[Vista] BSOD oorzaak=Geheugen?
  • quizzical
  • Laatst online: 10-10 11:25
Ik heb recent 2 extra gig overgekocht van een vriend en de 2 geheugenlatjes in mijn pc gestopt.
Nu heb ik 2 keer een Blue Screen of Death gehad en de dumplog zegt het volgende:
Microsoft (R) Windows Debugger Version 6.9.0003.113 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\Mini101008-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is:
SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008 Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6001.18063.amd64fre.vistasp1_gdr.080425-1930
Kernel base = 0xfffff800`0205c000 PsLoadedModuleList = 0xfffff800`02221db0
Debug session time: Fri Oct 10 13:20:46.013 2008 (GMT+2)
System Uptime: 0 days 2:44:39.377
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffff800020e3f3a, fffffa6007672020, 0}
Probably caused by : memory_corruption ( nt!MiFindEmptyAddressRange+1ba )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800020e3f3a, Address of the exception record for the exception that caused the bugcheck
Arg3: fffffa6007672020, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - De instructie op 0x%08lx verwijst naar geheugen op 0x%08lx. Een lees- of schrijfbewerking op het geheugen is mislukt: %s.
FAULTING_IP:
fffff800`020e3f3a a30000000000f7ffff mov dword ptr [FFFFF70000000000h],eax
CONTEXT: fffffa6007672020 -- (.cxr 0xfffffa6007672020)
rax=00000000fffffffe rbx=0000000000000001 rcx=000000000000061c
rdx=000000000000061c rsi=000000000000061c rdi=0000000000000000
rip=fffff800020e3f3a rsp=fffffa6007672880 rbp=0000000000010000
r8=07fffffff0000000 r9=fffff70000000ff8 r10=0000000000007fff
r11=0000000000007fff r12=000000000000061c r13=fffffa8005c93470
r14=fffff70000000000 r15=00000000fffffffe
iopl=0 nv up ei ng nz na pe nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010282
nt!MiFindEmptyAddressRange+0x1ba:
fffff800`020e3f3a a30000000000f7ffff mov dword ptr [FFFFF70000000000h],eax ds:002b:fffff700`00000000=????????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: avgscana.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff8000234e0fe to fffff800020e3f3a
STACK_TEXT:
fffffa60`07672880 fffff800`0234e0fe : 00000000`00001000 00000000`00000000 000007ff`fffdffff fffffa60`07672950 : nt!MiFindEmptyAddressRange+0x1ba
fffffa60`07672920 fffff800`0234eb6c : fffffa80`07c1b780 fffffa80`05c93470 fffffa60`07672b58 fffffa80`066d8370 : nt!MiMapViewOfDataSection+0x25e
fffffa60`07672a00 fffff800`0234ef92 : 00000000`00000001 fffffa80`05c93470 fffffa60`07672b58 00000000`00000000 : nt!MiMapViewOfSection+0x20c
fffffa60`07672af0 fffff800`020b0e33 : fffffa80`066d8370 00000000`060bf928 00000000`060bf8e8 fffff800`00000018 : nt!NtMapViewOfSection+0x281
fffffa60`07672bb0 00000000`77535cfa : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`060bf908 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77535cfa
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!MiFindEmptyAddressRange+1ba
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4812c3f7
STACK_COMMAND: .cxr 0xfffffa6007672020 ; kb
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0x3B_nt!MiFindEmptyAddressRange+1ba
Nu ben ik nogal een leek op dat vlak, maar het lijkt me dat ze zeggen dat ik een probleem heb met mijn geheugen. Ik heb een ingebouwde tool van vista het geheugenlaten controleren en mem test heeft test 5 en test 8 beide 8 keer gedraait en de default tests reeds 2 keer gedaan. Ik laat hem nog een nachtje doordraaien maar waarschijnlijk zal er dus nogaltijd staan dat er geen problemen zijn.
Wie heeft dan gelijk? Memtest86+ of de geheugendump?
Bedankt!
Esben
  • MrDummy
  • Laatst online: 25-07-2025
MrDummy
Nog steeds gek op anime...
Je draait memtest bij opstarten computer? Dan scan je heel geheugen.
De meldingen lijken inderdaad op geheugenfout. Memtest even laten draaien met alle mogelijke tests.
  • quizzical
Ik laat memtest86+ inderdaad draaien bij het booten.
in totaal nu 14u aan tests gedaan zonder fouten...
Ik begrijp er niks van?
Is er een kans dat memtest de fout niet ontdekt?
  • Onbekend
  • Laatst online: 23:36
Onbekend
Wat zijn de tijd-eigenschappen van die geheugens?
En heb je de bios daar ook fixed op ingesteld?
  • Haan
  • Laatst online: 11-10 17:01
Haan
dotnetter
Het is natuurlijk wel heel erg toevallig als je problemen krijgt op het moment dat je extra geheugen hebt toegevoegd.. Maar misschien kan je in je bios nog wat met instellingen voor het geheugen spelen, misschien dat de andere modules net iets andere timings gebruiken, of een iets hoger voltage nodig hebben om goed te werken.
dat is eigenlijk ook wat Onbekend hier boven zegt..
[ Voor 9% gewijzigd door Haan op 11-10-2008 09:58 ]
Kater? Eerst water, de rest komt later
  • alt-92
alt-92
ye olde farte
http://blogs.msdn.com/ntd...hardware-bitflipping.aspx
Daar kom je ook een dergelijk verhaal tegen, waarbij de voltages verhoogd moesten worden.
De ingebouwde geheugen test van Vista is niet memtest86+ !!! De test van Vista vind zeer veel geheugen problemen niet en ik zou hem nooit gebruiken.
Download gewoon even de echte memtest en laat die een nachtje draaien.
  • quizzical
Bedankt voor alle reacties,
Even voor de duidelijkheid: Ik heb die Vista test enkl de korte versie gedaan en memtest86+ 14 uur laten draaien.
Vandaag ben ik waarschijnlijk te druk bezig om jullie tips te onderzoeken maar zodra ik het heb gedaan laat ik iets weten ;)
Bedankt!
Esben
  • quizzical
Nog even vermelden: Voordat ik die 2 extra gigabytes aan de praat kreeg moest ik in het bios een functie aanzetten met de naam remapping of zo, anders herkende hij maar 3 gigabyte.
Ik heb even gekeken wat everest te vertellen had over mijn geheugen:
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
Versie EVEREST v4.00.976/nl
Benchmark Module 2.1.184.0
Startpagina http://www.lavalys.com/
Rapporttype Snelrapport
Computer HOOFDPC (HoofdPC)
Maker Appartement
Besturingssysteem Microsoft Windows Vista Home Premium 6.0.6001
Datum 2008-10-12
Tijd 12:01
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Kingston 1G-UDIMM ]
Eigenschappen Geheugenmodule:
Modulenaam Kingston 1G-UDIMM
Serienummer 681A5406h (106175080)
Fabricagedatum Week 13 / 2007
Modulegrootte 1024 MB (1 rank, 8 banks)
Moduletype Unbuffered DIMM
Geheugentype DDR2 SDRAM
Geheugensnelheid DDR2-667 (333 Mhz)
Modulebreedte 64 bit
Modulespanning SSTL 1.8
Foutdetectiemethode Geen
Verversingsfrequentie Gereduceerd (7.8 us), Self-Refresh
Geheugeninstellingen:
@ 333 Mhz 5-5-5-15 (CL-RCD-RP-RAS) / 20-43-3-5-3 (RC-RFC-RRD-WR-WTR)
@ 266 Mhz 4-4-4-12 (CL-RCD-RP-RAS) / 16-34-2-4-2 (RC-RFC-RRD-WR-WTR)
@ 200 Mhz 3-3-3-9 (CL-RCD-RP-RAS) / 12-26-2-3-2 (RC-RFC-RRD-WR-WTR)
Geheugenmodulefabrikant:
Firmanaam Kingston Technology Company, Inc.
Productinformatie http://www.kingston.com/products/default.asp
[ DIMM2: Kingston 99U5316-001.A02LF ]
Modulenaam Kingston 99U5316-001.A02LF
Serienummer 30341056h (1443902512)
Fabricagedatum Week 19 / 2007
Modulegrootte 1024 MB (2 ranks, 4 banks)
@ 333 Mhz 5-5-5-15 (CL-RCD-RP-RAS) / 20-35-3-5-3 (RC-RFC-RRD-WR-WTR)
@ 266 Mhz 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2 (RC-RFC-RRD-WR-WTR)
@ 200 Mhz 3-3-3-9 (CL-RCD-RP-RAS) / 12-21-2-3-2 (RC-RFC-RRD-WR-WTR)
[ DIMM3: Kingston 1G-UDIMM ]
Serienummer 9A19F676h (1995839898)
Fabricagedatum Week 12 / 2007
[ DIMM4: Kingston 99U5316-001.A02LF ]
Serienummer 29340E56h (1443771433)
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: Intel G965/P965 Chipset - Memory Controller Hub [C-2]
Offset 00: 86 80 A0 29 06 00 90 20 02 00 00 06 00 00 00 00
Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EA 81
Offset 30: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 01 90 D1 FE 00 00 00 00 01 40 D1 FE 00 00 00 00
Offset 50: 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 10 11 11 00 00 33 33 00 40 00 5F 00 00 0A 38 00
Offset A0: 40 00 00 18 00 00 00 80 00 00 00 00 00 00 00 80
Offset B0: 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 49 00 00 00 00 00 00 85
Offset E0: 09 00 09 01 6E C3 FF 89 86 0C 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 90 0F 04 00 00 00 00 00
B00 D01 F00: Intel G965/P965 Chipset - PCI Express Root Port [C-2]
Offset 00: 86 80 A1 29 07 01 10 00 02 00 04 06 08 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 00 A0 A0 00 00
Offset 20: 80 F8 80 FE E1 BF D1 DF 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 88 00 00 00 00 00 00 00 10 01 1A 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
Offset 80: 01 90 03 C8 08 00 00 00 0D 80 00 00 86 80 00 00
Offset 90: 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 10 00 41 01 00 80 00 00 00 00 00 00 01 25 01 02
Offset B0: 40 00 01 11 00 00 04 00 C0 01 48 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 01 00 03 E1 3F 00 90 0F 04 00 00 00 00 00
B00 D1A F00: Intel 82801HB ICH8 - USB Universal Host Controller [B-0]
Offset 00: 86 80 34 28 05 00 80 02 02 00 03 0C 00 00 80 00
Offset 20: 01 DC 00 00 00 00 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00
Offset 60: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 86 0F 02 00 00 00 00 00
B00 D1A F01: Intel 82801HB ICH8 - USB Universal Host Controller [B-0]
Offset 00: 86 80 35 28 05 00 80 02 02 00 03 0C 00 00 00 00
Offset 20: 01 E0 00 00 00 00 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 11 02 00 00
B00 D1A F07: Intel 82801HB ICH8 - USB2 Enhanced Host Controller [B-0]
Offset 00: 86 80 3A 28 06 00 90 02 02 20 03 0C 00 00 00 00
Offset 10: 00 FC BF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00
Offset 50: 01 58 C2 C9 00 00 00 00 0A 00 A0 20 00 00 00 00
Offset 60: 20 20 FF 01 00 00 00 00 01 00 01 01 05 20 00 E0
Offset 70: 00 00 DD 03 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 88 85 40 00 86 0F 02 00 06 97 02 20
B00 D1B F00: Intel 82801HB ICH8 - High Definition Audio Controller [B-0]
Offset 00: 86 80 4B 28 06 00 10 00 02 00 03 04 08 00 00 00
Offset 10: 04 80 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
Offset 40: 01 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 10 00 91 00 00 00 00 00 00 08 10 00 00 00 00 00
Offset C0: 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1C F00: Intel 82801HB ICH8 - PCI Express Root Port 1 [B-0]
Offset 00: 86 80 3F 28 06 01 10 00 02 00 04 06 08 00 81 00
Offset 10: 00 00 00 00 00 00 00 00 00 03 03 00 F0 00 00 20
Offset 20: F0 FF 00 00 E1 DF E1 DF 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 10 01 02 00
Offset 40: 10 80 41 01 C0 8F 00 00 00 00 10 00 11 4C 11 01
Offset 50: 00 00 01 10 60 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 0D A0 00 00 43 10 EC 81 00 00 00 00 00 00 00 00
Offset A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 11 00 00 00 00 00
Offset E0: 00 00 C7 00 06 07 08 00 30 00 00 00 00 00 00 00
B00 D1C F04: Intel 82801HB ICH8 - PCI Express Root Port 5 [B-0]
Offset 00: 86 80 47 28 07 01 10 00 02 00 04 06 08 00 81 00
Offset 10: 00 00 00 00 00 00 00 00 00 02 02 00 B0 B0 00 00
Offset 20: 90 FE 90 FE F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 40: 10 80 41 01 C0 8F 00 00 00 00 10 00 11 2C 11 05
Offset 50: 40 00 11 30 60 00 00 00 00 00 48 01 00 00 00 00
B00 D1D F00: Intel 82801HB ICH8 - USB Universal Host Controller [B-0]
Offset 00: 86 80 30 28 05 00 80 02 02 00 03 0C 00 00 80 00
Offset 20: 81 D4 00 00 00 00 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 17 01 00 00
B00 D1D F01: Intel 82801HB ICH8 - USB Universal Host Controller [B-0]
Offset 00: 86 80 31 28 05 00 80 02 02 00 03 0C 00 00 00 00
Offset 20: 01 D8 00 00 00 00 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
B00 D1D F02: Intel 82801HB ICH8 - USB Universal Host Controller [B-0]
Offset 00: 86 80 32 28 05 00 80 02 02 00 03 0C 00 00 00 00
Offset 20: 81 D8 00 00 00 00 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
B00 D1D F07: Intel 82801HB ICH8 - USB2 Enhanced Host Controller [B-0]
Offset 00: 86 80 36 28 06 00 90 02 02 20 03 0C 00 00 00 00
Offset 10: 00 F8 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Offset 60: 20 20 FF 01 00 00 00 00 01 00 00 00 00 20 00 C0
Offset 70: 00 00 CF 3F 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1E F00: Intel 82801HB I/O Controller Hub 8 (ICH8) [B-0]
Offset 00: 86 80 4E 24 07 01 10 00 F2 01 04 06 00 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 04 04 20 F0 00 80 22
Offset 20: A0 FE A0 FE F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 02 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
Offset 50: 0D 00 00 00 43 10 EC 81 00 00 00 00 00 00 00 00
B00 D1F F00: Intel 82801HB ICH8 - LPC Bridge [B-0]
Offset 00: 86 80 10 28 07 00 10 02 02 00 01 06 00 00 80 00
Offset 40: 01 08 00 00 80 00 00 00 81 04 00 00 10 00 00 00
Offset 60: 8B 85 8F 8A D0 00 00 00 80 80 83 8E 00 00 00 00
Offset 80: 00 00 0E 14 95 02 00 00 00 00 00 00 00 00 00 00
Offset A0: 20 06 00 00 39 00 00 00 13 00 00 00 00 03 00 00
Offset B0: 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 33 22 11 00 67 45 00 00 C0 C0 00 00 00 00 00 00
Offset E0: 09 00 0C 10 21 00 04 CA 60 00 00 00 00 00 00 00
Offset F0: 01 C0 D1 FE 19 66 2E 00 86 0F 02 00 00 00 00 00
B00 D1F F02: Intel 82801HB ICH8 - 4-port SATA Controller [B-0]
Offset 00: 86 80 20 28 05 00 B0 02 02 8F 01 01 00 00 00 00
Offset 10: 01 EC 00 00 81 E8 00 00 01 E8 00 00 81 E4 00 00
Offset 20: 01 E4 00 00 81 E0 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
Offset 40: 07 A3 00 80 00 00 00 00 01 00 01 00 00 00 00 00
Offset 50: 00 00 00 00 30 10 00 00 00 00 00 00 00 00 00 00
Offset 70: 01 00 03 40 08 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 03 81 80 01 00 00 00 00 00 00 01 00 00 00
Offset C0: 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F03: Intel 82801HB ICH8 - SMBus Controller [B-0]
Offset 00: 86 80 3E 28 01 00 80 02 02 00 05 0C 00 00 00 00
Offset 20: 01 04 00 00 00 00 00 00 00 00 00 00 43 10 EC 81
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 0A 03 00 00
Offset 40: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
Offset 80: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F05: Intel 82801HB ICH8 - 2-port SATA Controller [B-0]
Offset 00: 86 80 25 28 05 00 B0 02 02 85 01 01 00 00 00 00
Offset 10: 01 D4 00 00 81 D0 00 00 01 D0 00 00 01 CC 00 00
Offset 20: 81 C8 00 00 01 C8 00 00 00 00 00 00 43 10 EC 81
Offset 40: 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00
B01 D00 F00: Asus EN8800GTS 320MB Video Adapter
Offset 00: DE 10 93 01 07 00 10 00 A2 00 00 03 08 00 00 00
Offset 10: 00 00 00 FD 0C 00 00 C0 00 00 00 00 04 00 00 FA
Offset 20: 00 00 00 00 01 AC 00 00 00 00 00 00 43 10 3C 82
Offset 30: 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
Offset 40: 43 10 3C 82 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
Offset 60: 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 10 00 01 00 80 04 00 00
Offset 80: 10 28 00 00 01 2D 01 00 48 00 01 11 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B02 D00 F00: JMicron JMB363 SATA-II RAID Controller
Offset 00: 7B 19 63 23 07 00 10 00 03 85 01 01 08 00 00 00
Offset 10: 01 BC 00 00 81 B8 00 00 01 B8 00 00 81 B4 00 00
Offset 20: 01 B4 00 00 00 E0 9F FE 00 00 00 00 43 10 E4 81
Offset 30: 00 00 00 00 68 00 00 00 00 00 00 00 10 01 00 00
Offset 40: B1 51 80 80 CC 08 FF F0 20 00 00 20 02 00 00 00
Offset 50: 10 00 11 02 00 00 00 00 00 20 0C 00 11 44 02 01
Offset 60: 40 00 11 10 00 00 00 00 01 50 02 40 00 00 00 00
Offset 80: 00 00 00 00 A0 01 0A 00 0F AA 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 80
Offset C0: C3 8B 38 00 03 45 02 00 53 00 00 00 0F BC A6 00
Offset D0: 18 00 00 80 01 00 00 10 40 00 EB 00 00 00 00 15
Offset E0: 00 00 00 00 00 00 00 00 18 35 9C C2 01 BC 00 84
B04 D02 F00: Ralink RT2561 802.11g Turbo Wireless Network Adapter
Offset 00: 14 18 01 03 16 00 10 04 00 00 80 02 08 40 00 00
Offset 10: 00 80 AF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 01 06 00 00 37 17 55 00
Offset 30: 00 00 00 00 40 00 00 00 00 00 00 00 17 01 00 00
Offset 40: 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI-8086-29A0: Intel i946/965 MCHBAR
Offset 200: 10 00 10 00 18 00 20 00 86 00 02 02 00 00 00 00
Offset 210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 220: 00 00 00 00 02 01 08 04 00 00 00 00 08 02 01 10
Offset 230: 00 00 00 00 00 04 00 00 00 00 00 10 08 02 80 40
Offset 240: 00 10 01 00 10 23 15 00 01 09 04 08 00 11 01 00
Offset 250: 55 7B 2B AC 46 03 68 54 46 5D 05 2B 0C 00 F5 15
Offset 260: 90 09 D6 0B FF 00 0E 13 00 28 CA CF 31 18 02 00
Offset 270: 00 1E 55 01 01 88 08 00 82 10 23 08 31 01 00 00
Offset 280: 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
Offset 290: 1C 09 F2 04 00 00 00 00 14 14 B0 10 00 22 34 00
Offset 600: 10 00 10 00 18 00 20 00 86 00 02 02 00 00 00 00
Offset 610: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 620: 00 00 00 00 02 01 08 04 00 00 00 00 08 02 01 10
Offset 630: 00 00 00 00 00 04 00 00 00 00 00 10 08 02 80 40
Offset 640: 00 10 01 00 10 23 35 00 01 09 04 08 00 11 01 00
Offset 650: 55 7B 2B AC 46 03 68 54 46 5D 05 2B 0C 00 F5 15
Offset 660: 90 09 D6 0B FF 00 0E 13 00 28 CA CF 31 18 02 00
Offset 670: 00 1E 55 01 01 87 08 00 82 10 23 08 31 01 00 00
Offset 680: 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
Offset 690: 1C 09 F2 04 00 00 00 00 14 14 B0 10 00 22 34 00
Offset C00: 20 00 00 40 0F 0F 0F 0F 80 00 00 00 00 00 00 00
Offset C10: 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00
Offset C20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C30: 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00
Offset C40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CA0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CB0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CC0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CD0: 01 01 01 01 00 00 00 00 01 00 00 FF 00 00 00 00
Offset CE0: 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00
Offset CF0: 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.g.K7400.L.w.VIDEO ..........IBM VGA Compatible........04/12/07
C000:0040 ..................8.C.<..#.&#127;.....&#127;.&#127;...."..F......PMIDl.o.......
C000:0080 .....3..........HWEAPCIR............g.......ASUS EN8800GTS VGA B
C000:00C0 IOS Version 60.80.18.00.AS01.................................Ver
C000:0100 sion 60.80.18.00.01 ...Copyright (C) 1996-2006 NVIDIA Corp......
C000:0140 ....G80 Board - p356h00 ...............Chip Rev ..............
C000:0180 ............................................BIT......F2.....B...
C000:01C0 .C...8.D...F.A...J.I...M.L...].M..._.N.....P...l.S.....T.....U.
C000:0200 ....V.....c.....x.....i.&..........`..................\\........
C000:0240 .P.2...d.&#127;.P..R0R6RNR.R.R0R..(..R..P..".........................
C000:0280 B......P.....(m2..2#D.#g.....*..8.7........`........P..04/03/07.
C000:02C0 ........................C.<.&#127;.v.p.p........... .........C.<.&#127;.v.
C000:0300 p.p.,...w...1.....g.5...........G.....J.5.K.......Q...C.&#127;.......
C000:0340 ..(...............a...v...f...............n.....q.....t.y.=...x.
C000:0380 <.z...........?.?.?.i.p.p...k.s.t.u...E.......2....u....... P...
C000:03C0 ........X.............2......2.....f`2......fa.f`3.2......fa.f`3
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Om eerlijk te zijn is dat vrij veel Chinees voor mij maar ik leid eruit af dat ze dezelfde timings hebben.
Tot ik de geheugenlatjes naast elkaar zag dacht ik trouwens dat ze identiek waren. Beide sets werden verkocht als "Kingston 2GB DDR2 (2x1GB) PC5300 667Mhz CL5 Dual Channel Kit (KVR667D2N5K2/2G)"
Ik kan in men bios instellen dat het op 667Mhz moet draaien ipv "auto" is dat iets wat ik moet proberen? Denken jullie nogaltijd dat ik het voltage moet veranderen? Zoja naar wat?
Over instellen van tijd-eigenschappen heb ik niet meteen iets gevonden in het bios maar ik zal nog is kijken.
Ik probeer liever ook niet te riskante dingen, ik heb namelijk liever een werkende computer met 2GB dan een kapotte met 4GB.
Bedankt voor de hulp!
Esben
EDIT:
Ik zit nu in men bios en kan instellen:
DRAM CAS# Latency (nu 5)
DRAM CAS# to CAS# Delay (nu 6 DRAM Clocks)
DRAM RAS# Precharge (nu 6 DRAM Clocks)
DRAM RAS# Activate to Precha (nu 15 DRAM Clocks)
DRAM Write Recovery Time (nu 6 DRAM Clocks)
DRAM TRFC (nu 42 DRAM Clocks)
Zijn er daar dingen die ik moet veranderen? (Zonder risico liefst)
  • Onbekend
Onbekend
esben schreef op zondag 12 oktober 2008 @ 12:18:
Herkende de bios maar 3 GB of Vista?
Indien Vista, kan je deze functie weer uitzetten om te kijken of hij dan wel goed gaat.
  • quizzical
Zowel Vista als het BIOS herkenden maar 3 gigabyte voor ik die functie aan had gezet.
Moet ik de functie uitzetten en kijken of hij nog uitvalt? (valt ongeveer 1 keer per dag uit)
Dat betekend dan wel dat ik maar 3 gigabyte kan gebruiken.
Dus 1 geheugenlatje zou dan nutteloos zijn
  • quizzical
De remapping functie in het bios uitzetten hielp dus niet. De computer is gecrasht met die functie uit (en dus maar 3 gig werkend).
Ook het manueel instellen van het geheugen op ddr2-667 ipv auto hielp niet.
Welk van de andere mogelijkheden kan ik veilig proberen?
Ik ben meer en meer geneigd die 2 gig er gewoon uit te halen...
  • Haan
Haan
dotnetter
Het voltage iets verhogen (naar 1.9V bijv.) al geprobeerd?
  • quizzical
Ok ik heb het voltage verhoogt naar 1.9V, we zullen zien of dat helpt, maar ik betwijfel het want ik heb iets heel raar gevonden:
Mijn computer (met windows Vista 64 bit) is verbonden met een beveiligd (WPA) draadloos netwerk.
Nu zijn er mensen naast ons met een onbeveiligd draadloos netwerk, waar ik normaal probleemloos mee kan verbinden.
Zoals reeds gezegd moest ik de remapping functie aanzetten om Vista de 4 gigabyte te laten herkennen (geheugenslot kapot? Hoe kan ik zeker zijn? is het topic over toen ik dat probleem had)
Volgens de "RAM FAQ" (Abbadon in "RAM FAQ") is dat 1 van de voorwaarden opdat 4 gig herkent wordt:
i) 64bits OS
ii) x86 CPU met 64bits instructieset
iii) Chipset met remapping mogelijkheid (Intel 955, 965, 975 of enterprise chipset. Alle AMD chipsets die AMD64 cpu's ondersteunen)
iv) BIOS met remapping functie (staat default uit, dus wel aanzetten)
v) 4GB geheugen installeren
Het hele rare is dat met die functie aan ik NIET meer kan internetten via het draadloos netwerk van de buren.
Verbinden met het netwerk lukt maar Vista denkt dat het netwerk niet verbonden is met het internet...
De computer heeft ook windows xp 32 bit (dualboot) en daarmee kan ik wel verbinden met de remapping functie aan (waarschijnlijk zal die functie geen invloed hebben in xp omdat die toch niet meer dan 3 gig kan herkennen)
Ik zou denken dat zowel de BSOD's als het niet kunnen connecteren met het netwerk van de buren door hetzelfde probleem worden veroorzaakt maar dat lijkt niet te kloppen want de remapping functie uitzetten verhelpt het probleem met het verbinden met het netwerk van de buren maar de PC crasht nogaltijd...
Ik raak er echt niet meer aan uit....
Ik ga kijken of de PC nu nog crasht (met geheugen op 1.9V) waarschijnlijk zal hij wel crashen. Dan ga ik controleren of hij ook crasht in windows xp.
Heeft er iemand nog mogelijke oplossingen voor deze heel bizarre fenomenen???
Bedankt,
Esben
  • alt-92
alt-92
ye olde farte
Trek die wireless kaart er eens uit?
  • quizzical
EUH, wat bedoel je? PC uitzetten, PCI kaartje eruit halen, er weer in stoppen, PC aanzetten, kijken of het nu wel werkt???
  • alt-92
alt-92
ye olde farte
Precies.
Wellicht gebruikt dat ding een driver die niet goed omgaat met 4GB, of zorgt de kaart zelf voor een onvoordelige indeling van de beschikbare geheugenranges.
(elk PCI device claimt een stuk geheugen namelijk).
[ Voor 93% gewijzigd door alt-92 op 13-10-2008 19:44 ]
  • quizzical
Bedankt voor de tip.
Ik heb voorlopig het volgende gedaan:
De PCI kaart eruit gehaald en de pc opgestart zonder. Dan een usb wifi ding van sweex geinstalleerd en daarmee kan ik dus wel op het netwerk van de buren.
Nu ben ik benieuwd of de crashes uitblijven.
Indien er morgenavond nog geen crashes zijn gebeurd besluit ik dat de driver van de Linksys WMP54G v4.1 de oorzaak is van de crashes.
Wel heel irritant, ik had die kaart speciaal gekocht omdat ik graag een draadloze netwerkkaart wou hebben die werkte op Vista 64bit en ik dacht dat een kwaliteitsmerk als linksys zeker wel drivers zou maken daarvoor. Vista bestaat nu al lang en het is er nogaltijd niet...terwijl sweex dat wel kan...
Ik gebruik rare truckjes met Ralink drivers om dat ding aan de praat te krijgen.
Nu ben ik benieuwd als ik morgen de linksys kaart er weer in steek het probleem opgelost zal zijn of dat ik moet wachten tot linksys ooit 64bit drivers uitbrengt...
PS: De PC crashte ook met geheugen op 1.9 Volt
  • Haan
Haan
dotnetter
Ik had inderdaad ook een Linksys kaartje gekocht omdat ik daarvan verwachtte dat die zou werken onder 64-bits Vista, maar niets is minder waar ja :/ Bij mij werkt een SMC kaart die de helft kost nu prima.
  • quizzical
Met de Sweex kaart crasht de PC niet, ik heb de linksys pci kaart er weer ingestoken en kan daarmee nogaltijd niet op het onbeveiligde netwerk van de buren, waarschijnlijk zal de pc weer crashen met deze kaart.
Morgen zal ik proberen te kijken of ralink nieuwere drivers heeft gemaakt (ook al zijn die niet bedoelt voor mijn kaart).
Hebben jullie nog andere suggesties?
Indien niks lukt kan ik dus kiezen tussen een vista 64 bit draadloze netwerk kaart te gebruiken of 2 gigabyte ram te gebruiken ipv 4.
Heeft er iemand een vermoeden of 3 gigabyte ram problemen zou opleveren of niet?
  • Haan
Haan
dotnetter
Waarom blijf je die sweex kaart niet gebruiken, daarmee werkte toch wel alles?
  • quizzical
Dat is dus 1 van de mogelijkheden:
"Indien niks lukt kan ik dus kiezen tussen een vista 64 bit draadloze netwerk kaart te gebruiken of 2 gigabyte ram te gebruiken ipv 4."
Maar ik verkies die van linksys te gebruiken omdat daar een serieuze antenne op zit en bovendien hoort de Sweex kaart bij de laptop. Het is lastig om altijd te moeten verwisselen.
Ik heb via allerlei truckjes nieuwere ralink drivers geinstalleerd op mijn linksys kaart.
Ik kan nu verbinden met het netwerk van de buren. Hopelijk blijven ook de crashes uit, anders moet ik alsnog de sweex gebruiken.
