[SETI@Home] hitparade van week 25 Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
Mede-auteurs:
  • APClll
  • Laatst online: 23:44
APClll
Afbeeldingslocatie: http://tweakers.net/ext/f/JC7kwqqV82fi9ViRWtJgzDBy/full.jpg
nieuws: SETI stopt zoektocht naar aliens
Gaan wij ook stoppen?
NEE!
Zie voor meer informatie deze link:
http://setiathome.berkele...read.php?id=63888#1100648
Inhoudsopgave Seti@Home hitparades week 25
* geen correcte stats beschikbaar
Wat is Seti@Home ?
Wat is SETI@home?
SETI@home is de naam van een wetenschappelijk experiment dat computers die via het internet met elkaar verbonden zijn, inzet om buitenaardse intelligentie op te sporen. U kunt hieraan deelnemen middels een gratis computerprogramma dat radiotelescoop-data download en analyseert.
NIEUWS UPDATE
23 Jun 2011 | 21:35:31 UTC
Here's another catch-up tech news report. No big news, but more of the usual.
Last week we got beyond the annoying limits with the Astropulse database. There's still stuff to do "behind the scenes" but we are at least able to insert signals, and thus the assimilators are working again.
The upload server (bruno) keeps locking up. This is load related - it happens more often when we are maxed out, and of course we're pretty much maxed out all the time these days. We're thinking this may actually be a bad CPU. We'll swap it out and see if the problem goes away. Until then.. we randomly lose the ability to upload workunits and human intervention (to power cycle the machine locally or remotely) is required.
We've been moving back-end processes around. I mentioned before how we moved the assimilators to synergy as vader seemed overloaded. This was helpful. However one thing we forgot about is that the assimilators have a memory leak. This is something that's been an issue forever - like since we were compiling/running this on Sun/Solaris systems - yet completely impossible to find and fix. But an easy band aid is to have a cron job that restart the assimilators every so often to clear the pipes. Well, oops, we didn't have that cron job on synergy and the system wedged over the weekend. That cron job is now in place. But still.. not sure why it's so easy for user processes to lock up a whole system to the point you can't even get a root prompt. There should always be enough resources to get a root prompt.
The mysql replica continued to fall behind, so the easiest thing to try next was upgrading mysql from 5.1.x to 5.5 (which employs better parallelization, supposedly, and therefore better i/o in times of stress). However, Fedora Core 15 is the first version of Fedora to have mysql 5.5 in its rpm repositories. So I upgraded jocelyn to FC15.. only to find for some reason this version of Fedora cannot load the firmware/drivers for the old QLogic fibre channel card, and therefore can't see the data drives. I've been beating my head on this problem for days now to no avail. We could downgrade, but then we can't use mysql 5.5. I guess we could install mysql 5.5 ourselves instead of yumming it in, but that's given us major headaches in the past. This should all just work like it had in earlier versions of Fedora. Jeez.
Thanks for the kind words in the previous thread. Don't worry - I won't let it get to my head :).
- Matt
Ga naar de DPC website
[ Voor 49% gewijzigd door APClll op 26-06-2011 23:32 ]
  • grass460
grass460
zo gisteren was weer een goede dag voor DPC 14 plaatsen gestegen in de daily. Veroorzaakt mede door de grote stijgers in de top 5, buiten de top 5 is er ook flink gegraasd en dat heeft zijn vruchten ook afgeworpen.
Wat ook afgeworpen is, zijn de 7 mijlpalen van 500 tot 21 miljoen. Hulde jongens en meiden _/-\o_
Eagle3210 komt met 33 plaatsen in de top 30 en heeft daarmee FOTD award te pakken. *O*
DPC SETI@Home hitparade van 19 juni 2011
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 96 / 1.287 (7,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)127.957[DPC]Division_Brabant16.987.161(5)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)65.467[DPC] hansR36.185.950(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)44.303Tijntje8.613.890(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)36.024Falcon102.510.442(20)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)23.282ilium96444.086(70)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)16.930Sp@ceNv@der21.008.433(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.053F@stmem6.521.639(11)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)14.042Ensign Wildfire12.166.240(7)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)12.638apa3.617.607(14)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)10.940o25o8.403.997(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.305[DPC]Div.Delft5.147.191(13)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)8.976NicoClown970.668(43)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)6.595Wolfje6661.467.739(31)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)6.592K3th3r1.265.253(34)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.366[DPC] Switch12.273.673(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)5.498[DPC]TeamGrazzie17.333.258(4)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)4.964Zefod139.733(173)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)4.683[DPC]Blah.NET359.899(91)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)3.351Los Alcoholicos470.441(66)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.336denniswoot93.260(223)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.302AmeComputers3.354.950(16)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)3.166[DPC] Brainy0071.298.962(32)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)3.106[DPC]LightLuke127.494(182)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)2.979Asgoroth883.529(45)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)2.595Geejay90.904(229)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.510Override1.827.406(26)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.492Sentir101161.034(157)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)2.133Berkie1.875.118(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif20)1.979Tim270.631(112)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif33)1.885Eagle3210431.002(76)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.185.950[DPC] hansR65.467(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.008.433Sp@ceNv@der16.930(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.675.647Searchy! Internet Services V.O.F.140(73)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.333.258[DPC]TeamGrazzie5.498(16)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.987.161[DPC]Division_Brabant127.957(1)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.273.673[DPC] Switch6.366(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.166.240Ensign Wildfire14.042(8)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.610.124MaGNeT (a.k.a. BlueTooth76)0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.613.890Tijntje44.303(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.403.997o25o10.940(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.521.639F@stmem16.053(7)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.147.191[DPC]Div.Delft10.305(11)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.617.607apa12.638(9)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.437.765Team_Elteor_Borislavj0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.354.950AmeComputers3.302(21)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.200.789Mr Beamer0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.626dpc_kluizenaar0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.510.442Falcon1036.024(4)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.216.648[DPC]Spinpoint0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.020.396Herby23(94)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.892.883Teachalot889(46)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.875.118Berkie2.133(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.827.406Override2.510(26)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.710.061Intrud3r0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.602.694[DPC]Team Zuid-Holland0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.495.492Jox4440(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)145.389.115SETI.USA2.292.872.762(1)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)619.129BOINC Synergy662.140.088(10)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)585.613US NAVY458.605.488(18)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)513.543BroadbandReports.com Team Starfire570.121.041(14)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)500.359Elite Games305.779.392(28)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)495.387BOINC SETI@home RUSSIA304.947.963(29)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)493.503Team Starfire World BOINC512.448.135(15)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)482.284Team Art Bell431.255.131(19)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)464.577Dutch Power Cows291.277.359(31)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)452.601BOINC@Poland364.997.154(23)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)448.976Ars Technica368.445.789(22)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)415.221Amateur Radio Operators323.531.428(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)402.893SETI@Ticino159.007.981(51)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)401.051Carl Sagan259.430.717(37)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)390.781CANAL@Boinc107.763.147(74)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)389.506Boone Community School District - Iowa288.235.479(32)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.292.872.762SETI.USA145.389.115(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.793.049Team MacNN270.286(47)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.531.428Amateur Radio Operators415.221(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.739.789U.S.Air Force369.149(34)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.792.708BOINC.Italy346.042(38)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.779.392Elite Games500.359(19)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)304.947.963BOINC SETI@home RUSSIA495.387(20)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.621.559Phoenix Rising320.823(40)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)291.277.359Dutch Power Cows464.577(23)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.235.479Boone Community School District - Iowa389.506(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.203.900Brasil [SETIBR]386.510(32)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.225.426Team NIPPON363.284(36)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)284.260.196UK BOINC Team388.820(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)274.733.763Universe Examiners309.586(41)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)259.430.717Carl Sagan401.051(28)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.102.023AUSTRIA - NATIONAL - TEAM118.635(100)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant1.790.71126-02-2010
2.[DPC] hansR1.156.60326-02-2010
3.MaGNeT (a.k.a. BlueTooth76)959.79215-10-2010
4.Searchy! Internet Services V.O.F.785.77526-02-2010
5.[DPC]TeamGrazzie553.05604-01-2008
More...
Mijlpalen
Sp@ceNv@der21.000.000
Falcon102.500.000
[DPC]LightLuke125.000
Geejay90.000
denniswoot90.000
Expander40.000
didi500
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Ik was even bang dat je de stats vergeten was :P
Maar gelukkig niet. Bedankt voor de stats!
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • Wildfire
  • Laatst online: 22:23
Wildfire
Joy to the world!
Geen mijlpalen vandaag helaas, scheelt wel weer in de verzendkosten :P
DPC SETI@Home hitparade van 20 June 2011
Daily Top 30
Flushers: 40 / 1.287 (3,1 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.364[DPC]Division_Brabant16.995.525(5)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.459Falcon102.513.901(19)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.183[DPC] hansR36.188.133(1)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.826Tijntje8.615.716(9)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.824Ensign Wildfire12.168.064(7)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.789Sp@ceNv@der21.010.222(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.732ilium96445.818(70)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)1.355Asgoroth884.884(45)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.120NicoClown971.788(43)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)737[DPC]Div.Delft5.147.928(13)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)670F@stmem6.522.309(11)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)661[DPC]Blah.NET360.560(91)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)519denniswoot93.779(222)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)506Sentir101161.540(157)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)483Bruinbaard280.858(108)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)472o25o8.404.469(10)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)431Los Alcoholicos470.872(66)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)381[DPC]TeamGrazzie17.333.639(4)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)376Zefod140.109(172)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)355[DPC] Switch12.274.028(6)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)285Eagle3210431.287(76)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)283apa3.617.890(14)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)227Berkie1.875.345(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)203[DPC] Brainy0071.299.165(32)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)191K3th3r1.265.444(34)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)184CasB38.666(359)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)161hermanmonique728.705(50)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)151AmeComputers3.355.101(16)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)142Teachalot1.893.025(24)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)132dimaco286.810(107)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.188.133[DPC] hansR2.183(3)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.010.222Sp@ceNv@der1.789(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.675.681Searchy! Internet Services V.O.F.34(38)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.333.639[DPC]TeamGrazzie381(18)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.995.525[DPC]Division_Brabant8.364(1)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.274.028[DPC] Switch355(20)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.168.064Ensign Wildfire1.824(5)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.615.716Tijntje1.826(4)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.404.469o25o472(16)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.522.309F@stmem670(11)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.147.928[DPC]Div.Delft737(10)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.617.890apa283(22)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.355.101AmeComputers151(28)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.513.901Falcon103.459(2)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.513.166Jan Zandvliet & x-RaY990(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.020.498Herby102(36)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.893.025Teachalot142(29)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.875.345Berkie227(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.827.406Override0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)146.045.661SETI.USA2.293.529.308(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)105.523Team Starfire World BOINC512.553.658(15)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)103.698US NAVY458.709.186(18)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)100.165Amateur Radio Operators323.631.593(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)98.749UK BOINC Team284.358.945(35)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)96.261BOINC@Poland365.093.415(23)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)93.443TeAm AnandTech489.435.329(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)91.427Ars Technica368.537.216(22)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)88.419Dutch Power Cows291.365.778(31)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)80.977USA175.762.136(44)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)78.925Hungary218.096.944(39)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)74.932Brasil [SETIBR]288.278.832(33)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)69.694Team NIPPON285.295.120(34)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)66.666Universe Examiners274.800.429(36)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)65.854BOINC.Italy306.858.562(27)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)65.616U.S.Air Force317.805.405(26)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.293.529.308SETI.USA146.045.661(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.832.053Team MacNN39.004(60)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.631.593Amateur Radio Operators100.165(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.805.405U.S.Air Force65.616(38)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.858.562BOINC.Italy65.854(37)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.951.334Elite Games171.942(13)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.085.444BOINC SETI@home RUSSIA137.481(19)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.673.853Phoenix Rising52.294(44)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)291.365.778Dutch Power Cows88.419(31)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.285.381Boone Community School District - Iowa49.902(47)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.278.832Brasil [SETIBR]74.932(34)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.295.120Team NIPPON69.694(35)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)284.358.945UK BOINC Team98.749(27)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)274.800.429Universe Examiners66.666(36)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)259.492.777Carl Sagan62.060(42)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.128.511AUSTRIA - NATIONAL - TEAM26.488(96)
More...
Megaflush Top 5
posTeamFlushDate
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
Systeemspecs | Mijn V&A spulletjes | Mijn RIPE Atlas probe
  • TFHfony
  • Laatst online: 21:38
TFHfony
Professional Weirdo
Wildfire schreef op dinsdag 21 juni 2011 @ 11:40:
Voortaan gewoon laten afhalen ;) Scheelt de postbode ook weer een hernia ;)
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
TFHfony schreef op dinsdag 21 juni 2011 @ 11:53:
Ah, dus dát doe ik altijd fout :+
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Een onverwacht feestje is een leuk feestje, dus hierbij hangen we slingers op voor... ons nieuwste koetje:
*O* Welkom TFH|Fony *O*
En nee, nu niet aankomen met "het was een namechange", daar trappen we niet in. Feest is Feest. :+
En natuulijk veel plezier met de stats :P
DPC SETI@Home hitparade van 21 juni 2011
Daily Top 30
Flushers: 101 / 1.287 (7,8 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.783[DPC]Division_Brabant17.296.308(5)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)47.490[DPC] hansR36.235.623(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)28.762Ensign Wildfire12.196.826(7)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)28.399Falcon102.542.300(19)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)24.022Tijntje8.639.738(9)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)20.577Sp@ceNv@der21.030.799(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.213ilium96462.031(68)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)12.457apa3.630.347(14)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)12.186F@stmem6.534.495(11)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)9.099o25o8.413.568(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)7.783[DPC]Div.Delft5.155.711(13)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)6.180Zefod146.289(166)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.182Sentir101166.722(152)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.766NicoClown976.554(43)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.336[DPC]TeamGrazzie17.337.975(4)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)4.037[DPC] Switch12.278.065(6)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)3.546[DPC]Blah.NET364.106(90)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)3.466AmeComputers3.358.567(16)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.750denniswoot96.529(217)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.736Los Alcoholicos473.608(65)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)2.608Asgoroth887.492(45)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.063K3th3r1.267.507(34)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.014Beamerke93.968(222)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.988Geejay92.892(225)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)1.749Searchy! Internet Services V.O.F.18.677.430(3)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.571[DPC] Brainy0071.300.736(32)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.512MaGNeT (a.k.a. BlueTooth76)9.611.636(8)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)1.387Herman J.C. van der Bent237.169(126)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.281hermanmonique729.986(50)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.223Teachalot1.894.248(24)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.235.623[DPC] hansR47.490(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.030.799Sp@ceNv@der20.577(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.677.430Searchy! Internet Services V.O.F.1.749(25)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.337.975[DPC]TeamGrazzie4.336(15)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.296.308[DPC]Division_Brabant300.783(1)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.278.065[DPC] Switch4.037(16)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.196.826Ensign Wildfire28.762(3)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.611.636MaGNeT (a.k.a. BlueTooth76)1.512(27)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.639.738Tijntje24.022(5)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.413.568o25o9.099(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.534.495F@stmem12.186(9)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.155.711[DPC]Div.Delft7.783(11)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.630.347apa12.457(8)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.437.942Team_Elteor_Borislavj177(70)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.358.567AmeComputers3.466(18)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.542.300Falcon1028.399(4)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.020.626Herby128(80)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.894.248Teachalot1.223(30)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.876.449Berkie1.104(32)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.828.402Override996(33)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)148.092.517SETI.USA2.295.576.164(1)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif14)326.791Elite Games306.278.125(28)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)301.317Ars Technica368.838.533(22)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)298.082U.S.Air Force318.103.487(26)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)290.518999112.979.728(69)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)280.590USA176.042.726(43)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)276.594TeAm AnandTech489.711.923(17)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)274.209UK BOINC Team284.633.154(35)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)269.135Dutch Power Cows291.634.913(31)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)264.753Phoenix Rising295.938.606(30)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif27)256.733SETI@Ticino159.476.924(51)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)251.173Team NIPPON285.546.293(34)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)249.244Carl Sagan259.742.021(37)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)231.675Boone Community School District - Iowa288.517.056(33)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)230.312CrunchingBaseTeam107.765.947(75)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)224.587Team MacNN328.056.640(24)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.295.576.164SETI.USA148.092.517(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.056.640Team MacNN224.587(41)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.991.937Amateur Radio Operators360.344(21)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.103.487U.S.Air Force298.082(29)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.082.531BOINC.Italy223.969(42)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.278.125Elite Games326.791(27)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.414.906BOINC SETI@home RUSSIA329.462(26)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.938.606Phoenix Rising264.753(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)291.634.913Dutch Power Cows269.135(34)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)288.622.930Brasil [SETIBR]344.098(24)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)288.517.056Boone Community School District - Iowa231.675(39)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.546.293Team NIPPON251.173(37)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)284.633.154UK BOINC Team274.209(33)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)275.021.603Universe Examiners221.174(43)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)259.742.021Carl Sagan249.244(38)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.220.586AUSTRIA - NATIONAL - TEAM92.075(94)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
[DPC]Division_Brabant17.000.000
Martijn123490.000
DarthKoala60.000
mark40.000
Peter10.000
Martijn7059.000
Nieuwe Leden
TFH|Fony261.647
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • TFHfony
TFHfony
Professional Weirdo
APClll schreef op woensdag 22 juni 2011 @ 20:49:
Gna gna gna :) Inderdaad... Ik heb mijn account ondergebracht bij Division Brabant (natuurlijk!) en sinds vanmiddag draait ook mijn GTX460 op dit project, dus... ik zou wel een paar puntjes per dag moeten kunnen doneren.
So Move on over TeamGrazzie!
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
TFHfony schreef op woensdag 22 juni 2011 @ 21:05:
(...)So Move on over TeamGrazzie!
-O-
  • Witlof
  • Laatst online: 19:53
*O* *O* *O* Go Brabant *O* *O* *O*
  • TFHfony
TFHfony
Professional Weirdo
Oh ja... ennuh... stuur je de paal even op naar ons? Stuur maar naar ons clubhuis :)
_/-\o_ _/-\o_ Welkom Welkom TFH|Fony _/-\o_ _/-\o_
In de mooie brabantse stal
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
TFHfony schreef op woensdag 22 juni 2011 @ 22:20:
Sorry, maar dat lukt niet...
M'n postzegels zijn op, de winkels zijn dicht en hij past ook al niet door de frankeermachine... O-)
  • Witlof
Even geheel ter zijde. Het was dus geen name change. TFH|Fony komt van S@NL af. DB krijgt de punten dus wel in de overall, maar DPC niet omdat ze aan een ander team gekoppeld zitten. Desondanks is het wel beter voor DPC, want momenteel is TFH|Fony weer actief op dit project *O*
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Zouden we toch bijna de stats vergeten :(
* APClll toe de reskjuuuu
Ofzo :+
Confuzer en Jan Jasper de Kroon gefeliciteerd met de mijlpalen! d:)b
{verhaal}
DPC SETI@Home hitparade van 22 juni 2011
Daily Top 30
Flushers: 92 / 1.287 (7,1 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)36.049Tijntje8.675.787(9)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)35.463Ensign Wildfire12.232.289(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)34.911[DPC] hansR36.270.534(1)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)32.384Falcon102.574.684(19)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)29.782[DPC]Division_Brabant17.326.090(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)14.101ilium96476.132(66)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)11.190F@stmem6.545.685(11)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.929apa3.637.276(14)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)5.173[DPC] Switch12.283.238(6)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)4.573[DPC]Div.Delft5.160.284(13)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif62)4.459Kets_One299.233(104)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)4.422Sp@ceNv@der21.035.221(2)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.862o25o8.417.430(10)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)3.614Searchy! Internet Services V.O.F.18.681.044(3)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.540Zefod149.829(163)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.079denniswoot99.608(215)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.002Los Alcoholicos476.610(65)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.799[DPC]Blah.NET366.905(89)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif61)2.477Herby2.023.103(23)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.384Geejay95.276(220)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.305NicoClown978.859(43)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.274[DPC]TeamGrazzie17.340.249(4)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)2.191Override1.830.593(26)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.070AmeComputers3.360.637(16)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif29)1.958[DPC]LightLuke129.943(179)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)1.701Confuzer250.765(117)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif23)1.698Dr.Drax689.748(52)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.629[DPC] Brainy0071.302.365(32)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.562Asgoroth889.054(45)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)1.477HellBringer1.228.694(35)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.270.534[DPC] hansR34.911(3)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.035.221Sp@ceNv@der4.422(12)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.681.044Searchy! Internet Services V.O.F.3.614(14)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.340.249[DPC]TeamGrazzie2.274(22)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.326.090[DPC]Division_Brabant29.782(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.283.238[DPC] Switch5.173(9)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.232.289Ensign Wildfire35.463(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.612.876MaGNeT (a.k.a. BlueTooth76)1.240(34)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.675.787Tijntje36.049(1)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.417.430o25o3.862(13)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.545.685F@stmem11.190(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.160.284[DPC]Div.Delft4.573(10)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.637.276apa6.929(8)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.438.040Team_Elteor_Borislavj98(76)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.360.637AmeComputers2.070(24)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.574.684Falcon1032.384(4)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.023.103Herby2.477(19)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.894.399Teachalot151(63)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.877.460Berkie1.011(39)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.830.593Override2.191(23)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)150.563.238SETI.USA2.298.046.885(1)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)362.211USA176.404.937(43)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)349.199SAIC: From Science to Solutions89.724.606(91)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)333.173Brasil [SETIBR]288.956.103(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)331.821Carl Sagan260.073.842(37)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)329.772TeAm AnandTech490.041.695(17)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)327.311UK BOINC Team284.960.465(35)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)325.486Phoenix Rising296.264.092(30)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)311.347Dutch Power Cows291.946.260(31)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)306.852Boone Community School District - Iowa288.823.908(33)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)304.169999113.283.897(69)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)286.234Nosu dba team83.602.146(100)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)285.376Team NIPPON285.831.669(34)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)269.689Hungary218.572.461(39)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)256.271Universe Examiners275.277.874(36)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)240.724BOINC.Italy307.323.255(27)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.298.046.885SETI.USA150.563.238(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.266.616Team MacNN209.976(50)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.448.735Amateur Radio Operators456.798(22)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.477.304U.S.Air Force373.817(28)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.323.255BOINC.Italy240.724(44)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.782.759Elite Games504.634(19)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.924.289BOINC SETI@home RUSSIA509.383(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.264.092Phoenix Rising325.486(36)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)291.946.260Dutch Power Cows311.347(37)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.956.103Brasil [SETIBR]333.173(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.823.908Boone Community School District - Iowa306.852(38)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.831.669Team NIPPON285.376(41)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)284.960.465UK BOINC Team327.311(35)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)275.277.874Universe Examiners256.271(43)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)260.073.842Carl Sagan331.821(33)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.324.784AUSTRIA - NATIONAL - TEAM104.198(107)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Confuzer250.000
Jan Jasper de Kroon750
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Inhaalstats :)
{verhaal}
DPC SETI@Home hitparade van 23 June 2011
Daily Top 30
Flushers: 83 / 1.287 (6,4 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)33.750[DPC] hansR36.304.284(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)22.941Sp@ceNv@der21.058.162(2)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)20.023Falcon102.594.707(19)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)18.749Tijntje8.694.536(9)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)13.674Ensign Wildfire12.245.963(7)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.353ilium96486.485(64)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)8.405o25o8.425.835(10)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)8.192[DPC]Division_Brabant17.334.282(5)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)5.981NicoClown984.840(43)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)4.962F@stmem6.550.647(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)4.874apa3.642.150(14)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)3.377HellBringer1.232.071(35)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.976Los Alcoholicos479.586(66)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.753[DPC] Switch12.285.991(6)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif57)2.725Wolfje6661.471.382(31)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.676Kets_One301.909(102)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)2.355[DPC] Brainy0071.304.720(32)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.867[DPC]Div.Delft5.162.151(13)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.834AmeComputers3.362.471(16)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)1.399Bruinbaard284.258(108)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.385denniswoot100.993(211)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.379Asgoroth890.433(45)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.264Zefod151.093(162)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.102[DPC]TeamGrazzie17.341.351(4)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif60)1.029Rogier88.722(236)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)959Override1.831.552(26)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)914Berkie1.878.374(25)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)904Eagle3210434.598(75)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif26)789LeonJ207.080(142)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)751Geejay96.027(218)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.304.284[DPC] hansR33.750(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.058.162Sp@ceNv@der22.941(2)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.681.142Searchy! Internet Services V.O.F.98(71)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.341.351[DPC]TeamGrazzie1.102(24)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.334.282[DPC]Division_Brabant8.192(8)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.285.991[DPC] Switch2.753(14)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.245.963Ensign Wildfire13.674(5)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.612.876MaGNeT (a.k.a. BlueTooth76)0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.694.536Tijntje18.749(4)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.425.835o25o8.405(7)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.550.647F@stmem4.962(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.162.151[DPC]Div.Delft1.867(18)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.642.150apa4.874(11)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.438.062Team_Elteor_Borislavj22(82)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.362.471AmeComputers1.834(19)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.594.707Falcon1020.023(3)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.023.228Herby125(64)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.894.564Teachalot165(54)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.878.374Berkie914(27)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.831.552Override959(26)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)151.623.862SETI.USA2.299.107.509(1)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)214.299BOINC SETI@home RUSSIA306.138.588(29)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)192.951BOINC@Poland366.148.101(23)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)183.992BroadbandReports.com Team Starfire571.266.103(14)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)183.872SAIC: From Science to Solutions89.908.478(91)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)176.642Team Art Bell432.374.728(19)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)173.547US NAVY459.646.645(18)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)165.657Team Starfire World BOINC513.520.631(15)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)163.968Dutch Power Cows292.110.228(31)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)159.044Elite Games306.941.803(28)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)152.308USA176.557.245(43)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)151.906Amateur Radio Operators324.600.641(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)148.041TeAm AnandTech490.189.736(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)147.532U.S.Air Force318.624.836(26)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)144.998CANAL@Boinc108.680.443(74)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)134.697UK BOINC Team285.095.162(35)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.299.107.509SETI.USA151.623.862(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.358.943Team MacNN92.327(45)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.600.641Amateur Radio Operators151.906(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.624.836U.S.Air Force147.532(30)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.432.917BOINC.Italy109.662(39)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.941.803Elite Games159.044(26)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.138.588BOINC SETI@home RUSSIA214.299(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.393.143Phoenix Rising129.051(34)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)292.110.228Dutch Power Cows163.968(25)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.090.177Brasil [SETIBR]134.074(33)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)288.928.766Boone Community School District - Iowa104.858(41)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.959.079Team NIPPON127.410(35)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.095.162UK BOINC Team134.697(32)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)275.370.446Universe Examiners92.572(44)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)260.200.081Carl Sagan126.239(36)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.376.077AUSTRIA - NATIONAL - TEAM51.293(82)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Kets_One300.000
Zefod150.000
denniswoot100.000
Homerius90.000
pieter40.000
jnlx5.000
didi750
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
En de gewone stats van vandaag:
- Matt
DPC SETI@Home hitparade van 24 juni 2011
Daily Top 30
Flushers: 110 / 1.287 (8,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)79.117[DPC] hansR36.383.401(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)40.938Falcon102.635.645(18)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)36.831Tijntje8.731.367(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)34.706[DPC]Division_Brabant17.368.988(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)34.417Ensign Wildfire12.280.380(7)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)26.596ilium96513.081(61)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)26.240Sp@ceNv@der21.084.402(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)13.003[DPC]Div.Delft5.175.154(13)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)12.012apa3.654.162(14)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)10.126Wolfje6661.481.508(31)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)9.498F@stmem6.560.145(11)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)9.024o25o8.434.859(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)7.870NicoClown992.710(43)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif51)5.517mark45.750(328)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)5.256K3th3r1.274.668(34)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.161Kets_One307.070(101)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)4.484[DPC]TeamGrazzie17.345.835(5)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.424Los Alcoholicos484.010(65)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif52)4.244Searchy! Internet Services V.O.F.18.685.386(3)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)4.051[DPC]LightLuke134.372(176)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)3.922[DPC] Switch12.289.913(6)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)3.310[DPC]Blah.NET370.873(89)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)3.173[DPC] Brainy0071.307.893(32)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.997Zefod154.090(161)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.842AmeComputers3.365.313(16)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)2.765Asgoroth893.198(45)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.755Bruinbaard287.013(108)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.547Berkie1.880.921(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)2.506denniswoot103.499(204)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.320Geejay98.347(216)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.383.401[DPC] hansR79.117(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.084.402Sp@ceNv@der26.240(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.685.386Searchy! Internet Services V.O.F.4.244(19)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)17.368.988[DPC]Division_Brabant34.706(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)17.345.835[DPC]TeamGrazzie4.484(17)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.289.913[DPC] Switch3.922(21)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.280.380Ensign Wildfire34.417(5)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.613.636MaGNeT (a.k.a. BlueTooth76)760(46)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.731.367Tijntje36.831(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.434.859o25o9.024(12)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.560.145F@stmem9.498(11)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.175.154[DPC]Div.Delft13.003(8)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.654.162apa12.012(9)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.438.137Team_Elteor_Borislavj75(101)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.365.313AmeComputers2.842(25)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.635.645Falcon1040.938(2)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.595.626dpc_kluizenaar0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.025.276Herby2.048(31)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.895.126Teachalot562(51)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.880.921Berkie2.547(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.833.342Override1.790(33)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)154.716.647SETI.USA2.302.200.294(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)518.067BOINC@Poland366.666.168(23)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)509.992U.S.Air Force319.134.828(26)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)508.770Team Art Bell432.883.498(19)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)489.583SETI@Ticino160.588.825(51)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)458.555Brasil [SETIBR]289.548.732(32)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)457.832US NAVY460.104.477(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)446.658Ars Technica369.789.853(22)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)443.652Dutch Power Cows292.553.880(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)440.921CANAL@Boinc109.121.364(73)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)439.429SAIC: From Science to Solutions90.347.907(91)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)436.557999113.961.064(68)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)431.920UK BOINC Team285.527.082(35)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)430.155TeAm AnandTech490.619.891(17)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)424.292USA176.981.537(43)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)384.795Phoenix Rising296.777.938(30)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.302.200.294SETI.USA154.716.647(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.627.587Team MacNN268.644(46)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.127.669Amateur Radio Operators527.028(20)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.134.828U.S.Air Force509.992(22)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.746.213BOINC.Italy313.296(42)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.511.452Elite Games569.649(19)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.724.660BOINC SETI@home RUSSIA586.072(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.777.938Phoenix Rising384.795(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)292.553.880Dutch Power Cows443.652(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.548.732Brasil [SETIBR]458.555(25)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.197.776Boone Community School District - Iowa269.010(45)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)286.315.609Team NIPPON356.530(38)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.527.082UK BOINC Team431.920(32)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)275.698.540Universe Examiners328.094(39)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)260.569.996Carl Sagan369.915(37)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.517.793AUSTRIA - NATIONAL - TEAM141.716(88)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
ilium96500.000
Laurens van Eekelen300.000
CasB40.000
didi1.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
[ Voor 6% gewijzigd door APClll op 25-06-2011 19:21 ]
  • TFHfony
TFHfony
Professional Weirdo
*O* *O* *O* Division Brabant op #4 *O* *O* *O*
Gefeliciteerd aan ons zelf :)
TFHfony schreef op zaterdag 25 juni 2011 @ 22:56:
Gefeliciteerd Brabanders *O*
#5 Overall was ook al heel mooi ;)
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Verwijderd schreef op zondag 26 juni 2011 @ 21:34:
Ga je nou de concurrentie staan feliciteren omdat die ons verslagen hebben :?
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
En om de stats neutraal te houden van subteam-geneuzel, hierbij de onpartijdige stats van vandaag
Trek zelf uw conclusies :Y)
{verhaal}
DPC SETI@Home hitparade van 25 juni 2011
Daily Top 30
Flushers: 93 / 1.287 (7,2 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)52.616[DPC] hansR36.436.017(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)28.276[DPC]Division_Brabant17.397.264(4)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.862Tijntje8.757.229(9)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)25.453Falcon102.661.098(18)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.578Ensign Wildfire12.296.958(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)9.432Sp@ceNv@der21.093.834(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)8.994NicoClown1.001.704(43)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)6.642Wolfje6661.488.150(31)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)5.754ilium96518.835(61)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)5.036Zefod159.126(159)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.821F@stmem6.564.966(11)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)4.226[DPC]Div.Delft5.179.380(13)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)4.079apa3.658.241(14)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.954o25o8.438.813(10)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.534K3th3r1.278.202(34)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)3.266[DPC] Switch12.293.179(7)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.724mark48.474(321)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.481Searchy! Internet Services V.O.F.18.687.867(3)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)2.326AmeComputers3.367.639(16)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.175[DPC]TeamGrazzie17.348.010(5)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.994Los Alcoholicos486.004(65)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)1.933Override1.835.275(26)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)1.874hermanmonique733.620(50)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.764Bruinbaard288.777(107)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.646Sentir101171.167(150)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.509[DPC]LightLuke135.881(176)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif29)1.452Dr.Drax691.777(52)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.394Asgoroth894.592(45)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.222Geejay99.569(216)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)1.122Teunstah15.661(521)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.436.017[DPC] hansR52.616(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.093.834Sp@ceNv@der9.432(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.687.867Searchy! Internet Services V.O.F.2.481(18)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.397.264[DPC]Division_Brabant28.276(2)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.348.010[DPC]TeamGrazzie2.175(20)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)12.296.958Ensign Wildfire16.578(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)12.293.179[DPC] Switch3.266(16)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.614.342MaGNeT (a.k.a. BlueTooth76)706(43)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.757.229Tijntje25.862(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.438.813o25o3.954(14)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.564.966F@stmem4.821(11)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.179.380[DPC]Div.Delft4.226(12)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.658.241apa4.079(13)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.438.137Team_Elteor_Borislavj0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.367.639AmeComputers2.326(19)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.661.098Falcon1025.453(4)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.626dpc_kluizenaar0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.026.328Herby1.052(32)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.896.026Teachalot900(39)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.881.238Berkie317(50)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.835.275Override1.933(22)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)156.646.895SETI.USA2.304.130.542(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)321.886BroadbandReports.com Team Starfire572.164.563(14)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)320.505BOINC@Poland366.986.673(23)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)310.322Amateur Radio Operators325.437.991(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)309.995US NAVY460.414.472(18)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)291.765Team Art Bell433.175.263(19)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)275.308999114.236.372(68)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)271.343UK BOINC Team285.798.425(35)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)255.206Dutch Power Cows292.809.086(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)251.518TeAm AnandTech490.871.409(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)248.239SAIC: From Science to Solutions90.596.146(91)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)239.693Team Starfire World BOINC514.137.593(15)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)239.567Ars Technica370.029.420(22)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)235.063CANAL@Boinc109.356.427(73)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)235.058Brasil [SETIBR]289.783.790(32)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)234.337Carl Sagan260.804.333(37)
More...
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.304.130.542SETI.USA156.646.895(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.780.047Team MacNN152.460(52)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.437.991Amateur Radio Operators310.322(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.460.494U.S.Air Force325.666(20)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.959.257BOINC.Italy213.044(40)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.856.106Elite Games344.654(19)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.100.702BOINC SETI@home RUSSIA376.042(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.997.659Phoenix Rising219.721(38)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)292.809.086Dutch Power Cows255.206(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.783.790Brasil [SETIBR]235.058(34)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)289.371.298Boone Community School District - Iowa173.522(46)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)286.535.135Team NIPPON219.526(39)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)285.798.425UK BOINC Team271.343(27)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)275.889.124Universe Examiners190.584(43)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)260.804.333Carl Sagan234.337(35)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.618.593AUSTRIA - NATIONAL - TEAM100.800(78)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Tijntje8.750.000
NicoClown1.000.000
Dellape225.000
Stefan50.000
Mike@Home9.000
[DPC] Mastha-Hacker2.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
APClll schreef op zondag 26 juni 2011 @ 23:30:
Nou APCIII en als je het nu eens zo leest?
#5 Overall was ook al heel mooi........voor jullie (Brabanders)
Maar toch het blijft een fraaie prestatie die een felicitatie verdient. :)
  • Wildfire
Wildfire
Joy to the world!
En daar schuif ik een plekje omhoog in de overall top 30 en weet [DPC] Switch te passeren. Nice :P
  • TFHfony
TFHfony
Professional Weirdo
Wildfire schreef op dinsdag 28 juni 2011 @ 00:12:
Ook gefeliciteerd! :)
  • apa
  • Laatst online: 26-10 14:51
apa
Run Forest, ruuuuuuuuuunnnnn!!
Ter info: ik heb nu een tweetal weken de normale/nieuwste SETI@Home clients gedraaid en krijg de indruk dat die nog steeds minder performanter zijn dan de Lunatics clients...
Ik ga alvast terug naar Lunatics :9
PC: Dell Pro Max 16+ (MB16250) | 64GB | 2x 4TB | SD25TB5 | Eizo CX240 | Steinberg UR22MkII | JBL LSR305
  • TFHfony
TFHfony
Professional Weirdo
apa schreef op woensdag 29 juni 2011 @ 22:40:
Ik wist niet eens dat er nieuwe waren. Ik heb afgelopen week Seti@Home toegevoegd aan BOINC en zonder na te denken de Lunatics install er over heen gemikt :)
