Ik heb mijn post al aangepast bedankt voor de tip
ik heb ff wat verder gepru
tst en dit is nu mijn eth1:
eth1 Link encap:Ethernet HWaddr 00:02:02:31:xx:xx
inet addr:10.249.9x.xx Bcast:10.249.95.255 Mask:255.255.252.0
inet6 addr: fe80::202:2ff:fxxxx:dxxxx/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packe
ts:1422 errors:0 dropped:0 overruns:0 frame:0
TX packe
ts:2572 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:268380 (262.0 KiB) TX bytes:671968 (656.2 KiB)
als ik igmpproxy draai krijg ik dit:
adding VIF, Ix 0 Fl 0x0 IP 0xa501a8c0 eth0, Threshold: 1, Ratelimit: 0
adding VIF, Ix 1 Fl 0x0 IP 0x0d5cf90a eth1, Threshold: 1, Ratelimit: 0
joinMcGroup: 224.0.0.2 on eth0
RECV Membership query from 192.168.1.165 to 224.0.0.1
Inserted route table entry for 239.255.255.250 on VIF #-1
RECV V2 member report from 192.168.1.180 to 239.255.255.250
Updated route entry for 239.255.255.250 on VIF #0
Adding MFC: 192.168.1.5 -> 239.255.255.250, InpVIf: 1
joinMcGroup: 239.255.255.250 on eth1
RECV V2 member report from 192.168.1.10 to 239.255.255.250
tcpdump op eth1 geeft dit:
.0.224.in-addr.arpa. (41)
04:27:03.185448 IP 82.139.121.131.domain > 10.249.92.13.44383: 10702 NXDomain* 0/1/0 (91)
04:27:03.185853 IP 10.249.92.13.59918 > 82.139.121.131.domain: 15162+ PTR? 211.245.254.169.in-addr.arpa. (46)
04:27:03.193771 IP 82.139.121.131.domain > 10.249.92.13.59918: 15162 NXDomain* 0/1/0 (81)
04:27:03.194240 IP 10.249.92.13.58943 > 82.139.121.131.domain: 25998+ PTR? 1.92.249.10.in-addr.arpa. (42)
04:27:03.202150 IP 82.139.121.131.domain > 10.249.92.13.58943: 25998 NXDomain* 0/1/0 (92)
04:27:03.202378 IP 10.249.92.13.34464 > 82.139.121.131.domain: 42377+ PTR? 13.92.249.10.in-addr.arpa. (43)
04:27:03.210216 IP 82.139.121.131.domain > 10.249.92.13.34464: 42377 NXDomain* 0/1/0 (93)
04:27:03.210858 IP 10.249.92.13.58621 > 82.139.121.131.domain: 64152+ PTR? 131.121.139.82.in-addr.arpa. (45)
04:27:03.218727 IP 82.139.121.131.domain > 10.249.92.13.58621: 64152 NXDomain* 0/1/0 (95)
routes:
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
10.249.92.0 0.0.0.0 255.255.252.0 U 0 0 0 eth1
0.0.0.0 10.249.92.1 0.0.0.0 UG 0 0 0 eth1
Welke route moet er aangemaakt worden?
