Freeradius EAP-TTLS PAP met Windows client?
  • Carharttguy
  • Laatst online: 24-06 20:55
Hallo
Ik heb een Freeradius server opgezet, die verbinding maakt met onze Google Secure LDAP om zo op ons Wifi netwerk te kunnen authenticeren.
Android: Top, werkt perfect.
Windows: Nope, wil niet werken. Weinig zeggende error aand de client kant, maar aan de serverkant lijkt het alsof Windows tegen beter weten in toch MS-CHAP wil gaan doen ipv PAP.
Hier mijn Freeradius log met Android:
administrator@freeradius:~$ sudo freeradius -X
FreeRADIUS Version 3.0.20
Copyright (C) 1999-2019 The FreeRADIUS server project and contributors
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License
For more information about these matters, see the file named COPYRIGHT
Starting - reading configuration files ...
including dictionary file /usr/share/freeradius/dictionary
including dictionary file /usr/share/freeradius/dictionary.dhcp
including dictionary file /usr/share/freeradius/dictionary.vqp
including dictionary file /etc/freeradius/3.0/dictionary
including configuration file /etc/freeradius/3.0/radiusd.conf
including configuration file /etc/freeradius/3.0/proxy.conf
including configuration file /etc/freeradius/3.0/clients.conf
including files in directory /etc/freeradius/3.0/mods-enabled/
including configuration file /etc/freeradius/3.0/mods-enabled/cache_eap
including configuration file /etc/freeradius/3.0/mods-enabled/unix
including configuration file /etc/freeradius/3.0/mods-enabled/detail
including configuration file /etc/freeradius/3.0/mods-enabled/files
including configuration file /etc/freeradius/3.0/mods-enabled/passwd
including configuration file /etc/freeradius/3.0/mods-enabled/pap
including configuration file /etc/freeradius/3.0/mods-enabled/expr
including configuration file /etc/freeradius/3.0/mods-enabled/echo
including configuration file /etc/freeradius/3.0/mods-enabled/sradutmp
including configuration file /etc/freeradius/3.0/mods-enabled/exec
including configuration file /etc/freeradius/3.0/mods-enabled/attr_filter
including configuration file /etc/freeradius/3.0/mods-enabled/preprocess
including configuration file /etc/freeradius/3.0/mods-enabled/soh
including configuration file /etc/freeradius/3.0/mods-enabled/chap
including configuration file /etc/freeradius/3.0/mods-enabled/linelog
including configuration file /etc/freeradius/3.0/mods-enabled/dynamic_clients
including configuration file /etc/freeradius/3.0/mods-enabled/always
including configuration file /etc/freeradius/3.0/mods-enabled/replicate
including configuration file /etc/freeradius/3.0/mods-enabled/realm
including configuration file /etc/freeradius/3.0/mods-enabled/digest
including configuration file /etc/freeradius/3.0/mods-enabled/mschap
including configuration file /etc/freeradius/3.0/mods-enabled/logintime
including configuration file /etc/freeradius/3.0/mods-enabled/expiration
including configuration file /etc/freeradius/3.0/mods-enabled/unpack
including configuration file /etc/freeradius/3.0/mods-enabled/utf8
including configuration file /etc/freeradius/3.0/mods-enabled/ntlm_auth
including configuration file /etc/freeradius/3.0/mods-enabled/radutmp
including configuration file /etc/freeradius/3.0/mods-enabled/ldap
including configuration file /etc/freeradius/3.0/mods-enabled/detail.log
including configuration file /etc/freeradius/3.0/mods-enabled/eap
including files in directory /etc/freeradius/3.0/policy.d/
including configuration file /etc/freeradius/3.0/policy.d/moonshot-targeted-ids
including configuration file /etc/freeradius/3.0/policy.d/filter
including configuration file /etc/freeradius/3.0/policy.d/accounting
including configuration file /etc/freeradius/3.0/policy.d/debug
including configuration file /etc/freeradius/3.0/policy.d/cui
including configuration file /etc/freeradius/3.0/policy.d/canonicalization
including configuration file /etc/freeradius/3.0/policy.d/dhcp
including configuration file /etc/freeradius/3.0/policy.d/abfab-tr
including configuration file /etc/freeradius/3.0/policy.d/operator-name
including configuration file /etc/freeradius/3.0/policy.d/rfc7542
including configuration file /etc/freeradius/3.0/policy.d/control
including configuration file /etc/freeradius/3.0/policy.d/eap
including files in directory /etc/freeradius/3.0/sites-enabled/
including configuration file /etc/freeradius/3.0/sites-enabled/default
including configuration file /etc/freeradius/3.0/sites-enabled/inner-tunnel
main {
security {
user = "freerad"
group = "freerad"
allow_core_dumps = no
name = "freeradius"
prefix = "/usr"
localstatedir = "/var"
logdir = "/var/log/freeradius"
run_dir = "/var/run/freeradius"
main {
name = "freeradius"
prefix = "/usr"
sbindir = "/usr/sbin"
libdir = "/usr/lib/freeradius"
radacctdir = "/var/log/freeradius/radacct"
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 16384
pidfile = "/var/run/freeradius/freeradius.pid"
checkrad = "/usr/sbin/checkrad"
debug_level = 0
proxy_requests = yes
log {
stripped_names = no
auth = no
auth_badpass = no
auth_goodpass = no
colourise = yes
msg_denied = "You are already logged in - access denied"
resources {
security {
max_attributes = 200
reject_delay = 1.000000
status_server = yes
radiusd: #### Loading Realms and Home Servers ####
proxy server {
retry_delay = 5
retry_count = 3
default_fallback = no
dead_time = 120
wake_all_if_all_dead = no
home_server localhost {
ipaddr = 127.0.0.1
port = 1812
type = "auth"
secret = <<< secret >>>
response_window = 20.000000
response_timeouts = 1
max_outstanding = 65536
zombie_period = 40
status_check = "status-server"
ping_interval = 30
check_interval = 30
check_timeout = 4
num_answers_to_alive = 3
revive_interval = 120
limit {
max_connections = 16
max_requests = 0
lifetime = 0
idle_timeout = 0
coa {
irt = 2
mrt = 16
mrc = 5
mrd = 30
home_server_pool my_auth_failover {
type = fail-over
home_server = localhost
realm example.com {
auth_pool = my_auth_failover
realm LOCAL {
radiusd: #### Loading Clients ####
client localhost {
ipaddr = 127.0.0.1
require_message_authenticator = no
nas_type = "other"
proto = "*"
limit {
lifetime = 0
idle_timeout = 30
client TestAP {
ipaddr = 172.16.15.166
limit {
lifetime = 0
idle_timeout = 30
client StilleLeraarskamer {
ipaddr = 172.16.2.24
limit {
lifetime = 0
idle_timeout = 30
client localhost_ipv6 {
ipv6addr = ::1
limit {
lifetime = 0
idle_timeout = 30
Debugger not attached
systemd watchdog is disabled
# Creating Auth-Type = mschap
# Creating Auth-Type = digest
# Creating Auth-Type = ldap
# Creating Auth-Type = eap
# Creating Auth-Type = PAP
# Creating Auth-Type = CHAP
# Creating Auth-Type = MS-CHAP
radiusd: #### Instantiating modules ####
modules {
# Loaded module rlm_cache
# Loading module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
cache cache_eap {
driver = "rlm_cache_rbtree"
key = "%{%{control:State}:-%{%{reply:State}:-%{State}}}"
ttl = 15
max_entries = 0
epoch = 0
add_stats = no
# Loaded module rlm_unix
# Loading module "unix" from file /etc/freeradius/3.0/mods-enabled/unix
unix {
radwtmp = "/var/log/freeradius/radwtmp"
Creating attribute Unix-Group
# Loaded module rlm_detail
# Loading module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
detail {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
escape_filenames = no
log_packet_header = no
# Loaded module rlm_files
# Loading module "files" from file /etc/freeradius/3.0/mods-enabled/files
files {
filename = "/etc/freeradius/3.0/mods-config/files/authorize"
acctusersfile = "/etc/freeradius/3.0/mods-config/files/accounting"
preproxy_usersfile = "/etc/freeradius/3.0/mods-config/files/pre-proxy"
# Loaded module rlm_passwd
# Loading module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
passwd etc_passwd {
filename = "/etc/passwd"
format = "*User-Name:Crypt-Password:"
delimiter = ":"
ignore_nislike = no
ignore_empty = yes
allow_multiple_keys = no
hash_size = 100
# Loaded module rlm_pap
# Loading module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
pap {
normalise = yes
# Loaded module rlm_expr
# Loading module "expr" from file /etc/freeradius/3.0/mods-enabled/expr
expr {
safe_characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /äéöüàâæçèéêëîïôœùûüaÿÄÉÖÜßÀÂÆÇÈÉÊËÎÏÔŒÙÛÜŸ"
# Loaded module rlm_exec
# Loading module "echo" from file /etc/freeradius/3.0/mods-enabled/echo
exec echo {
wait = yes
program = "/bin/echo %{User-Name}"
input_pairs = "request"
output_pairs = "reply"
shell_escape = yes
# Loaded module rlm_radutmp
# Loading module "sradutmp" from file /etc/freeradius/3.0/mods-enabled/sradutmp
radutmp sradutmp {
filename = "/var/log/freeradius/sradutmp"
username = "%{User-Name}"
case_sensitive = yes
check_with_nas = yes
permissions = 420
caller_id = no
# Loading module "exec" from file /etc/freeradius/3.0/mods-enabled/exec
exec {
wait = no
shell_escape = yes
timeout = 10
# Loaded module rlm_attr_filter
# Loading module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.post-proxy {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/post-proxy"
key = "%{Realm}"
relaxed = no
# Loading module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.pre-proxy {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/pre-proxy"
key = "%{Realm}"
relaxed = no
# Loading module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.access_reject {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_reject"
key = "%{User-Name}"
relaxed = no
# Loading module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.access_challenge {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_challenge"
relaxed = no
# Loading module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.accounting_response {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/accounting_response"
relaxed = no
# Loaded module rlm_preprocess
# Loading module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
preprocess {
huntgroups = "/etc/freeradius/3.0/mods-config/preprocess/huntgroups"
hints = "/etc/freeradius/3.0/mods-config/preprocess/hints"
with_ascend_hack = no
ascend_channels_per_line = 23
with_ntdomain_hack = no
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
# Loaded module rlm_soh
# Loading module "soh" from file /etc/freeradius/3.0/mods-enabled/soh
soh {
dhcp = yes
# Loaded module rlm_chap
# Loading module "chap" from file /etc/freeradius/3.0/mods-enabled/chap
# Loaded module rlm_linelog
# Loading module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
linelog {
filename = "/var/log/freeradius/linelog"
syslog_severity = "info"
permissions = 384
format = "This is a log message for %{User-Name}"
reference = "messages.%{%{reply:Packet-Type}:-default}"
# Loading module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
linelog log_accounting {
filename = "/var/log/freeradius/linelog-accounting"
permissions = 384
format = ""
reference = "Accounting-Request.%{%{Acct-Status-Type}:-unknown}"
# Loaded module rlm_dynamic_clients
# Loading module "dynamic_clients" from file /etc/freeradius/3.0/mods-enabled/dynamic_clients
# Loaded module rlm_always
# Loading module "reject" from file /etc/freeradius/3.0/mods-enabled/always
always reject {
rcode = "reject"
simulcount = 0
mpp = no
# Loading module "fail" from file /etc/freeradius/3.0/mods-enabled/always
always fail {
rcode = "fail"
simulcount = 0
mpp = no
# Loading module "ok" from file /etc/freeradius/3.0/mods-enabled/always
always ok {
rcode = "ok"
simulcount = 0
mpp = no
# Loading module "handled" from file /etc/freeradius/3.0/mods-enabled/always
always handled {
rcode = "handled"
simulcount = 0
mpp = no
# Loading module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
always invalid {
rcode = "invalid"
simulcount = 0
mpp = no
# Loading module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
always userlock {
rcode = "userlock"
simulcount = 0
mpp = no
# Loading module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
always notfound {
rcode = "notfound"
simulcount = 0
mpp = no
# Loading module "noop" from file /etc/freeradius/3.0/mods-enabled/always
always noop {
rcode = "noop"
simulcount = 0
mpp = no
# Loading module "updated" from file /etc/freeradius/3.0/mods-enabled/always
always updated {
rcode = "updated"
simulcount = 0
mpp = no
# Loaded module rlm_replicate
# Loading module "replicate" from file /etc/freeradius/3.0/mods-enabled/replicate
# Loaded module rlm_realm
# Loading module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
realm IPASS {
format = "prefix"
delimiter = "/"
ignore_default = no
ignore_null = no
# Loading module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
realm suffix {
format = "suffix"
delimiter = "@"
ignore_default = no
ignore_null = no
# Loading module "bangpath" from file /etc/freeradius/3.0/mods-enabled/realm
realm bangpath {
format = "prefix"
delimiter = "!"
ignore_default = no
ignore_null = no
# Loading module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
realm realmpercent {
format = "suffix"
delimiter = "%"
ignore_default = no
ignore_null = no
# Loading module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
realm ntdomain {
format = "prefix"
delimiter = "\\"
ignore_default = no
ignore_null = no
# Loaded module rlm_digest
# Loading module "digest" from file /etc/freeradius/3.0/mods-enabled/digest
# Loaded module rlm_mschap
# Loading module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
mschap {
use_mppe = yes
require_encryption = no
require_strong = no
with_ntdomain_hack = yes
passchange {
allow_retry = yes
winbind_retry_with_normalised_username = no
# Loaded module rlm_logintime
# Loading module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
logintime {
minimum_timeout = 60
# Loaded module rlm_expiration
# Loading module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
# Loaded module rlm_unpack
# Loading module "unpack" from file /etc/freeradius/3.0/mods-enabled/unpack
# Loaded module rlm_utf8
# Loading module "utf8" from file /etc/freeradius/3.0/mods-enabled/utf8
# Loading module "ntlm_auth" from file /etc/freeradius/3.0/mods-enabled/ntlm_auth
exec ntlm_auth {
wait = yes
program = "/path/to/ntlm_auth --request-nt-key --domain=MYDOMAIN --username=%{mschap:User-Name} --password=%{User-Password}"
shell_escape = yes
# Loading module "radutmp" from file /etc/freeradius/3.0/mods-enabled/radutmp
radutmp {
filename = "/var/log/freeradius/radutmp"
permissions = 384
caller_id = yes
# Loaded module rlm_ldap
# Loading module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
ldap {
server = "ldaps://ldap.google.com:636"
identity = "Well-Docum"
password = <<< secret >>>
sasl {
user_dn = "LDAP-UserDn"
user {
scope = "sub"
access_positive = yes
sasl {
group {
filter = "(objectClass=posixGroup)"
scope = "sub"
name_attribute = "cn"
membership_attribute = "memberOf"
cacheable_name = no
cacheable_dn = no
allow_dangling_group_ref = no
client {
filter = "(objectClass=radiusClient)"
scope = "sub"
base_dn = "dc=maerlantatheneum,dc=be"
profile {
options {
ldap_debug = 40
chase_referrals = yes
rebind = yes
net_timeout = 1
res_timeout = 10
srv_timelimit = 3
idle = 60
probes = 3
interval = 3
tls {
certificate_file = "/etc/freeradius/3.0/certs/ldap-client.crt"
private_key_file = "/etc/freeradius/3.0/certs/ldap-client.key"
start_tls = no
require_cert = "allow"
Creating attribute LDAP-Group
# Loading module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail auth_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail reply_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/reply-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail pre_proxy_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/pre-proxy-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail post_proxy_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/post-proxy-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loaded module rlm_eap
# Loading module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
eap {
default_eap_type = "md5"
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
max_sessions = 16384
instantiate {
# Instantiating module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
rlm_cache (cache_eap): Driver rlm_cache_rbtree (module rlm_cache_rbtree) loaded and linked
# Instantiating module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
# Instantiating module "files" from file /etc/freeradius/3.0/mods-enabled/files
reading pairlist file /etc/freeradius/3.0/mods-config/files/authorize
reading pairlist file /etc/freeradius/3.0/mods-config/files/accounting
reading pairlist file /etc/freeradius/3.0/mods-config/files/pre-proxy
# Instantiating module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
rlm_passwd: nfields: 3 keyfield 0(User-Name) listable: no
# Instantiating module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
# Instantiating module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/post-proxy
# Instantiating module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/pre-proxy
# Instantiating module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_reject
# Instantiating module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_challenge
# Instantiating module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/accounting_response
# Instantiating module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/huntgroups
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/hints
# Instantiating module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
# Instantiating module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
# Instantiating module "reject" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "fail" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "ok" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "handled" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "noop" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "updated" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "bangpath" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
rlm_mschap (mschap): using internal authentication
# Instantiating module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
# Instantiating module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
# Instantiating module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
rlm_ldap: libldap vendor: OpenLDAP, version: 20449
accounting {
reference = "%{tolower:type.%{Acct-Status-Type}}"
post-auth {
reference = "."
rlm_ldap (ldap): Initialising connection pool
pool {
start = 5
min = 3
max = 32
spare = 10
uses = 0
lifetime = 0
cleanup_interval = 30
idle_timeout = 60
retry_delay = 30
spread = no
rlm_ldap (ldap): Opening additional connection (0), 1 of 32 pending slots used
rlm_ldap (ldap): Connecting to ldaps://ldap.google.com:636
rlm_ldap (ldap): Waiting for bind result...
ber_get_next failed.
rlm_ldap (ldap): Bind successful
rlm_ldap (ldap): Opening additional connection (1), 1 of 31 pending slots used
rlm_ldap (ldap): Opening additional connection (2), 1 of 30 pending slots used
rlm_ldap (ldap): Opening additional connection (3), 1 of 29 pending slots used
rlm_ldap (ldap): Opening additional connection (4), 1 of 28 pending slots used
# Instantiating module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
rlm_detail (auth_log): 'User-Password' suppressed, will not appear in detail output
# Instantiating module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
# Linked to sub-module rlm_eap_md5
# Linked to sub-module rlm_eap_leap
# Linked to sub-module rlm_eap_gtc
gtc {
challenge = "Password: "
auth_type = "PAP"
# Linked to sub-module rlm_eap_tls
tls {
tls = "tls-common"
tls-config tls-common {
verify_depth = 0
ca_path = "/etc/freeradius/3.0/certs"
pem_file_type = yes
private_key_file = "/etc/freeradius/3.0/certs/server.pem"
certificate_file = "/etc/freeradius/3.0/certs/server.pem"
ca_file = "/etc/freeradius/3.0/certs/ca.pem"
private_key_password = <<< secret >>>
dh_file = "/etc/freeradius/3.0/certs/dh"
fragment_size = 1024
include_length = yes
auto_chain = yes
check_crl = no
check_all_crl = no
cipher_list = "DEFAULT"
cipher_server_preference = no
ecdh_curve = "prime256v1"
tls_max_version = ""
tls_min_version = "1.0"
cache {
enable = no
lifetime = 24
max_entries = 255
verify {
skip_if_ocsp_ok = no
ocsp {
enable = no
override_cert_url = yes
url = "http://127.0.0.1/ocsp/"
use_nonce = yes
timeout = 0
softfail = no
The configuration allows TLS 1.0 and/or TLS 1.1. We STRONGLY recommned using only TLS 1.2 for security
Please set: min_tls_version = "1.2"
# Linked to sub-module rlm_eap_ttls
ttls {
tls = "tls-common"
copy_request_to_tunnel = no
use_tunneled_reply = yes
virtual_server = "inner-tunnel"
require_client_cert = no
tls: Using cached TLS configuration from previous invocation
# Linked to sub-module rlm_eap_peap
peap {
tls = "tls-common"
default_eap_type = "mschapv2"
proxy_tunneled_request_as_eap = yes
soh = no
# Linked to sub-module rlm_eap_mschapv2
mschapv2 {
send_error = no
} # modules
radiusd: #### Loading Virtual Servers ####
server { # from file /etc/freeradius/3.0/radiusd.conf
} # server
server default { # from file /etc/freeradius/3.0/sites-enabled/default
# Loading authenticate {...}
# Loading authorize {...}
Ignoring "sql" (see raddb/mods-available/README.rst)
# Loading preacct {...}
# Loading accounting {...}
# Loading post-proxy {...}
# Loading post-auth {...}
} # server default
server inner-tunnel { # from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
# Loading session {...}
} # server inner-tunnel
radiusd: #### Opening IP addresses and Ports ####
listen {
type = "auth"
ipaddr = *
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "acct"
ipaddr = *
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "auth"
ipv6addr = ::
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "acct"
ipv6addr = ::
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "auth"
ipaddr = 127.0.0.1
port = 18120
Listening on auth address * port 1812 bound to server default
Listening on acct address * port 1813 bound to server default
Listening on auth address :: port 1812 bound to server default
Listening on acct address :: port 1813 bound to server default
Listening on auth address 127.0.0.1 port 18120 bound to server inner-tunnel
Listening on proxy address * port 48889
Listening on proxy address :: port 45643
Ready to process requests
(0) Received Access-Request Id 246 from 172.16.2.24:43616 to 172.16.88.201:1812 length 216
(0) User-Name = "mathias.maes"
(0) NAS-Identifier = "802aa8d21ff5"
(0) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(0) NAS-Port-Type = Wireless-802.11
(0) Service-Type = Framed-User
(0) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(0) Connect-Info = "CONNECT 0Mbps 802.11b"
(0) Acct-Session-Id = "F611C1164C9282AB"
(0) WLAN-Pairwise-Cipher = 1027076
(0) WLAN-Group-Cipher = 1027076
(0) WLAN-AKM-Suite = 1027073
(0) Framed-MTU = 1400
(0) EAP-Message = 0x02290011016d6174686961732e6d616573
(0) Message-Authenticator = 0xec786fb2149f058e3bbb2d03f8c7e125
(0) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(0) authorize {
(0) policy filter_username {
(0) if (&User-Name) {
(0) if (&User-Name) -> TRUE
(0) if (&User-Name =~ / /) {
(0) if (&User-Name =~ / /) -> FALSE
(0) if (&User-Name =~ /@[^@]*@/ ) {
(0) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(0) if (&User-Name =~ /\.\./ ) {
(0) if (&User-Name =~ /\.\./ ) -> FALSE
(0) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(0) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(0) if (&User-Name =~ /\.$/) {
(0) if (&User-Name =~ /\.$/) -> FALSE
(0) if (&User-Name =~ /@\./) {
(0) if (&User-Name =~ /@\./) -> FALSE
(0) } # if (&User-Name) = notfound
(0) } # policy filter_username = notfound
(0) [preprocess] = ok
(0) [chap] = noop
(0) [mschap] = noop
(0) [digest] = noop
(0) suffix: Checking for suffix after "@"
(0) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(0) suffix: No such realm "NULL"
(0) [suffix] = noop
(0) eap: Peer sent EAP Response (code 2) ID 41 length 17
(0) eap: EAP-Identity reply, returning 'ok' so we can short-circuit the rest of authorize
(0) [eap] = ok
(0) } # authorize = ok
(0) Found Auth-Type = eap
(0) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(0) authenticate {
(0) eap: Peer sent packet with method EAP Identity (1)
(0) eap: Calling submodule eap_md5 to process data
(0) eap_md5: Issuing MD5 Challenge
(0) eap: Sending EAP Request (code 1) ID 42 length 22
(0) eap: EAP session adding &reply:State = 0xff99fa83ffb3fec8
(0) [eap] = handled
(0) } # authenticate = handled
(0) Using Post-Auth-Type Challenge
(0) Challenge { ... } # empty sub-section is ignored
(0) Sent Access-Challenge Id 246 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(0) EAP-Message = 0x012a001604108da0d284c326a1c734587e4d1457acfb
(0) Message-Authenticator = 0x00000000000000000000000000000000
(0) State = 0xff99fa83ffb3fec8c4b146a7c9273cc4
(0) Finished request
Waking up in 4.9 seconds.
(1) Received Access-Request Id 247 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(1) User-Name = "mathias.maes"
(1) NAS-Identifier = "802aa8d21ff5"
(1) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(1) NAS-Port-Type = Wireless-802.11
(1) Service-Type = Framed-User
(1) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(1) Connect-Info = "CONNECT 0Mbps 802.11b"
(1) Acct-Session-Id = "F611C1164C9282AB"
(1) WLAN-Pairwise-Cipher = 1027076
(1) WLAN-Group-Cipher = 1027076
(1) WLAN-AKM-Suite = 1027073
(1) Framed-MTU = 1400
(1) EAP-Message = 0x022a00060315
(1) State = 0xff99fa83ffb3fec8c4b146a7c9273cc4
(1) Message-Authenticator = 0x6e32250725247d4a18f619df76c2dfdd
(1) session-state: No cached attributes
(1) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(1) authorize {
(1) policy filter_username {
(1) if (&User-Name) {
(1) if (&User-Name) -> TRUE
(1) if (&User-Name =~ / /) {
(1) if (&User-Name =~ / /) -> FALSE
(1) if (&User-Name =~ /@[^@]*@/ ) {
(1) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(1) if (&User-Name =~ /\.\./ ) {
(1) if (&User-Name =~ /\.\./ ) -> FALSE
(1) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(1) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(1) if (&User-Name =~ /\.$/) {
(1) if (&User-Name =~ /\.$/) -> FALSE
(1) if (&User-Name =~ /@\./) {
(1) if (&User-Name =~ /@\./) -> FALSE
(1) } # if (&User-Name) = notfound
(1) } # policy filter_username = notfound
(1) [preprocess] = ok
(1) [chap] = noop
(1) [mschap] = noop
(1) [digest] = noop
(1) suffix: Checking for suffix after "@"
(1) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(1) suffix: No such realm "NULL"
(1) [suffix] = noop
(1) eap: Peer sent EAP Response (code 2) ID 42 length 6
(1) eap: No EAP Start, assuming it's an on-going EAP conversation
(1) [eap] = updated
(1) [files] = noop
rlm_ldap (ldap): Reserved connection (0)
(1) ldap: EXPAND (uid=%{%{Stripped-User-Name}:-%{User-Name}})
(1) ldap: --> (uid=mathias.maes)
(1) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mathias.maes)", scope "sub"
(1) ldap: Waiting for search result...
(1) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(1) ldap: Processing user attributes
(1) ldap: WARNING: No "known good" password added. Ensure the admin user has permission to read the password attribute
(1) ldap: WARNING: PAP authentication will *NOT* work with Active Directory (if that is what you were trying to configure)
rlm_ldap (ldap): Released connection (0)
Need 5 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (5), 1 of 27 pending slots used
(1) [ldap] = ok
(1) [expiration] = noop
(1) [logintime] = noop
Not doing PAP as Auth-Type is already set.
(1) [pap] = noop
(1) if (User-Password) {
(1) if (User-Password) -> FALSE
(1) } # authorize = updated
(1) Found Auth-Type = eap
(1) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(1) authenticate {
(1) eap: Expiring EAP session with state 0xff99fa83ffb3fec8
(1) eap: Finished EAP session with state 0xff99fa83ffb3fec8
(1) eap: Previous EAP request found for state 0xff99fa83ffb3fec8, released from the list
(1) eap: Peer sent packet with method EAP NAK (3)
(1) eap: Found mutually acceptable type TTLS (21)
(1) eap: Calling submodule eap_ttls to process data
(1) eap_ttls: Initiating new TLS session
(1) eap_ttls: [eaptls start] = request
(1) eap: Sending EAP Request (code 1) ID 43 length 6
(1) eap: EAP session adding &reply:State = 0xff99fa83feb2efc8
(1) [eap] = handled
(1) } # authenticate = handled
(1) Using Post-Auth-Type Challenge
(1) Challenge { ... } # empty sub-section is ignored
(1) Sent Access-Challenge Id 247 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(1) EAP-Message = 0x012b00061520
(1) Message-Authenticator = 0x00000000000000000000000000000000
(1) State = 0xff99fa83feb2efc8c4b146a7c9273cc4
(1) Finished request
Waking up in 3.7 seconds.
(2) Received Access-Request Id 248 from 172.16.2.24:43616 to 172.16.88.201:1812 length 354
(2) User-Name = "mathias.maes"
(2) NAS-Identifier = "802aa8d21ff5"
(2) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(2) NAS-Port-Type = Wireless-802.11
(2) Service-Type = Framed-User
(2) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(2) Connect-Info = "CONNECT 0Mbps 802.11b"
(2) Acct-Session-Id = "F611C1164C9282AB"
(2) WLAN-Pairwise-Cipher = 1027076
(2) WLAN-Group-Cipher = 1027076
(2) WLAN-AKM-Suite = 1027073
(2) Framed-MTU = 1400
(2) EAP-Message = 0x022b00891500160301007e0100007a0303729d177dc6e282d6084ff59d6ec37e5c43da16c555cedf4cc26eb6bfaba422d500001ec02bc02fc02cc030cca9cca8c009c013c00ac014009c009d002f0035000a0100003300170000ff01000100000a00080006001d00170018000b00020100000d00140012040308040401050308050501080606010201
(2) State = 0xff99fa83feb2efc8c4b146a7c9273cc4
(2) Message-Authenticator = 0x8d3a6b12ff756ae9ed5b1117d5fd5f67
(2) session-state: No cached attributes
(2) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(2) authorize {
(2) policy filter_username {
(2) if (&User-Name) {
(2) if (&User-Name) -> TRUE
(2) if (&User-Name =~ / /) {
(2) if (&User-Name =~ / /) -> FALSE
(2) if (&User-Name =~ /@[^@]*@/ ) {
(2) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(2) if (&User-Name =~ /\.\./ ) {
(2) if (&User-Name =~ /\.\./ ) -> FALSE
(2) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(2) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(2) if (&User-Name =~ /\.$/) {
(2) if (&User-Name =~ /\.$/) -> FALSE
(2) if (&User-Name =~ /@\./) {
(2) if (&User-Name =~ /@\./) -> FALSE
(2) } # if (&User-Name) = notfound
(2) } # policy filter_username = notfound
(2) [preprocess] = ok
(2) [chap] = noop
(2) [mschap] = noop
(2) [digest] = noop
(2) suffix: Checking for suffix after "@"
(2) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(2) suffix: No such realm "NULL"
(2) [suffix] = noop
(2) eap: Peer sent EAP Response (code 2) ID 43 length 137
(2) eap: Continuing tunnel setup
(2) [eap] = ok
(2) } # authorize = ok
(2) Found Auth-Type = eap
(2) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(2) authenticate {
(2) eap: Expiring EAP session with state 0xff99fa83feb2efc8
(2) eap: Finished EAP session with state 0xff99fa83feb2efc8
(2) eap: Previous EAP request found for state 0xff99fa83feb2efc8, released from the list
(2) eap: Peer sent packet with method EAP TTLS (21)
(2) eap: Calling submodule eap_ttls to process data
(2) eap_ttls: Authenticate
(2) eap_ttls: Continuing EAP-TLS
(2) eap_ttls: [eaptls verify] = ok
(2) eap_ttls: Done initial handshake
(2) eap_ttls: (other): before SSL initialization
(2) eap_ttls: TLS_accept: before SSL initialization
(2) eap_ttls: <<< recv TLS 1.3 [length 007e]
(2) eap_ttls: TLS_accept: SSLv3/TLS read client hello
(2) eap_ttls: >>> send TLS 1.2 [length 003d]
(2) eap_ttls: TLS_accept: SSLv3/TLS write server hello
(2) eap_ttls: >>> send TLS 1.2 [length 095f]
(2) eap_ttls: TLS_accept: SSLv3/TLS write certificate
(2) eap_ttls: >>> send TLS 1.2 [length 014d]
(2) eap_ttls: TLS_accept: SSLv3/TLS write key exchange
(2) eap_ttls: >>> send TLS 1.2 [length 0004]
(2) eap_ttls: TLS_accept: SSLv3/TLS write server done
(2) eap_ttls: TLS_accept: Need to read more data: SSLv3/TLS write server done
(2) eap_ttls: TLS - In Handshake Phase
(2) eap_ttls: TLS - got 2817 bytes of data
(2) eap_ttls: [eaptls process] = handled
(2) eap: Sending EAP Request (code 1) ID 44 length 1004
(2) eap: EAP session adding &reply:State = 0xff99fa83fdb5efc8
(2) [eap] = handled
(2) } # authenticate = handled
(2) Using Post-Auth-Type Challenge
(2) Challenge { ... } # empty sub-section is ignored
(2) Sent Access-Challenge Id 248 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(2) EAP-Message = 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
(2) Message-Authenticator = 0x00000000000000000000000000000000
(2) State = 0xff99fa83fdb5efc8c4b146a7c9273cc4
(2) Finished request
(3) Received Access-Request Id 249 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(3) User-Name = "mathias.maes"
(3) NAS-Identifier = "802aa8d21ff5"
(3) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(3) NAS-Port-Type = Wireless-802.11
(3) Service-Type = Framed-User
(3) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(3) Connect-Info = "CONNECT 0Mbps 802.11b"
(3) Acct-Session-Id = "F611C1164C9282AB"
(3) WLAN-Pairwise-Cipher = 1027076
(3) WLAN-Group-Cipher = 1027076
(3) WLAN-AKM-Suite = 1027073
(3) Framed-MTU = 1400
(3) EAP-Message = 0x022c00061500
(3) State = 0xff99fa83fdb5efc8c4b146a7c9273cc4
(3) Message-Authenticator = 0x7d0f88f4c33bad1184e7c6867eacf50b
(3) session-state: No cached attributes
(3) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(3) authorize {
(3) policy filter_username {
(3) if (&User-Name) {
(3) if (&User-Name) -> TRUE
(3) if (&User-Name =~ / /) {
(3) if (&User-Name =~ / /) -> FALSE
(3) if (&User-Name =~ /@[^@]*@/ ) {
(3) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(3) if (&User-Name =~ /\.\./ ) {
(3) if (&User-Name =~ /\.\./ ) -> FALSE
(3) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(3) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(3) if (&User-Name =~ /\.$/) {
(3) if (&User-Name =~ /\.$/) -> FALSE
(3) if (&User-Name =~ /@\./) {
(3) if (&User-Name =~ /@\./) -> FALSE
(3) } # if (&User-Name) = notfound
(3) } # policy filter_username = notfound
(3) [preprocess] = ok
(3) [chap] = noop
(3) [mschap] = noop
(3) [digest] = noop
(3) suffix: Checking for suffix after "@"
(3) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(3) suffix: No such realm "NULL"
(3) [suffix] = noop
(3) eap: Peer sent EAP Response (code 2) ID 44 length 6
(3) eap: Continuing tunnel setup
(3) [eap] = ok
(3) } # authorize = ok
(3) Found Auth-Type = eap
(3) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(3) authenticate {
(3) eap: Expiring EAP session with state 0xff99fa83fdb5efc8
(3) eap: Finished EAP session with state 0xff99fa83fdb5efc8
(3) eap: Previous EAP request found for state 0xff99fa83fdb5efc8, released from the list
(3) eap: Peer sent packet with method EAP TTLS (21)
(3) eap: Calling submodule eap_ttls to process data
(3) eap_ttls: Authenticate
(3) eap_ttls: Continuing EAP-TLS
(3) eap_ttls: Peer ACKed our handshake fragment
(3) eap_ttls: [eaptls verify] = request
(3) eap_ttls: [eaptls process] = handled
(3) eap: Sending EAP Request (code 1) ID 45 length 1004
(3) eap: EAP session adding &reply:State = 0xff99fa83fcb4efc8
(3) [eap] = handled
(3) } # authenticate = handled
(3) Using Post-Auth-Type Challenge
(3) Challenge { ... } # empty sub-section is ignored
(3) Sent Access-Challenge Id 249 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(3) EAP-Message = 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
(3) Message-Authenticator = 0x00000000000000000000000000000000
(3) State = 0xff99fa83fcb4efc8c4b146a7c9273cc4
(3) Finished request
(4) Received Access-Request Id 250 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(4) User-Name = "mathias.maes"
(4) NAS-Identifier = "802aa8d21ff5"
(4) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(4) NAS-Port-Type = Wireless-802.11
(4) Service-Type = Framed-User
(4) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(4) Connect-Info = "CONNECT 0Mbps 802.11b"
(4) Acct-Session-Id = "F611C1164C9282AB"
(4) WLAN-Pairwise-Cipher = 1027076
(4) WLAN-Group-Cipher = 1027076
(4) WLAN-AKM-Suite = 1027073
(4) Framed-MTU = 1400
(4) EAP-Message = 0x022d00061500
(4) State = 0xff99fa83fcb4efc8c4b146a7c9273cc4
(4) Message-Authenticator = 0xabda589aae605e3af3151667fa842610
(4) session-state: No cached attributes
(4) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(4) authorize {
(4) policy filter_username {
(4) if (&User-Name) {
(4) if (&User-Name) -> TRUE
(4) if (&User-Name =~ / /) {
(4) if (&User-Name =~ / /) -> FALSE
(4) if (&User-Name =~ /@[^@]*@/ ) {
(4) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(4) if (&User-Name =~ /\.\./ ) {
(4) if (&User-Name =~ /\.\./ ) -> FALSE
(4) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(4) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(4) if (&User-Name =~ /\.$/) {
(4) if (&User-Name =~ /\.$/) -> FALSE
(4) if (&User-Name =~ /@\./) {
(4) if (&User-Name =~ /@\./) -> FALSE
(4) } # if (&User-Name) = notfound
(4) } # policy filter_username = notfound
(4) [preprocess] = ok
(4) [chap] = noop
(4) [mschap] = noop
(4) [digest] = noop
(4) suffix: Checking for suffix after "@"
(4) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(4) suffix: No such realm "NULL"
(4) [suffix] = noop
(4) eap: Peer sent EAP Response (code 2) ID 45 length 6
(4) eap: Continuing tunnel setup
(4) [eap] = ok
(4) } # authorize = ok
(4) Found Auth-Type = eap
(4) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(4) authenticate {
(4) eap: Expiring EAP session with state 0xff99fa83fcb4efc8
(4) eap: Finished EAP session with state 0xff99fa83fcb4efc8
(4) eap: Previous EAP request found for state 0xff99fa83fcb4efc8, released from the list
(4) eap: Peer sent packet with method EAP TTLS (21)
(4) eap: Calling submodule eap_ttls to process data
(4) eap_ttls: Authenticate
(4) eap_ttls: Continuing EAP-TLS
(4) eap_ttls: Peer ACKed our handshake fragment
(4) eap_ttls: [eaptls verify] = request
(4) eap_ttls: [eaptls process] = handled
(4) eap: Sending EAP Request (code 1) ID 46 length 839
(4) eap: EAP session adding &reply:State = 0xff99fa83fbb7efc8
(4) [eap] = handled
(4) } # authenticate = handled
(4) Using Post-Auth-Type Challenge
(4) Challenge { ... } # empty sub-section is ignored
(4) Sent Access-Challenge Id 250 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(4) EAP-Message = 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
(4) Message-Authenticator = 0x00000000000000000000000000000000
(4) State = 0xff99fa83fbb7efc8c4b146a7c9273cc4
(4) Finished request
(5) Received Access-Request Id 251 from 172.16.2.24:43616 to 172.16.88.201:1812 length 349
(5) User-Name = "mathias.maes"
(5) NAS-Identifier = "802aa8d21ff5"
(5) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(5) NAS-Port-Type = Wireless-802.11
(5) Service-Type = Framed-User
(5) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(5) Connect-Info = "CONNECT 0Mbps 802.11b"
(5) Acct-Session-Id = "F611C1164C9282AB"
(5) WLAN-Pairwise-Cipher = 1027076
(5) WLAN-Group-Cipher = 1027076
(5) WLAN-AKM-Suite = 1027073
(5) Framed-MTU = 1400
(5) EAP-Message = 0x022e008415001603030046100000424104d9cedffa35763379cc31c62d194b431103b559580a1640d39afff113249f3ae59b8bdea220cac40e2b78d1016c053d2c339785530e6b39515c6a45c497e34e0814030300010116030300280000000000000000e4592bee43925bdfa2f9310f01db8f42fad0f37c4a6c9cb2f09ee58a8f0b08c4
(5) State = 0xff99fa83fbb7efc8c4b146a7c9273cc4
(5) Message-Authenticator = 0xcea397dfdac287d0f74930f84477618a
(5) session-state: No cached attributes
(5) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(5) authorize {
(5) policy filter_username {
(5) if (&User-Name) {
(5) if (&User-Name) -> TRUE
(5) if (&User-Name =~ / /) {
(5) if (&User-Name =~ / /) -> FALSE
(5) if (&User-Name =~ /@[^@]*@/ ) {
(5) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(5) if (&User-Name =~ /\.\./ ) {
(5) if (&User-Name =~ /\.\./ ) -> FALSE
(5) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(5) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(5) if (&User-Name =~ /\.$/) {
(5) if (&User-Name =~ /\.$/) -> FALSE
(5) if (&User-Name =~ /@\./) {
(5) if (&User-Name =~ /@\./) -> FALSE
(5) } # if (&User-Name) = notfound
(5) } # policy filter_username = notfound
(5) [preprocess] = ok
(5) [chap] = noop
(5) [mschap] = noop
(5) [digest] = noop
(5) suffix: Checking for suffix after "@"
(5) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(5) suffix: No such realm "NULL"
(5) [suffix] = noop
(5) eap: Peer sent EAP Response (code 2) ID 46 length 132
(5) eap: Continuing tunnel setup
(5) [eap] = ok
(5) } # authorize = ok
(5) Found Auth-Type = eap
(5) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(5) authenticate {
(5) eap: Expiring EAP session with state 0xff99fa83fbb7efc8
(5) eap: Finished EAP session with state 0xff99fa83fbb7efc8
(5) eap: Previous EAP request found for state 0xff99fa83fbb7efc8, released from the list
(5) eap: Peer sent packet with method EAP TTLS (21)
(5) eap: Calling submodule eap_ttls to process data
(5) eap_ttls: Authenticate
(5) eap_ttls: Continuing EAP-TLS
(5) eap_ttls: [eaptls verify] = ok
(5) eap_ttls: Done initial handshake
(5) eap_ttls: TLS_accept: SSLv3/TLS write server done
(5) eap_ttls: <<< recv TLS 1.2 [length 0046]
(5) eap_ttls: TLS_accept: SSLv3/TLS read client key exchange
(5) eap_ttls: TLS_accept: SSLv3/TLS read change cipher spec
(5) eap_ttls: <<< recv TLS 1.2 [length 0010]
(5) eap_ttls: TLS_accept: SSLv3/TLS read finished
(5) eap_ttls: >>> send TLS 1.2 [length 0001]
(5) eap_ttls: TLS_accept: SSLv3/TLS write change cipher spec
(5) eap_ttls: >>> send TLS 1.2 [length 0010]
(5) eap_ttls: TLS_accept: SSLv3/TLS write finished
(5) eap_ttls: (other): SSL negotiation finished successfully
(5) eap_ttls: TLS - Connection Established
(5) eap_ttls: TLS-Session-Cipher-Suite = "ECDHE-RSA-AES128-GCM-SHA256"
(5) eap_ttls: TLS-Session-Version = "TLS 1.2"
(5) eap_ttls: TLS - got 51 bytes of data
(5) eap_ttls: [eaptls process] = handled
(5) eap: Sending EAP Request (code 1) ID 47 length 61
(5) eap: EAP session adding &reply:State = 0xff99fa83fab6efc8
(5) [eap] = handled
(5) } # authenticate = handled
(5) Using Post-Auth-Type Challenge
(5) Challenge { ... } # empty sub-section is ignored
(5) session-state: Saving cached attributes
(5) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES128-GCM-SHA256"
(5) TLS-Session-Version = "TLS 1.2"
(5) Sent Access-Challenge Id 251 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(5) EAP-Message = 0x012f003d1580000000331403030001011603030028cf633a08613245d8e3beaa6506ee8b1f56248329d8cca80c924e11b3756c22e662b0c90689caa901
(5) Message-Authenticator = 0x00000000000000000000000000000000
(5) State = 0xff99fa83fab6efc8c4b146a7c9273cc4
(5) Finished request
(6) Received Access-Request Id 252 from 172.16.2.24:43616 to 172.16.88.201:1812 length 296
(6) User-Name = "mathias.maes"
(6) NAS-Identifier = "802aa8d21ff5"
(6) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(6) NAS-Port-Type = Wireless-802.11
(6) Service-Type = Framed-User
(6) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(6) Connect-Info = "CONNECT 0Mbps 802.11b"
(6) Acct-Session-Id = "F611C1164C9282AB"
(6) WLAN-Pairwise-Cipher = 1027076
(6) WLAN-Group-Cipher = 1027076
(6) WLAN-AKM-Suite = 1027073
(6) Framed-MTU = 1400
(6) EAP-Message = 0x022f004f1500170303004400000000000000010df81479983cb3977fec344ec54a11c551d5031c7a0a253c1454278e7015bfe37014bbc3b0ceaeb6ba3831674a0c4bed74d8fbbb528e41b0db1619d1
(6) State = 0xff99fa83fab6efc8c4b146a7c9273cc4
(6) Message-Authenticator = 0x113b2fbc053bd956b188111645901e53
(6) Restoring &session-state
(6) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES128-GCM-SHA256"
(6) &session-state:TLS-Session-Version = "TLS 1.2"
(6) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(6) authorize {
(6) policy filter_username {
(6) if (&User-Name) {
(6) if (&User-Name) -> TRUE
(6) if (&User-Name =~ / /) {
(6) if (&User-Name =~ / /) -> FALSE
(6) if (&User-Name =~ /@[^@]*@/ ) {
(6) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(6) if (&User-Name =~ /\.\./ ) {
(6) if (&User-Name =~ /\.\./ ) -> FALSE
(6) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(6) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(6) if (&User-Name =~ /\.$/) {
(6) if (&User-Name =~ /\.$/) -> FALSE
(6) if (&User-Name =~ /@\./) {
(6) if (&User-Name =~ /@\./) -> FALSE
(6) } # if (&User-Name) = notfound
(6) } # policy filter_username = notfound
(6) [preprocess] = ok
(6) [chap] = noop
(6) [mschap] = noop
(6) [digest] = noop
(6) suffix: Checking for suffix after "@"
(6) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(6) suffix: No such realm "NULL"
(6) [suffix] = noop
(6) eap: Peer sent EAP Response (code 2) ID 47 length 79
(6) eap: Continuing tunnel setup
(6) [eap] = ok
(6) } # authorize = ok
(6) Found Auth-Type = eap
(6) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(6) authenticate {
(6) eap: Expiring EAP session with state 0xff99fa83fab6efc8
(6) eap: Finished EAP session with state 0xff99fa83fab6efc8
(6) eap: Previous EAP request found for state 0xff99fa83fab6efc8, released from the list
(6) eap: Peer sent packet with method EAP TTLS (21)
(6) eap: Calling submodule eap_ttls to process data
(6) eap_ttls: Authenticate
(6) eap_ttls: Continuing EAP-TLS
(6) eap_ttls: [eaptls verify] = ok
(6) eap_ttls: Done initial handshake
(6) eap_ttls: [eaptls process] = ok
(6) eap_ttls: Session established. Proceeding to decode tunneled attributes
(6) eap_ttls: Got tunneled request
(6) eap_ttls: User-Name = "mathias.maes"
(6) eap_ttls: User-Password = "xxxxxxxxxxxxxxxxxxxxxxx"
(6) eap_ttls: FreeRADIUS-Proxied-To = 127.0.0.1
(6) eap_ttls: Sending tunneled request
(6) Virtual server inner-tunnel received request
(6) User-Password = "xxxxxxxxxxxxxxxxxxxxxx"
(6) FreeRADIUS-Proxied-To = 127.0.0.1
(6) WARNING: Outer and inner identities are the same. User privacy is compromised.
(6) server inner-tunnel {
(6) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(6) authorize {
(6) [suffix] = noop
(6) update control {
(6) &Proxy-To-Realm := LOCAL
(6) } # update control = noop
(6) eap: No EAP-Message, not doing EAP
(6) [eap] = noop
rlm_ldap (ldap): Reserved connection (1)
(6) ldap: EXPAND (uid=%{%{Stripped-User-Name}:-%{User-Name}})
(6) ldap: --> (uid=mathias.maes)
(6) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mathias.maes)", scope "sub"
(6) ldap: Waiting for search result...
(6) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(6) ldap: Processing user attributes
(6) ldap: WARNING: No "known good" password added. Ensure the admin user has permission to read the password attribute
(6) ldap: WARNING: PAP authentication will *NOT* work with Active Directory (if that is what you were trying to configure)
rlm_ldap (ldap): Released connection (1)
Need 4 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (6), 1 of 26 pending slots used
(6) [ldap] = ok
(6) [expiration] = noop
(6) [logintime] = noop
(6) [pap] = noop
(6) if (User-Password) {
(6) if (User-Password) -> TRUE
(6) Auth-Type := ldap
(6) } # if (User-Password) = noop
(6) Found Auth-Type = ldap
(6) # Executing group from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(6) authenticate {
rlm_ldap (ldap): Reserved connection (2)
(6) ldap: Login attempt by "mathias.maes"
(6) ldap: Using user DN from request "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(6) ldap: Waiting for bind result...
(6) ldap: Bind successful
(6) ldap: Bind as user "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be" was successful
rlm_ldap (ldap): Released connection (2)
Need 3 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (7), 1 of 25 pending slots used
(6) [ldap] = ok
(6) } # authenticate = ok
(6) # Executing section post-auth from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(6) post-auth {
(6) if (LDAP-Group == "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be"
rlm_ldap (ldap): Reserved connection (3)
(6) Using user DN from request "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(6) Checking user object's memberOf attributes
(6) Performing unfiltered search in "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be", scope "base"
(6) Waiting for search result...
(6) Processing memberOf value "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=classroom_docenten,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=iedereen,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=informatica,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=sharpinfo,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
rlm_ldap (ldap): Released connection (3)
Need 2 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (8), 1 of 24 pending slots used
(6) User is not a member of "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be"
(6) if (LDAP-Group == "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be") -> FALSE
(6) elsif (LDAP-Group == "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be"
rlm_ldap (ldap): Reserved connection (4)
rlm_ldap (ldap): Released connection (4)
Need 1 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (9), 1 of 23 pending slots used
(6) User is not a member of "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be"
(6) elsif (LDAP-Group == "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be") -> FALSE
(6) elsif (LDAP-Group == "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be"
(6) User is not a member of "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be"
(6) elsif (LDAP-Group == "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be") -> FALSE
rlm_ldap (ldap): Reserved connection (5)
rlm_ldap (ldap): Released connection (5)
(6) elsif (LDAP-Group == "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be"
(6) User found in group DN "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be". Comparison between membership: dn, check: dn
(6) elsif (LDAP-Group == "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be") -> TRUE
(6) update reply {
(6) Tunnel-Type = VLAN
(6) Tunnel-Medium-Type = IEEE-802
(6) Tunnel-Private-Group-Id = 10
(6) } # update reply = noop
(6) } # elsif (LDAP-Group == "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be") = noop
(6) ... skipping else: Preceding "if" was taken
(6) if (1) {
(6) if (1) -> TRUE
(6) if (1) {
(6) update reply {
(6) User-Name !* ANY
(6) Message-Authenticator !* ANY
(6) EAP-Message !* ANY
(6) Proxy-State !* ANY
(6) MS-MPPE-Encryption-Types !* ANY
(6) MS-MPPE-Encryption-Policy !* ANY
(6) MS-MPPE-Send-Key !* ANY
(6) MS-MPPE-Recv-Key !* ANY
(6) update {
(6) &outer.session-state::Tunnel-Type += &reply:Tunnel-Type• -> VLAN
(6) &outer.session-state::Tunnel-Medium-Type += &reply:Tunnel-Medium-Type• -> IEEE-802
(6) &outer.session-state::Tunnel-Private-Group-Id += &reply:Tunnel-Private-Group-Id• -> '10'
(6) } # update = noop
(6) } # if (1) = noop
(6) } # post-auth = noop
(6) } # server inner-tunnel
(6) Virtual server sending reply
(6) Tunnel-Private-Group-Id = "10"
(6) eap_ttls: Got tunneled Access-Accept
(6) eap: Sending EAP Success (code 3) ID 47 length 4
(6) eap: Freeing handler
(6) [eap] = ok
(6) # Executing section post-auth from file /etc/freeradius/3.0/sites-enabled/default
(6) post-auth {
(6) if (session-state:User-Name && reply:User-Name && request:User-Name && (reply:User-Name == request:User-Name)) {
(6) if (session-state:User-Name && reply:User-Name && request:User-Name && (reply:User-Name == request:User-Name)) -> FALSE
(6) update {
(6) &reply::TLS-Session-Cipher-Suite += &session-state:TLS-Session-Cipher-Suite• -> 'ECDHE-RSA-AES128-GCM-SHA256'
(6) &reply::TLS-Session-Version += &session-state:TLS-Session-Version• -> 'TLS 1.2'
(6) &reply::Tunnel-Type += &session-state:Tunnel-Type• -> VLAN
(6) &reply::Tunnel-Medium-Type += &session-state:Tunnel-Medium-Type• -> IEEE-802
(6) &reply::Tunnel-Private-Group-Id += &session-state:Tunnel-Private-Group-Id• -> '10'
(6) [exec] = noop
(6) policy remove_reply_message_if_eap {
(6) if (&reply:EAP-Message && &reply:Reply-Message) {
(6) if (&reply:EAP-Message && &reply:Reply-Message) -> FALSE
(6) else {
(6) [noop] = noop
(6) } # else = noop
(6) } # policy remove_reply_message_if_eap = noop
(6) Sent Access-Accept Id 252 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(6) MS-MPPE-Recv-Key = 0x1b44664b78cff6fc3f330eb258a1158b7f1b1e65ea07bb0465e5b966aca6d2db
(6) MS-MPPE-Send-Key = 0xf28ea12efb799871770dff57e799be42cecd67c7a77b58b137b452a3ce88a4d2
(6) EAP-Message = 0x032f0004
(6) Message-Authenticator = 0x00000000000000000000000000000000
(6) Tunnel-Type += VLAN
(6) Tunnel-Medium-Type += IEEE-802
(6) Tunnel-Private-Group-Id += "10"
(6) Finished request
(0) Cleaning up request packet ID 246 with timestamp +38
(1) Cleaning up request packet ID 247 with timestamp +38
(2) Cleaning up request packet ID 248 with timestamp +40
(3) Cleaning up request packet ID 249 with timestamp +40
(4) Cleaning up request packet ID 250 with timestamp +40
(5) Cleaning up request packet ID 251 with timestamp +40
(6) Sending duplicate reply to client StilleLeraarskamer port 43616 - ID: 252
Waking up in 9.9 seconds.
(6) Cleaning up request packet ID 252 with timestamp +40
En dan hier mijn Freeradius log met Windows (zelfde credentials)
(0) Received Access-Request Id 187 from 172.16.2.24:43616 to 172.16.88.201:1812 length 216
(0) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(0) Acct-Session-Id = "91947FC2865BC082"
(0) EAP-Message = 0x02720011016d6174686961732e6d616573
(0) Message-Authenticator = 0x515f9696923540a58f3eeae482177330
(0) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(0) authorize {
(0) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(0) [chap] = noop
(0) [mschap] = noop
(0) [digest] = noop
(0) [suffix] = noop
(0) eap: Peer sent EAP Response (code 2) ID 114 length 17
(0) [eap] = ok
(0) authenticate {
(0) eap: Sending EAP Request (code 1) ID 115 length 22
(0) eap: EAP session adding &reply:State = 0x8992220389e12690
(0) [eap] = handled
(0) Sent Access-Challenge Id 187 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(0) EAP-Message = 0x017300160410b1fd2b55fe05c489f528ef67441d4e20
(0) State = 0x8992220389e12690bf08241ae32c8474
(1) Received Access-Request Id 188 from 172.16.2.24:43616 to 172.16.88.201:1812 length 224
(1) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(1) Acct-Session-Id = "91947FC2865BC082"
(1) EAP-Message = 0x02730007031915
(1) State = 0x8992220389e12690bf08241ae32c8474
(1) Message-Authenticator = 0x6a137ff79215091f27021135b407b85c
(1) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(1) authorize {
(1) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(1) [chap] = noop
(1) [mschap] = noop
(1) [digest] = noop
(1) [suffix] = noop
(1) eap: Peer sent EAP Response (code 2) ID 115 length 7
(1) [eap] = updated
(1) [files] = noop
(1) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mat hias.maes)", scope "sub"
(1) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum, ou=Users,dc=maerlantatheneum,dc=be"
(1) ldap: WARNING: No "known good" password added. Ensure the admin user has per mission to read the password attribute
(1) [ldap] = ok
(1) [pap] = noop
(1) authenticate {
(1) eap: Expiring EAP session with state 0x8992220389e12690
(1) eap: Finished EAP session with state 0x8992220389e12690
(1) eap: Previous EAP request found for state 0x8992220389e12690, released from the list
(1) eap: Found mutually acceptable type PEAP (25)
(1) eap: Calling submodule eap_peap to process data
(1) eap_peap: Initiating new TLS session
(1) eap_peap: [eaptls start] = request
(1) eap: Sending EAP Request (code 1) ID 116 length 6
(1) eap: EAP session adding &reply:State = 0x8992220388e63b90
(1) [eap] = handled
(1) Sent Access-Challenge Id 188 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(1) EAP-Message = 0x017400061920
(1) State = 0x8992220388e63b90bf08241ae32c8474
(2) Received Access-Request Id 189 from 172.16.2.24:43616 to 172.16.88.201:1812 length 415
(2) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(2) Acct-Session-Id = "91947FC2865BC082"
(2) EAP-Message = 0x027400c61980000000bc16030300b7010000b303035ef1b84950ab98e3 5a88c093aa155fa457545259e9793f91f43d3d9e260d05f620a3350000e8831c94e64a00758ed88b 0f89d893ab528df0a8942760fdf3b604c1002ac02cc02bc030c02f009f009ec024c023c028c027c0 0ac009c014c013009d009c003d003c0035002f000a01000040000500050100000000000a00080006 001d00170018000b00020100000d0014001204010501020104030503020302020601060300230000 00170000ff01000100
(2) State = 0x8992220388e63b90bf08241ae32c8474
(2) Message-Authenticator = 0xbfe3022bd53b0a25be827b4eaa3e058b
(2) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(2) authorize {
(2) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(2) [chap] = noop
(2) [mschap] = noop
(2) [digest] = noop
(2) [suffix] = noop
(2) eap: Peer sent EAP Response (code 2) ID 116 length 198
(2) [eap] = ok
(2) authenticate {
(2) eap: Expiring EAP session with state 0x8992220388e63b90
(2) eap: Finished EAP session with state 0x8992220388e63b90
(2) eap: Previous EAP request found for state 0x8992220388e63b90, released from the list
(2) eap: Peer sent packet with method EAP PEAP (25)
(2) eap: Calling submodule eap_peap to process data
(2) eap_peap: Continuing EAP-TLS
(2) eap_peap: Peer indicated complete TLS record size will be 188 bytes
(2) eap_peap: Got complete TLS record (188 bytes)
(2) eap_peap: [eaptls verify] = length included
(2) eap_peap: (other): before SSL initialization
(2) eap_peap: TLS_accept: before SSL initialization
(2) eap_peap: <<< recv TLS 1.3 [length 00b7]
(2) eap_peap: TLS_accept: SSLv3/TLS read client hello
(2) eap_peap: >>> send TLS 1.2 [length 003d]
(2) eap_peap: TLS_accept: SSLv3/TLS write server hello
(2) eap_peap: >>> send TLS 1.2 [length 095f]
(2) eap_peap: TLS_accept: SSLv3/TLS write certificate
(2) eap_peap: >>> send TLS 1.2 [length 014d]
(2) eap_peap: TLS_accept: SSLv3/TLS write key exchange
(2) eap_peap: >>> send TLS 1.2 [length 0004]
(2) eap_peap: TLS_accept: SSLv3/TLS write server done
(2) eap_peap: TLS_accept: Need to read more data: SSLv3/TLS write server done
(2) eap_peap: TLS - In Handshake Phase
(2) eap_peap: TLS - got 2817 bytes of data
(2) eap_peap: [eaptls process] = handled
(2) eap: Sending EAP Request (code 1) ID 117 length 1004
(2) eap: EAP session adding &reply:State = 0x899222038be73b90
(2) [eap] = handled
(2) Sent Access-Challenge Id 189 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(2) EAP-Message = 0x017503ec19c000000b01160303003d020000390303ea8e43a59953f574 9627d6aaa5ec610f90e902b987e64922c6d93f7c7699c11000c030000011ff01000100000b000403 00010200170000160303095f0b00095b00095800040c30820408308202f0a003020102020103300d 06092a864886f70d01010b05003081ab310b30090603550406130242453118301606035504080c0f 576573742d566c61616e646572656e3115301306035504070c0c426c616e6b656e6265726765311a 3018060355040a0c114d6165726c616e7420417468656e65756d3126302406092a864886f70d0109 011617696374406d6165726c616e74617468656e65756d2e62653127302506035504030c1e4d6165 726c616e7420436572746966696361746520417574686f72697479301e170d323030363232313230 3731395a170d3238303930383132303731395a308191310b30090603550406130242453118301606 035504080c0f576573742d566c61616e646572656e311a301806
(2) State = 0x899222038be73b90bf08241ae32c8474
(3) Received Access-Request Id 190 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(3) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(3) Acct-Session-Id = "91947FC2865BC082"
(3) EAP-Message = 0x027500061900
(3) State = 0x899222038be73b90bf08241ae32c8474
(3) Message-Authenticator = 0xeda3f1678d96ef5860af25db6c4580ae
(3) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(3) authorize {
(3) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(3) [chap] = noop
(3) [mschap] = noop
(3) [digest] = noop
(3) [suffix] = noop
(3) eap: Peer sent EAP Response (code 2) ID 117 length 6
(3) [eap] = ok
(3) authenticate {
(3) eap: Expiring EAP session with state 0x899222038be73b90
(3) eap: Finished EAP session with state 0x899222038be73b90
(3) eap: Previous EAP request found for state 0x899222038be73b90, released from the list
(3) eap: Peer sent packet with method EAP PEAP (25)
(3) eap: Calling submodule eap_peap to process data
(3) eap_peap: Continuing EAP-TLS
(3) eap_peap: Peer ACKed our handshake fragment
(3) eap_peap: [eaptls verify] = request
(3) eap_peap: [eaptls process] = handled
(3) eap: Sending EAP Request (code 1) ID 118 length 1000
(3) eap: EAP session adding &reply:State = 0x899222038ae43b90
(3) [eap] = handled
(3) Sent Access-Challenge Id 190 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(3) EAP-Message = 0x017603e8194070488ce412eba7500f4d512568bd1d5209d0ad23dd1aaa a05927345a928880590587613a24aca2646c60f387f26fc46616d66ca22af9a18fa8db3dc1ed6173 7e6a2853ac59556b98b291415a51eb702d46518ca694d63afd6941e22d7c05578b40ab6a4182f50f f203346d98eb2a76bd46b0578116fb0416817971000546308205423082042aa003020102021422f4 15a6bd400b4959d074420f3af2929e3504a5300d06092a864886f70d01010b05003081ab310b3009 0603550406130242453118301606035504080c0f576573742d566c61616e646572656e3115301306 035504070c0c426c616e6b656e6265726765311a3018060355040a0c114d6165726c616e74204174 68656e65756d3126302406092a864886f70d0109011617696374406d6165726c616e74617468656e 65756d2e62653127302506035504030c1e4d6165726c616e74204365727469666963617465204175 74686f72697479301e170d3230303632323132303635305a170d
(3) State = 0x899222038ae43b90bf08241ae32c8474
(4) Received Access-Request Id 191 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(4) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(4) Acct-Session-Id = "91947FC2865BC082"
(4) EAP-Message = 0x027600061900
(4) State = 0x899222038ae43b90bf08241ae32c8474
(4) Message-Authenticator = 0xa2086c1e567ed9165fcb905e57e9caf5
(4) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(4) authorize {
(4) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(4) [chap] = noop
(4) [mschap] = noop
(4) [digest] = noop
(4) [suffix] = noop
(4) eap: Peer sent EAP Response (code 2) ID 118 length 6
(4) [eap] = ok
(4) authenticate {
(4) eap: Expiring EAP session with state 0x899222038ae43b90
(4) eap: Finished EAP session with state 0x899222038ae43b90
(4) eap: Previous EAP request found for state 0x899222038ae43b90, released from the list
(4) eap: Peer sent packet with method EAP PEAP (25)
(4) eap: Calling submodule eap_peap to process data
(4) eap_peap: Continuing EAP-TLS
(4) eap_peap: Peer ACKed our handshake fragment
(4) eap_peap: [eaptls verify] = request
(4) eap_peap: [eaptls process] = handled
(4) eap: Sending EAP Request (code 1) ID 119 length 835
(4) eap: EAP session adding &reply:State = 0x899222038de53b90
(4) [eap] = handled
(4) Sent Access-Challenge Id 191 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(4) EAP-Message = 0x0177034319006765311a3018060355040a0c114d6165726c616e742041 7468656e65756d3126302406092a864886f70d0109011617696374406d6165726c616e7461746865 6e65756d2e62653127302506035504030c1e4d6165726c616e742043657274696669636174652041 7574686f72697479821422f415a6bd400b4959d074420f3af2929e3504a5300f0603551d130101ff 040530030101ff30360603551d1f042f302d302ba029a0278625687474703a2f2f7777772e657861 6d706c652e6f72672f6578616d706c655f63612e63726c300d06092a864886f70d01010b05000382 0101001b15ac9e8823380db4f5cd501c671a15f6aa92262343001d1792cbeb33aff78f57b20306b1 84c7dcc4633daeed83a6e24bf2eed1eaee09050c9e09e2c6505857d0c4ffb0556ec0f65bdaf335af 1ba670a759ac6cc5cca630793f1e0dc9b2e9ac842a377944815c8174fced0736dacdf63e1fdc41b8 0d1374c6c57b5a1e308fc9f9311a56972cc72ff3812a9be3a00f
(4) State = 0x899222038de53b90bf08241ae32c8474
(5) Received Access-Request Id 192 from 172.16.2.24:43616 to 172.16.88.201:1812 length 353
(5) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(5) Acct-Session-Id = "91947FC2865BC082"
(5) EAP-Message = 0x0277008819800000007e16030300461000004241048b429ff5a317563b 7da86072baa0a06ddf0acf9bd093c9cdad91e512d268070941cf7f9edb8a34ea678d2669435a8fde 3d45f5e0376d5804d6051caccec292981403030001011603030028000000000000000056542f752d 543b1412aa0b51cf32485f64636ebceb87c480b5a4af2967654d12
(5) State = 0x899222038de53b90bf08241ae32c8474
(5) Message-Authenticator = 0xbcb9083b3b2c8b1c84e4c954d0761d67
(5) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(5) authorize {
(5) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(5) [chap] = noop
(5) [mschap] = noop
(5) [digest] = noop
(5) [suffix] = noop
(5) eap: Peer sent EAP Response (code 2) ID 119 length 136
(5) [eap] = ok
(5) authenticate {
(5) eap: Expiring EAP session with state 0x899222038de53b90
(5) eap: Finished EAP session with state 0x899222038de53b90
(5) eap: Previous EAP request found for state 0x899222038de53b90, released from the list
(5) eap: Peer sent packet with method EAP PEAP (25)
(5) eap: Calling submodule eap_peap to process data
(5) eap_peap: Continuing EAP-TLS
(5) eap_peap: Peer indicated complete TLS record size will be 126 bytes
(5) eap_peap: Got complete TLS record (126 bytes)
(5) eap_peap: [eaptls verify] = length included
(5) eap_peap: TLS_accept: SSLv3/TLS write server done
(5) eap_peap: <<< recv TLS 1.2 [length 0046]
(5) eap_peap: TLS_accept: SSLv3/TLS read client key exchange
(5) eap_peap: TLS_accept: SSLv3/TLS read change cipher spec
(5) eap_peap: <<< recv TLS 1.2 [length 0010]
(5) eap_peap: TLS_accept: SSLv3/TLS read finished
(5) eap_peap: >>> send TLS 1.2 [length 0001]
(5) eap_peap: TLS_accept: SSLv3/TLS write change cipher spec
(5) eap_peap: >>> send TLS 1.2 [length 0010]
(5) eap_peap: TLS_accept: SSLv3/TLS write finished
(5) eap_peap: (other): SSL negotiation finished successfully
(5) eap_peap: TLS - Connection Established
(5) eap_peap: TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(5) eap_peap: TLS-Session-Version = "TLS 1.2"
(5) eap_peap: TLS - got 51 bytes of data
(5) eap_peap: [eaptls process] = handled
(5) eap: Sending EAP Request (code 1) ID 120 length 57
(5) eap: EAP session adding &reply:State = 0x899222038cea3b90
(5) [eap] = handled
(5) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(5) Sent Access-Challenge Id 192 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(5) EAP-Message = 0x01780039190014030300010116030300285fb253d979c740904027949a 5e2d92a0cee956cab654dbb996b86aa71a8b29cbe4ecaaddf16277fb
(5) State = 0x899222038cea3b90bf08241ae32c8474
(6) Received Access-Request Id 193 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(6) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(6) Acct-Session-Id = "91947FC2865BC082"
(6) EAP-Message = 0x027800061900
(6) State = 0x899222038cea3b90bf08241ae32c8474
(6) Message-Authenticator = 0xc2a64f445aab020dba5dbe2e5007f270
(6) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(6) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(6) authorize {
(6) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(6) [chap] = noop
(6) [mschap] = noop
(6) [digest] = noop
(6) [suffix] = noop
(6) eap: Peer sent EAP Response (code 2) ID 120 length 6
(6) [eap] = ok
(6) authenticate {
(6) eap: Expiring EAP session with state 0x899222038cea3b90
(6) eap: Finished EAP session with state 0x899222038cea3b90
(6) eap: Previous EAP request found for state 0x899222038cea3b90, released from the list
(6) eap: Peer sent packet with method EAP PEAP (25)
(6) eap: Calling submodule eap_peap to process data
(6) eap_peap: Continuing EAP-TLS
(6) eap_peap: Peer ACKed our handshake fragment. handshake is finished
(6) eap_peap: [eaptls verify] = success
(6) eap_peap: [eaptls process] = success
(6) eap_peap: Session established. Decoding tunneled attributes
(6) eap_peap: PEAP state TUNNEL ESTABLISHED
(6) eap: Sending EAP Request (code 1) ID 121 length 40
(6) eap: EAP session adding &reply:State = 0x899222038feb3b90
(6) [eap] = handled
(6) } # authenticate = handled
(6) Using Post-Auth-Type Challenge
(6) Challenge { ... } # empty sub-section is ignored
(6) session-state: Saving cached attributes
(6) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(6) TLS-Session-Version = "TLS 1.2"
(6) Sent Access-Challenge Id 193 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(6) EAP-Message = 0x017900281900170303001d5fb253d979c74091903e99498f277d8556b9 8dc21e6eeedc1aed42a81a
(6) State = 0x899222038feb3b90bf08241ae32c8474
Waking up in 0.9 seconds.
(7) Received Access-Request Id 194 from 172.16.2.24:43616 to 172.16.88.201:1812 length 265
(7) User-Name = "mathias.maes"
(7) NAS-Identifier = "802aa8d21ff5"
(7) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(7) NAS-Port-Type = Wireless-802.11
(7) Service-Type = Framed-User
(7) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(7) Connect-Info = "CONNECT 0Mbps 802.11b"
(7) Acct-Session-Id = "91947FC2865BC082"
(7) WLAN-Pairwise-Cipher = 1027076
(7) WLAN-Group-Cipher = 1027076
(7) WLAN-AKM-Suite = 1027073
(7) Framed-MTU = 1400
(7) EAP-Message = 0x0279003019001703030025000000000000000163ae27ed6104c9ba4fd4 b42a8a5d6e01c023c9203e1187756780144b95
(7) State = 0x899222038feb3b90bf08241ae32c8474
(7) Message-Authenticator = 0x04c4a4ba869547230d3d295735f2d4fa
(7) Restoring &session-state
(7) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(7) &session-state:TLS-Session-Version = "TLS 1.2"
(7) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(7) authorize {
(7) policy filter_username {
(7) if (&User-Name) {
(7) if (&User-Name) -> TRUE
(7) if (&User-Name =~ / /) {
(7) if (&User-Name =~ / /) -> FALSE
(7) if (&User-Name =~ /@[^@]*@/ ) {
(7) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(7) if (&User-Name =~ /\.\./ ) {
(7) if (&User-Name =~ /\.\./ ) -> FALSE
(7) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(7) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(7) if (&User-Name =~ /\.$/) {
(7) if (&User-Name =~ /\.$/) -> FALSE
(7) if (&User-Name =~ /@\./) {
(7) if (&User-Name =~ /@\./) -> FALSE
(7) } # if (&User-Name) = notfound
(7) } # policy filter_username = notfound
(7) [preprocess] = ok
(7) [chap] = noop
(7) [mschap] = noop
(7) [digest] = noop
(7) suffix: Checking for suffix after "@"
(7) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(7) suffix: No such realm "NULL"
(7) [suffix] = noop
(7) eap: Peer sent EAP Response (code 2) ID 121 length 48
(7) eap: Continuing tunnel setup
(7) [eap] = ok
(7) } # authorize = ok
(7) Found Auth-Type = eap
(7) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(7) authenticate {
(7) eap: Expiring EAP session with state 0x899222038feb3b90
(7) eap: Finished EAP session with state 0x899222038feb3b90
(7) eap: Previous EAP request found for state 0x899222038feb3b90, released from the list
(7) eap: Peer sent packet with method EAP PEAP (25)
(7) eap: Calling submodule eap_peap to process data
(7) eap_peap: Continuing EAP-TLS
(7) eap_peap: [eaptls verify] = ok
(7) eap_peap: Done initial handshake
(7) eap_peap: [eaptls process] = ok
(7) eap_peap: Session established. Decoding tunneled attributes
(7) eap_peap: PEAP state WAITING FOR INNER IDENTITY
(7) eap_peap: Identity - mathias.maes
(7) eap_peap: Got inner identity 'mathias.maes'
(7) eap_peap: Setting default EAP type for tunneled EAP session
(7) eap_peap: Got tunneled request
(7) eap_peap: EAP-Message = 0x02790011016d6174686961732e6d616573
(7) eap_peap: Setting User-Name to mathias.maes
(7) eap_peap: Sending tunneled request to inner-tunnel
(7) eap_peap: FreeRADIUS-Proxied-To = 127.0.0.1
(7) eap_peap: User-Name = "mathias.maes"
(7) Virtual server inner-tunnel received request
(7) EAP-Message = 0x02790011016d6174686961732e6d616573
(7) FreeRADIUS-Proxied-To = 127.0.0.1
(7) WARNING: Outer and inner identities are the same. User privacy is compromis ed.
(7) server inner-tunnel {
(7) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/ inner-tunnel
(7) authorize {
(7) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FA LSE
(7) [suffix] = noop
(7) update control {
(7) &Proxy-To-Realm := LOCAL
(7) } # update control = noop
(7) eap: Peer sent EAP Response (code 2) ID 121 length 17
(7) eap: EAP-Identity reply, returning 'ok' so we can short-circuit the rest of authorize
(7) [eap] = ok
(7) # Executing group from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(7) authenticate {
(7) eap: Peer sent packet with method EAP Identity (1)
(7) eap: Calling submodule eap_mschapv2 to process data
(7) eap_mschapv2: Issuing Challenge
(7) eap: Sending EAP Request (code 1) ID 122 length 43
(7) eap: EAP session adding &reply:State = 0xd6a318ead6d902b4
(7) [eap] = handled
(7) } # authenticate = handled
(7) } # server inner-tunnel
(7) Virtual server sending reply
(7) EAP-Message = 0x017a002b1a017a002610af39985abac40acf623e7c81b06bacd3667265 657261646975732d332e302e3230
(7) Message-Authenticator = 0x00000000000000000000000000000000
(7) State = 0xd6a318ead6d902b4bcc6c898d0560e68
(7) eap_peap: Got tunneled reply code 11
(7) eap_peap: EAP-Message = 0x017a002b1a017a002610af39985abac40acf623e7c81b06b acd3667265657261646975732d332e302e3230
(7) eap_peap: Message-Authenticator = 0x00000000000000000000000000000000
(7) eap_peap: State = 0xd6a318ead6d902b4bcc6c898d0560e68
(7) eap_peap: Got tunneled reply RADIUS code 11
(7) eap_peap: Got tunneled Access-Challenge
(7) eap: Sending EAP Request (code 1) ID 122 length 74
(7) eap: EAP session adding &reply:State = 0x899222038ee83b90
(7) [eap] = handled
(7) Using Post-Auth-Type Challenge
(7) Challenge { ... } # empty sub-section is ignored
(7) session-state: Saving cached attributes
(7) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(7) TLS-Session-Version = "TLS 1.2"
(7) Sent Access-Challenge Id 194 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(7) EAP-Message = 0x017a004a1900170303003f5fb253d979c740921eb3e65834ef373ec35d e2fbae7d484dae98a561985509704ae6c71383396416e8c1756691c23c6e03785ff3f757b540dba6 b7d380e15f
(7) State = 0x899222038ee83b90bf08241ae32c8474
(7) Finished request
(8) Received Access-Request Id 195 from 172.16.2.24:43616 to 172.16.88.201:1812 length 319
(8) User-Name = "mathias.maes"
(8) NAS-Identifier = "802aa8d21ff5"
(8) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(8) NAS-Port-Type = Wireless-802.11
(8) Service-Type = Framed-User
(8) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(8) Connect-Info = "CONNECT 0Mbps 802.11b"
(8) Acct-Session-Id = "91947FC2865BC082"
(8) WLAN-Pairwise-Cipher = 1027076
(8) WLAN-Group-Cipher = 1027076
(8) WLAN-AKM-Suite = 1027073
(8) Framed-MTU = 1400
(8) EAP-Message = 0x027a00661900170303005b00000000000000027e5a30666bb006bee7dc 9188424c2f8d2d323705d3302c337288fbb4449c7305ce51c5a411dc54675908867ba9c07b971bcd 65c0a2568ce529f3415607805b578a5c28d87d8780e328ddaa1c7c630559d69d7a
(8) State = 0x899222038ee83b90bf08241ae32c8474
(8) Message-Authenticator = 0xfdacbbf0542569a766183455eb59bd92
(8) Restoring &session-state
(8) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(8) &session-state:TLS-Session-Version = "TLS 1.2"
(8) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(8) authorize {
(8) policy filter_username {
(8) if (&User-Name) {
(8) if (&User-Name) -> TRUE
(8) if (&User-Name =~ / /) {
(8) if (&User-Name =~ / /) -> FALSE
(8) if (&User-Name =~ /@[^@]*@/ ) {
(8) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(8) if (&User-Name =~ /\.\./ ) {
(8) if (&User-Name =~ /\.\./ ) -> FALSE
(8) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(8) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(8) if (&User-Name =~ /\.$/) {
(8) if (&User-Name =~ /\.$/) -> FALSE
(8) if (&User-Name =~ /@\./) {
(8) if (&User-Name =~ /@\./) -> FALSE
(8) } # if (&User-Name) = notfound
(8) } # policy filter_username = notfound
(8) [preprocess] = ok
(8) [chap] = noop
(8) [mschap] = noop
(8) [digest] = noop
(8) suffix: Checking for suffix after "@"
(8) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(8) suffix: No such realm "NULL"
(8) [suffix] = noop
(8) eap: Peer sent EAP Response (code 2) ID 122 length 102
(8) eap: Continuing tunnel setup
(8) [eap] = ok
(8) } # authorize = ok
(8) Found Auth-Type = eap
(8) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(8) authenticate {
(8) eap: Expiring EAP session with state 0xd6a318ead6d902b4
(8) eap: Finished EAP session with state 0x899222038ee83b90
(8) eap: Previous EAP request found for state 0x899222038ee83b90, released from the list
(8) eap: Peer sent packet with method EAP PEAP (25)
(8) eap: Calling submodule eap_peap to process data
(8) eap_peap: Continuing EAP-TLS
(8) eap_peap: [eaptls verify] = ok
(8) eap_peap: Done initial handshake
(8) eap_peap: [eaptls process] = ok
(8) eap_peap: Session established. Decoding tunneled attributes
(8) eap_peap: PEAP state phase2
(8) eap_peap: EAP method MSCHAPv2 (26)
(8) eap_peap: Got tunneled request
(8) eap_peap: EAP-Message = 0x027a00471a027a004231007c3c0965072c9267b33a349677 dcd000000000000000007180797575f18a484b780fedad03f2c98c4a3b026b4bfb77006d61746869 61732e6d616573
(8) eap_peap: Setting User-Name to mathias.maes
(8) eap_peap: Sending tunneled request to inner-tunnel
(8) eap_peap: FreeRADIUS-Proxied-To = 127.0.0.1
(8) eap_peap: User-Name = "mathias.maes"
(8) eap_peap: State = 0xd6a318ead6d902b4bcc6c898d0560e68
(8) Virtual server inner-tunnel received request
(8) EAP-Message = 0x027a00471a027a004231007c3c0965072c9267b33a349677dcd0000000 00000000007180797575f18a484b780fedad03f2c98c4a3b026b4bfb77006d6174686961732e6d61 6573
(8) FreeRADIUS-Proxied-To = 127.0.0.1
(8) State = 0xd6a318ead6d902b4bcc6c898d0560e68
(8) WARNING: Outer and inner identities are the same. User privacy is compromis ed.
(8) server inner-tunnel {
(8) session-state: No cached attributes
(8) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/ inner-tunnel
(8) authorize {
(8) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FA LSE
(8) [suffix] = noop
(8) update control {
(8) &Proxy-To-Realm := LOCAL
(8) } # update control = noop
(8) eap: Peer sent EAP Response (code 2) ID 122 length 71
(8) eap: No EAP Start, assuming it's an on-going EAP conversation
(8) [eap] = updated
(8) ldap: EXPAND (uid=%{%{Stripped-User-Name}:-%{User-Name}})
(8) ldap: --> (uid=mathias.maes)
(8) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mat hias.maes)", scope "sub"
(8) ldap: Waiting for search result...
(8) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum, ou=Users,dc=maerlantatheneum,dc=be"
(8) ldap: Processing user attributes
(8) ldap: WARNING: No "known good" password added. Ensure the admin user has per mission to read the password attribute
(8) ldap: WARNING: PAP authentication will *NOT* work with Active Directory (if that is what you were trying to configure)
rlm_ldap (ldap): Connecting to ldaps://ldap.google.com:636
rlm_ldap (ldap): Waiting for bind result...
ber_get_next failed.
rlm_ldap (ldap): Bind successful
(8) [ldap] = ok
(8) [expiration] = noop
(8) [logintime] = noop
(8) [pap] = noop
(8) if (User-Password) {
(8) if (User-Password) -> FALSE
(8) } # authorize = updated
(8) # Executing group from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(8) authenticate {
(8) eap: Finished EAP session with state 0xd6a318ead6d902b4
(8) eap: Previous EAP request found for state 0xd6a318ead6d902b4, released from the list
(8) eap: Peer sent packet with method EAP MSCHAPv2 (26)
(8) eap: Calling submodule eap_mschapv2 to process data
(8) eap_mschapv2: # Executing group from file /etc/freeradius/3.0/sites-enabled/ inner-tunnel
(8) eap_mschapv2: authenticate {
(8) mschap: WARNING: No Cleartext-Password configured. Cannot create NT-Passwor d
(8) mschap: Creating challenge hash with username: mathias.maes
(8) mschap: Client is using MS-CHAPv2
(8) mschap: ERROR: FAILED: No NT/LM-Password. Cannot perform authentication
(8) mschap: ERROR: MS-CHAP2-Response is incorrect
(8) eap_mschapv2: [mschap] = reject
(8) eap_mschapv2: } # authenticate = reject
(8) eap: Sending EAP Failure (code 4) ID 122 length 4
(8) eap: Freeing handler
(8) [eap] = reject
(8) } # authenticate = reject
(8) Failed to authenticate the user
(8) Using Post-Auth-Type Reject
(8) Post-Auth-Type REJECT {
(8) attr_filter.access_reject: EXPAND %{User-Name}
(8) attr_filter.access_reject: --> mathias.maes
(8) attr_filter.access_reject: Matched entry DEFAULT at line 11
(8) [attr_filter.access_reject] = updated
(8) update outer.session-state {
(8) &Module-Failure-Message := &request:Module-Failure-Message -> 'mscha p: FAILED: No NT/LM-Password. Cannot perform authentication'
(8) } # update outer.session-state = noop
(8) } # Post-Auth-Type REJECT = updated
(8) } # server inner-tunnel
(8) Virtual server sending reply
(8) MS-CHAP-Error = "zE=691 R=1 C=b10924bc7abd75c0851b13250ed2f621 V=3 M=Authe ntication rejected"
(8) EAP-Message = 0x047a0004
(8) Message-Authenticator = 0x00000000000000000000000000000000
(8) eap_peap: Got tunneled reply code 3
(8) eap_peap: MS-CHAP-Error = "zE=691 R=1 C=b10924bc7abd75c0851b13250ed2f621 V =3 M=Authentication rejected"
(8) eap_peap: EAP-Message = 0x047a0004
(8) eap_peap: Message-Authenticator = 0x00000000000000000000000000000000
(8) eap_peap: Got tunneled reply RADIUS code 3
(8) eap_peap: Tunneled authentication was rejected
(8) eap_peap: FAILURE
(8) eap: Sending EAP Request (code 1) ID 123 length 46
(8) eap: EAP session adding &reply:State = 0x8992220381e93b90
(8) [eap] = handled
(8) } # authenticate = handled
(8) Using Post-Auth-Type Challenge
(8) Challenge { ... } # empty sub-section is ignored
(8) session-state: Saving cached attributes
(8) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(8) TLS-Session-Version = "TLS 1.2"
(8) Module-Failure-Message := "mschap: FAILED: No NT/LM-Password. Cannot perf orm authentication"
(8) Sent Access-Challenge Id 195 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(8) EAP-Message = 0x017b002e190017030300235fb253d979c7409379efaaa15a1635ba03bc dbc4bbf12fde6352e9ae47dafcf94c9ee5
(8) State = 0x8992220381e93b90bf08241ae32c8474
(8) Finished request
(0) Cleaning up request packet ID 187 with timestamp +18
(9) Received Access-Request Id 196 from 172.16.2.24:43616 to 172.16.88.201:1812 length 263
(9) User-Name = "mathias.maes"
(9) NAS-Identifier = "802aa8d21ff5"
(9) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(9) NAS-Port-Type = Wireless-802.11
(9) Service-Type = Framed-User
(9) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(9) Connect-Info = "CONNECT 0Mbps 802.11b"
(9) Acct-Session-Id = "91947FC2865BC082"
(9) WLAN-Pairwise-Cipher = 1027076
(9) WLAN-Group-Cipher = 1027076
(9) WLAN-AKM-Suite = 1027073
(9) Framed-MTU = 1400
(9) EAP-Message = 0x027b002e190017030300230000000000000003b61f8dd5fb5be5381960 387d24bd9010c892d135ab85f950759b0f
(9) State = 0x8992220381e93b90bf08241ae32c8474
(9) Message-Authenticator = 0x61b91cb7c65c108a7be276cd6e3c0e6e
(9) Restoring &session-state
(9) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(9) &session-state:TLS-Session-Version = "TLS 1.2"
(9) &session-state:Module-Failure-Message := "mschap: FAILED: No NT/LM-Passwor d. Cannot perform authentication"
(9) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(9) authorize {
(9) policy filter_username {
(9) if (&User-Name) {
(9) if (&User-Name) -> TRUE
(9) if (&User-Name =~ / /) {
(9) if (&User-Name =~ / /) -> FALSE
(9) if (&User-Name =~ /@[^@]*@/ ) {
(9) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(9) if (&User-Name =~ /\.\./ ) {
(9) if (&User-Name =~ /\.\./ ) -> FALSE
(9) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(9) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(9) if (&User-Name =~ /\.$/) {
(9) if (&User-Name =~ /\.$/) -> FALSE
(9) if (&User-Name =~ /@\./) {
(9) if (&User-Name =~ /@\./) -> FALSE
(9) } # if (&User-Name) = notfound
(9) } # policy filter_username = notfound
(9) [preprocess] = ok
(9) [chap] = noop
(9) [mschap] = noop
(9) [digest] = noop
(9) suffix: Checking for suffix after "@"
(9) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(9) suffix: No such realm "NULL"
(9) [suffix] = noop
(9) eap: Peer sent EAP Response (code 2) ID 123 length 46
(9) eap: Continuing tunnel setup
(9) [eap] = ok
(9) } # authorize = ok
(9) Found Auth-Type = eap
(9) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(9) authenticate {
(9) eap: Expiring EAP session with state 0x8992220381e93b90
(9) eap: Finished EAP session with state 0x8992220381e93b90
(9) eap: Previous EAP request found for state 0x8992220381e93b90, released from the list
(9) eap: Peer sent packet with method EAP PEAP (25)
(9) eap: Calling submodule eap_peap to process data
(9) eap_peap: Continuing EAP-TLS
(9) eap_peap: [eaptls verify] = ok
(9) eap_peap: Done initial handshake
(9) eap_peap: [eaptls process] = ok
(9) eap_peap: Session established. Decoding tunneled attributes
(9) eap_peap: PEAP state send tlv failure
(9) eap_peap: Received EAP-TLV response
(9) eap_peap: ERROR: The users session was previously rejected: returning reje ct (again.)
(9) eap_peap: This means you need to read the PREVIOUS messages in the debug o utput
(9) eap_peap: to find out the reason why the user was rejected
(9) eap_peap: Look for "reject" or "fail". Those earlier messages will tell y ou
(9) eap_peap: what went wrong, and how to fix the problem
(9) eap: ERROR: Failed continuing EAP PEAP (25) session. EAP sub-module failed
(9) eap: Sending EAP Failure (code 4) ID 123 length 4
(9) eap: Failed in EAP select
(9) [eap] = invalid
(9) } # authenticate = invalid
(9) Failed to authenticate the user
(9) Using Post-Auth-Type Reject
(9) Post-Auth-Type REJECT {
(9) attr_filter.access_reject: EXPAND %{User-Name}
(9) attr_filter.access_reject: --> mathias.maes
(9) attr_filter.access_reject: Matched entry DEFAULT at line 11
(9) [attr_filter.access_reject] = updated
(9) [eap] = noop
(9) policy remove_reply_message_if_eap {
(9) if (&reply:EAP-Message && &reply:Reply-Message) {
(9) if (&reply:EAP-Message && &reply:Reply-Message) -> FALSE
(9) else {
(9) [noop] = noop
(9) } # else = noop
(9) } # policy remove_reply_message_if_eap = noop
(9) } # Post-Auth-Type REJECT = updated
(9) Delaying response for 1.000000 seconds
Waking up in 0.3 seconds.
Waking up in 0.6 seconds.
(1) Cleaning up request packet ID 188 with timestamp +18
(2) Cleaning up request packet ID 189 with timestamp +19
(3) Cleaning up request packet ID 190 with timestamp +19
(4) Cleaning up request packet ID 191 with timestamp +19
(5) Cleaning up request packet ID 192 with timestamp +19
(9) Sending delayed response
(9) Sent Access-Reject Id 196 from 172.16.88.201:1812 to 172.16.2.24:43616 lengt h 44
(9) EAP-Message = 0x047b0004
(9) Message-Authenticator = 0x00000000000000000000000000000000
Waking up in 2.7 seconds.
(6) Cleaning up request packet ID 193 with timestamp +22
(7) Cleaning up request packet ID 194 with timestamp +22
Waking up in 1.2 seconds.
(8) Cleaning up request packet ID 195 with timestamp +22
(9) Cleaning up request packet ID 196 with timestamp +23
Ready to process requests
Is er iemand die hieruit kan vissen wat er juist mis gaat? Mijn ervaring met Freeradius is eerder beperkt te noemen.
De error (8) Module-Failure-Message := "mschap: FAILED: No NT/LM-Password. Cannot perf orm authentication" valt op.
Maar dit zijn mijn Netwerk instellingen op Windows: https://i.imgur.com/EFW1vja.png
Iemand kennis van zaken of ideën?
Bedankt!
