7950X3D 4080 Noctua Azerty Creator Extreme
  • 515 views
  • dimir
  • Laatst online: 06-10 17:11
Azerty Creator Extreme North ProArt Powered by ASUS - AMD Ryzen 9 7950X3D
https://azerty.nl/product...&utm_medium=cpc&utm_term=
I have been saving up for a gaming pc, crypto made me save up more, and now i have so much saved up that i really do not know what to buy.
reading whatever about everything made me totally lose all interest in figuring out what i need.
this made me rethink what i really want.
I want a pc that is as silent as i can get, from a good company.
Azerty isnt to far from my home, and has a stunning history from what i know, so everything will be bought from them.
My budget is 5 to 6k euro.
My old pc that im using now is holding me back in the games i would want to play, so i mostly just play rust at this moment.
I would like the ability to be free of the hardware that holds me back.
Screwing around with settings to get games working above 20 fps has made my gaming life more then THIS IS NOT FUN.
So i have my mind set on this system, Noctua fans on everything , with the ability to under volt the video card and the CPU .
To make this as sound deprived as i could possibly buy.
Now i need advise on the screens to use.
I am used to 2 simple 1080 screens , half arsed set up on my base box and a little buildup i made for main screen,.
so i need a good screen mount that can hold up 2 screens , and that i can adjust a bit.
I need 2 good screens with that.
than i read 4k is not CPU bound so no good cpu needed etc.
Do i need 4k?
Is 144p better, i do not know.
I need the ability to watch youtube or whatever on my 2nd screen.,
While i am just farming.
I want to play whatever game i may want to play in the coming years at automatic best settings with good fps.
I dont care i could buy a new pc in 3 years to not spend good cash now,.
i need help for a good monitor setup and keyboard mouse headset, etc.
Azerty has a 100 euro coupon for a review on this system, i will give it to the one that needs it the most, but expect tweakers to still help me out.
i know its not the standard way of making this request, but im a bit drunk, so please give me a bit of slack on this.
Thank you all.
  • KilleBladhark
  • Registratie: December 2022
  • Laatst online: 06-11 12:32
Please use the following template to start a topic asking for advice on buying a desktop: Voorbeeldtopic Desktop koopadvies
Most important part of this template is that you make a concept/setup by yourself, which you think would be suitable to your needs. From there we can give further advice based on your needs.
Of course this is in Dutch, so you may have to translate it, but that shouldn't be a problem I assume.
EDIT: I guess we can use the Azerty desktop you provided as a baseline, which I seemingly missed lol. Are you only interested in buying a pre-built system, or would you be interested in building one yourself?
[ Voor 21% gewijzigd door KilleBladhark op 01-09-2023 08:21 ]
The One Piece is real. (Can we get much higher!)
  • Wolfp4ck
  • Registratie: April 2018
  • Laatst online: 27-10 11:50
if you have 5-6k then go for the sky,
rtx 4090
  • youridv1
  • Registratie: Juni 2016
  • Laatst online: 12-11 16:40
My only gripe with that noctua prebuilt is that it uses a 4080. I get why they did that, because there is no Noctua 4090, but after reading your post it seems like you're willing to spend anything up to 5-6K to get the best of the best. A 4080 is not the fastest gpu you can get for that money.
Azerty does sell this liquid cooled version of the 4090. uitvoering: ASUS ROG Strix LC GeForce RTX 4090 24GB GDDR6X OC Edition They allow you to custom order a PC with parts you picked yourself, so maybe you could custom order a pc that uses the same parts as the Noctua Extreme, but with this GPU. You can also have them replace the fans on the radiator with noctua fans to still have a "noctua cooled" quiet gpu.
The 4090 is around 20-30% faster than the 4080, so I think it's worth it with a budget this big.
I would get 2 1440p monitors. The one on which you're planning to play games should be at least 144Hz refreshrate to get the full experience of a gaming pc this fast. You can save some money by buying a cheaper second monitor, or you can buy two identical ones for symmetry / redundancy.
You could go for 4K with high refreshrate as well. I personally wouldn't, because the visual difference between 4K and 1440p resolution is barely noticable on a 27-32inch display, which is my personal maximum for desk use. You could consider 4K for 32 inch, but for 27 I would really stick to 1440p.
[ Voor 46% gewijzigd door youridv1 op 01-09-2023 09:24 ]
  • br00ky
  • Laatst online: 19:19
br00ky
Je kan prima Nederlands, dus een luie copy-paste die niet aan de voorwaarden voldoet gaat dicht.
