Er is vandaag een nieuwe beta firmware uitgekomen die hier te downloaden is.
http://dune-hd.com/firmware/
Changes since
091
02
3_1444:
- Added more conveniency for working with subtitles and audiotracks during
file and DVD playback:
- Added the setting "Misc / Playback / Enable subtitles by default for
files" which allows to choose one of the following settings:
- "No" -- do not use subtitles by default.
- "Yes" -- always use subtitles by default if any subtitles exist
(internal or external).
- "Internal only" -- if internal subtitles exist, use them by
default.
- "External only" (default) -- if external subtitles exist, use them
by default.
- Added the setting "Misc / Playback / Default subtitles preference"
with choices "Internal" and "External" (default), which controls which
kind of subtitles have priority if "Enable subtitles by default for
files" is set to "Yes" and both internal and external subtitles exist.
- Added the setting "Misc / Playback / Quick toggling of single
subtitles" (enabled by default), which enables special behavior of
SUBTITLE RC button when there is only one subtitles track: instead of
showing the usual subtitles menu, the SUBTITLE RC button allows to
quickly toggle this single subtitles track (select / deselect it). To
enter the subtitles setup, press SUBTITLE and then SETUP.
- Added a new possibility to conveniently and quickly show/hide the
currently selected subtitles track (even if there are multiple
subtitles) just by pressing the RC button "D" (blue).
- When a subtitles track is selected, the "D" RC button toggles the
visibility of the currently selected subtitles.
- When selecting a subtitles track from the subtitles menu, the "D"
RC button allows to select the subtitles track but hide it
initially (until the "D" RC button is pressed during playback to
show the subtitles).
- Added the setting "Misc / Playback / "ENTER" closes subtitles/audio
menu" (enabled by default). When enabled, selecting a track from the
menu of available subtitles/audio tracks (by pressing "ENTER" RC
button, or also "D" RC button for subtitles), automatically closes the
menu (instead of keeping it shown).
- Added bookmarks functionality also for file playback (previously was
worked only for DVD playback).
- Bookmarks work similarly to how they work for DVD playback: when
stopping playback of a file, the current position is remembered and
then automatically resumed when the file is played again; the bookmark
is automatically deleted when the file is played till the very end;
bookmarks are remembered for up to ~2
00 files.
- NOTE: you can press "
0" (jump to
0%) to quickly start file playback
from the very beginning, if bookmark was used.
- NOTE: there is no yet ability to disable bookmarks or confirm bookmark
usage, possibility to review recent bookmarks, etc.
- NOTE: still no support for generic Blu-ray bookmarks (only standard
bookmarking possibilities provided by some Blu-ray discs on their own
are supported).
- Added zoom functionality for photo viewer.
- Instructions:
- Use P+/P- to zoom-in/zoom-out.
- Use arrows to scroll through the zoomed picture.
- Use ZOOM to toggle through "fit to screen", "pixel to pixel", and
"custom" zoom modes.
- NOTE: Any zoom action shows ZOOM information box, which is
automatically hidden after some period of user inactivity. Press
ENTER or RETURN to hide it immediately.
- NOTE: Any zoom action pauses the slideshow. To resume the
slideshow, press PLAY.
- NOTE: When working with photos having very high resolution (much
bigger than FullHD 192
0x1
08
0), photo viewer initially loads photos
with a reduced resolution (minimal resolution which is enough to
ensure excellent photo quality on FullHD display, in order to speedup
things); after zooming into the picture, photo viewer initially shows
the already loaded version of the picture (with reduced resolution),
and then automatically loads and shows the version of the picture with
full resolution in background (so it may take some seconds to show the
best quality photo in zoom mode).
- Added time search (go to HH:MM:SS) functionality also for file playback
and DVD playback (previously was provided only for bluray playback, while
for file/DVD playback it was only possible to use +/-1
0sec/1min/1
0min
navigation).
- Instructions:
- Press SEARCH, enter HH:MM:SS, then press ENTER.
- When entering HH:MM:SS, the following RC buttons are available:
ENTER, RETURN, CLEAR, LEFT, RIGHT.
- NOTE: the "Quick Play" feature is still available, the same way as
before: quickly press SEARCH, then PLAY.
- Added more font sizes for text subtitles (file playback) in addition to
"small" and "medium": "large" (+25%), "x-large" (+5
0%), "xx-large"
(+1
00%).
- NOTE: This feature is intended primarily for relatively small screens
(or for relatively big viewing distance).
- Added a possibility to switch between Internet Radio stations, IPTV
channels, or other streamable media (where time search is not supported)
via P+/P- buttons. Instructions:
- Launch the playlist with streamable media sources in the usual way,
then use P+/P- buttons instead or in addition to the usual NEXT/PREV
buttons.
- Various playback and file format compatibility improvements:
- Performance of network playback from SMB servers further improved
(effective data transfer rate is now up to 2
0% bigger, and may be even
comparable to NFS, so even playback from problematic SMB servers
should work better now).
- Bugfix: specific Bluray images could not be played properly.
- Bugfix: specific DVD-Video discs with MPEG audio streams could not be
played properly.
- Bugfix: specific DVD-Video discs could not be played properly.
- Bugfix: playing TS files in a loop (more than 4
0 repeats) could cause
playback crash or hangup.
- General/miscellaneous improvements:
- Added more menu languages: Italian, Romanian, Spanish. Some other
languages updated/improved.
- Added a warning when the user attempts to choose non-recommended
settings in the "System" setup section.
- Improvement: FTP server and SMB server applications running on
Dune
consume less processing power during playback now (their "nice" level
increased).
- Improvement: switching directly to the main menu in file browser (via
RC button STOP/REPEAT/TITLE/TOP-MENU) works slightly faster now.
- Change: "IPTV" and "Internet Radio" items are now always shown on the
main screen when they are enabled in the "Applications" setup section
(even if their configuration is missing). To remove these items from
the main creen, disable them in the setup.
- Bugfix: setting "HDMI audio" to "off" caused wrong colorspace on HDMI
video output (purple/absent/distorted picture).
- Bugfix: after playing a video/music file from UPnP server and then
returning to file browser, an empty folder content could be shown in
specific rare cases.
- Bugfix: initialization of System Storage during firmware update could
not work for partitionless USB flash drives.
- Bugfix: system storage could not work properly in some cases after
putting the player into standby.
- Bugfix: emergency optical disc eject (holding EJECT during player
boot) did not work in some cases.
- Improvement: optical discs never spinned down in some cases. Now, when
not used, they should spin down in all cases (sometimes on some
timeout of up to 2 minutes).
- Various "
dune_folder.txt" mechanism improvements:
- Added support for images files not only in
Dune-specific AAI file
format, but also in BMP, PNG, JPG, and GIF formats.
- NOTE: For BMP and PNG formats (as well as AAI), transparancy and
alphachannel are supported.
- NOTE: The performance of reading images from various file formats
may differ, depending on the exact file format, image resolution,
and media source kind (e.g. local or network disk). In most cases,
AAI and BMP are the recommended formats having the best
performance. If you need a standard and widely used image file
format with tranparancy/alphachannel support and good performance
on
Dune, use BMP.
- Added progress indication during loading of custom background image
when image loading takes a while (could take place e.g. when loading
FullHD 192
0x1
08
0 background from a network media source).
- Added a possibility to show just icons w/o captions (filenames) below
them. Syntax:
- "paint_captions = no" (default is "yes").
- Added a possibility to hide the "path box" (the box showing the path
to the current folder at the top of the screen). Syntax:
- "paint_path_box = no" (default is "yes").
- Added a possibility to hide the scrollbar. Syntax:
- "paint_scrollbar = no" (default is "yes").
- Added a possibility to hide the "help line" ("CONTROLS: ..." text at
the bottom of the screen). Syntax:
- "paint_help_line = no" (default is "yes").
- Added a possibility to hide the "icon selection box" (a frame around
an icon indicating that the icon is selected).
Syntax:
- "paint_icon_selection_box = no" (default is "yes").
- Added a possibility to not paint the shaded background for the
"content box" (the area listing icons). Syntax:
- "paint_content_box_background = no" (default is "yes").
- Added a possibility to alter the location and internal padding for the
- "content_box_x = ..." (>=
0, -1 means default = auto).
- "content_box_y = ..." (>=
- "content_box_width = ..." (>
- "content_box_height = ..." (>
- "content_box_padding_left = ..." (>=
0, default = 2
0).
- "content_box_padding_top = ..." (>=
0, default = 2
0).
- "content_box_padding_right = ..." (>=
0, default = 2
0).
- "content_box_padding_bottom = ..." (>=
0, default = 2
0).
- Added new options for altering the way custom background is painted.
Syntax:
- "background_order = first/last". Here:
- "first" means paint custom background before "path_box",
"content_box", and "help_line" (i.e. under these elements).
- "last" (default) means paint custom background after these
elements (i.e. over them).
- "optimize_full_screen_background = yes" (default is "no"). "yes" is
reasonable to specify in order to slightly improve the performance
in the following cases:
- Custom background image is full-screen (192
0x1
08
0) solid image
(w/o transparent pixels).
- "background_order = first".
- Added a possibility to paint a custom scrollbar using a user-defined
image file. Syntax:
- "scroll_path = "
- "scroll_x = ..." (>=
- "scroll_y = ..." (>=
- "scroll_height = ..." (>
- Added a possibility to paint custom "mark" icons (icons used when
marking files via SELECT RC button, e.g. to select items for the
playlist) using a user-defined image file. Syntax:
- "mark_path = "
- "mark_dx = ..." (-96
0..96
0)
- "mark_dy = ..." (-54
0..54
0)
