[SETI@Home] hitparade van 17 juni Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 24-11 21:58
APClll
FP ProMod
[DPC] Team Grazzie
Wat is dat nu? Zit er niemand meer de hele dag te F5-en op de stats-pagina zelf en is niemand meer geinteresseerd in de DPCH zelf? Niemand die hier de nieuwe leden wil feliciteren? Of zit iedereen braaf op uw statsposter te wachten?
In dat geval: hier zijn de stats van vandaag :9
*O* Welkom Sypheron *O*
*O* Welkom picasso *O*
*O* Welkom wrovers *O*
17 Jun 2009 20:16:11 UTC
I've been busy. Almost too much to write about, none of it all that interesting in the grand scheme of things, so I'll just stick to recent stuff.
Our main problem lately has been the mysql database. Given the increased number of users, and the lack of astropulse work (which tends to "slow things down"), the result table in the mysql database is under constant heavy attack. Over the course of a week this table gets severely fragmented, thus resulting in more disk i/o to do the same selects/updates. This has always been a problem, which is why we "compress" the database every tuesday. However, the increased use means a larger, more fragmented table, and it doesn't fit so easily into memory.
This is really a problem when the splitter comes along every ten minutes and checks to see if there's enough work available to send out (thus asking the question: should I bother generating more work). This is a simple count on the result table, but if we're in a "bad state" this count which normally takes a second could take literally hours, and stall all other queries, like the feeder, and therefore nobody can get any work. There are up to six splitters running at any given time, so multiple this problem by six.
We came up with several obvious solutions to this problem, all of which had non-obvious opposite results. Finally we had another thing to try, which was to make a tiny database table which contains these counts, and have a separate program that runs every so often do these counts and populate the proper table. This way instead of six splitters doing a count query every ten minutes, one program does a single count query every hour (and against the replica database). We made the necessary changes and fired it off yesterday after the outage.
Of course it took forever to recover from the outage. When I checked in again at midnight last night I found the splitters finally got the call to generate more work.. and were failing on science database inserts. I figured this was some kind of compile problem, so I fell back to the previous splitter version... but that one was failing reading the raw data files! Then I realized we were in a spate of raw data files that were deemed "questionable" so this wasn't a surprise. I let it go as it was late.
As expected, nature took its course and a couple hours later the splitter finally found files it could read and got to work. That is, until our main /home account server crashed! When that happens, it kills *everything*.
Jeff got in early and was already recovering that system before I noticed. He pretty much had it booted up just when I arrived. However, all the systems were hanging on various other systems due to our web of cross-automounts. I had to reboot 5 or 6 of them and do all the cleanup following that. In one lucky case I was able to clean up the automounter maps without having to reboot.
So we're recovering from all that now. Hopefully we can figure out the new splitter problems and get that working as well or else we'll start hitting those bad mysql periods really soon.
- Matt
DPC SETI@Home hitparade van 17 juni 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 113 / 1.018 (11,1 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.032Searchy! Internet Services V.O.F.10.197.626(4)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)15.156[DPC] Switch9.739.765(5)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)13.551[DPC] hansR15.818.924(1)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)7.533F@stmem2.685.890(8)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)6.728Sp@ceNv@der12.434.491(3)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.296[DPC]TeamGrazzie13.490.967(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)6.067o25o & Dharkon5.209.909(6)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)6.025Ensign Wildfire3.666.780(7)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)5.398dpc_kluizenaar890.667(27)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)4.921seridan605.381(36)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)3.939Intrud3r183.846(98)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.988muppet99289.136(69)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)2.167AmeComputers1.993.636(12)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)1.982RWaC57.210(186)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.906Rene197039.632(239)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif29)1.891Nomen99.581(143)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.850Jox4441.016.457(25)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif34)1.812bpenris544.203(39)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.719Rydo873.728(28)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)1.639Falcon10372.821(51)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.538Mr Beamer2.030.461(11)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)1.503Team_Elteor_Borislavj726.884(30)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.452ERBrouwer190.577(95)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.400Andre Barnier37.807(246)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif82)1.244Edwin van der Geest482.664(41)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)1.228HellBringer113.331(128)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.195apa328.378(66)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)968Joey van den Berge356.544(55)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)951evildutchman73.783(165)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)854Ignitions465.551(44)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.818.924[DPC] hansR13.551(3)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.490.967[DPC]TeamGrazzie6.296(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.434.491Sp@ceNv@der6.728(5)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.197.626Searchy! Internet Services V.O.F.18.032(1)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.739.765[DPC] Switch15.156(2)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.209.909o25o & Dharkon6.067(7)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.666.780Ensign Wildfire6.025(8)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.685.890F@stmem7.533(4)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.919[DPC]Spinpoint0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.364.872[DPC]Trancemaus0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.030.461Mr Beamer1.538(21)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.993.636AmeComputers2.167(13)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.875.810Jan Zandvliet & x-RaY99608(35)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.528.357[DPC]Team Zuid-Holland636(33)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.469.490ray283(54)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.421.453Tijntje753(32)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.137.232Speedy67 & Friends0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.121.772visvogel60(91)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.096.261Berkie605(36)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.078.741Quark74(90)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.024.923Override104(77)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.016.457Jox4441.850(17)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)982.357Dadoke431(44)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)890.667dpc_kluizenaar5.398(9)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)873.728Rydo1.719(19)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)786.175MaGNeT aka BlueTooth76612(34)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)726.884Team_Elteor_Borislavj1.503(22)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.238.319SETI.USA1.099.258.030(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)236.387Team Art Bell214.204.466(17)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)217.757BOINC@AUSTRALIA158.050.764(23)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)217.316Elite Games118.393.334(36)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)216.186Brasil [SETIBR]67.676.655(53)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)213.909BOINC@Poland138.782.659(30)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)179.376U.S.Air Force157.833.416(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)178.615Amateur Radio Operators157.076.588(26)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)165.057Dutch Power Cows143.467.674(27)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)160.053Boone Community School District - Iowa104.219.551(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)158.086Planet 3DNow!120.734.105(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)157.073UK BOINC Team140.758.056(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)156.612Ars Technica158.937.169(22)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)151.750Team NIPPON124.132.070(34)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)146.711RoEduNet75.409.701(49)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)145.237BOINC.Italy157.939.421(24)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.099.258.030SETI.USA1.238.319(1)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)175.100.751Phoenix Rising240.698(20)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)167.066.275Canada258.687(18)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)158.937.169Ars Technica156.612(32)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)158.050.764BOINC@AUSTRALIA217.757(22)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)157.939.421BOINC.Italy145.237(35)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)157.833.416U.S.Air Force179.376(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)157.076.588Amateur Radio Operators178.615(27)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)143.467.674Dutch Power Cows165.057(28)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)140.758.056UK BOINC Team157.073(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)139.421.071Universe Examiners120.719(42)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)138.782.659BOINC@Poland213.909(25)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)131.521.016AUSTRIA - NATIONAL - TEAM132.223(39)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)127.625.693BOINC SETI@home RUSSIA131.617(40)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)124.259.933PC Perspective Killer Frogs117.303(44)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)124.132.070Team NIPPON151.750(33)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
Mijlpalen
madmax24080.000
Racemol40.000
jappe8.000
MRCL4.000
Ralph1.000
When do you get them
TeamAverageDays
BOINC.Italy178.652662
Amateur Radio Operators180.264672
Ars Technica178.276695
Team MacNN139.3461.152
Nieuwe Leden
Sypheron232
picasso4.984
wrovers81
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ha, in mijn enthousiamse wilde ik blijkbaar de stats twee keer posten :D
Na de auto-image-check drukte ik blijkbaar te snel of te langzaam op "enter"
Er is iets fout gegaan. Probeer het later nog eens, of ga terug.
Dubbelpost: het bericht is identiek aan uw laatst geplaatste bericht
(interne identificatie: topic::new_message::double_post)
Hieronder vind je de belangrijkste ingevoerde waarden terug, met een simpele copy&paste kan je deze weer gebruiken.
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
welkom iedereen
en de mijlpalen ook proficiat
btw krijg ik mijn wu niet meer geupload iemand anders ook dit probleem ?
  • Xaverius
  • Laatst online: 05-09 22:53
Acht plekken omhoog in de daily, ik ben trots! Gefeliciteerd teamgenoten, morgen weer? ;)
En een warm welkom aan de nieuwe leden, dat jullie galacatische weides veel vruchten mogen afwerpen. *O*
Doet wat met CLP, loopt niet meer hard 😢
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
grass460 schreef op donderdag 18 juni 2009 @ 22:09:
Hier ook moeilijkheden, zowel met up- als downloaden van WU's.
18-6-2009 23:14:39|SETI@home|Started upload of 30mr09ab.10053.2526.3.8.146_2_0
18-6-2009 23:14:53|SETI@home|Finished upload of 09mr09aa.25072.7025.6.8.14_0_0
18-6-2009 23:15:01||Project communication failed: attempting access to reference site
18-6-2009 23:15:01|SETI@home|Temporarily failed upload of 30mr09ab.10053.2526.3.8.146_2_0: connect() failed
18-6-2009 23:15:01|SETI@home|Backing off 37 min 35 sec on upload of 30mr09ab.10053.2526.3.8.146_2_0
18-6-2009 23:15:02||Internet access OK - project servers may be temporarily down.
Maar als de servers down zijn, waarom kan ik dan 20 seconden eerder wel werk uploaden :?
Volgens de stats zijn de servers gewoon draaiende.
[As of 18 Jun 2009 21:10:16 UTC
Program Host Status
download server 1 bane Running
download server 2 vader Running
upload server bruno Running
[ Voor 3% gewijzigd door APClll op 18-06-2009 23:22 ]
  • grass460
grass460
APClll schreef op donderdag 18 juni 2009 @ 23:21:
dat heb ik ook ja
18-6-2009 23:24:23 SETI@home Started upload of 10mr09ac.6383.511288.5.8.239_0_0
18-6-2009 23:24:46 Project communication failed: attempting access to reference site
18-6-2009 23:24:46 SETI@home Temporarily failed upload of 10mr09ac.6383.511288.5.8.239_0_0: HTTP error
18-6-2009 23:24:46 SETI@home Backing off 2 min 14 sec on upload of 10mr09ac.6383.511288.5.8.239_0_0
18-6-2009 23:24:47 Internet access OK - project servers may be temporarily down.
18-6-2009 23:25:30 SETI@home Computation for task 12mr09ad.29707.18477.4.8.57_0 finished
18-6-2009 23:25:30 SETI@home Starting 12mr09ad.29707.18477.4.8.60_0
18-6-2009 23:25:30 SETI@home Starting task 12mr09ad.29707.18477.4.8.60_0 using setiathome_enhanced version 608
18-6-2009 23:25:32 SETI@home Started upload of 12mr09ad.29707.18477.4.8.57_0_0
18-6-2009 23:25:54 Project communication failed: attempting access to reference site
18-6-2009 23:25:54 SETI@home Temporarily failed upload of 12mr09ad.29707.18477.4.8.57_0_0: HTTP error
18-6-2009 23:25:54 SETI@home Backing off 1 min 0 sec on upload of 12mr09ad.29707.18477.4.8.57_0_0
18-6-2009 23:25:55 Internet access OK - project servers may be temporarily down.
18-6-2009 23:26:55 SETI@home Started upload of 12mr09ad.29707.18477.4.8.57_0_0
18-6-2009 23:27:00 SETI@home Started upload of 10mr09ac.6383.511288.5.8.239_0_0
18-6-2009 23:27:11 SETI@home Finished upload of 12mr09ad.29707.18477.4.8.57_0_0
18-6-2009 23:27:15 SETI@home Finished upload of 10mr09ac.6383.511288.5.8.239_0_0
18-6-2009 23:27:35 SETI@home Sending scheduler request: To fetch work.
18-6-2009 23:27:35 SETI@home Reporting 5 completed tasks, requesting new tasks for GPU
