[SETI@Home] hitparade van 26 juni Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 21:13
APClll
FP ProMod
[DPC] Team Grazzie
Wat is nou een luch zonder verse cijfertjes? Juist...
Daarom speciaal voor vandaag: vers uit uw Seti-kantine, het stats-menu. Uiteraard voorzien van een bekertje verse melk. We hebben die koeien tenslotte toch.
Uiteraard hebben we ook een mooi dienblad, voorzien van zo'n flutpapiertje met de laatste nieuwtjes. Zie hieronder.
26 Jun 2008 21:07:44 UTC
The new scheduler continues to be handling its new duties just fine. Slowly but surely people are moving their connections over to this new server, but I'm not convinced the change rate is fast enough to do a whole sale cutover by next week. We shall see.
Funny aside: while getting new-ish donated server "clarke" up yesterday I was annoyed to find that Fedora Core 9 was booting to run level 5 (where it loads the X windowing environment). We don't need X on these servers, so we typically set our servers to boot to run level 3 via a change in /etc/inittab. In doing so, I'd comment out the old line with a "#" and enter in a new line with the adjusted run level. It was still booting up in X. Why? Turns out the latest inittab parser (new with FC9, I guess) ignores "#" comments in inittab, and just looks for lines containing the string "initdefault" and parses the first one it finds. Since I left the old line in there commented out (or so I thought) it was superseding the line I wanted. So much for standards (and clear documentation stating when/how standards change).
Nitpicker weirdness: While finally getting around to testing the few optimizations I made to Jeff's code I found that multiple runs of the nitpicker on the same pixel were producing slightly different results each time. We believe this is due to the order which the database pulls out rows - unless requested otherwise databases generally pull things out in random order, i.e. the order which requires the least I/O at that exact point in time (mostly due to page caching or where the many drive arms are currently located in our RAID set). Sorting query output adds significant (and usually unnecessary) overhead. But there are a lot of "fuzzy compares" in the nitpicker (due to floating point computations on different chips you can't expect decimal values to be "exactly exact"). When two items are close enough to be called "duplicates" you only need one, but which one you pick may cause different results down the road. So Jeff is elbow deep in this problem right now.
Apropos of nothing, the entire northern half of state of California is on fire. The smoke ending up here in the Bay Area is intense. I feel like I'm smoking a couple packs a day just walking around outside. I can smell it sitting here at my desk.
- Matt
Eet smakelijk allemaal! :Y)
PS, als uitsmijter serveren wij de bekende mijlpaal :*)
DPC SETI@Home hitparade van 26 juni 2008
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 122 / 844 (14,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.208[DPC] Switch3.677.747(6)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.860[DPC]TeamGrazzie7.767.758(3)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.612hansR10.088.106(1)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.207Sp@ceNv@der7.287.806(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.143AmeComputers318.363(48)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)9.018Ensign Wildfire1.379.623(10)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.693Searchy! Internet Services V.O.F.5.067.162(5)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)7.659o25o & Dharkon3.202.509(7)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)5.336Mr Beamer767.558(21)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.293Jox444241.790(57)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.242MAX34001.067.601(13)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.205F@stmem840.989(19)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.136[DPC]Trancemaus1.689.984(9)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.104Override463.123(30)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)2.589ray333.784(47)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.370herr_bernd60.597(123)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.028nouen36.954(164)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.934holy-shit344.606(43)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.781[DPC]Team Zuid-Holland1.296.973(11)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.602Robin Ovaere78.132(107)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.571Binno72.737(114)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.441Berkie821.985(20)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)1.402Asgoroth68.807(116)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.381Dellape37.138(160)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.352Administrator266.930(53)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.231Edwin van der Geest208.190(63)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)1.223Dr.Drax381.404(38)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.022dr bommel33.999(172)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)910Krispy50.520(135)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)908[DPC] Brainy007274.617(51)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.088.106hansR19.612(3)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.117.462REISinformatiegroep0(-)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.767.758[DPC]TeamGrazzie25.860(2)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.287.806Sp@ceNv@der19.207(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.067.162Searchy! Internet Services V.O.F.8.693(7)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.677.747[DPC] Switch33.208(1)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.202.509o25o & Dharkon7.659(8)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.420.397[DPC]Spinpoint672(39)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.689.984[DPC]Trancemaus3.136(13)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.379.623Ensign Wildfire9.018(6)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.296.973[DPC]Team Zuid-Holland1.781(19)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.269.018Jan Zandvliet & x-RaY99110(89)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.067.601MAX34005.242(11)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.067.010Speedy67 & Friends537(45)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.065.635visvogel720(37)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.043.115[DPC] Anticimex & Lock Metaaldetectie0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)961.852Tijntje641(42)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)840.989F@stmem3.205(12)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)821.985Berkie1.441(22)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)767.558Mr Beamer5.336(9)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)673.789Psyed0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)626.758Rydo428(51)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)626.692MaNDaRK0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)623.557Dadoke305(64)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)494.866Zwahillius0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)472.183dpijl100(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)470.775Team_Elteor_Borislavj0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)469.595ADHD NL0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)463.123Override3.104(14)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.387.938SETI.USA695.888.041(1)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)227.009Team MacNN145.973.638(12)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)211.279Canada91.656.646(23)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)210.034Amateur Radio Operators80.051.258(30)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)206.374PC Perspective Killer Frogs80.767.252(29)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)203.564Team Art Bell151.003.995(10)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)198.514BOINC@AUSTRALIA76.986.122(31)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)193.864UK BOINC Team82.618.155(26)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)180.044Dutch Power Cows83.740.515(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)175.069Phoenix Rising101.407.456(21)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)172.704BOINC SETI@home RUSSIA74.249.952(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)169.077Elite Games52.975.624(44)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)159.908BOINC@Denmark68.147.114(35)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)153.765AUSTRIA - NATIONAL - TEAM82.528.910(27)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)143.562Team NIPPON72.322.446(33)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)128.477Ars Technica110.476.641(20)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)695.888.041SETI.USA1.387.938(1)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)113.192.828BOINC.Italy111.803(38)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)111.804.636TeAm AnandTech303.683(11)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)110.476.641Ars Technica128.477(35)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)101.407.456Phoenix Rising175.069(29)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)94.564.765Universe Examiners113.939(37)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)91.656.646Canada211.279(22)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)87.676.222US NAVY285.497(14)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)83.740.515Dutch Power Cows180.044(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)82.618.155UK BOINC Team193.864(27)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)82.528.910AUSTRIA - NATIONAL - TEAM153.765(33)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)81.172.590U.S.Air Force275.956(16)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)80.767.252PC Perspective Killer Frogs206.374(24)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)80.051.258Amateur Radio Operators210.034(23)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)76.986.122BOINC@AUSTRALIA198.514(26)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)74.249.952BOINC SETI@home RUSSIA172.704(30)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.REISinformatiegroep165.30718-04-2007
5.hansR124.71718-04-2007
More...
Mijlpalen
[DPC]TeamGrazzie7.750.000
herr_bernd60.000
Krispy50.000
madmax10.000
server7.000
Toaby5.000
Amplified4.000
Joey2.000
When do you get them
TeamAverageDays
Universe Examiners122.229156
BOINC.Italy117.524398
Ars Technica160.340859
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
[ Voor 6% gewijzigd door APClll op 27-06-2008 12:33 ]
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • Amplified
  • Laatst online: 13:54
mn quad uier }:O graast lekker door hoor :)
zit al weer bijna @ 6000 :)
gefeli mede mijlpaalhalers, hopeijk smaken we lekker als uitsmijter 8)7
  • krispy
  • Laatst online: 01-11 21:48
krispy
weet het ook niet meer
Lekker toetje hoor... 50K :)
Het zal trouwens vanaf heden wat langzamer gaan, want ik heb tegenwoordig ook Rosetta toegevoegd. (Aan de ander kant krijg ik er waarschijnlijk binnen kort nog een dual-core koetje bij)
Mede paalhalers ook feli *O*
hmm.. that's interesting..
  • Bassie1978
  • Laatst online: 25-06 11:24
Bassie1978
Bassie
APC dank weer voor de stats _/-\o_
Gefeliciteerd mijlpaalhalers *O* (Ik feliciteer mezelf met mijn 800K paal :D)
..::www.pug205.nl::..
