[php] krijg mijn id niet door in postvariabele
  • 218 views
  • jasper199069
  • Laatst online: 30-09 13:34
mijn probleem is is dat ik mijn variabele (in het formulier hidden en genaamd id) niet door. als ik de string laat zien krijg ik geen variabele te zien
dit is mijn code:
<?php
session_start();
include("../sql/connect.php");
if( isset( $_SESSION["logged"] ) )
if( isset( $_POST["bev"] ) )
$begin_datum = $_POST["day"]."-".$_POST["month"]."-".$_POST["year"];
$eind_datum = $_POST["day2"]."-".$_POST["month2"]."-".$_POST["year2"];
$begin_dat = mysql_real_escape_string( $begin_datum );
$eind_dat = mysql_real_escape_string( $eind_datum );
$naam = mysql_real_escape_string( $_POST["naam"] );
$titel = mysql_real_escape_string( $_POST["titel"] );
$omschr = mysql_real_escape_string( $_POST["omschr"] );
$sql = "UPDATE taken SET naam='".$naam."', titel='".$titel."', omschr='".$omschr."', beg_dat='".$begin_dat."', eind_dat='".$eind_dat."', status='".$_POST["stat"]."' WHERE id='".$_POST["id"]."'";
//$result = mysql_query( $sql );
echo( $id );
echo("<br> ");
echo( $_POST["id"] );
echo("<br> ");
echo( $sql );
//if( $SESSION["function"] == "behandelaar" )
// header("location: eigen.php");
//if( $SESSION["function"] == "beheerder" )
// header("location: beheer.php");
else
$id = $_GET["id"];
$sql = "SELECT * FROM taken WHERE id = '".$id."'";
while( $row = mysql_fetch_array( $result ) )
$date = $row["beg_dat"];
list( $day, $month, $year ) = explode( '-',$date );
$date2 = $row["eind_dat"];
list( $day2, $month2, $year2 ) = explode( '-',$date2 );
<form name="upd_taak" method="POST" action="<?php echo( $_SERVER["PHP_SELF"] ); ?>">
Naam: <input type="text" name="naam" value="<?php echo( $row["naam"] ); ?>"><br>
Titel: <input type="text" name="titel" value="<?php echo( $row["titel"] ); ?>"><br>
Omschrijving:<br>
<textarea cols="15" rows="4" name="omschr"><?php echo( $row["omschr"] ); ?></textarea><br><br>
Begin datum (dd-mm-yyyy): <input type="text" name="day" value="<?php echo( $day ); ?>" size="2"> - <input type="text" name="month" value="<?php echo( $month ); ?>" size="2"> - <input type="text" name="year" value="<?php echo( $year ); ?>" size="4"><br>
Eind datum (dd-mm-yyyy): <input type="text" name="day2" value="<?php echo( $day2 ); ?>" size="2"> - <input type="text" name="month2" value="<?php echo( $month2 ); ?>" size="2"> - <input type="text" name="year2" value="<?php echo( $year2 ); ?>" size="4"><br><br>
<select name="stat">
<option value="non-actief">Non-Actief</option>
<option value="klaar">Klaar</option>
<option value="bezig">Bezig</option>
</select><br><br>
<input type="hidden" name="bev" value="1"
<input type="hidden" name="id" value="<?php echo( $row["id"] ); ?>">
<input type="submit" name="submit" value="Update"> <input type="reset" name="reset" value="Alles leegmaken"> <input type="button" value="terug" onClick="parent.history.back();">
</form>
<?php
else
echo("Eerst inloggen aub.");
met vriendelijke groet,
Jasper
  • Matis
  • Laatst online: 18-10 21:32
Matis
Rubber Rocket
psst,
Overzicht van UBB-codes #tag_code
En hoe staan de hidden values in de html-code?
[ Voor 27% gewijzigd door Matis op 18-02-2010 14:08 ]
  • lembregtse
  • Laatst online: 26-09 08:52
HTML:
Wordt niet afgesloten?
  • cariolive23
  • Laatst online: 18-10-2024
Tip: Ga wel even met de php-functie checkdate() aan de slag om te controleren of de datums wel correcte datums zijn. Voor je het weet heb je jouw database vol waardeloze gegevens staan...
Datums sla je hopelijk op in een kolom van het type DATE en dus in het ISO-formaat YYYY-MM-DD. Jouw PHP-code is dus fout, daar staat een fout formaat in.
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Euh; sorry, maar zo werken we hier niet.
Allereerst: als je code post, gebruik dan code tags. Daarbij zien we graag enkel relevante(!) code, en geen dump van een heel bestand.
Tot slot verwachten we ook heel wat meer van een topicstart zoals je dat kunt lezen in onze Quickstart. We zien, o.a., graag wat je zelf al hebt geprobeerd, wat er niet werkt, of je hebt gedebugged en wat daar weer uit kwam etc. (Debuggen: Hoe doe ik dat?).
In deze vorm is je topic niet meer dan een quickfix ("mijn probleem is dat... *dump code*") en daar doen we dus niet aan.
[ Voor 13% gewijzigd door RobIII op 18-02-2010 14:20 ]
Je eigen tweaker.me redirect
Over mij
