Degraded ZFS pool, geen SMART problemen
  • MartenBE
  • Laatst online: 11-10 00:46
ZFS geeft me de volgende error:
$ zpool status -x
  pool: backup
 state: DEGRADED
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
action: Determine if the device needs to be replaced, and clear the errors
        using 'zpool clear' or replace the device with 'zpool replace'.
   see: http://zfsonlinux.org/msg/ZFS-8000-9P
  scan: scrub repaired 0B in 0 days 07:35:56 with 0 errors on Fri Jul  3 18:06:36 2020
config:
        NAME                        STATE     READ WRITE CKSUM
        backup                      DEGRADED     0     0     0
          mirror-0                  DEGRADED     0     0     0
            wwn-0x50014ee25f82f352  ONLINE       0     0     0
            wwn-0x50014ee25e601355  DEGRADED     0     0     0  too many errors
errors: No known data errors
Maar de SMART waarden voor /dev/sda geven geen fouten aan, er is niets veranderd aan belangrijke SMART waarden sinds de laatste succesvolle ZFS scrub:
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.7.6-201.fc32.x86_64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   181   174   021    Pre-fail  Always       -       5925
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2085
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   072   072   000    Old_age   Always       -       21054
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       202
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       83
193 Load_Cycle_Count        0x0032   193   193   000    Old_age   Always       -       22765
194 Temperature_Celsius     0x0022   106   094   000    Old_age   Always       -       44
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       7
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
(UDMA_CRC_Error_Count staat al sinds een jaar op 7 en is nooit toegenomen).
Hoe kan ik weten wat er aan de hand is? SMART vertelt me dat de schijf werkt. De andere mirror heeft geen problemen, dus ligt het vermoedelijk ook niet aan PSU of MoBo. Het geheugen is ECC en is onlangs nog getest met memtest (4 passes, +/- 10u). Ik had gedacht om de SATA kabel eens te vervangen en het volgende te doen om te kijken of er nog fouten zijn:
zpool clear backup
zpool scrub backup
Is dit een goede werkwijze?
Troubleshooting en oorzaak ZFS cksum errors
https://forums.servetheho...rors-but-no-errors.23981/
https://serverfault.com/q...raded-zfs-pool-vs-faulted
https://forums.freebsd.or...ool-degraded-state.64073/
[ Voor 5% gewijzigd door MartenBE op 04-07-2020 19:04 ]
  • Q
Q
Au Contraire Mon Capitan!
Als er I/O issues zijn met die schijf dan zou ik wel verwachten dat er wat error op de gebruikelijke plek staan in /var/log/messages|syslog --> daar al iets gevonden?
Draai je Linux of BSD?
[ Voor 7% gewijzigd door Q op 04-07-2020 19:28 ]
  • MartenBE
Ik draai Fedora 32, volledig ge-updated. In `/var/log/messages` (syslog in fedora) vind ik wel het volgende terug:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
Jul  1 04:01:34 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x80400000 SErr 0x280100 action 0x6 frozen
Jul  1 04:01:34 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 04:01:34 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 04:01:34 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 04:01:34 mserver kernel: ata1.00: cmd 60/00:b0:c0:bc:6b/08:00:51:00:00/40 tag 22 ncq dma 1048576 in#012         res 40/00:fc:c0:b4:6b/00:00:51:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:01:34 mserver kernel: ata1.00: status: { DRDY }
Jul  1 04:01:34 mserver kernel: ata1.00: cmd 60/00:f8:c0:b4:6b/08:00:51:00:00/40 tag 31 ncq dma 1048576 in#012         res 40/00:fc:c0:b4:6b/00:00:51:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:01:34 mserver kernel: ata1: hard resetting link
Jul  1 04:01:35 mserver kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul  1 04:01:35 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#22 Sense Key : Illegal Request [current]
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#22 Add. Sense: Unaligned write command
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#22 CDB: Read(16) 88 00 00 00 00 00 51 6b bc c0 00 00 08 00 00 00
Jul  1 04:01:35 mserver kernel: blk_update_request: I/O error, dev sda, sector 1366015168 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:01:35 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=697252216832 size=1048576 flags=40080cb0
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#31 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#31 Sense Key : Illegal Request [current]
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#31 Add. Sense: Unaligned write command
Jul  1 04:01:35 mserver kernel: sd 0:0:0:0: [sda] tag#31 CDB: Read(16) 88 00 00 00 00 00 51 6b b4 c0 00 00 08 00 00 00
Jul  1 04:01:35 mserver kernel: blk_update_request: I/O error, dev sda, sector 1366013120 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:01:35 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=697251168256 size=1048576 flags=40080cb0
Jul  1 04:01:35 mserver kernel: ata1: EH complete
Jul  1 04:01:36 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x20001008 SErr 0x280100 action 0x6 frozen
Jul  1 04:01:36 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 04:01:36 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 04:01:36 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 04:01:36 mserver kernel: ata1.00: cmd 60/10:18:90:a0:50/00:00:5d:01:00/40 tag 3 ncq dma 8192 in#012         res 40/00:ec:c0:e4:6e/00:00:51:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:01:36 mserver kernel: ata1.00: status: { DRDY }
Jul  1 04:01:36 mserver kernel: ata1.00: cmd 60/00:60:c0:ec:6e/08:00:51:00:00/40 tag 12 ncq dma 1048576 in#012         res 40/00:ec:c0:e4:6e/00:00:51:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:01:36 mserver kernel: ata1.00: cmd 60/00:e8:c0:e4:6e/08:00:51:00:00/40 tag 29 ncq dma 1048576 in#012         res 40/00:ec:c0:e4:6e/00:00:51:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:01:36 mserver kernel: ata1: hard resetting link
Jul  1 04:01:36 mserver kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul  1 04:01:36 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#12 Sense Key : Illegal Request [current]
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#12 Add. Sense: Unaligned write command
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#12 CDB: Read(16) 88 00 00 00 00 00 51 6e ec c0 00 00 08 00 00 00
Jul  1 04:01:36 mserver kernel: blk_update_request: I/O error, dev sda, sector 1366224064 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:01:36 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=697359171584 size=1048576 flags=40080cb0
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#29 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#29 Sense Key : Illegal Request [current]
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#29 Add. Sense: Unaligned write command
Jul  1 04:01:36 mserver kernel: sd 0:0:0:0: [sda] tag#29 CDB: Read(16) 88 00 00 00 00 00 51 6e e4 c0 00 00 08 00 00 00
Jul  1 04:01:36 mserver kernel: blk_update_request: I/O error, dev sda, sector 1366222016 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:01:36 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=697358123008 size=1048576 flags=40080cb0
Jul  1 04:01:36 mserver kernel: ata1: EH complete
Jul  1 04:01:36 mserver zed[2895590]: eid=24 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:36 mserver zed[2076]: Missed 2 events
Jul  1 04:01:37 mserver zed[2895652]: eid=25 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:37 mserver zed[2895719]: eid=26 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:37 mserver zed[2895775]: eid=27 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:37 mserver zed[2895830]: eid=28 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:37 mserver zed[2895877]: eid=29 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:38 mserver zed[2895923]: eid=30 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:38 mserver zed[2895973]: eid=31 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:38 mserver zed[2896008]: eid=32 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:38 mserver zed[2896095]: eid=33 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:38 mserver zed[2896098]: eid=34 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:39 mserver zed[2896121]: eid=35 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:39 mserver zed[2896184]: eid=36 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:39 mserver zed[2896237]: eid=37 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:39 mserver zed[2896294]: eid=38 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:39 mserver zed[2896353]: eid=39 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:40 mserver zed[2896403]: eid=40 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:40 mserver zed[2896451]: eid=41 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:40 mserver zed[2896494]: eid=42 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:40 mserver zed[2896535]: eid=43 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:40 mserver zed[2896576]: eid=44 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:41 mserver zed[2896620]: eid=45 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:41 mserver zed[2896659]: eid=46 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:41 mserver zed[2896731]: eid=47 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:41 mserver zed[2896776]: eid=48 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:41 mserver zed[2896823]: eid=49 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:42 mserver zed[2896874]: eid=50 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:42 mserver zed[2896921]: eid=51 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:42 mserver zed[2896974]: eid=52 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:42 mserver zed[2897081]: eid=53 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:42 mserver zed[2897083]: eid=54 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:43 mserver zed[2897122]: eid=55 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:43 mserver zed[2897184]: eid=56 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:43 mserver zed[2897239]: eid=57 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:43 mserver zed[2897289]: eid=58 class=statechange pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 vdev_state=DEGRADED
Jul  1 04:01:45 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x40000020 SErr 0x280100 action 0x6 frozen
Jul  1 04:01:45 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 04:01:45 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 04:01:45 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 04:01:45 mserver kernel: ata1.00: cmd 60/00:28:48:e1:8b/08:00:51:00:00/40 tag 5 ncq dma 1048576 in#012         res 40/00:2c:48:e1:8b/00:00:51:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:01:45 mserver kernel: ata1.00: status: { DRDY }
Jul  1 04:01:45 mserver kernel: ata1.00: cmd 60/00:f0:48:d9:8b/08:00:51:00:00/40 tag 30 ncq dma 1048576 in#012         res 40/00:2c:48:e1:8b/00:00:51:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:01:45 mserver kernel: ata1: hard resetting link
Jul  1 04:01:45 mserver zed[2897751]: eid=59 class=config_sync pool_guid=0xFB3BF5EEF316637A
Jul  1 04:01:45 mserver kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul  1 04:01:45 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#5 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#5 Sense Key : Illegal Request [current]
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#5 Add. Sense: Unaligned write command
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#5 CDB: Read(16) 88 00 00 00 00 00 51 8b e1 48 00 00 08 00 00 00
Jul  1 04:01:45 mserver kernel: blk_update_request: I/O error, dev sda, sector 1368121672 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:01:45 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=698330746880 size=1048576 flags=40080cb0
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#30 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#30 Sense Key : Illegal Request [current]
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#30 Add. Sense: Unaligned write command
Jul  1 04:01:45 mserver kernel: sd 0:0:0:0: [sda] tag#30 CDB: Read(16) 88 00 00 00 00 00 51 8b d9 48 00 00 08 00 00 00
Jul  1 04:01:45 mserver kernel: blk_update_request: I/O error, dev sda, sector 1368119624 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:01:45 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=698329698304 size=1048576 flags=40080cb0
Jul  1 04:01:45 mserver kernel: ata1: EH complete
Jul  1 04:01:48 mserver zed[2898295]: eid=60 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:48 mserver zed[2898356]: eid=61 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:48 mserver zed[2898418]: eid=62 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:48 mserver zed[2898486]: eid=63 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:49 mserver zed[2898546]: eid=64 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:49 mserver zed[2898594]: eid=65 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:49 mserver zed[2898640]: eid=66 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:49 mserver zed[2898696]: eid=67 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:49 mserver zed[2898731]: eid=68 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:50 mserver zed[2898781]: eid=69 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:50 mserver zed[2898824]: eid=70 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:50 mserver zed[2898909]: eid=71 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:50 mserver zed[2898912]: eid=72 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:50 mserver zed[2898964]: eid=73 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:51 mserver zed[2899022]: eid=74 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:51 mserver zed[2899081]: eid=75 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:51 mserver zed[2899141]: eid=76 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:01:51 mserver zed[2899202]: eid=77 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:02:58 mserver kernel: ata1: limiting SATA link speed to 1.5 Gbps
Jul  1 04:02:58 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x408000 SErr 0x280100 action 0x6 frozen
Jul  1 04:02:58 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 04:02:58 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 04:02:58 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 04:02:58 mserver kernel: ata1.00: cmd 60/00:78:88:2c:4e/01:00:fa:00:00/40 tag 15 ncq dma 131072 in#012         res 40/00:7c:88:2c:4e/00:00:fa:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:02:58 mserver kernel: ata1.00: status: { DRDY }
Jul  1 04:02:58 mserver kernel: ata1.00: cmd 60/00:b0:88:2d:4e/06:00:fa:00:00/40 tag 22 ncq dma 786432 in#012         res 40/00:7c:88:2c:4e/00:00:fa:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:02:58 mserver kernel: ata1: hard resetting link
Jul  1 04:02:59 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 04:02:59 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#15 Sense Key : Illegal Request [current]
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#15 Add. Sense: Unaligned write command
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#15 CDB: Read(16) 88 00 00 00 00 00 fa 4e 2c 88 00 00 01 00 00 00
Jul  1 04:02:59 mserver kernel: blk_update_request: I/O error, dev sda, sector 4199427208 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
Jul  1 04:02:59 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=2147959181312 size=131072 flags=1808b0
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#22 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#22 Sense Key : Illegal Request [current]
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#22 Add. Sense: Unaligned write command
Jul  1 04:02:59 mserver kernel: sd 0:0:0:0: [sda] tag#22 CDB: Read(16) 88 00 00 00 00 00 fa 4e 2d 88 00 00 06 00 00 00
Jul  1 04:02:59 mserver kernel: blk_update_request: I/O error, dev sda, sector 4199427464 op 0x0:(READ) flags 0x700 phys_seg 12 prio class 0
Jul  1 04:02:59 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=2147959312384 size=786432 flags=40080cb0
Jul  1 04:02:59 mserver kernel: ata1: EH complete
Jul  1 04:02:59 mserver zed[2912808]: eid=78 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:02:59 mserver zed[2912811]: eid=79 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:02:59 mserver zed[2912859]: eid=80 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:02:59 mserver zed[2912922]: eid=81 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:03:00 mserver zed[2912973]: eid=82 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:03:00 mserver zed[2913028]: eid=83 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:03:00 mserver zed[2913072]: eid=84 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:03:00 mserver zed[2913117]: eid=85 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:03:55 mserver dockerd[2424]: time="2020-07-01T04:03:55.919718430+02:00" level=error msg="Not continuing with pull after error: errors:\ndenied: requested access to the resource is denied\nunauthorized: authentication required\n"
Jul  1 04:03:55 mserver dockerd[2424]: time="2020-07-01T04:03:55.919775081+02:00" level=info msg="Ignoring extra error returned from registry: unauthorized: authentication required"
Jul  1 04:03:55 mserver docker-compose[2763]: #033[36mwatchtower_1  |#033[0m time="2020-07-01T02:03:55Z" level=info msg="Unable to update container /qbittorrent_qbittorrent_1. Proceeding to next."
Jul  1 04:08:55 mserver dockerd[2424]: time="2020-07-01T04:08:55.855343774+02:00" level=error msg="Not continuing with pull after error: errors:\ndenied: requested access to the resource is denied\nunauthorized: authentication required\n"
Jul  1 04:08:55 mserver dockerd[2424]: time="2020-07-01T04:08:55.855399859+02:00" level=info msg="Ignoring extra error returned from registry: unauthorized: authentication required"
Jul  1 04:08:55 mserver docker-compose[2763]: #033[36mwatchtower_1  |#033[0m time="2020-07-01T02:08:55Z" level=info msg="Unable to update container /qbittorrent_qbittorrent_1. Proceeding to next."
Jul  1 04:10:10 mserver systemd[1]: Starting system activity accounting tool...
Jul  1 04:10:10 mserver systemd[1]: sysstat-collect.service: Succeeded.
Jul  1 04:10:10 mserver audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sysstat-collect comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul  1 04:10:10 mserver audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sysstat-collect comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul  1 04:10:10 mserver systemd[1]: Finished system activity accounting tool.
Jul  1 04:13:55 mserver dockerd[2424]: time="2020-07-01T04:13:55.875650711+02:00" level=error msg="Not continuing with pull after error: errors:\ndenied: requested access to the resource is denied\nunauthorized: authentication required\n"
Jul  1 04:13:55 mserver dockerd[2424]: time="2020-07-01T04:13:55.875706414+02:00" level=info msg="Ignoring extra error returned from registry: unauthorized: authentication required"
Jul  1 04:13:55 mserver docker-compose[2763]: #033[36mwatchtower_1  |#033[0m time="2020-07-01T02:13:55Z" level=info msg="Unable to update container /qbittorrent_qbittorrent_1. Proceeding to next."
Jul  1 04:14:05 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x100 SErr 0x280100 action 0x6 frozen
Jul  1 04:14:05 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 04:14:05 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 04:14:05 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 04:14:05 mserver kernel: ata1.00: cmd 60/00:40:d8:0e:ad/06:00:98:00:00/40 tag 8 ncq dma 786432 in#012         res 40/00:44:d8:0e:ad/00:00:98:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:14:05 mserver kernel: ata1.00: status: { DRDY }
Jul  1 04:14:05 mserver kernel: ata1: hard resetting link
Jul  1 04:14:05 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 04:14:05 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 04:14:05 mserver kernel: sd 0:0:0:0: [sda] tag#8 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:14:05 mserver kernel: sd 0:0:0:0: [sda] tag#8 Sense Key : Illegal Request [current]
Jul  1 04:14:05 mserver kernel: sd 0:0:0:0: [sda] tag#8 Add. Sense: Unaligned write command
Jul  1 04:14:05 mserver kernel: sd 0:0:0:0: [sda] tag#8 CDB: Read(16) 88 00 00 00 00 00 98 ad 0e d8 00 00 06 00 00 00
Jul  1 04:14:05 mserver kernel: blk_update_request: I/O error, dev sda, sector 2561478360 op 0x0:(READ) flags 0x700 phys_seg 12 prio class 0
Jul  1 04:14:05 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=1309329371136 size=786432 flags=40080cb0
Jul  1 04:14:05 mserver kernel: ata1: EH complete
Jul  1 04:14:06 mserver zed[3036317]: eid=86 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:14:06 mserver zed[3036401]: eid=87 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:14:06 mserver zed[3036472]: eid=88 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:14:06 mserver zed[3036531]: eid=89 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:14:06 mserver zed[3036567]: eid=90 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:14:07 mserver zed[3036607]: eid=91 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:14:07 mserver zed[3036648]: eid=92 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
Jul  1 04:35:43 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x4040000 SErr 0x280100 action 0x6 frozen
Jul  1 04:35:43 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 04:35:43 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 04:35:43 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 04:35:43 mserver kernel: ata1.00: cmd 60/00:90:a0:ac:22/08:00:99:00:00/40 tag 18 ncq dma 1048576 in#012         res 40/00:d4:a0:a4:22/00:00:99:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:35:43 mserver kernel: ata1.00: status: { DRDY }
Jul  1 04:35:43 mserver kernel: ata1.00: cmd 60/00:d0:a0:a4:22/08:00:99:00:00/40 tag 26 ncq dma 1048576 in#012         res 40/00:d4:a0:a4:22/00:00:99:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 04:35:43 mserver kernel: ata1: hard resetting link
Jul  1 04:35:43 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 04:35:43 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#18 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#18 Sense Key : Illegal Request [current]
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#18 Add. Sense: Unaligned write command
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#18 CDB: Read(16) 88 00 00 00 00 00 99 22 ac a0 00 00 08 00 00 00
Jul  1 04:35:43 mserver kernel: blk_update_request: I/O error, dev sda, sector 2569186464 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:35:43 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=1313275920384 size=1048576 flags=40080cb0
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#26 Sense Key : Illegal Request [current]
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#26 Add. Sense: Unaligned write command
Jul  1 04:35:43 mserver kernel: sd 0:0:0:0: [sda] tag#26 CDB: Read(16) 88 00 00 00 00 00 99 22 a4 a0 00 00 08 00 00 00
Jul  1 04:35:43 mserver kernel: blk_update_request: I/O error, dev sda, sector 2569184416 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 04:35:43 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=1313274871808 size=1048576 flags=40080cb0
Jul  1 04:35:43 mserver kernel: ata1: EH complete
Jul  1 04:35:44 mserver zed[3319696]: eid=93 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:44 mserver zed[3319746]: eid=94 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:44 mserver zed[3319807]: eid=95 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:44 mserver zed[3319870]: eid=96 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:44 mserver zed[3319918]: eid=97 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:45 mserver zed[3319975]: eid=98 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:45 mserver zed[3320013]: eid=99 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:45 mserver zed[3320066]: eid=100 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:45 mserver zed[3320114]: eid=101 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:45 mserver zed[3320163]: eid=102 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:46 mserver zed[3320216]: eid=103 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:46 mserver zed[3320258]: eid=104 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:46 mserver zed[3320287]: eid=105 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:46 mserver zed[3320338]: eid=106 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:46 mserver zed[3320391]: eid=107 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:46 mserver zed[3320453]: eid=108 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:47 mserver zed[3320498]: eid=109 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 04:35:47 mserver zed[3320538]: eid=110 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:04:40 mserver kernel: ata1.00: exception Emask 0x52 SAct 0x200000 SErr 0x800d00 action 0x6 frozen
Jul  1 05:04:40 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 05:04:40 mserver kernel: ata1: SError: { UnrecovData Proto HostInt LinkSeq }
Jul  1 05:04:40 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 05:04:40 mserver kernel: ata1.00: cmd 60/00:a8:88:28:75/06:00:55:00:00/40 tag 21 ncq dma 786432 in#012         res 40/00:ac:88:28:75/00:00:55:00:00/40 Emask 0x52 (ATA bus error)
Jul  1 05:04:40 mserver kernel: ata1.00: status: { DRDY }
Jul  1 05:04:40 mserver kernel: ata1: hard resetting link
Jul  1 05:04:40 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 05:04:40 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 05:04:40 mserver kernel: sd 0:0:0:0: [sda] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 05:04:40 mserver kernel: sd 0:0:0:0: [sda] tag#21 Sense Key : Illegal Request [current]
Jul  1 05:04:40 mserver kernel: sd 0:0:0:0: [sda] tag#21 Add. Sense: Unaligned write command
Jul  1 05:04:40 mserver kernel: sd 0:0:0:0: [sda] tag#21 CDB: Read(16) 88 00 00 00 00 00 55 75 28 88 00 00 06 00 00 00
Jul  1 05:04:40 mserver kernel: blk_update_request: I/O error, dev sda, sector 1433741448 op 0x0:(READ) flags 0x700 phys_seg 12 prio class 0
Jul  1 05:04:40 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=731928072192 size=786432 flags=40080cb0
Jul  1 05:04:40 mserver kernel: ata1: EH complete
Jul  1 05:04:41 mserver zed[3685959]: eid=111 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:04:41 mserver zed[3686018]: eid=112 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:04:41 mserver zed[3686078]: eid=113 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:04:41 mserver zed[3686137]: eid=114 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:04:42 mserver zed[3686211]: eid=115 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:04:42 mserver zed[3686259]: eid=116 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:04:42 mserver zed[3686302]: eid=117 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:29:19 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x60 SErr 0x280100 action 0x6 frozen
Jul  1 05:29:19 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 05:29:19 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 05:29:19 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 05:29:19 mserver kernel: ata1.00: cmd 60/00:28:00:d4:ea/01:00:04:01:00/40 tag 5 ncq dma 131072 in#012         res 40/00:34:00:d5:ea/00:00:04:01:00/40 Emask 0x10 (ATA bus error)
Jul  1 05:29:19 mserver kernel: ata1.00: status: { DRDY }
Jul  1 05:29:19 mserver kernel: ata1.00: cmd 60/00:30:00:d5:ea/01:00:04:01:00/40 tag 6 ncq dma 131072 in#012         res 40/00:34:00:d5:ea/00:00:04:01:00/40 Emask 0x10 (ATA bus error)
Jul  1 05:29:19 mserver kernel: ata1: hard resetting link
Jul  1 05:29:19 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 05:29:19 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#5 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#5 Sense Key : Illegal Request [current]
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#5 Add. Sense: Unaligned write command
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#5 CDB: Read(16) 88 00 00 00 00 01 04 ea d4 00 00 00 01 00 00 00
Jul  1 05:29:19 mserver kernel: blk_update_request: I/O error, dev sda, sector 4377465856 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
Jul  1 05:29:19 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=2239114969088 size=131072 flags=1808b0
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#6 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#6 Sense Key : Illegal Request [current]
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#6 Add. Sense: Unaligned write command
Jul  1 05:29:19 mserver kernel: sd 0:0:0:0: [sda] tag#6 CDB: Read(16) 88 00 00 00 00 01 04 ea d5 00 00 00 01 00 00 00
Jul  1 05:29:19 mserver kernel: blk_update_request: I/O error, dev sda, sector 4377466112 op 0x0:(READ) flags 0x700 phys_seg 2 prio class 0
Jul  1 05:29:19 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=2239115100160 size=131072 flags=1808b0
Jul  1 05:29:19 mserver kernel: ata1: EH complete
Jul  1 05:29:20 mserver zed[3941849]: eid=118 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:29:20 mserver zed[3941911]: eid=119 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
Jul  1 05:56:49 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x800 SErr 0x280100 action 0x6 frozen
Jul  1 05:56:49 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 05:56:49 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 05:56:49 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 05:56:49 mserver kernel: ata1.00: cmd 60/00:58:58:19:89/06:00:e3:00:00/40 tag 11 ncq dma 786432 in#012         res 40/00:5c:58:19:89/00:00:e3:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 05:56:49 mserver kernel: ata1.00: status: { DRDY }
Jul  1 05:56:49 mserver kernel: ata1: hard resetting link
Jul  1 05:56:49 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 05:56:49 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 05:56:49 mserver kernel: sd 0:0:0:0: [sda] tag#11 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 05:56:49 mserver kernel: sd 0:0:0:0: [sda] tag#11 Sense Key : Illegal Request [current]
Jul  1 05:56:49 mserver kernel: sd 0:0:0:0: [sda] tag#11 Add. Sense: Unaligned write command
Jul  1 05:56:49 mserver kernel: sd 0:0:0:0: [sda] tag#11 CDB: Read(16) 88 00 00 00 00 00 e3 89 19 58 00 00 06 00 00 00
Jul  1 05:56:49 mserver kernel: blk_update_request: I/O error, dev sda, sector 3817412952 op 0x0:(READ) flags 0x700 phys_seg 12 prio class 0
Jul  1 05:56:49 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=1952367882240 size=786432 flags=40080cb0
Jul  1 05:56:49 mserver kernel: ata1: EH complete
Jul  1 05:56:50 mserver zed[17995]: eid=120 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:50 mserver zed[18049]: eid=121 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:50 mserver zed[18099]: eid=122 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:50 mserver zed[18155]: eid=123 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:51 mserver zed[18247]: eid=124 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:51 mserver zed[18249]: eid=125 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:51 mserver zed[18257]: eid=126 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:51 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x4020000 SErr 0x280100 action 0x6 frozen
Jul  1 05:56:51 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 05:56:51 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 05:56:51 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 05:56:51 mserver kernel: ata1.00: cmd 60/00:88:50:21:80/08:00:fd:00:00/40 tag 17 ncq dma 1048576 in#012         res 40/00:8c:50:21:80/00:00:fd:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 05:56:51 mserver kernel: ata1.00: status: { DRDY }
Jul  1 05:56:51 mserver kernel: ata1.00: cmd 60/00:d0:50:29:80/08:00:fd:00:00/40 tag 26 ncq dma 1048576 in#012         res 40/00:8c:50:21:80/00:00:fd:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 05:56:51 mserver kernel: ata1: hard resetting link
Jul  1 05:56:52 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 05:56:52 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#17 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#17 Sense Key : Illegal Request [current]
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#17 Add. Sense: Unaligned write command
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#17 CDB: Read(16) 88 00 00 00 00 00 fd 80 21 50 00 00 08 00 00 00
Jul  1 05:56:52 mserver kernel: blk_update_request: I/O error, dev sda, sector 4253032784 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 05:56:52 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=2175405236224 size=1048576 flags=40080cb0
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#26 Sense Key : Illegal Request [current]
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#26 Add. Sense: Unaligned write command
Jul  1 05:56:52 mserver kernel: sd 0:0:0:0: [sda] tag#26 CDB: Read(16) 88 00 00 00 00 00 fd 80 29 50 00 00 08 00 00 00
Jul  1 05:56:52 mserver kernel: blk_update_request: I/O error, dev sda, sector 4253034832 op 0x0:(READ) flags 0x700 phys_seg 16 prio class 0
Jul  1 05:56:52 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=2175406284800 size=1048576 flags=40080cb0
Jul  1 05:56:52 mserver kernel: ata1: EH complete
Jul  1 05:56:52 mserver zed[18366]: eid=127 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:52 mserver zed[18419]: eid=128 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:52 mserver zed[18475]: eid=129 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:53 mserver zed[18521]: eid=130 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:53 mserver zed[18569]: eid=131 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:53 mserver zed[18600]: eid=132 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:53 mserver zed[18650]: eid=133 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:53 mserver zed[18692]: eid=134 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:54 mserver zed[18732]: eid=135 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:54 mserver zed[18774]: eid=136 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:54 mserver zed[18793]: eid=137 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:54 mserver zed[18829]: eid=138 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:54 mserver zed[18855]: eid=139 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:55 mserver zed[18899]: eid=140 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:55 mserver zed[18934]: eid=141 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:55 mserver zed[18969]: eid=142 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:55 mserver zed[18997]: eid=143 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 05:56:56 mserver zed[19032]: eid=144 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 06:26:48 mserver kernel: ata1.00: exception Emask 0x10 SAct 0x100000 SErr 0x280100 action 0x6 frozen
Jul  1 06:26:48 mserver kernel: ata1.00: irq_stat 0x08000000, interface fatal error
Jul  1 06:26:48 mserver kernel: ata1: SError: { UnrecovData 10B8B BadCRC }
Jul  1 06:26:48 mserver kernel: ata1.00: failed command: READ FPDMA QUEUED
Jul  1 06:26:48 mserver kernel: ata1.00: cmd 60/00:a0:70:fa:ae/06:00:3d:00:00/40 tag 20 ncq dma 786432 in#012         res 40/00:a4:70:fa:ae/00:00:3d:00:00/40 Emask 0x10 (ATA bus error)
Jul  1 06:26:48 mserver kernel: ata1.00: status: { DRDY }
Jul  1 06:26:48 mserver kernel: ata1: hard resetting link
Jul  1 06:26:48 mserver kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Jul  1 06:26:48 mserver kernel: ata1.00: configured for UDMA/133
Jul  1 06:26:48 mserver kernel: sd 0:0:0:0: [sda] tag#20 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
Jul  1 06:26:48 mserver kernel: sd 0:0:0:0: [sda] tag#20 Sense Key : Illegal Request [current]
Jul  1 06:26:48 mserver kernel: sd 0:0:0:0: [sda] tag#20 Add. Sense: Unaligned write command
Jul  1 06:26:48 mserver kernel: sd 0:0:0:0: [sda] tag#20 CDB: Read(16) 88 00 00 00 00 00 3d ae fa 70 00 00 06 00 00 00
Jul  1 06:26:48 mserver kernel: blk_update_request: I/O error, dev sda, sector 1034877552 op 0x0:(READ) flags 0x700 phys_seg 12 prio class 0
Jul  1 06:26:48 mserver kernel: zio pool=backup vdev=/dev/disk/by-id/wwn-0x50014ee25e601355-part2 error=5 type=1 offset=527709757440 size=786432 flags=40080cb0
Jul  1 06:26:48 mserver kernel: ata1: EH complete
Jul  1 06:26:49 mserver zed[471503]: eid=145 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 06:26:49 mserver zed[471574]: eid=146 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 06:26:49 mserver zed[471629]: eid=147 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 06:26:49 mserver zed[471696]: eid=148 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 06:26:49 mserver zed[471768]: eid=149 class=io pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 06:26:50 mserver zed[471815]: eid=150 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Jul  1 06:26:50 mserver zed[471859]: eid=151 class=checksum pool_guid=0xFB3BF5EEF316637A vdev_path=/dev/disk/by-id/wwn-0x50014ee25e601355-part2
Ondertussen heb ik deze fouten niet meer gehad.
  • Q
Q
  • MartenBE
Ik heb de kabel vervangen en `zpool clear` `zpool scrub` gedaan. Geen errors meer!
