Update net handmatige binnen gehaald, en nu aan het installeren.
Alleen een update aan de market volgens de htc site.
Heb me telefoon geroot, dus kon hem niet zo installeren op de htc manier.
Heb deze oplossing gevonden die wel werkt
On your Phone
open Astro and go to "download" folder
long
-press and select "edit"
press "move"
press back button
press "edit" from the top menu bar
press "paste"
long press the file
press "edit", then press "rename"
rename to update.zip then press OK
Installation
power off phone
hold "volume down" and turn on phone
A screen should appear showing your phone's system searching for various files. Scroll down to “recovery” using the volume down button and press the “Power” button
When you see the triangle with an exclamation point symbol, press the “Power” and “Volume Up” buttons at the same time. This may take a few attempts
From the menu that appears, use the trackball to select "Apply sdcard:update.zip." Press down on the trackball to start.
When the screen displays "Install from sdcard complete" use trackball to select "reboot system now" and wait for the phone to power back up.
Misschien handig voor de mensen die het zelfde probleem hadden
Voor 82% gewijzigd door
SoeperKees op 08-12-2010 16:34
