[SETI@Home] hitparade van 8 mei Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 23:16
APClll
FP ProMod
[DPC] Team Grazzie
*O* Welkom hague_nl *O*
Als ik goed gekeken heb, zag ik dat we gisteren geen stats hadden en ook geen "laatste nieuws". Dus hierbij het laatste nieuws. Je moet tenslotte toch wat verzinnen om 't verhaaltje boven de stats wat op te vullen ;)
7 May 2009 22:03:43 UTC
I came in this morning and went about my normal chores, including checking the raw data pipeline. We have automated scripts to do most of the work, including one called "splitter_janitor" which finds files ready for deletion, takes some action, and mails me/Jeff the results. Well, I didn't get any mail. So I looked at the system in question, thumper, and found the script was hung. Some poking around led me to discover that thumper was having trouble mounting directories on server ewen (Eric's hydrogen study server, which actually crashed yesterday but came up again just fine). Well, other machines were mounting ewen just fine. So what gives?
Sometimes the automounter needs a kick, so I restarted that. No dice. I restarted nfs/nfslock to no avail either. Hunh. Around this time I noticed the primary master science database, also on thumper, had gotten wedged. Great. Eric/Jeff were brought into the fold but nobody had any great ideas as to what was wrong and therefore how to fix it. We started killing processes one by one, including the database engine itself, which could only be stopped with a kill -9 (which isn't optimal, but informix has always been perfect recovering from such ugly shutdowns). With an empty process queue we still had mounting problems.
Normally one of the first things to try is a reboot as this is easy and usually works, but we were loathe to reboot thumper since (as you might remember if you are an avid reader of these threads) that its root RAID has some funkiness where, even if it's healthy, will show up as degraded (and require a long resync) upon reboot. But we had no choice at this point, so we rebooted it, and sure enough the system booted just fine (and we could mount everything again). That's the good news, the bad news is that our fears were realized, and we're in the middle of another long painful root drive resync. The system is functional in the meantime, so really it's not that big a deal - it's just annoying, and perhaps a bit scary.
Well, that ate up my whole morning. Then moved onto my Powerpoint/PHP tasks until Bob noticed the science database load was strangely low. This led to more snooping around, finally finding that our system vader (where the assimilators run) was having trouble mounting bruno's disks (where the result files are). So we weren't inserting results, which explains the bored science database. I rebooted vader, which is much easier than thumper, and that broke another dam.
- Matt
DPC SETI@Home hitparade van 8 mei 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 82 / 992 (8,3 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)27.793[DPC]TeamGrazzie12.709.967(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)26.714Searchy! Internet Services V.O.F.9.426.249(4)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.020Sp@ceNv@der11.853.672(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)13.999[DPC] hansR15.241.023(1)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)8.737[DPC] Switch9.290.855(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)8.377dpc_kluizenaar634.595(31)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.278Ensign Wildfire3.395.053(7)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)7.429F@stmem2.395.347(9)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)6.304AmeComputers1.875.770(12)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)6.267Quark844.384(26)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)4.402o25o & Dharkon4.898.136(6)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)4.020Mr Beamer1.931.425(11)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.777ray1.366.000(17)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)3.723dr bommel598.623(34)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.258[DPC]NGS24.288(291)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)2.788Intrud3r101.442(133)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)2.581MaGNeT aka BlueTooth76748.759(28)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.573Doelloos42.643(219)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif32)2.528Berkie1.059.498(21)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)2.523bpenris519.289(38)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.515Jox444927.252(25)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)2.515trout284.647(66)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.506Override971.831(23)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.505Dr.Drax563.637(35)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.334ERBrouwer112.188(119)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.118Wolfje66657.674(175)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)2.106Tijntje1.372.592(16)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif29)1.818Patch27.681(271)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.760Bram181.288(91)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif35)1.752Vrank167.183(100)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.241.023[DPC] hansR13.999(4)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.709.967[DPC]TeamGrazzie27.793(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.853.672Sp@ceNv@der18.020(3)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.426.249Searchy! Internet Services V.O.F.26.714(2)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.290.855[DPC] Switch8.737(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.898.136o25o & Dharkon4.402(11)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.395.053Ensign Wildfire8.278(7)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.583.536[DPC]Spinpoint1.609(34)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.395.347F@stmem7.429(8)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.353.588[DPC]Trancemaus0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.931.425Mr Beamer4.020(12)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.875.770AmeComputers6.304(9)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.806.539Jan Zandvliet & x-RaY991.611(33)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.498.194[DPC]Team Zuid-Holland711(53)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.372.592Tijntje2.106(27)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.366.000ray3.777(13)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.135.675Speedy67 & Friends48(77)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.121.438visvogel23(82)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.059.498Berkie2.528(19)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)971.831Override2.506(23)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)931.945Dadoke752(50)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)927.252Jox4442.515(21)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)844.384Quark6.267(10)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)814.813Rydo0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)748.759MaGNeT aka BlueTooth762.581(17)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)673.789Psyed0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)640.307[DPC] Brainy0071.250(42)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.504.812SETI.USA1.041.807.555(1)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)346.122Phoenix Rising161.680.770(20)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)284.973Elite Games107.618.359(35)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)273.747OcUK - Overclockers UK208.189.714(15)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)268.814The Planetary Society214.818.143(14)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)239.579Canada156.046.898(21)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)229.561Team NIPPON117.156.769(34)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)222.487BOINC@Poland129.346.108(30)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)219.689Dutch Power Cows135.373.588(27)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)213.261Nordlichter33.476.281(107)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)206.472U.S.Air Force149.312.168(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)205.754Boone Community School District - Iowa96.128.894(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)201.330PC Perspective Killer Frogs118.867.869(33)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)198.827RoEduNet68.221.740(49)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)187.440Brasil [SETIBR]59.141.122(58)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)187.315Ars Technica151.720.283(22)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.041.807.555SETI.USA1.504.812(1)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)161.680.770Phoenix Rising346.122(19)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)156.046.898Canada239.579(23)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)151.720.283Ars Technica187.315(33)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)150.633.541BOINC.Italy183.536(34)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)149.746.065Amateur Radio Operators166.223(39)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)149.312.168U.S.Air Force206.472(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)145.676.033BOINC@AUSTRALIA352.365(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)135.373.588Dutch Power Cows219.689(26)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)134.074.439UK BOINC Team174.725(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)133.201.329Universe Examiners164.591(41)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)129.346.108BOINC@Poland222.487(25)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)126.030.619AUSTRIA - NATIONAL - TEAM136.460(47)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)121.009.081BOINC SETI@home RUSSIA164.855(40)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)118.867.869PC Perspective Killer Frogs201.330(30)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)117.156.769Team NIPPON229.561(24)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
Mijlpalen
Intrud3r100.000
HellBringer50.000
Edward de Vries8.000
mschol6.000
Nieuwe Leden
hague_nl81.874
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
Dank je voor het posten van de stats.
Van harte welkom hague_nl bij dit gezellige team *O* *O* *O*.
Tevens jullie ook met de mooie mijlpalen Intrud3r, HellBringer, Edward de Vries en mschol. d:)b
Goh is lang geleden dat TeamGrazzie op¨no1 heeft gestaan, mooi werk allen :Y)
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Verwijderd schreef op zaterdag 09 mei 2009 @ 20:00:
Ik sluit me bij de vorige spreker aan :P
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
hague_nl welkom
en proficiat mijlpalers
als je het zo leest blijven die servers bij seti een probleem, het is natuurlijk ingewikkelde materie!!
