accordion menu
  • 363 views
  • puddinkie
  • Laatst online: 21-07-2024
ik ben bezig om een accordion menu in mijn site te voegen maar nu wil ik hebben dat mijn menu automatisch weer dicht gaat
iemand misschien die weet waar ik code(s) in moet voegen?
hier mijn codes:
ddaccordion.js
//** Accordion Content script: By Dynamic Drive, at http://www.dynamicdrive.com
//** Created: Jan 7th, 08'. Last updated: June 7th, 2010 to v1.9
//Version 1.9: June 7th, 2010':
//**1) Ajax content support added, so a given header's content can be dynamically fetched from an external file and on demand.
//**2) Optimized script performance by caching header and content container references
var ddaccordion={
ajaxloadingmsg: '<img src="loading2.gif" /><br />Loading Content...', //customize HTML to output while Ajax content is being fetched (if applicable)
headergroup: {}, //object to store corresponding header group based on headerclass value
contentgroup: {}, //object to store corresponding content group based on headerclass value
preloadimages:function($images){
$images.each(function(){
var preloadimage=new Image()
preloadimage.src=this.src
expandone:function(headerclass, selected){ //PUBLIC function to expand a particular header
this.toggleone(headerclass, selected, "expand")
collapseone:function(headerclass, selected){ //PUBLIC function to collapse a particular header
this.toggleone(headerclass, selected, "collapse")
expandall:function(headerclass){ //PUBLIC function to expand all headers based on their shared CSS classname
var $headers=this.headergroup[headerclass]
this.contentgroup[headerclass].filter(':hidden').each(function(){
$headers.eq(parseInt($(this).attr('contentindex'))).trigger("evt_accordion")
collapseall:function(headerclass){ //PUBLIC function to collapse all headers based on their shared CSS classname
this.contentgroup[headerclass].filter(':visible').each(function(){
toggleone:function(headerclass, selected, optstate){ //PUBLIC function to expand/ collapse a particular header
var $targetHeader=this.headergroup[headerclass].eq(selected)
var $subcontent=this.contentgroup[headerclass].eq(selected)
if (typeof optstate=="undefined" || optstate=="expand" && $subcontent.is(":hidden") || optstate=="collapse" && $subcontent.is(":visible"))
$targetHeader.trigger("evt_accordion")
ajaxloadcontent:function($targetHeader, $targetContent, config, callback){
var ajaxinfo=$targetHeader.data('ajaxinfo')
function handlecontent(content){ //nested function
if (content){ //if ajax content has loaded
ajaxinfo.cacheddata=content //remember ajax content
ajaxinfo.status="cached" //set ajax status to cached
if ($targetContent.queue("fx").length==0){ //if this content isn't currently expanding or collapsing
$targetContent.hide().html(content) //hide loading message, then set sub content's HTML to ajax content
ajaxinfo.status="complete" //set ajax status to complete
callback() //execute callback function- expand this sub content
if (ajaxinfo.status!="complete"){
setTimeout(function(){handlecontent(ajaxinfo.cacheddata)}, 100) //call handlecontent() again until ajax content has loaded (ajaxinfo.cacheddata contains data)
} //end nested function
if (ajaxinfo.status=="none"){ //ajax data hasn't been fetched yet
$targetContent.html(this.ajaxloadingmsg)
$targetContent.slideDown(config.animatespeed)
ajaxinfo.status="loading" //set ajax status to "loading"
$.ajax({
url: ajaxinfo.url, //path to external menu file
error:function(ajaxrequest){
handlecontent('Error fetching content. Server Response: '+ajaxrequest.responseText)
success:function(content){
content=(content=="")? " " : content //if returned content is empty, set it to "space" is content no longer returns false/empty (hasn't loaded yet)
else if (ajaxinfo.status=="loading")
expandit:function($targetHeader, $targetContent, config, useractivated, directclick, skipanimation){
if (ajaxinfo){ //if this content should be fetched via Ajax
if (ajaxinfo.status=="none" || ajaxinfo.status=="loading")
this.ajaxloadcontent($targetHeader, $targetContent, config, function(){ddaccordion.expandit($targetHeader, $targetContent, config, useractivated, directclick)})
else if (ajaxinfo.status=="cached"){
$targetContent.html(ajaxinfo.cacheddata)
ajaxinfo.cacheddata=null
this.transformHeader($targetHeader, config, "expand")
$targetContent.slideDown(skipanimation? 0 : config.animatespeed, function(){
config.onopenclose($targetHeader.get(0), parseInt($targetHeader.attr('headerindex')), $targetContent.css('display'), useractivated)
if (config.postreveal=="gotourl" && directclick){ //if revealtype is "Go to Header URL upon click", and this is a direct click on the header
var targetLink=($targetHeader.is("a"))? $targetHeader.get(0) : $targetHeader.find('a:eq(0)').get(0)
if (targetLink) //if this header is a link
setTimeout(function(){location=targetLink.href}, 200) //ignore link target, as window.open(targetLink, targetLink.target) doesn't work in FF if popup blocker enabled
collapseit:function($targetHeader, $targetContent, config, isuseractivated){
this.transformHeader($targetHeader, config, "collapse")
$targetContent.slideUp(config.animatespeed, function(){config.onopenclose($targetHeader.get(0), parseInt($targetHeader.attr('headerindex')), $targetContent.css('display'), isuseractivated)})
transformHeader:function($targetHeader, config, state){
$targetHeader.addClass((state=="expand")? config.cssclass.expand : config.cssclass.collapse) //alternate btw "expand" and "collapse" CSS classes
.removeClass((state=="expand")? config.cssclass.collapse : config.cssclass.expand)
if (config.htmlsetting.location=='src'){ //Change header image (assuming header is an image)?
$targetHeader=($targetHeader.is("img"))? $targetHeader : $targetHeader.find('img').eq(0) //Set target to either header itself, or first image within header
$targetHeader.attr('src', (state=="expand")? config.htmlsetting.expand : config.htmlsetting.collapse) //change header image
else if (config.htmlsetting.location=="prefix") //if change "prefix" HTML, locate dynamically added ".accordprefix" span tag and change it
$targetHeader.find('.accordprefix').html((state=="expand")? config.htmlsetting.expand : config.htmlsetting.collapse)
else if (config.htmlsetting.location=="suffix")
$targetHeader.find('.accordsuffix').html((state=="expand")? config.htmlsetting.expand : config.htmlsetting.collapse)
urlparamselect:function(headerclass){
var result=window.location.search.match(new RegExp(headerclass+"=((\\d+)(,(\\d+))*)", "i")) //check for "?headerclass=2,3,4" in URL
if (result!=null)
result=RegExp.$1.split(',')
return result //returns null, [index], or [index1,index2,etc], where index are the desired selected header indices
getCookie:function(Name){
var re=new RegExp(Name+"=[^;]+", "i") //construct RE to search for target name/value pair
if (document.cookie.match(re)) //if cookie found
return document.cookie.match(re)[0].split("=")[1] //return its value
return null
setCookie:function(name, value){
document.cookie = name + "=" + value + "; path=/"
init:function(config){
document.write('<style type="text/css">\n')
document.write('.'+config.contentclass+'{display: none}\n') //generate CSS to hide contents
document.write('a.hiddenajaxlink{display: none}\n') //CSS class to hide ajax link
document.write('<\/style>')
jQuery(document).ready(function($){
ddaccordion.urlparamselect(config.headerclass)
var persistedheaders=ddaccordion.getCookie(config.headerclass)
ddaccordion.headergroup[config.headerclass]=$('.'+config.headerclass) //remember header group for this accordion
ddaccordion.contentgroup[config.headerclass]=$('.'+config.contentclass) //remember content group for this accordion
var $headers=ddaccordion.headergroup[config.headerclass]
var $subcontents=ddaccordion.contentgroup[config.headerclass]
config.cssclass={collapse: config.toggleclass[0], expand: config.toggleclass[1]} //store expand and contract CSS classes as object properties
config.revealtype=config.revealtype || "click"
config.revealtype=config.revealtype.replace(/mouseover/i, "mouseenter")
if (config.revealtype=="clickgo"){
config.postreveal="gotourl" //remember added action
config.revealtype="click" //overwrite revealtype to "click" keyword
if (typeof config.togglehtml=="undefined")
config.htmlsetting={location: "none"}
else
config.htmlsetting={location: config.togglehtml[0], collapse: config.togglehtml[1], expand: config.togglehtml[2]} //store HTML settings as object properties
config.oninit=(typeof config.oninit=="undefined")? function(){} : config.oninit //attach custom "oninit" event handler
config.onopenclose=(typeof config.onopenclose=="undefined")? function(){} : config.onopenclose //attach custom "onopenclose" event handler
var lastexpanded={} //object to hold reference to last expanded header and content (jquery objects)
var expandedindices=ddaccordion.urlparamselect(config.headerclass) || ((config.persiststate && persistedheaders!=null)? persistedheaders : config.defaultexpanded)
if (typeof expandedindices=='string') //test for string value (exception is config.defaultexpanded, which is an array)
expandedindices=expandedindices.replace(/c/ig, '').split(',') //transform string value to an array (ie: "c1,c2,c3" becomes [1,2,3]
if (expandedindices.length==1 && expandedindices[0]=="-1") //check for expandedindices value of [-1], indicating persistence is on and no content expanded
expandedindices=[]
if (config["collapseprev"] && expandedindices.length>1) //only allow one content open?
expandedindices=[expandedindices.pop()] //return last array element as an array (for sake of jQuery.inArray())
if (config["onemustopen"] && expandedindices.length==0) //if at least one content should be open at all times and none are, open 1st header
expandedindices=[0]
$headers.each(function(index){ //loop through all headers
var $header=$(this)
if (/(prefix)|(suffix)/i.test(config.htmlsetting.location) && $header.html()!=""){ //add a SPAN element to header depending on user setting and if header is a container tag
$('<span class="accordprefix"></span>').prependTo(this)
$('<span class="accordsuffix"></span>').appendTo(this)
$header.attr('headerindex', index+'h') //store position of this header relative to its peers
$subcontents.eq(index).attr('contentindex', index+'c') //store position of this content relative to its peers
var $subcontent=$subcontents.eq(index)
var $hiddenajaxlink=$subcontent.find('a.hiddenajaxlink:eq(0)') //see if this content should be loaded via ajax
if ($hiddenajaxlink.length==1){
$header.data('ajaxinfo', {url:$hiddenajaxlink.attr('href'), cacheddata:null, status:'none'}) //store info about this ajax content inside header
var needle=(typeof expandedindices[0]=="number")? index : index+'' //check for data type within expandedindices array- index should match that type
if (jQuery.inArray(needle, expandedindices)!=-1){ //check for headers that should be expanded automatically (convert index to string first)
ddaccordion.expandit($header, $subcontent, config, false, false, !config.animatedefault) //3rd last param sets 'isuseractivated' parameter, 2nd last sets isdirectclick, last sets skipanimation param
lastexpanded={$header:$header, $content:$subcontent}
} //end check
else{
$subcontent.hide()
config.onopenclose($header.get(0), parseInt($header.attr('headerindex')), $subcontent.css('display'), false) //Last Boolean value sets 'isuseractivated' parameter
ddaccordion.transformHeader($header, config, "collapse")
$headers.bind("evt_accordion", function(e, isdirectclick){ //assign CUSTOM event handler that expands/ contacts a header
var $subcontent=$subcontents.eq(parseInt($(this).attr('headerindex'))) //get subcontent that should be expanded/collapsed
if ($subcontent.css('display')=="none"){
ddaccordion.expandit($(this), $subcontent, config, true, isdirectclick) //2nd last param sets 'isuseractivated' parameter
if (config["collapseprev"] && lastexpanded.$header && $(this).get(0)!=lastexpanded.$header.get(0)){ //collapse previous content?
ddaccordion.collapseit(lastexpanded.$header, lastexpanded.$content, config, true) //Last Boolean value sets 'isuseractivated' parameter
lastexpanded={$header:$(this), $content:$subcontent}
else if (!config["onemustopen"] || config["onemustopen"] && lastexpanded.$header && $(this).get(0)!=lastexpanded.$header.get(0)){
ddaccordion.collapseit($(this), $subcontent, config, true) //Last Boolean value sets 'isuseractivated' parameter
$headers.bind(config.revealtype, function(){
if (config.revealtype=="mouseenter"){
clearTimeout(config.revealdelay)
var headerindex=parseInt($(this).attr("headerindex"))
config.revealdelay=setTimeout(function(){ddaccordion.expandone(config["headerclass"], headerindex)}, config.mouseoverdelay || 0)
else{
$(this).trigger("evt_accordion", [true]) //last parameter indicates this is a direct click on the header
return false //cancel default click behavior
$headers.bind("mouseleave", function(){
config.oninit($headers.get(), expandedindices)
$(window).bind('unload', function(){ //clean up and persist on page unload
$headers.unbind()
var expandedindices=[]
$subcontents.filter(':visible').each(function(index){ //get indices of expanded headers
expandedindices.push($(this).attr('contentindex'))
if (config.persiststate==true && $headers.length>0){ //persist state?
expandedindices=(expandedindices.length==0)? '-1c' : expandedindices //No contents expanded, indicate that with dummy '-1c' value?
ddaccordion.setCookie(config.headerclass, expandedindices)
//preload any images defined inside ajaxloadingmsg variable
ddaccordion.preloadimages(jQuery(ddaccordion.ajaxloadingmsg).filter('img'))
script:
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
<script type="text/javascript" src="ddaccordion.js">
* Accordion Content script- (c) Dynamic Drive DHTML code library (www.dynamicdrive.com)
* Visit http://www.dynamicDrive.com for hundreds of DHTML scripts
* This notice must stay intact for legal use
</script>
<script type="text/javascript">
ddaccordion.init({
headerclass: "expandable", //Shared CSS class name of headers group that are expandable
contentclass: "categoryitems", //Shared CSS class name of contents group
revealtype: "mouseover", //Reveal content when user clicks or onmouseover the header? Valid value: "click", "clickgo", or "mouseover"
mouseoverdelay: 200, //if revealtype="mouseover", set delay in milliseconds before header expands onMouseover
collapseprev: true, //Collapse previous content (so only one open at any time)? true/false
defaultexpanded: [], //index of content(s) open by default [index1, index2, etc]. [] denotes no content
onemustopen: false, //Specify whether at least one header should be open always (so never all headers closed)
animatedefault: false, //Should contents open by default be animated into view?
persiststate: true, //persist state of opened contents within browser session?
toggleclass: ["", "openheader"], //Two CSS classes to be applied to the header when it's collapsed and expanded, respectively ["class1", "class2"]
togglehtml: ["prefix", "", ""], //Additional HTML added to the header when it's collapsed and expanded, respectively ["position", "html1", "html2"] (see docs)
animatespeed: "fast", //speed of animation: integer in milliseconds (ie: 200), or keywords "fast", "normal", or "slow"
oninit:function(headers, expandedindices){ //custom code to run when headers have initalized
//do nothing
onopenclose:function(header, index, state, isuseractivated){ //custom code to run whenever a header is opened or closed
//do nothing
</script>
.arrowlistmenu{
width: 170px; /*width of accordion menu*/
.arrowlistmenu .menuheader{ /*CSS class for menu headers in general (expanding or not!)*/
font: bold 14px Arial;
color: white;
background: black url(titlebar.png) repeat-x center left;
margin-bottom: 10px; /*bottom spacing between header and rest of content*/
text-transform:none;
padding: 4px 0 4px 10px; /*header text is indented 10px*/
cursor: hand;
cursor: pointer;
.arrowlistmenu .openheader{ /*CSS class to apply to expandable header when it's expanded*/
background-image: url(titlebar-active.png);
.arrowlistmenu ul{ /*CSS for UL of each sub menu*/
list-style-type: none;
margin: 0;
padding: 0;
margin-bottom: 8px; /*bottom spacing between each UL and rest of content*/
.arrowlistmenu ul li{
padding-bottom: 2px; /*bottom spacing between menu items*/
.arrowlistmenu ul li a{
color: #A70303;
background: url(arrowbullet.png) no-repeat center left; /*custom bullet list image*/
display: block;
padding: 2px 0;
padding-left: 19px; /*link text is indented 19px*/
text-decoration: none;
font-weight: bold;
border-bottom: 1px solid #dadada;
font-size: 90%;
.arrowlistmenu ul li a:visited{
color: #A70303;
.arrowlistmenu ul li a:hover{ /*hover state CSS*/
color: #A70303;
background-color: #F3F3F3;
</style>
body
<div class="arrowlistmenu">
<h3 class="menuheader" style="cursor: default"><a href="Nieuwe map/home.html" target="iframe">Home</a></h3>
<h3 class="menuheader" style="cursor: default"><a href="Nieuwe map/fotoalbum.html" target="iframe">Studio</a></h3>
<h3 class="menuheader" style="cursor: default"><a href="Nieuwe map/Aanbiedingen.html" target="iframe">Aanbiedingen</a></h3>
<h3 class="menuheader" style="cursor: default"><a href="Nieuwe map/bruidsarrangement.html" target="iframe">Bruidarrangement</a></h3>
<h3 class="menuheader expandable">Massages &#187 </h3>
<ul class="categoryitems">
<li><a href="Nieuwe map/hotstone.html" target="iframe">Hotstone</a></li>
<li><a href="Nieuwe map/Ontspanningsmassage.html" target="iframe">Ontspanning</a></li>
</ul>
<h3 class="menuheader expandable">Haar &#187 </h3>
<li><a href="Nieuwe map/haarverzorging.html" target="iframe">Haarverzorging</a></li>
<li><a href="Nieuwe map/haarproducten.html" target="iframe">Haarproducten</a></li>
</ul>
<h3 class="menuheader expandable">Schoonheid &#187 </h3>
<li><a href="Nieuwe map/Ontspanningsmassage.html" target="iframe" >Lichaamsverzorging</a></li>
<li><a href="Nieuwe map/Ontspanningsmassage.html" target="iframe">Schoonheidsverzorging</a></li>
<li><a href="Nieuwe map/schoonheidsproducten.html" target="iframe">Schoonheidsproducten</a></li>
</ul>
<h3 class="menuheader" style="cursor: default">contact</h3>
<h3 class="menuheader" style="cursor: default">Gastenboek</h3>
<div></div>
en dan heb ik nog een jquery.min.js die ik verder niet kan aanpassen.
ik hoop dat iemand mij kan helpen.
  • Naranya
  • Laatst online: 22:03
Je zult toch zelf wat meer inzet moeten tonen voordat je hier hulp krijgt..
Een compleet script hier neerknallen wordt niemand vrolijk van.
Oh en gebruik Code Tags dat leest wat duidelijker.
[ Voor 54% gewijzigd door Naranya op 24-01-2012 20:06 ]
  • TimothyW
  • Laatst online: 16-05-2025
Laat maar zitten...
[ Voor 91% gewijzigd door TimothyW op 24-01-2012 20:13 ]
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Ja :w
Zo zijn werken we hier niet en dat weet je donders goed.
Kan iemand even...?
Help, mijn script werkt niet (goed)
Bij het openen van een topic hanteer je onze Quickstart en als je code post gebruik dan code tags en post enkel-en-alleen relevante stukken code. Ruim 350 regels (andermans notabene!) code dumpen en 't ons laten oplossen is ronduit onbeschoft. Voor support op de code die je elders jat klop je maar bij de auteur(s), in dit geval DD zélf, aan.
Dit is de laatste keer dat we je hier op wijzen; de volgende keer is 't definitief game over.
@Rest: Mochten jullie 't nog niet weten: je kunt een Topic Report (Afbeeldingslocatie: http://tweakimg.net/g/forum/images/icons/icon_hand.gif, linksbovenaan de pagina) doen als je dergelijke topics tegenkomt; dan handelen wij 't verder af ;)
Overigens, hoewel DynamicDrive over 't algemeen gemeden dient te worden IMHO, is in dit geval de pagina waar je 't script vandaan hebt royaal voorzien van informatie én voorbeelden. Je had op z'n minst de moeite kunnen nemen die pagina eens door te nemen, dan had je je eigen vraag in dit topic prima kunnen beantwoorden.
Step 1: Insert the following code in the HEAD section of your page
Step 2: Insert the below sample code into the BODY section of your page:
[ Voor 55% gewijzigd door RobIII op 24-01-2012 21:52 ]
Je eigen tweaker.me redirect
Over mij
