Binnenkort verkrijgbaar en er is nog geen topic over. Bij deze wat meer informatie.
Website fabrikant
Dune HD Base 3.0
Dune HD Base 3.0 is the most affordable solution for Full HD (1080p) video playback based on Sigma Designs 8642 platform with internal HDD. Includes a comprehensive set of connectors: three USB 2.0 ports (one front, two back), eSATA port, Ethernet 100/1000(*) Mbit/s, HDMI 1.3, S/PDIF (optical and coaxial), 7.1 analog audio, 2.0 analog audio, component video, composite video.
Main features:
SATA HDD compartment for fast and easy HDD exchange
Playback of full Blu-ray structures from HDD and network (with Blu-ray menu, BD-J, BonusView, BD-Live)
Playback of video, music, photos from any media source (HDD, PC, NAS, etc)
Optical disc formats (when using an external optical drive): data discs (CD/DVD/BD) (MP3, JPEG, etc), Audio CD (PCM/DTS), DVD-Video (retail and user-authored discs), Blu-ray (user-authored discs)
Support for modern video file formats (MKV, H.264, VC1, etc) with very high bitrate (up to 50 Mbit/s and higher)
Dune Network Playback Accelerator: special optimizations ensuring best-in-class network playback performance for the Sigma Designs 864x platform and enabling smooth playback of any supported kind of media content via any network protocol (including NFS and SMB) in both 100 Mbit/s and 1000 Mbit/s networks.
Dimensions: 420 mm (width) x 262 mm (depth) x 50 mm (height)
Specification:
Processor: Sigma Designs 8642
Memory: RAM 512 MB, system Flash: 1 GB+, BD-Live: 1 GB+
Media sources: internal HDD (SATA 3.5"), external HDD (eSATA, USB), external optical drive (eSATA, USB), USB devices (USB flash drive, USB card reader, etc), PC and NAS in local network (SMB, NFS, UPnP, HTTP)
Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264
Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, Blu-Ray-ISO, BDMV, DVD-ISO, VIDEO_TS
Video output modes: wide range of supported modes and resolutions, including 23.976p, 24p, PAL, NTSC
Audio codecs: AC3 (Dolby Digital), DTS, MPEG, AAC, LPCM, WMA, WMAPro, EAC3 (Dolby Digital Plus), Dolby True HD, DTS HD High Resolution Audio, DTS HD Master Audio, FLAC, multichannel FLAC
Audio file formats: MP3, MPA, M4A, WMA, FLAC, WAV, DTS-WAV, DTS, AC3, AAC
Pass-through and decoding of HD audio formats, including Dolby TrueHD and DTS HD Master Audio
Picture file formats: JPEG, PNG, BMP, GIF
Subtitle formats: SRT, SUB, text/SSA/ASS (MKV), VobSub (MP4), PGS (full Blu-ray mode)
Playlist file formats: M3U, PLS
Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (readonly)
Other features:
Upscaling: high-quality upscaling and deinterlacing of DVD and other SD content to HD resolution (up to 1080p)
Access to network: browser of network shares (SMB, UPnP), user-defined shortcuts to network shares (SMB, NFS), links to HTTP media streams
NAS function: SMB and FTP access from network to the player's attached storage devices
IPTV: direct playback and recording of multicast IPTV streams (raw-UDP and RTP-over-UDP, SD and HD)
Internet radio: HTTP/MP3
Powerful file manager (copy, move, delete, rename, etc), built-in FTP and SMB file server (NAS function)
Photo viewer: slide-show function, picture transition eff ects, picture rotation
Playlists: music/photos/video, user-defined and automatically generated playlists, repeat and shuffle
FullHD-quality, fast, convenient, customizable interface (with covert-art and icon browsing support)
Future (free f/w upgrade): Flash Lite 3 support
Future (free f/w upgrade): Netflix support (for the USA market)
Options:
Wi-Fi 802.11n, internal 2.5" SATA HDD
Future option (Q1 2010): RF remote, a part of your future affordable Smart Home system
Dune BD Prime 3.0
Dune BD Prime 3.0 is the most comprehensive solution for Full HD (1080p) video playback based on Sigma Designs 8642 platform with a buit-in Blu-ray drive and support for retail Blu-ray discs.
Includes: three USB 2.0 ports (one front, two back), eSATA port, Ethernet 100/1000(*) Mbit/s, HDMI 1.3, S/PDIF (optical and coaxial), 7.1 analog audio, 2.0 analog audio, component video, composite video.
Main features:
Playback of retail Blu-ray and DVD discs
Optical disc formats: data discs (CD/DVD/BD) (MP3, JPEG, etc), Audio CD (PCM/DTS), DVD-Video (retail and user-authored discs), Blu-ray (retail and user-authored discs)
Specification:
Other features:
Options:
Aanbevolen firmware release:
Dune prime 3.0:
091229_1411_beta
Dune Base 3.0:
091229_1411_beta
In combinatie met de volgende settings voor optimaal kijk plezier:
Setup / Misc / System:
"Experimental Gigabit support" - DISABLED
"Fast disk access" - ENABLED
"Blu-ray playback improvents"- ENABLED
"Fast SMB access"- DISABLED
Setup / Audio:
"HDMI Audio" - ENABLED
Veel gestelde vragen
Q Kan de Dune Base 3.0 ook Blu-Ray films weergeven?
A Ja. Zowel in ISO als BDMV stuctuur formaat.
Q Het beeld speelt schokkerig af wanneer ik via het netwerk stream. Hoe kan dat?
A Waarschijnlijk is doorvoersnelheid van data naar de Dune te traag en is er dus een netwerk probleem. Je kunt dit nakijken daar naar een, liefst groot, bestand te gaan middels je Dune en te klikken op de POPMENU toets van je afstandbediening. Voer hier de read test uit. Een doorvoersnelheid tussen de 7.5 en 8.5 moet volstaan voor het afspelen van alle soorten formaten.
Q Wat voor soort externe drives kan ik gebruiken?
A Alle drives met een USB of eSata aansluiting zijn te gebruiken. Mocht je aan de Dune Base een bluray drive willen aansluiten, dan is dat ook geen probleem. Echter kunnen hiermee geen retail disks worden afgespeeld.
Q Kan ik ook een USB hub aansluiten, zodat ik de beschikking heb over meerdere USB poorten?
A Geen pobleem
Q Het lukt me niet om bestanden te delen met mijn Dune.
A Voor het juist instellen van bestanden delen via SMB verwijs ik naar de NMT wiki voor Windows Vista en Windows 7
Q Ik kan geen ISO, video_ts etc. bestanden afspelen via mijn netwerk.
A Zorg dat je Dune via SMB of NFS is verbonden met je netwerk. Upnp is hier niet voor geschikt.
Q Ik kan vanaf mijn PC geen bestanden wegschrijven naar mijn NTFS geformateerde schijf die aan mijn Dune hangt. (intern / extern)
A Klopt. Wegschrijven naar NTFS geformateerde schijven wordt (nog) niet ondersteund. Je dient de hardeschijf te formateren in EXT2/EXT3 formaat. Dit kan middels de Dune. Overigens kun je wel bestanden van deze schijven kopiëren naar je PC.
            Website fabrikant
Dune HD Base 3.0
Main features:
Specification:
Other features:
Options:
Dune BD Prime 3.0
Main features:
Specification:
Other features:
Options:
Dune prime 3.0:
091229_1411_beta
Dune Base 3.0:
091229_1411_beta
Setup / Audio:
A Geen pobleem
[ Voor 114% gewijzigd door MrX_Cuci op 25-02-2010 23:16 ]
