Asus ROG GL702VM ervaringen
  • dtrrr
  • Laatst online: 05-08-2024
Ik heb een Asus ROG GL702VM (GL702VM-GC026T-BE) gekocht. Niks over te vinden hier op Tweakers dus start deze thread om m'n wedervaarten te delen. Anderen zijn natuurlijk welkom om dat ook te doen.
Ik heb eerder een heel verhaal in het Engels op Notebookcheck geplaatst. Ik hoop dat men mij toestaat dit hier (ietwat geëdit) te posten:
Based on the review here (http://www.notebookcheck....book-Review.186918.0.html) I was hoping for good thermal and fan noise performance, compared to other GTX1060 laptops. I'm not seeing it though.
Running Prime95 (blend, 8 processes) and Furmark in parallel will push the CPU temps to 92°C and GPU to 85°C in 10 minutes or so. At that point the CPU will throttle down. Ambient temp +/-18°C.
Running a more conservative test closer to what my use will be (live audiovisual media performance, not gaming) the CPU will also push up to the 90's. Test is Prime 95 blend with 2 processes and Unigine Valley.
Undervolting the CPU by -0.125V will keep it at 90°C, just under throttling. This is with a room temp around 18°C so a hotter environment will push it to throttle. And this machine will see hotter environments...
Strangely, Furmark will make the GPU throttle down to +/-1260MHz instantly whereas Unigine Valley will run it at the expected boost of +/-1660MHz. I guess this is due to the synthetic test nature of Furmark. I wasn't able to push the GPU into throttling with Unigine. At 100% load without P95 running alongside it doesn't overheat. With P95 alongside the CPU overheats first, not the GPU. Maxes at 85°C.
All this said, when you look for it, all laptops with GTX1060 and up have cooling issues. I'm personally trying to find the most optimal one that's relatively silent, has Thunderbolt3 and doesn't break my back.
I'm disappointed that the Notebookcheck review led me to believe this one could be it but now I'm not so sure.
Other notes:
- screen shows noticeable edge bleed, haven't decided yet if it bothers me enough to return it, this being a workstation for me and not a movie/game/entertainment machine.
- apart from that I like the screen, not super bright as noted elsewhere but I mostly work in dark environments anyway
- touch pad feels great (coming from an ultra cheap crappy laptop though)
- don't like the gamer styling and keyboard layout, replacing numlock and end keys for it is dumb. i can live with it but i wish non-gamer styled laptops with GTX1060 and up would come out.
- numpad is present but it's slimmed down, and the arrow keys as well. even my super cheap 15" HP has a full sized numpad. add the gamer styled nonsense and typography on the keyboard keys and you have a useability-crippled keyboard on a relatively high-end 17" whereas a budget 15" got it perfectly right. ridiculous.
- plastic case is not very stiff. i didn't expect the toughest build quality as it is relatively cheap.
- speakers are relatively good. for laptop speakers.
  • dtrrr
Ik heb nu acceptabele resultaten met de laptop op een stand zodat de airflow beter is en met CPU op -0,150V.
P95 blend + Furmark geeft CPU cores rond 85° met pieken op 89° en de GPU op 83°. Kamertemp is rond 18°.
Heb deze laptop nodig voor een project binnenkort en dat gaat wel werken denk ik. Wanneer een nieuwe generatie GTX10xx laptops uitkomt is de kans wel groot dat ik deze weer inruil. Voor dagelijks gebruik is 14/15" sowieso beter voor me. Liefst zonder de gamer styling b*llsh*t.
  • dtrrr
Ik zou 't ook interessant vinden om deze naast andere GTX10xx laptops te zetten in een testing shoot out. Benchmarken, noise levels vergelijken, etc. Vrijwilligers mogen zich melden.
  • dtrrr
Hier is nuttige info om de CPU en GPU te under-volten: http://rog.asus.com/forum...es-Overheating-Throttling
CPU tweaken had bij mij al aardig verschil gemaakt. Met de voorgestelde GPU tweak zie ik maar een beetje verschil, nog vreemder gedrag met Furmark even terzijde: core frequency die bij 1000MHz blijft steken hoewel de GPU echt nog niet heet is. Met Unigine Valley kan ik wel zien dat de GPU volgens de getweakte curve werkt en de frequentie nu hoger gaat dan eerder. Ik scoor nu ongeveer 2 fps en 100 punten meer dan eerder (62.6fps/2620 vs 60.5fps/2531) met vergelijkbare temperatuur, 82° max bij ca. 18° kamertemperatuur.
[ Voor 60% gewijzigd door dtrrr op 31-12-2016 00:23 ]
  • dtrrr
Ik was niet erg tevreden over deze laptop en ben verder gaan kijken naar de MSI GS63VR. Ervaringen en vergelijkingen met de GL702VM hier: [Ervaringen] MSI GS63VR Stealth Pro
