Serious help needed about wich 26 or 27 " monitor
  • 1.194 views
  • Le_Freak !
  • Laatst online: 19-08 18:15
Hello,
I am in the market for a new,better and bigger monitor (my current monitor is a DELL 2407WFPB 24'')
I like to know wich of the current monitors below is the best choice or maybe one that is not listed below.
Ofcourse i know when i ask that question i get a lot of answers like what is most important for you.
Well i will try to describe what i am looking for:
* Crystal clear images and bright colours (by normal pc usage)
* no lagg during gaming (FPS games)
* resolution at 1920x1200
* Perfect for watching movies on.
So i like to know if some of you can tell me wich one i must buy.
Thankx in advance.
26"
Acer AL2616W PVA 1920x1200 1600 500 5 Y 1 1 N
Acer X263Wbi TN 1920x1200 3000 350 5 Y N Y HDMI
Belinea o.display 3_26" TN 1920x1200 800/2500 400 5 Y N 1 N
DoubleSight DS-263N H-IPS 1920x1200 800 500 TN Y 1 1 N
LG W2600H TN 1920x1200 5000 300 5 Y 1 1 N
LG W2600HP S-IPS 1920x1200 5000 400 5 Y 1 1 N
LG W2600V TN 1920x1200 5000 300 5 Y 1 1 HDMI
NEC 2690WUXi S-IPS 1920x1200 800 400 16 N 1 N N
Samsung 2693HM TN 1920x1200 1000/3000 400 5 Y 1 1 HDMI
Samsung T260 TN 1920x1200 1000/20000 300 5 Y 1 1 1 + HDMI
Samsung T260HD TN 1920x1200 1000/10000 300 5 Y 1 1 1 + 2 HDMI
Viewsonic VA2626wm TN 1920x1200 800 350 5 Y N 1 HDMI
Viewsonic VP2650wb TN 1920x1200 1000/4000 400 5 Y 1 1 N
27"
Dell 2707WFP S-PVA 1920x1200 1000 400 6 Y 1 Y Y
Dell 2709WFP S-PVA 1920x1200 3000 450 6 Y 1 Y Y
Samsung 275T S-PVA 1920x1200 3000 500 6 Y 1 Y Y
28"
Hanns.G HG281D TN 1920x1200 800 500 5 Y N 1 HDMI
Hanns.G HG281DP TN 1920x1200 800 500 5 Y N 1 HDMI
Viewsonic VX2835wm TN 1920x1200 800 500 3 Y 1 1 HDMI
Specs
  • sanzut
  • Laatst online: 00:20
sanzut
It's always christmas time
Waarom is je bericht in het engels? In je andere berichten is er niets mis met je nederlands?
Verder geen verstand van monitoren :p
  • Le_Freak !
Reinman bedankt voor je antwoordt maar op dat soort antwoorden zit ik niet te wachten, die had ik zelf al bedacht. ik ga er vanuit dat er hier mensen rondlopen met ervaring en kennis op dit gebied. en die aanvoelen wat ik bedoel en zoek.
Specs
  • J3roen
J3roen
Intentionally left blank
Nogal subjectief nietwaar; voor iedereen zijn de eisen anders. Jij bent de enige die een keuze kunt maken dus ik zou zeggen, ga zelf lekker op je gemak alles op een rijtje zetten en ga strepen.
De keuze tussen 24/27". Ik bedoel gaan wij dat voor jou uitmaken?
En de vraag waarom in het engels staat nog steeds; het is een nederlandsch forum :P
[ Voor 28% gewijzigd door J3roen op 27-11-2008 12:13 ]
  • Le_Freak !
Totaal niet subjectief, ik omschrijf exact wat ik precies zoek, iemand die ervaring heeft met grote monitoren en misschien met hetzelfde zat als ik nu mee zit.
Mensen die dus geen ervaringen hebben met grote monitors hoeven ook niet te reageren.
Lijkt me toch duidelijk ? en specs verzamelen heb ik allang gedaan, praktijkervaring is datgene wat ik zoek.
Specs
  • thijszor
  • Laatst online: 03-08 18:31
nou nou, een op wat meer normale manier van praten word hier op prijs gesteld.
Op deze manier krijg je dus nooit een normaal antwoord.
  • MensionXL
MensionXL
Optimaliseren!
Het staat ook vol met vreselijke taalfouten :+ Om te janken. :P
En lag tijdens games met een monitor? Je bedoelt ghosting. ;)
[ Voor 29% gewijzigd door MensionXL op 27-11-2008 15:32 ]
Goedkoop bellen via VoIP
  • Noork
Wat ik prettig vind, hoef jij nog niet prettig te vinden. Als je het budget hebt, zou ik gewoon de duurste nemen! Maar daar lees ik dus ook niks over....
'In the market' , wich?
  • Bejit
  • Laatst online: 23-08 09:11
Bejit
Svenska Faderland
Noork schreef op donderdag 27 november 2008 @ 15:32:
'In the market' ?
In the market is een vrij normale "Amerikaanse" term.
De HannsG en Viewsonic vallen sowieso af, aangezien de kleuren(Zelfs na calibratie) ver achterblijft dan die van de Dell.
Systeempje
  • Techno Overlord
  • Laatst online: 16:10
Techno Overlord
Nocturnal Metamorphoses™
Ik heb sinds een week een Samsung 2693HM. Ik draai op 1920x1200 en het ziet er ontzettend gelikt uit. In games heb ik Fallout 3 en Unreal Tournament 3 op max settings draaien en dus ook de hoogste resolutie. De monitor op zich ziet er qua design heel mooi uit vind ik. Ik heb m via een dvi-d to hdmi kabel aangesloten op mijn 2x HD4870 1gb Crossfire. Er zitten 2 usb-poorten aan de achterzijde die ik gebruik voor mij bedrade toetsenbord en draadloze muis. Ik heb helemaal niets aan te merken en het scherm presteert boven mijn verwachtingen. Ik had hiervoor een 19" CRT van ViewSonic. Nadeel is dat ik dus geen vergelijkend materiaal heb. Maargoed ik kan iedereen deze monitor van harte aanbevelen.
Waarom ik niet heb gekozen voor de T260 van Samsung is dat de 2693HM wel in hoogte verstelbaar is en dat deze VESA-compatible is en dus aan de muur bevestigt kan worden met een universeel mechanisme.
Specs:
Workstation
Server
RetroPC1
RetroPC2
RetroPC3
Le_Freak ! schreef op donderdag 27 november 2008 @ 14:23:
Leuk voor jouw, maar dit soort "Wat moet ik kopen" topics zijn op GoT niet toe gestaan. Verder had het netjes gestaan als je je post in het Nederlands had gemaakt.
[ Voor 6% gewijzigd door Verwijderd op 27-11-2008 15:41 ]
  • Koen_R
  • Laatst online: 22-08 16:57
Kijk eerst eens in de winkel naar het verschil tussen een TN en een IPS/PVA paneel.
Dat verschil is duidelijk zichtbaar. Kijk of het verschil je opvalt, of je het belangrijk vind, en of het verschil je de meerprijs waard vindt.
Over het algemeen geldt voor vrijwel alle schermen:
IPS/PVA: Betere kleurweergave en kijkhoek, duurder
TN: Hogere refreshrate, goedkoper
  • Stoffel
  • Registratie: Mei 2001
  • Laatst online: 25-05 17:40
Stoffel
Engineering the impossible
Waarom in het Engels? Waarschijnlijk omdat het copy/paste werk is van een ander forum waar je dezelfde vraag hebt gesteld. Dat getuigt niet echt van veel respect voor de lezers hier.
  • Le_Freak !
Stoffel schreef op donderdag 27 november 2008 @ 15:44:
Goh we hebben weer iemand die niks te doen heeft, wat heeft het nou met respect te maken man ? ga iets nuttigs doen of zo.
Specs
  • Le_Freak !
Verwijderd schreef op donderdag 27 november 2008 @ 15:41:
Er zitten hier echt een hoop wijven tussen he, ongeloofelijk 8)7
Specs
  • Le_Freak !
CaptainM schreef op donderdag 27 november 2008 @ 15:36:
Kijk daar heb ik wat aan :) bedankt voor je berichtje. dus gamen gaat perfect daarop ? geen ghosting of input lagg ? en als je gewoon internet ermee ? ook gewoon strakke en zeer heldere beelden ?
[ Voor 6% gewijzigd door Le_Freak ! op 27-11-2008 18:25 ]
Specs
  • weebl
  • Laatst online: 08:17
weebl
YARR!
Zeg vriend, GoT is een internetforum waarop mensen vrijwillig anderen helpen. De toon die jij hier aanslaat is wellicht acceptabel als je slecht word geholpen door een betaalde helpdesk, maar ik zou hier toch echt wat meer op je manieren letten. Je komt namelijk erg onbeschoft over zo.
  • Satch
Naar mijn mening zijn dat allemaal maar marginale updates van je huidige monitor. Tenzij je die paar inch groter erg belangrijk vindt. Naar mijn weten is de Dell 2407 ook een erg goede lcd monitor. Ik zelf heb de 2405 (voorloper) en ben daar ook zeer tevreden over. Misschien is de overstap naar een 30" monitor een optie? Alhoewel je dan wel een resolutie hebt van 2560x1600 en dat is voor games/films misschien wat te hoog. Voor desktop werk is dat natuurlijk alleen maar mooi. :)
  • SinergyX
  • Laatst online: 16:24
SinergyX
____(>^^(>0o)>____
Engels? Dutchlish ofzo... :X
:w
[ Voor 152% gewijzigd door Verwijderd op 27-11-2008 18:34 ]
