pc geeft via airtunes hiccups
  • 173 views
  • daanski82
  • Laatst online: 21-11-2025
ik zet mijn vraag hier neer omdat ik het idee heb dat het probleem door mijn P5Q-E moederbord word veroorzaakt. Heb ook al op het Apple forum de zelfde vraag gesteld maar daar heb ik nog geen andwoord op.
aan gezien daar alles al op staat heb ik de tekst 1 op 1 overgenomen.
ik zal hem in de loop van het weekend even vertalen maar ik wil jullie iedeen weten waar het probleem in zou kunnen liggen.
de tekst:
i buyd and build a new PC (PC spec are below)
When i play a song in I-tunes over my own speakers there is nothing wrong but when i sent the music to my air-tunes (apple airport express) the sound is hiccuping.
We have 4 other pc's in our network and the are working fine with the Airport/airtunes.
i have tryed the onboard NIC and my linksys NIC and the give the same problems.
What have i done so far.
When i used the onbord gigabit card:
installed the driver from CD
download and install newer driver from the Asus site. this doesn't solve the problem.
i installed my Linksys Gigabit NIC with the driver i had on my old P4 PC. that don't solve the problem eather.
Give Itunes 1 CPU to work with instead of 2 CPU (by default)
A friend attendant me on install the chip set. so i did but that doesn't work.
I called also to Apple care center in Holland but the never heard this problem.
I Mailed With ASUS and the are telling that its a program bug in I-tunes.
I enabled in the bios the ACPI 2.0 support and disable the 2 marvel NIC in
the bios but that doesn't solve the problem ether.
For this moment i'm out of troubleshooting perhaps this forum can help me solving the
hiccup problem ?
PC spec.
Asus p5q-e
Intel core duo 8400
Sapphire 4850 ATI video card
Kingston Value Ram KVR800D2N5K2/4G
All network data is going over my Linksys NIC (the onbord NIC's are disable in the bios)
PC software:
Windows XP pro UK
Avast 4.8
Windows bit defender
windows firewall is up
(this was the same software that i had with my old PC what was working)"
info from I-tunes:
Microsoft Windows XP Professional Service Pack 3 (Build 2600)
System manufacturer P5Q-E
iTunes 8.0.2.20
QuickTime 7.5.5
FairPlay 1.1.11
CD Driver 2.0.7.5
CD Driver DLL 2.1.1.1
Apple Mobile Device 2.1.2.7
Bonjour 1.0.6.2 (118.5)
iTunes Serial Number 406D2******64C
Current user is an administrator.
The current local date and time is 2009-01-28 08:11:00.
iTunes is not running in safe mode.
Video Display Information
ATI Radeon HD 4800 Series
o
# External Plug-ins Information ****
No external plug-ins installed.
o
# Network Connectivity Tests ****
Network Adapter Information
Adapter Name: {035E79CA-B88A-41FB-BC5E-5370FF2B7CF5}
Description: Linksys EG1032 v2 Instant Gigabit Network Adapter - Packet Scheduler Miniport
IP Address: **.**.**.**.**
Subnet Mask: 255.255.0.0
Default Gateway: **.**.**.**.**
DHCP Enabled: Yes
DHCP Server: **.**.**.**.**
Lease Obtained: Wed Jan 28 05:54:13 2009
Lease Expires: Wed Jan 28 17:54:13 2009
DNS Servers: -
Active Connection: LAN Connection
Connected: Yes
Online: Yes
Using Modem: No (I have ADSL so its a LAN modem)
Using LAN: Yes
Using Proxy: No
Firewall Information
Windows Firewall is on.
iTunes is enabled in Windows Firewall.
Connection attempt to Apple web site was successful.
Connection attempt to iTunes Store was successful.
Secure connection attempt to iTunes Store was successful.
Secure connection attempt to iPhone activation server was successful.
Last successful store access was 2009-01-27 17:56:07.
My laptop is sending the music arround 125 a 130 kBps over the netwerk to the airport express
So i installed netlimiter after finding out the my i-tunes is sending the music @ a speed of 150kBps to the airport. so i lower de upload speed to 130kBps and it doesn't work :-S. my PC had over a few momends a crash so I uninstalled Netlimiter.
Ik hoop dat iemand met een oplossing komt voor mijn I-tunes / airtunes probleem
Sorry voor wat spelfouten heb last van dyslectie. graag hier over geen opmerkingen.
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
1 topic lijkt me genoeg: [AirTunes] Hiccups in muziek
Verder is het wel zo netjes om gewoon in het NL te posten :)
