[NAS] wd netcenter
  • 491 views sinds 30-01-2008
Gisterenavond crashte mijn netcenter (500GB) spontaan
Ik kan nog wel de beheer in maar kan de data niet meer benaderen
Is er nog redding mogelijk?
hieronder het S.M.A.R.T. Rapport:
Device: WDC WD5000YS-01MPB0 Supports ATA Version 7
Drive supports S.M.A.R.T. and is enabled
Attribute ID 5 Failed
Attribute ID 7 Failed
Please save all data and call drive manufacture immediately.
General Smart Values:
Off-line data collection status: (0x84) Offline data collection activity was
suspended by an interrupting command
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run
Total time to complete off-line
data collection: (14400) Seconds
Capabilities: (0x7b)SMART EXECUTE OFF-LINE IMMEDIATE
Automatic timer ON/OFF support
Suspend Offline Collection upon new
command
Offline surface scan supported
Self-test supported
Smart Capablilities: (0x0003) Saves SMART data before entering
power-saving mode
Supports SMART auto save timer
Error logging capability: (0x01) Error logging supported
Short self-test routine
recommended polling time: ( 2) Minutes
Extended self-test routine
recommended polling time: ( 178) Minutes
Vendor Specific SMART Attributes with Thresholds:
Revision Number: 16
Attribute Flag Value Worst Threshold Raw Value
( 1)Raw Read Error Rate 0x000f 200 200 051 0
( 3)Spin Up Time 0x0003 224 218 021 5791
( 4)Start Stop Count 0x0032 097 097 000 3507
( 5)Reallocated Sector Ct 0x0033 104 104 140 764
( 7)Seek Error Rate 0x000f 001 001 051 37235
( 9)Power On Hours 0x0032 085 085 000 11239
( 10)Spin Retry Count 0x0013 100 100 051 0
( 11)Calibration Retry Count 0x0012 100 253 051 0
( 12)Power Cycle Count 0x0032 100 100 000 37
(190)Unknown Attribute 0x0022 054 036 045 46
(194)Temperature 0x0022 253 253 000 47
(195)Hardware ECC Recovered 0x000e 001 001 000 50382896
(196)Reallocated Event Count 0x0032 163 163 000 37
(197)Current Pending Sector 0x0012 200 200 000 0
(198)Offline Uncorrectable 0x0010 200 200 000 0
(199)UDMA CRC Error Count 0x003e 200 200 000 0
(200)Unknown Attribute 0x0009 200 200 051 0
SMART Error Log:
SMART Error Logging Version: 1
Error Log Data Structure Pointer: 02
ATA Error Count: 592
Non-Fatal Count: 0
Error Log Structure 1:
DCR FR SC SN CL SH D/H CR Timestamp
00 00 08 4c 42 5f 38 25 64
00 00 08 4c 42 63 38 25 64
00 00 08 4c 42 67 38 25 64
00 00 08 4c 42 6b 38 25 64
00 00 08 4c 42 6f 38 25 64
00 40 08 4c 42 6f e0 51 0
Error condition: 0 Error State: 3
Number of Hours in Drive Life: 11224 (life of the drive in hours)
Error Log Structure 2:
00 00 08 4c 42 5f 38 25 59
00 00 08 4c 42 63 38 25 59
00 00 08 4c 42 67 38 25 59
00 00 08 4c 42 6b 38 25 59
00 00 08 4c 42 6f 38 25 59
Error Log Structure 3:
00 00 10 ea 00 00 00 24 92
00 00 10 ea 00 00 00 24 93
00 00 08 f2 00 00 00 24 93
00 04 08 f2 00 00 e0 61 0
Error Log Structure 4:
Error Log Structure 5:
00 00 08 4c 42 5f 38 25 58
00 00 08 4c 42 63 38 25 58
00 00 08 4c 42 67 38 25 58
00 00 08 4c 42 6b 38 25 58
00 00 08 4c 42 6f 38 25 58
  • ChrisVrolijk
  • Laatst online: 28-09 09:34
En.. ik heb namelijk het zelfde met alleen ID 5
  • buggienuk
  • Laatst online: 02-10 10:49
buggienuk
lekker buggie
ChrisVrolijk schreef op donderdag 15 mei 2008 @ 17:58:
zie OM FAQ / Beleid, staat een leuk stukje in over datarecovery.
Vooral dit stukje;
Tips: er zijn hier goede ervaringen gemeld met op alfabetische volgorde Easy Recovery, File Scavenger, GetDataBack, R-Studio, Stellar, UFS Explorer en VirtualLab. Goede freeware datarecoveryprogrammaatjes zijn FindNTFS, Restoration en Testdisk. Voor flashkaarten is Digital Image Recovery een uitkomst. Wanneer jouw OS zodanig is gecrasht dat je niet meer in je OS kunt komen en je geen andere PC voorhanden hebt om de schijf te overzetten, dan zou je Knoppix kunnen proberen. Dat is een Linux-based besturingssysteem dat volledig vanuit de CD opereert. Er is ook een brandprogramma meegeleverd (K3M). Wanneer er redelijke haast bij is (HDD ligt op sterven, etc) en/of wanneer je zo snel nog geen andere harddisk hebt om ernaar te backuppen, dan kun je het beste met o.a. Ghost een image maken van de harddisk.
Ook bekend op XBL als buggienuk
