Blogger header code?!??!
  • 265 views
Ik heb een probleem met mijn header. ik begrijp er de ballen van...
Ik wil graag het hele bovenvak gebruiken maar op 1 of andere manier mag dat niet in mijn html code.
Kan iemand helpen?
Afbeeldingslocatie: http://pokit.org/get/img/cefbebfaa8f8dfaaead9706836c1effc.jpg
de code in mijn header is ..
</div>
<center>
<div style='clear:both;'/>
<div id='header-wrapper "background: url( );"'>
<b:section class='header' id='header' maxwidgets='2' showaddelement='yes'>
<b:widget id='Header1' locked='false' title='PAUL DE LEEUW, de website voor paul de leeuw fans! met de leeuw zingt long en Pauls puber kookshow (Kop)' type='Header'>
<b:includable id='main'>
<b:if cond='data:useImage'>
<b:if cond='data:imagePlacement == "REPLACE"'>
<!--Show just the image, no text-->
<div id='header-inner'>
<a expr:href='data:blog.homepageUrl' style='display: block'>
<img expr:alt='data:title' expr:height='data:height' expr:id='data:widget.instanceId + "_headerimg"' expr:src='data:sourceUrl' expr:width='data:width' style='display: block;padding-left:0px;padding-top:-20px;'/>
</a>
</div>
<b:else/>
Show image as background to text. You can't really calculate the width
reliably in JS because margins are not taken into account by any of
clientWidth, offsetWidth or scrollWidth, so we don't force a minimum
width if the user is using shrink to fit.
This results in a margin-width's worth of pixels being cropped. If the
user is not using shrink to fit then we expand the header.
<div expr:style='"background-image: url(\"" + data:sourceUrl + "\"); " + "background-position: " + data:backgroundPositionStyleStr + "; " + data:widthStyleStr + "min-height: " + data:height + "px;" + "_height: " + data:height + "px;" + "background-repeat: no-repeat; "' id='header-inner'>
<div class='titlewrapper' style='background: transparent'>
<h1 class='title' style='background: transparent; border-width: 0px'>
<b:include name='title'/>
</h1>
</div>
<b:include name='description'/>
</div>
</b:if>
<b:else/>
<!--No header image -->
<div class='titlewrapper'>
<h1 class='title'>
</h1>
</div>
</div>
</b:if>
</b:includable>
<b:includable id='description'>
<div class='descriptionwrapper'>
<p class='description'><span><data:description/></span></p>
</div>
</b:includable>
<b:includable id='title'>
<a expr:href='data:blog.homepageUrl'><data:title/></a>
</b:includable>
</b:widget>
</b:section>
<div id='header2'>
<div id='topsearch'>
<div id='search' title='Type and hit enter'>
</div>
</div>
</div>
</div> </center>
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Vast, maar niet op deze manier ;)
Kan iemand even...?
Help, mijn script werkt niet (goed)
We verwachten hier een beetje eigen inzet en nog wel wat andere zaken die ik nu in je topic niet terug zie. Open dus even een nieuw topic, maar hanteer dan onze Quickstart even; dan gaat het vanzelf goed. Also: als je code post, gebruik dan a.u.b. code tags en post een testcase met daarin enkel relevante(!) code om je probleem te reproduceren; laat overbodige fluff dus achterwege. Wanneer je zo'n testcase maakt heb je in 9 v.d. 10 gevallen, trust me, zélf al vaak opeens een aha-erlebnis waarbij je je eigen probleem oplost. En heb je die niet dan heb je volautomatisch voor ons overzichtelijke code in hapklare brokken (de testcase) zonder dat wij door de bomen 't bos moeten gaan zoeken ;) En liefst hebben we dan ook "foo company" i.p.v. daadwerkelijke (merk)namen etc. i.v.m. spam.
[ Voor 6% gewijzigd door RobIII op 24-03-2015 16:38 ]
Je eigen tweaker.me redirect
Over mij
