wachtwoord verloopt script fout
  • monta
  • Laatst online: 02-02-2025
Het volgende script start als inlog script indien de gebruiker inlogt op de Windows 7 laptop:
Indien de gebruiker niet op het domein inlogt maar de laptop buiten de deur heeft verschijnt er een script error.
VBScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
'A VBS script that goes in to your GPO that displays a popup window telling the user their password expires in # days and that
'the user MUST click OK to dismiss. It goes in the GPO - User Config - Policies - Admin Templates - System - Logon - Run these
'programs at user logon.  You will also need to add the folder location to IE Trusted Sites to avoid having a popup asking if
'it should run the script.
'PwExpChk.vbs
    ' First, get the domain policy.
    Dim oDomain
    Dim oUser
    Dim maxPwdAge
    Dim numDays
    Dim warningDays
    warningDays = 15
    Set LoginInfo = CreateObject("ADSystemInfo")
    Set objUser = GetObject("LDAP://" & LoginInfo.UserName & "")
    strDomainDN = UCase(LoginInfo.DomainDNSName)
    strUserDN = LoginInfo.UserName
    Set oDomain = GetObject("LDAP://" & strDomainDN)
    Set maxPwdAge = oDomain.Get("maxPwdAge")
    ' Calculate the number of days that are
    ' held in this value.
    numDays = CCur((maxPwdAge.HighPart * 2 ^ 32) + _
                    maxPwdAge.LowPart) / CCur(-864000000000)
    'WScript.Echo "Maximum Password Age: " & numDays
    ' Determine the last time that the user
    ' changed his or her password.
    Set oUser = GetObject("LDAP://" & strUserDN)
    ' Add the number of days to the last time
    ' the password was set.
    whenPasswordExpires = DateAdd("d", numDays, oUser.PasswordLastChanged)
    fromDate = Date
    daysLeft = DateDiff("d",fromDate,whenPasswordExpires)
    'WScript.Echo "Password Last Changed: " & oUser.PasswordLastChanged
    if (daysLeft < warningDays) and (daysLeft > -1) then
        Msgbox "password expires " & daysLeft & " dagen" & " op " & whenPasswordExpires & chr(13) & chr(13) & "LET OP!" & chr(13) &
   End if
De melding gaat over de regel: Set objUser = GetObject("LDAP://" & LoginInfo.UserName & "")
Hoe kan ik dit oplossen als de gebruiker niet inlogt op de laptop met netwerkkabel maar buiten de deur? Hij kan wellicht het domein niet vinden omdat men offline werkt..
De melding zegt: kan het opgegeven domein niet vinden...
Moet ik het domein ergens invullen?
[ Voor 0% gewijzigd door RobIII op 05-07-2012 10:17 . Reden: code tags toegevoegd ]
monta
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Waar hoort mijn topic?
WEB >> PRG
Verder: Als je code post, gebruik dan code tags a.u.b. Wat heb je zelf al geprobeerd, gezocht, gevonden? En tot slot: is dit script überhaupt van je eigen hand of mogen we support gaan leveren op 3rd party code? (Ik denk dat ik 't antwoord daar al wel op weet though ;) )
[ Voor 25% gewijzigd door RobIII op 05-07-2012 10:21 ]
Je eigen tweaker.me redirect
Over mij
  • monta
Ok ik zal er opletten. Heb reeds gegoogled maar heb geen script kennis en wellicht als iemand script kennis heeft dat hij/zij meteen ziet dat er een domein opgegeven moet worden of andere fout in het domein script zit. Het script staat in c:\windows\system32 dus het kan niet zijn dat het script niet gevonden kan worden omdat hij lokaal staat.
monta
  • muppet99
  • Laatst online: 16-11 13:39
Je script gaat op zoek naar het domein. Dus ja het kan wel kloppen dat hij die niet kan vinden als je er niet in hangt. Echter..... je zou deze ook uit je log in kunnen halen en hem als taak inschieten die dagelijks loopt. Daar kun je dan ook instellen dat hij niet loopt op het moment dat de gebruiker niet aan het domein hangt. Dan hoef je dus geen scriptkennis te hebben :)
Carpe Diem
  • monta
Maar het moet toch ook via dit script kunnen, als hij niet aan het domein hangt dan negeert hij het script verder..
monta
  • col-dejong
  • Laatst online: 15-11 23:03
Om het heel simpel op te lossen .. bovenin het script zet je het volgende neer:
On Error Resume Next
  • mhoogendam
  • Laatst online: 13:46
Je zal ook nog een syntax error krijgen door regel 53, je eindigt met een & teken. Hier moet nog iets achteraankomen.
  • NMe
  • Laatst online: 09:50
NMe
Quia Ego Sic Dico.
col-dejong schreef op vrijdag 06 juli 2012 @ 11:09:
Wat een heerlijk slecht advies. Dan verandert ergens in de toekomst de situatie waardoor het script op een andere plek eruit klapt, kun je niet vinden waar het hem in zit. 8)7
Als je al in de "On Error"-hoek wil kijken (liever niet), zet dan On Error Resume Next boven de regel(s) die hier fout gaat en dan On Error Goto 0 op de regel eronder, zodat andere foutmeldingen wel gewoon opgeworpen worden.
  • @r!k
  • Laatst online: 21-11 19:04
@r!k
It is I, Leclerq
Als ik het script goed begrijp kun je beter een functie inbouwen waarbij hij controleert of je verbinding hebt met het domein en als dit niet het geval is dat hij het script dan stopt. Hij leest uit hoe oud je wachtwoord is en geeft dan een waarschuwing, alleen je kunt die toch niet wijzigen als je niet op het domein aangemeld bent dus waarom zou je deze verder nog laten draaien?
Een hele rij microsoft certificeringen.
  • lordgandalf
  • Laatst online: 15:53
met ^
Steam: Profile / Socialclub: Profile / Uplay: minedwarf / Origin: lordgandalf3
  • col-dejong
NMe schreef op vrijdag 06 juli 2012 @ 13:35:
Normaal gesproken gebruik ik ook niet On Error Resume Next maar in deze situatie, omdat het aannemelijk is dat er niet meer verandert in het script is het hierbij een goede oplossing.
Om het anders op te vangen, hier de aangepaste code:
VBScript:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
'PwExpChk.vbs
    Dim oDomain
    Dim oUser
    Dim maxPwdAge
    Dim numDays
    Dim warningDays
    warningDays = 15
    If Err <> 0 Then
    'Wscript.Echo "Hier een foutmelding?"
    else
    fromDate = Date
   End if
   End If
Dit bijgevoegd na regel 20:
If Err <> 0 Then
else
En de laatste regeld End If
  • NMe
NMe
Quia Ego Sic Dico.
col-dejong schreef op vrijdag 06 juli 2012 @ 16:16:
Dat is het dus niet. ;) De code hoeft niet te veranderen om nieuwe fouten te introduceren. Wat als een software-upgrade op het systeem waar dit script draait een probleem oplevert? Dan stopt dit script ineens met werken zonder foutmelding. Dat debugt makkelijk. ;)
