• JBS
JBS
TwistLock schreef op zaterdag 26 november 2022 @ 10:54:
Heb dit ook nog wel eens. Zelfde toestel ander type samsung soundbar. Maar dit helpt wel (van Samsung community forum) :
FOR ANYONE WHO IS STILL STRUGGLING WITH THIS ISSUE (No TV/ARC, D.IN flashing, No sound from soundbar):
NOTE: @userSMcoldMP1L had the correct answer, which interestingly is not provided by Samsung support (nor does it appear in the manual as pointed out by @userigHescbxF2).
1) Unplug the HDMI cable from the soundbar and TV and power off both devices.
2) Go to your Samsung SmartThings app and DELETE the Samsung Sound+ soundbar.
3) Power ON the TV and Samsung soundbar and connect the HDMI cable to the HDMI-ARC ports on both devices.
4) Press and hold the VOLUME "---" button for SEVERAL seconds (it may take longer than you think), until you see the soundbar reset (LCD will flash CONNECT or something like that).
5) In SmartThings, Click the "+" button and "Add Device", then (make sure soundbar is on), click "Scan Nearby".
** It should quickly locate the Samsung Soundbar. If you did not do Step 4, it will detect the soundbar but won't let you add it because it is "owned by another account" (technically still "owned" by YOUR Samsung account, even though you deleted it). It will then prompt you to reset the soundbar, which is basically Step 4 (press/hold VOLUME DOWN). **
6) Once the soundbar has been successfully added, connected to your Wi-Fi (and after any necessary firmware updates), you can now do the following on the soundbar REMOTE CONTROL:
-- PRESS & HOLD LEFT "(" button on remote for 5(ish) seconds ------>
Trigger AUTO POWER ON/OFF
-- PRESS & HOLD RIGHT ")" button on remote for 5(ish) seconds ------>
Trigger ANYNET+ ON/OFF
7) [**CRITICAL STEP!**] Ensure that at least ANYNET+ is ON, and..... that's it. Your soundbar should flash "TV/ARC" again.
Heeft dit voor jou geholpen op het moment dat geluid niet via je soundbar wilde verlopen (waarbij ik in dat geval de TV opnieuw opstart door de stekker even uit stopcontact te trekken) of juist om te voorkomen dat dit zo af en toe gebeurt?
  • TwistLock
  • Laatst online: 19-10 15:22
Hoi,
Na een korte stroompanne oid gebeurt het weleens dat het niet meer werkt, en dan overloop ik die stappen en blijft deze werken. Als enkel de wifi eruit gaat, dan helpt het idd om even de tv en soundbar zonder stromm te zetten.
  • JBS
JBS
TwistLock schreef op maandag 28 november 2022 @ 17:18:
Hoi,
Interessant. Wat zou (de) WiFi (verbinding) te maken kunnen/moeten hebben met het correct functioneren van ARC?
  • Dijkertje
  • Laatst online: 12-11 21:52
Heb de UE49KS8000 sinds augustus 2016 en tv draait op 1260.
Sinds vorige week (of week daarvoor zou ook al kunnen) is de tv echt enorm traag met reageren op afstandsbediening input. Zowel de smart remote als de "dumb" remote laten de tv enorm traag reageren.
Uiteraard van beiden afstandsbedieningen de batterijen vervangen, maar dit heeft niet geholpen.
Ook 4 seconden ofzoiets op de aan/uit knop drukken reset de tv als een soort hard-reboot, maar werkt ook niet.
Stekker 30 sec eruit gehad: werkt ook niet. Wellicht was dat tekort en had afgelopen avond de hele nacht de stroom eraf gelaten: wederom helpt dit niet.
Ook een factory reset gedaan, en je raadt het al: werkt ook niet.
Is Samsung moedwillig oude tv's bewust trager aan het maken?? Want daar lijkt het op.
De tv zelf is verder prima, maar erger mij kapot aan de traagheid. Iemand enig idee?
[ Voor 4% gewijzigd door Dijkertje op 06-03-2023 21:54 ]
Pagina: 1 ... 59 60 Laatste
