Medal of Honor Spearhead
Sinds vandaag heb ik een probleem als ik het spel Medal of Honor Spearhead opstart.
Ik krijg dan een foutmelding van
--- Common Initialization ---
Medal of Honor Spearhead 2.15 win-x86 Mar 4 2003
----- FS_Startup -----
Current search path:
F:\Windows.old\Program Files\EA GAMES\mainta\pak5.pk3 (12 files)
F:\Windows.old\Program Files\EA GAMES\mainta\pak4.pk3 (59 files)
F:\Windows.old\Program Files\EA GAMES\mainta\pak3.pk3 (311 files)
F:\Windows.old\Program Files\EA GAMES\mainta\pak2.pk3 (399 files)
F:\Windows.old\Program Files\EA GAMES\mainta\pak1.pk3 (6969 files)
F:\Windows.old\Program Files\EA GAMES/mainta
F:\Windows.old\Program Files\EA GAMES\main\VSUK-AbbeyBeta.pk3 (65 files)
F:\Windows.old\Program Files\EA GAMES\main\User-TheLostVillage.pk3 (33 files)
F:\Windows.old\Program Files\EA GAMES\main\User-Eaglesnest-Final.pk3 (49 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak7Nl.pk3 (82 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak6Nl.pk3 (475 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak5.pk3 (259 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak4.pk3 (593 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak3.pk3 (669 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak2.pk3 (4722 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak1.pk3 (396 files)
F:\Windows.old\Program Files\EA GAMES\main\Pak0.pk3 (11174 files)
F:\Windows.old\Program Files\EA GAMES\main\Kmarzo-St Renan.pk3 (20 files)
26287 files in pk3 files
execing default.cfg
execing buildver.cfg
execing menu.cfg
execing newconfig.cfg
execing localize.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 14
You are now setup for medium mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 32, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Ik speel het spel al 5 jaar, ik zit in een officieel clan, en ik moet wedstrijden spelen voor een ranking systeem. Zou iemand mij kunnen helpen met het fixen van het probleem? Ik heb een Geforce 8600 GT en heb nieuwe drivers, heb ook geprobeerd om opnieuw te instaleren maar het werkt niet. Na 5 jaar spelen en opeens gebeurd er dit.
Mvg,
Roland
  • Gleighton
Je openGL drivers hebben de geest gegeven. Met die 'nieuwe drivers' bedoel je daarmee dat je pas na het installeren van die drivers dit probleem hebt gekregen?
  • Da_maniaC
  • Laatst online: 28-09 20:10
Da_maniaC
a.k.a. The Sequenz Pounder
Heb je die videokaart pas net?
Ik weet dat vanaf een bepaalde nieuwe driver versie deze games niet meer lijken te werken in ieder geval.
Wanneer je dan een game profile tool installeerd voor nvidia kaarten werken deze ineens weer wel.
Volgens mij heette deze tool nHancer.
Als je deze installeerd en de profiles voor alle MOHAA games aan zet zou het weer moeten werken.
Inventory | Instagram: @sequenzpounder | http://www.zdaemon.org | ZDaemon! Client/Server port for DOOM!
  • MensionXL
MensionXL
Optimaliseren!
Dit heet inderdaad nHancer. :)
Ik had hetzelfde probleem & dat heb ik opgelost door de Driver Extension Limit aan te passen (Dec -> Hex)
Hoe? Installeer (idd) nHancer & selecteer tijdens de installatie voor het inladen van alle SLI-profielen.
Scroll daarna in de profielen naar MOH:AA & check even wat daar aan het eind van de regel bij ExtLimit: xxxx staat. Wanneer daar bv 4520 staat moet je dit veranderen in 11A8.
Dus click MOH:AA even aan/maak hem blauw > ga naar "Options" & activeer "Allow override of predefined settings" > ga dan naar "Settings" (rechter kant schermpje) > selecteer "Compatibility" > activeer "Override" bij "Driver extension limit" & enter 11A8 > ALT-F4/Exit > klaar.
Uit: \[MOHAA:S] Game crashed tijdens opstarten
Dit zou het dus moeten oplossen. ;)
Goedkoop bellen via VoIP
nHancer heeft gewerkt, heel erg bedankt ;)
Mvg,
Roland
  • PromoX
  • Laatst online: 11-10 17:34
PromoX
Flying solo
Voor de volledigheid nog even een tikje richting Spielerij - Problemen & Vragen.
And I'm the only one and I walk alone.
