• BlacKstaR-
  • Laatst online: 03-10 21:02
Ik heb een PC en een Laptop thuis. De laptop heeft een M9600GT en de PC heeft een HD5750. Ik probeer een file stand af te spelen hier de info van de file:
Complete name : C:\Users\Nana\Desktop\The Colbert Report - S07E97 - Mary (Missy) Cummings.mkv
Format : Matroska
Format version : Version 2
File size : 556 MiB
Duration : 21mn 30s
Overall bit rate : 3 614 Kbps
Encoded date : UTC 2011-07-28 05:06:29
Writing application : mkvmerge v4.8.0 ('I Got The...') built on Jun 13 2011 20:36:23
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 21mn 30s
Bit rate : 3 158 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.057
Stream size : 486 MiB (87%)
Writing library : x264 core 116 r2037 f8ebd4a
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=16 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 21mn 30s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 59.1 MiB (11%)
Het probleem wat ik heb dat is dat er erg veel frames worden gedropt. Op de PC speelt hij af op 40-50 fps en op de laptop speelt hij af op 55-57 fps. Wat resulteert in hangende beelden en het geluid loopt niet meer synchroon. De PC is aangelosten op een 50PK550 LG scherm een deze heeft aan dat de input 60Hz is. Alleen de resolutie wordt omhoog getrokken naar 1080. De meeste mkv bestanden werken overigens gewoon feilloos, maar die hebben dan ook maar 29-30 fps. Deze file heeft 59-60fps.
kan iemand mij helpen omdit probleem te verhelpen om tenminste uitleggen waardoor het komt, dat het niet lekker loopt. Ik heb proberen af te spelen met VLC MHC Powerdvd10 en Arcsoft Totalmedia allemaal vertonen dezelfde probleem.
Mijn et9000 satelliet decoder is de enigste manier om deze bestand goed af te spelen, dus aan het bestand zelf ligt het niet.
  • PowerUp
  • Laatst online: 03-10 13:27
Foto & Video Media heeft niets te maken met het afspelen van conent. Ik geef dit topic een schopje naar Mediaspelers en HTPC's
  • Athome
  • Laatst online: 10:32
BlacKstaR- schreef op donderdag 28 juli 2011 @ 15:50:
Dan ligt het dus wel aan het bestand. Als een computer er niet goed mee overweg kan, moet je jezelf toch afvragen of het bestand wel goed is. Dat is mijn mening. Wat er precies aan mankeert kan ik niet zeggen.
Ik zie Header Stripping staan in de specs. Dit is iets wat nog wel eens problemen kan geven. Jouw PC mag er geen last van hebben. De mediaspeler in of onder je TV eventueel wel.
720P en 60Hz (afgerond) is op zich geen gekke combinatie
  • Mystikal
  • Laatst online: 30-09 11:23
Mystikal
It never hurts to help!
Welk os gebruik je?
W7 met Saf5.0 werkt hier meestal prima
Basement Bios ---- Exo-S
  • Archimond
  • Laatst online: 03-10 00:54
Archimond
Lopende Helpdesk
Met "the colbert report Season 07 episode 25 brian cox 720p.mkv" met 59.940 fps, bit depth 8 bit
Heb ik geen problemen als ik het afspeel met Potplayer 1.5.29162, MPHC 1.3.1249.0 en Splash Lite 1.6.1
- Kijk naar taakbeheer hoeveel je CPU belast wordt.
- Defragmenteer het bestand, misschien is het bestand te gefragmenteerd zodat de harde schijf het niet bij kan benen.
- Misschien komt het door slechte of verouderde codecs
- Het kan opgelost worden door nieuwe drivers
Ik heb zelf een Laptop met Intel Core 2 Duo P8600 2.4GHz, 4GB DDR2, ATI Radeon HD4650 1GB en Ati mobility Catalyst 11.7 (nieuwste). Ati Catalyst Download
[ Voor 9% gewijzigd door Archimond op 01-08-2011 21:58 ]
