• Wii4all
De game is deze week 55 euro bij de mediamarkt zag ik in het krantje.
Burp
Ike. schreef op dinsdag 13 juli 2010 @ 09:41:
Iedereen die alle trophies wilt halen kan beter even wachten met het spelen van de carreer, na de patch krijgt het spel een optie voor een makkelijkere carreer :P
Goed nieuws, daar hoor ik ook veel klachten over.
  • Ike.
Ike.
Nog wat meer patch info:
On top of optimizing load times, one of the things a lot of you have asked for is the ability to play with your friends in XP races. Well, I am very pleased to share with you that UFG has added this feature and it will be available in the upcoming patch as well. The patch is nearing the final development stages with UFG working hard to iron out some bugs before it will be ready for release.
  • TWFpa2Vs
  • Laatst online: 09-10 23:00
Voor de echte bouwers onder ons 10 handige tips:
10. There is dynamic help on most screens that appears when you wait 2-3 secs without touching the controller. It goes away when you move the joystick or press a button. So when you enter a new edit area wait a few seconds to see what other help appears.
9. In Mod Terrain one of the coolest Brushes are called Ground Cover brushes and they are the Last Tab when you maximise the brush list. - They let you paint thousands of flowers and grass and stuff to really make your track come to life.
8. Totally Hidden TIP!!! When you are driving the Steam Roller - Hold L3+ Press Triangle to TOGGLE SPEEDS - fast or slow. SUPER USEFUL.
7. All modes where you are scrubbing a cursor around that is locked to the track - you can toggle the cursor speed fast slow by holding L3 + Pressing Triangle
6. When 2 Props are close too each other or stacked on each other and you are trying to select one or the other - in SELECT PROPS Mode - you can press the D-PAD Up or Down to switch between these overlapping props.
5. When you are in select props mode and are locked onto a Prop - you can quickly switch to all the other copies of that same prop in the world by pressing Left/Right on the D-Pad.
4. You can scale and raise breadcrumbs off the ground. You need to raise breadcrumbs off the ground when you have a jump and you make the breadcrumb follow the arch of the jump so you dude won't reset when he takes the jump. You scale breadcrumbs large or small to affect their influence on the AI.
3. You probably know you use the R-Stick to revolve your camera and Zoom in and Out... but you can also TILT your camera at any time By Holding L3 and moving the R Stick UP/DOWN - SUPER USEFUL.
2. Advanced Edit is The most powerful way to edit your track it gives you much finer control for editing - when you are in the edit mode of Advanced edit use the D-Pad to move laterally when you are editing your track section - and you will see you can SUB-EDIT the track.
1. R3 is the QUICK MENU and is really useful for jumping from Preview and test drive and quickly returning to what you are editing. I use it all the time.
credits
  • SinergyX
  • Laatst online: 09:34
SinergyX
____(>^^(>0o)>____
Hoe maak je nu eigelijk van een bestaande weg een 'brug', zonder het stuk te verwijderen en daar de grond is naar beneden te gooien? Ik wilde wat stukken gaan verbeteren (clipping issues), maar het lukt me maar niet om een stuk direct om te zetten naar een brug (om er zo een ander stuk track onderdoor te laten lopen).
Als je in de steam roller en je tilt omhoog gaat de grond automatisch mee omhoog, daarmee lukte het me ook niet.
[ Voor 15% gewijzigd door SinergyX op 20-07-2010 10:13 ]
  • TWFpa2Vs
achteraf moet je kiezen voor circuit aanpassen en dan wegstijlen.. dan kies je vierkantje en kun je een brug of tunnel maken..
  • Wii4all
Gisteren een aantal potjes gedaan.
Eigenlijk de twee ergernisssen die ik heb zijn:
- Opstarten na het laden weer laden, kan het spel niet gewoon in een keer doorladen naar de arena. Ik wacht liever één keer lang
- Na een carreer race moet je een optie hebben om de volgende race te kunnen spelen, nu kom je weer terug in die arena
Verder online wat potjes gedaan, echt geweldig de creaties die iedereen heeft gemaakt, werkelijk geen poppetje / auto ziet er hetzelfde uit. Online is het wel andere koek als tegen de cpu, ik ben nog geen potje eerste geeindigd, alleen maar 3e en lager....
Burp
  • HoefMeistert
  • Laatst online: 18-09-2025
Wii4all schreef op woensdag 21 juli 2010 @ 11:16:
Dat opstarten is idd ECHT super irritant.
Je gaat wel door naar de volgende race in career, alleen is dit bij de eerste race van de eerste tour niet zo volgens mij.
PSNID : HoefMeistert
Mocht iemand de code voor de Kratos Pack EU hebben, laat het me aub weten.
In de eerdere posts kon ik het niet vinden...
Thx!
  • Qosmic
  • Laatst online: 10:04
kan je met MNR ook meerdere banen achter elkaar spelen?
Heb em gister binnen gehad en was even met mijn broertje aan het spelen, maar telkens als de race afgelopen was moet je dan weer een nieuwe selecteren.
Heb je ook zoiets als bij mario kart dat je een soort tournooitje kan doen?
Stop chasing the dream, you're already living it
  • Tweak15KW
  • Laatst online: 26-10 21:17
Is er al nieuws over de update om de laadtijden in te korten?
  • Ike.
Ike.
Tweak15KW schreef op vrijdag 30 juli 2010 @ 17:56:
as.maandag word in de wekelijkse blogpost gemeld wanneer de update zal worden uitgebracht
http://blog.eu.playstation.com/
http://blog.us.playstation.com/
  • Ike.
Ike.
ModNation Racers Patch Date and Details
Slashed Load Times
Yes, there are still going to be load times, but Sony is reporting that in some cases those loads will be 50 percent faster.
Casual Difficulty FTW
A lot of folks dug the gameplay in ModNation Racers, but they were getting pwned by the game's AI-controlled opponents; those computerized bastards never gave Player 1 a break! Well, this patch introduces Casual Difficulty Mode. This should give people who just want to have some fun the chance to do so without having to worry about hurling a controller after getting sideswiped in the third lap.
Friends with XP Benefits
Racing in XP Races and Series is key to earning experience points and leveling-up online. However, as it stands, you can't invite your friends to XP outings. It kind of sucks the fun out of your multiplayer romp. Well, next week, that'll be a thing of the past. This patch allows you to invite your buddies to races and series, so go level grind!
Death to Hot Lap Cheaters
Apparently, this patch will fix a bug that allowed players to cut through tracks and post ridiculous times in the online Hot Lap section. Only a few more days to steal the spotlight, kids!
The Ultimate Collector
Player cards -- the profile showing what you've whipped up -- will now display all of you creations and not just some of them.
Get Online Faster and Stay There
United Front Games is also fixing MNR so that you'll be able to jump into online races faster than ever. The developers say that this has been done by removing "the online game room from the ModSpot." On top of that, the server's been upgraded to help get rid of those pesky disconnects people were having to deal with. We'll see how that works next week.
Attain the Unattainable (Challenges)
United Front Games has listened to all of your ranting and raving and honed in on three challenges that it agrees are just too damn tough. When you download the patch, expect different completion conditions on the Devastator takedown on Wild Run, the Devastator takedown on Modobahn and the "sideswipe three opponents on the cliff side" task on Fracture.
Free Stuff
The Tin Bucket item will be unlocked for everyone! Hooray!
[ Voor 91% gewijzigd door Ike. op 31-07-2010 15:25 ]
  • Wii4all
Next week....ik ben benieuwd.
Burp
  • Qosmic
is er bekend wanneer exact?
  • himlims_
himlims_
🐧 Linux HOoligan
*O* whoooot daar komen ze nu meej, game net vorige week verkocht, njah dan maar weer nieuwe
  • Ike.
Ike.
Nog niet, check de PS3 blogs later vandaag, als het goed is maken ze vanavond bekend wanneer de patch online komt.
  • Ike.
Ike.
ModNation Monday: Title Update 1.02 Releases August 4th, Brings Improvements
http://blog.us.playstatio...-4th-brings-improvements/
  • Wii4all
Ike. schreef op maandag 02 augustus 2010 @ 19:25:
Ben benieuwd...
Burp
  • Qosmic
heb patch 1.02 er nu op staan, maar kan nou niet zeggen dat ik de laadtijden erg verbeterd vind...
  • Wii4all
ik heb nog geen ervaring met de nieuwe patch maar kan me voorstellen dat als de basis al niet al te best is dat je dan moeilijk verbeteringen kan aanbrengen zonder een groot deel te herschrijven. Dat hebben ze denk ik niet aangedurfd of hadden ze gewoon de tijd niet voor.
Burp
  • HoefMeistert
Qosmic schreef op woensdag 04 augustus 2010 @ 23:08:
Oww dan heb ik wellicht een andere patch of lijkt het mij sneller gaan :), hij lijkt meer van HDD te doen. Laadtijden zullen door de diversiteit wel blijven maar ze hadden het bij release zo moeten hebben als nu... Je kan ook meer skippen (intro filmpjes) en de keuze als je start vindt ik ook handiger, de online rooms heb ik nog niet gechecked...
[ Voor 5% gewijzigd door HoefMeistert op 05-08-2010 07:12 ]
  • Wii4all
Heb het vanochtend even getest.
Je kan de eerste paar filmpjes skippen met X
Vervolgens kun je in een opstart menuutje kiezen of je naar de creation shop wil, naar je carreer of naar de arena.
Dat is op zich wel een verbetering waren het niet dat ie daarna natuurlijk weer gaat laden om de arena te tonen
Burp
  • Ike.
Ike.
Mijn ps3 loopt compleet vast elke keer als ik een online XP series of race start sinds patch 1.02
Patch 1.03 zal binnenkort wel (moeten) uitkomen.
quote: PS3 twitter
ModNation Racers: Update 1.02 introduced an issue that affects online XP Races & XP Series. We're working on a solution to resolve the issue
  • Craztas
  • Laatst online: 05-11 12:29
edit; weet al hoe. Nu ff uit proberen.
[ Voor 174% gewijzigd door Craztas op 12-08-2010 19:42 ]
  • himlims_
himlims_
🐧 Linux HOoligan
  • Ike.
Ike.
Vanaf morgen double XP week voor PS3 en PSP.
Dus als iedereen vanaf morgenavond mijn creations (PS3) wil downloaden... 8)
Post je PSN ID zodat we elkaar kunnen helpen!
PSN: iikkee
[ Voor 16% gewijzigd door Ike. op 31-08-2010 11:29 ]
  • HoefMeistert
even een lijstje maken :)
How to Search via PSN ID
1. Go to the share spot in the ModSpot
2. Press []
3. Select Download
4. Press L2 or R2 to pick Mod/Kart/Track
5. Scroll down to Search by Text
6. Type in PSN ID and hit start
7. What comes up is a list of all creations made by that player.
PSN ID's
  • iikkee
  • HoefMeistert
[ Voor 63% gewijzigd door HoefMeistert op 31-08-2010 13:27 ]
  • evil kim
  • Laatst online: 25-09 09:19
Is er iemand die weet hoe het stunt pack te downloaden ?
Dit zou nog tot 09/11/2010 moeten gratis zijn, maar ik kan het nergens vinden.
  • Ike.
Ike.
evil kim schreef op dinsdag 02 november 2010 @ 07:09:
Vanaf morgenavond pas in de Europeese PSNstores.
Is er iemand die de 100 online wins trophy wil boosten met me?
Dit is erg makkelijk/snel te boosten op een kleine custom map.
Ik moet nog 60 wins :(
[ Voor 21% gewijzigd door Ike. op 02-11-2010 09:10 ]
  • Ike.
Ike.
De gratis DLC is een weekje uitgesteld.
  • evil kim
HoefMeistert schreef op dinsdag 31 augustus 2010 @ 13:26:
2. Press []
3. Select Download
PSN ID's
  • iikkee
  • HoefMeistert
  • evil_kim
Zo mijn id er ook bijgezet
  • evil kim
Ike. schreef op woensdag 03 november 2010 @ 18:25:
Zolang ze niet afstellen ben ik gelukkig :+
  • marapuru
  • Laatst online: 09-11 21:58
marapuru
db.
2. Press []
3. Select Download
PSN ID's
  • iikkee
  • HoefMeistert
  • evil_kim
  • break1985
  • Wii4all
zat gisteren al te zoeken maar kon niks vinden...
nu blijkt waarom ;)
Burp
  • SL65
  • Laatst online: 08:36
Ben ik de enige die dit te moeilijk vind voor een kiddy game? Midnight Club LA helemaal uitgespeeld en dat werd op veel forums als moeilijke racer aangeduid, maar ik vind dit spel niet normaal moeilijk :o
SL65 schreef op vrijdag 05 november 2010 @ 13:49:
Vind het ook niet altijd even makkelijk, speel daarom meer online dan carriere mode. Maar dat is ook leuk.
  • Wii4all
Is die update eigenlijk verschenen of niet? Ik was er vorige week even niet. Is het wat?
Burp
  • Ike.
Ike.
Wii4all schreef op zaterdag 13 november 2010 @ 09:54:
DLC info:
http://blog.us.playstatio...e-dlc-and-double-xp-week/
  • evil kim
Das eigenlijk nog geen antwoord op de vraag.
Ik ben ook nog aant wachten tot het hier zou beschibaar worden
  • Bor
  • Laatst online: 23:12
Bor
Coördinator Frontpage Admins / FP Powermod
01000010 01101111 01110010
Er staat een gratis download van 100KB maar ik weet niet zeker of dat hem is. Ik heb hem wel gedownload maar niet getest.
Over Bor | Vraag & Aanbod feedback | Frontpagemoderatie Forum
  • evil kim
Gisteren is er blijkbaar een update binnen gekomen (via autoupdate van de plus)
Vandaag eens kijken of daar iets inzit
  • Ike.
Ike.
evil kim schreef op donderdag 25 november 2010 @ 19:24:
Ik denk dat dat voor de Carnival DLC is. (je moet deze wel unlocken/kopen in de Store).
Deze week is het weer double XP.
[ Voor 5% gewijzigd door Ike. op 25-11-2010 19:31 ]
  • Flexicon
  • Laatst online: 09-11 19:23
Zijn er nog mensen die nog af en toe/actief spelen?
heb het spel van de week overgenomen van een mede tweaker, en bevalt me wel goed :D.
Voeg me maar toe: Flexicon
  • Superkiwi
Superkiwi
Hoi doei
Kleine topic bump :D
Nu het spel voor 7,50 in de PSN store te krijgen is hetb ik het ook gehaald.
Geen geld voor veel fun :)
Al met al een kleine 19 gig moeten downloaden, maar het was het wachten waard!
Enige nadeel vind ik de lange laadtijden, maar verder ultra grappig _/-\o_
Nog meer mensen die dit spel nu voor weinig hebben gedownload?
Ik heb het spel al tijden fysiek in mijn bezit (misschien al in 2010 gekocht, geen idee eigenlijk). Ik vind het erg vermakelijk en had ooit de intentie om voor de Trophies te gaan, maar dat doel heb ik nooit behaald door de grind Trophies en de problemen om fatsoenlijk online te kunnen racen. De laadtijden stonden mij ook wat tegen, maar dat neemt niet weg dat het spel erg vermakelijk is om te spelen.
Vorige week viel LittleBigPlanet Karting bij mij in de bus, dus de kans bestaat dat ik binnenkort weer de overstap ga maken naar het karten. :D
Vorige post is alweer van even terug, maar ik wilde wel even hier melden dat op 10 juli 2018 de servers van de PS3 versie van ModNation Racers definitief offline zullen gaan. De PS Vita werd vorig jaar al offline gehaald.
Mocht je dus nog online willen racen, dan kun je nog iets minder dan 3 maanden vooruit.
Pagina: 1 2 3 Laatste
