• Meijuh
  • Laatst online: 16-02 16:52
Het paneel van mijn hp compaq 8510w is stuk. Er zit een blauwe streep in het midden.
Is dit door mij zelf te repareren? Of kan ik het beste het paneel vervangen?
Hier: http://www.laptopscreen.c...P-Compaq/HP~COMPAQ~8510W/ zijn goedkoop nieuwe panelen te bestellen. Er staat duidelijk bij "Note: Make sure new screen has same size,
resolution, backlight as your old one!" De resolutie die mijn originiele scherm heeft is 1680 * 1050. Maar eigenwijs als ik ben; een 1920 * 1200 scherm moet er toch ook inpassen? Het heeft immers dezelfde grootte en achtergrondverlichting. Zou ik inderdaad een scherm kunnen nemen met een hogere resolutie? Iemand hier ervaring mee?
Asus EN8800GTS, Asus P5E, Intel E8400, 2x500gb Spinpoint (raid0), Zalman HP 600 watt, cnps 9500 led, creative xfi music, 4x1gb hyperX PC2 8500
  • ShittyOldMan
  • Laatst online: 29-10 00:17
Van dezelfde site:
Upgrade or downgrade of the LCD screen resolution:
In a nutshell - resolution of the replacement screen must be the same as resolution of the screen which is being replaced.
We advise our customers against upgrading or downgrading of the screen resolution. Our company witnessed several cases where as a result of a resolution upgrade customer's video card had ceased to work properly or became completely unresponsive. A video card operates in a similar way to the CPU, the only difference lies in its purpose. Video card is used solely for image processing. Just like CPU, it can be overloaded when connecting to a screen that has a significantly higher capacity, as it will require more processing power. There are exceptions to this rule. There are some customers who have successfully changed their laptop screen resolution while upgrading their screens. It all depends on the brand and capacity of particular video card. Screen manufacturers will sometimes install different resolution screens with the same video card, although, we would strongly recommend against trying this type of an upgrade as there is a chance of damaging video card and the cost of repairs can be as high as replacing an entire motherboard, if the video card is integrated.
Op eigen risico dus.
Mijn Home Cinema in aanbouw
  • Meijuh
Oh thx, iets te snel geconcludeerd dat ik er niets over kon vinden op hun site. Ik neem dit risico denk ik wel. Ik werk altijd met een extern beeldscherm en er zit een degelijke videokaart in.
  • Michael Knight
Michael Knight
Moderator Consumentenelektronica
KITT, I need you buddy!
Het is de vraag of de interne videokabel ook de hogere resoulties ondersteunt. Ik zou bijna zeggen van wel, aangezien er tegenwoordig vaak gewoon een dvi-signaal overeen gaat. Tevens zijn er modellen met hogere resolutie geleverd bij jouw laptop.
Als je op een externe monitor een hogere resolutie krijgt, acht ik de kans vrij groot dat je dat op een nieuw intern paneel ook moet kunnen halen.
(Zeldzame) retrogames en meer --> Aangeboden op V&A
