• Ryan1981
  • Laatst online: 18-11 07:51
Ryan1981
Je ne sais pas
Acer K330 Led Projector
Afbeeldingslocatie: http://www.imagedump.nl/img190/6140/88acer1.jpg
Afbeeldingslocatie: http://www.imagedump.nl/img560/9656/49acer2.jpg
Intro
Dit topic is bedoeld om over de Acer K330 Led Projector te praten. Als iemand zich geroepen voelt mede eigenaar te worden van dit topic en weet hoe dit moet dan hoor ik het wel.
Inhoudsopgave
Specificaties
FeatureSpecification
Projection SystemDLP®
Display Panel0.45" DMD
ResolutionNative:
  • 1,280 x 800 (WXGA)
Maximum:
  • 1,600 x 1,200 (UXGA)
  • 1,920 x 1,080 (1080p)
Video CompatibilityNTSC (3.58/4.43)
PAL (B/D/G/H/I/M/N)
SECAM (B/D/G/K/K1/L)
HDTV (720p, 1080i, 1080p)
EDTV (480p, 576p)
SDTV (480i, 576i)
Aspect RatioNative:
  • 16:10
Supported:
  • 4:3
  • 16:9
Contrast Ratio4,000:1
Brightness500 ANSI Lumens (Standard)
350 ANSI Lumens (ECO)
Projection LensF = 1.5, f = 13.92mm
Manual Focus
Projection Screen Size (Diagonal)30" ~ 100" (76cm ~ 254cm)
Projection Distance3.0' (0.9m) ~ 9.9' (3.0m)
Throw Ratio66"@2m (1.40:1)
Horizontal Refresh Scan Rate30k ~ 100k Hz
Vertical Refresh Scan Rate50 ~ 120 Hz
Lamp TypePhlatLight® LEDs
Lamp LifeLED life 20,000 Hours
Keystone Correction+/-40 Degrees (Vertical ), Manual & Auto
Projection ModeFront, Rear, Front-Ceiling, Rear-Ceiling
Ceiling Mounting CapabilityYes
AudioOne Internal Speaker with 2 watts Output
Weight2.73 lbs (1.24 Kg)
Dimensions (W x D x H)218 x 168 x 46.5 mm (8.6" x 6.6" x 1.8")
Remote ControlIR remote control
ZoomDigital: 1.7X
PIPN/A
Lens ShiftN/A
Power SupplyAC input 100~240V auto-switching power supply
Power Consumption120 Watts (Operation), < 1 Watts (Standby)
Operating Temperature5°C ~ 35°C / 41°F ~ 95°F
Operating Humidity80% RH (Max.)
Noise Level35 dBA (Bright mode)
33 dBA (Standard mode)
29 dBA (ECO mode)
I/O ConnectorsInput:
  • Analog RGB/Component Video (D-sub) x 1
  • Composite Video (RCA) x 1
  • Composite Video/Audio (3.5mm 4-pin mini jack) x 1
  • HDMI (Video, Audio, HDCP) x 1
  • USB (Type A) x 1
  • USB (Mini-B) x 1
  • SD (SDHC) x 1
Output:
  • PC Audio (Stereo mini jack) x 1
Control InterfaceUSB (Mini-B) x 1, shared with the one of Input Interface
Network InterfaceNone
WebsiteAcer K Series
SupportLink
Software
Handleiding
Bios (Firmware)
Drivers
Navigeer als volgt: Projector>K Series>K330
Terug naar de inhoudsopgave
Features
Low Noise Level
Acer SmartFormat Technology
Acer EcoProjection Technology
ColorSafe II
Empowering Key
Acer eTimer Management
Acer eView Management
Wall-Color Compensation
Acer ePower Management
High Altitude Mode
Installation Menu
Digital Connectivity-HDMI
Multi-PC Connectivity
Instant Pack
Auto Shutdown
Quick Start
Quick Detection
SmartDetection
Digital Zoom and Pan
ECO Mode
ExtremeECO
Alarm
Built-in Speaker
40° Vertical Keystone Correction
Auto Keystone Correction
Closed Captioning
Instant Resume
Instant On/Off
DLP 3D ready (PC only)
True 24p
iPhone/iPod Compatible
SD Card Reader (Audio&Videos, Photos, Office, PDF)
USB Multimedia (Audio&Videos, Photos, Office, PDF)
Display over USB (DoUSB)
Sealed Optical Engine
In de doos
AC power cord
VGA cable
Composite video cable
3.5mm mini jack A/V cable
Remote control
Battery for remote control
Lens cap
Carrying case
User's guide (CD-ROM)
Network/Multimedia guide (CD-ROM)
Quick start guide
Reviews
Projector Central
Picopros
PC Mag
slashgear
projectorreviews
Audiovideoclan
FAQ
Hoe kom ik in het service menu:
WAARSCHUWING. VOORDAT JE VERDER GAAT, MAAK EEN FOTO VAN ALLE MOGELIJKE INSTELLINGEN ZODAT JE ALTIJD WEER TERUG KAN.
Press the {POWER}, {LEFT}, {LEFT} & {MENU} buttons.
The Service Menu will be displayed.
To exit, turn the power off.
Welke chip zit er in de projector
Zijn er custom firmwares beschikbaar
Op het moment van schrijven niet maar het volgende heb ik gevonden in het AVS forum:
TCoretronic M/B Rev. A. 2011/06/17,
- firmware was created by Speakercrafts' EZ-Tools,
- the core system is Linux based,
- and compiled by GCC 4.3.3 for Actions MicroEltronics AM7x CPU,
- the wireless driver is for Ralink RT2870/RT3070, Alleen RT3070 is geverifieerd
- user interface is customizable (Acer,Optoma,Nec,Viewsonic)
- it is not encrypted.
Chips DLP: DPP6401/AFE1000
SOC: AM8201
Nand 16GB: Samsung 116 K9GAG08U0E
DDR Ram 512mb: HYNIX h5du5162etr-e3c
Video: ADV7612
Audio: PT2334
LED: LT10
Lamp: Blue: 53501 Red: 93969 Green: 65521
Etc.: NUVOTON N79A901/DRV602/LW052A/TPS65145/K330 M/B B09 7C44
Shortly: Developer can customize remote layout, user menu, special remote keys (Acer empowering), boot logo, etc in Ez-tools with Actions Media SDK for AM7x CPU, and create a bin file for flash.
That's all.
The problem is, how can we extract and edit the firmware.
Foto's
De kleinere thumbnails kan op geklikt worden voor een grotere versie.
Afbeeldingslocatie: http://www.plaatjesdump.nl/upload/e2d73c80852d52ca7a97e8993182a5cd.jpg
Afbeeldingslocatie: http://www.plaatjesdump.nl/upload/dc7081ce7f18d8bfcbc94f7dddb8c5d0.jpg
Afbeeldingslocatie: http://www.plaatjesdump.nl/upload/3d44016d293b693c69327bd39bb0d770.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/25abad404b930722070c414226381e31.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/52230bfe249dbc9820fd2090c23f3377.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/26c22275c78a68b254b39d6d4b88b87b.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/cf2279c2cae91ed17458a5d14bf6b91d.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/fd0d6fce0f5d7c44be51bae4c0bfcdd6.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/5fb5061f2249efe040f7731f68aed767.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/e9923b48d9da4189ca7e4dd8e1386e68.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/de998c9af3a3faaaa66758c9025d4692.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/87e629ed3832884e2f7d39921b887c09.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/cf29ba5b167c18aff7e673f1d065320f.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/e162b9f0427e47b8789a281f0c6dfb56.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/cad7f17a6c2830912d67b9c7b075741b.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/861c3a47ea1a4021b08b0aaa7d3a17eb.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/77152811f41fe8eab812b33b39795134.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/f8da12102ceead19a60312420a1097e1.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/04ceee8afeeabaf1b84c89e194c8de08.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/135bbaf2cec757d4026b1538da9753bb.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/76cd398571a532a9446e5c9c36bd411b.jpgAfbeeldingslocatie: http://www.plaatjesdump.nl/upload/2acb7fe6c76925def141f124a17defbe.jpg
Youtube
Handige Links
AVS Forum Thread Bevat heel veel informatie.
Changelog
[ Voor 49% gewijzigd door Ryan1981 op 19-03-2012 20:47 ]
  • Furinax
  • Laatst online: 07-09 10:40
Furinax
It'll only hurt until you die
Wat me opvalt bij de LED beamers is dat het aantal lumen een stuk lager ligt als bij beamers met een normale lamp.
Deze Acer beamer heeft volgende de specs
Brightness 500 ANSI Lumens (Standard)
Ben zelf aan het kijken voor een beamer en op mijn zoektocht naar info kwam ik deze site tegen
http://www.besteproduct.n...oeveel_heb_je_nodig_.html
Het minimaal aantal lumen wat op deze site wordt aangegeven is 900.
Houdt het in dat deze beamer alleen te gebruiken is in een kamer die volledig verduisterd is?
  • Ryan1981
Ryan1981
Je ne sais pas
Hoi Furinax,
Ik vind het ook lastig te beoordelen hoe veel licht nog acceptabel is, en dit zal ook per persoon verschillen. Ik denk dat de review van projector central een redelijk eerlijk beeld geeft:
Brightness. I measured the K330's brightness at 440 lumens in its Bright mode, or 88% of its rating. Other presets ranged from 287 to 334 lumens, with Eco mode dropping brightness by about 11%, to 393 lumens for the Bright mode. For our tests, I found the K330's image bright enough for comfortable viewing in theater dark lighting for a 92" diagonal image at the 16:10 native aspect ratio. Even with moderate light, the image is usable at that size, although it's a little washed out.
Hou er ook rekening mee dat volgens verschillende bronnen het aantal lumen van een LED of van een typische lamp projector niet altijd hetzelfde resultaat opleveren.
Verder is het ook nog afhankelijk van de grootte van het scherm. In mijn slaapkamer heb ik een 80" scherm. Met de gordijnen dicht (die overigens licht beige zijn en redelijk wat licht doorlaten) wordt het tegen schemer pas acceptabel om te kijken. Daarbij wel even melden dat de zon direct op het raam staat.
Het lastige is ook om de echte beeldkwaliteit weer te geven in een video, zodra je op het scherm richt stelt de camera zich gelijk opnieuw in zoals je in het filmpje van picopros ziet. Hij verteld nog wel er bij welke verlichting hij aan heeft maar de camera geeft een vertekend beeld.
Als je de mogelijkheid hebt, kijk of je ergens een demo kunt krijgen van de beamer, dat lijkt mij echt de beste manier om te kijken of je tevreden ben. Ik heb met mijn beamer de gok genomen en in mijn geval voldoet hij waar ik hem voor gebruik.
  • tjibbe
  • Laatst online: 24-05-2019
Hoi,
Ik las ergens dat deze beamers een diamand grid hadden met een omgerekende resolutie van 1140 x 912.
Heb je hier ooit wel eens wat van gemerkt dat het beeld in zijn native resolutie geschaald werd? En zo ja is het hinderlijk?
Of kan je dit ook zien van dichtbij dat het pixel raster onder een hoek van 45 graden ligt?
  • Ryan1981
Ryan1981
Je ne sais pas
Zodan, zie je reactie nu pas, sorry voor de late reactie, in het vervolg raad ik iedereen aan mij een DM te sturen want ik ben wel degelijk regelmatig actief op tweakers.
Het is inderdaad correct dat de pixels ruitvormig zijn, en ook dat de native resolutie niet 1280x720 is.
De ruitvormige pixels komen met name tot uiting bij fijne details. Persoonlijk zit ik standaard te ver af van het scherm om er iets van te merken maar bij b.v. computer applicaties kun je het wel zien. Als voorbeeld een windows waarschuwings berichtje met een OK knop daar zie je als je dicht bij staat dat de randjes op de knop en van het dialoog venster ruitvormig gekartelt is. Dit neemt niet weg dat het nog steeds scherp is en goed leesbaar.
De native resolutie en de schaling heb ik totaal niets van gemerkt tot nog toe. Het enige wat misschien zou kunnen is dat de interne video speler van de projector met hoge bitrate files wellicht problemen heeft om deze reden maar persoonlijk denk ik dat de interne speler gewoon niet krachtig genoeg is om dit type files af te spelen zonder schaling. Ik heb in ieder geval geen vervormingen gezien.
Wat mij opvalt is dat dit type projectors nog niet zo bekend is. Ik heb hem nu meerdere maanden in gebruik en ik ben nog steeds sterk onder de indruk. Het is mijn eerste projector, maar voor het geld krijg je naar mijn mening niets beters. Mijn ervaring is dat de enorme grootte van het scherm veel zwaarder weegt dan de eventuele betere beeldkwaliteit van een normale tv. Ik kijk gewoon nooit meer films op de 32" LCD. Ik heb zelfs met digitenne TV op de projector (USB TV kaart met CI adapter van hauppauge op mijn netbook) en ondanks dat je met deze schermgrootte van dichtbij toch wel kan zien dat SD DVB-T niet echt super is voor dit formaat scherm is het nog steeds een hele belevenis om alles zo groot te bekijken.
De mobiliteit van dit type projectoren is ook enorm. Ik had hem samen met mijn stand alone media speler (soort van WD Live TV) even mee naar mijn ouders genomen. Projector aansluiten, speler aansluiten aan projector en versterker en voila, 100" scherm op de witte muur en gaan met die banaan. Mijn ouders zeiden gelijk, waar kunnen we zo'n ding halen.
Het enige echte nadeel is dat je een verduisterde ruimte nodig hebt (maar hoeft niet compleet donker te zijn), of in ieder geval geen direct zonlicht op het projectievlak.
Misschien kan Tweakers dit type projectoren eens belichten met een review. Ik zag dat LG onlangs weer een nieuwere versie in dit segment uitgebracht had en dat verdiend volgens mij toch meer aandacht dan het nu krijgt.
[ Voor 3% gewijzigd door Ryan1981 op 10-08-2012 15:33 ]
  • Canon23
  • Laatst online: 23-11 21:25
Canon23
>>MY<< world
Ik zit in het proces van een huis kopen en er moet van mij ook een beamer komen voor het kijken van films.
(aansluit via BR-speler of AC-ryan hd2).
Nu had ik zelf de Optoma hd67n op het oog(pricewatch: Optoma HD67n)
, maar deze beamer heeft ook zo zijn voordelen.
Kwa resolutie zijn ze bijna hetzelfde.
Alleen de Acer is een LED en de andere een DLP beamer
Waar zou je led verkiezen boven DLP?
Of waarom deze Acer ipv de Optoma?
Nog een andere vraag waarde 720p gebruikers zelf ook mee geconfronteerd zijn geweest.
Vanaf welke afstand is 720p net zo scherp als 1080p voor een beamer (plusmin 100" scherm)
1..2 Freddy's coming for you, 3..4 Knocking at ya door, 5..6 Grab your crusifix, 7..8 Better stay up late, 9..10 Never sleep again|| SPECS
  • MrDummy
  • Laatst online: 27-10 11:01
MrDummy
Nog steeds gek op anime...
Canon23 schreef op zondag 12 augustus 2012 @ 21:12:
Ik heb 1080p beamer, maar wel met gewone lamp.
Je hebt niet goed opgelet.Vrijwel alle LED beamers maken nog steeds gebruik van DLP techniek. Verschil is dat de kleurenwiel ontbreekt. De 3 LEDs gaan hier gewoon om de beurt knipperen en DLP chip schakelt om en zo ontstaat er vanzelf een volledig beeld.
Het gaat om de levensduur en kwetsbaarheid. Gasontladinglamp in Optoma is kwetsbaar en moet je netjes mee omgaan. Eerst afkoelen voordat je dus gaat verplaatsen of je moet heel voorzichtig doen. Maar LED beamers zijn minder kwetsbaar en gaan langer mee. Je mag gewoon oppakken en ermee bewegen, ook als beamer nog brandt. Het gaat niet kapot, ook al plof je beetje te hard neer op de tafel.
LEDs gaan niet snel stuk en blijven dus werken, maar gasontlading lamp kan soms ineens stukgaan en dan moet je 300-500 Euro dokken. LEDs kun je zelf goedkoop proberen zoeken dus hoeft niet direct bij ACER dealer, kan ook gewoon van Duitse LED boer.
Gasonlading: 2000-4000 hr, LED heeft 10,000-20,000 hr.
Dat is voordeel van LED beamer: minder kwetsbaar, langere levensduur en voor domme mensen kan er weinig misgaan. Gaat ook (bijna) direct aan en kan je meteen kijken. Met gaslamp moet je even wachten tot ie op volle sterkte is.
Alleen gaslamp kan veel meer licht produceren dus donkere kamer is niet noodzakelijk.
Je moet maar voor de grap 1080p en 720p film kijken op je monitor. 720p is circa 33% minder scherp dan 1080p. Op afstand heeft dat impact daarom niet zo groot. Op afstand van 2 meter zie je voor je gevoel nog altijd scherp beeld. 2 meter is minimale afstand voor beamer scherm.
Ik denk diameter x 0,75 = minimale kijkafstand. 2,5 meter is dus 1,8m minimaal. Anders moet je meer je hoofd draaien en dat kan minder prettig zijn. Tussen 1 en 1,25 als afstandfactor zou de juiste plek zijn.
Ik heb even gekeken naar prijzen. Het is inderdaad niet duur en heeft acceptabele 500 lumen.
Maar er is nog andere LED beamer, merk Casio. Deze is veel meer licht dankzij hoop laserleds, op 3000 lumen. Kost wel dubbele van de prijs, maar dat is dus enige die veel licht maakt met LED techniek.
  • Canon23
Canon23
>>MY<< world
Thnx voor je uitleg
Deze beamer wekte mijn aandacht, alleen de projectie afstand is 3m en de kamer 3.65m en ik wil niet 65cm van het plafon een beamer hebben hangen dus jammer...ik hou het op de optoma hd67n.
Had wel interesse in de levensduur van de led optie...
Ik zit op het moment zelf te overwegen deze projector aan te schaffen, is deze tegenwoordig nog goed vergeleken met de nieuwe projectors die zijn uitgekomen, zelf als ze wat duurder zijn? Tevens, hoe erg is een beamerscherm een must?
Heb er ook een aparte topic over gemaakt hierzo: De beste LED beamer
  • oNNoZeLe
  • Laatst online: 13-11 10:37
Ik heb een vraag over hoe het beste audio te regel is..
Stel ik hang mijn ps3 aan deze beamer, hoe krijg ik dan het beste de audio op mijn stereo?
Uiteindelijk voor deze projector gegaan, zit alleen met het probleem dat het apparaat mijn VGA kabel met DVI opzetstukje niet pakt, deze is nodig aangezien mijn computer 2 DVI poorten heeft, deze methode werkte prima met mijn oude beamer die ook alleen een VGA poort had, ik heb hem aan de praat gekregen met een DVI kabel met HDMI opzetstukje maar wil deze liever niet gebruiken aangezien de HDMI poort nogal snel beschadigd en elke keer dat ik fullscreen ga voor een videobestand, internetvideo of spel krijg ik voor een seconde of 7 het Acer logo te zien, hier valt enigzins mee te leven maar ik hoop wel dat er een manier is om dit apparaat volledig te laten werken.
De VGA poort is overigens prima, hij pakt een directe VGA kabel naar m'n notebook zonder enig probleem, maar deze gebruik ik niet voor video aangezien het chronisch hapert.
  • Ryan1981
Ryan1981
Je ne sais pas
Las net je reactie, beetje laat zoals gewoonlijk, misschien heb je al een oplossing, zo ja laat het even weten kan bruikbaar voor anderen zijn.
Als eerste heb ik hem idd niet getest met DVI naar VGA. Ik weet dat DVI aansluitingen er in verschillende versies zijn, misschien is het mogelijke om verschillende types te testen en eens te googlen op dit probleem kijken of iemand het al opgelost heeft.
Er is ondertussen een hoop gaande rondom dit type projectoren heb ik begrepen. Zit toch stiekem te wachten op een full hd versie met veel lumens en normaal 3d support. Ik krijg met deze 3D ready het niet aan de praat op mijn ATI kaart (ook niet op mijn Nvidia kaart).
Acer heeft al lange tijd geen updates van de firmware uitgebracht. Ik vind het ook jammer dat de EDID informatie van de beamer niet gewoon de 1280x720p@120 hz mode doorgeeft want dit kan hij gewoon aan.
