Probleem met selecteren checkboxen
  • 926 views
Beste medetweakers,
Voor een project op school is het de bedoeling dat je enkele en meerdere checkboxen kunt selecteren en verwijderen. Het probleem is dat het mij niet lukt!, heb al heel wat tutorials afgezocht op internet.
Hier mijn code:
<?php
$result = mysql_query("SELECT * from evenement") or die(mysql_error());
$count=mysql_num_rows($result);
<table class="eventlijst">
<form method ="POST" ACTION="">
<tr>
<td>Naam</td><td><input type="text" size="8" name="naam"></td>
<td>Datum</td><td><input type="text" size="5" name="van"></td>
<td>tot</td><td><input type="text" size="5" name="tot"></td>
<td>Vereniging</td><td><select name="vereniging"><option value="%" selected></option><option value="1">De Blauwe Schuit</option><option value="2">De Deurdrievers</option><option value="3">De Deurzetters</option><option value="4">De Duumkes</option><option value="5">De Duvelse Dertien</option></select></td>
<td>Categorie</td><td><select name="categorie"><option value="%" selected></option><option value="1">Bierfeest</option><option value="2">Muziekfeest</option><option value="3">Themafeest</option></select></td>
<td> </td><td><input type="submit" name="Zoek" value="Zoek"></td> </form>
</table>
<br />
<form method="POST"<INPUT TYPE="submit" name="toevoegen" VALUE="toevoegen"> </form>
<form method="POST"> <input name="delete" type="submit" value="Delete"> <br /><br />
<table>
<tr class="thead">
<td width="10" class="thead"> </td><td width="75" class="thead">Naam</td><td width="125" class="thead">Begindatum</td><td width="125" class="thead">Einddatum</td><td width="100" class="thead">Vereniging</td><td width="100" class="thead">Categorie</td><td width="100" class="thead">Aanmelden?</td>
</table>
<?php
while($rows=mysql_fetch_array($result)){
<table>
<tr>
<td width="15"><input name="checkbox[]" type="checkbox" id="checkbox[]" value="<? echo $rows['evenementid']; ?>"></td>
<td width="85"><? echo $rows['naam']; ?></td>
<td width="130"><? echo $rows['begindatum']; ?></td>
<td width="175"><? echo $rows['einddatum']; ?></td>
<td width="100"><? echo $rows['categorieid']; ?></td>
<td width="100"><? echo $rows['organiserendeVerenigingid']; ?></td>
<td width="100"><? echo $rows['isAanmeldingVerplicht']; ?></td>
</tr>
</table>
</form>
<?php
<?php
if(empty($_POST['delete']) || !is_numeric($_POST['delete']))
echo "Geen berichten geselecteerd";
} else {
foreach ($_POST['checkbox'] as $id)
mysql_query("DELETE FROM evenement WHERE evenementid='".$id."'") or die(mysql_error());
Hoop dat jullie me kunnen helpen!
Alvast bedankt!
  • harrald
  • Laatst online: 24-09 08:52
En waar gaat het fout? Wat heb je zelf al geprobeerd? Hebben ze je op school al leren debuggen?
Naja, hij geeft een foutmelding aan bij foreach. Maar naar mijn idee is alles goed...
Ik heb vrij veel naar tutorials gezocht en gekeken, maar het lukt me maar niet.
debuggen nog niks over geleerd op school...
  • harrald
Het is namelijk handig als je in je firstpost even vermeld wat je dan al geprobeert hebt, want anders gaan wij allemaal dingen roepen die jij allang hebt geprobeert.
En welke foutmelding krijg je dan?
we hebben hier op got trouwens wel wat leesvoer over debuggen.
[ Voor 26% gewijzigd door harrald op 08-10-2010 21:26 ]
  • console
  • Laatst online: 20:37
Verwijderd schreef op vrijdag 08 oktober 2010 @ 21:15:
Doe eens een var_dump op je op je $_POST['checkbox'] en kijk of je een array terug krijgt van de geselecteerde checkboxen.
PHP:
var_dump($_POST['checkbox']);
Hij geeft een foutmelding bij foreach:
: Invalid argument supplied for foreach()
Maar volgens mij kloppen alle gegevens verder wel die daar in staan..
Dus ik weet niet of hij de gegevens wel goed ophaalt uit de checkboxen..
Zal ik in het vervolg doen bij firsttopic!, dit is mijn eerste;)
EDIT: ik krijg NULL terug
Form stond in de WHILE-loop, dit heb ik nu veranderd. Hij doet het nu;)
Wie sluit dit topic?
[ Voor 24% gewijzigd door Verwijderd op 08-10-2010 21:34 ]
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Een slotje is niet nodig op een topic als je je oplossing hebt. Zie daarvoor ook onze faq betreffende topiceinde.
Ik sluit het topic echter alsnog omdat het gewoon een quickfix / Kan iemand even...? is en daar doen we hier niet aan.
Voortaan; als je code post, gebruik dan code tags aub en neem even onze Quickstart door voordat je een nieuw topic opent ;)
[ Voor 22% gewijzigd door RobIII op 08-10-2010 22:01 ]
Je eigen tweaker.me redirect
Over mij
