Freeradius EAP-TTLS PAP met Windows client?
  • Carharttguy
  • Laatst online: 12-10 11:27
Hallo
Ik heb een Freeradius server opgezet, die verbinding maakt met onze Google Secure LDAP om zo op ons Wifi netwerk te kunnen authenticeren.
Android: Top, werkt perfect.
Windows: Nope, wil niet werken. Weinig zeggende error aand de client kant, maar aan de serverkant lijkt het alsof Windows tegen beter weten in toch MS-CHAP wil gaan doen ipv PAP.
Hier mijn Freeradius log met Android:
administrator@freeradius:~$ sudo freeradius -X
FreeRADIUS Version 3.0.20
Copyright (C) 1999-2019 The FreeRADIUS server project and contributors
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License
For more information about these matters, see the file named COPYRIGHT
Starting - reading configuration files ...
including dictionary file /usr/share/freeradius/dictionary
including dictionary file /usr/share/freeradius/dictionary.dhcp
including dictionary file /usr/share/freeradius/dictionary.vqp
including dictionary file /etc/freeradius/3.0/dictionary
including configuration file /etc/freeradius/3.0/radiusd.conf
including configuration file /etc/freeradius/3.0/proxy.conf
including configuration file /etc/freeradius/3.0/clients.conf
including files in directory /etc/freeradius/3.0/mods-enabled/
including configuration file /etc/freeradius/3.0/mods-enabled/cache_eap
including configuration file /etc/freeradius/3.0/mods-enabled/unix
including configuration file /etc/freeradius/3.0/mods-enabled/detail
including configuration file /etc/freeradius/3.0/mods-enabled/files
including configuration file /etc/freeradius/3.0/mods-enabled/passwd
including configuration file /etc/freeradius/3.0/mods-enabled/pap
including configuration file /etc/freeradius/3.0/mods-enabled/expr
including configuration file /etc/freeradius/3.0/mods-enabled/echo
including configuration file /etc/freeradius/3.0/mods-enabled/sradutmp
including configuration file /etc/freeradius/3.0/mods-enabled/exec
including configuration file /etc/freeradius/3.0/mods-enabled/attr_filter
including configuration file /etc/freeradius/3.0/mods-enabled/preprocess
including configuration file /etc/freeradius/3.0/mods-enabled/soh
including configuration file /etc/freeradius/3.0/mods-enabled/chap
including configuration file /etc/freeradius/3.0/mods-enabled/linelog
including configuration file /etc/freeradius/3.0/mods-enabled/dynamic_clients
including configuration file /etc/freeradius/3.0/mods-enabled/always
including configuration file /etc/freeradius/3.0/mods-enabled/replicate
including configuration file /etc/freeradius/3.0/mods-enabled/realm
including configuration file /etc/freeradius/3.0/mods-enabled/digest
including configuration file /etc/freeradius/3.0/mods-enabled/mschap
including configuration file /etc/freeradius/3.0/mods-enabled/logintime
including configuration file /etc/freeradius/3.0/mods-enabled/expiration
including configuration file /etc/freeradius/3.0/mods-enabled/unpack
including configuration file /etc/freeradius/3.0/mods-enabled/utf8
including configuration file /etc/freeradius/3.0/mods-enabled/ntlm_auth
including configuration file /etc/freeradius/3.0/mods-enabled/radutmp
including configuration file /etc/freeradius/3.0/mods-enabled/ldap
including configuration file /etc/freeradius/3.0/mods-enabled/detail.log
including configuration file /etc/freeradius/3.0/mods-enabled/eap
including files in directory /etc/freeradius/3.0/policy.d/
including configuration file /etc/freeradius/3.0/policy.d/moonshot-targeted-ids
including configuration file /etc/freeradius/3.0/policy.d/filter
including configuration file /etc/freeradius/3.0/policy.d/accounting
including configuration file /etc/freeradius/3.0/policy.d/debug
including configuration file /etc/freeradius/3.0/policy.d/cui
including configuration file /etc/freeradius/3.0/policy.d/canonicalization
including configuration file /etc/freeradius/3.0/policy.d/dhcp
including configuration file /etc/freeradius/3.0/policy.d/abfab-tr
including configuration file /etc/freeradius/3.0/policy.d/operator-name
including configuration file /etc/freeradius/3.0/policy.d/rfc7542
including configuration file /etc/freeradius/3.0/policy.d/control
including configuration file /etc/freeradius/3.0/policy.d/eap
including files in directory /etc/freeradius/3.0/sites-enabled/
including configuration file /etc/freeradius/3.0/sites-enabled/default
including configuration file /etc/freeradius/3.0/sites-enabled/inner-tunnel
main {
security {
user = "freerad"
group = "freerad"
allow_core_dumps = no
name = "freeradius"
prefix = "/usr"
localstatedir = "/var"
logdir = "/var/log/freeradius"
run_dir = "/var/run/freeradius"
main {
name = "freeradius"
prefix = "/usr"
sbindir = "/usr/sbin"
libdir = "/usr/lib/freeradius"
radacctdir = "/var/log/freeradius/radacct"
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 16384
pidfile = "/var/run/freeradius/freeradius.pid"
checkrad = "/usr/sbin/checkrad"
debug_level = 0
proxy_requests = yes
log {
stripped_names = no
auth = no
auth_badpass = no
auth_goodpass = no
colourise = yes
msg_denied = "You are already logged in - access denied"
resources {
security {
max_attributes = 200
reject_delay = 1.000000
status_server = yes
radiusd: #### Loading Realms and Home Servers ####
proxy server {
retry_delay = 5
retry_count = 3
default_fallback = no
dead_time = 120
wake_all_if_all_dead = no
home_server localhost {
ipaddr = 127.0.0.1
port = 1812
type = "auth"
secret = <<< secret >>>
response_window = 20.000000
response_timeouts = 1
max_outstanding = 65536
zombie_period = 40
status_check = "status-server"
ping_interval = 30
check_interval = 30
check_timeout = 4
num_answers_to_alive = 3
revive_interval = 120
limit {
max_connections = 16
max_requests = 0
lifetime = 0
idle_timeout = 0
coa {
irt = 2
mrt = 16
mrc = 5
mrd = 30
home_server_pool my_auth_failover {
type = fail-over
home_server = localhost
realm example.com {
auth_pool = my_auth_failover
realm LOCAL {
radiusd: #### Loading Clients ####
client localhost {
ipaddr = 127.0.0.1
require_message_authenticator = no
nas_type = "other"
proto = "*"
limit {
lifetime = 0
idle_timeout = 30
client TestAP {
ipaddr = 172.16.15.166
limit {
lifetime = 0
idle_timeout = 30
client StilleLeraarskamer {
ipaddr = 172.16.2.24
limit {
lifetime = 0
idle_timeout = 30
client localhost_ipv6 {
ipv6addr = ::1
limit {
lifetime = 0
idle_timeout = 30
Debugger not attached
systemd watchdog is disabled
# Creating Auth-Type = mschap
# Creating Auth-Type = digest
# Creating Auth-Type = ldap
# Creating Auth-Type = eap
# Creating Auth-Type = PAP
# Creating Auth-Type = CHAP
# Creating Auth-Type = MS-CHAP
radiusd: #### Instantiating modules ####
modules {
# Loaded module rlm_cache
# Loading module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
cache cache_eap {
driver = "rlm_cache_rbtree"
key = "%{%{control:State}:-%{%{reply:State}:-%{State}}}"
ttl = 15
max_entries = 0
epoch = 0
add_stats = no
# Loaded module rlm_unix
# Loading module "unix" from file /etc/freeradius/3.0/mods-enabled/unix
unix {
radwtmp = "/var/log/freeradius/radwtmp"
Creating attribute Unix-Group
# Loaded module rlm_detail
# Loading module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
detail {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
escape_filenames = no
log_packet_header = no
# Loaded module rlm_files
# Loading module "files" from file /etc/freeradius/3.0/mods-enabled/files
files {
filename = "/etc/freeradius/3.0/mods-config/files/authorize"
acctusersfile = "/etc/freeradius/3.0/mods-config/files/accounting"
preproxy_usersfile = "/etc/freeradius/3.0/mods-config/files/pre-proxy"
# Loaded module rlm_passwd
# Loading module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
passwd etc_passwd {
filename = "/etc/passwd"
format = "*User-Name:Crypt-Password:"
delimiter = ":"
ignore_nislike = no
ignore_empty = yes
allow_multiple_keys = no
hash_size = 100
# Loaded module rlm_pap
# Loading module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
pap {
normalise = yes
# Loaded module rlm_expr
# Loading module "expr" from file /etc/freeradius/3.0/mods-enabled/expr
expr {
safe_characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /äéöüàâæçèéêëîïôœùûüaÿÄÉÖÜßÀÂÆÇÈÉÊËÎÏÔŒÙÛÜŸ"
# Loaded module rlm_exec
# Loading module "echo" from file /etc/freeradius/3.0/mods-enabled/echo
exec echo {
wait = yes
program = "/bin/echo %{User-Name}"
input_pairs = "request"
output_pairs = "reply"
shell_escape = yes
# Loaded module rlm_radutmp
# Loading module "sradutmp" from file /etc/freeradius/3.0/mods-enabled/sradutmp
radutmp sradutmp {
filename = "/var/log/freeradius/sradutmp"
username = "%{User-Name}"
case_sensitive = yes
check_with_nas = yes
permissions = 420
caller_id = no
# Loading module "exec" from file /etc/freeradius/3.0/mods-enabled/exec
exec {
wait = no
shell_escape = yes
timeout = 10
# Loaded module rlm_attr_filter
# Loading module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.post-proxy {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/post-proxy"
key = "%{Realm}"
relaxed = no
# Loading module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.pre-proxy {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/pre-proxy"
key = "%{Realm}"
relaxed = no
# Loading module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.access_reject {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_reject"
key = "%{User-Name}"
relaxed = no
# Loading module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.access_challenge {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/access_challenge"
relaxed = no
# Loading module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
attr_filter attr_filter.accounting_response {
filename = "/etc/freeradius/3.0/mods-config/attr_filter/accounting_response"
relaxed = no
# Loaded module rlm_preprocess
# Loading module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
preprocess {
huntgroups = "/etc/freeradius/3.0/mods-config/preprocess/huntgroups"
hints = "/etc/freeradius/3.0/mods-config/preprocess/hints"
with_ascend_hack = no
ascend_channels_per_line = 23
with_ntdomain_hack = no
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
# Loaded module rlm_soh
# Loading module "soh" from file /etc/freeradius/3.0/mods-enabled/soh
soh {
dhcp = yes
# Loaded module rlm_chap
# Loading module "chap" from file /etc/freeradius/3.0/mods-enabled/chap
# Loaded module rlm_linelog
# Loading module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
linelog {
filename = "/var/log/freeradius/linelog"
syslog_severity = "info"
permissions = 384
format = "This is a log message for %{User-Name}"
reference = "messages.%{%{reply:Packet-Type}:-default}"
# Loading module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
linelog log_accounting {
filename = "/var/log/freeradius/linelog-accounting"
permissions = 384
format = ""
reference = "Accounting-Request.%{%{Acct-Status-Type}:-unknown}"
# Loaded module rlm_dynamic_clients
# Loading module "dynamic_clients" from file /etc/freeradius/3.0/mods-enabled/dynamic_clients
# Loaded module rlm_always
# Loading module "reject" from file /etc/freeradius/3.0/mods-enabled/always
always reject {
rcode = "reject"
simulcount = 0
mpp = no
# Loading module "fail" from file /etc/freeradius/3.0/mods-enabled/always
always fail {
rcode = "fail"
simulcount = 0
mpp = no
# Loading module "ok" from file /etc/freeradius/3.0/mods-enabled/always
always ok {
rcode = "ok"
simulcount = 0
mpp = no
# Loading module "handled" from file /etc/freeradius/3.0/mods-enabled/always
always handled {
rcode = "handled"
simulcount = 0
mpp = no
# Loading module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
always invalid {
rcode = "invalid"
simulcount = 0
mpp = no
# Loading module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
always userlock {
rcode = "userlock"
simulcount = 0
mpp = no
# Loading module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
always notfound {
rcode = "notfound"
simulcount = 0
mpp = no
# Loading module "noop" from file /etc/freeradius/3.0/mods-enabled/always
always noop {
rcode = "noop"
simulcount = 0
mpp = no
# Loading module "updated" from file /etc/freeradius/3.0/mods-enabled/always
always updated {
rcode = "updated"
simulcount = 0
mpp = no
# Loaded module rlm_replicate
# Loading module "replicate" from file /etc/freeradius/3.0/mods-enabled/replicate
# Loaded module rlm_realm
# Loading module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
realm IPASS {
format = "prefix"
delimiter = "/"
ignore_default = no
ignore_null = no
# Loading module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
realm suffix {
format = "suffix"
delimiter = "@"
ignore_default = no
ignore_null = no
# Loading module "bangpath" from file /etc/freeradius/3.0/mods-enabled/realm
realm bangpath {
format = "prefix"
delimiter = "!"
ignore_default = no
ignore_null = no
# Loading module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
realm realmpercent {
format = "suffix"
delimiter = "%"
ignore_default = no
ignore_null = no
# Loading module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
realm ntdomain {
format = "prefix"
delimiter = "\\"
ignore_default = no
ignore_null = no
# Loaded module rlm_digest
# Loading module "digest" from file /etc/freeradius/3.0/mods-enabled/digest
# Loaded module rlm_mschap
# Loading module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
mschap {
use_mppe = yes
require_encryption = no
require_strong = no
with_ntdomain_hack = yes
passchange {
allow_retry = yes
winbind_retry_with_normalised_username = no
# Loaded module rlm_logintime
# Loading module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
logintime {
minimum_timeout = 60
# Loaded module rlm_expiration
# Loading module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
# Loaded module rlm_unpack
# Loading module "unpack" from file /etc/freeradius/3.0/mods-enabled/unpack
# Loaded module rlm_utf8
# Loading module "utf8" from file /etc/freeradius/3.0/mods-enabled/utf8
# Loading module "ntlm_auth" from file /etc/freeradius/3.0/mods-enabled/ntlm_auth
exec ntlm_auth {
wait = yes
program = "/path/to/ntlm_auth --request-nt-key --domain=MYDOMAIN --username=%{mschap:User-Name} --password=%{User-Password}"
shell_escape = yes
# Loading module "radutmp" from file /etc/freeradius/3.0/mods-enabled/radutmp
radutmp {
filename = "/var/log/freeradius/radutmp"
permissions = 384
caller_id = yes
# Loaded module rlm_ldap
# Loading module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
ldap {
server = "ldaps://ldap.google.com:636"
identity = "Well-Docum"
password = <<< secret >>>
sasl {
user_dn = "LDAP-UserDn"
user {
scope = "sub"
access_positive = yes
sasl {
group {
filter = "(objectClass=posixGroup)"
scope = "sub"
name_attribute = "cn"
membership_attribute = "memberOf"
cacheable_name = no
cacheable_dn = no
allow_dangling_group_ref = no
client {
filter = "(objectClass=radiusClient)"
scope = "sub"
base_dn = "dc=maerlantatheneum,dc=be"
profile {
options {
ldap_debug = 40
chase_referrals = yes
rebind = yes
net_timeout = 1
res_timeout = 10
srv_timelimit = 3
idle = 60
probes = 3
interval = 3
tls {
certificate_file = "/etc/freeradius/3.0/certs/ldap-client.crt"
private_key_file = "/etc/freeradius/3.0/certs/ldap-client.key"
start_tls = no
require_cert = "allow"
Creating attribute LDAP-Group
# Loading module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail auth_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail reply_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/reply-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail pre_proxy_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/pre-proxy-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loading module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
detail post_proxy_log {
filename = "/var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/post-proxy-detail-%Y%m%d"
header = "%t"
permissions = 384
locking = no
# Loaded module rlm_eap
# Loading module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
eap {
default_eap_type = "md5"
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
max_sessions = 16384
instantiate {
# Instantiating module "cache_eap" from file /etc/freeradius/3.0/mods-enabled/cache_eap
rlm_cache (cache_eap): Driver rlm_cache_rbtree (module rlm_cache_rbtree) loaded and linked
# Instantiating module "detail" from file /etc/freeradius/3.0/mods-enabled/detail
# Instantiating module "files" from file /etc/freeradius/3.0/mods-enabled/files
reading pairlist file /etc/freeradius/3.0/mods-config/files/authorize
reading pairlist file /etc/freeradius/3.0/mods-config/files/accounting
reading pairlist file /etc/freeradius/3.0/mods-config/files/pre-proxy
# Instantiating module "etc_passwd" from file /etc/freeradius/3.0/mods-enabled/passwd
rlm_passwd: nfields: 3 keyfield 0(User-Name) listable: no
# Instantiating module "pap" from file /etc/freeradius/3.0/mods-enabled/pap
# Instantiating module "attr_filter.post-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/post-proxy
# Instantiating module "attr_filter.pre-proxy" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/pre-proxy
# Instantiating module "attr_filter.access_reject" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_reject
# Instantiating module "attr_filter.access_challenge" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/access_challenge
# Instantiating module "attr_filter.accounting_response" from file /etc/freeradius/3.0/mods-enabled/attr_filter
reading pairlist file /etc/freeradius/3.0/mods-config/attr_filter/accounting_response
# Instantiating module "preprocess" from file /etc/freeradius/3.0/mods-enabled/preprocess
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/huntgroups
reading pairlist file /etc/freeradius/3.0/mods-config/preprocess/hints
# Instantiating module "linelog" from file /etc/freeradius/3.0/mods-enabled/linelog
# Instantiating module "log_accounting" from file /etc/freeradius/3.0/mods-enabled/linelog
# Instantiating module "reject" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "fail" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "ok" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "handled" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "invalid" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "userlock" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "notfound" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "noop" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "updated" from file /etc/freeradius/3.0/mods-enabled/always
# Instantiating module "IPASS" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "suffix" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "bangpath" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "realmpercent" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "ntdomain" from file /etc/freeradius/3.0/mods-enabled/realm
# Instantiating module "mschap" from file /etc/freeradius/3.0/mods-enabled/mschap
rlm_mschap (mschap): using internal authentication
# Instantiating module "logintime" from file /etc/freeradius/3.0/mods-enabled/logintime
# Instantiating module "expiration" from file /etc/freeradius/3.0/mods-enabled/expiration
# Instantiating module "ldap" from file /etc/freeradius/3.0/mods-enabled/ldap
rlm_ldap: libldap vendor: OpenLDAP, version: 20449
accounting {
reference = "%{tolower:type.%{Acct-Status-Type}}"
post-auth {
reference = "."
rlm_ldap (ldap): Initialising connection pool
pool {
start = 5
min = 3
max = 32
spare = 10
uses = 0
lifetime = 0
cleanup_interval = 30
idle_timeout = 60
retry_delay = 30
spread = no
rlm_ldap (ldap): Opening additional connection (0), 1 of 32 pending slots used
rlm_ldap (ldap): Connecting to ldaps://ldap.google.com:636
rlm_ldap (ldap): Waiting for bind result...
ber_get_next failed.
rlm_ldap (ldap): Bind successful
rlm_ldap (ldap): Opening additional connection (1), 1 of 31 pending slots used
rlm_ldap (ldap): Opening additional connection (2), 1 of 30 pending slots used
rlm_ldap (ldap): Opening additional connection (3), 1 of 29 pending slots used
rlm_ldap (ldap): Opening additional connection (4), 1 of 28 pending slots used
# Instantiating module "auth_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
rlm_detail (auth_log): 'User-Password' suppressed, will not appear in detail output
# Instantiating module "reply_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "pre_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "post_proxy_log" from file /etc/freeradius/3.0/mods-enabled/detail.log
# Instantiating module "eap" from file /etc/freeradius/3.0/mods-enabled/eap
# Linked to sub-module rlm_eap_md5
# Linked to sub-module rlm_eap_leap
# Linked to sub-module rlm_eap_gtc
gtc {
challenge = "Password: "
auth_type = "PAP"
# Linked to sub-module rlm_eap_tls
tls {
tls = "tls-common"
tls-config tls-common {
verify_depth = 0
ca_path = "/etc/freeradius/3.0/certs"
pem_file_type = yes
private_key_file = "/etc/freeradius/3.0/certs/server.pem"
certificate_file = "/etc/freeradius/3.0/certs/server.pem"
ca_file = "/etc/freeradius/3.0/certs/ca.pem"
private_key_password = <<< secret >>>
dh_file = "/etc/freeradius/3.0/certs/dh"
fragment_size = 1024
include_length = yes
auto_chain = yes
check_crl = no
check_all_crl = no
cipher_list = "DEFAULT"
cipher_server_preference = no
ecdh_curve = "prime256v1"
tls_max_version = ""
tls_min_version = "1.0"
cache {
enable = no
lifetime = 24
max_entries = 255
verify {
skip_if_ocsp_ok = no
ocsp {
enable = no
override_cert_url = yes
url = "http://127.0.0.1/ocsp/"
use_nonce = yes
timeout = 0
softfail = no
The configuration allows TLS 1.0 and/or TLS 1.1. We STRONGLY recommned using only TLS 1.2 for security
Please set: min_tls_version = "1.2"
# Linked to sub-module rlm_eap_ttls
ttls {
tls = "tls-common"
copy_request_to_tunnel = no
use_tunneled_reply = yes
virtual_server = "inner-tunnel"
require_client_cert = no
tls: Using cached TLS configuration from previous invocation
# Linked to sub-module rlm_eap_peap
peap {
tls = "tls-common"
default_eap_type = "mschapv2"
proxy_tunneled_request_as_eap = yes
soh = no
# Linked to sub-module rlm_eap_mschapv2
mschapv2 {
send_error = no
} # modules
radiusd: #### Loading Virtual Servers ####
server { # from file /etc/freeradius/3.0/radiusd.conf
} # server
server default { # from file /etc/freeradius/3.0/sites-enabled/default
# Loading authenticate {...}
# Loading authorize {...}
Ignoring "sql" (see raddb/mods-available/README.rst)
# Loading preacct {...}
# Loading accounting {...}
# Loading post-proxy {...}
# Loading post-auth {...}
} # server default
server inner-tunnel { # from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
# Loading session {...}
} # server inner-tunnel
radiusd: #### Opening IP addresses and Ports ####
listen {
type = "auth"
ipaddr = *
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "acct"
ipaddr = *
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "auth"
ipv6addr = ::
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "acct"
ipv6addr = ::
port = 0
limit {
lifetime = 0
idle_timeout = 30
listen {
type = "auth"
ipaddr = 127.0.0.1
port = 18120
Listening on auth address * port 1812 bound to server default
Listening on acct address * port 1813 bound to server default
Listening on auth address :: port 1812 bound to server default
Listening on acct address :: port 1813 bound to server default
Listening on auth address 127.0.0.1 port 18120 bound to server inner-tunnel
Listening on proxy address * port 48889
Listening on proxy address :: port 45643
Ready to process requests
(0) Received Access-Request Id 246 from 172.16.2.24:43616 to 172.16.88.201:1812 length 216
(0) User-Name = "mathias.maes"
(0) NAS-Identifier = "802aa8d21ff5"
(0) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(0) NAS-Port-Type = Wireless-802.11
(0) Service-Type = Framed-User
(0) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(0) Connect-Info = "CONNECT 0Mbps 802.11b"
(0) Acct-Session-Id = "F611C1164C9282AB"
(0) WLAN-Pairwise-Cipher = 1027076
(0) WLAN-Group-Cipher = 1027076
(0) WLAN-AKM-Suite = 1027073
(0) Framed-MTU = 1400
(0) EAP-Message = 0x02290011016d6174686961732e6d616573
(0) Message-Authenticator = 0xec786fb2149f058e3bbb2d03f8c7e125
(0) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(0) authorize {
(0) policy filter_username {
(0) if (&User-Name) {
(0) if (&User-Name) -> TRUE
(0) if (&User-Name =~ / /) {
(0) if (&User-Name =~ / /) -> FALSE
(0) if (&User-Name =~ /@[^@]*@/ ) {
(0) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(0) if (&User-Name =~ /\.\./ ) {
(0) if (&User-Name =~ /\.\./ ) -> FALSE
(0) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(0) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(0) if (&User-Name =~ /\.$/) {
(0) if (&User-Name =~ /\.$/) -> FALSE
(0) if (&User-Name =~ /@\./) {
(0) if (&User-Name =~ /@\./) -> FALSE
(0) } # if (&User-Name) = notfound
(0) } # policy filter_username = notfound
(0) [preprocess] = ok
(0) [chap] = noop
(0) [mschap] = noop
(0) [digest] = noop
(0) suffix: Checking for suffix after "@"
(0) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(0) suffix: No such realm "NULL"
(0) [suffix] = noop
(0) eap: Peer sent EAP Response (code 2) ID 41 length 17
(0) eap: EAP-Identity reply, returning 'ok' so we can short-circuit the rest of authorize
(0) [eap] = ok
(0) } # authorize = ok
(0) Found Auth-Type = eap
(0) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(0) authenticate {
(0) eap: Peer sent packet with method EAP Identity (1)
(0) eap: Calling submodule eap_md5 to process data
(0) eap_md5: Issuing MD5 Challenge
(0) eap: Sending EAP Request (code 1) ID 42 length 22
(0) eap: EAP session adding &reply:State = 0xff99fa83ffb3fec8
(0) [eap] = handled
(0) } # authenticate = handled
(0) Using Post-Auth-Type Challenge
(0) Challenge { ... } # empty sub-section is ignored
(0) Sent Access-Challenge Id 246 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(0) EAP-Message = 0x012a001604108da0d284c326a1c734587e4d1457acfb
(0) Message-Authenticator = 0x00000000000000000000000000000000
(0) State = 0xff99fa83ffb3fec8c4b146a7c9273cc4
(0) Finished request
Waking up in 4.9 seconds.
(1) Received Access-Request Id 247 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(1) User-Name = "mathias.maes"
(1) NAS-Identifier = "802aa8d21ff5"
(1) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(1) NAS-Port-Type = Wireless-802.11
(1) Service-Type = Framed-User
(1) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(1) Connect-Info = "CONNECT 0Mbps 802.11b"
(1) Acct-Session-Id = "F611C1164C9282AB"
(1) WLAN-Pairwise-Cipher = 1027076
(1) WLAN-Group-Cipher = 1027076
(1) WLAN-AKM-Suite = 1027073
(1) Framed-MTU = 1400
(1) EAP-Message = 0x022a00060315
(1) State = 0xff99fa83ffb3fec8c4b146a7c9273cc4
(1) Message-Authenticator = 0x6e32250725247d4a18f619df76c2dfdd
(1) session-state: No cached attributes
(1) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(1) authorize {
(1) policy filter_username {
(1) if (&User-Name) {
(1) if (&User-Name) -> TRUE
(1) if (&User-Name =~ / /) {
(1) if (&User-Name =~ / /) -> FALSE
(1) if (&User-Name =~ /@[^@]*@/ ) {
(1) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(1) if (&User-Name =~ /\.\./ ) {
(1) if (&User-Name =~ /\.\./ ) -> FALSE
(1) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(1) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(1) if (&User-Name =~ /\.$/) {
(1) if (&User-Name =~ /\.$/) -> FALSE
(1) if (&User-Name =~ /@\./) {
(1) if (&User-Name =~ /@\./) -> FALSE
(1) } # if (&User-Name) = notfound
(1) } # policy filter_username = notfound
(1) [preprocess] = ok
(1) [chap] = noop
(1) [mschap] = noop
(1) [digest] = noop
(1) suffix: Checking for suffix after "@"
(1) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(1) suffix: No such realm "NULL"
(1) [suffix] = noop
(1) eap: Peer sent EAP Response (code 2) ID 42 length 6
(1) eap: No EAP Start, assuming it's an on-going EAP conversation
(1) [eap] = updated
(1) [files] = noop
rlm_ldap (ldap): Reserved connection (0)
(1) ldap: EXPAND (uid=%{%{Stripped-User-Name}:-%{User-Name}})
(1) ldap: --> (uid=mathias.maes)
(1) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mathias.maes)", scope "sub"
(1) ldap: Waiting for search result...
(1) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(1) ldap: Processing user attributes
(1) ldap: WARNING: No "known good" password added. Ensure the admin user has permission to read the password attribute
(1) ldap: WARNING: PAP authentication will *NOT* work with Active Directory (if that is what you were trying to configure)
rlm_ldap (ldap): Released connection (0)
Need 5 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (5), 1 of 27 pending slots used
(1) [ldap] = ok
(1) [expiration] = noop
(1) [logintime] = noop
Not doing PAP as Auth-Type is already set.
(1) [pap] = noop
(1) if (User-Password) {
(1) if (User-Password) -> FALSE
(1) } # authorize = updated
(1) Found Auth-Type = eap
(1) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(1) authenticate {
(1) eap: Expiring EAP session with state 0xff99fa83ffb3fec8
(1) eap: Finished EAP session with state 0xff99fa83ffb3fec8
(1) eap: Previous EAP request found for state 0xff99fa83ffb3fec8, released from the list
(1) eap: Peer sent packet with method EAP NAK (3)
(1) eap: Found mutually acceptable type TTLS (21)
(1) eap: Calling submodule eap_ttls to process data
(1) eap_ttls: Initiating new TLS session
(1) eap_ttls: [eaptls start] = request
(1) eap: Sending EAP Request (code 1) ID 43 length 6
(1) eap: EAP session adding &reply:State = 0xff99fa83feb2efc8
(1) [eap] = handled
(1) } # authenticate = handled
(1) Using Post-Auth-Type Challenge
(1) Challenge { ... } # empty sub-section is ignored
(1) Sent Access-Challenge Id 247 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(1) EAP-Message = 0x012b00061520
(1) Message-Authenticator = 0x00000000000000000000000000000000
(1) State = 0xff99fa83feb2efc8c4b146a7c9273cc4
(1) Finished request
Waking up in 3.7 seconds.
(2) Received Access-Request Id 248 from 172.16.2.24:43616 to 172.16.88.201:1812 length 354
(2) User-Name = "mathias.maes"
(2) NAS-Identifier = "802aa8d21ff5"
(2) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(2) NAS-Port-Type = Wireless-802.11
(2) Service-Type = Framed-User
(2) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(2) Connect-Info = "CONNECT 0Mbps 802.11b"
(2) Acct-Session-Id = "F611C1164C9282AB"
(2) WLAN-Pairwise-Cipher = 1027076
(2) WLAN-Group-Cipher = 1027076
(2) WLAN-AKM-Suite = 1027073
(2) Framed-MTU = 1400
(2) EAP-Message = 0x022b00891500160301007e0100007a0303729d177dc6e282d6084ff59d6ec37e5c43da16c555cedf4cc26eb6bfaba422d500001ec02bc02fc02cc030cca9cca8c009c013c00ac014009c009d002f0035000a0100003300170000ff01000100000a00080006001d00170018000b00020100000d00140012040308040401050308050501080606010201
(2) State = 0xff99fa83feb2efc8c4b146a7c9273cc4
(2) Message-Authenticator = 0x8d3a6b12ff756ae9ed5b1117d5fd5f67
(2) session-state: No cached attributes
(2) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(2) authorize {
(2) policy filter_username {
(2) if (&User-Name) {
(2) if (&User-Name) -> TRUE
(2) if (&User-Name =~ / /) {
(2) if (&User-Name =~ / /) -> FALSE
(2) if (&User-Name =~ /@[^@]*@/ ) {
(2) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(2) if (&User-Name =~ /\.\./ ) {
(2) if (&User-Name =~ /\.\./ ) -> FALSE
(2) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(2) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(2) if (&User-Name =~ /\.$/) {
(2) if (&User-Name =~ /\.$/) -> FALSE
(2) if (&User-Name =~ /@\./) {
(2) if (&User-Name =~ /@\./) -> FALSE
(2) } # if (&User-Name) = notfound
(2) } # policy filter_username = notfound
(2) [preprocess] = ok
(2) [chap] = noop
(2) [mschap] = noop
(2) [digest] = noop
(2) suffix: Checking for suffix after "@"
(2) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(2) suffix: No such realm "NULL"
(2) [suffix] = noop
(2) eap: Peer sent EAP Response (code 2) ID 43 length 137
(2) eap: Continuing tunnel setup
(2) [eap] = ok
(2) } # authorize = ok
(2) Found Auth-Type = eap
(2) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(2) authenticate {
(2) eap: Expiring EAP session with state 0xff99fa83feb2efc8
(2) eap: Finished EAP session with state 0xff99fa83feb2efc8
(2) eap: Previous EAP request found for state 0xff99fa83feb2efc8, released from the list
(2) eap: Peer sent packet with method EAP TTLS (21)
(2) eap: Calling submodule eap_ttls to process data
(2) eap_ttls: Authenticate
(2) eap_ttls: Continuing EAP-TLS
(2) eap_ttls: [eaptls verify] = ok
(2) eap_ttls: Done initial handshake
(2) eap_ttls: (other): before SSL initialization
(2) eap_ttls: TLS_accept: before SSL initialization
(2) eap_ttls: <<< recv TLS 1.3 [length 007e]
(2) eap_ttls: TLS_accept: SSLv3/TLS read client hello
(2) eap_ttls: >>> send TLS 1.2 [length 003d]
(2) eap_ttls: TLS_accept: SSLv3/TLS write server hello
(2) eap_ttls: >>> send TLS 1.2 [length 095f]
(2) eap_ttls: TLS_accept: SSLv3/TLS write certificate
(2) eap_ttls: >>> send TLS 1.2 [length 014d]
(2) eap_ttls: TLS_accept: SSLv3/TLS write key exchange
(2) eap_ttls: >>> send TLS 1.2 [length 0004]
(2) eap_ttls: TLS_accept: SSLv3/TLS write server done
(2) eap_ttls: TLS_accept: Need to read more data: SSLv3/TLS write server done
(2) eap_ttls: TLS - In Handshake Phase
(2) eap_ttls: TLS - got 2817 bytes of data
(2) eap_ttls: [eaptls process] = handled
(2) eap: Sending EAP Request (code 1) ID 44 length 1004
(2) eap: EAP session adding &reply:State = 0xff99fa83fdb5efc8
(2) [eap] = handled
(2) } # authenticate = handled
(2) Using Post-Auth-Type Challenge
(2) Challenge { ... } # empty sub-section is ignored
(2) Sent Access-Challenge Id 248 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(2) EAP-Message = 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
(2) Message-Authenticator = 0x00000000000000000000000000000000
(2) State = 0xff99fa83fdb5efc8c4b146a7c9273cc4
(2) Finished request
(3) Received Access-Request Id 249 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(3) User-Name = "mathias.maes"
(3) NAS-Identifier = "802aa8d21ff5"
(3) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(3) NAS-Port-Type = Wireless-802.11
(3) Service-Type = Framed-User
(3) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(3) Connect-Info = "CONNECT 0Mbps 802.11b"
(3) Acct-Session-Id = "F611C1164C9282AB"
(3) WLAN-Pairwise-Cipher = 1027076
(3) WLAN-Group-Cipher = 1027076
(3) WLAN-AKM-Suite = 1027073
(3) Framed-MTU = 1400
(3) EAP-Message = 0x022c00061500
(3) State = 0xff99fa83fdb5efc8c4b146a7c9273cc4
(3) Message-Authenticator = 0x7d0f88f4c33bad1184e7c6867eacf50b
(3) session-state: No cached attributes
(3) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(3) authorize {
(3) policy filter_username {
(3) if (&User-Name) {
(3) if (&User-Name) -> TRUE
(3) if (&User-Name =~ / /) {
(3) if (&User-Name =~ / /) -> FALSE
(3) if (&User-Name =~ /@[^@]*@/ ) {
(3) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(3) if (&User-Name =~ /\.\./ ) {
(3) if (&User-Name =~ /\.\./ ) -> FALSE
(3) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(3) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(3) if (&User-Name =~ /\.$/) {
(3) if (&User-Name =~ /\.$/) -> FALSE
(3) if (&User-Name =~ /@\./) {
(3) if (&User-Name =~ /@\./) -> FALSE
(3) } # if (&User-Name) = notfound
(3) } # policy filter_username = notfound
(3) [preprocess] = ok
(3) [chap] = noop
(3) [mschap] = noop
(3) [digest] = noop
(3) suffix: Checking for suffix after "@"
(3) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(3) suffix: No such realm "NULL"
(3) [suffix] = noop
(3) eap: Peer sent EAP Response (code 2) ID 44 length 6
(3) eap: Continuing tunnel setup
(3) [eap] = ok
(3) } # authorize = ok
(3) Found Auth-Type = eap
(3) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(3) authenticate {
(3) eap: Expiring EAP session with state 0xff99fa83fdb5efc8
(3) eap: Finished EAP session with state 0xff99fa83fdb5efc8
(3) eap: Previous EAP request found for state 0xff99fa83fdb5efc8, released from the list
(3) eap: Peer sent packet with method EAP TTLS (21)
(3) eap: Calling submodule eap_ttls to process data
(3) eap_ttls: Authenticate
(3) eap_ttls: Continuing EAP-TLS
(3) eap_ttls: Peer ACKed our handshake fragment
(3) eap_ttls: [eaptls verify] = request
(3) eap_ttls: [eaptls process] = handled
(3) eap: Sending EAP Request (code 1) ID 45 length 1004
(3) eap: EAP session adding &reply:State = 0xff99fa83fcb4efc8
(3) [eap] = handled
(3) } # authenticate = handled
(3) Using Post-Auth-Type Challenge
(3) Challenge { ... } # empty sub-section is ignored
(3) Sent Access-Challenge Id 249 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(3) EAP-Message = 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
(3) Message-Authenticator = 0x00000000000000000000000000000000
(3) State = 0xff99fa83fcb4efc8c4b146a7c9273cc4
(3) Finished request
(4) Received Access-Request Id 250 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(4) User-Name = "mathias.maes"
(4) NAS-Identifier = "802aa8d21ff5"
(4) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(4) NAS-Port-Type = Wireless-802.11
(4) Service-Type = Framed-User
(4) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(4) Connect-Info = "CONNECT 0Mbps 802.11b"
(4) Acct-Session-Id = "F611C1164C9282AB"
(4) WLAN-Pairwise-Cipher = 1027076
(4) WLAN-Group-Cipher = 1027076
(4) WLAN-AKM-Suite = 1027073
(4) Framed-MTU = 1400
(4) EAP-Message = 0x022d00061500
(4) State = 0xff99fa83fcb4efc8c4b146a7c9273cc4
(4) Message-Authenticator = 0xabda589aae605e3af3151667fa842610
(4) session-state: No cached attributes
(4) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(4) authorize {
(4) policy filter_username {
(4) if (&User-Name) {
(4) if (&User-Name) -> TRUE
(4) if (&User-Name =~ / /) {
(4) if (&User-Name =~ / /) -> FALSE
(4) if (&User-Name =~ /@[^@]*@/ ) {
(4) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(4) if (&User-Name =~ /\.\./ ) {
(4) if (&User-Name =~ /\.\./ ) -> FALSE
(4) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(4) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(4) if (&User-Name =~ /\.$/) {
(4) if (&User-Name =~ /\.$/) -> FALSE
(4) if (&User-Name =~ /@\./) {
(4) if (&User-Name =~ /@\./) -> FALSE
(4) } # if (&User-Name) = notfound
(4) } # policy filter_username = notfound
(4) [preprocess] = ok
(4) [chap] = noop
(4) [mschap] = noop
(4) [digest] = noop
(4) suffix: Checking for suffix after "@"
(4) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(4) suffix: No such realm "NULL"
(4) [suffix] = noop
(4) eap: Peer sent EAP Response (code 2) ID 45 length 6
(4) eap: Continuing tunnel setup
(4) [eap] = ok
(4) } # authorize = ok
(4) Found Auth-Type = eap
(4) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(4) authenticate {
(4) eap: Expiring EAP session with state 0xff99fa83fcb4efc8
(4) eap: Finished EAP session with state 0xff99fa83fcb4efc8
(4) eap: Previous EAP request found for state 0xff99fa83fcb4efc8, released from the list
(4) eap: Peer sent packet with method EAP TTLS (21)
(4) eap: Calling submodule eap_ttls to process data
(4) eap_ttls: Authenticate
(4) eap_ttls: Continuing EAP-TLS
(4) eap_ttls: Peer ACKed our handshake fragment
(4) eap_ttls: [eaptls verify] = request
(4) eap_ttls: [eaptls process] = handled
(4) eap: Sending EAP Request (code 1) ID 46 length 839
(4) eap: EAP session adding &reply:State = 0xff99fa83fbb7efc8
(4) [eap] = handled
(4) } # authenticate = handled
(4) Using Post-Auth-Type Challenge
(4) Challenge { ... } # empty sub-section is ignored
(4) Sent Access-Challenge Id 250 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(4) EAP-Message = 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
(4) Message-Authenticator = 0x00000000000000000000000000000000
(4) State = 0xff99fa83fbb7efc8c4b146a7c9273cc4
(4) Finished request
(5) Received Access-Request Id 251 from 172.16.2.24:43616 to 172.16.88.201:1812 length 349
(5) User-Name = "mathias.maes"
(5) NAS-Identifier = "802aa8d21ff5"
(5) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(5) NAS-Port-Type = Wireless-802.11
(5) Service-Type = Framed-User
(5) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(5) Connect-Info = "CONNECT 0Mbps 802.11b"
(5) Acct-Session-Id = "F611C1164C9282AB"
(5) WLAN-Pairwise-Cipher = 1027076
(5) WLAN-Group-Cipher = 1027076
(5) WLAN-AKM-Suite = 1027073
(5) Framed-MTU = 1400
(5) EAP-Message = 0x022e008415001603030046100000424104d9cedffa35763379cc31c62d194b431103b559580a1640d39afff113249f3ae59b8bdea220cac40e2b78d1016c053d2c339785530e6b39515c6a45c497e34e0814030300010116030300280000000000000000e4592bee43925bdfa2f9310f01db8f42fad0f37c4a6c9cb2f09ee58a8f0b08c4
(5) State = 0xff99fa83fbb7efc8c4b146a7c9273cc4
(5) Message-Authenticator = 0xcea397dfdac287d0f74930f84477618a
(5) session-state: No cached attributes
(5) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(5) authorize {
(5) policy filter_username {
(5) if (&User-Name) {
(5) if (&User-Name) -> TRUE
(5) if (&User-Name =~ / /) {
(5) if (&User-Name =~ / /) -> FALSE
(5) if (&User-Name =~ /@[^@]*@/ ) {
(5) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(5) if (&User-Name =~ /\.\./ ) {
(5) if (&User-Name =~ /\.\./ ) -> FALSE
(5) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(5) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(5) if (&User-Name =~ /\.$/) {
(5) if (&User-Name =~ /\.$/) -> FALSE
(5) if (&User-Name =~ /@\./) {
(5) if (&User-Name =~ /@\./) -> FALSE
(5) } # if (&User-Name) = notfound
(5) } # policy filter_username = notfound
(5) [preprocess] = ok
(5) [chap] = noop
(5) [mschap] = noop
(5) [digest] = noop
(5) suffix: Checking for suffix after "@"
(5) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(5) suffix: No such realm "NULL"
(5) [suffix] = noop
(5) eap: Peer sent EAP Response (code 2) ID 46 length 132
(5) eap: Continuing tunnel setup
(5) [eap] = ok
(5) } # authorize = ok
(5) Found Auth-Type = eap
(5) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(5) authenticate {
(5) eap: Expiring EAP session with state 0xff99fa83fbb7efc8
(5) eap: Finished EAP session with state 0xff99fa83fbb7efc8
(5) eap: Previous EAP request found for state 0xff99fa83fbb7efc8, released from the list
(5) eap: Peer sent packet with method EAP TTLS (21)
(5) eap: Calling submodule eap_ttls to process data
(5) eap_ttls: Authenticate
(5) eap_ttls: Continuing EAP-TLS
(5) eap_ttls: [eaptls verify] = ok
(5) eap_ttls: Done initial handshake
(5) eap_ttls: TLS_accept: SSLv3/TLS write server done
(5) eap_ttls: <<< recv TLS 1.2 [length 0046]
(5) eap_ttls: TLS_accept: SSLv3/TLS read client key exchange
(5) eap_ttls: TLS_accept: SSLv3/TLS read change cipher spec
(5) eap_ttls: <<< recv TLS 1.2 [length 0010]
(5) eap_ttls: TLS_accept: SSLv3/TLS read finished
(5) eap_ttls: >>> send TLS 1.2 [length 0001]
(5) eap_ttls: TLS_accept: SSLv3/TLS write change cipher spec
(5) eap_ttls: >>> send TLS 1.2 [length 0010]
(5) eap_ttls: TLS_accept: SSLv3/TLS write finished
(5) eap_ttls: (other): SSL negotiation finished successfully
(5) eap_ttls: TLS - Connection Established
(5) eap_ttls: TLS-Session-Cipher-Suite = "ECDHE-RSA-AES128-GCM-SHA256"
(5) eap_ttls: TLS-Session-Version = "TLS 1.2"
(5) eap_ttls: TLS - got 51 bytes of data
(5) eap_ttls: [eaptls process] = handled
(5) eap: Sending EAP Request (code 1) ID 47 length 61
(5) eap: EAP session adding &reply:State = 0xff99fa83fab6efc8
(5) [eap] = handled
(5) } # authenticate = handled
(5) Using Post-Auth-Type Challenge
(5) Challenge { ... } # empty sub-section is ignored
(5) session-state: Saving cached attributes
(5) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES128-GCM-SHA256"
(5) TLS-Session-Version = "TLS 1.2"
(5) Sent Access-Challenge Id 251 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(5) EAP-Message = 0x012f003d1580000000331403030001011603030028cf633a08613245d8e3beaa6506ee8b1f56248329d8cca80c924e11b3756c22e662b0c90689caa901
(5) Message-Authenticator = 0x00000000000000000000000000000000
(5) State = 0xff99fa83fab6efc8c4b146a7c9273cc4
(5) Finished request
(6) Received Access-Request Id 252 from 172.16.2.24:43616 to 172.16.88.201:1812 length 296
(6) User-Name = "mathias.maes"
(6) NAS-Identifier = "802aa8d21ff5"
(6) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(6) NAS-Port-Type = Wireless-802.11
(6) Service-Type = Framed-User
(6) Calling-Station-Id = "F6-E3-1F-FA-03-A9"
(6) Connect-Info = "CONNECT 0Mbps 802.11b"
(6) Acct-Session-Id = "F611C1164C9282AB"
(6) WLAN-Pairwise-Cipher = 1027076
(6) WLAN-Group-Cipher = 1027076
(6) WLAN-AKM-Suite = 1027073
(6) Framed-MTU = 1400
(6) EAP-Message = 0x022f004f1500170303004400000000000000010df81479983cb3977fec344ec54a11c551d5031c7a0a253c1454278e7015bfe37014bbc3b0ceaeb6ba3831674a0c4bed74d8fbbb528e41b0db1619d1
(6) State = 0xff99fa83fab6efc8c4b146a7c9273cc4
(6) Message-Authenticator = 0x113b2fbc053bd956b188111645901e53
(6) Restoring &session-state
(6) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES128-GCM-SHA256"
(6) &session-state:TLS-Session-Version = "TLS 1.2"
(6) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(6) authorize {
(6) policy filter_username {
(6) if (&User-Name) {
(6) if (&User-Name) -> TRUE
(6) if (&User-Name =~ / /) {
(6) if (&User-Name =~ / /) -> FALSE
(6) if (&User-Name =~ /@[^@]*@/ ) {
(6) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(6) if (&User-Name =~ /\.\./ ) {
(6) if (&User-Name =~ /\.\./ ) -> FALSE
(6) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(6) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALSE
(6) if (&User-Name =~ /\.$/) {
(6) if (&User-Name =~ /\.$/) -> FALSE
(6) if (&User-Name =~ /@\./) {
(6) if (&User-Name =~ /@\./) -> FALSE
(6) } # if (&User-Name) = notfound
(6) } # policy filter_username = notfound
(6) [preprocess] = ok
(6) [chap] = noop
(6) [mschap] = noop
(6) [digest] = noop
(6) suffix: Checking for suffix after "@"
(6) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(6) suffix: No such realm "NULL"
(6) [suffix] = noop
(6) eap: Peer sent EAP Response (code 2) ID 47 length 79
(6) eap: Continuing tunnel setup
(6) [eap] = ok
(6) } # authorize = ok
(6) Found Auth-Type = eap
(6) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(6) authenticate {
(6) eap: Expiring EAP session with state 0xff99fa83fab6efc8
(6) eap: Finished EAP session with state 0xff99fa83fab6efc8
(6) eap: Previous EAP request found for state 0xff99fa83fab6efc8, released from the list
(6) eap: Peer sent packet with method EAP TTLS (21)
(6) eap: Calling submodule eap_ttls to process data
(6) eap_ttls: Authenticate
(6) eap_ttls: Continuing EAP-TLS
(6) eap_ttls: [eaptls verify] = ok
(6) eap_ttls: Done initial handshake
(6) eap_ttls: [eaptls process] = ok
(6) eap_ttls: Session established. Proceeding to decode tunneled attributes
(6) eap_ttls: Got tunneled request
(6) eap_ttls: User-Name = "mathias.maes"
(6) eap_ttls: User-Password = "xxxxxxxxxxxxxxxxxxxxxxx"
(6) eap_ttls: FreeRADIUS-Proxied-To = 127.0.0.1
(6) eap_ttls: Sending tunneled request
(6) Virtual server inner-tunnel received request
(6) User-Password = "xxxxxxxxxxxxxxxxxxxxxx"
(6) FreeRADIUS-Proxied-To = 127.0.0.1
(6) WARNING: Outer and inner identities are the same. User privacy is compromised.
(6) server inner-tunnel {
(6) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(6) authorize {
(6) [suffix] = noop
(6) update control {
(6) &Proxy-To-Realm := LOCAL
(6) } # update control = noop
(6) eap: No EAP-Message, not doing EAP
(6) [eap] = noop
rlm_ldap (ldap): Reserved connection (1)
(6) ldap: EXPAND (uid=%{%{Stripped-User-Name}:-%{User-Name}})
(6) ldap: --> (uid=mathias.maes)
(6) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mathias.maes)", scope "sub"
(6) ldap: Waiting for search result...
(6) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(6) ldap: Processing user attributes
(6) ldap: WARNING: No "known good" password added. Ensure the admin user has permission to read the password attribute
(6) ldap: WARNING: PAP authentication will *NOT* work with Active Directory (if that is what you were trying to configure)
rlm_ldap (ldap): Released connection (1)
Need 4 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (6), 1 of 26 pending slots used
(6) [ldap] = ok
(6) [expiration] = noop
(6) [logintime] = noop
(6) [pap] = noop
(6) if (User-Password) {
(6) if (User-Password) -> TRUE
(6) Auth-Type := ldap
(6) } # if (User-Password) = noop
(6) Found Auth-Type = ldap
(6) # Executing group from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(6) authenticate {
rlm_ldap (ldap): Reserved connection (2)
(6) ldap: Login attempt by "mathias.maes"
(6) ldap: Using user DN from request "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(6) ldap: Waiting for bind result...
(6) ldap: Bind successful
(6) ldap: Bind as user "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be" was successful
rlm_ldap (ldap): Released connection (2)
Need 3 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (7), 1 of 25 pending slots used
(6) [ldap] = ok
(6) } # authenticate = ok
(6) # Executing section post-auth from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(6) post-auth {
(6) if (LDAP-Group == "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be"
rlm_ldap (ldap): Reserved connection (3)
(6) Using user DN from request "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be"
(6) Checking user object's memberOf attributes
(6) Performing unfiltered search in "uid=mathias.maes,ou=Secretariaat,ou=Atheneum,ou=Users,dc=maerlantatheneum,dc=be", scope "base"
(6) Waiting for search result...
(6) Processing memberOf value "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=classroom_docenten,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=iedereen,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=informatica,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
(6) Processing memberOf value "cn=sharpinfo,ou=Groups,dc=maerlantatheneum,dc=be" as a DN
rlm_ldap (ldap): Released connection (3)
Need 2 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (8), 1 of 24 pending slots used
(6) User is not a member of "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be"
(6) if (LDAP-Group == "cn=leerkrachten,ou=Groups,dc=maerlantatheneum,dc=be") -> FALSE
(6) elsif (LDAP-Group == "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be"
rlm_ldap (ldap): Reserved connection (4)
rlm_ldap (ldap): Released connection (4)
Need 1 more connections to reach 10 spares
rlm_ldap (ldap): Opening additional connection (9), 1 of 23 pending slots used
(6) User is not a member of "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be"
(6) elsif (LDAP-Group == "cn=secretariaat,ou=Groups,dc=maerlantatheneum,dc=be") -> FALSE
(6) elsif (LDAP-Group == "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be"
(6) User is not a member of "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be"
(6) elsif (LDAP-Group == "cn=ondersteuners,ou=Groups,dc=maerlantatheneum,dc=be") -> FALSE
rlm_ldap (ldap): Reserved connection (5)
rlm_ldap (ldap): Released connection (5)
(6) elsif (LDAP-Group == "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be") {
(6) Searching for user in group "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be"
(6) User found in group DN "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be". Comparison between membership: dn, check: dn
(6) elsif (LDAP-Group == "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be") -> TRUE
(6) update reply {
(6) Tunnel-Type = VLAN
(6) Tunnel-Medium-Type = IEEE-802
(6) Tunnel-Private-Group-Id = 10
(6) } # update reply = noop
(6) } # elsif (LDAP-Group == "cn=beheerders,ou=Groups,dc=maerlantatheneum,dc=be") = noop
(6) ... skipping else: Preceding "if" was taken
(6) if (1) {
(6) if (1) -> TRUE
(6) if (1) {
(6) update reply {
(6) User-Name !* ANY
(6) Message-Authenticator !* ANY
(6) EAP-Message !* ANY
(6) Proxy-State !* ANY
(6) MS-MPPE-Encryption-Types !* ANY
(6) MS-MPPE-Encryption-Policy !* ANY
(6) MS-MPPE-Send-Key !* ANY
(6) MS-MPPE-Recv-Key !* ANY
(6) update {
(6) &outer.session-state::Tunnel-Type += &reply:Tunnel-Type• -> VLAN
(6) &outer.session-state::Tunnel-Medium-Type += &reply:Tunnel-Medium-Type• -> IEEE-802
(6) &outer.session-state::Tunnel-Private-Group-Id += &reply:Tunnel-Private-Group-Id• -> '10'
(6) } # update = noop
(6) } # if (1) = noop
(6) } # post-auth = noop
(6) } # server inner-tunnel
(6) Virtual server sending reply
(6) Tunnel-Private-Group-Id = "10"
(6) eap_ttls: Got tunneled Access-Accept
(6) eap: Sending EAP Success (code 3) ID 47 length 4
(6) eap: Freeing handler
(6) [eap] = ok
(6) # Executing section post-auth from file /etc/freeradius/3.0/sites-enabled/default
(6) post-auth {
(6) if (session-state:User-Name && reply:User-Name && request:User-Name && (reply:User-Name == request:User-Name)) {
(6) if (session-state:User-Name && reply:User-Name && request:User-Name && (reply:User-Name == request:User-Name)) -> FALSE
(6) update {
(6) &reply::TLS-Session-Cipher-Suite += &session-state:TLS-Session-Cipher-Suite• -> 'ECDHE-RSA-AES128-GCM-SHA256'
(6) &reply::TLS-Session-Version += &session-state:TLS-Session-Version• -> 'TLS 1.2'
(6) &reply::Tunnel-Type += &session-state:Tunnel-Type• -> VLAN
(6) &reply::Tunnel-Medium-Type += &session-state:Tunnel-Medium-Type• -> IEEE-802
(6) &reply::Tunnel-Private-Group-Id += &session-state:Tunnel-Private-Group-Id• -> '10'
(6) [exec] = noop
(6) policy remove_reply_message_if_eap {
(6) if (&reply:EAP-Message && &reply:Reply-Message) {
(6) if (&reply:EAP-Message && &reply:Reply-Message) -> FALSE
(6) else {
(6) [noop] = noop
(6) } # else = noop
(6) } # policy remove_reply_message_if_eap = noop
(6) Sent Access-Accept Id 252 from 172.16.88.201:1812 to 172.16.2.24:43616 length 0
(6) MS-MPPE-Recv-Key = 0x1b44664b78cff6fc3f330eb258a1158b7f1b1e65ea07bb0465e5b966aca6d2db
(6) MS-MPPE-Send-Key = 0xf28ea12efb799871770dff57e799be42cecd67c7a77b58b137b452a3ce88a4d2
(6) EAP-Message = 0x032f0004
(6) Message-Authenticator = 0x00000000000000000000000000000000
(6) Tunnel-Type += VLAN
(6) Tunnel-Medium-Type += IEEE-802
(6) Tunnel-Private-Group-Id += "10"
(6) Finished request
(0) Cleaning up request packet ID 246 with timestamp +38
(1) Cleaning up request packet ID 247 with timestamp +38
(2) Cleaning up request packet ID 248 with timestamp +40
(3) Cleaning up request packet ID 249 with timestamp +40
(4) Cleaning up request packet ID 250 with timestamp +40
(5) Cleaning up request packet ID 251 with timestamp +40
(6) Sending duplicate reply to client StilleLeraarskamer port 43616 - ID: 252
Waking up in 9.9 seconds.
(6) Cleaning up request packet ID 252 with timestamp +40
En dan hier mijn Freeradius log met Windows (zelfde credentials)
(0) Received Access-Request Id 187 from 172.16.2.24:43616 to 172.16.88.201:1812 length 216
(0) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(0) Acct-Session-Id = "91947FC2865BC082"
(0) EAP-Message = 0x02720011016d6174686961732e6d616573
(0) Message-Authenticator = 0x515f9696923540a58f3eeae482177330
(0) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(0) authorize {
(0) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(0) [chap] = noop
(0) [mschap] = noop
(0) [digest] = noop
(0) [suffix] = noop
(0) eap: Peer sent EAP Response (code 2) ID 114 length 17
(0) [eap] = ok
(0) authenticate {
(0) eap: Sending EAP Request (code 1) ID 115 length 22
(0) eap: EAP session adding &reply:State = 0x8992220389e12690
(0) [eap] = handled
(0) Sent Access-Challenge Id 187 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(0) EAP-Message = 0x017300160410b1fd2b55fe05c489f528ef67441d4e20
(0) State = 0x8992220389e12690bf08241ae32c8474
(1) Received Access-Request Id 188 from 172.16.2.24:43616 to 172.16.88.201:1812 length 224
(1) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(1) Acct-Session-Id = "91947FC2865BC082"
(1) EAP-Message = 0x02730007031915
(1) State = 0x8992220389e12690bf08241ae32c8474
(1) Message-Authenticator = 0x6a137ff79215091f27021135b407b85c
(1) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(1) authorize {
(1) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(1) [chap] = noop
(1) [mschap] = noop
(1) [digest] = noop
(1) [suffix] = noop
(1) eap: Peer sent EAP Response (code 2) ID 115 length 7
(1) [eap] = updated
(1) [files] = noop
(1) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mat hias.maes)", scope "sub"
(1) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum, ou=Users,dc=maerlantatheneum,dc=be"
(1) ldap: WARNING: No "known good" password added. Ensure the admin user has per mission to read the password attribute
(1) [ldap] = ok
(1) [pap] = noop
(1) authenticate {
(1) eap: Expiring EAP session with state 0x8992220389e12690
(1) eap: Finished EAP session with state 0x8992220389e12690
(1) eap: Previous EAP request found for state 0x8992220389e12690, released from the list
(1) eap: Found mutually acceptable type PEAP (25)
(1) eap: Calling submodule eap_peap to process data
(1) eap_peap: Initiating new TLS session
(1) eap_peap: [eaptls start] = request
(1) eap: Sending EAP Request (code 1) ID 116 length 6
(1) eap: EAP session adding &reply:State = 0x8992220388e63b90
(1) [eap] = handled
(1) Sent Access-Challenge Id 188 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(1) EAP-Message = 0x017400061920
(1) State = 0x8992220388e63b90bf08241ae32c8474
(2) Received Access-Request Id 189 from 172.16.2.24:43616 to 172.16.88.201:1812 length 415
(2) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(2) Acct-Session-Id = "91947FC2865BC082"
(2) EAP-Message = 0x027400c61980000000bc16030300b7010000b303035ef1b84950ab98e3 5a88c093aa155fa457545259e9793f91f43d3d9e260d05f620a3350000e8831c94e64a00758ed88b 0f89d893ab528df0a8942760fdf3b604c1002ac02cc02bc030c02f009f009ec024c023c028c027c0 0ac009c014c013009d009c003d003c0035002f000a01000040000500050100000000000a00080006 001d00170018000b00020100000d0014001204010501020104030503020302020601060300230000 00170000ff01000100
(2) State = 0x8992220388e63b90bf08241ae32c8474
(2) Message-Authenticator = 0xbfe3022bd53b0a25be827b4eaa3e058b
(2) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(2) authorize {
(2) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(2) [chap] = noop
(2) [mschap] = noop
(2) [digest] = noop
(2) [suffix] = noop
(2) eap: Peer sent EAP Response (code 2) ID 116 length 198
(2) [eap] = ok
(2) authenticate {
(2) eap: Expiring EAP session with state 0x8992220388e63b90
(2) eap: Finished EAP session with state 0x8992220388e63b90
(2) eap: Previous EAP request found for state 0x8992220388e63b90, released from the list
(2) eap: Peer sent packet with method EAP PEAP (25)
(2) eap: Calling submodule eap_peap to process data
(2) eap_peap: Continuing EAP-TLS
(2) eap_peap: Peer indicated complete TLS record size will be 188 bytes
(2) eap_peap: Got complete TLS record (188 bytes)
(2) eap_peap: [eaptls verify] = length included
(2) eap_peap: (other): before SSL initialization
(2) eap_peap: TLS_accept: before SSL initialization
(2) eap_peap: <<< recv TLS 1.3 [length 00b7]
(2) eap_peap: TLS_accept: SSLv3/TLS read client hello
(2) eap_peap: >>> send TLS 1.2 [length 003d]
(2) eap_peap: TLS_accept: SSLv3/TLS write server hello
(2) eap_peap: >>> send TLS 1.2 [length 095f]
(2) eap_peap: TLS_accept: SSLv3/TLS write certificate
(2) eap_peap: >>> send TLS 1.2 [length 014d]
(2) eap_peap: TLS_accept: SSLv3/TLS write key exchange
(2) eap_peap: >>> send TLS 1.2 [length 0004]
(2) eap_peap: TLS_accept: SSLv3/TLS write server done
(2) eap_peap: TLS_accept: Need to read more data: SSLv3/TLS write server done
(2) eap_peap: TLS - In Handshake Phase
(2) eap_peap: TLS - got 2817 bytes of data
(2) eap_peap: [eaptls process] = handled
(2) eap: Sending EAP Request (code 1) ID 117 length 1004
(2) eap: EAP session adding &reply:State = 0x899222038be73b90
(2) [eap] = handled
(2) Sent Access-Challenge Id 189 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(2) EAP-Message = 0x017503ec19c000000b01160303003d020000390303ea8e43a59953f574 9627d6aaa5ec610f90e902b987e64922c6d93f7c7699c11000c030000011ff01000100000b000403 00010200170000160303095f0b00095b00095800040c30820408308202f0a003020102020103300d 06092a864886f70d01010b05003081ab310b30090603550406130242453118301606035504080c0f 576573742d566c61616e646572656e3115301306035504070c0c426c616e6b656e6265726765311a 3018060355040a0c114d6165726c616e7420417468656e65756d3126302406092a864886f70d0109 011617696374406d6165726c616e74617468656e65756d2e62653127302506035504030c1e4d6165 726c616e7420436572746966696361746520417574686f72697479301e170d323030363232313230 3731395a170d3238303930383132303731395a308191310b30090603550406130242453118301606 035504080c0f576573742d566c61616e646572656e311a301806
(2) State = 0x899222038be73b90bf08241ae32c8474
(3) Received Access-Request Id 190 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(3) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(3) Acct-Session-Id = "91947FC2865BC082"
(3) EAP-Message = 0x027500061900
(3) State = 0x899222038be73b90bf08241ae32c8474
(3) Message-Authenticator = 0xeda3f1678d96ef5860af25db6c4580ae
(3) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(3) authorize {
(3) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(3) [chap] = noop
(3) [mschap] = noop
(3) [digest] = noop
(3) [suffix] = noop
(3) eap: Peer sent EAP Response (code 2) ID 117 length 6
(3) [eap] = ok
(3) authenticate {
(3) eap: Expiring EAP session with state 0x899222038be73b90
(3) eap: Finished EAP session with state 0x899222038be73b90
(3) eap: Previous EAP request found for state 0x899222038be73b90, released from the list
(3) eap: Peer sent packet with method EAP PEAP (25)
(3) eap: Calling submodule eap_peap to process data
(3) eap_peap: Continuing EAP-TLS
(3) eap_peap: Peer ACKed our handshake fragment
(3) eap_peap: [eaptls verify] = request
(3) eap_peap: [eaptls process] = handled
(3) eap: Sending EAP Request (code 1) ID 118 length 1000
(3) eap: EAP session adding &reply:State = 0x899222038ae43b90
(3) [eap] = handled
(3) Sent Access-Challenge Id 190 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(3) EAP-Message = 0x017603e8194070488ce412eba7500f4d512568bd1d5209d0ad23dd1aaa a05927345a928880590587613a24aca2646c60f387f26fc46616d66ca22af9a18fa8db3dc1ed6173 7e6a2853ac59556b98b291415a51eb702d46518ca694d63afd6941e22d7c05578b40ab6a4182f50f f203346d98eb2a76bd46b0578116fb0416817971000546308205423082042aa003020102021422f4 15a6bd400b4959d074420f3af2929e3504a5300d06092a864886f70d01010b05003081ab310b3009 0603550406130242453118301606035504080c0f576573742d566c61616e646572656e3115301306 035504070c0c426c616e6b656e6265726765311a3018060355040a0c114d6165726c616e74204174 68656e65756d3126302406092a864886f70d0109011617696374406d6165726c616e74617468656e 65756d2e62653127302506035504030c1e4d6165726c616e74204365727469666963617465204175 74686f72697479301e170d3230303632323132303635305a170d
(3) State = 0x899222038ae43b90bf08241ae32c8474
(4) Received Access-Request Id 191 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(4) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(4) Acct-Session-Id = "91947FC2865BC082"
(4) EAP-Message = 0x027600061900
(4) State = 0x899222038ae43b90bf08241ae32c8474
(4) Message-Authenticator = 0xa2086c1e567ed9165fcb905e57e9caf5
(4) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(4) authorize {
(4) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(4) [chap] = noop
(4) [mschap] = noop
(4) [digest] = noop
(4) [suffix] = noop
(4) eap: Peer sent EAP Response (code 2) ID 118 length 6
(4) [eap] = ok
(4) authenticate {
(4) eap: Expiring EAP session with state 0x899222038ae43b90
(4) eap: Finished EAP session with state 0x899222038ae43b90
(4) eap: Previous EAP request found for state 0x899222038ae43b90, released from the list
(4) eap: Peer sent packet with method EAP PEAP (25)
(4) eap: Calling submodule eap_peap to process data
(4) eap_peap: Continuing EAP-TLS
(4) eap_peap: Peer ACKed our handshake fragment
(4) eap_peap: [eaptls verify] = request
(4) eap_peap: [eaptls process] = handled
(4) eap: Sending EAP Request (code 1) ID 119 length 835
(4) eap: EAP session adding &reply:State = 0x899222038de53b90
(4) [eap] = handled
(4) Sent Access-Challenge Id 191 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(4) EAP-Message = 0x0177034319006765311a3018060355040a0c114d6165726c616e742041 7468656e65756d3126302406092a864886f70d0109011617696374406d6165726c616e7461746865 6e65756d2e62653127302506035504030c1e4d6165726c616e742043657274696669636174652041 7574686f72697479821422f415a6bd400b4959d074420f3af2929e3504a5300f0603551d130101ff 040530030101ff30360603551d1f042f302d302ba029a0278625687474703a2f2f7777772e657861 6d706c652e6f72672f6578616d706c655f63612e63726c300d06092a864886f70d01010b05000382 0101001b15ac9e8823380db4f5cd501c671a15f6aa92262343001d1792cbeb33aff78f57b20306b1 84c7dcc4633daeed83a6e24bf2eed1eaee09050c9e09e2c6505857d0c4ffb0556ec0f65bdaf335af 1ba670a759ac6cc5cca630793f1e0dc9b2e9ac842a377944815c8174fced0736dacdf63e1fdc41b8 0d1374c6c57b5a1e308fc9f9311a56972cc72ff3812a9be3a00f
(4) State = 0x899222038de53b90bf08241ae32c8474
(5) Received Access-Request Id 192 from 172.16.2.24:43616 to 172.16.88.201:1812 length 353
(5) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(5) Acct-Session-Id = "91947FC2865BC082"
(5) EAP-Message = 0x0277008819800000007e16030300461000004241048b429ff5a317563b 7da86072baa0a06ddf0acf9bd093c9cdad91e512d268070941cf7f9edb8a34ea678d2669435a8fde 3d45f5e0376d5804d6051caccec292981403030001011603030028000000000000000056542f752d 543b1412aa0b51cf32485f64636ebceb87c480b5a4af2967654d12
(5) State = 0x899222038de53b90bf08241ae32c8474
(5) Message-Authenticator = 0xbcb9083b3b2c8b1c84e4c954d0761d67
(5) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(5) authorize {
(5) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(5) [chap] = noop
(5) [mschap] = noop
(5) [digest] = noop
(5) [suffix] = noop
(5) eap: Peer sent EAP Response (code 2) ID 119 length 136
(5) [eap] = ok
(5) authenticate {
(5) eap: Expiring EAP session with state 0x899222038de53b90
(5) eap: Finished EAP session with state 0x899222038de53b90
(5) eap: Previous EAP request found for state 0x899222038de53b90, released from the list
(5) eap: Peer sent packet with method EAP PEAP (25)
(5) eap: Calling submodule eap_peap to process data
(5) eap_peap: Continuing EAP-TLS
(5) eap_peap: Peer indicated complete TLS record size will be 126 bytes
(5) eap_peap: Got complete TLS record (126 bytes)
(5) eap_peap: [eaptls verify] = length included
(5) eap_peap: TLS_accept: SSLv3/TLS write server done
(5) eap_peap: <<< recv TLS 1.2 [length 0046]
(5) eap_peap: TLS_accept: SSLv3/TLS read client key exchange
(5) eap_peap: TLS_accept: SSLv3/TLS read change cipher spec
(5) eap_peap: <<< recv TLS 1.2 [length 0010]
(5) eap_peap: TLS_accept: SSLv3/TLS read finished
(5) eap_peap: >>> send TLS 1.2 [length 0001]
(5) eap_peap: TLS_accept: SSLv3/TLS write change cipher spec
(5) eap_peap: >>> send TLS 1.2 [length 0010]
(5) eap_peap: TLS_accept: SSLv3/TLS write finished
(5) eap_peap: (other): SSL negotiation finished successfully
(5) eap_peap: TLS - Connection Established
(5) eap_peap: TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(5) eap_peap: TLS-Session-Version = "TLS 1.2"
(5) eap_peap: TLS - got 51 bytes of data
(5) eap_peap: [eaptls process] = handled
(5) eap: Sending EAP Request (code 1) ID 120 length 57
(5) eap: EAP session adding &reply:State = 0x899222038cea3b90
(5) [eap] = handled
(5) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(5) Sent Access-Challenge Id 192 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(5) EAP-Message = 0x01780039190014030300010116030300285fb253d979c740904027949a 5e2d92a0cee956cab654dbb996b86aa71a8b29cbe4ecaaddf16277fb
(5) State = 0x899222038cea3b90bf08241ae32c8474
(6) Received Access-Request Id 193 from 172.16.2.24:43616 to 172.16.88.201:1812 length 223
(6) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(6) Acct-Session-Id = "91947FC2865BC082"
(6) EAP-Message = 0x027800061900
(6) State = 0x899222038cea3b90bf08241ae32c8474
(6) Message-Authenticator = 0xc2a64f445aab020dba5dbe2e5007f270
(6) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(6) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(6) authorize {
(6) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(6) [chap] = noop
(6) [mschap] = noop
(6) [digest] = noop
(6) [suffix] = noop
(6) eap: Peer sent EAP Response (code 2) ID 120 length 6
(6) [eap] = ok
(6) authenticate {
(6) eap: Expiring EAP session with state 0x899222038cea3b90
(6) eap: Finished EAP session with state 0x899222038cea3b90
(6) eap: Previous EAP request found for state 0x899222038cea3b90, released from the list
(6) eap: Peer sent packet with method EAP PEAP (25)
(6) eap: Calling submodule eap_peap to process data
(6) eap_peap: Continuing EAP-TLS
(6) eap_peap: Peer ACKed our handshake fragment. handshake is finished
(6) eap_peap: [eaptls verify] = success
(6) eap_peap: [eaptls process] = success
(6) eap_peap: Session established. Decoding tunneled attributes
(6) eap_peap: PEAP state TUNNEL ESTABLISHED
(6) eap: Sending EAP Request (code 1) ID 121 length 40
(6) eap: EAP session adding &reply:State = 0x899222038feb3b90
(6) [eap] = handled
(6) } # authenticate = handled
(6) Using Post-Auth-Type Challenge
(6) Challenge { ... } # empty sub-section is ignored
(6) session-state: Saving cached attributes
(6) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(6) TLS-Session-Version = "TLS 1.2"
(6) Sent Access-Challenge Id 193 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(6) EAP-Message = 0x017900281900170303001d5fb253d979c74091903e99498f277d8556b9 8dc21e6eeedc1aed42a81a
(6) State = 0x899222038feb3b90bf08241ae32c8474
Waking up in 0.9 seconds.
(7) Received Access-Request Id 194 from 172.16.2.24:43616 to 172.16.88.201:1812 length 265
(7) User-Name = "mathias.maes"
(7) NAS-Identifier = "802aa8d21ff5"
(7) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(7) NAS-Port-Type = Wireless-802.11
(7) Service-Type = Framed-User
(7) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(7) Connect-Info = "CONNECT 0Mbps 802.11b"
(7) Acct-Session-Id = "91947FC2865BC082"
(7) WLAN-Pairwise-Cipher = 1027076
(7) WLAN-Group-Cipher = 1027076
(7) WLAN-AKM-Suite = 1027073
(7) Framed-MTU = 1400
(7) EAP-Message = 0x0279003019001703030025000000000000000163ae27ed6104c9ba4fd4 b42a8a5d6e01c023c9203e1187756780144b95
(7) State = 0x899222038feb3b90bf08241ae32c8474
(7) Message-Authenticator = 0x04c4a4ba869547230d3d295735f2d4fa
(7) Restoring &session-state
(7) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(7) &session-state:TLS-Session-Version = "TLS 1.2"
(7) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(7) authorize {
(7) policy filter_username {
(7) if (&User-Name) {
(7) if (&User-Name) -> TRUE
(7) if (&User-Name =~ / /) {
(7) if (&User-Name =~ / /) -> FALSE
(7) if (&User-Name =~ /@[^@]*@/ ) {
(7) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(7) if (&User-Name =~ /\.\./ ) {
(7) if (&User-Name =~ /\.\./ ) -> FALSE
(7) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(7) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(7) if (&User-Name =~ /\.$/) {
(7) if (&User-Name =~ /\.$/) -> FALSE
(7) if (&User-Name =~ /@\./) {
(7) if (&User-Name =~ /@\./) -> FALSE
(7) } # if (&User-Name) = notfound
(7) } # policy filter_username = notfound
(7) [preprocess] = ok
(7) [chap] = noop
(7) [mschap] = noop
(7) [digest] = noop
(7) suffix: Checking for suffix after "@"
(7) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(7) suffix: No such realm "NULL"
(7) [suffix] = noop
(7) eap: Peer sent EAP Response (code 2) ID 121 length 48
(7) eap: Continuing tunnel setup
(7) [eap] = ok
(7) } # authorize = ok
(7) Found Auth-Type = eap
(7) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(7) authenticate {
(7) eap: Expiring EAP session with state 0x899222038feb3b90
(7) eap: Finished EAP session with state 0x899222038feb3b90
(7) eap: Previous EAP request found for state 0x899222038feb3b90, released from the list
(7) eap: Peer sent packet with method EAP PEAP (25)
(7) eap: Calling submodule eap_peap to process data
(7) eap_peap: Continuing EAP-TLS
(7) eap_peap: [eaptls verify] = ok
(7) eap_peap: Done initial handshake
(7) eap_peap: [eaptls process] = ok
(7) eap_peap: Session established. Decoding tunneled attributes
(7) eap_peap: PEAP state WAITING FOR INNER IDENTITY
(7) eap_peap: Identity - mathias.maes
(7) eap_peap: Got inner identity 'mathias.maes'
(7) eap_peap: Setting default EAP type for tunneled EAP session
(7) eap_peap: Got tunneled request
(7) eap_peap: EAP-Message = 0x02790011016d6174686961732e6d616573
(7) eap_peap: Setting User-Name to mathias.maes
(7) eap_peap: Sending tunneled request to inner-tunnel
(7) eap_peap: FreeRADIUS-Proxied-To = 127.0.0.1
(7) eap_peap: User-Name = "mathias.maes"
(7) Virtual server inner-tunnel received request
(7) EAP-Message = 0x02790011016d6174686961732e6d616573
(7) FreeRADIUS-Proxied-To = 127.0.0.1
(7) WARNING: Outer and inner identities are the same. User privacy is compromis ed.
(7) server inner-tunnel {
(7) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/ inner-tunnel
(7) authorize {
(7) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FA LSE
(7) [suffix] = noop
(7) update control {
(7) &Proxy-To-Realm := LOCAL
(7) } # update control = noop
(7) eap: Peer sent EAP Response (code 2) ID 121 length 17
(7) eap: EAP-Identity reply, returning 'ok' so we can short-circuit the rest of authorize
(7) [eap] = ok
(7) # Executing group from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(7) authenticate {
(7) eap: Peer sent packet with method EAP Identity (1)
(7) eap: Calling submodule eap_mschapv2 to process data
(7) eap_mschapv2: Issuing Challenge
(7) eap: Sending EAP Request (code 1) ID 122 length 43
(7) eap: EAP session adding &reply:State = 0xd6a318ead6d902b4
(7) [eap] = handled
(7) } # authenticate = handled
(7) } # server inner-tunnel
(7) Virtual server sending reply
(7) EAP-Message = 0x017a002b1a017a002610af39985abac40acf623e7c81b06bacd3667265 657261646975732d332e302e3230
(7) Message-Authenticator = 0x00000000000000000000000000000000
(7) State = 0xd6a318ead6d902b4bcc6c898d0560e68
(7) eap_peap: Got tunneled reply code 11
(7) eap_peap: EAP-Message = 0x017a002b1a017a002610af39985abac40acf623e7c81b06b acd3667265657261646975732d332e302e3230
(7) eap_peap: Message-Authenticator = 0x00000000000000000000000000000000
(7) eap_peap: State = 0xd6a318ead6d902b4bcc6c898d0560e68
(7) eap_peap: Got tunneled reply RADIUS code 11
(7) eap_peap: Got tunneled Access-Challenge
(7) eap: Sending EAP Request (code 1) ID 122 length 74
(7) eap: EAP session adding &reply:State = 0x899222038ee83b90
(7) [eap] = handled
(7) Using Post-Auth-Type Challenge
(7) Challenge { ... } # empty sub-section is ignored
(7) session-state: Saving cached attributes
(7) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(7) TLS-Session-Version = "TLS 1.2"
(7) Sent Access-Challenge Id 194 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(7) EAP-Message = 0x017a004a1900170303003f5fb253d979c740921eb3e65834ef373ec35d e2fbae7d484dae98a561985509704ae6c71383396416e8c1756691c23c6e03785ff3f757b540dba6 b7d380e15f
(7) State = 0x899222038ee83b90bf08241ae32c8474
(7) Finished request
(8) Received Access-Request Id 195 from 172.16.2.24:43616 to 172.16.88.201:1812 length 319
(8) User-Name = "mathias.maes"
(8) NAS-Identifier = "802aa8d21ff5"
(8) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(8) NAS-Port-Type = Wireless-802.11
(8) Service-Type = Framed-User
(8) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(8) Connect-Info = "CONNECT 0Mbps 802.11b"
(8) Acct-Session-Id = "91947FC2865BC082"
(8) WLAN-Pairwise-Cipher = 1027076
(8) WLAN-Group-Cipher = 1027076
(8) WLAN-AKM-Suite = 1027073
(8) Framed-MTU = 1400
(8) EAP-Message = 0x027a00661900170303005b00000000000000027e5a30666bb006bee7dc 9188424c2f8d2d323705d3302c337288fbb4449c7305ce51c5a411dc54675908867ba9c07b971bcd 65c0a2568ce529f3415607805b578a5c28d87d8780e328ddaa1c7c630559d69d7a
(8) State = 0x899222038ee83b90bf08241ae32c8474
(8) Message-Authenticator = 0xfdacbbf0542569a766183455eb59bd92
(8) Restoring &session-state
(8) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(8) &session-state:TLS-Session-Version = "TLS 1.2"
(8) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(8) authorize {
(8) policy filter_username {
(8) if (&User-Name) {
(8) if (&User-Name) -> TRUE
(8) if (&User-Name =~ / /) {
(8) if (&User-Name =~ / /) -> FALSE
(8) if (&User-Name =~ /@[^@]*@/ ) {
(8) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(8) if (&User-Name =~ /\.\./ ) {
(8) if (&User-Name =~ /\.\./ ) -> FALSE
(8) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(8) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(8) if (&User-Name =~ /\.$/) {
(8) if (&User-Name =~ /\.$/) -> FALSE
(8) if (&User-Name =~ /@\./) {
(8) if (&User-Name =~ /@\./) -> FALSE
(8) } # if (&User-Name) = notfound
(8) } # policy filter_username = notfound
(8) [preprocess] = ok
(8) [chap] = noop
(8) [mschap] = noop
(8) [digest] = noop
(8) suffix: Checking for suffix after "@"
(8) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(8) suffix: No such realm "NULL"
(8) [suffix] = noop
(8) eap: Peer sent EAP Response (code 2) ID 122 length 102
(8) eap: Continuing tunnel setup
(8) [eap] = ok
(8) } # authorize = ok
(8) Found Auth-Type = eap
(8) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(8) authenticate {
(8) eap: Expiring EAP session with state 0xd6a318ead6d902b4
(8) eap: Finished EAP session with state 0x899222038ee83b90
(8) eap: Previous EAP request found for state 0x899222038ee83b90, released from the list
(8) eap: Peer sent packet with method EAP PEAP (25)
(8) eap: Calling submodule eap_peap to process data
(8) eap_peap: Continuing EAP-TLS
(8) eap_peap: [eaptls verify] = ok
(8) eap_peap: Done initial handshake
(8) eap_peap: [eaptls process] = ok
(8) eap_peap: Session established. Decoding tunneled attributes
(8) eap_peap: PEAP state phase2
(8) eap_peap: EAP method MSCHAPv2 (26)
(8) eap_peap: Got tunneled request
(8) eap_peap: EAP-Message = 0x027a00471a027a004231007c3c0965072c9267b33a349677 dcd000000000000000007180797575f18a484b780fedad03f2c98c4a3b026b4bfb77006d61746869 61732e6d616573
(8) eap_peap: Setting User-Name to mathias.maes
(8) eap_peap: Sending tunneled request to inner-tunnel
(8) eap_peap: FreeRADIUS-Proxied-To = 127.0.0.1
(8) eap_peap: User-Name = "mathias.maes"
(8) eap_peap: State = 0xd6a318ead6d902b4bcc6c898d0560e68
(8) Virtual server inner-tunnel received request
(8) EAP-Message = 0x027a00471a027a004231007c3c0965072c9267b33a349677dcd0000000 00000000007180797575f18a484b780fedad03f2c98c4a3b026b4bfb77006d6174686961732e6d61 6573
(8) FreeRADIUS-Proxied-To = 127.0.0.1
(8) State = 0xd6a318ead6d902b4bcc6c898d0560e68
(8) WARNING: Outer and inner identities are the same. User privacy is compromis ed.
(8) server inner-tunnel {
(8) session-state: No cached attributes
(8) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/ inner-tunnel
(8) authorize {
(8) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FA LSE
(8) [suffix] = noop
(8) update control {
(8) &Proxy-To-Realm := LOCAL
(8) } # update control = noop
(8) eap: Peer sent EAP Response (code 2) ID 122 length 71
(8) eap: No EAP Start, assuming it's an on-going EAP conversation
(8) [eap] = updated
(8) ldap: EXPAND (uid=%{%{Stripped-User-Name}:-%{User-Name}})
(8) ldap: --> (uid=mathias.maes)
(8) ldap: Performing search in "dc=maerlantatheneum,dc=be" with filter "(uid=mat hias.maes)", scope "sub"
(8) ldap: Waiting for search result...
(8) ldap: User object found at DN "uid=mathias.maes,ou=Secretariaat,ou=Atheneum, ou=Users,dc=maerlantatheneum,dc=be"
(8) ldap: Processing user attributes
(8) ldap: WARNING: No "known good" password added. Ensure the admin user has per mission to read the password attribute
(8) ldap: WARNING: PAP authentication will *NOT* work with Active Directory (if that is what you were trying to configure)
rlm_ldap (ldap): Connecting to ldaps://ldap.google.com:636
rlm_ldap (ldap): Waiting for bind result...
ber_get_next failed.
rlm_ldap (ldap): Bind successful
(8) [ldap] = ok
(8) [expiration] = noop
(8) [logintime] = noop
(8) [pap] = noop
(8) if (User-Password) {
(8) if (User-Password) -> FALSE
(8) } # authorize = updated
(8) # Executing group from file /etc/freeradius/3.0/sites-enabled/inner-tunnel
(8) authenticate {
(8) eap: Finished EAP session with state 0xd6a318ead6d902b4
(8) eap: Previous EAP request found for state 0xd6a318ead6d902b4, released from the list
(8) eap: Peer sent packet with method EAP MSCHAPv2 (26)
(8) eap: Calling submodule eap_mschapv2 to process data
(8) eap_mschapv2: # Executing group from file /etc/freeradius/3.0/sites-enabled/ inner-tunnel
(8) eap_mschapv2: authenticate {
(8) mschap: WARNING: No Cleartext-Password configured. Cannot create NT-Passwor d
(8) mschap: Creating challenge hash with username: mathias.maes
(8) mschap: Client is using MS-CHAPv2
(8) mschap: ERROR: FAILED: No NT/LM-Password. Cannot perform authentication
(8) mschap: ERROR: MS-CHAP2-Response is incorrect
(8) eap_mschapv2: [mschap] = reject
(8) eap_mschapv2: } # authenticate = reject
(8) eap: Sending EAP Failure (code 4) ID 122 length 4
(8) eap: Freeing handler
(8) [eap] = reject
(8) } # authenticate = reject
(8) Failed to authenticate the user
(8) Using Post-Auth-Type Reject
(8) Post-Auth-Type REJECT {
(8) attr_filter.access_reject: EXPAND %{User-Name}
(8) attr_filter.access_reject: --> mathias.maes
(8) attr_filter.access_reject: Matched entry DEFAULT at line 11
(8) [attr_filter.access_reject] = updated
(8) update outer.session-state {
(8) &Module-Failure-Message := &request:Module-Failure-Message -> 'mscha p: FAILED: No NT/LM-Password. Cannot perform authentication'
(8) } # update outer.session-state = noop
(8) } # Post-Auth-Type REJECT = updated
(8) } # server inner-tunnel
(8) Virtual server sending reply
(8) MS-CHAP-Error = "zE=691 R=1 C=b10924bc7abd75c0851b13250ed2f621 V=3 M=Authe ntication rejected"
(8) EAP-Message = 0x047a0004
(8) Message-Authenticator = 0x00000000000000000000000000000000
(8) eap_peap: Got tunneled reply code 3
(8) eap_peap: MS-CHAP-Error = "zE=691 R=1 C=b10924bc7abd75c0851b13250ed2f621 V =3 M=Authentication rejected"
(8) eap_peap: EAP-Message = 0x047a0004
(8) eap_peap: Message-Authenticator = 0x00000000000000000000000000000000
(8) eap_peap: Got tunneled reply RADIUS code 3
(8) eap_peap: Tunneled authentication was rejected
(8) eap_peap: FAILURE
(8) eap: Sending EAP Request (code 1) ID 123 length 46
(8) eap: EAP session adding &reply:State = 0x8992220381e93b90
(8) [eap] = handled
(8) } # authenticate = handled
(8) Using Post-Auth-Type Challenge
(8) Challenge { ... } # empty sub-section is ignored
(8) session-state: Saving cached attributes
(8) TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(8) TLS-Session-Version = "TLS 1.2"
(8) Module-Failure-Message := "mschap: FAILED: No NT/LM-Password. Cannot perf orm authentication"
(8) Sent Access-Challenge Id 195 from 172.16.88.201:1812 to 172.16.2.24:43616 le ngth 0
(8) EAP-Message = 0x017b002e190017030300235fb253d979c7409379efaaa15a1635ba03bc dbc4bbf12fde6352e9ae47dafcf94c9ee5
(8) State = 0x8992220381e93b90bf08241ae32c8474
(8) Finished request
(0) Cleaning up request packet ID 187 with timestamp +18
(9) Received Access-Request Id 196 from 172.16.2.24:43616 to 172.16.88.201:1812 length 263
(9) User-Name = "mathias.maes"
(9) NAS-Identifier = "802aa8d21ff5"
(9) Called-Station-Id = "80-2A-A8-D2-1F-F5:FreeRadius Test"
(9) NAS-Port-Type = Wireless-802.11
(9) Service-Type = Framed-User
(9) Calling-Station-Id = "E4-A7-A0-B0-AE-C8"
(9) Connect-Info = "CONNECT 0Mbps 802.11b"
(9) Acct-Session-Id = "91947FC2865BC082"
(9) WLAN-Pairwise-Cipher = 1027076
(9) WLAN-Group-Cipher = 1027076
(9) WLAN-AKM-Suite = 1027073
(9) Framed-MTU = 1400
(9) EAP-Message = 0x027b002e190017030300230000000000000003b61f8dd5fb5be5381960 387d24bd9010c892d135ab85f950759b0f
(9) State = 0x8992220381e93b90bf08241ae32c8474
(9) Message-Authenticator = 0x61b91cb7c65c108a7be276cd6e3c0e6e
(9) Restoring &session-state
(9) &session-state:TLS-Session-Cipher-Suite = "ECDHE-RSA-AES256-GCM-SHA384"
(9) &session-state:TLS-Session-Version = "TLS 1.2"
(9) &session-state:Module-Failure-Message := "mschap: FAILED: No NT/LM-Passwor d. Cannot perform authentication"
(9) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/de fault
(9) authorize {
(9) policy filter_username {
(9) if (&User-Name) {
(9) if (&User-Name) -> TRUE
(9) if (&User-Name =~ / /) {
(9) if (&User-Name =~ / /) -> FALSE
(9) if (&User-Name =~ /@[^@]*@/ ) {
(9) if (&User-Name =~ /@[^@]*@/ ) -> FALSE
(9) if (&User-Name =~ /\.\./ ) {
(9) if (&User-Name =~ /\.\./ ) -> FALSE
(9) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) {
(9) if ((&User-Name =~ /@/) && (&User-Name !~ /@(.+)\.(.+)$/)) -> FALS E
(9) if (&User-Name =~ /\.$/) {
(9) if (&User-Name =~ /\.$/) -> FALSE
(9) if (&User-Name =~ /@\./) {
(9) if (&User-Name =~ /@\./) -> FALSE
(9) } # if (&User-Name) = notfound
(9) } # policy filter_username = notfound
(9) [preprocess] = ok
(9) [chap] = noop
(9) [mschap] = noop
(9) [digest] = noop
(9) suffix: Checking for suffix after "@"
(9) suffix: No '@' in User-Name = "mathias.maes", looking up realm NULL
(9) suffix: No such realm "NULL"
(9) [suffix] = noop
(9) eap: Peer sent EAP Response (code 2) ID 123 length 46
(9) eap: Continuing tunnel setup
(9) [eap] = ok
(9) } # authorize = ok
(9) Found Auth-Type = eap
(9) # Executing group from file /etc/freeradius/3.0/sites-enabled/default
(9) authenticate {
(9) eap: Expiring EAP session with state 0x8992220381e93b90
(9) eap: Finished EAP session with state 0x8992220381e93b90
(9) eap: Previous EAP request found for state 0x8992220381e93b90, released from the list
(9) eap: Peer sent packet with method EAP PEAP (25)
(9) eap: Calling submodule eap_peap to process data
(9) eap_peap: Continuing EAP-TLS
(9) eap_peap: [eaptls verify] = ok
(9) eap_peap: Done initial handshake
(9) eap_peap: [eaptls process] = ok
(9) eap_peap: Session established. Decoding tunneled attributes
(9) eap_peap: PEAP state send tlv failure
(9) eap_peap: Received EAP-TLV response
(9) eap_peap: ERROR: The users session was previously rejected: returning reje ct (again.)
(9) eap_peap: This means you need to read the PREVIOUS messages in the debug o utput
(9) eap_peap: to find out the reason why the user was rejected
(9) eap_peap: Look for "reject" or "fail". Those earlier messages will tell y ou
(9) eap_peap: what went wrong, and how to fix the problem
(9) eap: ERROR: Failed continuing EAP PEAP (25) session. EAP sub-module failed
(9) eap: Sending EAP Failure (code 4) ID 123 length 4
(9) eap: Failed in EAP select
(9) [eap] = invalid
(9) } # authenticate = invalid
(9) Failed to authenticate the user
(9) Using Post-Auth-Type Reject
(9) Post-Auth-Type REJECT {
(9) attr_filter.access_reject: EXPAND %{User-Name}
(9) attr_filter.access_reject: --> mathias.maes
(9) attr_filter.access_reject: Matched entry DEFAULT at line 11
(9) [attr_filter.access_reject] = updated
(9) [eap] = noop
(9) policy remove_reply_message_if_eap {
(9) if (&reply:EAP-Message && &reply:Reply-Message) {
(9) if (&reply:EAP-Message && &reply:Reply-Message) -> FALSE
(9) else {
(9) [noop] = noop
(9) } # else = noop
(9) } # policy remove_reply_message_if_eap = noop
(9) } # Post-Auth-Type REJECT = updated
(9) Delaying response for 1.000000 seconds
Waking up in 0.3 seconds.
Waking up in 0.6 seconds.
(1) Cleaning up request packet ID 188 with timestamp +18
(2) Cleaning up request packet ID 189 with timestamp +19
(3) Cleaning up request packet ID 190 with timestamp +19
(4) Cleaning up request packet ID 191 with timestamp +19
(5) Cleaning up request packet ID 192 with timestamp +19
(9) Sending delayed response
(9) Sent Access-Reject Id 196 from 172.16.88.201:1812 to 172.16.2.24:43616 lengt h 44
(9) EAP-Message = 0x047b0004
(9) Message-Authenticator = 0x00000000000000000000000000000000
Waking up in 2.7 seconds.
(6) Cleaning up request packet ID 193 with timestamp +22
(7) Cleaning up request packet ID 194 with timestamp +22
Waking up in 1.2 seconds.
(8) Cleaning up request packet ID 195 with timestamp +22
(9) Cleaning up request packet ID 196 with timestamp +23
Ready to process requests
Is er iemand die hieruit kan vissen wat er juist mis gaat? Mijn ervaring met Freeradius is eerder beperkt te noemen.
De error (8) Module-Failure-Message := "mschap: FAILED: No NT/LM-Password. Cannot perf orm authentication" valt op.
Maar dit zijn mijn Netwerk instellingen op Windows: https://i.imgur.com/EFW1vja.png
Iemand kennis van zaken of ideën?
Bedankt!
Google Pixel 7 Sony WH-1000XM5 Apple iPhone 14 Samsung Galaxy Watch5, 44mm Sonic Frontiers Samsung Galaxy Z Fold4 Insta360 X3 Nintendo Switch Lite
Tweakers is samen met Hardware Info, AutoTrack, Gaspedaal.nl, Nationale Vacaturebank, Intermediair en Independer onderdeel van DPG Media B.V.
Alle rechten voorbehouden © 1998 - 2022 Hosting door True
Tweakers maakt gebruik van cookies
Tweakers plaatst functionele en analytische cookies voor het functioneren van de website en het verbeteren van de website-ervaring. Deze cookies zijn noodzakelijk. Om op Tweakers relevantere advertenties te tonen en om ingesloten content van derden te tonen (bijvoorbeeld video's), vragen we je toestemming. Via ingesloten content kunnen derde partijen diensten leveren en verbeteren, bezoekersstatistieken bijhouden, gepersonaliseerde content tonen, gerichte advertenties tonen en gebruikersprofielen opbouwen. Hiervoor worden apparaatgegevens, IP-adres, geolocatie en surfgedrag vastgelegd.
Meer informatie vind je in ons cookiebeleid.
Sluiten
Toestemming beheren
Hieronder kun je per doeleinde of partij toestemming geven of intrekken. Meer informatie vind je in ons cookiebeleid.
Functioneel en analytisch
Deze cookies zijn noodzakelijk voor het functioneren van de website en het verbeteren van de website-ervaring. Klik op het informatie-icoon voor meer informatie. Meer details
janee
    Relevantere advertenties
    Dit beperkt het aantal keer dat dezelfde advertentie getoond wordt (frequency capping) en maakt het mogelijk om binnen Tweakers contextuele advertenties te tonen op basis van pagina's die je hebt bezocht. Meer details
    Tweakers genereert een willekeurige unieke code als identifier. Deze data wordt niet gedeeld met adverteerders of andere derde partijen en je kunt niet buiten Tweakers gevolgd worden. Indien je bent ingelogd, wordt deze identifier gekoppeld aan je account. Indien je niet bent ingelogd, wordt deze identifier gekoppeld aan je sessie die maximaal 4 maanden actief blijft. Je kunt deze toestemming te allen tijde intrekken.
    Ingesloten content van derden
    Deze cookies kunnen door derde partijen geplaatst worden via ingesloten content. Klik op het informatie-icoon voor meer informatie over de verwerkingsdoeleinden. Meer details
    janee
