[SETI@Home] hitparade van 10 november Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
damnit souped up stats :?
toch belangrijk genoeg voor een nieuwe post met alleen wat nieuws van het front
nock yourself out ;)
10 Nov 2009 22:58:34 UTC
Today's Tuesday - that means we had our normal weekly maintenance outage, and we're recovering from that now. Outside of the normal database compression, backup, and log rotation type tasks we also took care of the following:
1. Replaced the faulty drive on thumper (the primary science database server). This system is on Sun Service so such hardware failures are trivial. A drive fails, we call Sun, they send us a new drive right away, we plop it in, we send back the old drive, done. However there are still nagging problems on thumper at the OS/database level that still require our attention (a corrupt row in the Astropulse signal database and that funky root/RAID configuration that can only be fixed during a clean OS install).
2. Upgraded mysql on both the master and replica servers (mork and jocelyn) to version 5.1.37. This was finally made available in the Fedora distros and from what I've been told may fix those unload/reload formatting bugs. While we were at it, we yum'ed up pretty much everything.
3. Rebooted mork and ptolemy to pick up crash-dump parameters for the kernels. We were going to install debug versions of the kernels but Jeff was having odd results with that while testing one on his desktop, so we're holding off for now. Rebooted jocelyn to pick up a new kernel as well.
That's about it for the outage. Recovery will continue for a while. I'm rebuilding the replica mysql database right now using the dump from today. When that's finished we'll start up the replica (maybe tomorrow morning).
Speaking of tomorrow morning, it's a holiday (Veteran's Day), so I won't be up at the lab (probably just doing the usual "check in from home every few hours and tweak this and that").
- Matt
10 Nov 2009 0:24:48 UTC
Our master mysql database server (mork) crashed on Sunday. The first crash when we brought mork on line way back when was a "fluke" - the crash a few weeks ago was explainable (or so we thought) - but now we're in the realm of "grave concern" about this particular server. However, the result of each crash is just an annoying chunk of downtime - the actual data remain intact after recovery, and recovery goes along without too much ado. Maybe we have just been lucky so far. I could see a flat out crash being a bit more disastrous.
Eric did the remote work of initial and post-reboot cleanup, Dan actually came up to the lab to physically power cycle the machine, which Jeff walked him through over the phone. I assumed we'd all just wait until the next day when we're all back at the lab to set things right (after all, we've have longer unexpected outages before). When I returned from prior obligations to find the projects up I was pleased by the heroic effort. Still, I quickly noticed that the splitters were in a funny state which required my intervention or else we would have immediately run out of work to send out, so I fixed all that.
Anyway, we'll have to do some extra recovery tasks tomorrow during the regular outage. This will include putting a debug kernel on mork and some other crash-test stuff that may hopefully give us clues if mork decides to disappear again.
- Matt
grass460 :w :w naar iedereen
`t gaat lekker daar de laatste tijd,het is iedere keer wat met die servers ! ! :(
maar gelukkig heb ik voor me }:O nog een baal of 5 op de hooizolder liggen dus die kan nog tot het weekeinde vooruit ! ;)
iedereen er veel sterkte mee ! !
en voor deze jongen ; die gaat ook :O
  • APClll
  • Laatst online: 11-11 23:33
APClll
FP ProMod
[DPC] Team Grazzie
Hierbij ben ik zo vrij om toch even het bewijs te posten dat we werkelijk statsloze stats hebben vandaag ;)
Meestal is het juist op dat soort dagen dat er iets fout gaat, waarbij het nodig is dat iemand ter plekke de brokken kan opruimen :/
DPC SETI@Home hitparade van 10 november 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 0 / 1.083 (0,0 %)
posdailymembertotal
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.361.753[DPC] hansR0(-)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.297.054[DPC]TeamGrazzie0(-)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.852.707Searchy! Internet Services V.O.F.0(-)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.652.452Sp@ceNv@der0(-)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.328.791[DPC] Switch0(-)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.098.974o25o & Dharkon0(-)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.030.259Ensign Wildfire0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.328.792Team_Elteor_Borislavj0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.834.019F@stmem0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.605.355[DPC]Spinpoint0(-)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.501.734AmeComputers0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.373.923Jan Zandvliet & x-RaY990(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.179.578Mr Beamer0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.810.651Tijntje0(-)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.747.664dpc_kluizenaar0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.723.551[DPC]Division_Brabant0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.607.048[DPC] ray0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.598.895[DPC]Team Zuid-Holland0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.328.909Jox4440(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.300.047Berkie0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.161.944Dadoke0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.140.370visvogel0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.138.619Speedy67 & Friends0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.088.439Quark0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.054.609Override0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
More...
Teams Daily Top 15
posdailyteamtotal
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.318.624.311SETI.USA0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)203.459.307BOINC@AUSTRALIA0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)202.211.042Phoenix Rising0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)195.829.667Ars Technica0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)190.011.842Amateur Radio Operators0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)188.244.640U.S.Air Force0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)184.395.176BOINC.Italy0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)182.578.061BOINC@Poland0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)171.392.620Dutch Power Cows0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)167.125.236UK BOINC Team0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)164.122.235Universe Examiners0(-)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)160.003.784AUSTRIA - NATIONAL - TEAM0(-)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)154.989.569Elite Games0(-)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)153.316.569BOINC SETI@home RUSSIA0(-)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)152.841.908Team NIPPON0(-)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)140.371.744Boone Community School District - Iowa0(-)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant596.27101-09-2009
2.[DPC]TeamGrazzie553.05604-01-2008
3.chelloo.com261.22709-01-2008
4.[DPC]DeApen190.21819-10-2009
5.Team_Elteor_Borislavj186.12006-10-2009
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • Herby
  • Laatst online: 17-01-2022
Herby
Stalknecht
Ok ik zal het nog 1 keer voordoen medeboeren. Het is vandaag een statloze dag, jullie hebben dus niets te doen. Dit betekend dat jullie verplicht zijn hier te gaan posthoeren :+
Tradities moet je eren ;)
Compromis? Hoezo heb ik het mis dan?! | Geluk = gelul met een K | з=(•̪●)=ε
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Herby schreef op woensdag 11 november 2009 @ 16:52:
Nou, posthoeren zou ik 't niet willen noemen... Feit is gewoon dat 't op een statsloze dag drukker hoort te zijn dan op een normale dag.
Dat dat een traditie is, helemaal mee eens :Y)
Maar om deze post nog ietwat nuttig te maken:
Results ready to send 78,834
Er is dus voldoende werk én alle servers draaien zoals het hoort. Hopelijk was dit dus de laatste statsloze dag van 't jaar B)
  • grass460
grass460
laten we hopen dat het daar dan bij blijft
maar gezien het feit dat de servers er zowat ieder weekend uit liggen, heb ik daar weinig hoop op
we gaan er gewoon vanuit dat het niet zo is
