• Sjuf
  • Registratie: Juni 2016
  • Laatst online: 02-06 06:14
Voor de mensen die nu ENJ hebben gekregen.
dit onderstaande lukt.
Let me send a quick guide on viewing your ENJ tokens in Enjin Blockchain Console:
First, make sure that your Polkadot{.js} wallet is configured to work with Enjin Blockchain Console by following the steps here: Configuring Polkadot{.js} for use with the Enjin Blockchain Console.
Then, navigate the Enjin Blockchain Console: https://console.enjin.io and switch over to the Enjin Matrixchain: Switching to the Enjin Matrixchain.
Next, click on the Accounts --> Accounts button in the menu, you should be able to see your funds there.
Maar dan ben je er dus blijkbaar nog niet. Klopt het dat ik nu eerst de ENJ die ik heb ontvangen moet burnen, voor ik ze naar bv Kraken kan sturen?
Step 1: Burning the tokens
⚠️ Please be aware, the process of migrating involves burning the tokens from your current wallet and claiming the migrated tokens on the Enjin Blockchain. This process is irreversible.
If you attempt to burn tokens directly from an exchange wallet, you risk losing your tokens permanently. We strongly advise that you only proceed with this process if the tokens are held in a personal, non-exchange wallet over which you have full control.
Always ensure that you understand each step of the process before proceeding.
The first step involves burning the tokens you wish to migrate.
To migrate Ethereum ENJ tokens, transfer them to this address to burn them: 0x000000000000000000000000000000000000dEaD
To migrate Ethereum EFI tokens, transfer them to this address to burn them: 0x000000000000000000000000000000000000dEaD
Bron:https://support.enjin.io/hc/en-gb/articles/13685897042962-How-to-migrate-ERC20-ENJ-EFI-tokens-to-Native-ENJ-on-non-Enjin-wallet#h_01HA5E916P9D1YE9MNXNX8VVQE
  • _superboer_
Ik ben eens al m'n crowdloans van Polkadot aan het langslopen en kom er nu niet uit waar mijn dots zijn gebleven.
Ik zie dat ik van 1 crowdloand m'n inleg terug heb gekregen, volgens mij is dat van Moonbeam. Ik mis echter nog de dots van de crowdloans van Astar, Parallel en Acala. Ik het het ingelegd via polkadot.js.org, moet ik deze zelf nog ergens claimen?
  • resusaapje
  • Laatst online: 06:15
_superboer_ schreef op maandag 4 december 2023 @ 08:36:
Ha, leven in de lijst!
Ja, van allevier had je de DOTjes al terug moeten hebben. Weet je zeker dat ze niet verscholen zijn tussen de tientallen andere DOTs in je portemonnee? ;-)
ASTR is een simpele situatie: ze zouden gewoon in je verzameling moeten staan.
ACA en PARA kunnen anderszins gealloceerd zijn. Kijk daarvoor op:
https://apps.acala.network/portfolio
https://app.parallel.fi/
Bij de inschrijving kon je namelijk aangeven dat je virtuele DOTs wilde hebben. Daarmee kon je op de sites van Acala en Parallel handelen ipv dat alles gelocked was. Weet niet of jij dat aangevinkt had?
  • _superboer_
resusaapje schreef op maandag 4 december 2023 @ 09:51:
Ik weet zeker dat ze niet verscholen zijn aangezien m'n transactieoverzicht zeer overzichtelijk is:
Afbeeldingslocatie: https://tweakers.net/i/ZlliahhCTCfUUUmL3i8ZJEHfiRc=/800x/filters:strip_exif()/f/image/Ov2tQEohPKmOer3zm3H7P7ny.png?f=fotoalbum_large
Lichtblauw is een testtransactie.
Geel is overboeking van de rest.
Groen is het aanmaken van een Proxy
En alle rode bedragen zijn 1/5e van geel, waarbij er dus 4x dat bedrag uit is gegaan, en 1x dat bedrag is binnengekomen.
Bij Acala zie ik geen DOT, LDOT, ICDOT in m'n portfolio. Bij parallel heb ik een minibedrag aan dot op de Relaychain Balance, maar dat is maar ±2,5% van wat ik in de crowdloan heb gestopt.
  • resusaapje
_superboer_ schreef op maandag 4 december 2023 @ 12:46:
Vreemd...
Kijk eens via https://app.talisman.xyz/history
Ook via "History" en dan filter Module="Crowdloan"
  • _superboer_
resusaapje schreef op maandag 4 december 2023 @ 13:19:
Vreemd...
Thanks voor de hulp, ze waren niet naar m'n originele dot account overgemaakt maar naar de nieuwe wallets die ik had gemaakt voor de crowdloan. Wel vreemd dat ik ze dan niet in de apps terug zie. In ieder geval kan ik er nu weer bij, thanks!
Enige waar ik dan nog tegenaan loop is om m'n Acala weg te halen:
Afbeeldingslocatie: https://tweakers.net/i/jDw1iYgfGLz3AhPtHG3w9cThaWU=/800x/filters:strip_exif()/f/image/swK00fvk9n0X4QoEX5RCTTWt.png?f=fotoalbum_large
Als ik de vested Acala wil claimen krijg ik melding "1010: Invalid Transaction: Inability to pay some fees , e.g. account balance too low". Van de andere Acala heb ik uberhaupt geen idee waar ik die kan vinden :?
[ Voor 39% gewijzigd door _superboer_ op 04-12-2023 13:45 ]
  • DJ-Promo
  • Laatst online: 09:43
Pas wat CDOT om kunnen zetten naar DOT. vanalles tijden terug in crowdloans gezet maar niks meer mee gedaan.
Nu zie ik nog een paar van deze: cDOT 10/17.
Hoe moet ik die 10/17 lezen? Kan nergens vinden wanneer deze nu vrij komen.
  • resusaapje
DJ-Promo schreef op maandag 22 januari 2024 @ 11:06:
Dude, je geeft steeds halve informatie door. Schrijf gewoon het hele verhaal, zodat anderen niet hoeven gissen.
Zo gis ik, dat je mee hebt gedaan via Acala en/of Parallel Finance. Ik gis dat je bij één of beiden hebt aangegeven dat je in ruil voor de gelockte DOT, virtuele DOT wil hebben. Die virtuele DOT had je vervolgens kunen verkopen of staken. Na afloop van de locking periode kan je ze dan weer 1:1 terugruilen voor originele DOT. Dat doe je dus op het platform waar je ze vandaan hebt. Daar zie je dan ook cDOT 10/17 staan.
Slechts giswerk van mijn kant 8)
  • DJ-Promo
resusaapje schreef op maandag 22 januari 2024 @ 13:28:
My bad. Gaat inderdaad om Parallel Finance. Ik zie ze daar staan als CDOT maar kan ze nog niet claimen. Ik snap dus niet wanneer wel. Als ik er op google kom ik alleen tegen dat bepaalde batches van crowdoans zo'n nummer achter die CDOT hebben staan.
  • resusaapje
EFINITY
Zo, hèhè, de Efinity crowdloan DOT's zijn ook vrijgekomen.
Voor mij alleen nog wachten op Polkadex en OriginTrail in april en dan ben ik van die ellende af.
Hoe is jullie gevoel bij die hele parachain hype?
  • resusaapje
DJ-Promo schreef op maandag 22 januari 2024 @ 13:30:
Jaaaaa, je kan het wel ;)
cDOT =/= cDOT.
De nummertjes erachter geven aan bij welke crowdloan je thuishoort en -het belangrijkste- wanneer ze vrijkomen.
Dus in mijn geval: Litentry, Polkadex en Origitrail DOT's komen april 2024 vrij en had ik meegedaan via Parallel ipv rechtstreeks, kan ik dan dus mijn cDOT-8/15's 1:1 inruilen tegen ekte DOT's.
Het kan ook eerder, maar dan swap je tegen een onvoordeligere koers
  • DJ-Promo
resusaapje schreef op maandag 22 januari 2024 @ 13:42:
cDOT =/= cDOT.
Haha thanks!
  • Slonzo
Slonzo
Taarsidath-an Halsaam
resusaapje schreef op maandag 22 januari 2024 @ 13:33:
Huh? Welke hype? :+
  • resusaapje
Jaja, goudvis, zeven seconden, maak een zin 8)
  • Chaes
  • Laatst online: 13-07 16:45
Chaes
#HODL
EFINITY
Vraagje: heb jij iets van ENJ kunnen claimen i.p.v. Efinity? Dit was de bedoeling volgens mij toch? Alleen zelf heb ik er niks van gezien. En Pdex heb ik ook niet ontvangen. Jij wel al iets?
  • resusaapje
Chaes schreef op zaterdag 3 februari 2024 @ 13:28:
Ja, da's het gemene, ze zijn meteen verhuisd. Je zoekt je ongans :)
Efinity --> Enjin: https://console.enjin.io
Polkadex: https://polkadex.trade/rewards
  • Chaes
Chaes
#HODL
resusaapje schreef op zaterdag 3 februari 2024 @ 17:28:
Zowel op de 1e als de 2e link zie ik niks?
Via de eerste link, als ik met mijn polkadot.js account inlog, staat er '0 transferable ENJ'.
En als ik mijn wallet verbind met de Polkadex website staat er dat deze wallet geen rewards heeft/zal ontvangen.
  • resusaapje
Chaes schreef op zaterdag 3 februari 2024 @ 18:15:
Je hebt niet toevallig meegedaan via een CEX of een DEX?
Mocht je keurig via polkadot,js hebben ingelegd dan is het adres iets preciezer:
https://console.enjin.io/#/accounts
Polkadex zijn in mijn boek oplichters. Je kunt hier https://polkadex.trade/rewards namelijk alleen je PDEX claimen, als je al PDEX hebt: https://www.reddit.com/r/...iled_claim_crown_rewards/
  • Chaes
Chaes
#HODL
resusaapje schreef op zaterdag 3 februari 2024 @ 23:59:
Nee, heb zowel EFI als PDEX via Kraken gedaan.
En van beide dus nog niks ontvangen. Neem aan dat ik PDEX niet hoef te claimen op hun eigen platform als ik in de crowdloan participeer via Kraken...?
  • resusaapje
Chaes schreef op zondag 4 februari 2024 @ 21:48:
Oooooooooooooooooooooooooooh, zegdatdanmeteeeeeeeeeen!
Dan is het tussen jou en Kraken. En ik herinner me dat Kraken ruzie heeft met minstens één partij. Zoek even op "kraken" eerder in deze draad...
  • Mr. Unexist
  • Laatst online: 13-08 22:17
Parallel Finance overleden??
Op Coingecko ziet het er ook wat uitgestorven uit :|
Afbeeldingslocatie: https://tweakers.net/i/gp8WYViq3Id05YkPExvkz9Fdqko=/x800/filters:strip_icc():strip_exif()/f/image/D4Z6cleEe6KMrTTwFmbsuvZp.jpg?f=fotoalbum_large
  • resusaapje
Mr. Unexist schreef op vrijdag 16 februari 2024 @ 22:56:
Op Twitter gisteren allerlei berichten over nieuwe samenwerkingen.
Bv " We're thrilled to have teamed up with @zkLink_Official!"
Ook de site doet het nog steeds: https://app-polkadot.parallel.fi/
  • Kol Nedra
  • Laatst online: 07:53
verkeerde topic
[ Voor 92% gewijzigd door Kol Nedra op 17-02-2024 00:42 ]
nothing stops this train
  • Mr. Unexist
resusaapje schreef op zaterdag 17 februari 2024 @ 00:32:
Dan zal het wel een delisting zijn :?
Dit kom ik tegen op de site van Kraken:
Parallel Finance (PARA) is not available on Kraken.
Anyway, heb het naar m'n Subwallet verplaatst. Heb er geen € aan besteed dus zie wel waar het schip strandt.
  • resusaapje
Mr. Unexist schreef op zaterdag 17 februari 2024 @ 12:53:
Ja precies, dat €10tje is de moeite verder niet ;)
  • resusaapje
OriginTrail
Let op: OriginTrail Parachain ($OTP) is omgedoopt in NeuroWebAI ($NEURO)
Motto: Knowledge Mining for art -O-
En de waarde van dat token? NIET GELIST!!! _O-
  • Chaes
Chaes
#HODL
Ik wacht nog steeds op Polkadex (PDEX) en wat andere om uitgekeerd te worden via Kraken.
Maarja, $6m market cap... heb je dus helemaal niks aan.
  • resusaapje
Polkadex
Chaes schreef op dinsdag 9 april 2024 @ 11:12:
Ik zie via Talisman dat Polkadex (PDEX) opeens BitTensor (TAO) is geworden? WTH?
  • Chaes
Chaes
#HODL
resusaapje schreef op dinsdag 9 april 2024 @ 11:33:
Polkadex
haha wtf...
Weet je het zeker?
[ Voor 3% gewijzigd door Chaes op 09-04-2024 11:44 ]
  • resusaapje
Chaes schreef op dinsdag 9 april 2024 @ 11:43:
haha wtf...
Weet je het zeker?
Ik zie wat ik zie ;)
Ik denk dat PDEX z'n parachain lease niet verlengd heeft en dat toevallig juist die bij TAO in diens self-funded lease is beland. Morgen komt die lease vrij, dus ik vermoed dat ik nu tussen oud en nieuw hang: oude lock, nieuwe eigenaar.
Maar wel even een wtf-momentje 8)
  • Chaes
Chaes
#HODL
resusaapje schreef op dinsdag 9 april 2024 @ 11:53:
Dus ook geen PDEX tokens voor ons dan I guess.
  • resusaapje
Chaes schreef op dinsdag 9 april 2024 @ 12:23:
Tja. Voor jou is het Kraken die ertussen zit en moeilijk doet. Voor mij is het Polkadex die de boel flest. Ik had het al vermeld geloof ik? Om mijn PDEX te kunnen claimen, moet ik eerst PDEX hebben. Gezien de waarde van dat spul is het de moeite niet. Misschien ooit als het x100 is gegaan...
  • Alpina
  • Registratie: November 2019
  • Laatst online: 23-07 11:14
Jammer dat je geen gratis TAO krijgt dan. Kende de Parachain historie wel maar volgens mij is dat niet meer van toepassing?
Of krijgen er heel wat mensen nog gratis TAO? Die zijn happy.
  • Chaes
Chaes
#HODL
Gewoon een grote flop geweest dat hele rewards gebeuren omtrent parachains.
  • NordicMan
  • Registratie: Mei 2022
  • Laatst online: 26-08-2024
Chaes schreef op dinsdag 9 april 2024 @ 15:08:
Ghoh, m'n LIT rewards waren meer waard dan de DOT die ik erin gestoken heb. Enige probleem, parachain loopt af, maar ook bij Kraken... Nog geen LIT gezien natuurlijk.
Pagina: 1 ... 7 8 Laatste
