[SETI@Home] hitparade van 4 juni Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 00:11
APClll
FP ProMod
[DPC] Team Grazzie
Alles lijkt weer de goede kant op te gaan! De stats zijn weer heel én we mogen weer iemand verwelkomen!
*O* Welkom Jewest *O*
Bij gebrek aan tech_news (zou er dan écht helemaal niets fout gegaan zijn gisteren?) valt er verder niet zoveel te melden. Ik hou 't dus wat kort.
Afbeeldingslocatie: http://seticlassic.ssl.berkeley.edu/screensaver/images/screen_sm-3.0.gif
Maar wat zien we nu hierboven? Laten we het eens deel voor deel bekijken:
Vandaag kijken we naar de onderste grafiek. (dat 3D-landschap)
FREQUENCY-TIME-POWER GRAPH
Here is where you can observe the graphical representation of the fast fourier transforms as they are calculated. Frequency runs along the horizontal x-axis, power along the vertical y-axis and time along the in/out z-axis. Here you may note the difference between the different frequency resolution FFT's. For a resolution of 0.075 Hz you will notice that we only do 8 FFT's to cover our 107 seconds of data. This will look different than the 0.14 Hz resolution where we do 16 FFT's. Everytime we reduce the frequency resolution by 1/2 (doubling the bandwidth) we get twice the time resolution (we do twice the number of FFT's). At the final resolution of 1200 Hz, we get a time resolution of 0.008192 seconds which also means that we do a total of 131,072 FFT's just for this one graph! This allows detection of fairly short pulses, but the frequency measurement cannot be as precise, and the sensitivity to find continuous signals is reduced.
The colors you see in the graph signify absolutely nothing. They were used only for aesthetic purposes. We hope you enjoy them as much as we do.
A significant extraterrestrial signal may not be visible in this graph as it may be masked by all the natural noise around it. So, if you see something, don't get overly excited, it's probably just a strong source somewhere local, or a satellite passing overhead. On the average we look at the same part of the sky every 3 to 6 months, so it will get re-checked at that time for the same strong signal.
DPC SETI@Home hitparade van 4 juni 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 123 / 1.009 (12,2 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)22.990[DPC]TeamGrazzie13.292.420(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)22.194Searchy! Internet Services V.O.F.9.946.999(4)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.711[DPC] hansR15.640.267(1)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)21.488Sp@ceNv@der12.301.494(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)17.524[DPC] Switch9.590.852(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)15.193[DPC]NGS282.010(68)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)10.345Ensign Wildfire3.578.877(7)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)8.824AmeComputers1.956.495(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)8.566F@stmem2.591.593(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)6.331muppet99255.723(73)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)5.306Sylvester365.625(50)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)5.061Morpheus51.352(200)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)4.936dpc_kluizenaar808.759(28)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.629dr bommel702.721(30)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)4.504Override1.017.435(24)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)4.201o25o & Dharkon5.104.443(6)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.978Bram225.880(79)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.784Intrud3r145.788(107)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)3.742Team_Elteor_Borislavj680.664(31)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)3.537Mr Beamer1.998.749(11)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.157Rene197019.409(326)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.979ERBrouwer167.538(102)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)2.815Quark1.038.578(23)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.703Kick @sz11.235(400)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif18)2.698Wolfje666126.219(116)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.696Racemol34.010(251)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)2.465HellBringer93.682(141)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.402Joey van den Berge317.297(63)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif21)2.141apa298.933(67)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif15)1.834RonaldS222.843(81)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.640.267[DPC] hansR21.711(3)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.292.420[DPC]TeamGrazzie22.990(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.301.494Sp@ceNv@der21.488(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.946.999Searchy! Internet Services V.O.F.22.194(2)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.590.852[DPC] Switch17.524(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.104.443o25o & Dharkon4.201(16)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.578.877Ensign Wildfire10.345(7)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.594.179[DPC]Spinpoint275(71)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.591.593F@stmem8.566(9)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.363.633[DPC]Trancemaus0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.998.749Mr Beamer3.537(20)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.956.495AmeComputers8.824(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.862.597Jan Zandvliet & x-RaY991.489(37)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.518.726[DPC]Team Zuid-Holland956(53)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.456.800ray0(-)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.402.815Tijntje910(54)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.137.104Speedy67 & Friends0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.121.475visvogel0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.078.052Berkie449(61)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.038.578Quark2.815(23)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.017.435Override4.504(15)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)992.654Jox4441.736(32)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)966.628Dadoke1.319(42)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)856.594Rydo193(76)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)808.759dpc_kluizenaar4.936(13)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)776.582MaGNeT aka BlueTooth761.402(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)702.721dr bommel4.629(14)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.779.728SETI.USA1.081.259.392(1)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)381.667Nordlichter42.788.568(87)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)363.726OcUK - Overclockers UK215.425.993(15)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)362.499The Planetary Society222.655.640(14)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)325.660Canada163.433.234(21)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)303.336Brasil [SETIBR]64.740.316(55)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)292.327Elite Games115.189.598(36)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)282.349BOINC@Poland135.708.379(30)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)278.472Dutch Power Cows141.068.918(27)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)275.792U.S.Air Force155.025.087(24)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)269.953Boone Community School District - Iowa101.549.118(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)251.136Team Art Bell211.407.300(18)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)233.569Amateur Radio Operators154.758.281(25)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)222.143Ars Technica156.496.061(22)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)220.139Team Norway68.330.353(52)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)216.304BOINC.Italy155.632.364(23)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.081.259.392SETI.USA1.779.728(1)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)171.428.715Phoenix Rising410.605(18)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)163.433.234Canada325.660(23)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)156.496.061Ars Technica222.143(32)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)155.632.364BOINC.Italy216.304(34)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)155.025.087U.S.Air Force275.792(28)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)154.758.281Amateur Radio Operators233.569(31)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)154.310.225BOINC@AUSTRALIA408.211(19)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)141.068.918Dutch Power Cows278.472(27)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)138.593.770UK BOINC Team197.475(37)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)137.587.916Universe Examiners177.450(41)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)135.708.379BOINC@Poland282.349(26)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)129.764.748AUSTRIA - NATIONAL - TEAM168.772(44)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)125.417.973BOINC SETI@home RUSSIA193.046(39)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)122.606.754PC Perspective Killer Frogs175.464(42)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)121.886.369Team NIPPON214.551(35)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
Mijlpalen
dr bommel700.000
[DPC]NGS275.000
muppet99250.000
Bram225.000
Wolfje666125.000
whirlloqxan125.000
Morpheus50.000
Herrie10.000
Kick @sz10.000
base.sg8.000
B-BRAIN3.000
DangerPatter3.000
TDDOL2.000
Ralph500
Nick Pieters250
When do you get them
TeamAverageDays
Team MacNN137.9651.215
Nieuwe Leden
Jewest675
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
[ Voor 103% gewijzigd door APClll op 05-06-2009 00:11 ]
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
Welkom Jewest natuurlijk *O* *O* *O*
Tevens wil ik mededelen dat ik vanaf morgen op vakantie ben en mijn }:O doen vrolijk mee.
  • Black Piet
Veel plezier! Ik ben nog druk bezig om mijn tweede PC te voorzien van wat versie installaties...dus mijn tweede PC is ook nog even offline...
And welcom Jewest!
Mooooooeeeee......
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
@ Creator Boinc fijne vakantie
en welkom Jewest *O* *O*
WOW wat een berg mijlpalen congrats allemaal d:)b *O*
