[SETI@Home] hitparade van week 27 Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
Mede-auteurs:
  • APClll
  • Laatst online: 17-11 22:13
APClll
  • delta9vdp
  • Laatst online: 04-10 17:44
delta9vdp
Afbeeldingslocatie: http://tweakers.net/ext/f/JC7kwqqV82fi9ViRWtJgzDBy/full.jpg
nieuws: SETI stopt zoektocht naar aliens
Gaan wij ook stoppen?
NEE!
Zie voor meer informatie deze link:
http://setiathome.berkele...read.php?id=63888#1100648
Inhoudsopgave Seti@Home hitparades week 27
* geen correcte stats beschikbaar
Wat is Seti@Home ?
Wat is SETI@home?
SETI@home is de naam van een wetenschappelijk experiment dat computers die via het internet met elkaar verbonden zijn, inzet om buitenaardse intelligentie op te sporen. U kunt hieraan deelnemen middels een gratis computerprogramma dat radiotelescoop-data download en analyseert.
NIEUWS UPDATE
23 Jun 2011 | 21:35:31 UTC
Here's another catch-up tech news report. No big news, but more of the usual.
Last week we got beyond the annoying limits with the Astropulse database. There's still stuff to do "behind the scenes" but we are at least able to insert signals, and thus the assimilators are working again.
The upload server (bruno) keeps locking up. This is load related - it happens more often when we are maxed out, and of course we're pretty much maxed out all the time these days. We're thinking this may actually be a bad CPU. We'll swap it out and see if the problem goes away. Until then.. we randomly lose the ability to upload workunits and human intervention (to power cycle the machine locally or remotely) is required.
We've been moving back-end processes around. I mentioned before how we moved the assimilators to synergy as vader seemed overloaded. This was helpful. However one thing we forgot about is that the assimilators have a memory leak. This is something that's been an issue forever - like since we were compiling/running this on Sun/Solaris systems - yet completely impossible to find and fix. But an easy band aid is to have a cron job that restart the assimilators every so often to clear the pipes. Well, oops, we didn't have that cron job on synergy and the system wedged over the weekend. That cron job is now in place. But still.. not sure why it's so easy for user processes to lock up a whole system to the point you can't even get a root prompt. There should always be enough resources to get a root prompt.
The mysql replica continued to fall behind, so the easiest thing to try next was upgrading mysql from 5.1.x to 5.5 (which employs better parallelization, supposedly, and therefore better i/o in times of stress). However, Fedora Core 15 is the first version of Fedora to have mysql 5.5 in its rpm repositories. So I upgraded jocelyn to FC15.. only to find for some reason this version of Fedora cannot load the firmware/drivers for the old QLogic fibre channel card, and therefore can't see the data drives. I've been beating my head on this problem for days now to no avail. We could downgrade, but then we can't use mysql 5.5. I guess we could install mysql 5.5 ourselves instead of yumming it in, but that's given us major headaches in the past. This should all just work like it had in earlier versions of Fedora. Jeez.
Thanks for the kind words in the previous thread. Don't worry - I won't let it get to my head :).
- Matt
Ga naar de DPC website
[ Voor 0% gewijzigd door APClll op 10-07-2011 20:44 ]
  • grass460
grass460
Zo weer een nieuwe week met verse stats. En wat zien ik, een jong kalfje is onze stal rijker geworden. luc de keuster is zijn naam en dus heet ik hem van harte welkom. *O*
5 mijlpalen zijn er weer verdient, ze liggen klaar in het DPC magazijn en per direct af te halen. Ojaa breng wel een aanhangwagen mee.
Helaas merk ik nu dat ik geen werk meer kan uploaden en dat dat inhoud dat er pas na dinsdag wat aan ge daan kan worden. Dit ivm 4th of July in de VS.
DPC SETI@Home hitparade van 3 juli 2011
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 94 / 1.290 (7,3 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)54.039[DPC] hansR36.870.844(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.067Falcon102.879.705(18)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)20.351[DPC]Division_Brabant17.601.270(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)19.156[DPC]Div.Delft5.344.055(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)18.922Tijntje8.945.155(9)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)18.744Ensign Wildfire12.417.410(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)14.207Sp@ceNv@der21.190.226(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.632Wolfje6661.540.446(29)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)10.077NicoClown1.065.761(42)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.180F@stmem6.626.384(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)6.704o25o8.497.625(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)3.064Los Alcoholicos508.746(62)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)3.001K3th3r1.295.414(33)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)2.438[DPC]TeamGrazzie17.364.037(5)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.398apa3.699.543(14)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.345Tim279.914(110)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)2.158AmeComputers3.384.535(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.115ilium96551.930(58)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif33)2.009[DPC] Mastha-Hacker7.158(665)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.996Override1.850.394(26)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.967Herby2.035.789(23)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)1.511BladE_992.368(852)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.350T-800774.504(46)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.303[DPC] Switch12.317.377(7)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)1.287[DPC]LightLuke146.180(168)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)1.249Sentir101202.091(144)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.211Zefod177.105(150)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.085LeonJ212.325(142)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.053Asgoroth910.607(45)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif32)1.003dimaco292.464(108)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.870.844[DPC] hansR54.039(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.190.226Sp@ceNv@der14.207(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.697.117Searchy! Internet Services V.O.F.0(-)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.601.270[DPC]Division_Brabant20.351(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.364.037[DPC]TeamGrazzie2.438(14)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.417.410Ensign Wildfire18.744(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.317.377[DPC] Switch1.303(24)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.619.404MaGNeT (a.k.a. BlueTooth76)144(71)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.945.155Tijntje18.922(5)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.497.625o25o6.704(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.626.384F@stmem7.180(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.344.055[DPC]Div.Delft19.156(4)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.699.543apa2.398(15)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.439.394Team_Elteor_Borislavj0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.384.535AmeComputers2.158(17)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.200.789Mr Beamer0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.879.705Falcon1023.067(2)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.626dpc_kluizenaar0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.216.648[DPC]Spinpoint0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.789Herby1.967(21)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.900.967Teachalot23(93)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.888.905Berkie501(41)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.850.394Override1.996(20)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.710.061Intrud3r0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.602.694[DPC]Team Zuid-Holland0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.540.446Wolfje66610.632(8)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)171.861.422SETI.USA2.319.345.069(1)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)323.305BroadbandReports.com Team Starfire574.827.044(14)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)317.147BOINC SETI@home RUSSIA309.834.648(28)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)300.357Amateur Radio Operators328.039.800(25)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)299.557SETI@Ticino163.191.631(49)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.293U.S.Air Force321.868.016(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)294.730999116.315.209(68)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)286.573Team Art Bell435.636.190(19)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)263.116Dutch Power Cows295.006.476(31)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)260.936SAIC: From Science to Solutions92.903.183(90)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)246.921USA179.171.047(43)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)242.725Ars Technica371.953.803(22)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)242.234UK BOINC Team287.940.132(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)238.505Brasil [SETIBR]291.727.314(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)226.729CANAL@Boinc111.153.868(71)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)224.547TeAm AnandTech492.964.829(17)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.319.345.069SETI.USA171.861.422(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)330.109.095Team MacNN154.055(49)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.039.800Amateur Radio Operators300.357(22)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.868.016U.S.Air Force297.293(24)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.697.653Elite Games326.560(19)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)309.834.648BOINC SETI@home RUSSIA317.147(21)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)309.766.946BOINC.Italy211.349(35)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)298.811.244Phoenix Rising199.913(37)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.006.476Dutch Power Cows263.116(27)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)291.727.314Brasil [SETIBR]238.505(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.293.681Boone Community School District - Iowa100.341(70)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.081.413Team NIPPON174.060(45)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)287.940.132UK BOINC Team242.234(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)277.197.871Universe Examiners114.379(60)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)262.600.627Carl Sagan184.920(43)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)223.300.410AUSTRIA - NATIONAL - TEAM81.789(94)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant1.790.71126-02-2010
2.[DPC] hansR1.156.60326-02-2010
3.MaGNeT (a.k.a. BlueTooth76)959.79215-10-2010
4.Searchy! Internet Services V.O.F.785.77526-02-2010
5.[DPC]TeamGrazzie553.05604-01-2008
More...
Mijlpalen
sander2774175.000
Wouter30.000
[DPC] Mastha-Hacker7.000
BladE_992.000
Alchedin250
Nieuwe Leden
luc de keuster6.195
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
*O* Welkom luc de keuster *O*
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • delta9vdp
Om te beginnen, welkom luc de keuster. *O*
Vandaag geen nieuwe koeien in de wei, maar het magazijn moet weer overuren draaien. Alle mijlpalers gelieve zsm hun palen op te halen. :D
Snel verder met de orde van de dag:
DPC SETI@Home hitparade van 4 juli 2011
Daily Top 30
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.208[DPC] hansR36.914.052(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)29.383[DPC]Division_Brabant17.630.653(4)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)28.223Tijntje8.973.378(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)18.987Falcon102.898.692(18)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)18.771Ensign Wildfire12.436.181(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)17.881[DPC]Div.Delft5.361.936(13)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)16.889apa3.716.432(14)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)11.902Sp@ceNv@der21.202.128(2)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.795NicoClown1.074.556(41)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.679F@stmem6.635.063(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.999o25o8.505.624(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)7.600Wolfje6661.548.046(29)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.659Tim283.573(109)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.449Los Alcoholicos512.195(62)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)2.337[DPC] Brainy0071.324.680(32)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.200[DPC] Mastha-Hacker9.358(606)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)2.121Sentir101204.212(143)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.945K3th3r1.297.359(33)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.914ilium96553.844(58)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.861Asgoroth912.468(45)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.752Override1.852.146(26)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.729Herby2.037.518(23)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.712AmeComputers3.386.247(16)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.575Laurens van Eekelen308.833(101)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.459luc de keuster7.654(650)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.385T-800775.889(46)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.384LeonJ213.709(142)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.200denniswoot115.449(193)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.141Zefod178.246(150)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)1.098Hans vandebos717.424(51)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.914.052[DPC] hansR43.208(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.202.128Sp@ceNv@der11.902(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.697.304Searchy! Internet Services V.O.F.187(57)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.630.653[DPC]Division_Brabant29.383(2)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.364.845[DPC]TeamGrazzie808(36)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.436.181Ensign Wildfire18.771(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.318.389[DPC] Switch1.012(31)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.619.882MaGNeT (a.k.a. BlueTooth76)478(42)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.973.378Tijntje28.223(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.505.624o25o7.999(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.635.063F@stmem8.679(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.361.936[DPC]Div.Delft17.881(6)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.716.432apa16.889(7)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.439.537Team_Elteor_Borislavj143(66)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.386.247AmeComputers1.712(23)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.898.692Falcon1018.987(4)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.037.518Herby1.729(22)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.901.278Teachalot311(51)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.889.850Berkie945(33)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.852.146Override1.752(21)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.548.046Wolfje6667.600(12)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)173.751.375SETI.USA2.321.235.022(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)321.883U.S.Air Force322.189.899(26)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)311.219BroadbandReports.com Team Starfire575.138.263(14)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)309.559Amateur Radio Operators328.349.359(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)306.121SETI@Ticino163.497.752(49)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)297.084Team Art Bell435.933.274(19)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)292.763BOINC SETI@home RUSSIA310.127.411(28)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)273.214UK BOINC Team288.213.346(35)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)257.788Dutch Power Cows295.264.264(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)255.912CANAL@Boinc111.409.780(71)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)244.718TeAm AnandTech493.209.547(17)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)243.752SAIC: From Science to Solutions93.146.935(90)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)237.963Brasil [SETIBR]291.965.277(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)233.956Ars Technica372.187.759(22)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)233.797BOINC.Italy310.000.743(29)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)219.233USA179.390.280(43)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.321.235.022SETI.USA173.751.375(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)330.268.757Team MacNN159.662(50)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.349.359Amateur Radio Operators309.559(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.189.899U.S.Air Force321.883(21)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.044.630Elite Games346.977(19)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.127.411BOINC SETI@home RUSSIA292.763(26)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.000.743BOINC.Italy233.797(34)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.024.574Phoenix Rising213.330(36)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.264.264Dutch Power Cows257.788(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)291.965.277Brasil [SETIBR]237.963(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.389.010Boone Community School District - Iowa95.329(79)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.280.321Team NIPPON198.908(39)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.213.346UK BOINC Team273.214(27)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)277.310.761Universe Examiners112.890(65)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)262.812.191Carl Sagan211.564(37)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)223.390.738AUSTRIA - NATIONAL - TEAM90.328(88)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
o25o8.500.000
Dr.Drax700.000
Opiate150.000
[DPC] Mastha-Hacker9.000
luc de keuster7.000
BladE_993.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • delta9vdp
nieuwe dag, nieuwe stats *O*
Geen verse koeien vandaag maar wel 2 mijlpalen.
Feli luc de keuster en BladE_99 ( paaltjes op gebruikelijke plek op te halen ) }:O
[tech vraagje]
Staat een gtx 560 Ti uit zn neus te vreten. heeft wat foutje jobs ingeleverd en krijgt nu geen vers gras meer.
mogelik probleem ( driver issue ) is opgelost, maar.....no food!
any idea's?
[\tech vraagje]
Maar we kwamen hier voor stats.
DPC SETI@Home hitparade van 5 juli 2011
Daily Top 30
Flushers: 74 / 1.290 (5,7 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.270[DPC] hansR36.929.322(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)15.096Falcon102.913.788(18)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.076Tijntje8.984.454(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)10.456[DPC]Division_Brabant17.641.109(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)8.571[DPC]Div.Delft5.370.507(13)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)6.421o25o8.512.045(10)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)6.198Sp@ceNv@der21.208.326(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)4.858Ensign Wildfire12.441.039(6)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.844Wolfje6661.551.890(29)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.498F@stmem6.638.561(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.704NicoClown1.077.260(41)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.387Los Alcoholicos514.582(62)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.983apa3.718.415(14)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)1.817[DPC] Switch12.320.206(7)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)1.803[DPC]TeamGrazzie17.366.648(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.650Tim285.223(109)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.625Asgoroth914.093(45)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.430BladE_994.777(741)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.372Sentir101205.584(143)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.350Override1.853.496(26)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.225AmeComputers3.387.472(16)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.153luc de keuster8.807(620)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif45)1.054-=nbq=- LD_Viper330.109(98)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)1.001dimaco293.827(108)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)971Andre Barnier381.941(89)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)919[DPC]LightLuke147.456(167)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)887K3th3r1.298.246(33)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)753Herby2.038.271(23)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)745hermanmonique737.628(50)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif43)745mark55.380(292)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.929.322[DPC] hansR15.270(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.208.326Sp@ceNv@der6.198(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.697.985Searchy! Internet Services V.O.F.681(31)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.641.109[DPC]Division_Brabant10.456(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.366.648[DPC]TeamGrazzie1.803(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.441.039Ensign Wildfire4.858(8)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.320.206[DPC] Switch1.817(14)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.620.170MaGNeT (a.k.a. BlueTooth76)288(40)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.984.454Tijntje11.076(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.512.045o25o6.421(6)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.638.561F@stmem3.498(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.370.507[DPC]Div.Delft8.571(5)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.718.415apa1.983(13)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.439.537Team_Elteor_Borislavj0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.387.472AmeComputers1.225(21)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.913.788Falcon1015.096(2)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.038.271Herby753(28)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.901.278Teachalot0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.890.332Berkie482(35)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.853.496Override1.350(20)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.551.890Wolfje6663.844(9)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)174.844.292SETI.USA2.322.327.939(1)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)158.745Brasil [SETIBR]292.124.022(32)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)155.064Team Art Bell436.088.338(19)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)152.513UK BOINC Team288.365.859(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)150.921CANAL@Boinc111.560.701(71)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)147.565SETI@Ticino163.645.317(49)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)146.618999116.794.094(68)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)131.890Team MacNN330.400.647(24)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)126.773Dutch Power Cows295.391.037(31)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)123.886Ars Technica372.311.645(22)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)116.669USA179.506.949(43)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)112.845Team Starfire World BOINC516.034.166(15)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)110.790CrunchingBaseTeam110.013.612(74)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)108.750BOINC.Italy310.109.493(29)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)101.390SwissTeam.NET135.232.184(59)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)101.037Space Quest54.953.118(145)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.322.327.939SETI.USA174.844.292(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)330.400.647Team MacNN131.890(32)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.567.844Amateur Radio Operators218.485(18)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.352.823U.S.Air Force162.924(24)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.215.814Elite Games171.184(21)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.292.456BOINC SETI@home RUSSIA165.045(22)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.109.493BOINC.Italy108.750(38)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.118.591Phoenix Rising94.017(47)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.391.037Dutch Power Cows126.773(33)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)292.124.022Brasil [SETIBR]158.745(26)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.429.854Boone Community School District - Iowa40.844(102)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.378.569Team NIPPON98.248(43)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.365.859UK BOINC Team152.513(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)277.395.251Universe Examiners84.490(52)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)262.907.841Carl Sagan95.650(45)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)223.447.860AUSTRIA - NATIONAL - TEAM57.122(74)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
luc de keuster8.000
BladE_994.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Ik denk dat er ergens bijgehouden wordt dat jouw GPU "fout" is.
Als dat lokaal in een .xml-file is, dan kun je 't zelf aanpassen. >:)
Also you could edit the app_info.xml file then for to let run 2+ WUs/GTX550 Ti simultaneously.
I would start with 2 WUs.
Look with help of e.g. GPU-Z how high the GPU load is. If it's average ~ 95 % I guess it's enough.
If you test 3 WUs simultaneously and you have continuously 100 % it's too much.
<coproc>
<type>CUDA</type>
<count>1</count>
</coproc>
to..
<coproc>
<type>CUDA</type>
<count>0.5</count>
</coproc>
..for 2 WUs/GPU..
<coproc>
<type>CUDA</type>
<count>0.33</count>
</coproc>
..for 3 WUs/GPU.
Als 't in Berkeley bijgehouden wordt, heb je pech... :'( Maar volgens mij wordt "de kraan" automatisch weer langzaam opengezet.
Het probleem van "veel errors" komt vaker voor, maar ik kan zo vlug niets terugvinden van iemand die "helemaal geen werk" meer krijgt.
http://setiathome.berkeley.edu/forum_thread.php?id=64734
http://setiathome.berkeley.edu/forum_thread.php?id=64675
Draai je de standaard Seti-app, of heb je een Lunatics client?
  • delta9vdp
Was even zoeken....
In de pending van deze koe staan nog een berg jobs: Completed, validation inconclusive
Deze moeten eerst worden verwerkt voordat er vers gras wordt aangevoerd :(
Moet nog even geduld hebben..
APCIII: thnx voor het meedenken.
  • TFHfony
  • Laatst online: 17-11 19:41
TFHfony
Professional Weirdo
delta9vdp schreef op woensdag 06 juli 2011 @ 20:57:
Was even zoeken....
Het project resetten in de BOINC client helpt niet?
  • delta9vdp
Goed nieuws. Ik zie net dat er een trekker met vers gras voor de GPU is gearriveerd.
En nu hopen dat het idd een driver probje was.
Zou snel genoeg duidelijk moeten worden in de daily }:O stats. :P
Maar goed, genoeg hierover, we zijn hier per slot van rekening voor de stats.
Alle mijlpalers gefeliciteerd. Palen kunnen weer worden afgehaald, alleen hansR moet hem ff af fabriek halen. Deze is te groot voor het magazijn. _/-\o_
DPC SETI@Home hitparade van 6 juli 2011
Daily Top 30
Flushers: 96 / 1.290 (7,4 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)74.340[DPC] hansR37.003.662(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)33.579Tijntje9.018.033(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)31.081Falcon102.944.869(18)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)27.208Ensign Wildfire12.468.247(6)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)21.704[DPC]Division_Brabant17.662.813(4)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)21.117NicoClown1.098.377(40)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)17.438[DPC]Div.Delft5.387.945(13)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)14.027F@stmem6.652.588(11)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)13.186Sp@ceNv@der21.221.512(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)12.838o25o8.524.883(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)9.583Wolfje6661.561.473(29)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)6.422apa3.724.837(14)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)5.199[DPC] Mastha-Hacker14.557(535)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)3.805Searchy! Internet Services V.O.F.18.701.790(3)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.520Tim288.743(109)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.826Override1.856.322(26)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.754AmeComputers3.390.226(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)2.652[DPC] Brainy0071.327.826(32)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.635Los Alcoholicos517.217(62)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.573Sentir101208.157(143)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.354[DPC] Switch12.322.560(7)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)2.259Zefod180.759(150)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.190BladE_996.967(671)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.882-=nbq=- LD_Viper331.991(98)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.836K3th3r1.300.082(33)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)1.614T-800777.770(46)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.571mark56.951(288)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)1.562[DPC]TeamGrazzie17.368.210(5)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif42)1.329Confuzer258.701(117)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)1.259Geejay107.432(203)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)37.003.662[DPC] hansR74.340(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.221.512Sp@ceNv@der13.186(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.701.790Searchy! Internet Services V.O.F.3.805(14)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.662.813[DPC]Division_Brabant21.704(5)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.368.210[DPC]TeamGrazzie1.562(28)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.468.247Ensign Wildfire27.208(4)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.322.560[DPC] Switch2.354(21)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.621.335MaGNeT (a.k.a. BlueTooth76)1.165(33)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.018.033Tijntje33.579(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.524.883o25o12.838(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.652.588F@stmem14.027(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.387.945[DPC]Div.Delft17.438(7)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.724.837apa6.422(12)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.390.226AmeComputers2.754(17)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.944.869Falcon1031.081(3)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.039.132Herby861(37)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.901.361Teachalot83(85)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.890.891Berkie559(48)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.856.322Override2.826(16)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.561.473Wolfje6669.583(11)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)177.049.562SETI.USA2.324.533.209(1)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)461.938BOINC Synergy668.824.049(10)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)451.287Elite Games311.667.101(27)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)425.309US NAVY463.982.457(18)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)420.819BOINC SETI@home RUSSIA310.713.275(28)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)388.483U.S.Air Force322.741.306(26)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)372.206999117.166.300(68)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)359.237Team Art Bell436.447.575(19)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)351.538Dutch Power Cows295.742.575(31)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)343.735Amateur Radio Operators328.911.579(25)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)342.800BroadbandReports.com Team Starfire575.661.027(14)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)342.726SETI@Ticino163.988.043(49)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)342.037CANAL@Boinc111.902.738(71)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)334.193UK BOINC Team288.700.052(34)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)305.765Ars Technica372.617.410(22)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)284.170Nosu dba team86.048.646(99)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.324.533.209SETI.USA177.049.562(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)330.605.610Team MacNN204.963(45)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.911.579Amateur Radio Operators343.735(25)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.741.306U.S.Air Force388.483(21)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.667.101Elite Games451.287(18)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.713.275BOINC SETI@home RUSSIA420.819(20)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.352.069BOINC.Italy242.576(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.397.731Phoenix Rising279.140(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.742.575Dutch Power Cows351.538(24)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)292.383.488Brasil [SETIBR]259.466(36)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.546.141Boone Community School District - Iowa116.287(75)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)288.700.052UK BOINC Team334.193(29)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)288.573.752Team NIPPON195.183(46)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)277.567.577Universe Examiners172.326(54)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)263.171.512Carl Sagan263.671(35)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)223.547.307AUSTRIA - NATIONAL - TEAM99.447(89)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
[DPC] hansR37.000.000
Tijntje9.000.000
Bruinbaard300.000
QuasaR60.000
[DPC] Mastha-Hacker10.000
luc de keuster9.000
BladE_996.000
peetjo3.000
Alchedin500
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Zo. Even een kleine update aan de topicstart gegeven.
delta9vdp bedankt voor de stats van de afgelopen dagen! :)
Welkom aan onze statsposter delta9vdp :)
Wat er allemaal gebeurde dat zie je zo, wat er bij valt te vertellen ja dat komt zo, waardoor onze cows werden opgeschrikt ja dat vertel ik je zo.
[SETI@Home] hitparade van 7 juli
Vandaag 102 flushers en dat is geen slechte zaak. d:)b
Zij / wij gaan in volle kracht door.
Cows met vakantie, ja hoor er staan zelfs cows op groene velden in Frankrijk.
Ja dat zien we als we de Tour volgen, maar cows die worden opgeschrikt door een karavaan vierwielers en daarna een hoop getoeter van tweewielers tot het grote moment in de etappe.....
Een groepje tweewielers passeert en zij maken weinig lawaai, langs de weg staan er van die tweebeeners en die doen dat wel! Aanmoedigen noemen ze dat geloof ik. :?
Ja, wat is dat opeens voor een gekkenhuis tijdens onze koeien-vakantie?
Want Normandie, ja dat wordt rustig grazen voor onze cows dat dachten we.
En vandaag wat staat ons te verwachten vandaag?
Le Mans, eh..... Le Mans dat is dus bekend van snelheid van lawaai!
Maar goed dat ligt gelukkig niet in Normandie, wij blijven grazen hoe lastig dat ook was vandaag met die Tour dat leidt toch af. Wij gaan nu genieten van onze welverdiende vakantie.
Ja ze, die tweewielers, ze bekijken het maar, zij zijn nerveus in hun 1e week, zij vallen bij bosjes, nou wij niet wij vallen niet, wij grazen niet dicht op elkaar, wij doen gewoon ons werk, niks engs aan. }:O
Wij zijn geroutineerde Dutch Power Cows en wij feliciteren de mijlpaalhalers BladE_99, [DPC] Tijl, mark en luc de keuster ook tijdens onze vakantie en grazen zoals altijd door, ja gewoon door.
DPC SETI@Home hitparade van 7 Juli 2011
Daily Top 30
Flushers: 102 / 1.290 (7,9 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)76.105[DPC] hansR37.079.767(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)35.590Falcon102.980.459(18)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)33.305Tijntje9.051.338(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)20.202Sp@ceNv@der21.241.714(2)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)19.235[DPC]Div.Delft5.407.180(13)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)18.064[DPC]Division_Brabant17.680.877(4)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)16.024F@stmem6.668.612(11)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)14.895NicoClown1.113.272(40)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)12.647Ensign Wildfire12.480.894(6)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)11.912Wolfje6661.573.385(29)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.105o25o8.530.988(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)5.605Los Alcoholicos522.822(61)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)5.567mark62.518(276)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.010apa3.729.847(14)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.563Tim292.306(109)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)3.131K3th3r1.303.213(33)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)3.016Zefod183.775(149)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.860BladE_999.827(602)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.788[DPC] Switch12.325.348(7)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.434Searchy! Internet Services V.O.F.18.704.224(3)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)2.150Herby2.041.282(23)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.079T-800779.849(46)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)2.047Laurens van Eekelen311.777(101)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.957AmeComputers3.392.183(16)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.787Sentir101209.944(143)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.691[DPC] Brainy0071.329.517(32)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif30)1.651[DPC] Tijl60.079(284)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.594[DPC]TeamGrazzie17.369.804(5)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.471Asgoroth916.657(45)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.450ilium96556.516(58)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)37.079.767[DPC] hansR76.105(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.241.714Sp@ceNv@der20.202(4)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.704.224Searchy! Internet Services V.O.F.2.434(20)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.680.877[DPC]Division_Brabant18.064(6)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.369.804[DPC]TeamGrazzie1.594(28)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.480.894Ensign Wildfire12.647(9)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.325.348[DPC] Switch2.788(19)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.622.482MaGNeT (a.k.a. BlueTooth76)1.147(35)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.051.338Tijntje33.305(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.530.988o25o6.105(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.668.612F@stmem16.024(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.407.180[DPC]Div.Delft19.235(5)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.729.847apa5.010(14)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.439.720Team_Elteor_Borislavj183(76)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.392.183AmeComputers1.957(24)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.980.459Falcon1035.590(2)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.041.282Herby2.150(21)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.901.422Teachalot61(89)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.891.123Berkie232(71)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.857.759Override1.437(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.573.385Wolfje66611.912(10)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)179.490.007SETI.USA2.326.973.654(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)420.065Team Art Bell436.867.640(19)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)414.743SETI@Ticino164.402.786(49)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)411.889BroadbandReports.com Team Starfire576.072.916(14)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)407.582Amateur Radio Operators329.319.161(25)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)402.811BOINC SETI@home RUSSIA311.116.086(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)390.180UK BOINC Team289.090.232(34)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)353.024SAIC: From Science to Solutions94.025.463(90)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)339.125Dutch Power Cows296.081.700(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)323.338CANAL@Boinc112.226.076(71)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)319.695999117.485.995(68)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)308.038Brasil [SETIBR]292.691.526(32)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)293.359Ars Technica372.910.769(22)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)288.663Nosu dba team86.337.309(99)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)287.003Carl Sagan263.458.515(37)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)286.901New Zealand100.952.514(80)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.326.973.654SETI.USA179.490.007(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)330.826.854Team MacNN221.244(43)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.319.161Amateur Radio Operators407.582(24)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.161.920U.S.Air Force420.614(20)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)312.124.745Elite Games457.644(19)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.116.086BOINC SETI@home RUSSIA402.811(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.627.736BOINC.Italy275.667(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.673.421Phoenix Rising275.690(38)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.081.700Dutch Power Cows339.125(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)292.691.526Brasil [SETIBR]308.038(31)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.642.998Boone Community School District - Iowa96.857(104)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.090.232UK BOINC Team390.180(26)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.798.653Team NIPPON224.901(42)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)277.753.408Universe Examiners185.831(54)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)263.458.515Carl Sagan287.003(34)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)223.662.695AUSTRIA - NATIONAL - TEAM115.388(89)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
[DPC] Tijl60.000
mark60.000
luc de keuster10.000
BladE_999.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
:w
[ Voor 3% gewijzigd door Verwijderd op 08-07-2011 01:13 ]
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Ook vanaf mijn kant de felicitaties naar de mijlpalen van vandaag! _/-\o_
En ook een vriendelijke :) naar de statsposter van vandaag. Dee midden-in-de-nacht-stats zijn we niet meer gewend de laatste tijd O+
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
{verhaal}
DPC SETI@Home hitparade van 8 juli 2011
Daily Top 30
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)58.209[DPC] hansR37.137.976(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)29.101Falcon103.009.560(18)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.170Tijntje9.076.508(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)23.187Ensign Wildfire12.504.081(6)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)14.826[DPC]Division_Brabant17.695.703(4)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)13.808[DPC]Div.Delft5.420.988(13)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)11.440Sp@ceNv@der21.253.154(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.087NicoClown1.123.359(40)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)9.369F@stmem6.677.981(11)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.593Wolfje6661.580.978(29)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.701apa3.733.548(14)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.405Los Alcoholicos526.227(61)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)3.069T-800782.918(46)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.841BladE_9912.668(559)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.507K3th3r1.305.720(33)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)2.459[DPC] Brainy0071.331.976(32)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)2.366mark64.884(273)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.217[DPC] Switch12.327.565(7)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)2.154Override1.859.913(26)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.133Searchy! Internet Services V.O.F.18.706.357(3)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)2.027o25o8.533.015(10)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.816AmeComputers3.393.999(16)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.597Sentir101211.541(143)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.332Laurens van Eekelen313.109(101)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.257LeonJ216.515(140)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.214[DPC]TeamGrazzie17.371.018(5)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.188Herby2.042.470(23)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)1.184Confuzer260.547(116)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)1.049MartenZ45.545(329)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif15)1.022Tim293.328(109)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)37.137.976[DPC] hansR58.209(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.253.154Sp@ceNv@der11.440(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.706.357Searchy! Internet Services V.O.F.2.133(20)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.695.703[DPC]Division_Brabant14.826(5)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.371.018[DPC]TeamGrazzie1.214(26)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.504.081Ensign Wildfire23.187(4)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.327.565[DPC] Switch2.217(18)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.622.802MaGNeT (a.k.a. BlueTooth76)320(50)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.076.508Tijntje25.170(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.533.015o25o2.027(21)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.677.981F@stmem9.369(9)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.420.988[DPC]Div.Delft13.808(6)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.733.548apa3.701(11)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.440.077Team_Elteor_Borislavj357(46)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.393.999AmeComputers1.816(22)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.009.560Falcon1029.101(2)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.042.470Herby1.188(27)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.901.422Teachalot0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.892.055Berkie932(31)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.859.913Override2.154(19)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.580.978Wolfje6667.593(10)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)181.446.122SETI.USA2.328.929.769(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)312.959U.S.Air Force323.474.879(26)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)308.212UK BOINC Team289.398.444(34)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)304.705Amateur Radio Operators329.623.866(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)303.895BroadbandReports.com Team Starfire576.376.811(14)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)285.113Team Art Bell437.152.753(19)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)284.832CANAL@Boinc112.510.908(71)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)271.222Brasil [SETIBR]292.962.748(32)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)258.531Dutch Power Cows296.340.231(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)256.846SETI@Ticino164.659.632(49)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)256.684SAIC: From Science to Solutions94.282.147(90)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)244.669Ars Technica373.155.438(22)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)224.074TeAm AnandTech494.159.620(17)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)221.712999117.707.707(68)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)216.107Space Quest55.697.760(145)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)214.455USA180.241.970(43)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.328.929.769SETI.USA181.446.122(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)331.007.736Team MacNN180.882(43)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.623.866Amateur Radio Operators304.705(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.474.879U.S.Air Force312.959(21)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)312.473.383Elite Games348.638(18)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.444.466BOINC SETI@home RUSSIA328.380(20)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.835.852BOINC.Italy208.116(37)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.874.686Phoenix Rising201.265(39)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.340.231Dutch Power Cows258.531(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)292.962.748Brasil [SETIBR]271.222(27)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.730.651Boone Community School District - Iowa87.653(88)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.398.444UK BOINC Team308.212(22)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.970.313Team NIPPON171.660(46)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)277.897.033Universe Examiners143.625(54)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)263.669.192Carl Sagan210.677(36)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)223.746.306AUSTRIA - NATIONAL - TEAM83.611(93)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Falcon103.000.000
m0s100.000
BladE_9910.000
Alchedin750
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
En zo zijn we weer helemaal bij. Of we ook blij zijn, tja, daar kan ik vanuit m'n luie stoel natuurlijk niets over zeggen.
...het weekend is tenslotte weer bijna om...
Veel plezier met de stats :Y)
DPC SETI@Home hitparade van 9 juli 2011
Daily Top 30
Flushers: 93 / 1.290 (7,2 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)46.872[DPC] hansR37.184.848(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)29.278Falcon103.038.838(18)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)22.764Tijntje9.099.272(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.692Ensign Wildfire12.523.773(6)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)15.664[DPC]Div.Delft5.436.652(13)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)13.835NicoClown1.137.194(40)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)12.817[DPC]Division_Brabant17.708.520(4)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)11.352Sp@ceNv@der21.264.506(2)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)8.578Wolfje6661.589.556(29)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.072apa3.738.620(14)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.072BladE_9916.740(515)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.453T-800786.371(46)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.365Los Alcoholicos529.592(61)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.861F@stmem6.680.842(11)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.588Searchy! Internet Services V.O.F.18.708.945(3)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)2.107Herby2.044.577(23)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.043Override1.861.956(26)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif43)2.032Martijn123497.239(219)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.831AmeComputers3.395.830(16)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.720K3th3r1.307.440(33)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)1.701Zefod185.952(148)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.696SandmanNL30.336(409)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.653[DPC] Switch12.329.218(7)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.522[DPC]TeamGrazzie17.372.540(5)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.479groentje12.991(555)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)1.453[DPC] Brainy0071.333.429(32)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)1.394Eagle3210446.397(71)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.253o25o8.534.268(10)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)1.018Opiate153.312(162)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif56)945HellBringer1.236.350(35)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)37.184.848[DPC] hansR46.872(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.264.506Sp@ceNv@der11.352(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.708.945Searchy! Internet Services V.O.F.2.588(15)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.708.520[DPC]Division_Brabant12.817(7)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.372.540[DPC]TeamGrazzie1.522(24)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.523.773Ensign Wildfire19.692(4)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.329.218[DPC] Switch1.653(23)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.623.681MaGNeT (a.k.a. BlueTooth76)879(31)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.099.272Tijntje22.764(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.534.268o25o1.253(28)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.680.842F@stmem2.861(14)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.436.652[DPC]Div.Delft15.664(5)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.738.620apa5.072(10)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.440.215Team_Elteor_Borislavj138(69)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.395.830AmeComputers1.831(19)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.038.838Falcon1029.278(2)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.044.577Herby2.107(16)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.892.393Berkie338(56)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.861.956Override2.043(17)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.589.556Wolfje6668.578(9)
More...
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)183.180.946SETI.USA2.330.664.593(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)310.241U.S.Air Force323.785.120(26)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)304.992BOINC SETI@home RUSSIA311.749.458(28)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.576Amateur Radio Operators329.921.442(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)287.304UK BOINC Team289.685.748(34)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)281.051Team Art Bell437.433.804(19)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)270.830TeAm AnandTech494.430.450(17)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)260.157SETI@Ticino164.919.789(49)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)246.861Dutch Power Cows296.587.092(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)244.834999117.952.541(68)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)244.348Carl Sagan263.913.540(37)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)238.084CANAL@Boinc112.748.992(71)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)237.737Phoenix Rising300.112.423(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)234.703Brasil [SETIBR]293.197.451(32)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)228.295Ars Technica373.383.733(22)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)223.979Space Quest55.921.739(145)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.330.664.593SETI.USA183.180.946(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)331.167.986Team MacNN160.250(45)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.921.442Amateur Radio Operators297.576(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.785.120U.S.Air Force310.241(21)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)312.811.876Elite Games338.493(18)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.749.458BOINC SETI@home RUSSIA304.992(22)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.031.683BOINC.Italy195.831(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.112.423Phoenix Rising237.737(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.587.092Dutch Power Cows246.861(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)293.197.451Brasil [SETIBR]234.703(33)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.828.187Boone Community School District - Iowa97.536(74)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.685.748UK BOINC Team287.304(24)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.142.394Team NIPPON172.081(40)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)278.014.150Universe Examiners117.117(60)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)263.913.540Carl Sagan244.348(30)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)223.814.311AUSTRIA - NATIONAL - TEAM68.005(112)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
SandmanNL30.000
TheCalculator20.000
max8.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
