Informatie Processor/Moederbord
  • 344 views
Hey,
Ik zou graag een nieuwe processor in mijn moederbord steken. Wat zijn momenteel de beste processoren van Intel? Welke kan ik in mijn moederbord steken?
Hier zijn de gegevens van mijn moederbord:
MS-7204 mBTX Mainboard
Mainboard Specifications
CPU†
* Supports Intel® Pentium 4/ Celeron D Prescott LGA775 processors (Prescott
and Smithfield) in LGA775 package.
* Supports 2005 Performance FMB CPU VR Design.
* Supports 3/4 pin CPU Fan Pin-Header with Fan Speed Control.
* Supports up to Pentium 4 3XX, 5XX, 6XX & 8XX (Prescott and Smithfield)
Chipset
† Intel® 945P chipset
- Supports FSB 533/ 800/1066MHz.
- Supports PCI Express x16 graphics interface.
- Supports DDR2 533/667
† Intel® ICH7/ICH7R chipset (optional)
- Hi-Speed USB (USB2.0) controller, 480Mb/sec, up to 8 ports.
- 4 SATAII ports with transfer rate up to 3Gb/s.
- 1 channel Ultra ATA 100 bus Master IDE controller.
- PCI Master v2.3, I/O APIC.
- ACPI 2.0 Compliant.
- Serial ATA RAID 0, RAID 1, RAID 10, RAID 5 and Matrix RAID. (for ICH7R)
- Integrated AHCI controller (ICH7R).
Main Memory
† Supports four unbuffered DIMM of 1.8 Volt DDR2 SDRAM
† Supports up to 4GB memory size.
† Supports Dual channel DDR memory architecture.
† Supports DDR2 533/667 memory interface.
Slots
† One PCI Express x16 slot.
† One PCI Express x1 slots.
† Two 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
† The second PCI slot (PCI 2.2, in green color) supports 3 devices.
On-Board IDE
† One Ultra DMA 66/100 IDE controllers integrated in ICH7/ICH7R.
- Supports PIO, Bus Master operation modes.
† SATAII controller integrated in ICH7/ICH7R.
- Up to 300MB/sec transfer speed.
- Can connect up to four SATAII devices.
- Supports AHCI controller with SATA Raid 0, Raid 1 and Matrix Raid (ICH7R).
On-Board Peripherals
† On-Board Peripherals include:
- 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 Line-In / Front-Out / Side Surround / Center Bass / Back Surround
- 1 coaxial SPDIF-Out / SPDIF-In / Optical SPDIF-Out / SPDIF-In
- 8 USB ports (Rear * 4/ Front * 4)
- 1 RJ-45 LAN jack
LAN
† Intel 8100C
- Supports 10 / 100 Mb/s.
1394(optional)
† Supports two IEEE1394 onboard pinheader. Transfer rate is up to 400 Mbps.
† Controlled by VIA VT6307 chip.
Audio
† High Definition link controller integrated in Intel® ICH7/ICH7R chip.
† 7.1 + 2 channels audio codec Realtek ALC882.
- Compliant with Azalia 1.0 Spec.
BIOS
† The mainboard BIOS provides “Plug & Play” BIOS which detects the peripheral
devices and expansion cards of the board automatically.
† The mainboard provides a Desktop Management Interface (DMI) function which
records your mainboard specifications.
Mounting and Dimension
† mBTX Form Factor: 26.7 cm x 26.5 cm
† 7 mounting holes
Als mijn moederbord geen Core Duo of beter(??) aankan, dan ben ik bereid een nieuw aan te schaffen. Wat gaat mij dit dan kosten?
Alvast bedankt,
Ashwin
  • Rone
Rone
Moderator Tweaking
Begin eens met een kijkje in PMG FAQ » Welke processor moet ik nemen? :)
PC1: 9800X3D + RX 9070 XT
PC2: 5800X3D + RTX 3080
  • Nielson
  • Laatst online: 17:35
  • dion_b
  • Laatst online: 15:55
dion_b
say Baah
PMG Beleid
1) zie dat stukje over ellenlange uitdraai? We vragen specs. Specs worden door mensen geschreven. Alleen een uitdraai als dit geeft aan dat je zelf 0,0 moeite gestoken om te begrijpen wat je onder ogen hebt, dus per definitie voldoet een topicstart als dit niet aan de eisen die we op GoT stellen qua zelfwerkzaamheid.
2) we hebben niet voor niets een FAQ geschreven, sowieso zijn "welke ... moet ik kopen?"-topics op GoT niet de bedoeling. Een Tweaker kan zelf mogelijkheden opzoeken, eisen stellen, reviews en ervaringen lezen en dan zelf kiezen.
Oslik, blyat! Oslik!
