[SETI@Home] hitparade van 26 maart Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 21:58
APClll
FP ProMod
[DPC] Team Grazzie
Deze keer beginnen we niet met een (geleend) verhaaljte. Nee, deze keer beginnen we met de belangrijke zaken. * APClll schraapt keel:
*O* Welkom Edward de Vries *O*
26 Mar 2009 20:25:02 UTC
So the focus is still on thumper, the science database/raw data server. Last night we finished resyncing all the root drives (a three drive mirror). We still have to do some swapping to install grub on the third and final drive - we'll do this during the outage next week. Until then we're officially resuming normal operations, at least at the server level. Phew. I started up several raw data transfer jobs since that's been backed up for a week.
Now we can turn our attention to the database. We're dumping the entire pulse table to a file so we can recreate the table in a larger set of db spaces. This is basically all you can do when you run out of extents - unload the table, then reload into new db spaces. I roughly estimate the unload will take at least 24 more hours.
Since we couldn't insert pulses until we got more extents, the assimilator queue grew fairly large. So why stop now? There's really no reason not to split/create new multibeam workunits - we can still insert workunits into the science database. So I started a single multibeam splitter if only to satisfy some workunit demand until we can assimilate again. Of course, if we can't assimilate, we can't delete - and we've been running low on space to store workunits. But being that we've been running only astropulse for a day that actually helped push a lot of ap workunits/results through the validation/assimilation/deletion queues, which in turn cleared up a fair amount of storage. So we're good for the moment, at least storage-wise (seems like even the one splitter is sensitive to the current heavy load on thumper).
Tomorrow is actually an official university holiday (the staff gets its one day of spring break). However, like always, Jeff, Eric, Bob and I will be poking and prodding at the servers remotely over the weekend.
- Matt
En waar doen we dit nu allemaal voor? Tja, lastig te zeggen. De een doet mee voor het nobele streven ooit groene mannetjes te vinden. De ander doet mee om zo hoog mogelijk in de stats te verschijnen. ;)
Maar, speciaal voor die eerste groep, eens een overzichtje van de Seti-resultaten tot nu toe.
page generated: 24 Mar 2009 15:50:22 UTC
Signals Already Found at Current Telescope Sky Position¹
Type        #   Multiplets²
Spikes    642      5
Gaussians 127      4
Pulses    219      2
Triplets  210      8
Stars³     0
¹ All signals previously found by SETI@home that fall within 0.0500 degrees of where Arecibo Observatory is currently pointing (coordinates taken 0 minutes ago). If we are recording data, these numbers will eventually increase.
² Multiplets are groups of signals of the same type seen over multiple different observations which also fall within a small frequency window (freq_win: 10.0000). They are statistically common, even in random noise, and typically are caused by RFI, but nevertheless score better when compared to lone signals.
³ Star data are from the Hipparcos Star Catalog. This is the number of known stars seen at this pixel. The pixels are small enough that we average about one star for every 150 pixels. We will divide this star count into more specific classes at a later date.
DPC SETI@Home hitparade van 26 maart 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 74 / 971 (7,6 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)28.676Sp@ceNv@der11.085.518(3)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)28.060Searchy! Internet Services V.O.F.8.706.656(4)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)23.421[DPC] Switch8.696.764(5)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)14.365[DPC] hansR15.051.179(1)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)14.154Blackmore55.039(169)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)12.948MaGNeT aka BlueTooth76348.871(54)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)11.075AmeComputers1.720.388(12)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif47)9.824muppet99154.618(99)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)9.401Ensign Wildfire3.107.853(7)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)8.407F@stmem2.140.466(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)6.834dpc_kluizenaar363.200(48)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)6.735[DPC]TeamGrazzie12.474.019(2)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)6.277dr bommel414.977(42)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif44)4.854K3th3r166.415(91)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.310o25o & Dharkon4.737.932(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)3.760ray1.227.204(17)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif53)3.741Quark490.929(36)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)3.721Vrank160.548(95)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)3.687Jox444828.221(25)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)3.643Sylvester234.587(70)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.368Bram106.258(119)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.230Jan Zandvliet & x-RaY991.695.833(13)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.184Mr Beamer1.833.474(11)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.162Intrud3r47.169(194)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.864Joey van den Berge257.939(67)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif26)2.710mat.hi.as14.342(343)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.643[DPC] Brainy007578.671(30)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)2.440[DPC]Trancemaus2.265.271(9)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)2.268Tijntje1.323.484(16)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif38)2.078grass460104.465(123)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.051.179[DPC] hansR14.365(4)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.474.019[DPC]TeamGrazzie6.735(12)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.085.518Sp@ceNv@der28.676(1)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.706.656Searchy! Internet Services V.O.F.28.060(2)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.696.764[DPC] Switch23.421(3)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.737.932o25o & Dharkon4.310(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.107.853Ensign Wildfire9.401(9)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.555.641[DPC]Spinpoint513(52)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.265.271[DPC]Trancemaus2.440(28)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.140.466F@stmem8.407(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.833.474Mr Beamer3.184(23)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.720.388AmeComputers11.075(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.695.833Jan Zandvliet & x-RaY993.230(22)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.474.749[DPC]Team Zuid-Holland0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.323.484Tijntje2.268(29)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.227.204ray3.760(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.134.155Speedy67 & Friends0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.117.816visvogel0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.043.157Berkie1.980(31)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)906.558Override1.241(38)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)886.459Dadoke1.641(33)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)828.221Jox4443.687(19)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)768.232Rydo0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)673.789Psyed0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)626.692MaNDaRK0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)581.964holy-shit0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)578.671[DPC] Brainy0072.643(27)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.705.761SETI.Germany793.315.643(2)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)410.604US NAVY160.428.848(19)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)353.054BOINC@AUSTRALIA134.560.320(26)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)327.171The Planetary Society205.183.570(13)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)318.863Canada146.527.937(21)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)311.174OcUK - Overclockers UK199.146.497(16)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)298.775U.S.Air Force141.719.374(25)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)293.963BOINC@Poland121.193.980(30)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)278.242Dutch Power Cows128.490.982(27)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)259.924Team Art Bell199.186.215(15)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)249.962UK BOINC Team127.146.450(28)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)243.657Team NIPPON109.871.066(34)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)234.874Elite Games99.395.492(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)232.722Boone Community School District - Iowa89.212.639(39)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)213.528Team MacNN202.767.782(14)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)211.603Planet 3DNow!93.665.430(38)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)993.152.076SETI.USA1.439.219(2)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)148.576.436Phoenix Rising485.329(14)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)146.527.937Canada318.863(20)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)145.215.233Ars Technica188.812(36)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)144.565.397BOINC.Italy198.201(34)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)143.620.137Amateur Radio Operators192.690(35)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)141.719.374U.S.Air Force298.775(22)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)134.560.320BOINC@AUSTRALIA353.054(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)128.490.982Dutch Power Cows278.242(24)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)127.146.450UK BOINC Team249.962(26)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)126.573.245Universe Examiners202.507(32)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)121.193.980BOINC@Poland293.963(23)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)120.745.684AUSTRIA - NATIONAL - TEAM168.494(41)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)115.003.934BOINC SETI@home RUSSIA199.778(33)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)114.323.378PC Perspective Killer Frogs142.599(46)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)109.871.066Team NIPPON243.657(27)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
Mijlpalen
muppet99150.000
Blackmore50.000
Bebbet5.000
ERBrouwer3.000
Racemol3.000
Nieuwe Leden
Edward de Vries1.219
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • BlueTooth76
  • Laatst online: 23:39
BlueTooth76
Let the sun shine!
M'n MultiBeam WU's beginnen nu echt bijna op te raken...
Hopelijk is Thumper snel weer online en gaan alle MB splitters weer hard aan het werk!
Ik verbaas me echt over de output van mijn Q9550 met (inmiddels) 2 CUDA devices.
Naast de XFX9800GTX+ draait er nu ook nog een Asus 9800GT in het systeem.
2x SE8K | 68x Talesun 300Wp | 16 oost, 16 west, 25 zuid, 11 noord | 20.400Wp | pvoutput.org | Mitsubishi Zubadan 14kW @ 50% vermogen
  • BlueTooth76
BlueTooth76
Let the sun shine!
Niet te geloven maar m'n wachtrij zit weer bijna vol met Multibeam WU's :D _/-\o_
M'n koe kan weer overuren draaien :)
[ Voor 30% gewijzigd door BlueTooth76 op 28-03-2009 00:56 ]
