[OSx86] Installatie ervaringen & discussie
Pagina: 1 ... 39 ... 47 Laatste
  • insanity83NL
  • Laatst online: 15-04-2025
Geen matches
Hoi iedereen,
op een ander forum heb ik mijn Hackintosh Build staan. Hij is volledig confirmed ;)
Succes !
PS: ik draai inmiddels Mac OSX 10.8.5 met dualscreen ;)
Alles onderdelen zijn gewoon in NL te bestellen
insanityNL's Build: Core i5-2300 - MSI H61M-E33 - MSI Radeon HD 6850 - ML 10.8.4
Components
Apple Mac OS X Mountain Lion 10.8.4
http://itunes.apple.com/u...on/id537386512?ls=1&mt=12
Windows 8 Pro
MSI H61M-E33 HDMI Micro ATX Motherboard
http://www.amazon.com/dp/B004W9BHCU
MSI Radeon HD 6850 1 GB DDR5 2DVI/ HDMI/DisplayPort PCI-Express Video Card, R6850 CYCLONE PE/OC
http://www.amazon.com/dp/B004HKIA2Y
Intel Core i5-2300 Processor 2.8 GHz 6 MB Cache Socket LGA1155
http://www.amazon.com/dp/B004EBUXIU/
Corsair XMS3 8GB (2x4GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMX8GX3M2A1600C9)
http://www.amazon.com/dp/B0042A7CAA
Thermaltake Germany Series Berlin 630W ATX 2.3 (W0393RE)
http://skinflint.co.uk/eu...-2-3-w0393re-a636301.html
Cooler Master Elite 370 RC-370-KKR400 400W ATX Mid Tower Case (Black)
http://www.amazon.com/dp/B005JIPZ6M
OCZ Technology 240GB Agility 3 Series SATA 6Gb/s 2.5-Inch Midrange Performance Solid State Drive (SSD) with Max 525MB/s Read and Max 85K IOPS- AGT3-25SAT3-240G
http://www.amazon.com/dp/B004Z0S6S4/
Samsung Electronics Samsung 840 Series Solid State Drive (SSD) 500 GB SATAIII 2.5-Inch MZ-7TD500BW
http://www.amazon.com/dp/B009NHAF3I
Samsung S24B150BL 23.6 inch LED Monitor (200cd/m2, 1920x1080, 5ms, DVI, VGA)
http://www.amazon.co.uk/dp/B008JJPBH6
Comments
Before I go in further details I must add I have some extra HDD's installed, but are not worth mentioning because they are only used for storage.
For this you can choose any HDD you that is compatible with this motherboard.
OS X Installation Guide
-Step 1) Create a bootable USB drive from your Mac App Store purchased copy of the "Install OS X Mountain Lion.app" by using "UniBeast - Mountain Lion".
-Step 2) Once Unibeast has finished creating your bootable USB drive, place all the modified and extra kexts in the SLE directory
and suitable smbios and chameleon.boot files in the Extra directory. ( reason for this step is that My System would right Royaly spit the dummy if done otherwise)
-Step 3) Boot your system from Unibeast, and install Mountain Lion, make sure you're installing to a partition/drive that's using "GUID Partition Table/GPT", not "Master Boot Record/MBR".
-Step 4) Once your installation is finished, reboot. Once the system loads, fill out the setup wizard accordingly, and Reboot.
-That's it
MultiBeast settings
Unfortunatly I forgot what specific options I used. However if I am not mistaken these options can be found on this forum.
I can provide you with the org.chameleon.Boot.plist content:
29
30
31
32
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>EthernetBuiltIn</key>
<string>Yes</string>
<key>GenerateCStates</key>
<key>GeneratePStates</key>
<key>AtiConfig</key>
<string>Gibba</string>
<key>AtiPorts</key>
<string>4</string>
<key>GraphicsEnabler</key>
<key>Kernel</key>
<string>mach_kernel</string>
<key>Kernel Flags</key>
<string>darkwake=0</string>
<key>Legacy Logo</key>
<key>Instant Menu</key>
<key>UseKernelCache</key>
<key>Hide Partition</key>
<string>hd(3,1)</string>
<key>Graphics Mode</key>
<string>"1920x1080x32"</string>
</dict>
</plist>
Getting the graficscard to work properly
That is very easy. Install the attached kext file with KextBeast. ( Major thnx to danip for his awsome post )
After you installed the kext you are not done yet.
Go to Finder > Extra and open org.chameleon.Boot.plist
Edit or add the following lines:
    <key>AtiPorts</key>
    <string>4</string>
After a reboot your Hackintosh should reboot normaly and dual screen should work properly when only DVI-connections are used!
Since Mac OS X Mountain Lion the compatibility is majorly been improved, but still I would advice everyone to look for hardware compatibility on this forum, or just click here.
If you have any questions, please let me know.
Cheers all !
  • Jns1986
  • Laatst online: 12-10 15:26
Geen matches
matty___ schreef op woensdag 23 oktober 2013 @ 12:11:
Misschien een ander motherboard?
Ja of nog een graphical card erbij.
..sorry flauw
Maareh deze processor i5 3470 werkt dus alleen met grafische kaart en niet met de IGP.
  • matty___
  • Laatst online: 19-03 20:24
Geen matches
Jns1986 schreef op woensdag 23 oktober 2013 @ 16:05:
..sorry flauw
Meer als een Gigabyte geeft het minste gezeur (ten minsten was vroeger altijd zo, misschien met UEFI niet meer). Je moet het jezelf wel makkelijk maken. ;)
  • OgWok
  • Laatst online: 09-10 09:17
Geen matches
Reeds een Mavericks DMG gesignaleerd?
MacPro Core i5 750, Mac Mini, hier en daar een verdwaalde pc.....
  • iMick
  • Laatst online: 12-10 22:19
Geen matches
Waarvoor heb je een Mavericks DMG nodig? De app is al genoeg.
  • OgWok
Geen matches
iMick schreef op woensdag 23 oktober 2013 @ 19:46:
Hoe krijg ik die app? Van joe ;)
  • matty___
Geen matches
OgWok schreef op woensdag 23 oktober 2013 @ 19:55:
Van de appstore |:(
GRATIS DOWNLOAD!!!!!!1 _/-\o_
  • eXtink
Geen matches
De Install OS Mavericks is gratis beschikbaar in de app store [Link]
  • matty___
Geen matches
Deze keer echt lui geweest en gewoon over de bestaande ML installatie geïnstalleerd. Werkt als een zonnetje.
Behalve dat de iMessage niet werkt maar daar hebben meer mensen last van maar nog geen echte oplossing zo te lezen
[ Voor 35% gewijzigd door matty___ op 23-10-2013 22:49 ]
Geen matches
matty___ schreef op woensdag 23 oktober 2013 @ 22:49:
Kan je je bestaande setup zonder problemen gewoon upgraden????? Dat is wel heel relaxt.
  • matty___
Geen matches
Verwijderd schreef op woensdag 23 oktober 2013 @ 22:50:
Wel via een install USB/Disk gedaan dus niet via de appstore update route. Vervolgens niet de doeldisk leeg maken maar gewoon erover heen installen zoals je ook op een echte mac zou doen als je alles via de appstore doet.
Geen matches
matty___ schreef op woensdag 23 oktober 2013 @ 22:52:
Moet jee dan niet nog veel customizen? Zou superrelaxt zijn als dat mogelijk was.
  • iMick
Geen matches
Mavericks werkt in de meeste gevallen gewoon met je Extra folder van Mountain Lion, mits goed geconfigureerd. Enkel je audio zou problemen op kunnen leveren.
  • matty___
Geen matches
Verwijderd schreef op donderdag 24 oktober 2013 @ 11:01:
Mijn ML systeem draaide ook altijd prima.
Belangrijk is dat je de bootloader update en de laatste fakeSMC kan ook geen kwaad. Verder alleen audio patch, ssd trim en RTC cmos reset patches gedraaid (naast de bestaande kext die ik al had)
[ Voor 4% gewijzigd door matty___ op 24-10-2013 11:19 ]
  • OgWok
Geen matches
iMick schreef op donderdag 24 oktober 2013 @ 11:05:
Dus als ik je goed begrijp kan ik hem zo over een goedwerkende 10.6.8 heenkletsen ?
[ Voor 6% gewijzigd door OgWok op 24-10-2013 11:59 ]
  • Mick1990
Geen matches
Ik heb Mountain Lion ook gewoon een update gegeven naar Mavericks. Via de Appstore lukt inderdaad niet, maar met unibeast wel. Gewoon exact hetzelfde stappenplan als een nieuwe installatie, maar dan niet de harde schijf wissen maar gewoon op installeren drukken.
Daarna Multibeast voor mavericks eroverheen en alles werkt gewoon nog steeds zoals het hoort:
Gigabyte Z87n-wifi
Intel i5 4670k
8GB DDR3
GTX660 ti
Het geheel voelt iets sneller aan dan Mountain Lion. Mijn iPhoto bibliotheek met 5000 afbeeldingen is nu bijvoorbeeld in 3 seconden geopend; bij Mountain Lion duurde dat zeker 6 seconden... Ik vind dat nogal een verschil.
WP: Mitsubishi SUZ-SWM40 VA + EHST20D-VM2D | WTW: Zehnder E300
  • ronzelver
  • Laatst online: 07-09 23:51
Geen matches
Mick1990 schreef op donderdag 24 oktober 2013 @ 16:50:
Gigabyte Z87n-wifi
Intel i5 4670k
8GB DDR3
GTX660 ti
Ik heb dezelfde setup maar zonder GTX660 (onboard HD4600). Welke Multibeast kext's en verder opties heb jij gebruikt? Na het toepassen van de 'Intel E1000...'-kext boot mijn systeem niet meer. Daarvoor wel nog maar ik had een ontzettende slechte netwerk performance (traag).
Ron
GA-Z97X-UD5H, Core i5 4670, 8Gb DDR3, MSI GTX 1050 Ti 4Gb, Samsung 840 EVO 250 Gb SSD, BCM94360CD Wifi+Bluetooth 4.0LE, MacOS 13 High Sierra
  • Mick1990
Geen matches
Ron,
Ik neem aan dat je Multibeast versie 6.0.0 hebt gebruikt?
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/24409276/Schermafbeelding%202013-10-24%20om%2017.25.14.png
Ik heb zowel de Atheros als de Intel kext aangevinkt. Werkt bij mij zonder problemen. Bij Mountain Lion wilde mijn systeem ook een keer niet booten na het aanvinken van de Intel netwerk kext, maar na nog een keer proberen werkte het om een of andere vage reden ineens wel...
  • eXtink
Geen matches
Voor degene die Retail iWork/iLife/Aperture hebben gekocht en problemen hebben tijdens het upgraden, als je dan de mogelijkheid hebt om een VM aan te maken of ergens anders een verse installatie kan uitvoeren, doe dat dan. In deze "nieuwe" installatie kan je de apps installeren en updaten en dan worden ze gelijk aan je appleID toegevoegd :)
  • matty___
Geen matches
Heb een fix voor het iMessage probleem. In Chameloen Wizzard kun je modules installeren en daar hebik de NVram module geïnstalleerd en dat heeft het login issue opgelost
  • seninha
  • Laatst online: 14-10 08:13
seninha
god's right foot
Geen matches
Hier draait Maverick ook als een zonnetje, inlcusief imessage (dank zij NVram module)
Nu alleen nog kijken naar een andere bootloader omdat Chimera mijn UEFI partitie waar windows 8.1 op staat niet ziet.
Heb daarom nu de Windows schijft als first boot. Als ik OSX wil opstarten dan moet ik tijdens het starten even op F12 drukken en de OSX schijf kiezen.
Las dat de bootloader Clover wel met UEFI om kan gaan, dus moet me daar even in verdiepen.
iRacing Profile Flickr
  • matty___
Geen matches
seninha schreef op vrijdag 25 oktober 2013 @ 11:34:
Heeft Chameloen hetzelfde probleem?
  • seninha
seninha
god's right foot
Geen matches
Voor zover ik weet kan die ook niet met UEFI omgaan.
Je kan wel alles draaiend krijgen, zelfs zonder DSDT maar je Windows boot partitie is niet te zien.
Als ik nu F12 druk en de OSX schijf kies dan krijg ik de bootscherm te zien maar daar staat alleen de OSX schijf op.
[ Voor 68% gewijzigd door seninha op 25-10-2013 14:00 ]
Geen matches
seninha schreef op vrijdag 25 oktober 2013 @ 13:59:
Clover ondersteunt UEFI
  • OgWok
Geen matches
;) En werkt Little Snitch nog ?
[ Voor 8% gewijzigd door OgWok op 25-10-2013 17:15 ]
  • blouweKip
  • Laatst online: 12-09 21:42
Geen matches
Als je versie 2 hebt dan zul je moeten upgraden naar 3
"For my friends, anything; for my enemies, the law."
  • seninha
seninha
god's right foot
Geen matches
3.3 werkt perfect hier.
Geen matches
blouweKip schreef op vrijdag 25 oktober 2013 @ 17:59:
3.0 kan niet, krijg problemen in m'n virtuele bak
  • matty___
Geen matches
Zo nog even lekker heel mijn installatie verneukt omdat ik zo nodig naar UEFI bios moest gaan.
Vervolgens steeds bij het booten P-State stepper error.
Had mijn DSDT.aml wel weggehaald van te voren maar blijkbaar moest de P/C state en DropSSDT er ook uit de config.
Maar hij doet het nu wel weer.
  • Gusev
  • Laatst online: 20:23
Geen matches
Ik heb in het verleden eens Snow Leopard geïnstalleerd op mijn HP 6930p laptop. Ik zou nu echter Mavericks wel eens willen proberen. Hoe ver zou ik komen met onderstaande config:
<<< Systeemoverzicht >>>
  > Moederbord : HP 30DB
  > Chipset : Intel GM45/GM47
  > Processor : Intel Mobile Core 2 Duo P8600 @ 2400   MHz
  > Fysiek Geheugen : 4096  MB  (2 x 2048 DDR2-SDRAM )
  > Videokaart : Mobile Intel(R) 4 Series Express Chipset Family (Microsoft Corporation - WDDM 1.1)
  > Harde Schijf : Samsung SSD 840 EVO 120GB (120GB)
  > DVD-Rom Station : Toshiba-Samsung CDDVDW TS-L633M
  > Monitor Type : SAMSUNG  - 14 inches
  > Netwerkkaart : Intel 82567LM Gigabit Network Connection
  > Netwerkkaart : Intel Wireless WiFi Link 5300
  • iMick
Geen matches
Je WiFi gaat niet werken en ik denk dat je grafische chip ook niet ondersteund wordt. Als die uberhaupt al in Snow Leopard ondersteund was, dan zul je maar tot aan Lion ondersteuning hebben.
  • br13an
  • Laatst online: 21-09 14:53
Geen matches
Ik heb momenteel 1 probleempje, heb eerder deze week geupdate naar 10.9.
Sinds de update moet ik nu elke keer bij het booten GraphicsEnabler=yes invullen, terwijl ik het in MultiBeast wel gewoon aangevinkt heb, hoe kan ik de oude kexts(en welke) verwijderen, zodat ik MultiBeast er weer overheen kan laten gaan en de bootloader laat aanpassen?
  • Mick1990
Geen matches
Ik zou eerst met de Finder naar ~/Extra/ gaan en dan de file org.chameleon.Boot.plist openen met bijvoorbeeld het programma Textwrangler om vervolgens te kijken of dit er wel in staat:
  • Teun_2
  • Laatst online: 13-10 21:16
Matched: osx86
Voor de Belgen die een standaard AZERTY toetsenbord gebruiken is deze link wel nuttig: http://el-tramo.be/be-non-apple/ hiermee kan je een standaard Belgisch AZERTY toetsenbord gebruiken op je OSX86 (of echte mac naturlijk ook).
Ik heb het altijd al gek gevonden dat Apple de Belgische versie van AZERTY wat moest aanpassen, ik zou niet weten wat daar de reden voor is.
Geen matches
Ik heb een perfect werkende Gigabyte Q77M-2dh setup met 5 monitoren (HD4000 + 6850 radeon). Sleep werkt etc. Ik gebruik clover als bootloader.
Ik heb niet heel veel tijd en wil graag weten of ik eenvoudig kan upgraden zonder dagenlang bezig te zijn. Een upgrade zou perfect zijn want ik heb weinig trek om tig programma's opnieuw erop te zetten.
Iemand een tip? Anders blijf ik voorlopig ML draaien, enige wat ik wel erg interessant aan Mavericks vind is de multi monitor extra ondersteuningen.
  • Kypo
  • Laatst online: 13-10 15:45
Geen matches
Verwijderd schreef op zondag 27 oktober 2013 @ 22:34:
Ik had, zoals eerder beschreven, de app gedownload van mavericks. Vervolgens met unibeast een bootable usb gemaakt. Dan booten van deze usb en installeren. Enkel moest ik daarna nog de audiokext opnieuw installeren, maar dat moet ik bij elke update :)
Ik draai op een MSI Z77A-G45 met i5 3570K en een Club3D 7870 XT (Tahiti), waarbij ik voor de videokaart flink wat toeren moest uithalen om hem te laten werken :) Maar zelfs dat blijft gewoon werken na de update :)
Geen matches
Kypo schreef op maandag 28 oktober 2013 @ 08:12:
Ok klinkt goed! Toch maar overwegen, of even clone disk maken en uitproberen.
  • matty___
Geen matches
Dus de 7870 werkt nu OOB?
  • MelvinB
  • Laatst online: 20-07 13:15
Geen matches
Eens even kijken of Mavericks op mijn nieuw bestelde laptop (Dell Inspiron 15 7000-series /I7 Haswell, 16GB DDR, GT750M) te installeren is:
Afbeeldingslocatie: http://www.gadgetreview.com/wp-content/uploads/2013/10/dell-inspiron-15-7000.jpg
http://www.dell.com/nl/p/...c=nl&l=nl&s=dhs&cs=nldhs1
[ Voor 8% gewijzigd door MelvinB op 28-10-2013 12:02 ]
| DELL XPS 15 Haswell QHD | APPLE iPhone X Silver | APPLE iPad Air |
  • Luukwa
  • Laatst online: 07-10 14:50
Luukwa
o/
Geen matches
Zou wel heel sick zijn, mooie laptop trouwens!
Soundcloud!
  • Kypo
Geen matches
Eeh volgens mij wel redelijk, er staan genoeg tutorials op inet hierover. Echter heb ik 2 schermen op m'n videokaart aangesloten. Daarvoor moest ik alleen een tooltje laten draaien :)
Link
[ Voor 10% gewijzigd door Kypo op 28-10-2013 12:10 ]
  • Danno88
  • Laatst online: 24-09 12:28
Geen matches
Hier Maverick werkend gekregen op een Vostro V131.
Jammer genoeg nog geen kexts voor de audio en wifi.
  • RoyK
  • Laatst online: 13-10 20:16
RoyK
Hobby tekenaar
Geen matches
toch is het ook wel een beetje "gedoe" allemaal.. en als je pech hebt, zit je te klooien en te pielen tot het wel werkt, right?
Mijn portfolio op Instagram
  • OgWok
Geen matches
RoyK schreef op woensdag 30 oktober 2013 @ 23:36:
Yeah, right ;)
  • SB249
  • Laatst online: 23:01
Geen matches
Daarom moet je ook hardware kopen uit de whitelist. Heb een jaar geleden zo'n systeem gebouwd puur als proof of concept. Werkte feilloos out of the box.
  • Luukwa
Luukwa
o/
Geen matches
Ik heb mijn hackintosh gebouwt uit oude hardware, werkt ook als een zonnetje.
Welliswaar iatkos gebruikt, maar dat maakt niet uit.
Soundcloud!
  • seninha
seninha
god's right foot
Geen matches
Precies. Als je de juiste hardware gebruikt dan ben je verzekerd van een goed draaiend Hackintosh.
Heb zelf alles 2de hands genomen en systeem draait als een zonnetje.
-gigabyte moederbord (UEFI)
-Intel i5 2500K
-120SSD Samsung
-16gb DDR3
-29" LCD + 17 LCD
Systeem draait dual boot met Windows 8.1.
Enige wat ik nog niet aan de praat gekregen heb is om via Chameleon Windows op te starten. Dit ligt gewoon aan het feit dat deze niet met UEFI om kan gaan. Heeft dus niets met OSX zelf te maken.
  • MelvinB
Geen matches
Net ff SmoothMouse geïnstalleerd op mijn Mavericks-hackintosh, "muizen" gaat nu veel beter merk ik.
Info:
http://www.insanelymac.co...ouse-mouse-behaviour-fix/
Download:
http://smoothmouse.com
  • xirerf
  • Laatst online: 12-10 10:04
Geen matches
Ik heb m'n hackintosh werkend!
i7 3770
HD 4000 768mb
Gigabyte h77-ds3h
Seagate Barracuda 1TB 7200rpm
Ik vroeg me alleen af of iemand hier toevallig ervaring heeft met USB wifi adapters? Ik kan wel het een en ander vinden op internet over usb wifi adapters, maar het is me nog steeds niet helemaal duidelijk welke er wel of niet werken. Mocht er hier iemand zijn die toevallig een goede ervaring heeft met een bepaalde adapter, dan hoor ik het graag. Anders gok ik er maar op dat die ik op internet kan vinden werken. Ik vraag het toch liever eerst even hier :)
seninha schreef op vrijdag 01 november 2013 @ 17:12:
-Intel i5 2500K
-120SSD Samsung
-16gb DDR3
-29" LCD + 17 LCD
Daar heb ik ook last van. Ik moet dan handmatig booten van de windows boot manager. Geen probleem, het voelt alleen net iets minder "af" nu. :P
[ Voor 40% gewijzigd door xirerf op 01-11-2013 22:35 ]
  • MelvinB
Geen matches
Heb deze op mijn oude klooi-Toshiba Satellite A200-1NH met OS X 10.7 in gebruik:
http://gembird.nl/item.aspx?id=6978&lang=nl
Werkt volgens mij met de 10.8-driver ook prima in Mavericks.
  • Slaiter
Slaiter
Firesnake
Geen matches
Wat mij in negatieve zin opvalt aan Maverick is dat mijn CLP320 printer niet meer werkt. Onder 10.8.5 installeerde de drivers automatisch onder Maverick echter gebeurd er niets ook niet met de 10.8 drivers jammer genoeg.
Verder loopt het als een zonnetje en draait alles zoals voorheen, met uitzondering van de printer dan.
  • xirerf
Geen matches
MelvinB schreef op vrijdag 01 november 2013 @ 22:45:
Ah oké, bedankt! Heb jij de drivers van 10.8 toevallig ergens gevonden? Kan ze alleen van 10.7 vinden..
  • MelvinB
Geen matches
bfrerix schreef op zaterdag 02 november 2013 @ 09:55:
Ik weet niet meer hoe ik aan de 10.8-versie kwam, mogelijk dat ik die van de bijgeleverde mini-cd heb gehaald.
Maar ik heb de driver ff voor je geupload: http://speedy.sh/4Xe6f/Gembird.zip
Is voor 10.6 en 10.8. De 10.8-versie werkt gewoon ook onder Mavericks. Net getest namelijk. :)
  • xirerf
Geen matches
Super! Bedankt :)
  • MelvinB
Geen matches
Geen probleem.
Is de adapter nog wel te koop trouwens? Zie wel staan op=op.
  • xirerf
Geen matches
Jep, dit moet 'm dan zijn geloof ik: http://afuture.nl/productview.php?productID=287615
15 euro, maargoed, dan is het ook klaar.
  • MelvinB
Geen matches
Deze zou ook moeten werken onder OS X: (staat bij driver-download op website fabrikant)
http://www.conrad.nl/ce/n...-20-Nano-adapter-150-Mbps
WinXP/Vista/7/Mac/Linux
  • xirerf
Geen matches
Jup, op internet staat dat die onder mountain lion moet werken, maar als jij die andere onder mavericks hebt getest dan speel ik liever op safe voor die paar euro's :)
Ik neem trouwens aan dat het ding ook gewoon onder mac verbinding kan maken met het WPA/WPA2 PSK netwerk hier?
[ Voor 25% gewijzigd door xirerf op 02-11-2013 16:32 . Reden: typo ]
  • MelvinB
Geen matches
Ja, dat wil prima.
-edit-
Wat je moet doen is zorgen dat uiteraard je USB-poorten werken op je Hackintosh.
Vervolgens de adapter er in steken en de driver installeren. Hierna moet je rebooten en zal er na het inloggen in OSX, een netwerktooltje in beeld komen. Die vraagt of je voor 1x in Systeemvoorkeuren, Netwerk wilt opstarten. Dan voegt ie de adapter toe. Daarna zal er een netwerktooltje tevoorschijn komen waarmee je je netwerk kan opzoeken en toevoegen als profiel. :)
[ Voor 92% gewijzigd door MelvinB op 02-11-2013 17:06 ]
  • xirerf
Geen matches
Fijn, bedankt voor de uitleg! Ik denk dat ik hem vanavond effe ga bestellen, dan hoop ik dat de stick na m'n laatste tentamen binnen komt, en niet er voor (haha, en dan zul je zien dat hij maandag ochtend om 9 uur op de mat ligt).
Ik zal nog effe laten horen of het werkt!
  • Mick1990
Geen matches
Iemand anders ook een spontaan hoge idle power consumption? Als mijn hackintosh met 10.9 Mavericks net is opgestart dan heeft deze een idle verbruik van zo'n 45W. Na een bepaalde tijd blijft hij ineens hangen bij 80W idle? Cpu is gewoon 0% in de task manager...
  • matty___
Geen matches
Mick1990 schreef op zaterdag 02 november 2013 @ 18:45:
Nu met UEFI en goede SSDT netjes 10W idle (i72600k)
  • iMick
Geen matches
Bedenk wel dat er nadelen zijn bij het gebruik van een USB WiFi adapter.. Hij wordt niet herkend als Airport / WiFi in Systeemvoorkeuren > Netwerk. Hierdoor kun je geen gebruik maken van locatie services in Apple Maps / Zoek mijn Mac etc.
En vaak heb je bij het opstarten ook een programma wat in beeld komt. Het werkt helaas niet met de native WiFi drivers.
Echter vaak wel een goedkoop alternatief. Zeker wanneer je geen vrije PCI(e) poorten meer hebt.
Geen matches
Hoe werkt die upgrade procedure precies?Ik heb gisteren geprobeerd 10.8.4 -> 10.9 te upgraden door een bootable unibeast usb te maken en dan de install over mijn 10.8.4 te gooien. Ik zag nergens dat hij aan het upgraden was, helaas kon ik nog niet booten, dus kan niet testen of het werkte, maar ik vermoed dat ik gewoon een kale install deed :(
ben nu een ccc naar usb aan het doen om het vanaf usb te fixen ipv harde schijven. Moet een bruikbaar systeem hebben en werk nu vanaf mijn ccc harddisk.
  • Henk
  • Laatst online: 29-09 12:24
Geen matches
Verwijderd schreef op zondag 03 november 2013 @ 10:34:
Timemachine backup maken, Mavericks installeren en je TM terugzetten, werkt hier altijd als een tierelier...
Mijn hackpro beest gaat binnenkort ook aan de upgrade, nu nog iets te hard nodig, en zo spannend vind ik Mavericks eigenlijk niet... macbook pro kwam er standaard mee, maar de verschillen zijn kleiner dan de vorige edities.
  • toos87
  • Laatst online: 11-10 19:36
Geen matches
Mocht iemand nog een usb wifi adapter zoeken.
Deze heb ik net van het weekend werkend gekregen onder Mavericks hackintosh.
ICIDU Nano USB Adapter 150N:
http://www.dixons.nl/comp...n.html?prs=1#.UnfIeflWym4
De driver kun je hier weghalen (RTL8188SU):
http://www.realtek.com.tw...false&Downloads=true#2287
[ Voor 3% gewijzigd door toos87 op 04-11-2013 17:26 . Reden: Omschrijving product ]
  • blouweKip
Geen matches
Ik kon na het booten met unibeast kiezen om mijn mountain lion install bij te werken of een nieuwe install te doen, hou er ook rekening mee dat je je bootloader moet upgraden als je dat nog niet gedaan had (anders boot 10.9 niet)
  • OgWok
Geen matches
blouweKip schreef op dinsdag 05 november 2013 @ 07:07:
Bootloader upgraden van welke naar welke versie? Of bedoel je Chameleon opnieuw installeren op de EFI partitie?
  • seninha
seninha
god's right foot
Geen matches
bfrerix schreef op vrijdag 01 november 2013 @ 22:30:
i7 3770
HD 4000 768mb
Gigabyte h77-ds3h
Je zou Clover EFI bootloader kunnen proberen. Deze schijnt met UEFI om te kunnen gaan.
Heb het zelf alleen niet aan de praat gekregen.
Als eerste heb ik het op een USB stick gezet en dan de Hackintosh vanuit USB laten starten, maar er gebeur niets. Data wat er in zit wordt niet gezien, dus Windows 8.1 start gewoon op.
Daarna heb ik deze op de OSX SSD geinstalleerd, boot volgorde aangepast maar dan start chimera op ipv Clover.
Geen idee waar om.
Moet er even meer tijd in steken.
  • blouweKip
Geen matches
De laatste werkt meestal wel, ik draai nu toevallig chameleon maar het zal ook opgaan voor andere (clover/chimeara)
Geen matches
Imessage werkt nog niet, heb de nvram module geinstalleerd, smbios op imac 13,2 gezet. Las ergens dat chimera vervangen moet worden door chameleon, zal dat was oplossen? Iemand nog een ander tip?
  • iMick
Geen matches
Wanneer je Chimera, een rip off, gebruikt dan heb je een grote kans dat iMessage nog steeds niet werkt. Gebruik gewoon Chameleon icm de NVRam module en het zal waarschijnlijk werken.
In de NVRam module is een slimmigheid ingebouwd die controleert of het Chameleon of Chimera is. De maker van de module ondersteunt TonyMac niet. Echter dacht ik dat MacMan (van TonyMac) als iets had ingebouwd, waardoor hij op sommige plekken Chameleon toont, om het te omzeilen.
Wanneer het met Chameleon nog niet werkt, dan is er mogelijk meer aan de hand. Denk aan een goed genereerde SMSerial (in je SMBios) en EthernetBuiltIn in je org.Chameleon.boot.plist.
  • manmetdehamer
  • Laatst online: 22:40
Geen matches
Ik heb mijn pc werkend gemaakt met multibeast + oxs 10.9
Het overgroote deel lijkt te werken, echter heb ik nog een vreemd probleem.
De USB 2.0 poorten op het moedebord doen het niet.
USB3 werkt wel en ook de poorten aan de voorzijde zijn functioneel.
Heeft iemand een idee wat het probleem kan zijn?
#ProductPrijsSubtotaal
1Intel Core i5 2500K Boxed€ 179,-€ 179,-
1Gigabyte GA-Z68X-UD3H-B3€ 99,95€ 99,95
1Zotac GeForce GTX560 Ti 448 Cores (ZT-50313-10M)€ 0,-€ 0,-
1Antec One Hundred€ 0,-€ 0,-
1Cooler Master Hyper 212 EVO€ 24,95€ 24,95
1Antec H2O 620€ 53,60€ 53,60
1Cooler Master Blade Master 120MM/25MM PWM, 120mm€ 7,95€ 7,95
3Nexus 120MM PWM Series Real Silent Case Fan, 120mm€ 6,05€ 18,15
1Corsair Vengeance LP CML8GX3M2A1600C9€ 75,68€ 75,68
1Sony Optiarc AD-7280S Zwart€ 0,-€ 0,-
1Corsair Builder CX500 V2€ 0,-€ 0,-
Bekijk collectie
Importeer producten
Totaal€ 459,28
Geen matches
iMick schreef op dinsdag 05 november 2013 @ 12:14:
het werkt, ik moest handmatig die filenvram erin zetten 1.1.3 ipv via chameleon bootlader. Ook heb ik lan naar server 0 gedaan ipv 1. Werkt nu, ik ben blij
nu nog een fix voor het multimon probleem, hij onthoudt niet waar mijn vensters stonden op welke monitor enzo. alleen enkele vensters wel. heel vreemd
parallels bootcamp doet ook vreemd, soms moet ik mijn bootcamp harddisken opnieuw koppelen want anders doet hij niks?
[ Voor 5% gewijzigd door Verwijderd op 05-11-2013 13:57 ]
Geen matches
beste tweakers ik wil van mijn windows 7 deskop een hackintosh maken
nu is het mij al gelukt om via iatkos een boot cd te maken en ook te booten maar als ik bij het installatieprogramma aankom reageert mijn usb muis niet meer kan ik alleen maar via toetsenbord werken
instellingen zoals ahci enzo staan allemaal juist maar dus geen usb support voorlopig
specs van mijn pc zijn
quadcore intel core i 5 750
8 gig ram
1 terabyte opslag
nvidia geforce gt 440 1024 mb
alvast bedankt voor snelle reacties
  • xirerf
Geen matches
Je moederboard is belangrijk. Welke heb je?
  • xirerf
Geen matches
MelvinB schreef op zaterdag 02 november 2013 @ 17:03:
Ja, dat wil prima.
-edit-
Dit lijstje even gevolgd en het werkt perfect! Stabiele internet snelheid van ongeveer 2Mb/s, dus zeer prima gezien het feit dat de router op de begane grond staat en de pc op de tweede verdieping. Ik moet wel zeggen dat ik hem eerst in de achterkant van mn computer had zitten en dit extreem trage verbinding gaf, denk aan 40kb/s met uitschieters van 100kb/s en 10kb/s... Vervolgens een willekeurige usb-kabel van een meter gepakt, het wifi-stickje een meter van de computer af gelegd en voila, het werkt perfect! Ook na een cold boot wordt er automatisch verbinding gemaakt :)
-EDIT-
Net Mavericks aan het werk gekregen. Waar anderen het verschil niet extreem groot vind voelt Mavericks voor mij echt aanzienlijk soepeler -natuurlijke mede doordat mavericks op mijn ssd staat en mountain lion op mijn hdd. Vooral het resizen van vensters, zoals bijvoorbeeld safari, was in mountain lion echt dramatisch, in mavericks ziet het er heel smooth uit!
[ Voor 13% gewijzigd door xirerf op 07-11-2013 00:51 ]
Geen matches
@ bfrerix
net nagekeken mijn moederbord is gigabyte h55m s2h
ik heb het ondertussen ook al geprobeerd met kakewalk maar daar boot hij naar installer en dan blijft hij uren hangen zonder iets te installeren
alvast bedankt
  • Mick1990
Geen matches
Een H55M is geen UEFI moederbord, meestal lukt het booten met dit regeltje:
GraphicsEnabler=Yes PCIRootUID=1
Mocht dat niet lukken, probeer dan te booten met:
-v
en post een foto nadat je geen nieuwe regels meer ziet verschijnen of ergens ERROR of Kernel_Panic ziet staan.
Geen matches
ook via myhack geprobeerd en ook hier boot hij maar eenmaal bij osx installer weigert hij te installeren zal mijn hackintosh plannen maar opbergen tenzij er iemand dicht rond antwerpen zou wonen en nog wat vrije tijd heeft voor mijn systeem te voorzien van osx natuurlijk wordt dit vergoed ik hoor het wel en desnoods wordt het gewoon een echte imac of mac mini die mijn macbook pro vergezelt
  • Kwak
  • Laatst online: 17-09 19:36
Geen matches
@Kajou
Interpunctie maakt je tekst beter leesbaar.
Wat gebeurt er als je in je installer zit? Doet je muis het niet, krijg je foutmeldingen? Heb je wel een lege schijf met juiste formattering (Mac OS Extended (Journaled))? Niet te snel op geven. Na enig gepruts kom je er vrijwel altijd uit.
Specs
  • Mick1990
Matched: tonymacx86
Niet zomaar opgeven inderdaad; een H55M is prima werkend te krijgen. Zelf ben ik geen fan van 'distributies' zoals kakewalk, myhack, iAtkos etc die je op usenet / torrents kunt vinden. in 2011 heb ik ook een H55M hackintosh gehad en toen lukte het ook niet met zulke distributies. Maar nadat ik een Snow Leopard DVD bij Apple had gekocht, lukte het meteen!
Ik kan je dan ook aanraden om voor het zeer lage bedrag van €18 een Snow Leopard DVD te kopen: http://store.apple.com/nl...mac-os-x-106-snow-leopard
Als je dan dit stappenplan volgt dan moet het gewoon lukken: http://tonymacx86.blogspo...-install-mac-os-x-on.html
Geen matches
@ kwak
hij komt op installatie van osx en begint onderaan gewoon rond te draaien maar na 1 uur blijft het hetzelfde doen
ik heb nu wel nog mijn harde schijf niet geformatteerd moet ik dit al doen door het uit de pc te halen en formatteren met mac of zijn er nog andere fouten
muis herkent hij ook niet meer
ik ga het misschien gewoon proberen met de snow leopard dvd zoals mick aanhaalt misschien is dat nog simpelste manier
alvast bedankt
  • OgWok
Geen matches
Heb hier een ML installatie 10.8.5 op een H67M-D2-B3. Via myHack 3.3.1.
Draait prima; ook Safari erg snel. Behalve geluid. Kan geen goede kext vinden voor de ALC889 die op het bord zit (met 10.7.5 geen probleem met geluid). Gebruik wel een DSDT.aml (maar die is niet zo goed dat het geluid werkt)
Asus GT630 met 2GB mem wordt ook netjes herkend :)
Iemand een idee/tip of een oplossing voor het geluid?
  • matty___
Geen matches
OgWok schreef op dinsdag 26 november 2013 @ 15:01:
Al wel een keer de multibeast route probeert met de kext en HDAenablers die daar bij zitten?
Of VooDoo hoewel ik daar zelf geen ervaring mee heb schijnt het wel te werken
  • Dreamvoid
Geen matches
Multibeast draaien en de patched 889 kext kiezen, dat werkt met dit bord.
  • harmz
  • Laatst online: 09-09 14:19
Geen matches
Ik probeer op dit moment iAtkos ML2 te instaleren. Helaas blijft na een kwartier het wieltje hangen. 3 kwartier daarna kon ik de taal kiezen wat enorm traag was. Daarna kreeg ik de foutmelding: The mac OSx installation couldn't be completed. Iemand een idee wat het zou kunnen zijn?
  • OgWok
Geen matches
Dreamvoid schreef op dinsdag 26 november 2013 @ 18:09:
Heb MultiBeast 5.4.3 en 5.5.5 getest en nog geen geluid. Over welke versie heb jij het?
  • Mick1990
Geen matches
Heb je al gekeken in 'Systeemvoorkeuren' en dan 'Geluid' in OSX zelf? Bij het tabblad 'Uitvoer' moet dan 'Interne luidsprekers' geselecteerd zijn. Volgens mij staat hij standaard op 'Digitale uitvoer'.
  • harmz
Geen matches
Is er een mogelijkheid om een extern display uit te zetten? Ik heb mijn tv via hdmi aangesloten. Maar als die uit is. Dan blijven er programma's "verdwijnen" naar de uitstaande tv.
  • TweakedTea
  • Laatst online: 16-08-2025
Geen matches
Je kunt de display normaal gezien verwijderen, heb ik ook gedaan met mijn tv, is helaas wel al een tijdje geleden.
Voor de mensen hier, mijn Hackintosh draait als een zonnetje.
Specs:
i5 3570K
MSI Z77A-GD65
Corsair Vengeance 8GB 1600MHz.
GTX 470.
Alles werkt perfect. ( Op Bootcamp na dan, maar dat werkt zuwiso niet ).
Geen matches
TweakedTea schreef op woensdag 11 december 2013 @ 09:59:
Specs:
i5 3570K
MSI Z77A-GD65
GTX 470.
neem aan dat je wel gewoon dual boot werkt? Want bootcamp parallels/fusion werkt perfect hier.
  • pBook
  • Laatst online: 16-05 20:02
Geen matches
Aan de hand van de Buyer's Guide November 2013 van Tonymac heb ik dit lijstje samengesteld.
1Intel Core i7 4770S Boxed€ 244,94€ 244,94
1Gigabyte GA-Z87-HD3€ 91,-€ 91,-
1MSI N660 TF 2GD5/OC€ 159,99€ 159,99
1Seagate Barracuda 7200.14 ST3000DM001, 3TB€ 96,-€ 96,-
1Cooler Master Silencio 652€ 88,50€ 88,50
1TP-Link TL-WDN4800€ 32,95€ 32,95
2Dell Ultrasharp U2312HM Zwart€ 178,90€ 357,80
1Scythe Big Shuriken 2 Rev. B€ 31,-€ 31,-
1Crucial Ballistix Tactical BLT2CP8G3D1608DT1TX0CEU€ 115,60€ 115,60
1Seasonic S12G 650W€ 88,40€ 88,40
2Crucial 2.5" M500 120GB€ 74,99€ 149,98
Bekijk collectie
Importeer producten
Totaal€ 1.456,16
Ik twijfel nog over de SSD configuratie. Ik was van plan twee SSD's in RAID 0 te zetten, maar misschien ben ik beter af met 1 SSD van 256GB. Belangrijk is vooral stilte en genoeg power voor grote muziekproducties in Logic Pro (er komt een externe audio interface aan te hangen). Iemand nog suggesties of verbeteringen? ;)
  • br13an
Geen matches
pBook, er is geen optie om met ethernet (bekabeld) te werken?
Ook die Seagate barracuda's zijn niet heel stil, heb zelf ook een en vindt dattie toch nog wel wat lawaai heeft als je heb vergelijkt met bijvoorbeeld de WD Red schijven.
Als er een stille voeding in moet zou ik ook overwegen om wellicht een Bequiet voeding te nemen, behoorlijk stille voedingen imo.
  • Hokkie
  • Laatst online: 13-10 20:24
Hokkie
Hello
Geen matches
pBook schreef op vrijdag 13 december 2013 @ 10:48:
Een alternatief zou kunnen zijn dat je een ssd gebruikt voor het 'systeem' en een ssd voor je 'gebruikers mappen'.
hier een linkje hoe je dat kunt doen, werkt erg!! snel:
http://computers.tutsplus...rive-or-volume--mac-48822
 MacBook Air M2  Apple TV 4 64GB  HomeKit  iPhone 13 Pro  Apple Watch Ultra || Pass Labs XA25 || Dynaudio Special Forty || Bluesound Node n130
  • TweakedTea
Geen matches
@TennisBal
Ik bedoel de ´´Bootcamp´´ functie in OS X zelf. Deze werkt alleen op een echte Mac :)
Ik draai geen Windows.
  • blouweKip
Geen matches
pBook, raid-0 heeft toch alleen maar zin als je regelmatig tegen de limiet van SATA-600 zit, als dat in het dagelijks gebruik geen probleem vormt zou ik gewoon voor 1 schijf gaan.
  • Mick1990
Geen matches
@pBook: een 650W voeding is te veel van het goede. Ik heb een pricewatch: Seasonic M12II 520W en zelfs dat is eigenlijk al overkill. Ik heb een i5 4670K en een 660Ti, en mijn systeem verbruikt hooguit 250W.
SSD in RAID0 zou ik niet doen. Uit benchmarks blijkt namelijk dat je er weinig van merkt als gebruiker. Dan kun je voor die €150 beter één SSD nemen pricewatch: Samsung 840 EVO 250GB nemen.
De 660 GPU werkt overigens prima, ook met dual monitor.
  • pBook
Geen matches
Bedankt voor de tips! Wat betreft de WiFi-kaart: die is 'voor het geval dat', ik ga ervan uit dat ik de onboard ethernet het vaakst gebruik. Ik heb de voeding, SSD en harde schijf aangepast. Ik heb zelf veel betere ervaringen met Seagate dan met WD, dus ik ben daar een beetje huiverig mee haha :)
Dit is de nieuwe lijst:
1Intel Core i7 4770S Boxed€ 234,95€ 234,95
1WD Red SATA 6 Gb/s WD20EFRX, 2TB€ 86,85€ 86,85
1Seasonic S12G 550W€ 72,10€ 72,10
1Samsung 840 EVO 250GB€ 139,64€ 139,64
Bekijk collectie
Importeer producten
Totaal€ 1.410,38
Nog tips voor het geheugen of om dit setje nog stiller te krijgen?
  • Mick1990
Geen matches
De Scythe Big Shuriken 2 is een hele stille koeler:
http://nl.hardware.info/r...sultaten-geluidsproductie
De grootste boosdoener zal de harde schijf zijn, maar ook de WD Red is behoorlijk stil:
http://nl.hardware.info/r...or-nasen-geluidsproductie
Je kan natuurlijk ook instellen dat de harde schijf in sleep modus gaat als je hem niet gebruikt. Ik heb vrijwel een vergelijkbaar systeem in geluidsproductie, en als de harde schijf in sleep mode gaat dan kan ik de PC gewoon niet horen. Best wel eng af en toe :+
Om de doorzoekbaarheid te verbeteren moeten problemen en specifieke vragen in een apart (nieuw) topic: MS Beleid. Gebruik dan wel de ~~~[OSx86] tag!
Het verkrijgen van OS X mag niet worden besproken.
