[SETI@Home] hitparade van 13 januari Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 11-11 23:33
APClll
FP ProMod
[DPC] Team Grazzie
WTF, dit zijn eigenlijk al de stats van morgen. In dat geval ben ik niet 23 uur te laat, maar een uur te vroeg :?
Waren we toch bijna de stats van vandaag vergeten :o
Ach, de dag is nog niet om dus het is nog niet helemaal oud nieuws :P
Kijken we vluchtig naar de stats, dan zien we vandaag weinig spannende zaken. Geen nieuwe leden en ook geen mijlpalen.
Kijken we wat beter, dan zien we een hele mooie Flusher van de Dag! Paul, gefeliciteerd met de 99 plekjes winst d:)b
13 Jan 2010 0:05:06 UTC
We had an unexpected short outage early this morning. One of our internal file servers crashed, hanging everything. Jeff noticed it upon arrival at the lab this morning and kicked it (and the projects) back to life. Of course an hour later we had to bring everything back down again for the usual weekly maintenance (for mysql database compression and backup). The first outage caused a bit of delay, hence the extended length of what was otherwise a rather vanilla outage.
Jeff and I have been on a binge cleaning up the lab a bit, which has gotten overrun with cables, hardware, compact disc cases, etc. that we'll never need or use. Get it all out of here! Last week we uncovered an unlabeled box containing a motherboard and some RAM which would fit perfectly in this one tower Intel donated a year ago but never worked. So I spent a chunk of yesterday replacing this motherboard, only drawing blood a few times during the course of handling or maneuvering around all the unfortunately sharp heat sinks/solder joints/inner edges of the case. I also managed, while forcing the main power supply plug into the new board, to jam my right index finger down full force onto a set of exposed pins, one of which plunged a good half centimeter underneath my fingernail.
Did I ever mention how much I hate dealing with hardware?
Anyway... the new board works, but for some reason installing the OS on it has been a pain. I'm currently at attempt number five - all the problems stemming from the disk partition layout. This OS install worked perfectly on other systems, including the easy disk formatting GUI. Not sure why on this system I'm only able to create three primary partitions via the GUI, not four. I ultimately had to partition it myself in rescue mode to get it to behave how I wanted. Weird and frustrating. On top of that, the installer was logically swapping sdb and sdc, so when I placed a RAID on what I thought was sda/b it came up "missing" a drive and failed. Whatever. It's sort of working now. Not sure exactly what we'll do with it - probably just replace the slightly less powerful (and crashy) BOINC web server. Two CPUs, 8 GB of memory...
Meanwhile, some more bad news: we're having to backtrack a few steps in the secondary science database recovery project (on bambi). We were able to recover from the backup (a process that took a week or so) but the logical logs have since wrapped around. So we could recover from the continuous logical log backup, right? I mean, that's why we do the continuous logical log backup, no? Well, apparently we can't. Not sure why. So we're going to try to do the whole recovery/rebuild again in a manner that will hopefully take less than the time for those logical logs to wrap around (about 4 days). We'll see. Let me remind you this has zero effect on the public part of the project - well, except that astropulse is still kind of on hold until we're done. Yes, that's much greater than zero.
- Matt
{verhaal}
DPC SETI@Home hitparade van 13 January 2010
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 46 / 1.115 (4,1 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.502[DPC] hansR20.920.707(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.616Searchy! Internet Services V.O.F.14.115.586(3)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif48)1.972F@stmem2.933.833(11)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.266Sp@ceNv@der12.995.908(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.011[DPC]TeamGrazzie15.639.146(2)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)988[DPC]Division_Brabant3.653.760(9)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)984Teachalot871.304(35)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif99)362Paul25.240(339)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)239Asgoroth513.870(51)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)235Vrank224.621(99)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)234Wolfje666659.802(42)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)228o25o & Dharkon6.438.447(6)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)226Jeremy195.752(112)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif49)225Diocletianus24.610(343)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)224darude1234436.923(60)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)198Tijntje2.073.699(17)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif27)174Kick @sz139.289(130)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)172Herby756.400(38)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)150Gerwinvo18.277(388)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif23)145Alex van Niel12.124(450)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif40)133Job133.552(134)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)132Redus265.582(88)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif35)123Jitte21.340(363)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)123Sylvester553.692(49)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)120Handige Harrie2.316(712)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)118Inity (Hugo Westerlow)10.774(470)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)118Koen Wijnstok141.105(129)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif27)111David7.969(520)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)111Override1.149.958(25)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif26)104Ensign Wildfire5.625.489(8)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)20.920.707[DPC] hansR4.502(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.639.146[DPC]TeamGrazzie1.011(5)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.115.586Searchy! Internet Services V.O.F.3.616(2)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.995.908Sp@ceNv@der1.266(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.638.736[DPC] Switch0(-)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.438.447o25o & Dharkon228(12)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.625.489Ensign Wildfire104(30)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.653.760[DPC]Division_Brabant988(6)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.437.428Team_Elteor_Borislavj0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.933.833F@stmem1.972(3)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.620.560AmeComputers0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.605.355[DPC]Spinpoint0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.401.660Jan Zandvliet & x-RaY990(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.179.578Mr Beamer0(-)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.073.699Tijntje198(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.882.406dpc_kluizenaar0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.607.300[DPC] ray0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.599.875[DPC]Team Zuid-Holland0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.440.627Jox44486(37)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.393.629Berkie0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.166.668Dadoke0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.149.958Override111(29)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.149.914Speedy67 & Friends0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.143.565visvogel0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.105.271[DPC]NGS0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.088.439Quark0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)106.424SETI.USA1.416.735.971(1)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)16.698Team NIPPON168.156.389(32)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)16.425BOINC@AUSTRALIA221.223.939(21)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)16.167Antares Predator12.218.031(351)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)16.064Elite Games174.070.769(31)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)15.775U.S.Air Force203.217.208(26)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)14.926Carl Sagan140.296.408(38)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)14.7362CPU.com114.169.097(42)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)14.425Dutch Power Cows183.750.179(28)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)14.222Universe Examiners176.960.390(30)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)12.859seti.international25.484.034(177)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)12.116The Jedi Alliance29.623.703(157)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif27)12.094Nosu dba team21.134.415(206)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)11.954Sicituradastra.43.124.189(111)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)11.633Hungary139.495.149(39)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)11.544BOINC SETI@home RUSSIA166.836.509(34)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.416.735.971SETI.USA106.424(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)221.223.939BOINC@AUSTRALIA16.425(28)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)220.172.332Ars Technica33.254(9)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)215.406.503Phoenix Rising7.635(53)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)204.594.262Amateur Radio Operators19.747(22)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)203.306.904BOINC@Poland17.999(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)203.217.208U.S.Air Force15.775(31)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)197.979.587BOINC.Italy17.381(25)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)183.750.179Dutch Power Cows14.425(34)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)177.040.667UK BOINC Team10.054(46)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)176.960.390Universe Examiners14.222(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)174.070.769Elite Games16.064(30)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)168.156.389Team NIPPON16.698(27)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)167.482.661AUSTRIA - NATIONAL - TEAM7.030(58)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)166.836.509BOINC SETI@home RUSSIA11.544(41)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)152.114.947Boone Community School District - Iowa2.774(172)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant596.27101-09-2009
2.[DPC]TeamGrazzie553.05604-01-2008
3.chelloo.com261.22709-01-2008
4.[DPC]DeApen190.21819-10-2009
5.Team_Elteor_Borislavj186.12006-10-2009
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
AARGH!!!
Wat een dramatische dag voor ons allen. |:(
Het kon ook niet anders: SETI had weer een storing, de }:O }:O lusten geen CUDA. }:|
:'( de Brabantse stal keldert zomaar ff 4 plaatsen
maar zoals een groot filosoof ooit sprak : WE'LL BE BACK ! ! :( (a.zwarteneckert)
het zal wel weer goed komen met de stats morgen denk ik zo ! !
dus de verwachting voor morgen is dan ook : hier en daar een miniflush en voor de rest overal vrij bestendige flushes met een enkele duikeling in de Daily ! ! ;)
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Verwijderd schreef op donderdag 14 januari 2010 @ 17:23:
Leuk! Ik hou wel van verrassingen :P
...alleen jammer dat ik nu al weet wat er morgen gaat gebeuren ;)
