    }\n    \n    if ( (ErrText > \"\")\n      && ( StartTime > context.First_StartTime + 15 )\n       )\n    {   \n        node.warn(\"Get_Functions:\" + NewLine + ErrText);\n\n        node.status({fill:\"red\", shape:\"dot\",\n                     text: ProgName + \": Error Get_Functions\" \n                     + \"\\n\\r\" + ErrText}\n                   );\n    }\n    \n} // try\ncatch (error)\n{\n    Result = false;\n    \n    node.error(\"Program: \" + ProgName + NewLine\n    + \"Step: Get_Functions\" + NewLine\n    + \"Error: \" + error)\n    \n} // catch\n\nreturn Result;\n    \n} // Get_Functions\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nif ( msg.topic == \"Batt_Charge_State\" )\n{\n    \n    msg.payload = msg.topic + \" \" + msg.payload + \": \" + msg.textvalue;\n/*    \n    if (msg.payload == \"0\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Initializing\"\n    }\n    else if (msg.payload == \"1\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Bulk\"\n    }\n    else if (msg.payload == \"2\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Absorption\"\n    }\n    else if (msg.payload == \"3\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Float\"\n    }\n    else if (msg.payload == \"4\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Storage\"\n    }\n    else if (msg.payload == \"5\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Absorp Repeat\"\n    }\n    else if (msg.payload == \"6\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Forced Absorb\"\n    }\n    else if (msg.payload == \"7\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Equalise\"\n    }\n    else if (msg.payload == \"8\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Bulk STopped\"\n    }\n    else if (msg.payload == \"9\")\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Unknown\"\n    }\n    else\n    {\n        msg.payload = msg.topic + \" \" + msg.payload + \": Unknown\"\n    }\n*/    \n    msg.topic = msg.topic + \"_Text\";\n    \n    node.status( {fill:\"green\", shape:\"dot\",\n                  text: \"@ \" + NowTime + \": \"\n                  + msg.payload }\n               );\n               \n}\nelse \n{\n    msg = null;\n}\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 220,
        "y": 1360,
        "wires": [
                "29ed2bca9bf58176"
        "id": "01c3cbde84bf4335",
        "path": "/Alarms/GridLost",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Grid lost alarm",
            "enum": {
                "0": "Ok",
                "2": "Alarm"
        "initial": "",
        "name": "Grid_Lost_Alarm",
        "x": 136,
        "y": 1920,
        "wires": [
                "579401fa45c450f5"
        "id": "2880c73ffcc9698f",
        "type": "link in",
        "name": "Entry Point Set State",
        "links": [
            "8e38f3b762cd85ab",
            "72d582578c02f0cd",
            "67639ea8dca2895e",
            "1ab0e39b023e2eca",
            "6dad5bca7e6496b7",
            "c424324946c8d0df",
            "32aa3d4a5c947b8e",
            "50fc62634e324a1e",
            "0029ad7a00cf0b7a",
            "4251c2214bfb5fd7",
            "b68016548bd8048a",
            "5d52d345d45747af",
            "c0dd8c60400b4654",
            "29ed2bca9bf58176",
            "31a8580e6fd4dbc3",
            "b5258fd655ebedca"
        "x": 645,
        "y": 1552,
        "wires": [
                "579401fa45c450f5"
        "id": "29ed2bca9bf58176",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 405,
        "y": 1360,
        "wires": []
        "id": "84fb05a6d7387a7d",
        "type": "victron-input-temperature",
        "service": "com.victronenergy.temperature/24",
        "path": "/Temperature",
        "serviceObj": {
            "name": "Multiplus II (1) Temp"
        "pathObj": {
            "type": "float",
            "name": "Temperature (°C)"
        "name": "Multiplus_II_1_Temp",
        "roundValues": "0",
        "x": 142,
        "y": 2160,
        "wires": [
                "579401fa45c450f5"
        "id": "a1b2d22e035c31ce",
        "service": "com.victronenergy.temperature/25",
        "serviceObj": {
            "name": "Multiplus II (2) Temp"
        "pathObj": {
            "type": "float",
        "name": "Multiplus_II_2_Temp",
        "roundValues": "0",
        "x": 142,
        "y": 2208,
        "wires": [
                "579401fa45c450f5"
        "id": "4926c1874c79556a",
        "service": "com.victronenergy.temperature/26",
        "serviceObj": {
            "name": "Multiplus II (3) Temp"
        "pathObj": {
            "type": "float",
        "name": "Multiplus_II_3_Temp",
        "roundValues": "0",
        "x": 142,
        "y": 2256,
        "wires": [
                "579401fa45c450f5"
        "id": "16e540753921a6ed",
        "type": "victron-input-digitalinput",
        "service": "com.victronenergy.digitalinput/1",
        "path": "/Alarm",
        "serviceObj": {
            "name": "Smoke alarm"
        "pathObj": {
            "path": "/Alarm",
            "type": "enum",
            "name": "Digital input alarm",
            "enum": {
                "0": "No alarm",
                "1": "Warning",
                "2": "Alarm"
        "initial": "",
        "name": "Smoke_Alarm",
        "x": 122,
        "y": 1968,
        "wires": [
                "579401fa45c450f5"
        "id": "ad07ebb674632a2a",
        "name": "Show Changed",
        "x": 528,
        "y": 1776,
        "wires": [
        "id": "c5de25a26b0e421a",
        "type": "comment",
        "name": "Green: no change \\n Yellow: changed",
        "info": "",
        "x": 542,
        "y": 1664,
        "wires": []
        "id": "aef8f060832f3d48",
        "type": "victron-input-settings",
        "path": "/Settings/CGwacs/MaxDischargePercentage",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "ESS max discharge current (fractional) (%)",
            "mode": "both"
        "name": "Max_Discharge_Current_Perc",
        "roundValues": "0",
        "x": 184,
        "y": 1552,
        "wires": [
                "579401fa45c450f5"
  • MJ de Bruijn
Flow States - EV / Autolaadstation
Ik gebruik een Victron Auto Laadstation. Het gebruik daarvan heeft invloed op de instellingen van het huis-systeem.
Afbeeldingslocatie: https://tweakers.net/i/4zBF5r2iER8y44YQ3cGVIgj1F3I=/800x/filters:strip_exif()/f/image/if2unDHNcArUtzYy1WcZ54EI.png?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
        "type": "subflow",
        "name": "Show",
        "info": "",
        "category": "",
        "in": [
                "x": 52,
                "y": 48,
                "wires": [
        "out": [
                "x": 308,
                "y": 48,
                "wires": [
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99",
        "status": {
            "x": 308,
            "y": 96,
            "wires": [
                    "port": 1
        "type": "function",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 176,
        "y": 64,
        "wires": [
        "id": "0b1e401c5678eb33",
        "type": "victron-input-evcharger",
        "service": "com.victronenergy.evcharger/40",
        "path": "/Mode",
        "serviceObj": {
            "name": "Auto Laadstation"
        "pathObj": {
            "path": "/Mode",
            "type": "enum",
            "name": "Mode",
            "enum": {
                "0": "Manual",
                "1": "Auto",
                "2": "Schedule"
        "initial": "",
        "name": "EV_Mode",
        "x": 112,
        "y": 2400,
        "wires": [
                "6c2651c0295e7d0b",
                "0029ad7a00cf0b7a"
        "id": "605b02abb2d0e6f1",
        "path": "/MaxCurrent",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Maximum charge current (A)"
        "name": "EV_Max_Charge_Auto_A",
        "roundValues": "no",
        "x": 162,
        "y": 2592,
        "wires": [
                "e05d655aba2681ce",
                "b68016548bd8048a"
        "id": "a80b4d274276dc17",
        "path": "/SetCurrent",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Set charge current (manual mode) (A)"
        "name": "EV_Max_Charge_Manual_A",
        "x": 172,
        "y": 2688,
        "wires": [
                "0a1cb1f18e5a53ef",
                "5d52d345d45747af"
        "id": "2973019f7c9ef5e1",
        "path": "/StartStop",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Start/stop charging (manual mode)",
            "enum": {
                "0": "Stop",
                "1": "Start"
        "initial": "",
        "name": "EV_Start_Stop",
        "x": 132,
        "y": 2496,
        "wires": [
                "56d7e84e89e2ac93",
                "4251c2214bfb5fd7"
        "id": "3c33a3ae0c28f30d",
        "path": "/Status",
        "serviceObj": {
        "pathObj": {
            "path": "/Status",
            "type": "enum",
            "name": "Status",
            "enum": {
                "0": "Disconnected",
                "1": "Connected",
                "2": "Charging",
                "3": "Charged",
                "4": "Waiting for sun",
                "5": "Waiting for RFID",
                "6": "Waiting for start",
                "7": "Low SOC",
                "8": "Ground test error",
                "9": "Welded contacts test error",
                "10": "CP input test error (shorted)",
                "11": "Residual current detected",
                "12": "Undervoltage detected",
                "13": "Overvoltage detected",
                "14": "Overheating detected",
                "15": "Reserved",
                "16": "Reserved",
                "17": "Reserved",
                "18": "Reserved",
                "19": "Reserved",
                "20": "Charging limit",
                "21": "Start charging",
                "22": "Switching to 3 phase",
                "23": "Switching to 1 phase",
                "24": "Stop charging"
        "initial": "",
        "name": "EV_State",
        "x": 112,
        "y": 2304,
        "wires": [
                "440497f22eeb2c4b",
                "50fc62634e324a1e"
        "id": "6c2651c0295e7d0b",
        "type": "function",
        "name": "To Text: EV_Mode",
        "func": "// Function To Text: EV_Mode\n\ncontext = context || {};\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - \n\nfunction Code_To_Text (p_code)\n{\n    if (Number(p_code) == 0) \n    {\n        Result = p_code + \": Manual\"\n    }\n    else if (Number(p_code) == 1) \n    {\n        Result = p_code + \": Auto\"\n    }\n    else if (Number(p_code) == 2) \n    {\n        Result = p_code + \": Scheduled\"\n    }\n    else\n    {\n        Result = p_code + \": Unknown\"\n    }\n    \n    return Result;\n\n} // Code_To_Text\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - \n\nif ( msg.topic == \"EV_Mode\" )\n{\n    msg.payload = Code_To_Text(msg.payload);\n\n    if (context.LastPayload != msg.payload)\n    {\n        if (context.LastPayload != null)\n        {\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_EV_Mode\"); // remove\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_EV_Mode\",\n                NowTime + \"; \" +  context.LastPayload + \" --> \" + msg.payload);\n        }\n\n        context.LastPayload = msg.payload\n\n        node.status( {fill:\"yellow\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    }\n    else\n    {\n        node.status( {fill:\"green\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    \n        msg = null;\n    }\n               \n}\nelse {\n    msg = null;\n}\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 342,
        "y": 2448,
        "wires": [
                "e9f4035e7b4b5c7c"
        "id": "e05d655aba2681ce",
        "type": "function",
        "name": "To Text: EV_Max_Charge_Auto_A",
        "func": "// Function To Text: EV_Max_Charge_Auto_A\n\ncontext = context || {};\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\nif ( msg.topic == \"EV_Max_Charge_Auto_A\" )\n{\n    if (context.LastPayload != msg.payload)\n    {\n        if (context.LastPayload != null)\n        {\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_Max_Charge_Auto\"); // remove\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_Max_Charge_Auto\",\n                NowTime + \"; \" +  context.LastPayload + \" --> \" + msg.payload);\n        }\n\n        context.LastPayload = msg.payload\n        \n        msg.payload = \"Max Charge Auto: \" + msg.payload;\n\n        node.status( {fill:\"yellow\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    }\n    else\n    {\n        node.status( {fill:\"green\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    \n        msg = null;\n    }\n}\nelse {\n    msg = null;\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 292,
        "y": 2640,
        "wires": [
                "e9f4035e7b4b5c7c"
        "id": "0a1cb1f18e5a53ef",
        "type": "function",
        "name": "To Text: EV_Max_Charge_Manual_A",
        "func": "// Function To Text: EV_Max_Charge_Manual_A\n\ncontext = context || {};\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\nif ( msg.topic == \"EV_Max_Charge_Manual_A\" )\n{\n    if (context.LastPayload != msg.payload)\n    {\n        if (context.LastPayload != null)\n        {\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_Max_Charge_Manual\"); // remove\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_Max_Charge_Manual\",\n                NowTime + \"; \" +  context.LastPayload + \" --> \" + msg.payload);\n        }\n\n        context.LastPayload = msg.payload\n\n        msg.payload = \"Max Charge Manual: \" + msg.payload;\n\n        node.status( {fill:\"yellow\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    }\n    else\n    {\n        node.status( {fill:\"green\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    \n        msg = null;\n    }\n\n}\nelse {\n    msg = null;\n}\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 282,
        "y": 2736,
        "wires": [
                "e9f4035e7b4b5c7c"
        "id": "56d7e84e89e2ac93",
        "type": "function",
        "name": "To Text: EV_Start_Stop",
        "func": "// Function To Text: EV_Start_Stop\n\ncontext = context || {};\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\nif ( msg.topic == \"EV_Start_Stop\" )\n{\n    if (context.LastPayload != msg.payload)\n    {\n        if (context.LastPayload != null)\n        {\n            if (Number(msg.payload) == 0)\n            {\n                global.set( \"Victron_MESS.LastRun.EV_Charger.State_Stop\"); // remove\n                global.set( \"Victron_MESS.LastRun.EV_Charger.State_Stop\",\n                    NowTime + \"; \" +  context.LastPayload + \" --> \" + msg.payload);\n            }\n            else\n            {\n                global.set( \"Victron_MESS.LastRun.EV_Charger.State_Start\"); // remove\n                global.set( \"Victron_MESS.LastRun.EV_Charger.State_Start\",\n                    NowTime + \"; \" +  context.LastPayload + \" --> \" + msg.payload);\n                \n            }\n        }\n        \n        context.LastPayload = msg.payload\n    \n        if (msg.payload == \"0\") \n        {\n            msg.payload = msg.topic + \" \" + msg.payload + \": Stop\"\n        }\n        else if (msg.payload == \"1\") \n        {\n            msg.payload = msg.topic + \" \" + msg.payload + \": Start\"\n        }\n        else\n        {\n            msg.payload = \"EV_Start_Stop \" + msg.payload + \": Unknown\"\n        }\n        \n        node.status( {fill:\"yellow\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n\n    }\n    else\n    {\n        node.status( {fill:\"green\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    \n        msg = null;\n    }\n               \n}\nelse {\n    msg = null;\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 322,
        "y": 2544,
        "wires": [
                "e9f4035e7b4b5c7c"
        "id": "440497f22eeb2c4b",
        "type": "function",
        "name": "To Text: EV_State",
        "func": "// Function To Text: EV_State\n\ncontext = context || {};\n\nconst Now = new Date();\nlet NowTime = Now.getFullYear() + \"-\"\n            + (\"0\" + (Now.getMonth() + 1)).slice(-2) + \"-\"\n            + (\"0\" + Now.getDate()).slice(-2) + \" \"\n            + (\"0\" + Now.getHours()).slice(-2) + \":\"\n            + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n            + (\"0\" + Now.getSeconds()).slice(-2) ;\n\n\nfunction Code_To_Text (p_code)\n{\n    let Result = \"\";\n    \n    if (p_code == \"0\")\n\t{\n        Result = p_code + \": Disconnected\"\n\t}\n    else if (p_code == \"1\")\n\t{\n        Result = p_code + \": Connected\"\n\t}\n    else if (p_code == \"2\")\n\t{\n        Result = p_code + \": Charging\"\n\t}\n    else if (p_code == \"3\")\n\t{\n        Result = p_code + \": Charged\"\n\t}\n    else if (p_code == \"4\")\n\t{\n        Result = p_code + \": Waiting for Sun\"\n\t}\n    else if (p_code == \"5\")\n\t{\n        Result = p_code + \": Waiting for RFID\"\n\t}\n    else if (p_code == \"6\")\n\t{\n        Result = p_code + \": Waiting for Start\"\n\t}\n    else if (p_code == \"7\")\n\t{\n        Result = p_code + \": Low SoC\"\n\t}\n    else if (p_code == \"8\")\n\t{\n        Result = p_code + \": Ground Fault\"\n\t}\n    else if (p_code == \"9\")\n\t{\n        Result = p_code + \": Welded Contacts\"\n\t}\n    else if (p_code == \"10\")\n\t{\n        Result = p_code + \": CP input Shorted\"\n\t}\n    else if (p_code == \"11\")\n\t{\n        Result = p_code + \": Residual Current Detected\"\n\t}\n    else if (p_code == \"12\")\n\t{\n        Result = p_code + \": Under Voltage Detected\"\n\t}\n    else if (p_code == \"13\")\n\t{\n        Result = p_code + \": Overvoltage Detected\"\n\t}\n    else if (p_code == \"14\")\n\t{\n        Result = p_code + \": Overheating Detected\"\n\t}\n    else if (p_code == \"21\")\n\t{\n        Result = p_code + \": Start Charge\"\n\t}\n    else if (p_code == \"22\")\n\t{\n        Result = p_code + \": Switch to 3 Phase\"\n\t}\n    else if (p_code == \"23\")\n\t{\n        Result = p_code + \": Switch to 1 Phase\"\n\t}\n    else\n    {\n        Result = p_code + \": Unknown\"\n    }\n    \n    return Result\n    \n} // Code_To_Text\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nif ( msg.topic == \"EV_State\" )\n{\n    msg.topic = \"EV_State_Text\";\n    \n    msg.payload = Code_To_Text(msg.payload);\n    \n    if (context.LastPayload != msg.payload)\n    {\n        if (context.LastPayload != null)\n        {\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_EV_State\"); // remove\n            global.set( \"Victron_MESS.LastRun.EV_Charger.State_EV_State\",\n                NowTime + \"; \" +  context.LastPayload + \" --> \" + msg.payload);\n        }\n\n        node.status( {fill:\"yellow\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n                   \n        context.LastPayload = msg.payload\n    }\n    else\n    {\n        node.status( {fill:\"green\", shape:\"dot\",\n                      text: \"@ \" + NowTime + \": \"\n                      + msg.payload }\n                   );\n    \n        msg = null;\n    }\n               \n}\nelse {\n    msg = null;\n}\n\nreturn msg;\n\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 342,
        "y": 2352,
        "wires": [
                "50fc62634e324a1e",
                "e9f4035e7b4b5c7c"
        "id": "445dc615fa81dfc9",
        "path": "/Current",
        "serviceObj": {
        "pathObj": {
            "path": "/Current",
            "type": "float",
            "name": "Charge current (A)"
        "name": "EV_Charge_Current_A",
        "roundValues": "0",
        "x": 152,
        "y": 2896,
        "wires": [
                "c0dd8c60400b4654"
        "id": "50fc62634e324a1e",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 497,
        "y": 2304,
        "wires": []
        "id": "0029ad7a00cf0b7a",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 349,
        "y": 2400,
        "wires": []
        "id": "4251c2214bfb5fd7",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 349,
        "y": 2496,
        "wires": []
        "id": "b68016548bd8048a",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 349,
        "y": 2592,
        "wires": []
        "id": "5d52d345d45747af",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 349,
        "y": 2688,
        "wires": []
        "id": "c0dd8c60400b4654",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 413,
        "y": 2896,
        "wires": []
        "id": "e9f4035e7b4b5c7c",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "type",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "domain",
                "pt": "msg",
                "to": "input_text",
                "tot": "str"
                "t": "set",
                "p": "service",
                "pt": "msg",
                "to": "set_value",
                "tot": "str"
                "t": "set",
                "p": "entity_id",
                "pt": "msg",
                "to": "input_text.helper_auto_laadstation_log",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 578,
        "y": 2736,
        "wires": [
                "584d22203201a042"
        "id": "ce5d8709278fd758",
        "type": "link out",
        "mode": "link",
        "links": [
            "30a7afbf79ee7ae6"
        "x": 539,
        "y": 2800,
        "wires": []
        "id": "584d22203201a042",
        "type": "delay",
        "name": "",
        "pauseType": "rate",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 294,
        "y": 2800,
        "wires": [
                "133911b52fe5091d"
        "id": "133911b52fe5091d",
        "name": "",
        "x": 446,
        "y": 2800,
        "wires": [
                "ce5d8709278fd758"
  • MJ de Bruijn
Flow States - SolarEdge
Dan is er nog mijn zonne-energie installatie van SolarEdge.
Afbeeldingslocatie: https://tweakers.net/i/XaVmMFvOdnIbrFFMa_AkEBx0zdM=/800x/filters:strip_exif()/f/image/NMfr0k7CbBbPqCeHDtKrOc4H.png?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
        "type": "subflow",
        "name": "Show",
        "info": "",
        "category": "",
        "in": [
                "x": 52,
                "y": 48,
                "wires": [
        "out": [
                "x": 308,
                "y": 48,
                "wires": [
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99",
        "status": {
            "x": 308,
            "y": 96,
            "wires": [
                    "port": 1
        "type": "function",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 176,
        "y": 64,
        "wires": [
        "id": "321d9521a4b6084d",
        "path": "/Ac/Energy/Forward",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Total energy (kWh)"
        "name": "SolarEdge (ET340) Energy (kWh)",
        "roundValues": "1",
        "x": 186,
        "y": 3088,
        "wires": [
                "3bc4ac71a41be621"
        "id": "d604ef190a895338",
        "type": "debug",
        "name": "SolarEdge_Reading_kWh",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 514,
        "y": 3152,
        "wires": []
        "id": "3bc4ac71a41be621",
        "type": "function",
        "name": "Monitor SolarEdge",
        "func": "const ProgName = \"Monitor SolarEdge\";\n\ncontext = context || {};\n\nlet Now = new Date();\nStartTime = Math.floor(Now.getTime() / 1000);\n\nlet NewLine = \"\\n\\r\";\n\nif (context.First_StartTime == null)\n{\n    context.First_StartTime = StartTime;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nif ( !(Get_Functions() ) )\n{   \n    return null;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nfunction Get_Functions() {\n\nlet NewLine = \"\\n\\r\";\nlet FuncCount = 0;\nlet FuncNull = 0;\nlet ErrText = \"\";\nlet Result = true;\n\ntry {\n\n    FuncCount++;\n    GetNowTime = global.get(\"Victron_MESS.Functions.GetNowTime\");\n    if (GetNowTime  == null)\n    {   ErrText += \"Victron_MESS.Functions.GetNowTime\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    FuncCount++;\n    Not = global.get(\"Victron_MESS.Functions.Not\");\n    if (Not  == null)\n    {   ErrText += \"Victron_MESS.Functions.Not\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n    \n    FuncCount++;\n    Round = global.get(\"Victron_MESS.Functions.Round\");\n    if (Round  == null)\n    {   ErrText += \"Victron_MESS.Functions.Round\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    if ( !(Result) )\n    {\n        node.status(\n            {fill:\"black\",\n            shape:\"dot\",\n            text: \"Wait for Get_Functions \"\n                + \"(\" + FuncNull + \"/\" + FuncCount + \")...\"\n            }\n        );\n    }\n    \n    if (ErrText > \"\")\n    {   \n        if (context.Next_Error_Time == null)\n        {\n            context.Next_Error_Time = StartTime;\n        }\n        if (StartTime >= context.Next_Error_Time)\n        {\n            node.warn(\"Error Get_Functions:\" + NewLine + ErrText);\n            context.Next_Error_Time = StartTime + 15;\n        }\n\n        node.status({fill:\"red\", shape:\"dot\",\n                     text: ProgName + \": Error Get_Functions\" }\n                   );\n    }\n    \n} // try\ncatch (error)\n{\n    Result = false;\n    \n    node.error(\"Program: \" + ProgName + NewLine\n    + \"Step: Get_Functions\" + NewLine\n    + \"Error: \" + error)\n    \n} // catch\n\nreturn Result;\n    \n} // Get_Functions\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nlet NowTime = GetNowTime();\nlet NowHour = GetNowTime(\"NowHour\");\nlet NowQuarterHour = GetNowTime(\"NowQuarterHour\");\n\nvar SolarEdge_Energy = 0;\n\nif (context.LastQuarterHour == null) {\n    context.LastQuarterHour = -1;\n}\nif (context.LastReading == null) {\n    context.LastReading = -1;\n}\nif (context.SolarEdge_Reading_kWh == null) {\n    context.SolarEdge_Reading_kWh = global.get(\"Victron_MESS.SolarEdge.Reading\");\n    context.LastQuarterHour = -1;\n    context.LastReading = -1;\n}\nif (context.SolarEdge_Reading_kWh == null) {\n    // e.g. after reboot\n    context.SolarEdge_Reading_kWh = new Array(96); // initialize\n    context.SolarEdge_Reading_kWh.fill(0);\n}\n\n\nswitch (msg.topic) {\n    \n  case \"SolarEdge (ET340) Energy (kWh)\":\n    SolarEdge_Energy = msg.payload;  \n    msg = null;\n    break;\n\n  default: \n    node.warn(\"Unknown Topic: \" + msg.topic \n              + \" Payload: \" + msg.payload);\n    msg = null;\n    break;\n\n} // switch for input all variables\n\nlet newMsg = null;\n\nif (SolarEdge_Energy != null) // a value was received\n{\n    if ( (NowQuarterHour != context.LastQuarterHour)\n      || (context.SolarEdge_Reading_kWh == null) )\n    { // a new quarter has started\n    \n        // node.warn(\"a new quarter has started\");\n    \n        if (NowQuarterHour == 0) \n        { //send old values\n            newMsg = { topic: \"Victron_MESS.SolarEdge.Reading\",\n                       payload: context.SolarEdge_Reading_kWh };\n        } // if new day\n        \n        if ( (NowQuarterHour == 0) || (context.LastQuarterHour == 95) )\n        { // New day, clear history\n            context.SolarEdge_Reading_kWh = new Array(96); // initialize\n            context.SolarEdge_Reading_kWh.fill(0);\n        } // if new day\n        \n        // make sure current value is processed\n        context.LastReading = -1; \n        context.LastQuarterHour = NowQuarterHour;\n    }\n\n    if (SolarEdge_Energy != context.LastReading)\n    { // the value has changed\n\n        context.SolarEdge_Reading_kWh[NowQuarterHour] = SolarEdge_Energy;\n        \n        global.set(\"Victron_MESS.SolarEdge.Reading\", context.SolarEdge_Reading_kWh);\n    \n        global.set(\"Victron_MESS.LastRun.SolarEdge.Reading\"); // remove\n        global.set(\"Victron_MESS.LastRun.SolarEdge.Reading\", NowTime);\n    \n        node.status( \n          { fill:\"green\", \n            shape:\"dot\",\n            text: \"@ \" + NowTime + \" SolarEdge Reading: \"\n                + context.SolarEdge_Reading_kWh[NowQuarterHour] + \" kWh\" } \n        );\n\n        context.LastReading = SolarEdge_Energy;\n    }\n    \n} // if there was a value received\n\nreturn newMsg;\n",
        "outputs": 1,
        "timeout": "4",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 486,
        "y": 3088,
        "wires": [
                "d604ef190a895338"
        "id": "cfd0a6d8af878a24",
        "z": "873bf4cb2fbee905",
        "path": "/Ac/Power",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Total Power (W)"
        "name": "",
        "onlyChanges": false,
        "roundValues": "0",
        "x": 202,
        "y": 2960,
        "wires": [
                "414db56412cf3068"
        "id": "e8a47e95d40e124a",
        "type": "change",
        "name": "x -> Off",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "SolarEdge_Production",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "Off",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 644,
        "y": 2944,
        "wires": [
                "32aa3d4a5c947b8e"
        "id": "414db56412cf3068",
        "type": "switch",
        "name": "<= 0 or > 0",
        "propertyType": "msg",
        "rules": [
                "t": "lte",
                "v": "0",
                "vt": "num"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 466,
        "y": 2960,
        "wires": [
                "e8a47e95d40e124a"
                "a0e077644d6d7185"
        "id": "a0e077644d6d7185",
        "type": "change",
        "name": "x -> On",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "On",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 644,
        "y": 2976,
        "wires": [
                "32aa3d4a5c947b8e"
        "id": "32aa3d4a5c947b8e",
        "type": "link out",
        "mode": "link",
        "links": [
            "2880c73ffcc9698f"
        "x": 763,
        "y": 2960,
        "wires": []
        "id": "9eb212513d62fe57",
        "path": "/ErrorCode",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "name": "Error",
            "enum": {
                "0": "No Error"
        "name": "",
        "roundValues": "0",
        "x": 162,
        "y": 3024,
        "wires": [
                "e7399cf50aa5d7a1"
        "id": "e7399cf50aa5d7a1",
        "name": "",
        "x": 402,
        "y": 3024,
        "wires": [
  • MJ de Bruijn
  • Registratie: November 2016
  • Laatst online: 08:59
Flow States - Monitoring Consumptie
Ik probeer inzicht te krijgen in mijn actuele consumptie per uur (per kwartier is niet nauwkeurig te meten). Het huisverbruik wordt geregistreerd en verder na-berekend.
Afbeeldingslocatie: https://tweakers.net/i/acw40OukSUxJT-sdreFfsYWYuf0=/800x/filters:strip_exif()/f/image/p4gxIQYz73ow65HbsrdHswDq.png?f=fotoalbum_large
Het resultaat wordt één maal per dag per e-mail aan mijzelf gestuurd zodat ik dit in een spreadsheet kan verwerken.
Afbeeldingslocatie: https://tweakers.net/i/b3OFKORRxSVVyrgP3QyV7DKmyiM=/800x/filters:strip_exif()/f/image/gjOXLXxYvNbsKK6kf1QvnYZZ.png?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
        "id": "76b3d3c432059f79",
        "type": "victron-input-vebus",
        "service": "com.victronenergy.vebus/276",
        "path": "/Energy/AcIn1ToAcOut",
        "serviceObj": {
            "name": "MultiPlus-II 48/3000/35-32"
        "pathObj": {
            "type": "float",
            "name": "Energy ACIn1 to AcOut (kWh)"
        "name": "AcIn1_To_AcOut",
        "roundValues": "3",
        "x": 136,
        "y": 3296,
        "wires": [
                "685dbdcbb65adb98"
        "id": "526006de042d3c61",
        "path": "/Energy/InverterToAcOut",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Inverter To AcOut (kWh)"
        "name": "Inv_To_AcOut",
        "roundValues": "3",
        "x": 126,
        "y": 3392,
        "wires": [
                "685dbdcbb65adb98"
        "id": "07446ba43def2347",
        "path": "/Energy/OutToInverter",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "AcOut to Inverter (kWh)"
        "name": "AcOut_To_Inv",
        "roundValues": "3",
        "x": 126,
        "y": 3440,
        "wires": [
                "685dbdcbb65adb98"
        "id": "51f962c6b55724d1",
        "path": "/Energy/AcOutToAcIn1",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Energy AcOut to AcIn1 (kWh)"
        "name": "AcOut_To_AcIn1",
        "roundValues": "3",
        "x": 136,
        "y": 3344,
        "wires": [
                "685dbdcbb65adb98"
        "id": "853b26802516bd20",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Total Forward Energy (bought) (kWh)"
        "name": "Grid_In",
        "roundValues": "3",
        "x": 106,
        "y": 3584,
        "wires": [
                "685dbdcbb65adb98"
        "id": "eb788518dffb1489",
        "path": "/Ac/Energy/Reverse",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Total Reverse Energy (sold) (kWh)"
        "name": "Grid_Out",
        "roundValues": "3",
        "x": 116,
        "y": 3632,
        "wires": [
                "685dbdcbb65adb98"
        "id": "9c3105c15958fdfe",
        "path": "/Energy/AcIn1ToInverter",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Energy AcIn1 to Inverter (kWh)"
        "name": "AcIn1_To_Inv",
        "roundValues": "3",
        "x": 126,
        "y": 3488,
        "wires": [
                "685dbdcbb65adb98"
        "id": "fa57ea8d3a0c2bce",
        "path": "/Energy/InverterToAcIn1",
        "serviceObj": {
        "pathObj": {
            "type": "float",
            "name": "Energy Inverter to AcIn1 (kWh)"
        "name": "Inv_To_AcIn1",
        "roundValues": "3",
        "x": 126,
        "y": 3536,
        "wires": [
                "685dbdcbb65adb98"
        "id": "685dbdcbb65adb98",
        "type": "function",
        "name": "Monitor Consumption",
        "func": "const ProgName = \"Monitor Consumption\";\n\ncontext = context || {};\n\nlet Now = new Date();\nStartTime = Math.floor(Now.getTime() / 1000);\n\nlet NewLine = \"\\n\\r\";\n\nif (context.First_StartTime == null)\n{\n    context.First_StartTime = StartTime;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nif ( !(Get_Functions() ) )\n{   \n    return null;\n}\n\n// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -\n\nfunction Get_Functions() {\n\nlet NewLine = \"\\n\\r\";\nlet FuncCount = 0;\nlet FuncNull = 0;\nlet ErrText = \"\";\nlet Result = true;\n\ntry {\n\n    FuncCount++;\n    GetNowTime = global.get(\"Victron_MESS.Functions.GetNowTime\");\n    if (GetNowTime  == null)\n    {   ErrText += \"Victron_MESS.Functions.GetNowTime\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    FuncCount++;\n    GetYesterday = global.get(\"Victron_MESS.Functions.GetYesterday\");\n    if (GetYesterday  == null)\n    {   ErrText += \"Victron_MESS.Functions.GetYesterday\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    FuncCount++;\n    Not = global.get(\"Victron_MESS.Functions.Not\");\n    if (Not  == null)\n    {   ErrText += \"Victron_MESS.Functions.Not\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n    \n    FuncCount++;\n    Round = global.get(\"Victron_MESS.Functions.Round\");\n    if (Round  == null)\n    {   ErrText += \"Victron_MESS.Functions.Round\" + NewLine;\n        FuncNull += 1;\n        Result = false;\n    }\n\n    if ( !(Result) )\n    {\n        node.status(\n            {fill:\"black\",\n            shape:\"dot\",\n            text: \"Wait for Get_Functions \"\n                + \"(\" + FuncNull + \"/\" + FuncCount + \")...\"\n            }\n        );\n    }\n    \n    if (ErrText > \"\")\n    {   \n        if (context.Next_Error_Time == null)\n        {\n            context.Next_Error_Time = StartTime;\n        }\n        if (StartTime >= context.Next_Error_Time)\n        {\n            node.warn(\"Error Get_Functions:\" + NewLine + ErrText);\n            context.Next_Error_Time = StartTime + 15;\n        }\n\n        node.status({fill:\"red\", shape:\"dot\",\n                     text: ProgName + \": Error Get_Functions\" }\n                   );\n    }\n    \n} // try\ncatch (error)\n{\n    Result = false;\n    \n    node.error(\"Program: \" + ProgName + NewLine\n    + \"Step: Get_Functions\" + NewLine\n    + \"Error: \" + error)\n    \n} // catch\n\nreturn Result;\n    \n} // Get_Functions\n\n// - - - - - - - - - - - - - - - - - - - - - - -\n\nfunction MakeEmail(p_Name)\n{\n\n    // node.warn(\"MakeEmail Started\");\n    DebugStep = \"MakeEmail Started\";\n    \n    let Export = \"\";\n    let NewLine = \"\\n\\r\";\n    let Delimiter = \"; \";\n    \n\n    DebugStep = \"MakeEmail; Fill Sensorlist\";\n    \n    for (let t=0 ; t < 3; t++) // three title lines\n    {\n        let Split_Col1 = [\"\", \"\", \"uur\"];\n        Export += Split_Col1[t];\n\n        for (let i = 0; i < SensorList.length; i++)\n        {\n            let Split_Title = (SensorList[i]+ \" _ _\").split(\"_\");\n            let Split_Delta = [\"\", \"dit\", \"uur\"];\n            Export += Delimiter + Split_Title[t]\n                    + Delimiter + Split_Delta[t];\n        }\n\n        let Consump_Critical_Title = [ \"\", \"Consump\", \"Critical\"];\n        let Consump_Non_Crit_Title = [ \"\", \"Consump\", \"Non.Crit\"];\n        let Consump_Total_Title = [ \"\", \"Consump\", \"Total\"];\n\n        Export += Delimiter + Consump_Critical_Title[t];\n        Export += Delimiter + Consump_Non_Crit_Title[t];\n        Export += Delimiter + Consump_Total_Title[t];\n        \n        Export += EndLine;\n    }\n    Export += EndLine;\n\n    DebugStep = \"MakeEmail; Fill Table\";\n    \n    for (let u = 0; u<25; u++)\n    {   // now individual rows\n        Export += u;\n\n        for (let i = 0; i < SensorList.length; i++)\n        {\n            Export += Delimiter \n                + context.ReadingTable[i][u].toLocaleString( \"nl-NL\", {useGrouping: false} );\n\n            if ( (u <= 23)\n              && (context.ReadingTable[i][u+1] != 0) )\n            {\n                let Delta_This_Hour = \n                    context.ReadingTable[i][u+1] - context.ReadingTable[i][u];\n                Export += Delimiter \n                    + Delta_This_Hour.toLocaleString( \"nl-NL\", {useGrouping: false} );\n            }\n            else\n            {\n                Export += Delimiter + \"0\";\n            }\n        }\n\n        let Consump_Critical = 0;\n        let Consump_Non_Crit = 0;\n\n        if ( (u <= 23)\n          && (context.ReadingTable[0][u+1] != 0) )\n        {\n            Consump_Critical = \n                context.ReadingTable[0][u+1] - context.ReadingTable[0][u] // AcIn1_To_AcOut\n                + context.ReadingTable[2][u+1] - context.ReadingTable[2][u] // Inv_To_AcOut\n                + context.ReadingTable[8][u+1] - context.ReadingTable[8][u] // SolarEdge\n                - context.ReadingTable[1][u+1] + context.ReadingTable[1][u] // AcOut_To_AcIn1\n                - context.ReadingTable[3][u+1] + context.ReadingTable[3][u]; // AcOut_To_Inv\n                \n            Consump_Non_Crit = \n                context.ReadingTable[6][u+1] - context.ReadingTable[6][u] // Grid_In\n                - context.ReadingTable[7][u+1] + context.ReadingTable[7][u] // Grid_Out\n                - context.ReadingTable[0][u+1] + context.ReadingTable[0][u] // AcIn1_To_AcOut\n                - context.ReadingTable[4][u+1] + context.ReadingTable[4][u] // AcIn1_To_Inv\n                + context.ReadingTable[3][u+1] - context.ReadingTable[3][u] // AcOut_To_Inv\n                + context.ReadingTable[5][u+1] - context.ReadingTable[5][u]; // Inv_To_AcIn1\n        }    \n        \n        let Consump_Total = Consump_Critical + Consump_Non_Crit;\n        \n        Export += Delimiter \n            + Consump_Critical.toLocaleString( \"nl-NL\", {useGrouping: false} );\n        \n        Export += Delimiter \n            + Consump_Non_Crit.toLocaleString( \"nl-NL\", {useGrouping: false} );\n\n        Export += Delimiter \n            + Consump_Total.toLocaleString( \"nl-NL\", {useGrouping: false} );\n\n        Export += EndLine;\n    }\n    \n    DebugStep = \"MakeEmail; Make msgEmail\";\n    \n    msgEmail = { \n        topic: \"All Reading \" + p_Name,\n        payload: Export};\n    \n} // MakeEmail\n\n// - - - - - - - - - - - - - - - - - - - - - - -\n\ntry\n{\n\n    var DebugStep = \"Start\";\n\n    var NowTime = GetNowTime();\n    var NowHour = GetNowTime(\"NowHour\");\n    var Yesterday = GetYesterday(\"YYYYMMDD\");\n    Yesterday = Yesterday.replaceAll(\"-\", \"\").substring(4);\n\n    var EndLine = \"\\n\";\n    var msgEmail = null;\n    var Explain = \"\";\n    var Make_Snapshot = false;\n    var Make_Email_Now = false;\n\n// - - - - - - - - - - - - - - - - - - - - - - -\n\n    DebugStep = \"Clear Context\";\n\n    if (msg.clearcontext) \n    {\n        context = null;\n    \n        node.status({fill:\"blue\",\n            shape:\"dot\",\n            text: \"@ \" + NowTime + \" - Clear Context\"}\n         );\n    \n        return null;\n    }\n\n    DebugStep = \"Prepare Lists\";\n    \n    var SensorList = [\"AcIn1_To_AcOut\",\n            \"AcOut_To_AcIn1\",\n            \"Inv_To_AcOut\",\n            \"AcOut_To_Inv\",\n            \"AcIn1_To_Inv\",\n            \"Inv_To_AcIn1\",\n            \"Grid_In\",\n            \"Grid_Out\",\n            \"SolarEdge\"\n        ]\n    \n    if (context.ReadingTable == null) {\n        context.ReadingTable = [];\n    }\n    \n    if (context.LastReadingValue == undefined) {\n        context.LastReadingValue = new Array(SensorList.length);\n        context.LastReadingValue.fill(0);\n    }\n\n    DebugStep = \"Input Msg\";\n    \n    if (msg.topic == \"Snapshot\")\n    {\n        Make_Snapshot = true;\n    }\n    else if (msg.topic == \"EmailNow\")\n    {\n        Make_Email_Now = true;\n    }\n    else if (SensorList.indexOf(msg.topic) >= 0)\n    {\n        context.LastReadingValue[SensorList.indexOf(msg.topic)] = msg.payload;\n    }\n    else\n    {\n        node.warn(\"Unknown topic: \" + msg.topic);\n    }\n\n    DebugStep = \"Prepare Reading Table\";\n    \n    for (let i = 0; i < SensorList.length; i++)\n    {\n        if (context.ReadingTable[i] == null) {\n            // node.warn(\"Read from Global: \" + SensorList[i]+ \"...\")\n            context.ReadingTable[i] = \n                global.get(\"Victron_MESS.Reading.Today.\" + SensorList[i]);\n            if (context.ReadingTable[i] == null) \n            {   // e.g. after reboot\n                // node.warn(\"Initialise: \" + SensorList[i]+ \"...\")\n                context.ReadingTable[i] = new Array(25); // initialize\n                for (let j = 0; j<25; j++)\n                {\n                    context.ReadingTable[i][j] = 0;\n                }\n            }\n        }\n    }\n\n    if (Make_Email_Now == true)\n    {\n        \n        DebugStep = \"Monitor Consumption; Make_Email_Now == true\";\n        \n        MakeEmail(\"On_Demand\");\n\n        node.status({fill:\"yellow\",\n            shape:\"dot\",\n            text: \"@ \" + NowTime + \" - Email Now\"}\n         );\n    \n    }\n\n    else if (Make_Snapshot == true)\n    {\n        DebugStep = \"Snapshot is true\";\n\n        if (NowHour == 0)\n        {   \n            DebugStep = \"Finish previous day\";\n            \n            for (let i = 0; i < SensorList.length; i++)\n            {\n                context.ReadingTable[i][24] = context.LastReadingValue[i];\n                \n                let TempTable = [];\n                for (let j = 0; j < 25; j++)\n                {\n                    TempTable[j] = context.ReadingTable[i][j];\n                }\n                global.set(\"Victron_MESS.Reading.\" + Yesterday + \".\"\n                    + SensorList[i] ); //  delete\n                global.set(\"Victron_MESS.Reading.\" + Yesterday + \".\"\n                    + SensorList[i], TempTable );\n            }\n            \n            DebugStep = \"MakeEmail\";\n            \n            MakeEmail(Yesterday);\n\n            // start new day\n            for (let i = 0; i < SensorList.length; i++)\n            {\n                for (let j = 0; j<25; j++)\n                {\n                    context.ReadingTable[i][j] = 0;\n                }\n            } // all tables\n            \n            \n        } // if NowHour = 0\n\n        DebugStep = \"Fill current day\";\n        \n        for (let i = 0; i < SensorList.length; i++)\n        {\n            context.ReadingTable[i][NowHour] = context.LastReadingValue[i];\n            \n            global.set(\"Victron_MESS.Reading.Today.\" + SensorList[i],\n                context.ReadingTable[i]);\n                \n            global.set(\"Victron_MESS.LastRun.Reading\"); // remove\n            global.set(\"Victron_MESS.LastRun.Reading\", NowTime);\n            \n        } // write current states\n\n        DebugStep = \"Status\";\n    \n        node.status( \n            { fill:\"green\", \n                shape:\"dot\",\n                text: \"@ \" + NowTime} \n            )\n    \n    } // if snapshot\n\n} // try\ncatch (error)\n{\n    node.warn(\"Error in Monitor Consumption: \" + NewLine\n        + \"  Step = \" + DebugStep + NewLine\n        + \"  Error \" + error)\n    \n}\n\nreturn msgEmail;\n",
        "outputs": 1,
        "timeout": "4",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 468,
        "y": 3584,
        "wires": [
                "7f8af95245cd6c5f"
        "id": "7cf9c6eb4e888055",
        "type": "victron-input-pvinverter",
        "service": "com.victronenergy.pvinverter/31",
        "serviceObj": {
            "name": "SolarEdge (ET340)"
        "pathObj": {
            "type": "float",
        "name": "SolarEdge",
        "roundValues": "3",
        "x": 116,
        "y": 3680,
        "wires": [
                "685dbdcbb65adb98"
        "id": "75a1fdade29288f0",
        "type": "cronplus",
        "name": "Every Hour",
        "outputField": "payload",
        "timeZone": "",
        "storeName": "",
        "commandResponseMsgOutput": "output1",
        "defaultLocation": "",
        "defaultLocationType": "default",
        "outputs": 1,
        "options": [
                "name": "schedule1",
                "topic": "Snapshot",
                "payloadType": "default",
                "payload": "",
                "expressionType": "cron",
                "expression": "0 0 * * * * *",
                "location": "",
                "offset": "0",
                "solarType": "all",
                "solarEvents": "sunrise,sunset"
        "x": 126,
        "y": 3248,
        "wires": [
                "685dbdcbb65adb98"
        "id": "6ce833fc22cf97c9",
        "type": "change",
        "name": "",
        "rules": [
                "t": "delete",
                "p": "Victron_MESS.Reading.Today",
                "pt": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 534,
        "y": 3344,
        "wires": [
        "id": "3453b9a19d9232d2",
        "type": "inject",
        "name": "On Demand",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Delete Reading Today",
        "payload": "( $moment().format(\"YYYY-MM-DD HH:mm:ss\") )",
        "payloadType": "jsonata",
        "x": 438,
        "y": 3296,
        "wires": [
                "6ce833fc22cf97c9"
        "id": "7f8af95245cd6c5f",
        "type": "link out",
        "name": "Link Out Readings to Email",
        "mode": "link",
        "links": [
            "937f02372220657c"
        "x": 627,
        "y": 3568,
        "wires": []
        "id": "315f5c9b26681c1e",
        "type": "change",
        "name": "Set Clear Context",
        "rules": [
                "t": "set",
                "p": "clearcontext",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Clear Context",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 658,
        "y": 3488,
        "wires": [
                "685dbdcbb65adb98"
        "id": "b983663d4790616b",
        "type": "inject",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Delete Context",
        "x": 450,
        "y": 3488,
        "wires": [
                "315f5c9b26681c1e"
        "id": "9ba440736a726214",
        "type": "inject",
        "name": "Email Now",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "EmailNow",
        "payload": "",
        "payloadType": "date",
        "x": 116,
        "y": 3200,
        "wires": [
                "685dbdcbb65adb98"
  • MJ de Bruijn
Zoek de juiste kwartieren - hoog laag enz.
Voor lezers die zich laten inspireren door de beschrijvingen van MESS geeft ik hier een toelichting op de werkwijze van het programma dat de 'juiste' kwartieren opzoekt. Wat juist is of niet hangt af van de situatie van de dag. Voorbeeld, 20 cent (netto) voor de KiloWattUur prijs kan soms hoog zijn, maar soms ook laag zijn. Dat is afhankelijk van de andere prijzen van die dag. Er is een situatie geweest dat ik bij 60 cent per KwH heb geladen om bij 90 cent per KwH terug te leveren aan het Grid. Toch nog 'winst'.
Het programma heet Find High and Low QH en is opgenomen in een Flow DayAhead. Het gaat om de resterende kwartieren van de actuele dag en de kwartieren van de volgende dag.
Afbeeldingslocatie: https://tweakers.net/i/obG5etNk_YgrPDhuuL8JScqtVMo=/800x/filters:strip_exif()/f/image/680BJR1FKBmnRtcYy1jzKeIW.png?f=fotoalbum_large
Kies hieronder voor de JavaScript-programmatekst van de drie functies.
Programma Find High and Low QH
Programma QH_Ct to Separate Hours
Programma High and Low as Text to Home Assistant
In de Flow zie je een Inject Node Trace On. Als je deze gebruikt verschijnt er een kort verslag van de opties en beslissingen.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
Start of Program
SoC_Min_Manual_Perc: 20
NegativePriceThresholdCt: -0.5
ZeroPriceThresholdCt: 0.1
VeryLowPriceThresholdCt: 2
Conversion_Loss_Factor: 0.9
Sell_Price_Difference_Limit: 5.0ct
Buy_Price_Difference_Limit: 10.0ct
SoC_Now_Perc: 100
Today_HighestPrice: 15.4ct
Today_LowestPrice: 4.7ct
Today_AveragePrice: 8.7ct
Today High Threshold: 12.0ct
Today Low Threshold: 5.7ct
Tomorrow_HighestPrice: -99.0ct
Tomorrow_LowestPrice: -99.0ct
Tomorrow_AveragePrice: -99.0ct
Tomorrow High Threshold: -99.0ct
Tomorrow Low Threshold: -99.0ct
Search for high and low QH
Sort QH_High High to Low
Sort other Tables Low to High
Find Sell QH by Highest prices
Current SoC: 100%
MaxSellQH: 6
High Price 17:30: 15.4ct
    incl.Cost: 33.4ct
    Conv.loss: 30.1ct
  Search matching re-charge QH
High Price 17:45: 15.1ct
    incl.Cost: 33.0ct
    Conv.loss: 29.7ct
High Price 16:45: 14.9ct
    incl.Cost: 32.8ct
    Conv.loss: 29.5ct
High Price 17:15: 14.7ct
    incl.Cost: 32.5ct
    Conv.loss: 29.3ct
High Price 18:00: 14.7ct
    incl.Cost: 32.5ct
    Conv.loss: 29.3ct
High Price 16:30: 13.5ct
    incl.Cost: 31.1ct
    Conv.loss: 28.0ct
High Price 19:00: 12.9ct
    incl.Cost: 30.4ct
    Conv.loss: 27.3ct
Find earlier QH to Charge extra...
Write Tables to Global
Done.
Korte toelichting.
  • Het programma haalt eerst de parameters op die worden gebruikt bij de beoordeling. Ik ga ervan uit dat de namen voldoende weergeven wat de betekenis is.
  • Dan berekent het programma de grenswaarden voor de actuele dag en de volgende dag. Een waarde -99 cent betekent dat de gegevens nog niet bekend zijn.
  • De aldus gemaakte tabellen worden gesorteerd op bedrag en, afhankelijk van de berekende grenswaarden, geplaatst in tabellen 'hoog', 'laag' etc.
  • Het kan zinvol zijn om bij hoge tarieven actief naar het Grid te ontladen. Maar... alleen als er kort daarna kan worden geladen tegen een voldoende lagere prijs. Er moet voldoende energie in de batterij overblijven om dat re-charge punt te halen. Als dat er niet is vervalt de verkoop-optie.
  • Als er verkoop-kwartieren gevonden worden kan het (ook nog) interessant zijn om tevoren de batterij extra te laden. Er is dan meer om te verkopen.
Een uitgebreidere uitleg plaats ik bij de programma-tekst hierna.
Er zijn ook nog twee functies die de gevonden gegevens naar Home Assistant sturen. Ik heb daar een dashboard gemaakt. Voor de werking van MESS is dit niet essentieel.
Afbeeldingslocatie: https://tweakers.net/i/VswYlNDIKBfES9b8wKZQNJPW8c0=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/FEV1vz77F0ARwA9ppx6gZlhF.png?f=user_large
Afbeeldingslocatie: https://tweakers.net/i/fdCiNsO8UISOXOp5uhbop4p_JSM=/x800/filters:strip_exif()/f/image/fdPZvwFWzEwuelx2Tje5oPqs.png?f=fotoalbum_large
De Prognose SoC wordt berekend op basis van het overschot van de Prognose Zonne-opbrenst (het Surplus) en het geschatte huis-verbruik (Consumptie). Hierbij is nog geen rekening gehouden met laden / ontladen van het Grid. Dat is namelijk wat MESS - op basis van deze prognose - gaat bepalen.
[ Voor 30% gewijzigd door MJ de Bruijn op 02-12-2025 14:09 ]
Een mens leert van zijn fouten. Ik heb in mijn leven heel veel geleerd.
  • MJ de Bruijn
Voor lezers die dit programma willen nabouwen - of er inspiratie uit halen - volgt hier de programma-tekst met toelichting. Vanwege de maximale lengte van een forum-bijdrage heb ik dit over meerdere bijdragen verdeeld.
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
const ProgName = "Find High and Low QH";
const Prog_ID = "HighAndLow";
let NewLine = "\n\r";
    return;
let FuncCount = 0;
let FuncNull = 0;
let ErrText = "";
let Result = true;
try {
    FuncCount++;
    GetNowTime = global.get("Victron_MESS.Functions.GetNowTime");
    {   ErrText += "Victron_MESS.Functions.GetNowTime" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    Not = global.get("Victron_MESS.Functions.Not");
    if (Not  == null)
    {   ErrText += "Victron_MESS.Functions.Not" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    CtToText = global.get("Victron_MESS.Functions.CtToText");
    if (Not  == null)
        FuncNull += 1;
        Result = false;
    FuncCount++;
    HourToText = global.get("Victron_MESS.Functions.HourToText");
    if (HourToText  == null)
    {   ErrText += "Victron_MESS.Functions.HourToText" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    QHToText = global.get("Victron_MESS.Functions.QHToText");
    if (QHToText  == null)
    {   ErrText += "Victron_MESS.Functions.QHToText" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    Round = global.get("Victron_MESS.Functions.Round");
    if (Round  == null)
    {   ErrText += "Victron_MESS.Functions.Round" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    Price_incl_Cost = global.get("Victron_MESS.Functions.Price_incl_Cost");
    if (Price_incl_Cost  == null)
    {   ErrText += "Victron_MESS.Functions.Price_incl_Cost" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    IsInArrayOfSets = global.get("Victron_MESS.Functions.IsInArrayOfSets");
    if (IsInArrayOfSets  == null)
    {   ErrText += "Victron_MESS.Functions.IsInArrayOfSets" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    ArrayOfSets_SortByPrice_Asc =
        global.get("Victron_MESS.Functions.ArrayOfSets_SortByPrice_Asc");
    if (ArrayOfSets_SortByPrice_Asc  == null)
    {   ErrText += "Victron_MESS.Functions.ArrayOfSets_SortByPrice_Asc" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    ArrayOfSets_SortByPrice_Desc =
        global.get("Victron_MESS.Functions.ArrayOfSets_SortByPrice_Desc");
    if (ArrayOfSets_SortByPrice_Desc  == null)
    {   ErrText += "Victron_MESS.Functions.ArrayOfSets_SortByPrice_Desc" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    ArrayOfSets_SortOnlyByPrice_Asc =
        global.get("Victron_MESS.Functions.ArrayOfSets_SortOnlyByPrice_Asc");
    if (ArrayOfSets_SortOnlyByPrice_Asc  == null)
    {   ErrText += "Victron_MESS.Functions.ArrayOfSets_SortOnlyByPrice_Asc" + NewLine;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    Add_Trace = global.get("Victron_MESS.Functions.Add_Trace");
    if (Add_Trace  == null)
    {   ErrText += "Victron_MESS.Functions.Add_Trace" + NewLine;
        FuncNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "ClearTrace");
    if ( !(Result) )
        node.status(
            {fill:"black",
            shape:"dot",
            text: "Wait for Get_Functions "
                + "(" + FuncNull + "/" + FuncCount + ")..."
    if ( (ErrText > "")
        node.warn("Get_Functions:" + NewLine + ErrText);
        node.status({fill:"red", shape:"dot",
                     text: ProgName + ": Error Get_Functions"
                     + "\n\r" + ErrText}
} // try
catch (error)
    Result = false;
    node.error("Program: " + ProgName + NewLine
    + "Step: Get_Functions" + NewLine
    + "Error: " + error)
} // catch
return Result;
} // Get_Functions
Het programma begint met het ophalen van voor MESS gemaakte 'standaard' functies.
Voor de inhoud van deze functies zie:
Flow Parameters - SetGlobalFunctions
[ Voor 83% gewijzigd door MJ de Bruijn op 02-12-2025 13:07 ]
  • MJ de Bruijn
vervolg...
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
function GlobalGetAll()
let Result = true;
let ErrText = "";
let VarCount = 0;
let VarNull = 0;
try {
    VarCount += 1;
    SoC_Min_Manual_Perc = global.get("Victron_MESS.Manual.SoC_Min_Perc");
    if (SoC_Min_Manual_Perc == null) {
        ErrText += "Victron_MESS.Manual.SoC_Min_Perc: null" + NewLine;
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "SoC_Min_Manual_Perc: " + SoC_Min_Manual_Perc + NewLine);
    VarCount += 1;
    QH_Ct =
      global.get("Victron_MESS.DayAhead.QH_Ct");
    if (QH_Ct == null) {
        ErrText += "Victron_MESS.DayAhead.QH_Ct: null" + NewLine;
        VarNull += 1;
        Result = false;
    VarCount += 1;
    QH_Level =
      global.get("Victron_MESS.DayAhead.QH_Level");
    if (QH_Level == null) {
        ErrText += "Victron_MESS.DayAhead.QH_Level: null" + NewLine;
        VarNull += 1;
        Result = false;
    VarCount += 1;
    NegativePriceThresholdCt =
      global.get("Victron_MESS.Param.NegativePriceThresholdCt");
    if (NegativePriceThresholdCt == null) {
        ErrText += "Victron_MESS.Param.NegativePriceThresholdCt: null" + NewLine;
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "NegativePriceThresholdCt: " + NegativePriceThresholdCt + NewLine);
    VarCount += 1;
    ZeroPriceThresholdCt =
      global.get("Victron_MESS.Param.ZeroPriceThresholdCt");
    if (ZeroPriceThresholdCt == null) {
        ErrText += "Victron_MESS.Param.ZeroPriceThresholdCt: null" + NewLine;
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "ZeroPriceThresholdCt: " + ZeroPriceThresholdCt + NewLine);
    VarCount += 1;
    VeryLowPriceThresholdCt =
      global.get("Victron_MESS.Param.VeryLowPriceThresholdCt");
    if (VeryLowPriceThresholdCt == null) {
        ErrText += "Victron_MESS.Param.VeryLowPriceThresholdCt: null" + NewLine;
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "VeryLowPriceThresholdCt: " + VeryLowPriceThresholdCt + NewLine);
    VarCount += 1;
    Conversion_Loss_Factor =
      global.get("Victron_MESS.Param.Conversion_Loss_Factor");
    if (Conversion_Loss_Factor == null) {
        ErrText += "Victron_MESS.Param.Conversion_Loss_Factor: null" + NewLine;
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "Conversion_Loss_Factor: " + Conversion_Loss_Factor + NewLine);
    VarCount += 1;
    Sell_Price_Difference_LimitCt =
      global.get("Victron_MESS.Param.Sell_Price_Difference_LimitCt");
    if (Sell_Price_Difference_LimitCt == null) {
        ErrText += "Victron_MESS.Param.Sell_Price_Difference_LimitCt: null" + "\n\r";
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "Sell_Price_Difference_Limit: "
            + CtToText(Sell_Price_Difference_LimitCt) + NewLine);
    VarCount += 1;
    Buy_Price_Difference_LimitCt =
      global.get("Victron_MESS.Param.Buy_Price_Difference_LimitCt");
    if (Buy_Price_Difference_LimitCt == null) {
        ErrText += "Victron_MESS.Param.Buy_Price_Difference_LimitCt: null" + "\n\r";
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "Buy_Price_Difference_Limit: "
            + CtToText(Buy_Price_Difference_LimitCt) + NewLine);
    VarCount += 1;
    SoC_Now_Perc =
      global.get("Victron_MESS.State.SoC_Now_Perc");
    if (SoC_Now_Perc == null) {
        ErrText += "Victron_MESS.State.SoC_Now_Perc: null" + "\n\r";
        VarNull += 1;
        Result = false;
    else
        Add_Trace(Prog_ID, "SoC_Now_Perc: "
            + SoC_Now_Perc + NewLine);
    if ( Not(Result) )
        node.status(
            {fill:"black",
            shape:"dot",
            text: " Wait for Global_Get_All "
                + "(" + VarNull + "/" + VarCount + ")..."
    if ( (ErrText > "")
        node.warn("Global_Get_All:" + NewLine + ErrText);
                     text: ProgName + ": Error Global_Get_All"
                     + "\n\r" + ErrText}
    Add_Trace(Prog_ID, NewLine);
} // try
catch (error)
    Result = false;
    node.warn("Program: " + ProgName + NewLine
    + "Step: Global_Get_All" + NewLine
} // catch
return Result;
} // Global_Get_All
Op analoge wijze haalt het programma Parameters en Statussen op (GlobalGetAll).
Zie: Flow Parameters - Diverse Parameters
Ook worden twee tabellen met de kwartierprijzen opgehaald: QH_Ct en QH_Level.
Deze twee tabellen worden gemaakt door Flow Tibber - Dagelijks Ophalen Kwartierprijzen
Afbeeldingslocatie: https://tweakers.net/i/0mVG2oVeJSp6vJ5X8VZcpLymAKM=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/hLgRIoldrvCv0n15j2eLfgqH.png?f=user_large
De tabel QH_Level bevat de - door Tibber bepaalde - beoordeling van de hoogte van de prijzen.
Afbeeldingslocatie: https://tweakers.net/i/V9MClhfaE27MlSgm54oF0-uzw20=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/WPEvKNhWL2LwIugokmV4vPBx.png?f=user_large
[ Voor 6% gewijzigd door MJ de Bruijn op 02-12-2025 20:40 ]
  • MJ de Bruijn
vervolg...
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
var DebugStep = "Start";
var Explain = ProgName + NewLine;
var TraceOn= false;
try
    DebugStep = "All variables";
    let NowHour = GetNowTime("NowHour");
    let Now_QH = GetNowTime("NowQuarter");
    let NowMinutes = GetNowTime("NowMinutes");
    let StartInSeconds = GetNowTime("NowInSeconds");
        context = null;
        node.status({fill:"blue",
            shape:"dot",
            text: "@ " + NowTime + " - Clear Context"}
        return [msg];
    if (msg.traceon)
            shape:"dot",
            text: "@ " + NowTime + " - Debug"}
        TraceOn= true;
    var QH_Ct = null;
    var QH_High = [];
    var QH_Normal = [];
    var QH_Low = [];
    var QH_VeryLow = [];
    var QH_Zero = [];
    var QH_Negative = [];
    var QH_By_Price = [];
    var QH_Buy = [];
    var QH_Sell = [];
    // var QH_BlocksCt = []
    var NegativePriceThresholdCt = 0;
    var ZeroPriceThresholdCt = 0;
    var VeryLowPriceThresholdCt = 0;
    var Conversion_Loss_Factor = 0;
    var Sell_Price_Difference_LimitCt = 0;
    var Buy_Price_Difference_LimitCt = 0;
    var PriceState = "Unknown";
    var Sell_QH_Count = 0;
    var Max_Sell_QH = 0;
    var Recharge_Look_Ahead_Number_of_QH = 20;
    Add_Trace(Prog_ID, "Find High and Low QH" + NewLine);
    DebugStep = "Start of Program";
    Add_Trace(Prog_ID, DebugStep + NewLine);
    if (!GlobalGetAll())
         node.warn('GlobalGetAll failed.');
         node.status({fill:"red",shape:"dot",
              text: "GlobalGetAll failed."
        return null;
    // discharge 12% per QH
    Max_Sell_QH = Math.floor((SoC_Now_Perc - SoC_Min_Manual_Perc) / 12);
    // find hours of Highest and Lowest prices
    let Today_HighestPrice =
      QH_Ct.slice(0,95).reduce((a, b) => Math.max(a, b), -Infinity);
    let Today_LowestPrice =
      QH_Ct.slice(0,95).reduce((a, b) => Math.min(a, b), Infinity);
    let Today_Sum =
      QH_Ct.slice(0, 95).reduce((a, b) => a + b, 0);
    let Today_Count =
      QH_Ct.slice(0, 95).length;
    let Today_AveragePrice =
      Math.round(1000*Today_Sum/Today_Count)/1000;
    let Today_HighPrice_Threshold =
      Math.round((Today_AveragePrice + (Today_HighestPrice - Today_AveragePrice) / 2) * 1000) / 1000;
    let Today_LowPrice_Threshold =
      Math.round((Today_AveragePrice - (Today_AveragePrice - Today_LowestPrice) * 0.75) * 1000) / 1000;
    let Tomorrow_HighestPrice =
      QH_Ct.slice(96).reduce((a, b) => Math.max(a, b), -Infinity);
    let Tomorrow_LowestPrice =
      QH_Ct.slice(96).reduce((a, b) => Math.min(a, b), Infinity);
    let Tomorrow_Sum =
      QH_Ct.slice(96).reduce((a, b) => a + b, 0);
    let Tomorrow_Count =
      QH_Ct.slice(96).length;
    let Tomorrow_AveragePrice =
      Math.round(1000*Tomorrow_Sum/Tomorrow_Count)/1000;
    let Tomorrow_HighPrice_Threshold =
      Math.round((Tomorrow_AveragePrice + (Tomorrow_HighestPrice - Tomorrow_AveragePrice) / 2)* 1000) / 1000;
    let Tomorrow_LowPrice_Threshold =
      Math.round((Tomorrow_AveragePrice - (Tomorrow_AveragePrice - Tomorrow_LowestPrice) / 2) * 1000) / 1000;
    Add_Trace(Prog_ID,
    "Today_HighestPrice: " + CtToText(Today_HighestPrice) + NewLine
    + "Today_LowestPrice: " + CtToText(Today_LowestPrice)  + NewLine
    + "Today_AveragePrice: " + CtToText(Today_AveragePrice) + NewLine
    + "Today High Threshold: " + CtToText(Today_HighPrice_Threshold) + NewLine
    + "Today Low Threshold: " + CtToText(Today_LowPrice_Threshold) + NewLine
    + NewLine
    + "Tomorrow_HighestPrice: " + CtToText(Tomorrow_HighestPrice) + NewLine
    + "Tomorrow_LowestPrice: " + CtToText(Tomorrow_LowestPrice)  + NewLine
    + "Tomorrow_AveragePrice: " + CtToText(Tomorrow_AveragePrice) + NewLine
    + "Tomorrow High Threshold: " + CtToText(Tomorrow_HighPrice_Threshold) + NewLine
    + "Tomorrow Low Threshold: " + CtToText(Tomorrow_LowPrice_Threshold) + NewLine
    + NewLine )
Vervolgens worden variabelen aangemaakt en de te gebruiken lege tabellen.
QH_High Zal de kwartieren bevatten met de - voor dat moment - hoge prijzen.
QH_Normal Bevat de kwartieren die niet onder de andere categorieën vallen.
QH_Low De - voor dat moment - lage prijzen.
QH_VeryLow De grenswaarde voor erg lage prijzen wordt vastgelegd in VeryLowPriceThresholdCt.
QH_Zero Voor de vaststelling of een prijs negatief is wordt een heel kleine marge aangehouden,
QH_Negative
Voor de vaststelling of een prijs negatief is wordt een heel kleine marge aangehouden (ZeroPriceThresholdCt) om eventueel snel uit- en aanschakelen van zonne-omvormers te voorkomen.
QH_By_Price Deze tabel tenslotte zal alle kwartieren met prijzen gaan bevatten van laag naar hoog, vanaf het huidige kwartier tot aan de beschikbare DayAhead kwartieren. Als het programma klaar is ziet dit er zo uit:
Afbeeldingslocatie: https://tweakers.net/i/FpkymCbW8g2_HrM7Wnb874sbsbg=/x800/filters:strip_exif()/f/image/mFCKdQkdyhqsDNz9AVTRHUSY.png?f=fotoalbum_large
Parameter [0] is het kwartier-nummer van 0 tot 191. 0 tot 95 is vandaag, 96 tot 191 is morgen,
parameter [1] is de KwH prijs van dat kwartier en
parameter [2] is de begintijd van het kwartier in leesbare vorm.
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
    DebugStep = "Search for high and low QH";
    for (let q = Now_QH; q < QH_Ct.length; q++)
        let curQH_AsText = QHToText(q);
        if (QH_Ct [  q  ] <= -98)
        {   // price unknown
            continue;
        else if (QH_Level [  q  ].toLowerCase() == "very_expensive" )
            QH_High.push([q, QH_Ct [  q  ], curQH_AsText ] )
        // else if (QH_Level [  q  ].toLowerCase() == "expensive" )
        //     QH_High.push([q, QH_Ct [  q  ], curQH_AsText ] )
        else if (QH_Ct [  q  ] <= NegativePriceThresholdCt)
            QH_Negative.push([q, QH_Ct [  q  ], curQH_AsText ] )
        else if (QH_Ct [  q  ] <= ZeroPriceThresholdCt)
            QH_Zero.push([q, QH_Ct [  q  ] , curQH_AsText ] )
        else if (QH_Ct [  q  ] <= VeryLowPriceThresholdCt)
            QH_VeryLow.push([q, QH_Ct [  q  ] , curQH_AsText ] )
        else if (QH_Level [  q  ].toLowerCase() == "cheap" )
            QH_Low.push([q, QH_Ct [  q  ] , curQH_AsText ] )
        else if ( ( (q <= 95) && (QH_Ct [  q  ] <= Today_LowPrice_Threshold) )
               || ( (q >  95) && (QH_Ct [  q  ] <= Tomorrow_LowPrice_Threshold) )
        else if ( ( (q <= 95) && (QH_Ct [  q  ]  >= Today_HighPrice_Threshold) )
               || ( (q >  95) && (QH_Ct [  q  ]  >= Tomorrow_HighPrice_Threshold) )
            QH_High.push( [ q, QH_Ct [  q  ] , curQH_AsText ] )
        else
            QH_Normal.push( [ q, QH_Ct [  q  ] , curQH_AsText ] )
        QH_By_Price.push([q, QH_Ct [  q  ] , curQH_AsText ] ) ;
    } // try all prices
Het programma leest alle beschikbare kwartieren stuk voor stuk uit en zal deze - afhankelijk van de vastgestelde grenswaarden - toevoegen aan de tabellen QH_High, QH_Negative, QH_Zero, QH_VeryLow, QH_Low.
[ Voor 10% gewijzigd door MJ de Bruijn op 02-12-2025 20:41 ]
  • MJ de Bruijn
vervolg...
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
    DebugStep = "Sort QH_High High to Low";
    QH_High.sort( ArrayOfSets_SortByPrice_Desc ) ;
    DebugStep = "Sort other Tables Low to High";
    QH_By_Price.sort( ArrayOfSets_SortOnlyByPrice_Asc ) ;
    QH_Normal.sort( ArrayOfSets_SortByPrice_Asc) ;
    QH_Low.sort( ArrayOfSets_SortByPrice_Asc) ;
    QH_VeryLow.sort( ArrayOfSets_SortByPrice_Asc ) ;
    QH_Zero.sort( ArrayOfSets_SortByPrice_Asc ) ;
    QH_Negative.sort( ArrayOfSets_SortByPrice_Asc ) ;
    Add_Trace(Prog_ID, NewLine );
    DebugStep = "Find Sell QH by Highest prices";
    Add_Trace(Prog_ID, "Current SoC: " + SoC_Now_Perc + "%" + NewLine);
    Add_Trace(Prog_ID, "MaxSellQH: " + Max_Sell_QH + NewLine);
    let QH_Repl_Used = [];
    for (let i = 0; i < QH_High.length; i++) // try all high prices
        if (Sell_QH_Count >= Max_Sell_QH) {break} // max number depends on SoC
        let Sell_Result = false;
        let Explain = "";
        // let idxHighPrice = QH_By_Price.length - q - 1;
        let HighPrice_QH = QH_High[i][0];
        let HighPrice = QH_High[i][1];
        let HighPrice_incl_cost = Price_incl_Cost(HighPrice, DebugStep);
        let HighPrice_Conv_Loss = HighPrice_incl_cost * Conversion_Loss_Factor;
        if (HighPrice_QH > Now_QH + 32)
            Add_Trace(Prog_ID, "Skip "
            + QHToText(HighPrice_QH) + NewLine );
            continue
        Add_Trace(Prog_ID,
            "High Price "
            + ": " + CtToText(HighPrice) + NewLine);
        Add_Trace(Prog_ID, "    incl.Cost: " + CtToText(HighPrice_incl_cost)
            + NewLine );
        Add_Trace(Prog_ID, "    Conv.loss: " + CtToText(HighPrice_Conv_Loss)
            + NewLine );
        Add_Trace(Prog_ID, "  Search matching re-charge QH"
            + NewLine );
Vervolgens worden de tabellen gesorteerd op bedrag. De 'High' tabel van hoog naar laag en de overige tabellen van laag naar hoog.
Om de bezien or er kwartieren zijn waarbij het zinvol is om actief aan het Grid terug te leveren zal het programma alle hoge prijzen stuk voor stuk bezien.
Er moet in de periode na het 'hoge' kwartier een moment zijn dat de verkochte energie gecompenseerd kan worden tegen een gunstige prijs.
De 'waarde' van een verkochte KwH is niet zomaar de netto prijs. Ook de belasting en leverancier-kosten kunnen (vooralsnog) worden verrekend. Maar, het ontladen van de batterij gaat gepaard met conversie-verlies. Daarom moet er een waarde-vermindering worden toegepast (Conversion_Loss_Factor). Ik heb deze op 0,9 gesteld.
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
        for (let q = HighPrice_QH + 1;
            q < Math.min(QH_Ct.length,
                        HighPrice_QH + 1 + Recharge_Look_Ahead_Number_of_QH) ;
            q++)
            let ReplPrice = QH_Ct   [   q   ]     ;
            if (ReplPrice < -98) { continue }
            let ReplPrice_incl_cost = Price_incl_Cost(ReplPrice, DebugStep);
            let ReplPrice_Conv_Loss = ReplPrice_incl_cost / Conversion_Loss_Factor;
            Explain = "    Try " + QHToText(q)
                + " " + CtToText(ReplPrice)
                + "/" + CtToText(ReplPrice_incl_cost)
                + "/" + CtToText(ReplPrice_Conv_Loss)
                + NewLine;
            if (QH_Repl_Used.indexOf(q) >= 0)
                // Replace QH already reserved for another Sell QH.
                continue;
            if (HighPrice_Conv_Loss
                < ReplPrice_Conv_Loss + Sell_Price_Difference_LimitCt)
            {   // No Sell
                // Add_Trace(Prog_ID, "  Re-charge costs more than Sell"
                //    + NewLine );
            else
            {   // Sell
                Sell_Result = true;
                QH_Repl_Used.push(q);
                Add_Trace(Prog_ID,
                    Explain
                    +"    Re-charge costs less than Sell"
                    + NewLine );
                break;
        } // try all High_QH
        if (Sell_Result == true)
            if (Not( IsInArrayOfSets(QH_Sell, [HighPrice_QH]) ) )
                if (QH_Ct[HighPrice_QH] > 0)
                    QH_Sell.push( [HighPrice_QH, QH_Ct[HighPrice_QH],
                        QHToText(HighPrice_QH) ] );
                    Add_Trace(Prog_ID, "  Add: "
                        + " to QH_Sell."
                        + NewLine );
                    Sell_QH_Count++;
        } // if Sell_Result == true
    // node.warn(QH_Sell);
Het programma check de prijzen van de kwartieren in de eerste uren na het kandidaat-verkoop-moment.
Ook hier wordt de netto-prijs omgerekend inclusief kosten en wordt de conversie-factor toegepast maar nu om de prijs te verhogen (= delen door Conversion_Loss_Factor). Het verschil tussen verkoop-waarde (HighPrice_Conv_Loss) en terugkoop-waarde (ReplPrice_Conv_Loss) moet ook nog groter zijn dan een minimum bedrag (Sell_Price_Difference_LimitCt) anders staat het systeem maar elektronen rond te pompen zonder dat er iets verdiend wordt.
Als er geen zinvol terugkoop moment wordt gevonden wordt het kandidaat-verkoop-kwartier verworpen.
[ Voor 15% gewijzigd door MJ de Bruijn op 02-12-2025 20:41 ]
  • MJ de Bruijn
vervolg...
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
    DebugStep = "Find earlier QH to Charge extra...";
    for (let i = 0; i < QH_Sell.length; i++)
        let cur_Sell_QH = QH_Sell[i][0];
        let cur_Sell_price = QH_Sell[i][1];
        let cur_Sell_price_incl_cost = Price_incl_Cost(cur_Sell_price, DebugStep);
        let cur_Sell_price_conv = cur_Sell_price_incl_cost * Conversion_Loss_Factor;
        DebugStep = "Find earlier QH. Find Match for cur_Sell_QH";
        Add_Trace(Prog_ID,
            NewLine
            + "Find match for "
            + QHToText(cur_Sell_QH)
            + " (" + CtToText(cur_Sell_price_conv) + ")"
            + NewLine);
        // now check all earlier QH's
        for (let Cand_QH = cur_Sell_QH - 1;
                Cand_QH >= Math.max(Now_QH, cur_Sell_QH - 12);
                Cand_QH--)
            DebugStep = "Find earlier QH. Check Candidate " + Cand_QH;
            let Cand_price = QH_Ct[Cand_QH]
            let Cand_price_incl_cost = Price_incl_Cost(Cand_price, DebugStep);
            let Cand_price_conv = Cand_price_incl_cost / Conversion_Loss_Factor;
            let Pred_price = QH_Ct[Cand_QH-1]
            let Pred_price_incl_cost = Price_incl_Cost(Pred_price, DebugStep);
            let Pred_price_conv = Pred_price_incl_cost / Conversion_Loss_Factor;
            if ( Cand_price < -98 )
                    + Cand_QH + " undefined";
                Add_Trace(Prog_ID, "  "
                    + QHToText(Cand_QH) + ": Price undefined."
                    + NewLine);
            else if ( Cand_price_conv >= cur_Sell_price_conv )
                    + Cand_QH + " to high";
                    + QHToText(Cand_QH)
                    + " (Buy: " + CtToText(Cand_price_conv) + ")"
                    + " to high."
                    + NewLine);
            else if ( Cand_price_conv > Pred_price_conv )
                    + Cand_QH + " higher then predecessor";
                    + QHToText(Cand_QH)
                    + " (buy: " + CtToText(Cand_price_conv) + ")"
                    + " is higher"
                    + NewLine
                    + "    than " + QHToText(Cand_QH-1)
                    + " (buy: " + CtToText(Pred_price_conv) + ")"
                    + "." + NewLine );
                // break; // don't try further
                        cur_Sell_price_conv - Buy_Price_Difference_LimitCt)
                    + Cand_QH + " low but not enough";
                    + QHToText(Cand_QH)
                    + " is low."
                    + NewLine);
            else
                    + Cand_QH + " is lowest";
                    + QHToText(Cand_QH)
                    + " low enough."
                    + NewLine);
                if ( IsInArrayOfSets(QH_Buy, [Cand_QH]) )
                    Add_Trace(Prog_ID,
                    "    Already selected for another Peak."
                    + NewLine);
                    continue
                else
                    Add_Trace(Prog_ID, "Add "
                    + QHToText(Cand_QH)
                    + " to QH_Buy array."
                    + NewLine);
                    QH_Buy.push([Cand_QH, QH_Ct[Cand_QH], QHToText(Cand_QH) ] );
                    // node.warn("Buy + : " + q)
                    break
            } // else
        } // for Cand_QH all earlier QH
    } // i all peaks
    if (QH_Level[Now_QH] != null)
        PriceState = QH_Level[Now_QH].toLowerCase();
    else if (IsInArrayOfSets(QH_Negative, [Now_QH]) ) {
        PriceState = "Negative";
    else if (IsInArrayOfSets(QH_Zero, [Now_QH]) ) {
        PriceState = "Zero";
    else if (IsInArrayOfSets(QH_High, [Now_QH]) ) {
        PriceState = "High";
    else if (IsInArrayOfSets(QH_VeryLow, [Now_QH]) ) {
        PriceState = "Very Low";
    else if (IsInArrayOfSets(QH_Low, [Now_QH]) ) {
        PriceState = "Low";
    else if (IsInArrayOfSets(QH_Normal, [Now_QH]) ) {
        PriceState = "Normal";
    else {
    DebugStep = "Write Tables to Global";
    global.set( "Victron_MESS.DayAhead.QH_By_Price",  QH_By_Price );
    global.set( "Victron_MESS.DayAhead.QH_High",  QH_High );
    global.set( "Victron_MESS.DayAhead.QH_Normal",  QH_Normal );
    global.set( "Victron_MESS.DayAhead.QH_Low",  QH_Low );
    global.set( "Victron_MESS.DayAhead.QH_VeryLow",  QH_VeryLow );
    global.set( "Victron_MESS.DayAhead.QH_Zero",  QH_Zero );
    global.set( "Victron_MESS.DayAhead.QH_Negative",  QH_Negative );
    // global.set( "Victron_MESS.DayAhead.QH_BlocksCt", QH_BlocksCt );
    global.set( "Victron_MESS.DayAhead.QH_Buy", QH_Buy );
    global.set( "Victron_MESS.DayAhead.QH_Sell", QH_Sell );
    global.set( "Victron_MESS.DayAhead.PriceState",  PriceState );
    global.set( "Victron_MESS.LastRun.DayAhead.HighAndLowHours"); // remove
    global.set( "Victron_MESS.LastRun.DayAhead.HighAndLowHours",  NowTime);
    DebugStep = "Done.";
    node.status({fill:"green",shape:"dot",
catch (error)
        + "Error in " + "Main Program" + ":" + NewLine
        + "Step: " + DebugStep + NewLine
if ( TraceOn )
        let curTraceText = global.get("Trace." + Prog_ID);
        for (let i = 0; i < curTraceText.length; i++ )
            node.warn(curTraceText[i]);
if (TraceOn)
    return null;
else
    return msg;
Indien er aldus een kwartier is gevonden waarbij het zinvol is om actief te verkopen probeert het programma nog of in de voorafgaande kwartieren misschien een lage prijs is waarbij het zinvol is om 'extra' te laden. Er kan dan meer verkocht worden. De berekening van het relevante verschil wordt analoog uitgevoerd zoals hierboven beschreven. Echter, het prijsverschil om extra in te kopen (Buy_Price_Difference_LimitCt) moet groter zijn dan bij verkoop omdat er anders slechts sprake is van verschuiving.
Tenslotte schrijft het programma de gevulde tabellen weg naar de Context Global Geheugenruimte.
Deze kunnen door het 'Brein' van MESS worden gebruikt bij de beoordeling van de gewenste instellingen, Verkopen, kopen, balans of slapen. Zie ook Kwartierprijzen
Het programma dat de beoordeling doet zal ik separaat beschrijven. Zie ook verderop.
[ Voor 5% gewijzigd door MJ de Bruijn op 02-12-2025 20:41 ]
  • MJ de Bruijn
En, gewoon om compleet te zijn, dit is het programma dat de gegevens naar Home Assistant stuurt.
JavaScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
const ProgramName = "QH_Ct to Separate Hours";
    return;
let FuncCount = 0;
let FuncNull = 0;
let ErrText = "";
let Result = true;
try {
    FuncCount++;
        FuncNull += 1;
        Result = false;
    FuncCount++;
    if (Not  == null)
        FuncNull += 1;
        Result = false;
    FuncCount++;
    if (Round  == null)
        FuncNull += 1;
        Result = false;
    if ( !(Result) )
        node.status(
            {fill:"black",
            shape:"dot",
    if ( (ErrText > "")
      && ( StartTime > context.First_StartTime + 15 )
                     + "\n\r" + ErrText}
} // try
catch (error)
    Result = false;
    node.error("Program: " + ProgramName + NewLine
} // catch
return Result;
} // Get_Functions
var Explain = "";
try
    let Now_QH =  GetNowTime("NowQuarterHour");
        context = null;
            shape:"dot",
        return [null];
    QH_Ct = global.get("Victron_MESS.DayAhead.QH_Ct");
    if (context.LastPrice == null) {
        context.LastPrice = {};
        for (let i = 0; i < 48; i++) {
            context.LastPrice[i] = null;
    let NewPrice = {};
        NewPrice[i] = -99;
    let HighValue = 0;
    let LowValue = 0;
    let MsgCount = 0;
    // node.warn(QH_Ct);
    NodeStep = "High and Low values";
        if ( (i >= NowHour)
          && (i < Math.floor(QH_Ct.length/4)) )
            if ( (QH_Ct[i*4] == null)
              || (QH_Ct[i*4+1] == null)
              || (QH_Ct[i*4+2] == null)
              || (QH_Ct[i*4+3] == null) )
            else if ( (isNaN(QH_Ct[i*4]))
                   || (isNaN(QH_Ct[i*4+1]))
                   || (isNaN(QH_Ct[i*4+2]))
                   || (isNaN(QH_Ct[i*4+3])) )
            else
                if ( (QH_Ct[i*4] > -98)
                  && (QH_Ct[i*4+1] > -98)
                  && (QH_Ct[i*4+2] > -98)
                  && (QH_Ct[i*4+3] > -98) )
                    NewPrice[i] =
                        Round(10*(
                        QH_Ct[i*4]
                        + QH_Ct[i*4+1]
                        + QH_Ct[i*4+2]
                        + QH_Ct[i*4+3] )
                        , 0)/40;
                    HighValue = Math.max(HighValue,
                          QH_Ct[i*4],
                          QH_Ct[i*4+1],
                          QH_Ct[i*4+2],
                          QH_Ct[i*4+3]
                    LowValue = Math.min(LowValue,
                          QH_Ct[i*4],
                          QH_Ct[i*4+1],
                          QH_Ct[i*4+2],
                          QH_Ct[i*4+3]
        DebugStep = "Create messages";
        msg.type = "call_service";
        msg.domain = "input_number";
        msg.service = "set_value";
        let CurHour = "0" + i;
        CurHour = CurHour.substring(CurHour.length - 2)
        msg.topic = "input_number.dayahead_price_"
          + CurHour + "_hr";
        msg.entity_id = msg.topic;
        if (NewPrice[i] != context.LastPrice[i]) {
            msg.payload = NewPrice[i];
            context.LastPrice[i] = NewPrice[i];
                shape:"dot",
                 text: "@ " + NowTime  + "; " + CurHour + "hr: " + msg.payload}
            MsgCount++;
            // node.warn("Send: " + CurHour + "hr: " + msg.payload);
            node.send( msg );
    // node.warn("High: " + HighValue);
    // node.warn("Low: " + LowValue);
    DebugStep = "Messages for High and Low";
    msg.topic = "input_number.dayahead_price_lowvalue";
    msg.payload = Round(LowValue, 0);
    msg.entity_id = "input_number.dayahead_price_lowvalue";
    msg.priority = true;
    if (msg.payload != context.LastLowValue)
        context.LastLowValue = msg.payload;
            shape:"dot",
             text: "@ " + NowTime  + "; LowValue: " + msg.payload}
        MsgCount++;
        global.set( "Victron_MESS.DayAhead.LowValue", msg.payload);
        node.send( msg );
    msg.topic = "input_number.dayahead_price_highvalue";
    msg.payload = Round(HighValue, 0);
    msg.entity_id = "input_number.dayahead_price_highvalue";
    if (msg.payload != context.LastHighValue)
        context.LastHighValue = msg.payload;
            shape:"dot",
             text: "@ " + NowTime  + "; HighValue: " + msg.payload}
        MsgCount++;
        global.set( "Victron_MESS.DayAhead.HighValue", msg.payload);
        node.send( msg );
    global.set( "Victron_MESS.LastRun.DayAhead.SeparateHours"); // remove
    global.set( "Victron_MESS.LastRun.DayAhead.SeparateHours",
       NowTime + "; " + MsgCount + " messages sent.");
        shape:"dot",
         text: "@ " + NowTime + "; " + MsgCount + " messages sent."}
catch (error)
        node.warn("Program: " + ProgramName + NewLine
        + "Error in " + arguments.callee.name + ":" + NewLine
node.done();
  • MJ de Bruijn
En deze...
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
const ProgramName = "High and Low as Text to Home Assistant";
  return;
let FuncCount = 0;
let FuncNull = 0;
let ErrText = "";
let Result = true;
try {
  FuncCount++;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  if (Not  == null)
    FuncNull += 1;
    Result = false;
  FuncCount++;
  if (Round  == null)
    FuncNull += 1;
    Result = false;
  FuncCount++;
    FuncNull += 1;
    Result = false;
  FuncCount++;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  if (CtToText  == null)
  {   ErrText += "Victron_MESS.Functions.CtToText" + NewLine;
    FuncNull += 1;
    Result = false;
  if ( !(Result) )
    node.status(
      {fill:"black",
      shape:"dot",
  if ( (ErrText > "")
           + "\n\r" + ErrText}
} // try
catch (error)
  Result = false;
} // catch
return Result;
} // Get_Functions
var Explain = "";
function Clear_Context_Last()
  context.Last_QH_Negative = [];
  context.Last_QH_VeryLow = [];
  context.Last_QH_Low = []
  context.Last_QH_Normal = []
  context.Last_QH_High = [];
  context.Last_QH_Buy = [];
  context.Last_QH_Sell = [];
  context.Last_PriceState = "";
  context.Last_Current_Price = "";
  context.Last_QH_GridCharge = [];
  context.Last_QH_SolarCharge = [];
function sortFirstElement(a, b) {
  if (a[0] === b[0]) {
    return 0;
  else {
    return (a[0] < b[0]) ? -1 : 1;
function QH_Price_Array_To_List (ParamArrayName, ParamArray)
  Result = "";
  const QH_ymbol = [":00", ":15", ":30", ":45"];
  let lastElement = -2;
  let delimiter = "";
  let NextElement = -2;
  if (ParamArray.length > 0)
    for (let i = 0; i < ParamArray.length; i++) {
      NextElement = -2;
      if (Number.isInteger(ParamArray[i]))
        curElement = ParamArray[i];
        if (i < ParamArray.length-1)
          NextElement = ParamArray[i+1];
      else
        curElement = ParamArray[i][0];
          NextElement = ParamArray[i+1][0];
      if (curElement == lastElement + 1)
      {   // continue series
        delimiter = "..";
        lastElement = curElement;
      else
      {   // new series
        Result += delimiter;
        Result += QHToText(curElement);
        delimiter = ', ';
        continue;
      if (curElement != NextElement - 1)
      {   // end series
        delimiter = ', ';
        continue;
      if (i == ParamArray.length-1)
      {   // last
  } // if the input Array has length
  Result = ParamArrayName + ": [" + Result + "]";
  return Result;
} // QH_Price_Array_To_List
try {
  DebugStep = "All Variables";
  let Now_QH = GetNowTime("Now_QH");
  let MsgCount = 0;
    context = null;
      shape:"dot",
    Clear_Context_Last();
    return [null];
  DebugStep = "All get";
  QH_High = global.get( "Victron_MESS.DayAhead.QH_High");
  QH_Normal = global.get( "Victron_MESS.DayAhead.QH_Normal");
  QH_Low = global.get( "Victron_MESS.DayAhead.QH_Low");
  QH_VeryLow = global.get( "Victron_MESS.DayAhead.QH_VeryLow" );
  QH_Zero = global.get( "Victron_MESS.DayAhead.QH_Zero" );
  QH_Negative = global.get( "Victron_MESS.DayAhead.QH_Negative" );
  QH_Buy = global.get( "Victron_MESS.DayAhead.QH_Buy" );
  QH_Sell = global.get( "Victron_MESS.DayAhead.QH_Sell" );
  PriceState = global.get( "Victron_MESS.DayAhead.PriceState" );
  QH_Ct = global.get( "Victron_MESS.DayAhead.QH_Ct" );
  QH_GridCharge =
    global.get( "Victron_MESS.Targets.Grid_QH_To_Charge" );
  if (QH_GridCharge == null)
    QH_GridCharge = [];
  QH_SolarCharge =
    global.get( "Victron_MESS.Targets.Solar_QH_To_Charge" );
  if (QH_SolarCharge == null)
  if (QH_High == null)
    node.warn("QH_High is null")
  else
    QH_High = QH_High.sort(sortFirstElement);
  if (QH_Normal == null)
    node.warn("QH_Normal is null")
  else
    QH_Normal = QH_Normal.sort(sortFirstElement);
  if (QH_Low == null)
    node.warn("QH_Low is null")
  else
    QH_Low = QH_Low.sort(sortFirstElement);
  if (QH_VeryLow == null)
    node.warn("QH_VeryLow is null")
  else
    QH_VeryLow = QH_VeryLow.sort(sortFirstElement);
  if (QH_Zero == null)
    node.warn("QH_Zero is null")
  else
    QH_Zero = QH_Zero.sort(sortFirstElement);
  if (QH_Negative == null)
    node.warn("QH_Negative is null")
  else
    QH_Negative = QH_Negative.sort(sortFirstElement);
  if (QH_Buy == null)
    node.warn("QH_Buy is null")
  else
    QH_Buy = QH_Buy.sort(sortFirstElement);
  if (QH_Sell == null)
    node.warn("QH_Sell is null")
  else
    QH_Sell = QH_Sell.sort(sortFirstElement);
    node.warn("QH_GridCharge is null")
  else
    QH_GridCharge =
    QH_GridCharge.sort(function(a, b) {return a - b;} );
    node.warn("QH_SolarCharge is null")
  else
    QH_SolarCharge =
    QH_SolarCharge.sort(function(a, b) {return a - b;} );
  DebugStep = "Make messages";
  msg.domain = "input_text";
  if (QH_Negative != null)
    msg.payload =
     QH_Price_Array_To_List("Negative", QH_Negative);
    msg.entity_id = "input_text.helper_dayahead_negative";
    msg.topic = msg.entity_id;
    if ( msg.payload != context.Last_QH_Negative )
      context.Last_QH_Negative = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_Zero != null)
    msg.payload =
      QH_Price_Array_To_List("Zero", QH_Zero);
    msg.entity_id = "input_text.helper_dayahead_zero";
    if ( msg.payload != context.Last_QH_Zero )
      context.Last_QH_Zero = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_VeryLow != null)
    msg.payload =
      QH_Price_Array_To_List("Very low", QH_VeryLow);
    msg.entity_id = "input_text.helper_dayahead_verylow";
    if ( msg.payload != context.Last_QH_VeryLow )
      context.Last_QH_VeryLow = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_Low != null)
    msg.payload =
      QH_Price_Array_To_List("Low", QH_Low);
    msg.entity_id = "input_text.helper_dayahead_low";
    if ( msg.payload != context.Last_QH_Low )
      context.Last_QH_Low = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_Normal != null)
    msg.payload =
      QH_Price_Array_To_List("Normal", QH_Normal);
    msg.entity_id = "input_text.helper_dayahead_price_normal";
    if ( msg.payload != context.Last_QH_Normal )
      context.Last_QH_Normal = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_High != null)
    msg.payload =
      QH_Price_Array_To_List("High", QH_High);
    msg.entity_id = "input_text.helper_dayahead_high";
    if ( msg.payload != context.Last_QH_High )
      context.Last_QH_High = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_Buy != null)
    msg.payload =
      QH_Price_Array_To_List("Buy", QH_Buy);
    msg.entity_id = "input_text.helper_dayahead_buy";
    if ( msg.payload != context.Last_QH_Buy )
      context.Last_QH_Buy = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_Sell != null)
    msg.payload =
      QH_Price_Array_To_List("Sell", QH_Sell);
    msg.entity_id = "input_text.helper_dayahead_sell";
    if ( msg.payload != context.Last_QH_Sell )
      context.Last_QH_Sell = msg.payload;
      node.send(msg);
      MsgCount++;
  if (PriceState != null)
    msg.payload = PriceState;
    msg.entity_id = "input_text.helper_dayahead_price_state";
    if ( msg.payload != context.Last_PriceState )
      context.Last_PriceState = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_Ct != null)
    msg.payload =
      "Current Price: " + CtToText(QH_Ct[Now_QH])
      + "; incl.cost: " + CtToText(Price_incl_Cost(QH_Ct[Now_QH], "High and Low as Text"))
    msg.entity_id = "input_text.helper_dayahead_current_price";
    if ( msg.payload != context.Last_Current_Price )
      context.Last_Current_Price = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_GridCharge != null)
    msg.payload =
      QH_Price_Array_To_List("Grid Charge", QH_GridCharge);
    msg.entity_id = "input_text.helper_dayahead_rule_grid";
    if ( msg.payload != context.Last_QH_GridCharge )
      context.Last_QH_GridCharge = msg.payload;
      node.send(msg);
      MsgCount++;
  if (QH_SolarCharge != null)
    msg.payload =
      QH_Price_Array_To_List("Solar Charge", QH_SolarCharge);
    msg.entity_id = "input_text.helper_dayahead_rule_solar";
    if ( msg.payload != context.Last_QH_SolarCharge )
      context.Last_QH_SolarCharge = msg.payload;
      node.send(msg);
      MsgCount++;
    shape:"dot",
catch (error)
node.done();
De afhandeling van de te verzenden berichten is in een separate Flow opgenomen. Hier is ook een wachtrij, een controle en een retry mechanisme in opgenomen.
Mogelijk beschrijf ik dat nog wel eens. Zoek daarvoor dan in de inhoudsopgave.
[ Voor 12% gewijzigd door MJ de Bruijn op 02-12-2025 20:44 ]
  • Tillumen
  • Registratie: November 2024
  • Laatst online: 13:28
@MJ de Bruijn Wat en werk en leuk om te lezen! Zou het een idee zijn om de config ergens op GIT ofzo te zetten zodat de laatste versie altijd ergens staat?
  • MJ de Bruijn
  • Registratie: November 2016
  • Laatst online: 08:59
Tillumen schreef op donderdag 4 december 2025 @ 10:31:
Leuk te horen dat je het op prijs stelt.
Ik heb erover gedacht om mijn software beschikbaar te maken. Maar het is heel erg op een specifieke situatie toegesneden, Niemand kan het 'as is' overnemen. Het kan ter inspiratie dienen voor zelfbouw of gewoon om te lezen hoe je zaken aanpakt. Dat helpt te begrijpen hoe andere systemen werken.
Ik ben ook niet meer in staat om ondersteuning te bieden. Als ik het via GIT beschikbaar zou maken zou de kwaliteit een stuk hoger moeten liggen. Die 'lat' haal ik niet.
  • Gustavebbers
  • Laatst online: 13-07 20:01
@MJ de Bruijn Harstikke bedankt voor MESS, heeft vorig jaar perfect gedraait met een aantal wijzigingen totdat het kwartierprijzen werden. Ik zag bij alleen DESS dat ik mijn accu vol had tegen de tijd dat stroom goedkoop werd, waar MESS het lukte om op de goedkope momenten te laden ipv terug te leveren.
Momenteel ben ik je november upgrades aan het doorvoeren, maar ik mis denk ik het "brein" stukje. Mocht je deze nog willen delen, zou ik daar heel blij van worden. Aanpassen is een stuk makkelijker als iets nieuws maken. Ook al zou mijn "algoritme" waarschijnlijk behoorlijk anders zijn.
  • MJ de Bruijn
Gustavebbers schreef op zaterdag 21 maart 2026 @ 00:04:
@MJ de Bruijn Harstikke bedankt...
Ik heb inmiddels een 'kwartier versie' werkend.
Ik zal in de komende dagen proberen dit hier te delen.
  • MJ de Bruijn
Mag weg.
[ Voor 98% gewijzigd door MJ de Bruijn op 21-03-2026 09:40 ]
  • MJ de Bruijn
Dit is mijn actuele flow "Targets".
Afbeeldingslocatie: https://tweakers.net/i/ZGkzivhq9dFc-ZZ3agAbo5Syuls=/x800/filters:strip_icc():strip_exif()/f/image/JWDqk7IrosyAahkgD9blQ9Ri.jpg?f=fotoalbum_large
  • MJ de Bruijn
De Node "Calculate Targets" is zoals eerder beschreven het "brein" van MESS.
Dit programma gebruikt echter wel het voorwerk dat is gedaan door andere Nodes zoals
"Find High and Low QH".
Omdat de programma-tekst te lang is om als één geheel in een post op te nemen heb ik deze in stukken opgedeeld. Zie hierna.
[ Voor 56% gewijzigd door MJ de Bruijn op 26-03-2026 11:22 ]
  • MJ de Bruijn
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
791
792
793
794
795
796
797
798
799
800
801
802
803
804
805
806
807
808
809
810
811
812
813
814
815
816
817
818
819
820
821
822
823
824
825
826
827
828
829
830
831
832
833
834
835
836
837
838
839
840
841
842
843
844
845
846
847
848
849
850
851
852
853
854
855
856
857
858
859
860
861
862
863
864
865
866
867
868
869
870
871
872
873
874
875
876
877
878
879
880
881
882
883
884
885
886
887
888
889
890
891
892
893
894
895
896
897
898
899
900
901
902
903
904
905
906
907
908
909
910
911
912
913
914
915
916
917
918
919
920
921
922
923
924
925
926
927
928
929
930
931
932
933
934
935
936
937
938
939
940
941
942
943
944
945
946
947
948
949
950
951
952
953
954
955
956
957
958
959
960
961
962
963
964
965
966
967
968
969
970
971
972
973
974
975
976
977
978
979
980
981
982
const ProgName = "Calculate Targets";
const Prog_ID = "Targets";
context = context || {};
let Now = new Date();
StartTime = Math.floor(Now.getTime() / 1000);
let NewLine = "\r\n";
if (context.First_StartTime == null)
  context.First_StartTime = StartTime;
if ( !(Get_Functions() ) )
  return;
let NowTime = GetNowTime();
let NowQH = GetNowTime("NowQH");
let NowQHAsText = QHToText(NowQH);
// Variables to read from Global
var SoC_Min_Manual_Perc = null;
var Grid_Setpoint_Manual_W = null;
var QH_Ct = null;
var Solar_Forecast_Modified = null;
var Sunrise = null;
var Sunset = null;
var Sunrise_QH = -1;
var Sunset_QH = -1;
var Sunrise_DateTime = "";
var Sunset_DateTime = "";
var Grid_Lost_Alarm = null;
var Smoke_Alarm = null;
var DayAheadRule = "";
var ErrorText = "";
var Solar_Today_Wh = 0;
var Solar_Surplus_Today_Wh = 0;
var Solar_Remain_Today_Wh = 0;
var Solar_Remain_This_QH_Wh = 0;
var Solar_Remain_Negative_Price_Wh = 0;
var Solar_Remain_Zero_Price_Wh = 0;
var Solar_Remain_VeryLow_Price_Wh = 0;
var Solar_Remain_Low_Price_Wh = 0;
var Solar_Remain_High_Price_Wh = 0;
var Solar_Remain_Rest_Price_Wh = 0;
var Solar_Delta_at_Sunset_Wh = 0;
var Solar_Tomorrow_Wh = 0;
var Solar_By_Price = [];
var Solar_QH_To_Charge = [];
var Grid_QH_To_Charge = [];
var Solar_To_Batt_Perc = 0;
var Batt_Forecast_Wh = [];
var Batt_Prognosis_Perc = [];
var Batt_Forecast_Incl_Grid_Wh = [];
var Batt_Full_Wh = 0;
var Batt_Min_Manual_Wh = 0;
var Batt_Min_Bottom_Wh = 0;
var Batt_Now_Wh = 0;
var Batt_Free_Wh = 0;
var Batt_Max_Current_Grid_A = 0;
var Batt_Max_Current_Solar_A = 0;
var Grid_This_Morning_Wh = 0; // Current Night
var Grid_until_Sunset_Wh = 0; // Today
var Grid_until_Batt_Next_Min_Wh = 0;
var Grid_until_Sunrise_Tomorrow_Wh = 0; // Coming night
var Grid_Needed_Today_Wh = 0;
var Grid_Needed_Tonight_Wh = 0;
var Energy_to_Sell_Wh = 0; // when negative price comes
var Energy_to_Sell_Buffer_Wh = 0; // do not discharge
var Energy_for_Discharge_W = 0;
var Forecast_Stay_Above_Minimum_QH = -1;
var SoC_Min_Bottom_Perc = 0;
var SoC_Min_Target_Perc = 0;
var Grid_Setpoint_Unload_W = 0;
var Grid_Setpoint_Target_W = 0;
var Max_Discharge_Current_Target_Perc = 100;
var Charge_Disable_Target = 0; // 1 = disabled; 0 = charging enabled
var Solar_Charger_Target = 1; // 1 = ON; 4 OFF
var SolarEdge_Target = 'On'; // On /  Off
// Messages with settings
var msg_DayAhead_Rule = null;
var msg_Batt_Max_Current_Target_A = null;
var msg_SoC_Min_Target_Perc = null;
var msg_Grid_Setpoint_Target_W = null;
var msg_Max_Discharge_Current_Target_Perc = null;
var msg_Charge_Disable_Target = null;
var msg_Solar_Charger_Target = null;
var msg_SolarEdge_Target = null;
var msg_HA_Email = null;
if ( Not(Global_Get_All() ) )
  return;
let idx_QH = 0;
let idxcurPrice = 1;
let idx_QHAsText = 2;
let idxcurSolar = 1;
let idxSolarDelta = 2;
var DebugStep = "Unknown";
  context = null;
  // Variables for input messages
  context.RunNow = false;
  context.Energy_from_Solar_Now_W = null;
  context.Grid_To_Battery_Start_Seconds = 0;
  context.SoC_Now_Perc = null;
  context.SoC_Min_Venus = null;
  context.Max_Charge_A = null;
  context.Max_Charge_V = null;
  context.Grid_Setpoint = null;
  context.Temperature_Limit_Factor = null;
  context.Charge_Disable = null;
  context.Solar_Charger = null;
  context.SolarEdge = null;
  context.Grid_to_Batt_Limit_A = 120; // dafault
  context.TraceOn = false;
  // Results from previous calculations
  context.Grid_To_Battery_End_Time = 0;
  context.Grid_To_Battery_Start_Time = 0;
    shape:"dot",
  return [msg];
if (context.Last_DayAheadRule == null)
  Init_Context();
function Init_Context()
  Add_Trace(Prog_ID, "Init_Context..." + NewLine);
  if (context.Grid_To_Battery_Start_Seconds == null)
  if (context.Grid_To_Battery_End_Time == null)
  if (context.Temperature_Limit_Factor == null)
    context.Temperature_Limit_Factor = 1;
function Quarter_Remain_Factor() {
  return (15 - (NowMinutes % 15)) / 15;
  Add_Trace(Prog_ID, "Clear_Context_Last..." + NewLine);
  // Clear other reference-values
  context.Last_Solar_Today_Wh = 0;
  context.Last_Solar_Surplus_Today_Wh = 0;
  context.Last_Solar_Remain_Today_Wh = 0;
  context.Last_Solar_Remain_This_QH_Wh = 0;
  context.Last_Solar_Tomorrow_Wh = 0;
  context.Last_Batt_Forecast_Wh = -99;
  context.Last_Batt_Prognosis_Perc = -99;
  context.Last_SoC_Min_Manual_Perc = -1;
  context.Last_SoC_Now_Perc = -1;
  context.Last_Batt_High_Value = -1;
  context.Last_Batt_Low_Value = -1;
  context.Last_Batt_Next_Min_Value = -1;
  context.Last_Forecast_Stay_Above_Minimum_QH = -2;
  context.Last_Grid_This_Morning_Wh = -100;
  context.Last_Grid_until_Sunset_Wh = -100;
  context.Last_Grid_until_Batt_Next_Min_Wh = -100;
  context.Last_Grid_until_Sunrise_Tomorrow_Wh = -100;
  context.Last_SoC_Min_Target_Perc = -1;
  context.last_Temperature_Limit_Factor = 0;
  context.Last_Batt_Max_Current_Grid_A = -2;
  context.Last_Batt_Max_Current_Solar_A = -2;
  context.Last_Batt_Max_Current_Target_A = -2;
  context.last_Max_Discharge_Current_Target_Perc = -2;
  context.Last_Grid_Setpoint_Target_W = -2;
  context.Last_Charge_Disable_Target = -1;
  context.Last_Solar_Charger_Target = -1;
  context.Last_SolarEdge_Target = 'Unknown';
  context.Last_Solar_QH_To_Charge = [];
  context.Last_Grid_QH_To_Charge = [];
  context.Last_DayAheadRule = "";
} // Clear_Context_Last
function Get_Functions() {
let FuncCount = 0;
let FuncNull = 0;
let ErrText = "";
let Result = true;
try {
  FuncCount++;
  if (GetNowTime  == null)
    FuncNull += 1;
    Result = false;
  FuncCount++;
  if (Not  == null)
    FuncNull += 1;
    Result = false;
  FuncCount++;
  if (Not  == null)
    FuncNull += 1;
    Result = false;
  FuncCount++;
    FuncNull += 1;
    Result = false;
  FuncCount++;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  WhToText = global.get("Victron_MESS.Functions.WhToText");
  if (WhToText  == null)
  { ErrText += "Victron_MESS.Functions.WhToText" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  kWhToWh = global.get("Victron_MESS.Functions.kWhToWh");
  if (kWhToWh  == null)
  { ErrText += "Victron_MESS.Functions.kWhToWh" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  if (Round  == null)
    FuncNull += 1;
    Result = false;
  FuncCount++;
  PriceToBuyValue = global.get("Victron_MESS.Functions.PriceToBuyValue");
  if (PriceToBuyValue  == null)
  { ErrText += "Victron_MESS.Functions.PriceToBuyValue" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  PriceToDirectValue = global.get("Victron_MESS.Functions.PriceToDirectValue");
  if (PriceToDirectValue  == null)
  { ErrText += "Victron_MESS.Functions.PriceToDirectValue" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  PriceToSellValue = global.get("Victron_MESS.Functions.PriceToSellValue");
  if (PriceToSellValue  == null)
  { ErrText += "Victron_MESS.Functions.PriceToSellValue" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  PosInArrayOfSets = global.get("Victron_MESS.Functions.PosInArrayOfSets");
  if (PosInArrayOfSets  == null)
  { ErrText += "Victron_MESS.Functions.PosInArrayOfSets" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  ArrayOfSetsGetPriceByHour =
    global.get("Victron_MESS.Functions.ArrayOfSetsGetPriceByHour");
  if (ArrayOfSetsGetPriceByHour  == null)
  { ErrText += "Victron_MESS.Functions.ArrayOfSetsGetPriceByHour" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  TimestampTo_HH_MM_SS = global.get("Victron_MESS.Functions.TimestampTo_HH_MM_SS");
  if (TimestampTo_HH_MM_SS  == null)
  { ErrText += "Victron_MESS.Functions.TimestampTo_HH_MM_SS" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
  TimestampTo_QH = global.get("Victron_MESS.Functions.TimestampTo_QH");
  if (TimestampTo_QH  == null)
  { ErrText += "Victron_MESS.Functions.TimestampTo_QH" + NewLine;
    FuncNull += 1;
    Result = false;
  FuncCount++;
    FuncNull += 1;
    Result = false;
  else
  if ( !(Result) )
    node.status(
      {fill:"black",
      shape:"dot",
  if ( (ErrText > "")
           + "\n\r" + ErrText}
} // try
catch (error)
  Result = false;
} // catch
return Result;
} // Get_Functions
function Global_Get_All()
let VarCount = 0;
let VarNull = 0;
let ErrText = "";
let Result = true;
try {
  Add_Trace(Prog_ID, "Global_Get_All..." + NewLine);
  DebugStep = "Parameters (fixed)";
  VarCount += 1;
  Batt_Current_Limit_A  =
    global.get("Victron_MESS.Param.Batt_Current_Limit_A");
  if (Batt_Current_Limit_A  == null)
  { ErrText += "Victron_MESS.Param.Batt_Current_Limit_A " + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
    global.get("Victron_MESS.Param.Energy_to_Sell_Buffer_Wh");
  if (Energy_to_Sell_Buffer_Wh == null) {
    ErrText += "Victron_MESS.Param.Energy_to_Sell_Buffer_Wh: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  SolarEdge_Production_Limit_W =
    global.get("Victron_MESS.Param.SolarEdge_Production_Limit_W");
  if (SolarEdge_Production_Limit_W == null)
  { ErrText += "Victron_MESS.Param.SolarEdge_Production_Limit_W" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Batt_Capacity_Wh =
    global.get("Victron_MESS.Param.Batt_Capacity_Wh");
  if (Batt_Capacity_Wh == null) {
    ErrText += "Victron_MESS.Param.Batt_Capacity_Wh: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  SoC_Full_Perc =
    global.get("Victron_MESS.Param.SoC_Full_Perc");
  if (SoC_Full_Perc == null) {
    ErrText += "Victron_MESS.Param.SoC_Full_Perc: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
    ErrText += "Victron_MESS.Param.Sell_Price_Difference_LimitCt: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
    ErrText += "Victron_MESS.Param.Buy_Price_Difference_LimitCt: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  PV_Turn_Off_Price_LimitCt =
    global.get("Victron_MESS.Param.PV_Turn_Off_Price_LimitCt");
  if (PV_Turn_Off_Price_LimitCt == null) {
    ErrText += "Victron_MESS.Param.PV_Turn_Off_Price_LimitCt: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Grid_Setpoint_Limit_W =
    global.get("Victron_MESS.Param.Grid_Setpoint_Limit_W");
  if (Grid_Setpoint_Limit_W == null) {
    ErrText += "Victron_MESS.Param.Grid_Setpoint_Limit_W: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Solar_Charge_Perc =
    global.get("Victron_MESS.Param.Solar_Charge_Perc");
  if (Solar_Charge_Perc == null) {
    ErrText += "Victron_MESS.Param.Solar_Charge_Perc: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Batt_Max_Charge_W =
    global.get("Victron_MESS.Param.Batt_Max_Charge_W");
  if (Batt_Max_Charge_W == null) {
    ErrText += "Victron_MESS.Param.Batt_Max_Charge_W: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Batt_Max_Discharge_W =
    global.get("Victron_MESS.Param.Batt_Max_Discharge_W");
  if (Batt_Max_Discharge_W == null) {
    ErrText += "Victron_MESS.Param.Batt_Max_Discharge_W: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Finish_Grid_Charge_Seconds =
    global.get("Victron_MESS.Param.Finish_Grid_Charge_Seconds");
  if (Finish_Grid_Charge_Seconds == null) {
    ErrText += "Victron_MESS.Param.Finish_Grid_Charge_Seconds: null" + NewLine;
    VarNull += 1;
    Result = false;
  // States
  VarCount += 1;
  SoC_Min_Venus =
    global.get("Victron_MESS.State.SoC_Min_Venus");
  if (SoC_Min_Venus == null)
  { ErrText += "Victron_MESS.State.SoC_Min_Venus" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Grid_Setpoint_W =
    global.get("Victron_MESS.State.Grid_Setpoint_W");
  if (Grid_Setpoint_W == null)
  { ErrText += "Victron_MESS.State.Grid_Setpoint_W" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Charge_Disable =
    global.get("Victron_MESS.State.Charge_Disable");
  if (Charge_Disable == null)
  { ErrText += "Victron_MESS.State.Charge_Disable" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Solar_Charger =
    global.get("Victron_MESS.State.Solar_Charger");
  if (Solar_Charger == null)
  { ErrText += "Victron_MESS.State.Solar_Charger" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  SolarEdge_Production =
    global.get("Victron_MESS.State.SolarEdge_Production");
  if (SolarEdge_Production == null)
  { ErrText += "Victron_MESS.State.SolarEdge_Production" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Multiplus_II_1_Temp =
    global.get("Victron_MESS.State.Multiplus_II_1_Temp");
  if (Multiplus_II_1_Temp == null)
  { ErrText += "Victron_MESS.State.Multiplus_II_1_Temp" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Multiplus_II_2_Temp =
    global.get("Victron_MESS.State.Multiplus_II_2_Temp");
  if (Multiplus_II_2_Temp == null)
  { ErrText += "Victron_MESS.State.Multiplus_II_2_Temp" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Multiplus_II_3_Temp =
    global.get("Victron_MESS.State.Multiplus_II_3_Temp");
  if (Multiplus_II_3_Temp == null)
  { ErrText += "Victron_MESS.State.Multiplus_II_3_Temp" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  SoC_Now_Perc =
  { ErrText += "Victron_MESS.State.SoC_Now_Perc" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Batt_SoC_Full_Time =
    global.get("Victron_MESS.Targets.Batt_SoC_Full_Time");
  if (Batt_SoC_Full_Time == null)
    Batt_SoC_Full_Time = "";
  VarCount += 1;
  DESS_Mode =
    global.get("Victron_MESS.State.DESS_Mode");
  if (DESS_Mode == null)
  { ErrText += "Victron_MESS.State.DESS_Mode" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Grid_Lost_Alarm =
    global.get("Victron_MESS.State.Grid_Lost_Alarm");
  if (Grid_Lost_Alarm == null)
  { ErrText += "Victron_MESS.State.Grid_Lost_Alarm" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Smoke_Alarm =
    global.get("Victron_MESS.State.Smoke_Alarm");
  if (Smoke_Alarm == null)
  { ErrText += "Victron_MESS.State.Smoke_Alarm" + NewLine;
    VarNull += 1;
    Result = false;
  // EV_Charger
  // From EV Charger Monitor
  VarCount += 1;
  EV_Charger_Grid_to_Batt_A =
    global.get("Victron_MESS.EV_Charger.Grid_to_Batt_A");
  if (EV_Charger_Grid_to_Batt_A == null)
  { // ErrText += "Victron_MESS.EV_Charger.Grid_to_Batt_A" + NewLine;
    // Result = false;
    VarNull += 1;
    EV_Charger_Grid_to_Batt_A = Batt_Current_Limit_A ;
  // DayAhead
  VarCount += 1;
  QH_High =
    global.get("Victron_MESS.DayAhead.QH_High");
  { ErrText += "Victron_MESS.DayAhead.QH_High" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Normal =
    global.get("Victron_MESS.DayAhead.QH_Normal");
  { ErrText += "Victron_MESS.DayAhead.QH_Normal" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Low =
    global.get("Victron_MESS.DayAhead.QH_Low");
  if (QH_Low == null)
  { ErrText += "Victron_MESS.DayAhead.QH_Low" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_VeryLow =
    global.get("Victron_MESS.DayAhead.QH_VeryLow");
  { ErrText += "Victron_MESS.DayAhead.QH_VeryLow" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Zero =
    global.get("Victron_MESS.DayAhead.QH_Zero");
  { ErrText += "Victron_MESS.DayAhead.QH_Zero" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Negative =
    global.get("Victron_MESS.DayAhead.QH_Negative");
  { ErrText += "Victron_MESS.DayAhead.QH_Negative" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Buy =
    global.get("Victron_MESS.DayAhead.QH_Buy");
  if (QH_Buy == null)
  { ErrText += "Victron_MESS.DayAhead.QH_Buy" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Sell =
    global.get("Victron_MESS.DayAhead.QH_Sell");
  { ErrText += "Victron_MESS.DayAhead.QH_Sell" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Ct =
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_Level =
    VarNull += 1;
    Result = false;
  VarCount += 1;
  QH_By_Price =
    global.get("Victron_MESS.DayAhead.QH_By_Price");
  if (QH_By_Price == null) {
    ErrText += "Victron_MESS.DayAhead.QH_By_Price: null" + NewLine;
    VarNull += 1;
    Result = false;
  // Manual
  VarCount += 1;
    VarNull += 1;
    Result = false;
  SoC_Min_Bottom_Perc = Math.min(15, SoC_Min_Manual_Perc);
  VarCount += 1;
  Grid_Setpoint_Manual_W = global.get("Victron_MESS.Manual.Grid_Setpoint");
  if (Grid_Setpoint_Manual_W == null) {
    ErrText += "Victron_MESS.Manual.Grid_Setpoint: null" + NewLine;
    VarNull += 1;
    Result = false;
  // Solar
  VarCount += 1;
  Solar_Forecast_Modified = global.get("Victron_MESS.Solar.Forecast.Modified");
  if (Solar_Forecast_Modified == null) {
    ErrText += "Victron_MESS.Solar.Forecast.Modified: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Sunrise = global.get("Victron_MESS.Solar.Sunrise");
  if (Sunrise == null) {
    ErrText += "Victron_MESS.Solar.Sunrise: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Sunrise_DateTime = global.get("Victron_MESS.Solar.Sunrise_DateTime");
  if (Sunrise_DateTime == null) {
    ErrText += "Victron_MESS.Solar.Sunrise_DateTime: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Sunrise_QH = global.get("Victron_MESS.Solar.Sunrise_QH");
  if (Sunrise_QH == null) {
    ErrText += "Victron_MESS.Solar.Sunrise_QH: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Sunset = global.get("Victron_MESS.Solar.Sunset");
  if (Sunset == null) {
    ErrText += "Victron_MESS.Solar.Sunset: null" + NewLine;
    Result = false;
  VarCount += 1;
  Sunset_DateTime = global.get("Victron_MESS.Solar.Sunset_DateTime");
  if (Sunset_DateTime == null) {
    ErrText += "Victron_MESS.Solar.Sunset_DateTime: null" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Sunset_QH = global.get("Victron_MESS.Solar.Sunset_QH");
  if (Sunset_QH == null) {
    ErrText += "Victron_MESS.Solar.Sunset_QH: null" + NewLine;
    Result = false;
  VarCount += 1;
  Solar_Corr_Factor = global.get("Victron_MESS.Solar.Forecast.Corr_Factor");
  if (Solar_Corr_Factor == null) {
    ErrText += "Victron_MESS.Solar.Forecast.Corr_Factor: null" + NewLine;
    Result = false;
  VarCount += 1;
  context.Solar_Now_W =
    global.get("Victron_MESS.State.Solar_Surplus");
  if (context.Solar_Now_W == null)
  { ErrText += "Victron_MESS.State.Solar_Surplus" + NewLine;
    VarNull += 1;
    Result = false;
  // Parameters
  VarCount += 1;
  Batt_Max_Charge_Voltage_V =
    global.get("Victron_MESS.State.Batt_Max_Charge_Voltage_V");
  if (Batt_Max_Charge_Voltage_V == null)
  { ErrText += "Victron_MESS.State.Batt_Max_Charge_Voltage_V" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Batt_Max_Charge_Current_A =
    global.get("Victron_MESS.State.Batt_Max_Charge_Current_A");
  if (Batt_Max_Charge_Current_A == null)
  { ErrText += "Victron_MESS.State.Batt_Max_Charge_Current_A" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Max_Inverter_Power_W =
    global.get("Victron_MESS.State.Max_Inverter_Power_W");
  if (Max_Inverter_Power_W == null)
  { ErrText += "Victron_MESS.State.Max_Inverter_Power_W" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Max_Discharge_Current_Perc =
    global.get("Victron_MESS.State.Max_Discharge_Current_Perc");
  if (Max_Discharge_Current_Perc == null)
  { ErrText += "Victron_MESS.State.Max_Discharge_Current_Perc" + NewLine;
    VarNull += 1;
    Result = false;
  VarCount += 1;
  Consump_Forecast_Wh =
    global.get("Victron_MESS.Consump.Forecast");
  if (Consump_Forecast_Wh == null) {
    ErrText += "Victron_MESS.Consump.Forecast: null" + NewLine;
    VarNull += 1;
    Result = false;
  if ( Not(Result) )
    node.status(
      {fill:"black",
      shape:"dot",
        + " Wait for Global_Get_All "
  if ( (ErrText > "")
    node.status({fill:"red", shape:"dot",
           + "\n\r" + ErrText}
  Add_Trace(Prog_ID, NewLine + "Batt_SoC_Full_Time: " + Batt_SoC_Full_Time + NewLine);
} // try
catch (error)
  Result = false;
  node.error("Program: " + ProgName + NewLine
  + "Error: " + error)
} // catch
return Result;
} // Global_Get_All
Een mens leert van zijn fouten. Ik heb in mijn leven heel veel geleerd.
  • MJ de Bruijn
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
function Solar_Make_Forecasts()
  // Calculate Solar Forecast per QH
  Add_Trace(Prog_ID, NewLine + "Solar_Make_Forecasts..." + NewLine);
  for (let q = 0; q <= 95; q++)
    if ( QH_Ct [ q ] <= PV_Turn_Off_Price_LimitCt )
      // When the panels are off because of price
      // charge from Grid to the max.
      // So emulate max Solar.
      Solar_Today_Wh +=
        (SolarEdge_Production_Limit_W / 4);
    else
      Solar_Today_Wh += Solar_Forecast_Modified [ q ];
  Solar_Today_Wh = Round( Solar_Today_Wh, -2);
  if ( context.Last_Solar_Today_Wh != Solar_Today_Wh )
    Add_Trace(Prog_ID, "  Solar Today: "
      + WhToText(Solar_Today_Wh) + NewLine);
    context.Last_Solar_Today_Wh = Solar_Today_Wh;
  Add_Trace(Prog_ID, "Solar Forecast Remain..." + NewLine);
  for (let q = NowQH; q <= 95; q++)
    if (q == NowQH)
        Solar_Forecast_Modified [ q ] * Quarter_Remain_Factor();
    else
      Solar_Remain_This_QH_Wh = Solar_Forecast_Modified [ q ];
    Solar_Remain_Today_Wh += Solar_Remain_This_QH_Wh;
    if ( Is_Negative_Price(q) )
      Solar_Remain_Negative_Price_Wh += Solar_Remain_This_QH_Wh;
    else if ( Is_Zero_Price(q) )
      Solar_Remain_Zero_Price_Wh += Solar_Remain_This_QH_Wh;
    else if ( Is_Very_Low_Price(q) )
      Solar_Remain_VeryLow_Price_Wh += Solar_Remain_This_QH_Wh;
    else if ( Is_Low_Price(q) )
      Solar_Remain_Low_Price_Wh += Solar_Remain_This_QH_Wh;
    else if ( Is_High_Price(q) )
      Solar_Remain_High_Price_Wh += Solar_Remain_This_QH_Wh;
    else
      Solar_Remain_Rest_Price_Wh += Solar_Remain_This_QH_Wh;
  } // Next QuarterHour until midnight
  Solar_Remain_Today_Wh = Round( Solar_Remain_Today_Wh, -2);
  if ( context.Last_Solar_Remain_Today_Wh != Solar_Remain_Today_Wh )
    Add_Trace(Prog_ID, "  Solar Remain Today: "
      + WhToText(Solar_Remain_Today_Wh) + NewLine);
    let RowDelimiter = "  (price ";
    let EndDelimiter = "";
    if (Solar_Remain_Negative_Price_Wh > 0)
      Add_Trace(Prog_ID, RowDelimiter);
      Add_Trace(Prog_ID, "negative: ");
      Add_Trace(Prog_ID, WhToText(Solar_Remain_Negative_Price_Wh));
      RowDelimiter = ", ";
      EndDelimiter = ")" + NewLine;
    if (Solar_Remain_Zero_Price_Wh > 0)
      Add_Trace(Prog_ID, "zero: ");
      Add_Trace(Prog_ID, WhToText(Solar_Remain_Zero_Price_Wh));
    if (Solar_Remain_VeryLow_Price_Wh > 0)
      Add_Trace(Prog_ID, "very_low: ");
      Add_Trace(Prog_ID, WhToText(Solar_Remain_VeryLow_Price_Wh));
    if (Solar_Remain_Low_Price_Wh > 0)
      Add_Trace(Prog_ID, "low: ");
      Add_Trace(Prog_ID, WhToText(Solar_Remain_Low_Price_Wh));
    if (Solar_Remain_High_Price_Wh > 0)
      Add_Trace(Prog_ID, "high: ");
      Add_Trace(Prog_ID, WhToText(Solar_Remain_High_Price_Wh));
    if (Solar_Remain_Rest_Price_Wh > 0)
      Add_Trace(Prog_ID, "rest: ");
      Add_Trace(Prog_ID, WhToText(Solar_Remain_Rest_Price_Wh) );
    Add_Trace(Prog_ID, EndDelimiter);
    context.Last_Solar_Remain_This_QH_Wh = Solar_Remain_This_QH_Wh;
  Add_Trace(Prog_ID, "Solar Forecast "+  "\u03A3" + " Surplus..." + NewLine);
  for (let q = NowQH; q <= Sunset_QH; q++)
    if (q == NowQH)
        + Solar_Forecast_Modified [ q ] * Quarter_Remain_Factor()
        - Consump_Forecast_Wh [ q ] * Quarter_Remain_Factor();
    else
        - Consump_Forecast_Wh [ q ];
  Solar_Surplus_Today_Wh = Round( Solar_Surplus_Today_Wh, -2);
  if ( context.Last_Solar_Surplus_Today_Wh != Solar_Surplus_Today_Wh )
    Add_Trace(Prog_ID, "  Solar " + "\u03A3" + " Surplus Today: "
     + WhToText(Solar_Surplus_Today_Wh) + NewLine);
    context.Last_Solar_Surplus_Today_Wh = Solar_Surplus_Today_Wh;
  Add_Trace(Prog_ID, "Solar Forecast Tomorrow..." + NewLine);
  for (let q = 96; q < Solar_Forecast_Modified.length; q++)
    Solar_Tomorrow_Wh += Solar_Forecast_Modified [ q ];
  Solar_Tomorrow_Wh = Round( Solar_Tomorrow_Wh, -2);
  if ( context.Last_Solar_Tomorrow_Wh != Solar_Tomorrow_Wh )
    Add_Trace(Prog_ID, "  Solar Tomorrow: "
      + WhToText(Solar_Tomorrow_Wh) + NewLine);
    context.Last_Solar_Tomorrow_Wh = Solar_Tomorrow_Wh;
  DayAheadRule += "Solar remain: "
    + ", " + "\u03A3" + " Surplus: "
    + "; Tomorrow: "
  if (Solar_Corr_Factor != 1)
    DayAheadRule += " Corr: " + Round(Solar_Corr_Factor, 1) + ".";
} // Solar_Make_Forecasts
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
function Fill_Solar_By_Price()
  try
    DebugStep = "Fill Solar_By_Price";
    // Array Solar_By_Price will contain sets of three values
    // in order of price
    // The first is the QH
    // second is the Solar-Forecast of that QH
    // Third is the sum of Solar, up and including, to that point
    let Charge_Delta_Wh = 0;
    for (let i = 0; i < QH_By_Price.length; i++)
      let curQH = QH_By_Price[i][idx_QH]; // QuarterHour
      if (curQH < NowQH) { continue }
      if (curQH > 95) { continue } // only today
      let curPrice = QH_By_Price[i][idxcurPrice]; // This QuarterHour Price
      let curSolar = Solar_Forecast_Modified[curQH]; // Solar
      let curConsump = Consump_Forecast_Wh[curQH]; // Consumption
      if (curSolar > 0) {
        if (curQH == NowQH)
          Charge_Delta_Wh +=
            Round(Quarter_Remain_Factor() *
            Math.min( curSolar - curConsump,
                  Batt_Max_Charge_W / 4 ) );
        else
          Charge_Delta_Wh +=
            Round( Math.min(curSolar - curConsump,
        Solar_By_Price.push( [curQH, curSolar, Charge_Delta_Wh] );
        // Add_Trace(Prog_ID, "  " + curQH + ": "
        //  + CtToText(QH_Ct[curQH]) + ", "
        //  + WhToText(curSolar) + ", "
        //  + WhToText(curConsump)+ ", "
        //  + WhToText(Charge_Delta_Wh) + NewLine
      } // if Solar > 0
    } // for i --> All QH by price
    Add_Trace(Prog_ID, "  Solar_By_Price: "
      + Solar_By_Price.length + " items" + NewLine);
    DebugStep = "Solar_Delta_at_Sunset_Wh...";
    if (Solar_By_Price.length == 0)
    else
        Round(Solar_By_Price[Solar_By_Price.length-1][idxSolarDelta], -2);
    Add_Trace(Prog_ID, "  Solar_Delta_at_Sunset_Wh: "
      + WhToText(Solar_Delta_at_Sunset_Wh) + NewLine)
    DebugStep = "Trace";
    Add_Trace(Prog_ID, "qH, Price, Solar, Charge-delta " + NewLine);
    for (let q=0; q < Solar_By_Price.length; q++)
     Add_Trace(Prog_ID, QHToText(Solar_By_Price [ q ][idx_QH]) + ": "
       + CtToText(QH_Ct[Solar_By_Price [ q ][idx_QH]]) + ", "
       + WhToText(Solar_By_Price [ q ][idxcurSolar]) + ", "
       + WhToText(Solar_By_Price [ q ][idxSolarDelta]) + NewLine
  } // try
  catch (error)
    node.warn("Program: " + ProgName + NewLine
} // Fill_Solar_By_Price
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
function Battery_Calculate_Levels()
try
  // Calculate Expected Battery energy-levels
  // without charging from Grid
  DebugStep = "Start";
  Add_Trace(Prog_ID, "" + NewLine);
  Add_Trace(Prog_ID, "Battery_Calculate_Levels..." + NewLine);
  Batt_Full_Wh =
    Round(Batt_Capacity_Wh * SoC_Full_Perc / 100);
  Batt_Now_Wh =
    Round(Batt_Capacity_Wh * SoC_Now_Perc / 100);
  Batt_Free_Wh =
    Math.max(Batt_Full_Wh - Batt_Now_Wh, 0);
    Round(Batt_Capacity_Wh * SoC_Min_Manual_Perc / 100);
    Round(Batt_Capacity_Wh * SoC_Min_Bottom_Perc / 100);
  for (let q = 0; q < 192; q++)
    Batt_Forecast_Wh [ q ] = 0; // initialise
    Batt_Prognosis_Perc [ q ] = 0; // initialise
  DebugStep = "Batt_Forecast_Wh Now";
  Batt_Forecast_Wh[NowQH] =
    Math.min(Batt_Full_Wh, // full is full
    Round( Batt_Now_Wh
       + Solar_Forecast_Modified[NowQH] * Quarter_Remain_Factor()
       - Consump_Forecast_Wh[NowQH] * Quarter_Remain_Factor()
  DebugStep = "Batt_Forecast_Wh Future";
  for (let q = NowQH + 1; q < Solar_Forecast_Modified.length; q++)
    DebugStep = "Batt_Forecast_Wh " + QHToText(q);
        Round(Batt_Forecast_Wh [q-1]
         - Consump_Forecast_Wh [ q ] ) );
    // Add_Trace(Prog_ID, QHToText(q) + ": "
    //   + Batt_Forecast_Wh [q-1]
    //   + " + " + Solar_Forecast_Modified [ q ]
    //   + " - " + Consump_Forecast_Wh [ q ]
    //   + " = " + Batt_Forecast_Wh [ q ]
    //   + NewLine
  } // calculate Battery Forecast per QuarterHour
  global.set("Victron_MESS.Targets.Batt_Forecast", Batt_Forecast_Wh);
  DebugStep = "High and Low";
  let Batt_Low_Value = Batt_Forecast_Wh[NowQH];
  let Batt_Low_QH = Batt_Forecast_Wh.length;
  let Batt_Low_QH_Text = "";
  let Batt_High_Value = Batt_Forecast_Wh[NowQH];
  let Batt_High_QH = Batt_Forecast_Wh.length;
  let Batt_High_QH_Text = "";
  for (let q = Batt_Forecast_Wh.length; q >= NowQH; q--)
    if (Batt_Forecast_Wh [ q ] <= Batt_Low_Value)
      Batt_Low_Value = Batt_Forecast_Wh [ q ];
      Batt_Low_QH = q; // end of this Quarterhour
    if (Batt_Forecast_Wh [ q ] >= Batt_High_Value)
      Batt_High_Value = Batt_Forecast_Wh [ q ];
      Batt_High_QH = q; // end of this QuarterHour
  DebugStep = "Set Trace";
  Batt_Low_QH_Text = QHToText(Batt_Low_QH);
  Batt_High_QH_Text = QHToText(Batt_High_QH);
  if (context.Last_SoC_Min_Manual_Perc != SoC_Min_Manual_Perc)
    Add_Trace(Prog_ID, "  Batt Capacity: ");
    Add_Trace(Prog_ID, WhToText(Batt_Capacity_Wh) + NewLine);
    Add_Trace(Prog_ID, "  Batt Full: ");
    Add_Trace(Prog_ID, SoC_Full_Perc + "% (");
    Add_Trace(Prog_ID, WhToText(Batt_Full_Wh) + ")" + NewLine);
    Add_Trace(Prog_ID, "  Min Manual SoC: ");
    Add_Trace(Prog_ID, SoC_Min_Manual_Perc + "% (");
    Add_Trace(Prog_ID, WhToText(Batt_Min_Manual_Wh) + ")" + NewLine);
    Add_Trace(Prog_ID, "  Min Bottom SoC: ");
    Add_Trace(Prog_ID, SoC_Min_Bottom_Perc + "% (");
    Add_Trace(Prog_ID, WhToText(Batt_Min_Bottom_Wh) + ")" + NewLine);
    context.Last_SoC_Min_Manual_Perc = SoC_Min_Manual_Perc;
  if ( context.Last_SoC_Now_Perc != SoC_Now_Perc )
    Add_Trace(Prog_ID, "  SoC Now Perc: ");
    Add_Trace(Prog_ID, SoC_Now_Perc + "% (");
    Add_Trace(Prog_ID, WhToText(Batt_Now_Wh) + ")" + NewLine);
    Add_Trace(Prog_ID, "  Batt_Free: ");
    Add_Trace(Prog_ID, WhToText(Batt_Free_Wh) + NewLine);
    context.Last_SoC_Now_Perc = SoC_Now_Perc;
  if ( Round(context.Last_Batt_Low_Value / 100)
       != Round(Batt_Low_Value / 100) )
    Add_Trace(Prog_ID, "  Prognose Low: "
      + Batt_Low_QH_Text + ": "
      + WhToText(Batt_Low_Value) + NewLine);
    context.Last_Batt_Low_Value = Batt_Low_Value;
  if ( Round(context.Last_Batt_High_Value / 100)
       != Round(Batt_High_Value / 100))
    Add_Trace(Prog_ID, "  Prognose High: "
      + Batt_High_QH_Text + ": "
      + WhToText(Batt_High_Value) + NewLine);
    context.Last_Batt_High_Value = Batt_High_Value;
  // Find QH 'Horizon' that Battery can stay above
  // Minimum without charging from Grid
  // This is the last QH that can be used to find
  // High and Low QHs
  DebugStep = "Horizon";
  for (let q = NowQH; q < Solar_Forecast_Modified.length; q++)
    Forecast_Stay_Above_Minimum_QH = q-1; // previous QH is OK
    if (Batt_Forecast_Wh [ q ] < Batt_Min_Manual_Wh) {break}
  if (context.Last_Forecast_Stay_Above_Minimum_QH
    != Forecast_Stay_Above_Minimum_QH)
    Add_Trace(Prog_ID, "  Above minimum until: ");
    Add_Trace(Prog_ID, QHToText(Forecast_Stay_Above_Minimum_QH));
    Add_Trace(Prog_ID, "hr." + NewLine);
      = Forecast_Stay_Above_Minimum_QH;
  DebugStep = "Batt_Prognosis_Perc";
    Round(Batt_Forecast_Wh [ q ] / Batt_Full_Wh * 100);
} // try
catch (error)
} // Battery_Calculate_Levels
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
function Find_Solar_QH_To_Charge()
try
  // Sort Solar Forecast in order by DayAhead Price
  let Explain = "";
  DebugStep = "Find_Solar_QH_To_Charge";
        + DebugStep + "..."
        + NewLine);
  for (let i = 0; i < Solar_By_Price.length; i++)
    let curQH = Solar_By_Price[i][idx_QH]; // QuarterHour
    //let curQHAsText = QHToText(Solar_By_Price[i][idx_QHAsText]);
    let curSolarDelta = Solar_By_Price[i][idxSolarDelta];
    // This QuarterHour Price:
    let curPrice_Sell_Value = PriceToSellValue(QH_Ct[curQH], arguments.callee.name);
    if (Solar_By_Price[i][idxSolarDelta] > Batt_Free_Wh)
      Add_Trace(Prog_ID, "  Needed Charge Reached: "
        + QHToText(curQH) + "; "
        + curSolarDelta + " > " + Batt_Free_Wh
        + NewLine
      break;
     // Lowest Price:
    // let LowPrice = PriceToSellValue(QH_By_Price[0][idxcurPrice]);
    if ( curPrice_Sell_Value <= PV_Turn_Off_Price_LimitCt ) {
      Add_Trace(Prog_ID, "  Grid instead of Solar: "
        + curQHAsText
        + NewLine);
      Grid_QH_To_Charge.push(curQH);
    else {
      Solar_QH_To_Charge.push(curQH);
  DebugStep = "Finalize";
  if (context.Last_Solar_QH_To_Charge != Solar_QH_To_Charge)
    global.set("Victron_MESS.Targets.Solar_QH_To_Charge",
      Solar_QH_To_Charge);
    Explain += "  Solar_QH_To_Charge: ["
    let Delimiter = ","
    for (let i = 0; i < Solar_QH_To_Charge.length; i++)
      Explain += Delimiter + QHToText(Solar_QH_To_Charge[i]);
      Delimiter = ", ";
    Explain += "]" + NewLine;
    Add_Trace(Prog_ID, Explain);
    context.Last_Solar_QH_To_Charge = Solar_QH_To_Charge;
} // try
catch (error)
} // Find_Solar_QH_To_Charge
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
function Find_Grid_QH_To_Charge()
try
  DebugStep = "Determine the QHs for Grid Charge"
  Add_Trace(Prog_ID, "Find_Grid_QH_To_Charge..." + NewLine);
  let ScheduleType = 0; // No schedule
  DebugStep = "Battery prognose incl.Grid"
  Add_Trace(Prog_ID, DebugStep + NewLine);
  for (let q = 0; q < Batt_Forecast_Wh.length; q++)
    Batt_Forecast_Incl_Grid_Wh [ q ] = Batt_Forecast_Wh [ q ];
  for (let ScheduleType = 1; ScheduleType < 4; ScheduleType++)
    let CheckQHFirst = 0;
    let CheckQHLast = 0;
    DebugStep = "find needed charge per QH ";
    if (ScheduleType == 1)
      Add_Trace(Prog_ID, "- Until sunrise today" + NewLine )
      CheckQHFirst = NowQH;
      CheckQHLast = Math.min(Sunrise_QH + 16, 40);
      // margin to fill possible minimum until sun is enough
      // QH 40 = 10:00
    else if (ScheduleType == 2)
      Add_Trace(Prog_ID, "- Until sunset today" + NewLine)
      CheckQHLast = Sunset_QH;
    else if (ScheduleType == 3)
      Add_Trace(Prog_ID, "- Until sunrise tomorrow" + NewLine)
      CheckQHFirst = Sunset_QH + 1;
      CheckQHLast = Math.min(Sunrise_QH + 96 + 16, 136);
      // QH 136 = +10:00
    for (let CheckQH = CheckQHFirst; CheckQH <= CheckQHLast; CheckQH++)
      DebugStep = "ScheduleType for QH " + CheckQH + " is " + ScheduleType;
      let CurEnergy_Needed = 0;
      { // until sunrise today
        CurEnergy_Needed =
          Math.max(Batt_Min_Manual_Wh
              - Batt_Forecast_Incl_Grid_Wh[CheckQH],
            0);
      { // until sunset today
        if ( (Date.parse(GetNowTime("YYYY-MM-DD")) < Date.parse(Batt_SoC_Full_Time))
           && Date.parse(Batt_SoC_Full_Time) < Date.parse(Sunset_DateTime)
        {  // Battery was already Full once today
          Add_Trace(Prog_ID, "  Grid Until "
            + QHToText(CheckQH) + "hr: " + NewLine
            + "  Batt full: "
            + "  No More Grid Charge." + NewLine);
        else
          Batt_Forecast_Lowest = 99999;
          for (let q2 = CheckQH; q2 <= CheckQHLast; q2++)
              Math.min(Batt_Forecast_Lowest, Batt_Forecast_Wh [q2])
          CurEnergy_Needed =
             - Batt_Forecast_Lowest
             - Solar_Surplus_Today_Wh,
              0);
          Batt_Forecast_Highest = 0;
              Math.max(Batt_Forecast_Highest, Batt_Forecast_Wh [q2])
          CurEnergy_Needed =
                - Batt_Forecast_Highest
              0);
        // During day-time, charge only onze to full
        CheckQH = CheckQHLast;
      } // ScheduleType 2
      { // until sunrise tomorrow
        CurEnergy_Needed =
            0);
      DebugStep = "Find Charge-QHs for QH " + CheckQH;
        // QuarterHour
        let CandidateChargeQH = QH_By_Price[i][idx_QH];
        let CandidateChargeQHAsText = QH_By_Price[i][idx_QHAsText];
        let CandidateChargePrice = QH_By_Price[i][idxcurPrice];
        if (CandidateChargePrice < -98) { continue } // unknown price
        let CandidateChargePrice_Buy_Value =
          Round(PriceToBuyValue(CandidateChargePrice, arguments.callee.name), 2);
        // Lowest Price until now:
        let LowPrice =
          Round(PriceToBuyValue(QH_By_Price[0][idxcurPrice],
        if ( CandidateChargeQH < NowQH ) { continue } // already passed
        if ( CandidateChargeQH >= CheckQH ) { continue } // to late
        if ( CandidateChargeQH < CheckQHFirst) { continue }
        if ( CandidateChargeQH > CheckQHLast) { continue }
        if ( (Charge_Delta_Wh > 0)
          && (Charge_Delta_Wh > CurEnergy_Needed)
        { // other charges are enough
          Add_Trace(Prog_ID,  "  " + CandidateChargeQHAsText
            + ": Stop. Charge is enough; "
            + NewLine
            + "  Charge: " + WhToText(Charge_Delta_Wh)
            + "; Needed: " + WhToText(CurEnergy_Needed)
            + NewLine);
          break; // for i QH_By_Price
        DebugStep = "Here when Charge is not enough"
        if (PriceToSellValue(CandidateChargePrice) - PriceToBuyValue(LowPrice)
        { // these price(s) is/are to high to charge from grid
            + ": Price " + CtToText(CandidateChargePrice) + " to high."
            + NewLine );
          continue; // for i QH_By_Price
        else if (CurEnergy_Needed > 0)
          if ( Not(Grid_QH_To_Charge.includes(CandidateChargeQH)) )
              + WhToText(CurEnergy_Needed) + NewLine);
            Charge_Delta_Wh =
              Math.min(Round(Batt_Max_Charge_W / 4),
                Batt_Capacity_Wh
                - Batt_Forecast_Incl_Grid_Wh[CandidateChargeQH]) ;
            Grid_QH_To_Charge.push(CandidateChargeQH);
            Add_Trace(Prog_ID,  "  " + CandidateChargeQHAsText + ": "
              + CtToText(CandidateChargePrice) + ", "
              + "\u0394" + "=" + WhToText(Charge_Delta_Wh)
              + NewLine
            Batt_Forecast_Incl_Grid_Wh[CandidateChargeQH] += Charge_Delta_Wh;
            CurEnergy_Needed -= Charge_Delta_Wh
            for (let q2 = CandidateChargeQH+1;
                  q2 <  Batt_Forecast_Incl_Grid_Wh.length;
                  q2++)
            { // Increase all coming QH
              Charge_Delta_Wh =
                Math.max(0,
                  Math.min(Charge_Delta_Wh,
                    Batt_Capacity_Wh - Batt_Forecast_Incl_Grid_Wh [q2])
              Batt_Forecast_Incl_Grid_Wh [q2] += Charge_Delta_Wh;
            // Add_Trace(Prog_ID, "  " + QHToText(CandidateChargeQH) + ": "
            //   + "+" + Charge_Delta_Wh
            //   + " = " + Batt_Forecast_Incl_Grid_Wh[CandidateChargeQH]
            //   + NewLine);
          // Unicode escape Sigma "\u03A3"
          // Unicode escape Delta "\u0394"
        } // if Grid needed
        DebugStep = "After Add QH to load";
      } // All QHs
    } // for CheckQH all Batt Forecast
  } // All ScheduleTypes
  DebugStep = "Global.set and Trace"
  global.set("Victron_MESS.Targets.Grid_QH_To_Charge", Grid_QH_To_Charge);
  if (context.Last_Grid_QH_To_Charge != Grid_QH_To_Charge)
    Add_Trace(Prog_ID, "  Grid_QH_To_Charge: [");
    for (let i = 0; i < Grid_QH_To_Charge.length; i++)
      Add_Trace(Prog_ID, QHToText(Grid_QH_To_Charge[i]));
      if (i != Grid_QH_To_Charge.length-1)
        Add_Trace(Prog_ID, ", ");
    Add_Trace(Prog_ID, "]" + NewLine);
    context.Last_Grid_QH_To_Charge = Grid_QH_To_Charge;
  let Batt_Perc_Excl_Grid = []
  let Batt_Perc_Incl_Grid = []
    Batt_Perc_Excl_Grid [ q ] =
      Round(Batt_Forecast_Wh [ q ] / Batt_Capacity_Wh * 100) ;
    Batt_Perc_Incl_Grid [ q ] =
      Round(Batt_Forecast_Incl_Grid_Wh [ q ] / Batt_Capacity_Wh * 100) ;
  global.set("Victron_MESS.Targets.Batt_Perc_Excl_Grid", Batt_Perc_Excl_Grid);
  global.set("Victron_MESS.Targets.Batt_Perc_Incl_Grid", Batt_Perc_Incl_Grid);
} // try
catch (error)
    + "Step: " + DebugStep + NewLine
} // Find_Grid_QH_To_Charge
  • MJ de Bruijn
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
function Is_Negative_Price(p_QH)
  return ( IsInArrayOfSets(QH_Negative, [p_QH]) )
} // Is_Negative_Price
function Is_Zero_Price(p_QH)
  return ( IsInArrayOfSets(QH_Zero, [p_QH]) )
} // Is_Zero_Price
function Is_Very_Low_Price(p_QH)
  return ( IsInArrayOfSets(QH_VeryLow, [p_QH]) )
} // Is_Very_Low_Price
function Is_Low_Price(p_QH)
  return ( IsInArrayOfSets(QH_Low, [p_QH]) )
} // Is_Low_Price
function Is_Normal_Price(p_QH)
  return ( IsInArrayOfSets(QH_Normal, [p_QH]) )
} // Is_High_Price
function Is_High_Price(p_QH)
  return ( IsInArrayOfSets(QH_High, [p_QH]) )
} // Is_High_Price
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
function Find_Energy_To_Sell()
  DebugStep = "Find_Energy_To_Sell";
  let Explain = "";
  Add_Trace(Prog_ID, NewLine);
  Add_Trace(Prog_ID, "Find_Energy_To_Sell" + NewLine);
  let cur_Price = QH_Ct[NowQH];
  let cur_Price_conv = PriceToSellValue(cur_Price, DebugStep);
  // This is now available
  Energy_to_Sell_Wh =
    Round(Batt_Full_Wh * SoC_Now_Perc / 100);
  Add_Trace(Prog_ID, "  Current SoC: " + Energy_to_Sell_Wh + ";" + NewLine);
  // A minimum SoC  should remain
  Energy_to_Sell_Wh -=
    Round(Math.floor(Batt_Full_Wh * SoC_Min_Manual_Perc / 100));
  Add_Trace(Prog_ID,
    "  minus Minimum SoC: "
    + Round(Math.floor(Batt_Full_Wh * SoC_Min_Manual_Perc / 100) )
    + ";" + NewLine );
  // Also a minimum buffer should be maintained
  Energy_to_Sell_Wh -= Energy_to_Sell_Buffer_Wh;
  Add_Trace(Prog_ID, "  minus Buffer: " + Energy_to_Sell_Buffer_Wh + ";" + NewLine);
  // Minus Consumption this QH proportionally
  let Expected_Consumption =
    Round(Consump_Forecast_Wh[NowQH] * Quarter_Remain_Factor());
  Add_Trace(Prog_ID, "  minus consump this QH: " + Expected_Consumption + ";" + NewLine);
  Energy_to_Sell_Wh -= Expected_Consumption;
  // Plus Solar this QH proportionally
  let Expected_Solar =
    Round(Solar_Forecast_Modified[NowQH]
  Add_Trace(Prog_ID, "  plus Solar this QH: " + Expected_Solar + ";" + NewLine);
  Energy_to_Sell_Wh += Expected_Solar;
  // when there come no low prices, energy is needed for consumption
  Expected_Consumption = 0;
  Expected_Solar = 0;
  let lastQH = NowQH;
  for (let q = NowQH + 1; q < QH_Ct.length; q++)
    let than_Price = QH_Ct [ q ];
    let than_Price_conv = PriceToBuyValue(than_Price, DebugStep);
    if (cur_Price_conv > than_Price_conv + Sell_Price_Difference_LimitCt)
      // low enough for recharging
      break;
    else
      lastQH = q;
      Expected_Consumption += Consump_Forecast_Wh [ q ];
      Expected_Solar = Solar_Forecast_Modified [ q ];
  Add_Trace(Prog_ID, "  minus consump until "
    + QHToText(lastQH) + ": "
  // Value can't be negative
  Energy_to_Sell_Wh =
    Math.max(0, Energy_to_Sell_Wh);
  // Add_Trace(Prog_ID, Explain + NewLine);
  Add_Trace(Prog_ID, "  Balance Energy to Sell: "
    + Energy_to_Sell_Wh + NewLine);
} // Find_Energy_To_Sell
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
function Try_Rule_Smoke_Alarm()
  let Result = false;
  if (Smoke_Alarm != 0)
    DayAheadRule += " Smoke_Alarm.";
    SoC_Min_Target_Perc = SoC_Min_Manual_Perc;
    Max_Discharge_Current_Target_Perc = 0;
    Charge_Disable_Target = 1;
    Solar_Charger_Target = 4; // OFF
    SolarEdge_Target = 'Off';
    Result = true;
  } // There was Smoke_Alarm
  Add_Trace(Prog_ID, "Try_Rule_Smoke_Alarm: " + Result + NewLine);
  return Result;
} // Try_Rule_Smoke_Alarm
function Try_Rule_Grid_Lost_Alarm()
  let Result = false;
  if (Grid_Lost_Alarm != 0)
    DayAheadRule += " Grid_Lost_Alarm.";
    Batt_Max_Current_Solar_A = Batt_Current_Limit_A ;
    Result = true;
  } // There was Grid_Lost_Alarm
  Add_Trace(Prog_ID, "Try_Rule_Grid_Lost_Alarm: " + Result + NewLine);
  return Result;
} // Try_Rule_Grid_Lost_Alarm
function Try_Rule_DESS()
  let Result = false;
  if (DESS_Mode != 0)
    DayAheadRule += " DESS_Mode " + DESS_Mode + ".";
    // Batt_Max_Current_Grid_A = -1;
    // Batt_Max_Current_Solar_A = 0;
    Result = true;
  Add_Trace(Prog_ID, "Try_Rule_DESS: " + Result + NewLine
    + "  DESS_Mode: " + DESS_Mode + "." + NewLine);
  return Result;
} // Try_Rule_DESS
function Try_Rule_Finish_Charging()
  let Result = false;
  let Explain = "";
  Explain+= "  Grid_To_Battery_End_Time: "
    + context.Grid_To_Battery_End_Time
    + NewLine;
  if (StartInSeconds < context.Grid_To_Battery_End_Time)
    DayAheadRule += " Finish Charging.";
    // changed 31-10-2024. Previous SoC should be used
    SoC_Min_Target_Perc = context.Last_SoC_Min_Target_Perc;
    // changed 14-11-2024. Previous value should be used.
    Batt_Max_Current_Grid_A = context.Last_Batt_Max_Current_Grid_A;
    Result = true;
    Explain += "  SoC Target: " + SoC_Min_Target_Perc
      + "%; Max Current: " + Batt_Max_Current_Grid_A + "A"
      + NewLine;
  } // Finish Charging
  Add_Trace(Prog_ID, "Try_Rule_Finish_Charging: "
    + Result + NewLine + Explain);
  return Result;
} // Try_Rule_Finish_Charging
function Try_Rule_SoC_Below_Bottom()
  let Result = false;
  let Explain = "";
  // SoC is below ultimate minimum
  if (SoC_Now_Perc <= SoC_Min_Bottom_Perc)
    DayAheadRule += " SoC much to low ("
      + SoC_Now_Perc + "% <= " + SoC_Min_Bottom_Perc + "%).";
    Explain +=
      "  " + SoC_Now_Perc + "% <= " + SoC_Min_Bottom_Perc + "%.";
    SoC_Min_Target_Perc = SoC_Min_Bottom_Perc;
    // Charge at least several minutes
    if ( context.Grid_To_Battery_End_Time < StartInSeconds)
        StartInSeconds + Fish_Grid_Charge_Seconds;
    DayAheadRule += " Charge from Grid.";
    Result = true;
  } // SoC is below ultimate minimum
  else
    Explain +=
      "  " + SoC_Now_Perc + "% > " + SoC_Min_Bottom_Perc + "%.";
  Add_Trace(Prog_ID, "Try_Rule_SoC_Below_Bottom: "
  + Result + NewLine + Explain + NewLine);
  return Result;
} // Try_Rule_SoC_Below_Bottom
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
function Try_Rule_Buy()
  let DebugStep = "Start"
  let Result = false;
  let Explain = "";
try
  // Charge now to sell at high price
  let Surplus_Until_Sell_Wh = 0;
  let Next_Sell_QH = 0
  DebugStep = "Table lengths";
  if (QH_Buy.length == 0)
    Explain += '  QH_Buy is empty' + NewLine;
  else
    Explain += "  QH_Buy: "
      + QH_Buy.length + " items."
      + NewLine;
    Explain += '  Needed: '
      + WhToText(Batt_Now_Wh) + ' --> '
      + WhToText(Batt_Full_Wh) + NewLine;
  if (QH_Sell.length == 0)
    Explain += '  QH_Sell is empty' + NewLine;
  else
    Next_Sell_QH = QH_Sell[0][0];
    for (let q = NowQH; q < Next_Sell_QH; q++)
      if (q == NowQH)
      { // Add Remainder of current QH
        Surplus_Until_Sell_Wh +=
          Round( Solar_Forecast_Modified [ q ]
              * Quarter_Remain_Factor() );
        Surplus_Until_Sell_Wh -=
          Round( Consump_Forecast_Wh [ q ]
      else
        Surplus_Until_Sell_Wh += Solar_Forecast_Modified [ q ];
        Surplus_Until_Sell_Wh -= Consump_Forecast_Wh [ q ];
    } // scan QHs till Sell QH
    Explain += "  Solar Surplus "
      + QHToText(Next_Sell_QH) + ": "
      + WhToText(Surplus_Until_Sell_Wh) + NewLine;
  DebugStep = "Solar Surplus until Sell";
  if ( IsInArrayOfSets(QH_Buy, [NowQH]) )
    DebugStep = "Process QH " + NowQH;
    Explain += '  ' + NowQHAsText + ' is a Buy QH' + NewLine;
    DebugStep = "Calculate Result";
    if (Batt_Now_Wh >= Batt_Full_Wh - Surplus_Until_Sell_Wh)
      Result = false;
      Explain += '  Solar Surplus will be enough' + NewLine;
    else
      Result = true;
      DayAheadRule += " Start Buying.";
      SoC_Min_Target_Perc = SoC_Full_Perc;
      Batt_Max_Current_Grid_A = Batt_Current_Limit_A;
  else
    DebugStep = "Not a Buy QH";
    Result = false;
      + ' is not a Buy QH.' + NewLine;
  // Explain += "Unreliable" + NewLine;
  // Result = false;
  Add_Trace(Prog_ID, "Try_Rule_Buy: " + Result + NewLine);
catch (error)
    + "Error in " + arguments.callee.name + ":" + NewLine
return Result;
} // Try_Rule_Buy
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
function Try_Rule_Sell()
  let Result = false;
  let Explain = "";
try
  DebugStep = "QH_Sell";
  // possible discharge for high price
  // and charge later for low price
  Explain += "  QH_Sell: "
    + QH_Sell.length + " items."
    + NewLine;
  if ( QH_Sell.length == 0 )
    Result = false;
    Explain += '  QH_Sell is empty.' + NewLine;
  else if (IsInArrayOfSets(QH_Sell , [NowQH]) )
    Explain += '  '
      + NowQHAsText + ' is Sell QH.' + NewLine;
    if (Energy_to_Sell_Wh == 0)
      Result = false;
      Explain += '  No balance to sell' + NewLine;
    else
      Result = true;
      DayAheadRule += " Sell QH.";
  else
    Result = false;
    Explain += '  '
      + NowQHAsText + ' is not a Sell QH' + NewLine;
  DebugStep = "Result";
  if ( Result)
    // do not charge
    DayAheadRule += " Sell ";
    DayAheadRule += WhToText( Round(Energy_to_Sell_Wh, -1) );
    DayAheadRule += ", ";
    DayAheadRule += Round(QH_Ct[NowQH], 1);
    DayAheadRule += " ct.";
      -Math.max(200,
       Math.min(Grid_Setpoint_Limit_W,
         Round(Energy_to_Sell_Wh / Quarter_Remain_Factor() )
          ); // note the minus-sign: negative value
    Result = true;
  } // Discharge at High price for later Charge at Low price
  // Result = false;
  Add_Trace(Prog_ID, "Try_Rule_Sell: "
    + Result + NewLine
    + Explain);
  return Result;
catch (error)
} // Try_Rule_Sell
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
function Try_Rule_Is_Charge_QH() {
let Result = false;
let Explain = "";
try
  DebugStep = "Solar_QH_To_Charge";
  Explain += "  Solar_QH_To_Charge: "
    + Solar_QH_To_Charge.length + " items."
    + NewLine;
  if (context.Solar_Now_W <= 0 )
    Explain += "  No Solar Surplus." + NewLine;
  else if (Solar_QH_To_Charge.indexOf(NowQH) > -1)
    DayAheadRule += " Solar charge now.";
    Solar_To_Batt_Perc = Solar_Charge_Perc;
      Round( Solar_To_Batt_Perc / 100
         * context.Solar_Now_W
         / Batt_Max_Charge_Voltage_V);
    Result = true;
    Explain += "  Solar charge Now." + NewLine;
  else
  { // use only x% of Solar
    Solar_To_Batt_Perc = (100 - Solar_Charge_Perc);
    Explain += "  Use " + Solar_To_Batt_Perc + "% Solar." + NewLine;
  DayAheadRule += " Solar use " + Solar_To_Batt_Perc + "%.";
  DebugStep = "Grid_QH_To_Charge";
  Explain += "  Grid_QH_To_Charge: "
    + Grid_QH_To_Charge.length + " items."
    + NewLine;
  if ( context.Grid_To_Battery_Start_Seconds > 0)
    Explain += "  Grid_To_Battery_Start: "
    + TimestampTo_HH_MM_SS(context.Grid_To_Battery_Start_Seconds)
    + NewLine;
  if (Grid_QH_To_Charge.indexOf(NowQH) > -1)
    DayAheadRule += "; Grid charge QH.";
    Result = true;
    Explain += "  Grid charge Now." + NewLine;
    if (context.Grid_To_Battery_Start_Seconds == 0)
      context.Grid_To_Battery_Start_Seconds = StartInSeconds;
  else if (context.Grid_To_Battery_Start_Seconds >
    StartInSeconds - Finish_Grid_Charge_Seconds)
  { // charging should at least continue for several minutes
    DebugStep = "Finish Grid charge";
    DayAheadRule += "; Finish Grid charge";
    Result = true;
// node.warn(StartInSeconds);
// node.warn(context.Grid_To_Battery_Start_Seconds);
    Explain += "  Finisch Grid charge, "
      + toString( StartInSeconds - context.Grid_To_Battery_Start_Seconds )
      + " sec." + NewLine;
  else
    DebugStep = "No Grid charge QH";
    Explain += "  No Grid charge QH." + NewLine;
  Add_Trace(Prog_ID, "Try_Rule_Is_Charge_QH: " + Result
    + NewLine
    + Explain);
} // try
catch (error)
return Result;
} // Try_Rule_Is_Charge_QH
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
function Try_Rule_Use_Grid_Direct() {
let Result = false;
let Explain = "";
try
  DebugStep = "Try_Rule_Use_Grid_Direct - Index CurPrice";
  let curPrice_Direct_Value = PriceToDirectValue(QH_Ct[NowQH], DebugStep);
  // Direct use: No Conversion loss
  let idxCurPrice = PosInArrayOfSets(QH_By_Price, NowQH);
  Explain += "  curPrice: " + CtToText(QH_Ct[NowQH])
    + "; incl." + CtToText(curPrice_Direct_Value)
    + NewLine;
  if ( QH_Level[NowQH].toLowerCase() == "very_expensive" )
    Result = false; // do not use grid
    Max_Discharge_Current_Target_Perc = 100; // use battery
    Explain += "  Level: Very Expensive" + NewLine;
  else if ( QH_Level[NowQH].toLowerCase() == "expensive" )
   Explain += "  Level: Expensive" + NewLine;
  else if ( Is_High_Price(NowQH) == true )
    Explain += "  High price" + NewLine;
  else if ( Is_Normal_Price(NowQH) == true )
    Result = true; // use grid
    Max_Discharge_Current_Target_Perc = 0; // use grid
    Explain += "  Normal price" + NewLine;
  else if ( Is_Low_Price(NowQH) == true )
    Explain += "  Low price" + NewLine;
  else if ( Is_Very_Low_Price(NowQH) == true )
    Explain += "  Very Low price" + NewLine;
  else if ( Is_Zero_Price(NowQH) == true )
    Explain += "  Zero price" + NewLine;
  else if ( Is_Negative_Price(NowQH) == true )
    Explain += "  Negative price" + NewLine;
  else
    Explain += "  Not a high price" + NewLine;
  if ( Result == true)
    DayAheadRule += " Grid Direct.";
  DebugStep = "Try_Rule_Use_Grid_Direct - Set Target Discharge Current";
  Explain += "  Target Discharge Current: "
    + Max_Discharge_Current_Target_Perc + " %" + NewLine;
  Add_Trace(Prog_ID, "Try_Rule_Use_Grid_Direct: " + Result + NewLine
    + Explain);
} // try
catch (error)
return Result;
} // Try_Rule_Use_Grid_Direct
function Try_Rule_High_Price_Now()
  let Result = false;
  let Explain = "";
  Explain += "  QH_High: "
    + QH_High.length + " items."
    + NewLine;
  if ( Is_High_Price(NowQH) )
    Result = true;
    Explain += '  ' + NowQHAsText + ' is High QH.' + NewLine;
    DayAheadRule += " High Price.";
  else
    Result = false;
    Explain += '  '
      + NowQHAsText + ' is not a High QH' + NewLine;
    Result = true;
  } // Price is High
  Add_Trace(Prog_ID, "Try_Rule_High_Price_Now: " + Result
    + NewLine
    + Explain );
  return Result;
} // Try_Rule_High_Price_Now
function Try_Rule_SoC_Below_Minimum()
  let Result = false;
  if (SoC_Now_Perc < SoC_Min_Manual_Perc)
  { // SoC is below Manual minimum
    DayAheadRule += " SoC to low ("
      + SoC_Now_Perc + "<" + SoC_Min_Manual_Perc + "),";
    Result = true;
  } // SoC is below minimum
  Add_Trace(Prog_ID, "Try_Rule_SoC_Below_Minimum: " + Result + NewLine);
  return Result;
} // Try_Rule_SoC_Below_Minimum
function Try_Rule_No_Special_Price()
  let Result = false;
  // Default = no special price = Always True
  { // default keep minimal SoC
    DayAheadRule += " No special Price.";
    // Not higher than SoC_Min_Manual_Perc
    // But lower is allowed when Solar energy is enough
    // But not lower then SoC_Min_Bottom_Perc
    Batt_Max_Current_Grid_A = 0; // but not from Grid
    Result = true;
  } // No special price
  Add_Trace(Prog_ID, "Try_Rule_No_Special_Price: " + Result + NewLine);
  return Result;
} // Try_Rule_No_Special_Price
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
function Try_All_Rules()
let DebugStep = "Start";
try
  DebugStep = "Set Default Values";
  Add_Trace(Prog_ID, "Try_All_Rules..." + NewLine);
  // Start with default values
    Math.min(SoC_Min_Manual_Perc,
    Math.max(SoC_Now_Perc, SoC_Min_Bottom_Perc)
  // Default is max charge
  Batt_Max_Current_Grid_A = Math.min(EV_Charger_Grid_to_Batt_A,
                     Batt_Current_Limit_A );
  DebugStep = "Check Try_Rule_Smoke_Alarm";
  if ( Try_Rule_Smoke_Alarm() ) { return }
  DebugStep = "Check Try_Rule_Grid_Lost_Alarm";
  if ( Try_Rule_Grid_Lost_Alarm() ) { return }
  DebugStep = "Check Try_Rule_DESS";
  if ( Try_Rule_DESS() ) { return }
  if ( Try_Rule_SoC_Below_Bottom() ) { return }
  DebugStep = "Check Try_Rule_Buy";
  if ( Try_Rule_Buy() ) { return }
  DebugStep = "Check Try_Rule_Sell";
  if ( Try_Rule_Sell() ) { return }
  DebugStep = "Check Try_Rule_Is_Charge_QH";
  if ( Try_Rule_Is_Charge_QH() ) { return }
  DebugStep = "Check Try_Rule_High_Price_Now";
  if ( Try_Rule_High_Price_Now() ) { return }
  DebugStep = "Check Try_Rule_Use_Grid_Direct";
  if ( Try_Rule_Use_Grid_Direct() ) { return }
  DebugStep = "Check Try_Rule_SoC_Below_Minimum";
  if ( Try_Rule_SoC_Below_Minimum() ) { return }
  DebugStep = "Check Try_Rule_Finish_Charging";
  if ( Try_Rule_Finish_Charging() ) { return }
  DebugStep = "Check Try_Rule_No_Special_Price";
  if ( Try_Rule_No_Special_Price() ) { return }
  DebugStep = "After Check All Rules";
  Add_Trace(Prog_ID, "No Rule matched." + NewLine)
  Add_Trace(Prog_ID, "Try_All_Rules done." + NewLine); // Now all Rules are evaluated
} // try
catch (error)
} // Try_All_Rules
function Price_Limit_Turn_Off_Solar()
  Add_Trace(Prog_ID, "  Price_Limit_Turn_Off_Solar..." + NewLine);
  Result = false;
  if ( QH_Ct[NowQH] <= PV_Turn_Off_Price_LimitCt )
    DayAheadRule += " Price Limit: Solar Off.";
    // Load maximal from Grid
    Result = true;
  Add_Trace(Prog_ID, "  Solar Turn Off: " + Result + NewLine);
  return Result;
} // Price_Limit_Turn_Off_Solar
function Set_Temperature_Limit_Factor()
  Add_Trace(Prog_ID, "  Set_Temperature_Limit_Factor..." + NewLine);
  let HighTemp = Math.max(Multiplus_II_1_Temp,
              Multiplus_II_2_Temp,
              Multiplus_II_3_Temp);
  if (HighTemp < 35)
  else if (HighTemp > 45)
    context.Temperature_Limit_Factor = 0.5;
  else
      Round(0.5 + (45 - HighTemp) * 0.05, 2);
  if (context.Temperature_Limit_Factor !=
    context.last_Temperature_Limit_Factor)
    Add_Trace(Prog_ID, "  Temperature Limit Factor: "
      + context.Temperature_Limit_Factor + NewLine);
      context.Temperature_Limit_Factor;
  if (context.Temperature_Limit_Factor != 1)
    DayAheadRule += " Temp factor: " + context.Temperature_Limit_Factor + ".";
} // Set_Temperature_Limit_Factor
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
function Set_Targets()
  Add_Trace(Prog_ID, "Set_Targets..." + NewLine);
  Price_Limit_Turn_Off_Solar();
  Set_Temperature_Limit_Factor();
  // Set_Solar_Batt_Current();
  if ( Batt_Max_Current_Grid_A == 0 )
    DayAheadRule += " No Grid charge.";
  if ( context.Solar_Now_W == 0 )
    DayAheadRule += " No Solar Surplus.";
  else if ( Batt_Max_Current_Solar_A == 0 )
    DayAheadRule += " No Solar charge.";
  // Maximum speed to charge battery
  context.Batt_Max_Current_Target_A =
         Batt_Current_Limit_A ,
         Batt_Max_Current_Grid_A + Batt_Max_Current_Solar_A);
    Round(context.Temperature_Limit_Factor
        * context.Batt_Max_Current_Target_A);
  // if (Max_Discharge_Current_Perc != null)
  //   Max_Discharge_Current_Target_Perc = Max_Discharge_Current_Perc;
  if (Grid_Setpoint_Unload_W == 0)
  { Grid_Setpoint_Target_W = Grid_Setpoint_Manual_W;
  else
    Grid_Setpoint_Unload_W + context.Solar_Now_W;
  DayAheadRule = DayAheadRule.trim(); // remove spaces
  Add_Trace(Prog_ID, "  DayAheadRule: " + DayAheadRule + NewLine);
  if (context.Last_SoC_Min_Target_Perc != SoC_Min_Target_Perc)
    Add_Trace(Prog_ID, "  SoC_Min_Target_Perc: "
      + SoC_Min_Target_Perc + "%" + NewLine);
    context.Last_SoC_Min_Target_Perc = SoC_Min_Target_Perc;
  if (context.Last_Grid_Setpoint_Target_W != Grid_Setpoint_Target_W)
    Add_Trace(Prog_ID, "  Grid Setpoint Target: "
      + Grid_Setpoint_Target_W + " W" + NewLine);
    context.Last_Grid_Setpoint_Target_W = Grid_Setpoint_Target_W;
  if (context.Last_Max_Discharge_Current_Target_Perc
        != Max_Discharge_Current_Perc)
    Add_Trace(Prog_ID, "  Max_Discharge_Current: "
      + Max_Discharge_Current_Target_Perc + " %" + NewLine);
  if (context.Last_Batt_Max_Current_Grid_A != Batt_Max_Current_Grid_A)
    Add_Trace(Prog_ID, "  Batt Max Current Grid: "
      + Batt_Max_Current_Grid_A + " A" + NewLine);
    context.Last_Batt_Max_Current_Grid_A = Batt_Max_Current_Grid_A;
  if (context.Last_Batt_Max_Current_Solar_A != Batt_Max_Current_Solar_A)
    Add_Trace(Prog_ID, "  Batt Max Current Solar: "
      + Batt_Max_Current_Solar_A + " A" + NewLine);
    context.Last_Batt_Max_Current_Solar_A = Batt_Max_Current_Solar_A;
  if (context.Last_Batt_Max_Current_Target_A != context.Batt_Max_Current_Target_A)
    Add_Trace(Prog_ID, "  Batt Max Current Target: "
      + context.Batt_Max_Current_Target_A + " A" + NewLine);
    context.Last_Batt_Max_Current_Target_A = context.Batt_Max_Current_Target_A;
  if (context.Last_Charge_Disable_Target != Charge_Disable_Target)
    Add_Trace(Prog_ID, "  Charge Disable: "
      + Charge_Disable_Target + NewLine);
    context.Last_Charge_Disable_Target = Charge_Disable_Target;
  if ( (context.Last_Solar_Charger_Target != Solar_Charger_Target)
    || ( (context.Solar_Now_W > 0)
    && (Solar_Charger_Target != 1) )
    if (Solar_Charger_Target == 1) {
      Add_Trace(Prog_ID, "  Solar Charger: On" + NewLine);
    else {
      Add_Trace(Prog_ID, "  Solar Charger: Off" + NewLine);
    context.Last_Solar_Charger_Target = Solar_Charger_Target;
  if ( (context.Last_SolarEdge_Target != SolarEdge_Target)
    && (SolarEdge_Target != 'On') )
    if (SolarEdge_Target == 'On') {
      Add_Trace(Prog_ID, "  SolarEdge: On" + NewLine);
    else {
      Add_Trace(Prog_ID, "  SolarEdge: Off" + NewLine);
    context.Last_SolarEdge_Target = SolarEdge_Target;
  global.set("Victron_MESS.Targets.Batt_Perc", Batt_Prognosis_Perc);
  Add_Trace(Prog_ID, "Set_Targets done" + NewLine);
} // Set_Targets
function Create_Return_Messages()
  if ( (context.Last_DayAheadRule.substr(7) != (DayAheadRule).substr(7))
    || (context.Deploy_End_Time > StartInSeconds) )
    Add_Trace(Prog_ID, "Create Return Messages..." + NewLine);
    msg_DayAhead_Rule =
      { topic: "DayAhead_Rule",
      payload: DayAheadRule.substring(0.255) };
    context.Last_DayAheadRule = DayAheadRule;
  if ( (context.Batt_Max_Current_Target_A != Batt_Max_Charge_Current_A)
      { topic: "Batt_Max_Current_Target_A",
      payload: context.Batt_Max_Current_Target_A };
  if ( (SoC_Min_Target_Perc != SoC_Min_Venus)
      { topic: "SoC_Min_Target_Perc", payload: SoC_Min_Target_Perc };
  if ( (Grid_Setpoint_Target_W != Grid_Setpoint_W)
      { topic: "Grid_Setpoint_Target_W", payload: Grid_Setpoint_Target_W };
  if  ((Max_Discharge_Current_Target_Perc != Max_Discharge_Current_Perc)
      { topic: "Max_Discharge_Current_Target_Perc",
      payload: Max_Discharge_Current_Target_Perc };
  if ( (Charge_Disable_Target != Charge_Disable)
      { topic: "Charge_Disable_Target", payload: Charge_Disable_Target };
  if (( Solar_Charger_Target != Solar_Charger)
      { topic: "Solar_Charger_Target", payload: Solar_Charger_Target };
  if (( SolarEdge_Target != SolarEdge_Production)
    // node.warn(SolarEdge_Production + " --> " + SolarEdge_Target );
      { topic: "SolarEdge_Target", payload: SolarEdge_Target };
  if ( context.TargetsTrace == true )
    msg_HA_Email =
      { topic: "Victron MESS - TargetsTrace",
      payload: "" };
    let curTraceText = global.get("Trace." + Prog_ID);
    let TempText = ""
    for (let i = 0; i < curTraceText.length ; i++)
      TempText += curTraceText[i].trimEnd();
    msg_HA_Email.payload = TempText;
    msg_HA_Email.priority = true;
  msg_Dummy =
      { topic: "Dummy", payload: "Reset Node.Statusses" };
} // Create_Return_Messages
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
// S T A R T   O F   T H E   P R O G R A M
switch (msg.topic) {
  case "RunNow":
  context.RunNow = true;
  context.TargetsTrace = false;
  msg = null;
  break;
  case "Trace":
  context.TraceOn = true;
  msg = null;
  break;
  case "TargetsTrace":
  context.TargetsTrace = true;
  // node.warn("TargetsTrace request received");
  msg = null;
  break;
  default:
    node.error("Unknown Topic: " + msg.topic
    + " Payload: " + msg.payload);
} // switch for input all variables
if (context.RunNow == true)
  Add_Trace(Prog_ID, "RunNow..." + NewLine);
  context.RunNow = false; // don't repeat until next launch
  // if ( (context.TraceOn) || (HA_Email_Request > "") )
  if ( (context.TraceOn == true) || (context.TargetsTrace == true) )
    Clear_Context_Last(); // full Trace
  // SolarEdgeSetProductionState();
  Solar_Make_Forecasts();
  Fill_Solar_By_Price();
  Battery_Calculate_Levels();
  Find_Solar_QH_To_Charge();
  Find_Grid_QH_To_Charge();
  Find_Energy_To_Sell();
  Try_All_Rules();
  Set_Targets();
  Create_Return_Messages();
  Add_Trace(Prog_ID, "node status" + NewLine);
  node.status({fill:"green",shape:"dot",
         text: "@ " + NowTime + ": "
         + "Min.SoC: " + SoC_Min_Target_Perc + "%; "
         + Batt_Max_Current_Grid_A + " + "
         + Batt_Max_Current_Solar_A + " Amp ("
         + Solar_To_Batt_Perc + "%)"}
  Add_Trace(Prog_ID, "node send" + NewLine);
  node.send(msg_DayAhead_Rule);
  node.send(msg_Batt_Max_Current_Target_A);
  node.send(msg_SoC_Min_Target_Perc);
  node.send(msg_Grid_Setpoint_Target_W);
  node.send(msg_Max_Discharge_Current_Target_Perc);
  node.send(msg_Charge_Disable_Target);
  node.send(msg_Solar_Charger_Target);
  node.send(msg_SolarEdge_Target);
  node.send(msg_HA_Email);
  node.send(msg_Dummy);
  node.done();
  Add_Trace(Prog_ID, "node.send done" + NewLine);
  Add_Trace(Prog_ID, "Program end" + NewLine);
  if (ErrorText > "") {
    node.warn(ErrorText);
  if ( context.TraceOn )
    let curTraceText = global.get("Trace." + Prog_ID );
    for (let i = 0; i < curTraceText.length; i++ )
      node.warn(curTraceText[i]);
    context.TraceOn = false;
} // if context.RunNow
  • MJ de Bruijn
  • Registratie: November 2016
  • Laatst online: 08:59
Zonnepanelen - uitzetten of moduleren?
Op moment van schrijven is het afschaffen van de salderingsregeling dichtbij. Voor sommige gebruikers is dit zelfs al actueel als de vervaldatum van je contract ongunstig valt, bijvoorbeeld rond 1 oktober. Dan kun je de energiebelasting van de donkere maanden niet meer verrekenen met productie in het volgende lichte seizoen.
Het werd dus interessant om eens te kijken of mijn huidige strategiën nog wel optimaal zijn.
Ik heb (onder andere) gekeken hoe zinvol het is om terug te leveren. Eerder was dat nauwelijks een issue. Zelf bij flink negatieve netto prijzen was het altijd nog wel interessant om de saldering te pakken. Dat wordt nu anders. Niet alleen krijg je de saldering niet meer terug, je moet zelfs kosten betalen voor terugleveren.
Ik heb een variabel contract bij Tibber. Daar wordt tegenwoordig 2,48 cent kosten berekend (per kwh) voor terugleveren. Dus bij een netto prijs onder +2,48 cent (jawel plus) kost terugleveren je al geld. Bij negatieve stroomprijzen kun je de zonnepanelen uitschakelen, maar dan moet je de energie van het net inkopen, dat is nog duurder. Of je moet de stroom uit je batterij gebruiken. Maar misschien moet je batterij nog wel worden opgeladen. Als de zonnepanelen meer produceren dan de batterij kan absorberen is er overschot en dat gaat het net in en dat kost dus geld.
Kortom, tijd voor wat programmeer-werk.
Mijn zonnepanelen worden bediend door een SolarEdge systeem. SolarEdge heeft een fraaie optie om de productie te kunnen reguleren. Er zijn 16 stappen beschikbaar die je zelf kunt instellen. Dus naast helemaal uit en helemaal aan zijn er nog 14 mogelijkheden om de productie nauwkeurig te beperken.
Mijn strategie is als volgt: Ik bereken wat 'het huis' verbruikt (consumptie). Dat verhoog ik met de actuele laadstroom van de batterij. Dit samen is wat de zonnepanelen minimaal moeten leveren. Ik zoek de dichtstbijzijnde stap in de regulering van SolarEdge waarbij ik naar boven afrond. Er moet altijd iets meer geproduceerd worden dan verbruikt omdat terugleveren van het overschot nét iets minder duur is dan inkopen van eventueel tekort.
Het programma kijkt iedere twee seconden naar het actuele verbruik en stelt de SolarEdge direct bij indien er meer verbruikt wordt, bijvoorbeeld als de waterkoker aan gaat. Het terugregelen doe ik in stapjes met een vertraging van steeds 10 seconden.
Al met al blijft de zonne-productie steeds net boven het huisverbruik zodat de teruglevering (met kosten) minimaal is, afname van het net (met nog meer kosten) vrijwel nihil is en de batterij nog kan worden opgeladen van je 'eigen' zonnestroom.
Voor de aansturing van de SolarEdge gebruikt ik de "Victron GX IO-Extender 150"
Voor de aansluiting op de SolarEdge zie: SolarEdge - Power Reduction Control met ESP8266
  • Rimco
  • Laatst online: 16:45
Rimco
Lekker duurzaam, denk ik
@MJ de Bruijn Zit het huis incl. PV op AC-out?
PV: 49 kWp | ZB: 8kWp | WPs: 3x Pana 7J + Pana 5J + Nibe Savent + Vaillant aroSTOR + Samsung DVM S (L/L) | ESS: 90kWh/24kW + 30kWh/12kW
  • MJ de Bruijn
Rimco schreef op vrijdag 17 juli 2026 @ 22:38:
Mijn 'kritieke' gebruikers zitten op AC-OUT.
Mijn 'niet-kritieke' gebruikers (wasmachine, droger, oven) zitten op AC-IN.
En de SolarEdge zit ook op AC-OUT i.v.m. off-grid gebruik.
  • MJ de Bruijn
NTS schreef op vrijdag 17 juli 2026 @ 22:19:
Heb je dan meer PV opwek dan wat je batterijen kunnen verwerken? Want dat geeft sowieso uitdagingen in eilandbedrijf door de 1:1 regel? Of bedoel je als de batterijen bijna vol zijn dat je je PV niet meer kwijt kunt?
Ik heb inderdaad (ruim) meer PV opwek dan mijn batterij kan verwerken.
En ja, bij eilandbedrijf kan het dan snel mis gaan. Als de batterij boven 80% SoC komt neemt de opname capaciteit al (snel) af.
Ik gebruik de methode van moduleren (voor SolarEdge 'throttle') dus ook in een off-grid situatie.
Lees voor een toelichting SoC 80%, 90% in "Het grote Victron Off-Grid topic"
en Testen Off-Grid gebruik Victron in "Het grote Victron Off-Grid topic"
  • Rimco
Rimco
MJ de Bruijn schreef op zaterdag 18 juli 2026 @ 09:05:
Ok, dan wordt het lastiger. Want als alles op AC-out zit zou je los kunnen koppelen van het net om een perfecte NOM te regelen.
  • gys4tweakers
  • Registratie: Juli 2023
  • Laatst online: 23-10 19:17
Mijn complimenten voor de uitgebreide uitwerking van een m.i. logische aansturing.
Ik probeer al bijna een jaar naar een vergelijkbare functionele besturing te komen. Ik heb 25kWh batterij met 3300Wp solar en een Tibber contract en verwarm met een warmtepomp (binnenkort all-electric). De solar krijgt deze accu nooit op 100% SOC
Ik heb beginners kennis van Node Red en ben met jou instructies al flink opgeschoten. Waar ik nu vast loop is het bouwen van de flow High&Low en de laatste flow Targets. Zou jij deze als json kunnen publiceren?
Daarnaast is mij nog niet geheel duidelijk welke van alle uitgewerkte flows nodig zijn om tot een werkende besturing te komen volgens de laatse versie (Tibber kwartier prijzen). Misschien wil jij hiervan een opsomming delen.
  • MJ de Bruijn
gys4tweakers schreef op maandag 28 september 2026 @ 08:18:
Ik probeer te begrijpen waarom je dit noemt. Is dit omdat je zonnepanelen niet voldoende produceren? Daar kan ik niets aan doen.
Of, stopt het laden bij een lager percentage? Dat kan een verschil zijn in de berekening van een eigen BMS van de batterij en de berekening van Victron. Bij mij zit daar ook altijd een paar procent tussen.
De functie High & Low is bedoeld om de hoogste en laagste prijzen te vinden per kwartier en om te bepalen of er verkocht moet worden.
Ik heb deze HIER gepubliceerd.
Volgens mij bedoel je DIT.
Bij mij hangt alles samen. Ik gebruik veel tabellen die soms op de ene plaats en soms op de ander plaats worden aangemaakt.
Ik kan niet bepalen welk deel jij gebruikt en wat niet. Sorry daarvoor.
P.S. Publiceren als JSON is technisch niet mogelijk. Dit forum staat een maximum aantal tekens per bijdrage toe. Dat is veel minder dan de lengte van een JSON bestand.
[ Voor 9% gewijzigd door MJ de Bruijn op 28-09-2026 14:24 ]
  • gys4tweakers
MJ de Bruijn schreef op maandag 28 september 2026 @ 14:20:
Hier wil ik alleen maar aangeven dat ik (meestal) dagelijks moet bijladen uit het net, de solar dekt niet altijd het verbruik
Ik probeer deze functie na te bouwen en loop dan vast op mijn beperkte kennis, ik begrijp niet hoe de "link in"en "link out" moeten worden ingesteld, ook niet "Trace On" en de timer "After every QH"
Ook hier schiet mijn kennis te kort om dit na te bouwen vandaar de vraag of je dit stuk als json wilt vrijgeven
Ik heb nu de flow Solar, Tibber, Parameters, Targets, Flowstates en "HomeAssistant nagebouwd en gemodificeerd. Zonder de flow DayAhead worden de tabellen DayAhead_QH_Ct enQH_level gevuld. Daarmee ging ik er vanuit dat de oorspronkelijk flow DayAhead overbodig is geworden. Vandaar de vraag naar de opbouw flows die nog actueel zijn
Maar ik heb meerdere flows opgebouwd vanaf jou gepubliceerde (deel) json code. Dus ik dacht dan moet dat ook mogelijk zijn voor deze specifieke detail aanpassingen.
Ik dacht een deel-flow laat zich wel publiceren toch? Dan moet ik alleen nog de aanpassingen en de eventuele samenhang uitzoeken
Neemt niet weg dat ik dankbaar ben voor het werkt dat je hebt verzet en al flink op weg geholpen om de installatie volgens mijn wensen aan te sturen. De Victron DESS dekt namelijk niet de lading
[ Voor 7% gewijzigd door gys4tweakers op 03-10-2026 16:33 ]
  • gys4tweakers
waar moet je 'find high en low' het time commando 'After Every QH' mee koppelen?Afbeeldingslocatie: https://tweakers.net/i/FmWLE5Feyl1PzKRUhdfjSauigCo=/800x/filters:strip_exif()/f/image/VhbNbM2WGFd2w5FUyXIQ7kqb.png?f=fotoalbum_large
  • gys4tweakers
hehe een crontab timer "After Every QH"
[ Voor 27% gewijzigd door gys4tweakers op 17-10-2026 15:18 ]
  • MJ de Bruijn
Sorry dat ik zelf niet op je eerdere vraag heb gereageerd, ik was even medisch off-line.
Is je vraag/probleem nu opgelost?
  • gys4tweakers
MJ de Bruijn schreef op zondag 18 oktober 2026 @ 10:21:
Gezondheid gaat voor op alles.
Ik ben de programmering aan het omzetten naar mijn situatie. Had de afgelopen week weinig tijd om me verder te verdiepen.
Ik heb de flows solar, tiber en states nu werkend (mogelijk is states nog niet compleet). Mijn installatie is uitgerust met een mppt en het huis zit compleet op de AC-out. Als beginner is het dan best een klus om de code te begrijpen en waarnodig aan te passen.
Op dit moment ben ik bezig met de debug van "Monitor Consumption"en "Monitor MPPT". Hier loop ik tegen de waarschuwing "Unknown Topic: yz1solar_yield_today" resp. "Unknown Topic: yz1solar_Reading". Bij Consumption had ik yield-today geselecteerd, na wijzigen in yield since reset is de foutmelding weg.
Bij monitor MPPT verdwijnt de fout als ik bij yield_today selecteer "only changes"
In global context blijft de array yz1solar.Reading alles op 0 staan. Waar/hoe vul ik de array?
De volgende stap is dan de target flow na te lopen en aan te passen aan mijn situatie.
Onder flow targets zie ik nog een foutmelding voor functions "PriceToBuyValue", "PriceToDirectValue" en PriceToSellValue".
Er is nog werk aan de winkel.
  • gys4tweakers
De volgende functies leiden tot foutmelding onder Targets, "Calculate Targets":
Get_Functions:
Victron_MESS.Functions.PriceToBuyValue
Victron_MESS.Functions.PriceToDirectValue
Victron_MESS.Functions.PriceToSellValue
Onder "Parameters>SetGlobalFunctions"worden ze niet aangemaakt. Vraag is dan waar en met welke code maak ik deze aan?
Ook de inhoud van overige functies zoals "Only Day Ahead Rule" etc. in flow Targets heb ik nogf leeg. Wat moet er inhoudelijk in deze functies staan?
  • MJ de Bruijn
Naar aanleiding van de voorgaande vraag is het goed om recente wijzigingen te documenteren.
Ik heb de methode 'SetGlobalFunctions' vervangen door de functie 'MakeLoaders'.
MakeLoaders maakt (nog steeds) globale functies aan maar is ook in staat om (alle) variabelen uit een sectie van de Global geheugenruimte in een functie te laden.
Afbeeldingslocatie: https://tweakers.net/i/JoUx25ICjsHahTfX3MGzRxDYgRg=/800x/filters:strip_exif()/f/image/nRuyEtrNQbxrPO7vtXa0lsPq.png?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
        "id": "e0dfb9db0c37b271",
        "type": "subflow",
        "name": "Show",
        "info": "",
        "category": "",
        "in": [
                "x": 68,
                "y": 80,
                "wires": [
                        "id": "274fd352337bfbb9"
        "out": [
                "x": 364,
                "y": 64,
                "wires": [
                        "id": "274fd352337bfbb9",
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99",
        "status": {
            "x": 364,
            "y": 112,
            "wires": [
                    "port": 1
        "type": "function",
        "z": "e0dfb9db0c37b271",
        "name": "Show Payload",
        "func": "if ( (global.get( \"MESS.UseDebug\" ) || false) === false )\n{\n  if ( (context.get(\"StateIsClear\") || false) === true )\n    { \n      return [msg, null] \n    }\n  else\n    { \n      context.set(\"StateIsClear\", true);\n      return [msg, {topic:'', payload:{text:''}}] \n    }\n}\n\nconst Now = new Date();\nlet NowTime = (\"0\" + Now.getHours()).slice(-2) + \":\"\n                + (\"0\" + Now.getMinutes()).slice(-2) + \":\"\n                + (\"0\" + Now.getSeconds()).slice(-2) ;\n\ncontext.set(\"StateIsClear\", false)\nlet msgState = { topic:'state', \n             payload:\n             { text: NowTime + \": \" + msg.topic + \": \" + msg.payload,\n               shape: \"dot\",\n               fill: \"grey\"\n             }\n};\n\nnode.send( [msg, msgState] );\n\nnode.done();",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 208,
        "y": 80,
        "wires": [
        "id": "6e66bd5553496300",
        "type": "function",
        "z": "05f545a17b05a933",
        "name": "MakeLoaders",
        "func": "",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "// Code added here will be run once\n// whenever the node is started.\n\nthis.ProgName = \"MakeLoaders\"\nthis.Prog_ID = \"MakeLoaders\"\n",
        "finalize": "node.warn(this.ProgName + \" Cleanup...\");\n\nglobal.set(\"MESS.LastRun.Deploy\"); // remove\nglobal.set(\"MESS.Loaders\"); // remove\nglobal.set(\"MESS.Functions\"); // remove\nglobal.set(\"MESS.Param\");\n",
        "libs": [],
        "x": 368,
        "y": 864,
        "wires": [
                "168187c5aea578b5",
                "d6a71004f3a95346"
        "id": "4334cee68d6cbe3f",
        "type": "function",
        "name": "Make Consump",
        "func": "",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "this.ProgName = \"Make Consumption Forecast\"\nthis.Prog_ID = \"Consumption_Forecast\"\n",
        "finalize": "node.warn(this.ProgName + \" Cleanup...\");\n\nglobal.set(\"MESS.Consump.Forecast_Wh_QH\"); // remove\n",
        "libs": [],
        "x": 368,
        "y": 1056,
        "wires": [
                "5ba94da504c3e36e",
                "80d29df57812ec2c"
        "id": "c497c92850753308",
        "type": "inject",
        "name": "On Demand",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "0.3",
        "topic": "Delete Functions",
        "payload": "( $moment().format(\"YYYY-MM-DD HH:mm:ss\") )",
        "payloadType": "jsonata",
        "x": 150,
        "y": 816,
        "wires": [
                "a5615530580775b2"
        "id": "a264bda36682d6d8",
        "type": "inject",
        "name": "At Deploy",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": "0.1",
        "topic": "At Deploy",
        "x": 128,
        "y": 672,
        "wires": [
                "1ff901c044cad217",
                "91fc0c6b701d4568"
        "id": "aad492f80ec98c5c",
        "type": "cronplus",
        "name": "at 00:00:00",
        "outputField": "payload",
        "timeZone": "",
        "storeName": "",
        "commandResponseMsgOutput": "output1",
        "defaultLocation": "",
        "defaultLocationType": "default",
        "outputs": 1,
        "options": [
                "name": "schedule1",
                "topic": "AtMidnight",
                "expressionType": "cron",
                "expression": "0 0 0 * * * * ",
                "location": "",
                "offset": "0",
                "solarType": "all",
                "solarEvents": "sunrise,sunset"
        "x": 138,
        "y": 624,
        "wires": [
                "1ff901c044cad217",
                "91fc0c6b701d4568"
        "id": "91fc0c6b701d4568",
        "type": "change",
        "name": "Delete Trace",
        "rules": [
                "t": "delete",
                "p": "Trace",
                "pt": "global"
                "t": "set",
                "p": "MESS.Deploy.Delete_Trace",
                "pt": "global",
                "to": "( $moment().format(\"YYYY-MM-DD HH:mm:ss\") )",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 358,
        "y": 720,
        "wires": [
                "9f2c45a9b996b139",
                "1b802d69f16957bc"
        "id": "168187c5aea578b5",
        "type": "link out",
        "name": "link out Check Deploy is finished",
        "mode": "link",
        "links": [
            "8d9156004535a8ca"
        "x": 531,
        "y": 864,
        "wires": []
        "id": "5ba94da504c3e36e",
        "type": "link out",
        "mode": "link",
        "links": [
            "8d9156004535a8ca"
        "x": 531,
        "y": 1056,
        "wires": []
        "id": "9f2c45a9b996b139",
        "type": "link out",
        "mode": "link",
        "links": [
            "8d9156004535a8ca"
        "x": 533,
        "y": 720,
        "wires": []
        "id": "d6a71004f3a95346",
        "type": "subflow:e0dfb9db0c37b271",
        "name": "",
        "x": 338,
        "y": 912,
        "wires": [
                "3107422456d50542"
        "id": "80d29df57812ec2c",
        "name": "",
        "x": 338,
        "y": 1104,
        "wires": [
        "id": "1ff901c044cad217",
        "name": "",
        "x": 338,
        "y": 672,
        "wires": [
        "id": "a5615530580775b2",
        "type": "change",
        "name": "Delete Loaders/Functions/Consump",
        "rules": [
                "t": "delete",
                "p": "MESS.Deploy.Loaders_Ready",
                "pt": "global"
                "t": "delete",
                "p": "MESS.Loaders",
                "pt": "global"
                "t": "set",
                "p": "MESS.Deploy.Loaders_Deleted",
                "pt": "global",
                "tot": "jsonata"
                "t": "delete",
                "p": "MESS.Deploy.Consump_Ready",
                "pt": "global"
                "t": "delete",
                "p": "MESS.Consump",
                "pt": "global"
                "t": "set",
                "p": "MESS.Deploy.Consump_Deleted",
                "pt": "global",
                "tot": "jsonata"
                "t": "delete",
                "p": "MESS.Functions",
                "pt": "global"
                "t": "set",
                "p": "MESS.Deploy.Functions_Deleted",
                "pt": "global",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 432,
        "y": 816,
        "wires": [
                "6e66bd5553496300",
                "3086d316701879aa"
        "id": "1b802d69f16957bc",
        "type": "change",
        "name": "Delete MESS.Batt",
        "rules": [
                "t": "delete",
                "p": "MESS.Batt",
                "pt": "global"
                "t": "set",
                "p": "MESS.Deploy.Batt_All_Deleted",
                "pt": "global",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 378,
        "y": 768,
        "wires": [
                "a5615530580775b2"
        "id": "3107422456d50542",
        "type": "change",
        "name": "Set MESS.Param.EntsoeApiKey",
        "rules": [
                "t": "set",
                "p": "MESS.Param.EntsoeApiKey",
                "pt": "global",
                "to": "secret",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 422,
        "y": 960,
        "wires": [
                "dac188ac635c56ae"
        "id": "dac188ac635c56ae",
        "type": "change",
        "name": "Set MESS.Param.SolcastApiKey",
        "rules": [
                "t": "set",
                "p": "MESS.Param.SolcastApiKey",
                "pt": "global",
                "to": "secret",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 436,
        "y": 1008,
        "wires": [
                "4334cee68d6cbe3f"
        "id": "bf41e634f54e5afc",
        "type": "comment",
        "name": "Check if Deploy has finished",
        "info": "",
        "x": 648,
        "y": 752,
        "wires": []
        "id": "b47bb3bf3f463540",
        "type": "comment",
        "info": "",
        "x": 648,
        "y": 896,
        "wires": []
        "id": "ad7f7ad223aecbd8",
        "type": "comment",
        "info": "",
        "x": 648,
        "y": 1088,
        "wires": []
        "id": "cacffa090232d056",
        "type": "comment",
        "info": "",
        "x": 760,
        "y": 848,
        "wires": []
        "id": "3086d316701879aa",
        "type": "link out",
        "mode": "link",
        "links": [
            "8d9156004535a8ca"
        "x": 641,
        "y": 816,
        "wires": []
Afbeeldingslocatie: https://tweakers.net/i/2MhIKmF9Jm2WYPx_D6cZnEH_XxI=/800x/filters:strip_exif()/f/image/g63tEQXhORtyHKVhOdJclMPQ.png?f=fotoalbum_large
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
        "type": "subflow",
        "name": "Show",
        "info": "",
        "category": "",
        "in": [
                "x": 68,
                "y": 80,
                "wires": [
        "out": [
                "x": 364,
                "y": 64,
                "wires": [
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99",
        "status": {
            "x": 364,
            "y": 112,
            "wires": [
                    "port": 1
        "type": "function",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 208,
        "y": 80,
        "wires": [
        "id": "9439121f6be1fcec",
        "type": "subflow",
        "name": "Wait Deploy",
        "info": "",
        "category": "",
        "in": [
                "x": 60,
                "y": 48,
                "wires": [
                        "id": "0f54e83663e3c00e"
        "out": [
                "x": 628,
                "y": 96,
                "wires": [
                        "id": "4e711671b89ca482",
                        "port": 0
        "env": [],
        "meta": {},
        "color": "#DDAA99",
        "status": {
            "x": 628,
            "y": 144,
            "wires": [
                    "id": "ee1351bac2215a95",
                    "port": 2
                    "port": 1
        "id": "0f54e83663e3c00e",
        "type": "switch",
        "z": "9439121f6be1fcec",
        "name": "Deploy not Ready / Ready",
        "property": "MESS.Deploy.Ready",
        "propertyType": "global",
        "rules": [
                "t": "null"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 226,
        "y": 48,
        "wires": [
                "ee1351bac2215a95"
                "4e711671b89ca482"
        "type": "function",
        "name": "Push to Queue",
        "func": "let msgQueueName = null;\n\nif (context.get(\"QueueName\") == null)\n{\n  let uniqueSubflowInstanceId =\n    env.get(\"NR_SUBFLOW_INSTANCE_ID\") || node.id;\n  uniqueSubflowInstanceId =\n    uniqueSubflowInstanceId.replace(/[^a-zA-Z0-9]/g, \"\");\n\n  context.set(\"QueueName\", \"$parent.\" + uniqueSubflowInstanceId); \n\n  // clear previous instance\n  flow.set(context.get(\"QueueName\"));\n\n  msgQueueName = {\n    topic: \"QueueName\",\n    payload: context.get(\"QueueName\")\n  }\n} // if QueueName = null\n\nlet Queue = flow.get(context.get(\"QueueName\")) || [];\nQueue.push(msg);\nflow.set(context.get(\"QueueName\"), Queue);\n\nlet msgState = {\n  topic: 'state',\n  payload: {\n    text: msg.topic + \": \" + msg.payload\n      + \"; \" + Queue.length + \" msgs pending\",\n    shape: \"dot\",\n    fill: \"blue\"\n  }\n};\n\nreturn [msg, msgQueueName, msgState];\n",
        "outputs": 3,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 464,
        "y": 48,
        "wires": [
                "4e711671b89ca482"
        "type": "function",
        "name": "Read Queue",
        "func": "let msgState = null;\n\nif (msg.topic == \"QueueName\") \n{\n  context.set(\"QueueName\", msg.payload);\n  return [null, null];\n}\n\nif (typeof context.get(\"QueueDone\") === \"undefined\")\n{\n  context.set(\"QueueDone\", false);\n}\n\nif ( (typeof context.get(\"QueueName\") !== \"undefined\")\n  && (context.get(\"QueueDone\") == false) )\n{\n  let Queue = flow.get(context.get(\"QueueName\")) || [];\n  for (let msgItem of Queue) \n  {\n    msgState = {\n      topic: 'state',\n      payload: {\n        text: msgItem.topic + \": \" + msgItem.payload,\n        shape: \"dot\",\n        fill: \"yellow\"\n      }\n    };\n\n    node.send( [msgItem, msgState] );\n  }\n  \n  // Clear Queue in memory]\n  flow.set(context.get(\"QueueName\"), null);\n\n  context.set(\"QueueDone\", true);\n} // QueueDone is false\n\nmsgState = {\n  topic: 'state',\n  payload: {\n    text: msg.topic + \": \" + msg.payload,\n    shape: \"dot\",\n    fill: \"green\"\n  }\n};\n\nreturn [msg, msgState];\n",
        "outputs": 2,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "context.set(\"QueueDone\", false);\n",
        "libs": [],
        "x": 458,
        "y": 112,
        "wires": [
        "id": "15280dc1293e4200",
        "type": "switch",
        "name": "Deploy Loaders is null",
        "property": "MESS.Deploy.Loaders_Ready",
        "rules": [
                "t": "null"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 372,
        "y": 1248,
        "wires": [
                "ea8e640ce08b8681"
                "140dcc445642cdb3"
        "id": "8d9156004535a8ca",
        "type": "link in",
        "name": "link in Check Deploy is finished",
        "links": [
            "3c8d72451cf3c95f",
            "168187c5aea578b5",
            "5ba94da504c3e36e",
            "9f2c45a9b996b139",
            "703fe186021ff7c6",
            "3086d316701879aa"
        "x": 145,
        "y": 1248,
        "wires": [
                "15280dc1293e4200",
                "966bb0807494a4ed"
        "id": "966bb0807494a4ed",
        "type": "subflow:9439121f6be1fcec",
        "name": "",
        "x": 342,
        "y": 1536,
        "wires": [
                "aff4769a148ef413",
                "643ba5457d5077e6"
        "id": "140dcc445642cdb3",
        "type": "switch",
        "name": "Deploy Consump is null",
        "property": "MESS.Deploy.Consump_Ready",
        "rules": [
                "t": "null"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 382,
        "y": 1296,
        "wires": [
                "fcf004566952b6e3"
                "4f26607a1d1ca070"
        "id": "ea8e640ce08b8681",
        "name": "",
        "x": 606,
        "y": 1248,
        "wires": [
        "id": "fcf004566952b6e3",
        "name": "",
        "x": 606,
        "y": 1296,
        "wires": [
        "id": "9b62af08049c44a8",
        "type": "debug",
        "name": "debug Deploy",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "topic & \" \" & payload",
        "targetType": "jsonata",
        "statusVal": "",
        "statusType": "auto",
        "x": 608,
        "y": 1488,
        "wires": []
        "id": "fa1c4030c38b4e37",
        "type": "link out",
        "name": "Link Out After Deploy is Ready",
        "mode": "link",
        "links": [
            "8de1257c814a90d9",
            "b4bf75cf2df3ef8b",
            "13fa55fc8b7732fc",
            "ffcd0aab2bf5ae1d",
            "6dc5f7ef3b76a593",
            "5e5f43dab4d29faa",
            "1682f0c29aa6fdc4",
            "6e8fe8fe286dc609"
        "x": 545,
        "y": 1440,
        "wires": []
        "id": "4f26607a1d1ca070",
        "type": "change",
        "name": "Set Deploy Ready",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Deploy Ready",
                "tot": "str"
                "t": "set",
                "p": "MESS.Deploy.Ready",
                "pt": "global",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 362,
        "y": 1344,
        "wires": [
                "d535b442595fc72d"
        "id": "5004a422e89f842c",
        "name": "",
        "x": 322,
        "y": 1440,
        "wires": [
                "fa1c4030c38b4e37",
                "966bb0807494a4ed",
                "9b62af08049c44a8"
        "id": "d535b442595fc72d",
        "type": "delay",
        "name": "",
        "pauseType": "rate",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "5",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 352,
        "y": 1392,
        "wires": [
                "5004a422e89f842c"
        "id": "2e4c1e080be2a4e5",
        "type": "change",
        "name": "Get MESS.Param",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Param",
                "tot": "str"
                "t": "set",
                "p": "target",
                "pt": "msg",
                "to": "MESS",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "MESS.Param",
                "tot": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 362,
        "y": 1600,
        "wires": [
                "cbe5c5d426009513"
        "id": "cbe5c5d426009513",
        "type": "link out",
        "name": "Link Out to HaNodeRed MQTT",
        "mode": "link",
        "links": [
            "8e1c3c8242995023"
        "x": 545,
        "y": 1600,
        "wires": []
        "id": "041bc434d2acb0a0",
        "type": "change",
        "name": "Get MESS.Consump.Consump_Forecast_Wh_QH",
        "rules": [
                "t": "set",
                "p": "topic",
                "pt": "msg",
                "to": "Consump_Forecast_Wh_QH",
                "tot": "str"
                "t": "set",
                "p": "target",
                "pt": "msg",
                "to": "MESS.Consump",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "MESS.Consump.Consump_Forecast_Wh_QH",
                "tot": "global"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 466,
        "y": 1648,
        "wires": [
                "bad32c2923ff3f07"
        "id": "bad32c2923ff3f07",
        "type": "link out",
        "mode": "link",
        "links": [
            "8e1c3c8242995023"
        "x": 545,
        "y": 1696,
        "wires": []
        "id": "aff4769a148ef413",
        "type": "link out",
        "name": "Link Out Call Set EV_Power defaults",
        "mode": "link",
        "links": [
            "5ec002b06846fa84"
        "x": 545,
        "y": 1536,
        "wires": []
        "id": "643ba5457d5077e6",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 180,
        "y": 1600,
        "wires": [
                "2e4c1e080be2a4e5",
                "2eb08b8db8bfcb5c"
        "id": "2eb08b8db8bfcb5c",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 180,
        "y": 1648,
        "wires": [
                "041bc434d2acb0a0"
        "id": "0ff6339d11d38670",
        "type": "comment",
        "name": "Set EVPower Defaults",
        "info": "",
        "x": 668,
        "y": 1536,
        "wires": []
        "id": "f7c6b5c1159007df",
        "type": "comment",
        "name": "Send to Home Assistant",
        "info": "",
        "x": 668,
        "y": 1600,
        "wires": []
        "id": "b096f5563c59c68d",
        "type": "comment",
        "info": "",
        "x": 668,
        "y": 1696,
        "wires": []
        "id": "b857cf919fcd231d",
        "type": "comment",
        "name": "Process States + Solar",
        "info": "",
        "x": 668,
        "y": 1440,
        "wires": []
        "id": "cb1770fd6685d4ac",
        "type": "comment",
        "name": "Link in Check if Deploy has finished",
        "info": "",
        "x": 188,
        "y": 1216,
        "wires": []
De functie 'MakeLoaders' plaats ik in de volgende post.
[ Voor 3% gewijzigd door MJ de Bruijn op 20-10-2026 12:30 ]
Een mens leert van zijn fouten. Ik heb in mijn leven heel veel geleerd.
  • MJ de Bruijn
Dit is de actuele functie MakeLoaders
Let op: Controleer altijd in de inhoudsopgave of er een meer recentere versie is geplaatst.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
791
792
793
794
795
796
797
798
799
800
801
802
803
804
805
806
807
808
809
810
811
812
813
814
815
816
817
818
819
820
821
822
823
824
825
826
827
828
829
830
831
832
833
834
835
836
837
838
839
840
841
842
843
844
845
846
847
848
849
850
851
852
853
854
855
856
857
858
859
860
861
862
863
864
865
866
867
868
869
870
871
872
873
874
875
876
877
878
879
880
881
882
883
884
885
886
887
888
889
890
891
892
893
894
895
896
897
898
899
900
901
902
903
904
905
906
907
908
909
910
911
912
913
914
915
916
917
918
919
920
921
922
923
924
925
926
927
928
929
930
931
932
933
934
935
936
937
938
939
940
941
942
943
944
945
946
947
948
949
950
951
952
953
954
955
956
957
958
959
960
961
962
963
964
965
966
967
968
969
970
971
972
973
974
975
976
977
978
979
980
981
982
983
984
985
986
987
988
989
990
991
992
993
994
995
996
997
998
999
1000
1001
1002
1003
1004
1005
1006
1007
1008
1009
1010
1011
1012
1013
1014
1015
1016
1017
1018
1019
1020
1021
1022
1023
1024
1025
1026
1027
1028
1029
1030
1031
1032
1033
1034
1035
1036
1037
1038
1039
1040
1041
1042
1043
1044
1045
1046
1047
1048
1049
1050
1051
1052
1053
1054
1055
1056
1057
1058
1059
1060
1061
1062
1063
1064
1065
1066
1067
1068
1069
1070
1071
1072
1073
1074
1075
1076
1077
1078
1079
1080
1081
1082
1083
1084
1085
1086
1087
1088
1089
1090
1091
1092
1093
1094
1095
1096
1097
1098
1099
1100
1101
1102
1103
1104
1105
1106
1107
1108
1109
1110
1111
1112
1113
1114
1115
1116
1117
1118
1119
1120
1121
1122
1123
1124
1125
1126
1127
1128
1129
1130
1131
1132
1133
1134
1135
1136
1137
1138
1139
1140
1141
1142
1143
1144
1145
1146
1147
1148
1149
1150
1151
1152
1153
1154
1155
1156
1157
1158
1159
1160
1161
1162
1163
1164
1165
1166
1167
1168
1169
1170
1171
1172
1173
1174
1175
1176
1177
1178
1179
1180
1181
1182
1183
1184
1185
1186
1187
1188
1189
1190
1191
1192
1193
1194
1195
1196
1197
1198
1199
1200
1201
1202
1203
1204
1205
1206
1207
1208
1209
1210
1211
1212
1213
1214
1215
1216
1217
1218
1219
1220
1221
1222
1223
1224
1225
1226
1227
1228
1229
1230
1231
1232
1233
1234
1235
1236
1237
1238
1239
1240
1241
1242
1243
1244
1245
1246
1247
1248
1249
1250
1251
1252
1253
// @ts-nocheck
// See On Start
// Daarin staat:
// this.ProgName = "MakeLoaders"
// this.Prog_ID = "MakeLoaders"
let NewLine = "\r\n";
global.set("MESS.Deploy.Loaders_Ready"); // remove
try {
  DebugStep = "Trace";
  const Trace = (p_ID, p_Text) =>
    if ( (global.get( "MESS.UseDebug" ) || false) === false ) { return null } ;
    const NewLine = "\n";
    let formattedText = p_Text;
    if (p_Text === "ClearTrace")
      formattedText = "ClearTrace";
    else if (Array.isArray(p_Text))
      // Toon type, lengte en inhoud van de Array
      formattedText = `Array(${p_Text.length})`;
    else if (typeof p_Text === 'object' && p_Text !== null)
      // Toon inhoud van het Object
      formattedText = `[Object]: ${JSON.stringify(p_Text)}`;
    else if (p_Text === null)
      formattedText = "null";
    else if (p_Text === undefined)
      formattedText = "undefined";
    else
      formattedText = String(p_Text);
    if (p_ID == null)
      node.warn("Trace: p_ID is null!");
      return null;
    let curTraceText = global.get("Trace." + p_ID);
    if (curTraceText == null)
      curTraceText = [""];
    let curTraceTextIndex = curTraceText.length - 1;
    if (formattedText === "ClearTrace")
      curTraceTextIndex = 0;
    else
    if ((curTraceText[curTraceTextIndex].length + formattedText.length) > 1000)
      curTraceText[curTraceTextIndex] += NewLine;
      curTraceTextIndex++;
      curTraceText[curTraceTextIndex] = formattedText;
    else
      curTraceText[curTraceTextIndex] += formattedText;
    global.set("Trace." + p_ID, curTraceText);
    return null;
  global.set("MESS.Functions.Trace", Trace);
  Trace(Prog_ID, "ClearTrace" + NewLine)
  Trace(Prog_ID, "Loaders.LoadFunctions" + NewLine)
  Trace(Prog_ID, "Trace" + NewLine)
  DebugStep = "GetNowTime";
  const GetNowTime = (p_format) =>
      if (p_format == "NowHour")
          // return ("0" + Now.getHours()).slice(-2);
          return Now.getHours();
      else if ( (p_format == "NowQuarter")
              || (p_format == "NowQuarterHour")
              || (p_format == "Now_QH")
              || (p_format == "NowQH")
          return (4 * Now.getHours()
                + Math.floor(Now.getMinutes()/15) );
      else if (p_format == "NowMinutes")
          // return ("0" + Now.getMinutes()).slice(-2);
          return Now.getMinutes();
      else if (p_format == "NowInSeconds")
          return Math.floor(Now.getTime() / 1000);
      if ( (p_format == "uu:mm")
        || (p_format == "UU:MM") )
                  + ("0" + Now.getMinutes() ).slice(-2);
      else if ( (p_format == "yyyymmdd")
              || (p_format == "YYYYMMDD") )
          return Now.getFullYear()
              + ("0" + (Now.getMonth() + 1)).slice(-2)
              + ("0" + Now.getDate()).slice(-2);
      else if ( (p_format == "yyyy-mm-dd")
              || (p_format == "YYYY-MM-DD") )
              + "-" + ("0" + (Now.getMonth() + 1)).slice(-2)
              + "-" + ("0" + Now.getDate()).slice(-2);
      else if ( (p_format == "uu:mm:ss")
              || (p_format == "UU:MM:SS") )
          return ("0" + Now.getHours()).slice(-2) + ":"
              + ("0" + Now.getMinutes()).slice(-2) + ":"
              + ("0" + Now.getSeconds()).slice(-2) ;
      else
          return Now.getFullYear() + "-"
              + ("0" + (Now.getMonth() + 1)).slice(-2) + "-"
              + ("0" + Now.getDate()).slice(-2) + " "
              + ("0" + Now.getHours()).slice(-2) + ":"
  global.set("MESS.Functions.GetNowTime", GetNowTime);
  Trace(Prog_ID, "GetNowTime" + NewLine)
  Trace(Prog_ID, "= " + GetNowTime() + NewLine)
  DebugStep = "GetTomorrow";
  const GetTomorrow = (p_format) =>
      let Tomorrow = new Date();
      Tomorrow.setDate(Tomorrow.getDate() + 1);
      if (p_format == "yyyymmdd")
          return Tomorrow.getFullYear()
                + ("0" + (Tomorrow.getMonth() + 1)).slice(-2)
                + ("0" + Tomorrow.getDate()).slice(-2) ;
      else
          return Tomorrow.getFullYear() + "-"
                + ("0" + (Tomorrow.getMonth() + 1)).slice(-2) + "-"
  global.set("MESS.Functions.GetTomorrow", GetTomorrow);
  Trace(Prog_ID, "GetTomorrow" + NewLine)
  DebugStep = "GetYesterday";
  const GetYesterday = (p_format) =>
      let Yesterday = new Date();
      Yesterday.setDate(Yesterday.getDate() - 1);
          return Yesterday.getFullYear()
                + ("0" + (Yesterday.getMonth() + 1)).slice(-2)
                + ("0" + Yesterday.getDate()).slice(-2) ;
      else
          return Yesterday.getFullYear() + "-"
                + ("0" + (Yesterday.getMonth() + 1)).slice(-2) + "-"
  global.set("MESS.Functions.GetYesterday", GetYesterday);
  Trace(Prog_ID, "GetYesterday" + NewLine)
  DebugStep = "TimestampTo_HH_MM_SS";
  const TimestampTo_HH_MM_SS = (p_date) =>
      const curdate = new Date(null);
      curdate.setSeconds(p_date)
      return ( ("0" + curdate.getHours()).slice(-2) + ":"
              + ("0" + curdate.getMinutes()).slice(-2) + ":"
              + ("0" + curdate.getSeconds()).slice(-2)
  global.set("MESS.Functions.TimestampTo_HH_MM_SS",
              TimestampTo_HH_MM_SS);
  Trace(Prog_ID, "TimestampTo_HH_MM_SS" + NewLine)
  DebugStep = "TimestampTo_QH";
  const TimestampTo_QH = (p_date) =>
      try
          var TempDate = new Date(p_date);
          return (4 * TempDate.getHours()
                + Math.floor(TempDate.getMinutes()/15) );
      catch (error)
          node.warn("Error TimestampTo_QH: " + error);
          return ("");
  global.set("MESS.Functions.TimestampTo_QH", TimestampTo_QH);
  Trace(Prog_ID, "TimestampTo_QH" + NewLine)
  DebugStep = "QHToText";
  const QHToText = (p_QH) =>
      const QH_Symbol = [":00", ":15", ":30", ":45"];
      let curHour = Math.floor(p_QH/4);
      let curQH = p_QH - 4 * curHour;
      let Result = "";
      if (curHour < 24) {
          Result +=
            ('0' + curHour.toString()).slice(-2)
            + QH_Symbol[curQH];
      else {
          Result += "+"
            + ('0' + (curHour-24).toString()).slice(-2)
            + QH_Symbol[curQH];
      return Result;
  global.set("MESS.Functions.QHToText", QHToText);
  Trace(Prog_ID, "QHToText" + NewLine)
  DebugStep = "Not";
  const Not = (p_Boolean) =>
      return !p_Boolean;
  global.set("MESS.Functions.Not", Not);
  Trace(Prog_ID, "Not" + NewLine)
  DebugStep = "CtToText";
  const CtToText = (C) =>
      let C1= Round(C, 1);
      return Number(C1).toFixed(1) + "ct";
  } // CtToText
  global.set("MESS.Functions.CtToText", CtToText);
  Trace(Prog_ID, "CtToText" + NewLine)
  DebugStep = "HourToText";
  const HourToText = (H) =>
      if (Number(H) <= 23) {
          return Number(H).toString();
      else {
          return "+" + (Number(H)-24).toString();
  } // HourToText
  global.set("MESS.Functions.HourToText", HourToText);
  Trace(Prog_ID, "HourToText" + NewLine)
  DebugStep = "WhToText";
  const WhToText = (p_Wh, dec) =>
      let WhSign = Math.sign(p_Wh);
      let WhAbs = Math.abs(p_Wh);
      if (WhAbs >= 1000) {
          if (dec == null) // 1 decimal
              { return ((WhSign * Round(WhAbs/100)/10)).toFixed(1) + "kWh" }
          else if (dec == 0)
              { return ((WhSign * Round(WhAbs/1000))).toFixed(dec) + "kWh" }
          else if (dec == 1)
              { return ((WhSign * Round(WhAbs/100)/10)).toFixed(dec) + "kWh" }
          else if (dec == 2)
              { return ((WhSign * Round(WhAbs/10)/100)).toFixed(dec) + "kWh" }
      else {
          return (WhSign * Round(WhAbs)).toString() + "Wh";
  } // WhToText
  global.set("MESS.Functions.WhToText", WhToText);
  Trace(Prog_ID, "WhToText" + NewLine)
  DebugStep = "kWhToWh";
  const kWhToWh = (x) =>
    return Round(x * 1000);
  } // kWhToWh
  global.set("MESS.Functions.kWhToWh", kWhToWh);
  Trace(Prog_ID, "kWhToWh" + NewLine)
  DebugStep = "BoolToChar";
  const BoolToChar = (p_Bool) =>
    if (p_Bool)
        return "\u2714"; // check
    else if ( !(p_Bool) )
        return "\u2718"; // ballot
    else
        return "\u2047"; // double ??
  } // BoolToChar
  global.set("MESS.Functions.BoolToChar", BoolToChar);
  Trace(Prog_ID, "BoolToChar" + NewLine)
  DebugStep = "Max";
  const Max = Math.max;
  global.set("MESS.Functions.Max", Max);
  Trace(Prog_ID, "Max" + NewLine)
  DebugStep = "Min";
  const Min = Math.min;
  global.set("MESS.Functions.Min", Min);
  Trace(Prog_ID, "Min" + NewLine)
  DebugStep = "Round";
  const Round = (x, dec) =>
      let curSign = Math.sign(x);
      let x_abs = Math.abs(x);
      if (dec == null)
          { return curSign * Math.round(x_abs) }
      else if (dec == 0)
      else if (dec == 1)
          { return curSign * Math.round(x_abs*10) / 10 }
      else if (dec == 2)
          { return curSign * Math.round(x_abs*100) / 100 }
      else if (dec == 3)
          { return curSign * Math.round(x_abs*1000) / 1000 }
      else if (dec == -1)
          { return curSign * Math.round(x_abs/10) * 10 }
      else if (dec == -2)
          { return curSign * Math.round(x_abs/100) * 100 }
      else if (dec == -3)
          { return curSign * Math.round(x_abs/1000) * 1000 }
      else
  } // Round
  global.set("MESS.Functions.Round", Round);
  Trace(Prog_ID, "Round" + NewLine)
  DebugStep = "PriceToBuyValue";
  const PriceToBuyGross = (Net_Price, CallerName) =>
    { // excl. Conversion loss
        var DebugStep = "Start";
        var NewLine = "\n\r";
    try
        DebugStep = "Test Undefined";
        var Result = 0;
        // node.warn(typeof Net_Price);
        if (typeof Net_Price == 'undefined')
            node.warn("CallerName: " + CallerName + NewLine
                + "PriceToBuyValue; Net_Price is: " + Net_Price);
        DebugStep = "Calculate Result";
      let BTW_fact = 1 + global.get("MESS.Param.Param_BTW_Perc") / 100;
        Result =
          Round(
            ( Net_Price
              + global.get("MESS.Param.Param_kWh_Buy_TaxCt")
              + global.get("MESS.Param.Param_kWh_Buy_CostCt") )
            * BTW_fact,
          2 );
      catch (error)
        node.warn("Error in " + "PriceToBuyGross" + ":" + NewLine
        + "CallerName: " + CallerName + NewLine
        + "Step: " + DebugStep + NewLine
        + "Error: " + error)
      return Result;
  global.set("MESS.Functions.PriceToBuyGross", PriceToBuyGross);
  Trace(Prog_ID, "PriceToBuyGross" + NewLine)
  const PriceToBuyValue = (Net_Price, CallerName) =>
  { //incl. conversion loss
    Result = Round(PriceToBuyGross(Net_Price, CallerName)
      / global.get("MESS.Param.Param_Conversion_Loss_Factor"),
             2 );
    return Result;
  global.set("MESS.Functions.PriceToBuyValue", PriceToBuyValue);
  Trace(Prog_ID, "PriceToBuyValue" + NewLine)
  DebugStep = "PriceToDirectValue";
  const PriceToDirectValue = (Net_Price, CallerName) =>
    return PriceToBuyGross(Net_Price, CallerName);
  global.set("MESS.Functions.PriceToDirectValue", PriceToDirectValue);
  Trace(Prog_ID, "PriceToDirectValue" + NewLine)
  DebugStep = "PriceToSellGross";
  const PriceToSellGross = (Net_Price, CallerName) =>
    try
      var Result = 0;
            + "PriceToSellValue; Net_Price is: " + Net_Price);
      DebugStep = "Get Globals";
      if (!(global.get("MESS.Param.Param_kWh_Buy_TaxCt")) ) {
        node.warn("MESS.Param.Param_kWh_Buy_TaxCt: null");
      if (typeof global.get("MESS.Param.Param_kWh_Sell_TaxCt") === 'undefined')
        node.warn("MESS.Param.Param_kWh_Sell_TaxCt: null");
      if (!(global.get("MESS.Param.Param_kWh_Buy_CostCt")) ) {
        node.warn("MESS.Param.Param_kWh_Buy_CostCt: null");
      if (!(global.get("MESS.Param.Param_kWh_Sell_CostCt")) ) {
        node.warn("MESS.Param.Param_kWh_Sell_CostCt: null");
      if (!(global.get("MESS.Param.Param_BTW_Perc")) ) {
        node.warn("MESS.Param.Param_BTW_Perc: null");
      if (!(global.get("MESS.Param.Param_Conversion_Loss_Factor")) ) {
        node.warn("MESS.Param.Param_Conversion_Loss_Factor: null");
      let BTW_fact = 1 + Number(global.get("MESS.Param.Param_BTW_Perc")) / 100;
      Result =
        Round(
          ( Net_Price
            - Number(global.get("MESS.Param.Param_kWh_Sell_CostCt"))
          ) * BTW_fact,
        2 );
    catch (error)
      node.warn("Error in " + "PriceToSellGross" + ":" + NewLine
    return Result;
  global.set("MESS.Functions.PriceToSellGross", PriceToSellGross);
  Trace(Prog_ID, "PriceToSellGross" + NewLine)
  DebugStep = "PriceToSellValue";
  const PriceToSellValue = (Net_Price, CallerName) =>
    return Round( PriceToSellGross(Net_Price, CallerName)
      * global.get("MESS.Param.Param_Conversion_Loss_Factor"),
            2 );
  global.set("MESS.Functions.PriceToSellValue", PriceToSellValue);
  Trace(Prog_ID, "PriceToSellValue" + NewLine)
  DebugStep = "PosInArrayOfSets";
  const PosInArrayOfSets = (p_ArrayOfSets, p_SearchQH) =>
      let Result = -1;
      for ( let i = 0; i < p_ArrayOfSets.length; i++)
          if ( p_ArrayOfSets[i][0] == p_SearchQH )
              Result = i;
              break;
          } // Item was found
      } // for i
      return Result;
  } // PosInArrayOfSets
  global.set("MESS.Functions.PosInArrayOfSets", PosInArrayOfSets);
  Trace(Prog_ID, "PosInArrayOfSets" + NewLine)
  DebugStep = "IsInArrayOfSets";
  const IsInArrayOfSets = (p_ArrayOfSets, p_SearchQHs) =>
  { // See if any of the items within array p_SearchQHs
    // are in array p_ArrayOfSets{hour, value]
      let Result = false;
      for (let i = 0; i < p_SearchQHs.length; i++) {
          for ( let j = 0; j < p_ArrayOfSets.length; j++)
              if ( p_ArrayOfSets[j][0] == p_SearchQHs[i] )
                  Result = true;
                  break;
              } // Item was found
          } // for j
          if (Result) break;
      } // all items
      return Result; // not found
  } // IsInArrayOfSets
  global.set("MESS.Functions.IsInArrayOfSets", IsInArrayOfSets);
  Trace(Prog_ID, "IsInArrayOfSets" + NewLine)
  DebugStep = "Is_PV_Modulate_QH";
  const Is_PV_Modulate_QH = (p_QH) =>
    let QH_PV_Modulate =
      global.get("MESS.DayAhead.QH_PV_Modulate");
    return (IsInArrayOfSets(QH_PV_Modulate, [p_QH]) )
  } // Is_PV_Modulate_QH
  global.set("MESS.Functions.Is_PV_Modulate_QH", Is_PV_Modulate_QH);
  Trace(Prog_ID, "Is_PV_Modulate_QH" + NewLine)
  DebugStep = "Is_PVOff_QH";
  const Is_PVOff_QH = (p_QH) => {
    let QH_PVOff = global.get("MESS.DayAhead.QH_PVOff");
    return (IsInArrayOfSets(QH_PVOff, [p_QH]))
  } // Is_PVOff_QH
  global.set("MESS.Functions.Is_PVOff_QH", Is_PVOff_QH);
  Trace(Prog_ID, "Is_PVOff_QH" + NewLine)
  DebugStep = "Is_Negative_Price";
  const Is_Negative_Price = (p_QH) =>
    let QH_Negative = global.get("MESS.DayAhead.QH_Negative");
    return ( IsInArrayOfSets(QH_Negative, [p_QH]) )
  } // Is_Negative_Price
  global.set("MESS.Functions.Is_Negative_Price", Is_Negative_Price);
  Trace(Prog_ID, "Is_Negative_Price" + NewLine)
  DebugStep = "Is_Zero_Price";
  const Is_Zero_Price = (p_QH) =>
    let QH_Zero = global.get("MESS.DayAhead.QH_Zero");
    return ( IsInArrayOfSets(QH_Zero, [p_QH]) )
  } // Is_Zero_Price
  global.set("MESS.Functions.Is_Zero_Price", Is_Zero_Price);
  Trace(Prog_ID, "Is_Zero_Price" + NewLine)
  DebugStep = "Is_Very_Low_Price";
  const Is_Very_Low_Price = (p_QH) =>
    let QH_VeryLow = global.get("MESS.DayAhead.QH_VeryLow");
    return ( IsInArrayOfSets(QH_VeryLow, [p_QH]) )
  } // Is_Very_Low_Price
  global.set("MESS.Functions.Is_Very_Low_Price", Is_Very_Low_Price);
  Trace(Prog_ID, "Is_Very_Low_Price" + NewLine)
  DebugStep = "Is_Low_Price";
  const Is_Low_Price = (p_QH) =>
    let QH_Low = global.get("MESS.DayAhead.QH_Low");
    return ( IsInArrayOfSets(QH_Low, [p_QH]) )
  } // Is_Low_Price
  global.set("MESS.Functions.Is_Low_Price", Is_Low_Price);
  Trace(Prog_ID, "Is_Low_Price" + NewLine)
  DebugStep = "Is_Normal_Price";
  const Is_Normal_Price = (p_QH) =>
    let QH_Normal = global.get("MESS.DayAhead.QH_Normal");
    return ( IsInArrayOfSets(QH_Normal, [p_QH]) )
  } // Is_Normal_Price
  global.set("MESS.Functions.Is_Normal_Price", Is_Normal_Price);
  Trace(Prog_ID, "Is_Normal_Price" + NewLine)
  DebugStep = "Is_High_Price";
  const Is_High_Price = (p_QH) =>
    let QH_High = global.get("MESS.DayAhead.QH_High");
    return ( IsInArrayOfSets(QH_High, [p_QH]) )
  } // Is_High_Price
  global.set("MESS.Functions.Is_High_Price", Is_High_Price);
  Trace(Prog_ID, "Is_High_Price" + NewLine)
  DebugStep = "ArrayOfSetsGetPriceByHour";
  const ArrayOfSetsGetPriceByHour = (p_ArrayOfSets, p_SearchQH) =>
  { // Find the price of the specified hour
    // is in array p_ArrayOfSets{hour, value]
      let Result = null;
      for (let i = 0; i < p_ArrayOfSets.length; i++) {
              Result = p_ArrayOfSets[i][1];
              break;
          } // Item was found
      } // all items
      return Result;
  } // ArrayOfSetsGetPriceByHour
  global.set("MESS.Functions.ArrayOfSetsGetPriceByHour",
                ArrayOfSetsGetPriceByHour);
  Trace(Prog_ID, "ArrayOfSetsGetPriceByHour" + NewLine)
  DebugStep = "SortDef_FirstElement_Asc";
  const SortDef_FirstElement_Asc = (Set_1, Set_2) =>
      if ( Set_1[0] === Set_2[0] )
          return 0
      else if ( Set_1[0] < Set_2[0] )
          return -1
      else
          return 1
  global.set("MESS.Functions.SortDef_FirstElement_Asc",
                SortDef_FirstElement_Asc);
  Trace(Prog_ID, DebugStep + NewLine)
  DebugStep = "SortDef_ByPrice_Asc";
  const SortDef_ByPrice_Asc = (pair_1, pair_2) =>
      // each param a, b contains [ hour, price ]
      // So, argument [0] is hour, argument [1] is price
      if ( ( (pair_1[0] <= 95) && (pair_2[0] <= 95) )
        || ( (pair_1[0] > 95)  && (pair_2[0] > 95)  )
          ) // same day
        if (pair_1[1] < pair_2[1])
          { return -1 }
        else
          { return 1 }
      else if ( (pair_1[0] <= 95) && (pair_2[0] > 95) )
          { return -1 }
      else
          { return 1 }
  } // SortDef_ByPrice_Asc
  global.set("MESS.Functions.SortDef_ByPrice_Asc",
                SortDef_ByPrice_Asc);
  DebugStep = "SortDef_ByPrice_Desc";
  const SortDef_ByPrice_Desc = (pair_1, pair_2) =>
          ) // same day
        if (pair_2[1] < pair_1[1])
        { return -1 }
        else { return 1 }
      { return -1 }
      else { return 1 }
  } // SortDef_ByPrice_Desc
  global.set("MESS.Functions.SortDef_ByPrice_Desc",
                SortDef_ByPrice_Desc);
  DebugStep = "SortDef_OnlyByPrice_Desc";
  const SortDef_OnlyByPrice_Desc = (pair_1, pair_2) =>
      // each param pair_1, pair_2 contains [ hour, price ]
      { return -1 }
      else
      { return 1 }
  } // SortDef_OnlyByPrice_Desc
  global.set("MESS.Functions.SortDef_OnlyByPrice_Desc",
                SortDef_OnlyByPrice_Desc);
  DebugStep = "QH_Array_To_Text";
  const QH_Array_To_Text = (p_ArrayName, p_Array) =>
      let ResultText = "";
      let lastElement = -2;
      let delimiter = "";
      let NextElement = -2;
      if (p_Array && p_Array.length > 0)
          for (let i = 0; i < p_Array.length; i++)
              NextElement = -2;
              let curElement;
              if (Number.isInteger(p_Array[i]))
                  curElement = p_Array[i];
                  if (i < p_Array.length - 1)
                      { NextElement = p_Array[i+1] }
              else
                  curElement = p_Array[i][0];
                      { NextElement = p_Array[i+1][0] }
              if (curElement == lastElement + 1)
                  delimiter = "..";
                  lastElement = curElement;
              else
                  ResultText += delimiter + QHToText(curElement);
                  delimiter = ', ';
                  continue;
              if ( ( curElement != NextElement - 1 )
              ||  ( i == p_Array.length - 1) )
                  delimiter = ', ';
      return p_ArrayName + ": [" + ResultText + "]";
  global.set("MESS.Functions.QH_Array_To_Text",
                QH_Array_To_Text);
  DebugStep = "Quarter_Remain_Factor";
  const Quarter_Remain_Factor = () =>
      const NowMinutes = Now.getMinutes();
      return (15 - (NowMinutes % 15)) / 15;
  } // Quarter_Remain_Factor
  global.set("MESS.Functions.Quarter_Remain_Factor",
                Quarter_Remain_Factor);
  Trace(Prog_ID, "Quarter_Remain_Factor" + NewLine)
  DebugStep = "Loaders.Functions";
  const LoadFunctions = (targetScope, p_Restart = true) =>
    targetScope.NewLine = "\r\n";
    const allFuncs = global.get("MESS.Functions");
    if (allFuncs) {
      Object.keys(allFuncs).forEach(name =>
        targetScope[name] = allFuncs[name];
          let hasRunBefore = false;
          if (targetScope.context
              && typeof targetScope.context.get === "function") {
              hasRunBefore = !!targetScope.context.get("LoadFunctions");
              targetScope.context.set("LoadFunctions", true);
      if ( p_Restart || !hasRunBefore )
          targetScope.Trace(targetScope.Prog_ID, "ClearTrace");
          targetScope.Trace(targetScope.Prog_ID, targetScope.ProgName + NewLine);
          targetScope.Trace(targetScope.Prog_ID, "LoadFunctions \u2714" + NewLine);
      return true;
    return false;
  global.set("MESS.Loaders.LoadFunctions", LoadFunctions);
  DebugStep = "Loaders.LoadConstants";
  Trace(Prog_ID, NewLine + "Loaders.LoadConstants" + NewLine)
  const LoadConstants = (targetScope, p_Restart = true) =>
      // Gebruik de lijst die aan de functie zelf hangt
      const list = LoadConstants.ConstantList;
      Object.keys(list).forEach(key => {
          Object.defineProperty(targetScope, key, {
              get: function() {
                  return list[key];
              configurable: true,
              enumerable: true
          hasRunBefore = !!targetScope.context.get("LoadConstants");
      if ( !hasRunBefore )
              firstRunTime = GetNowTime();
              targetScope.context.set("firstRunTime", firstRunTime);
          targetScope.context.set("LoadConstants", true);
        Trace(targetScope.Prog_ID, "LoadConstants \u2714" + NewLine);
        Trace(targetScope.Prog_ID, "FirstRun:" + NewLine
          + targetScope.context.get("firstRunTime") + NewLine);
        Trace(targetScope.Prog_ID, "NowDateTime:" + NewLine
          + targetScope.NowDateTime + NewLine);
      return true;
  // CRUCIAAL: Hang de lijst aan de functie ZODAT de trace erbij kan
  LoadConstants.ConstantList = {
    "NewLine": "\r\n",
      "SigmaChar": "\u2211",
      "DeltaChar": "\u0394",
      "CheckChar": "\u2714",
      "FailChar": "\u2718",
      "QuestionChar": "\u2047",
      "ThereforeChar": "\u2234",
    get NowDateTime() { return GetNowTime(); },
    get NowTime() { return GetNowTime("UU:MM:SS"); },
    get NowHour() { return GetNowTime("NowHour"); },
    get NowQH() { return GetNowTime("NowQH"); },
    get NowQHAsText() { return QHToText(GetNowTime("NowQH")); },
    get NowMinutes() { return GetNowTime("NowMinutes"); },
    get Yesterday() { return GetYesterday("YYYYMMDD"); },
    get Nowyyyymmdd() { return GetNowTime("yyyymmdd"); },
    get Tomorrowyyyymmdd() { return GetTomorrow("yyyymmdd"); },
    get StartInSeconds() { return GetNowTime("NowInSeconds"); }
  global.set("MESS.Loaders.LoadConstants", LoadConstants);
  Object.keys(LoadConstants.ConstantList).forEach(key =>
      Trace(Prog_ID, "  " + key + NewLine);
  DebugStep = "Loaders.LoadParams";
  Trace(Prog_ID, NewLine + "Loaders.LoadParams" + NewLine)
  const LoadParams = (targetScope) => {
      const list = LoadParams.ParamList;
        // Defines the variables safely and instantly on 'this' without eval()
          value: list[key],
          writable: true,
          configurable: true,
          enumerable: true
      Trace(targetScope.Prog_ID, "LoadParam \u2714" + NewLine);
      return true;
  LoadParams.ParamList = {
  "Param_Batt_Capacity_Wh": 15360, // (3 x 5.12 x 1000)
  "Param_Batt_Max_Current_A": 100, //(100A ivm bus-bar)
  "Param_Batt_Max_Charge_W": 5100,
  "Param_Batt_Max_Discharge_W": 5200,
  "Param_SoC_Full_Perc": 98,
  "Param_Grid_Setpoint_Limit_W": 10000,
  "Param_Solar_Charge_Perc": 100,
  "Param_Energy_to_Sell_Buffer_Wh": 500,
  "Param_NegativePriceThresholdCt": -0.2,
  "Param_ZeroPriceThresholdCt": 0.1,
  "Param_VeryLowPriceThresholdCt": 2,
  "Param_Sell_Price_Difference_LimitCt": 6,
  "Param_Buy_Price_Difference_LimitCt": 8,
  "Param_kWh_Buy_CostCt": 2.48, // (Tibber 2026: 2.48 / 1.21 = 2.05)
  "Param_kWh_Sell_CostCt": 2.48, // (Tibber 2026: 2.48 / 1.21 = 2.05)
  "Param_kWh_Buy_TaxCt": 9.16, // (2026: 11.08 / 1.21 = 9.16)
  "Param_kWh_Sell_TaxCt": 9.16, // (2026: 11.08 / 1.21 = 9.16)
  // "Param_kWh_Sell_TaxCt": 0, // (2026: 11.08 / 1.21 = 9.16)
  "Param_BTW_Perc": 21,
  // "Param_PV_Modulate_Price_Ct": -11.64,
  // "Param_PV_Turn_Off_Price_Ct": -16,
  "Param_PV_Modulate_Price_Ct": 2.48,
  "Param_PV_Turn_Off_Price_Ct": -2.48,
  "Param_Conversion_Loss_Factor": 0.9,
  "Param_SolarEdge_Production_Limit_W": 6060,
  "Param_Finish_Grid_Charge_Seconds": 300,
  "Param_Max_Allowed_Grid_Amp": 25,
  "Solar_Latitude": 52.01016,
  "Solar_Longitude": 4.43628,
  "Solar_Group": ["East", "South", "West"],
  "Solar_Declination": [50, 30, 50],
  "Solar_Azimuth": [-109, -20, 67],
  "Solar_Power": [6, 3.3, 3.9]
  global.set("MESS.Loaders.LoadParams", LoadParams);
  Trace(Prog_ID, "LoadParam \u2714" + NewLine);
  Object.keys(LoadParams.ParamList).forEach((key) =>
      let value = LoadParams.ParamList[key];
      global.set("MESS.Param." + key, value);
      Trace(Prog_ID, "  " + key + ": " + value + NewLine);
  DebugStep = "Loaders.LoadSection";
  Trace(Prog_ID, NewLine + "Loaders.LoadSection" + NewLine)
  const LoadSection = (targetScope, sectionName) => {
      const sectionData = global.get("MESS." + sectionName) || {};
      Object.keys(sectionData).forEach(key => {
          value: sectionData[key],
          writable: true,
          configurable: true,
          enumerable: true
      Trace(targetScope.Prog_ID, "LoadSection " + sectionName + " \u2714" + NewLine);
      return true;
  // Sla de loader op in de globale context
  global.set("MESS.Loaders.LoadSection", LoadSection);
  Trace(Prog_ID, "Loaders.LoadSection" + NewLine)
  Trace(Prog_ID, "Done: " + GetNowTime("uu:mm:ss") +  NewLine)
  DebugStep = "Finish";
  global.set("MESS.Deploy.Loaders_Ready", GetNowTime());
  msg.topic = Prog_ID;
  node.status(
    { fill:"green",
      shape:"dot",
      text: "@ " + GetNowTime()
catch (error)
  node.warn("Error in " + ProgName + ":" + NewLine
  node.status( {
      fill: "red",
      shape: "dot",
      text: error
return msg;
In andere functies worden de functies, parameters en Global-variabelen alsvolgt opgevraagd:
  DebugStep = "Loaders";
  LoadFunctions = global.get("MESS.Loaders.LoadFunctions");
  if (LoadFunctions) LoadFunctions(this);
  LoadConstants = global.get("MESS.Loaders.LoadConstants");
  if (LoadConstants) LoadConstants(this);
  LoadParams = global.get("MESS.Loaders.LoadParams");
  if (LoadParams) LoadParams(this);
  LoadSection = global.get("MESS.Loaders.LoadSection");
  if (LoadSection) LoadSection(this, "Solar")
  if (LoadSection) LoadSection(this, "DayAhead")
  if (LoadSection) LoadSection(this, "SolarEdge")
Omdat de diverse functies na laden worden geactiveerd kan het zijn dat benodigde variabelen in Global nog niet beschikbaar zijn. Daarom volgen na de Loaders controles of de variabelen beschikbaar zijn.
Voorbeelden:
if (typeof kWh_Price_Ct === "undefined")
  node.status({
    fill: "red",
    shape: "ring",
    text: "Waiting for kWh_Price_Ct..."
  Trace(Prog_ID, "Waiting for kWh_Price_Ct" + NewLine);
  return null;
if (typeof Solar_Forecast_All === "undefined")
  node.status({
    fill: "red",
    shape: "ring",
    text: "Waiting for Solar/Solar_Forecast_All..."
  Trace(Prog_ID, "Waiting for Solar_Forecast_All" + NewLine);
  return null;
De via LoadSection opgehaalde gegevens zijn in de functie via hun naam direct als variabele beschikbaar.
Let op: Als een variabele naam in twee Global.MESS secties identiek voorkomt kan dit tot fouten leiden.
[ Voor 106% gewijzigd door MJ de Bruijn op 21-10-2026 11:33 ]
  • gys4tweakers
MJ de Bruijn schreef op dinsdag 20 oktober 2026 @ 12:16:
Dit is wel een heel interessante.
Klopt het dat de benamingen gewijzigd zijn en dat daarnaast de "get functions" regels in diverse programmeringen vervallen?
Heb jij misschien een overzicht of kun jij dit maken van de diverse benamingen uit "SetGlobalFunctions" en de nieuwe naam in "MakeLoaders"?
Pagina: 1 2 Laatste
