Asus A7V 1006 Bios is uit !!!
  • 133 views sinds 30-01-2008
  • Jake
  • Registratie: September 1999
Hier staat dus de allernieuwste telg uit de A7V bios familie!
Of als je in een keer wilt downen: A7V1006
Ik ga straks (later vanmiddag) downen en flashen, als je kan wachten dan wacht je, zo niet, dan flash je zelf, graag ervaringen posten natuurlijk
  • Jake
WHOAH!!!
ik lees net in newsgroup:
1006 screwed up my system. floppy would not boot. win2k pro returned blue screen of death. i booted winme from cdrom and was able to flash 1005D much much better. what idiots they are to post that trash !
ben ik ff blij dat ik dat eerst gelezen heb...
edit (extra meldingen, van anderen):
This BIOS screwed up my system. I was lucky to be able to boot off the
CD-Rom because I was unable to boot off the hard drive or floppy drive. I
then was able to reflash to 1005d. Whewww!!!!!!!
Good luck to those that still try and I hope they have better luck than me.
It's strange though because I've not had any problems flashing the BIOS on
this motherboard many times before.
Damn!
Flashing to 1006 killed my machine! Now the bios hangs on post while testing
the memory!
I hope a hardware-cmos reset will fix the thing. Otherwise I'm screwed!!!
Seba
Totally messed up my system - had to clear CMOS on the motherboard just to
get it to boot !
Don't pannic because you'll be fine.
Just boot off your cd-rom with a win98 disk and then put the floppy disk you
use to flash with in your drive and flash back to an older BIOS version.
Remember that after you boot off the cdrom your floppy drive may be letter
b: now.
Asus already fucked up with 1005 final. I'm going to kill all of them!!!! Do
some testing before releasing this shit dammit!!!!!
Seba
  • Triple-D
  • Laatst online: 09-08-2023
Ik heb hem net geflashed, en dit vorige bericht had ik nog niet gelezen.
Ik kreeg m eerst voor geen mogelijkheid aan de praat, en van floppy booten was ook niet megelijk.
Na 100 instellingen veranderd te hebben en mijn geheugen op 100 Mhz gezet kan ik dit bericht typen.
Ik zal zometeen weer ff 133 proberen.
En ik laat nog wel van me horen als ie vastloopt ofzo
  • Smarron
  • Laatst online: 21:46
Smarron
The bend
Ik heb hem gedownload .. en na het lezen van deze topic ook meteen weer verwijderd!
-=Dell Inspiron 7591=- -=Samsung Galaxy A52s 8GB=- -=Nikon D750=- -=Flickr=-
  • Exirion
  • Laatst online: 23:04
Exirion
Gadgetfetisjist
No flame intended hoor, maar het lijkt wel alsof die A7V niet stabiel te krijgen is met al die BIOS meuk.
  • Triple-D
Nou net weer ff op 133 geprobeerd, maar met slecht resultaat.
Wil gewoon niet booten.
Blijft hangen met windows me scherm
Alleen die blauwe balk blijft wel doordraaien.
Ik zet nu weer een andere erop, wat is de beste?
  • JvdBosch
  • Laatst online: 26-08 22:04
Dit is inderdaad geen aanrader! 1005D werkt bij mij prima, net als 1004D.
e-Niro Runway Red met Smokey Grey interieur
  • Triple-D
Ik heb nu 1005C erop staan.
Wat is het voordeel van D tegen C?
Ik ben in iedergeval weer blij dat die 1006 eraf is.
wat een sicke bios
Ik draai nu een week met 1002 bios van de 133 en het loopt bij mij echt zeer goed. Geheugenbenchmark is hoger, maar daar merk je natuurlijk niks van. Voelt gewoon stabiel aan. Toch zie je maar weer dat het impulsief flashen van een nieuw bios link kan zijn. Ben achteraf blij dat 1002 zo goed werkt. (bij mij !!)
  • Jake
Op donderdag 15 februari 2001 15:51 schreef koosmp3 het volgende:
Sorry, maar ik zo snel als ik kon geplaats... (daarom ook eerst maar 1 quote)
Hopen dat je alles weer goed krijgt, een reflash met oude versie doet wonderen (schijnt).
Met versie D hoeft de boot up virus detectie niet mee aan om van de promise ata 100 controller te booten, en hij loopt gewoon stabieler heb ik de indruk.
Ben nu overgestapt op de a7v133 bios, dat werkt gewoon nog veel beter, en sneller.
Ongeveer 10% mem performance meer, en ik kan nu de bus verder overklokken.:P
Ik snap ook niet wat asus aan het doen is met die biosen van hun voor de a7v maar boven 1004d zuigen ze allemaal stuk voor stuk, heb er geen goed woord voor over:(
het zijn gewoon een stelletje {:O
Ik weet niet wat jullie allemaal zitten te kloten :?:?
Ik heb mij A7V deze week vers uit de winkel, ik heb er nix aan verandert (heb ik ook geen verstand van) en het draait perfect.
Blijf er dan ook gewoon af met je poten! :)
(yep zo rijmt ie wel :P)
zeg hou je onzinnige posts efe voor je ja
en dan druk ik het noog heel netjes uit ok
als je niet weet waar het over gaat hou je kop dan!!!!!!!:(
Als de eerste zin laat eindigen op "kloten"
dan rijmt het tenminste!
ja maar jij bent ook een van de laatsten die zo'n bord koopt dus daar zit dan gewoon 1004d of 1005d standaard in !!! wij ( die 'm gelijk kopen als ie uitkomt) krijgen een 1002 versie mee en moeten eerst naar 1003
1004a tm d om het perfecte bios te krijgen !!
dus ja dan ga je proberen he ?
Op donderdag 15 februari 2001 16:56 schreef Mutant het volgende:
sorry dat ik me vraag zo plat stelde hoor, maar hij was niet onvriendelijk bedoeld. Ik vroeg me gewoon af waarom jullie allemaal met die bios zitten te rommelen.
Maar zoals ik nu begrijp waren de 1ste versies van de bios dus niet geheel foutloos :?
Ohw ik heb trouwens, zie ik nu met asus Probe, versie 1005c. Niet dat asus probe erg betrouwbaar is want de cpu temperatuur geeft ie ook 10 graden te warm aan. Naja het zal wel voorlopig doet ie het goed hier :)
  • 4POX
  • Laatst online: 17:32
4POX
Everybody is wired
Welke revisies hebben jullie.. Dat is ook wel leuk om te weten.. Ik werk met 1.01 en heb nooit problemen.. Dus ik ga lekker die 1006 proberen (to tweak or not to tweak)
AKA Rinkel weblog
  • jota
Bios flashen doe je op eigen risico.
BTW.
If it ain't broken don't fix it.
  • 4POX
4POX
Everybody is wired
Op donderdag 15 februari 2001 17:06 schreef 4eyes het volgende:
BTW.
Nu je het zegt.. 1 blauw scherm per 2 maanden.. Ik flash niet !!!
AKA Rinkel weblog
Hoezo nou "if it ain't broken, don't try to fix it???"
Deze site heet natuurlijk niet voor niets TWEAKERS.net ;)
  • jota
Op donderdag 15 februari 2001 17:13 schreef MisterSmith het volgende:
Heb je zeker het tweede bericht niet gelezen in deze draad.
So what? DAT is het risico van het tweaken... Kan beter of slechter worden. Dit forum is er nu juist voor om dit soort dingen kenbaar te maken.
hmm ik probeer net die 1002 van de 133 te flashen maar dan blijft het awdflash hangen en doet dan niks .... lijkt wel system lockup of zo , gelukkig kan ik dan resetten en is er niks aan de hand maar ja .....
  • Yigal76
  • Laatst online: 16-04 21:49
Ik heb hier nog steeds bios 1002 draaien. Ik zie totaal geen reden om te gaan flashen. Alles draait stabiel en naar behoren, al een half jaar.
  • blimmel
  • Registratie: Augustus 1999
blimmel
Matched: TeamBVD
4eyes thanx!
en draait de 1005d een beetje op een versie 1.01 A7V?
Join TeamBVD!
  • jota
Op donderdag 15 februari 2001 17:42 schreef blimmel het volgende:
heeft iemand die 1005d voor mij?
op de duitse ftp kan ik 'm (niet zo snel) vinden.....
Check je mailbox.
  • McLambo
  • Laatst online: 22:29
McLambo
MTB Junky
Dus als ik het goed gelezen heb flashen jullie een A7V met een A7V133 bios?
wat is daar het voordeel van, buiten die dingen van: "volgens mij..." en "ik voel dat"
Die 1006 is idd een kut bios. hij loopt iedere keer op een ander moment vast. na veel pijn en moeite kon ik booten van een flop en terug flashen
Dus iedereen even een mailtje sturen naar de duitse tech support :)
  • Jake
het voordeel schijnt te zijn dat Sandra zegt dat je Mem-performance omhoog gaat (ik denk dat die 1006 ongeveer dezelfde is als die voor a7v133 alleen zit er een grote bug in deze, what else is new... volgens mij willen ze alleen maar BIOS'en met achtervoegsel, en komt dus morgen 1006A uit :))
edit: quote 'vergeten'
  • NiMu83
  • Laatst online: 18-08-2025
NiMu83
AFCA
ik draai nu ook 1 week 1002a en hij RULES....
echt hij is super stabiel...hehe...dus mensen met een a7v: flash naar 1002a van de a7v133.
Effe over de stelling:
"If it ain't broke, don't try to fix it..."
maar
"If it can better, try to do it better!"
tweakers rules!
:P
Voetbal is de belangrijkste bijzaak in het leven.
  • 4POX
4POX
Everybody is wired
Op donderdag 15 februari 2001 18:52 schreef Windhoosje het volgende:
maar
tweakers rules!
:P
Ik heb zonet ook naar 1002a-1 geflast en idd, Geheugen performance schiet omhoog.. Echt goed.. Misschien moet ik maar eens kijken voor een a7v13 plank.. Dan kan mijn duron 600 eens op 133 gaan draaien
AKA Rinkel weblog
  • 4POX
4POX
Everybody is wired
En de 4-way instelling staat ook al goed in dit bios.. Jammie
AKA Rinkel weblog
  • FrankGuthrie
  • Laatst online: 27-08 21:36
FrankGuthrie
I Wanna Be Kate
Rev 1.02 1004D, doet het nog goed.
Russian Blue Neji
Kate Bush
Blue Horizon(a website about Star Trek & Babylon 5)
Een zo wezenlijk onderdeel van je PC is toch niet iets wat je zo maar in het wilde weg gaat lopen flashen!
Ik vind het altijd raar dat mensen hun BIOS gaan flashen. De performance neemt zelden echt merkbaar toe, en het zijn vaak uitsluitend bug fixen - meestal van problemen waar je zelf geen last van hebt.
Als je peg hebt echter dan krijg je dus situaties als deze, dus daarom lijkt het toch veel beter om eerst even de kat uit de boom te kijken en na een paar weken eens te flashen.
  • NiMu83
NiMu83
AFCA
voordeel van 1002a1 bios versie:
-je ken je FSB hoger zetten...draai nu op 110 ipv 100...hehe ben bezig nog steeds...
-als je je FB op 104 en hoger zet springt de system performance niet meer op Normal (2x AGP) maar blijft rustig op Optimal (4x AGP) staan
-Systeem start VEEEEEEEEL sneller (bij mij dan) en geen 10 sec wachten meer...
hehe
conclusie...
tja...vul maar in!
:P
Nou, ik heb net dus voor dat ik deze topic las de 1006 erop gezet. Geen enkel probleem tot zover.. Mochten er toch problemen komen zal ik dat weer ff posten lijkt me.
Op donderdag 15 februari 2001 18:40 schreef Jake het volgende:
Als het goed is moet er een nieuwe ATA100 bios inzitten
Build 35 ipv build 33
  • Jake
Promise BIOS 35 moet er nu toch al inzitten ?
En Windhoosje: waar zit die 10 sec wachten bij jou normaal dan ? (bij promise bios?)
  • jota
Bios 1006:r is niet goed, ben terug gegaan naar
de vorige versie (1005D);).
Ik raad ook aan Bios 1002a-1 voor de A7V133
werkt reuze stabiel, draait al zeker een week bij mij, en nog eens hogere memory score!
dus een aanrader:)
Hallo zijn we nou slim of super slim:?
Flash je bios gewoon naar 1002a1 133 en alle problemen zijn werkelijk verdwenen.
Zorgt er wel voor dat je Aflash131 gebruik want die doet het 100%
Je hoef dan voorlopig niet meer te flashen want beter dan met deze bios zal je A7V voorlopig niet meer draaien :Y)
Op donderdag 15 februari 2001 15:56 schreef Exirion het volgende:
loopt hier anders rete stabiel :)
  • jota
Geen 1006:( maar 1005D:) of 1002a1 133*D
He Krojo,
De A7V is af fabriek gewoon een zeer brak/kritisch bordje, punt uit.
Maar weinig mensen hebben hem 100% goed aan de praat gekregen.
  • NiMu83
NiMu83
AFCA
Op donderdag 15 februari 2001 21:53 schreef Jake het volgende:
Bij "bezig met starten Windows"
OKeeeeey,
1006 dus ff geprobeerd, maar inderdaad, alleen met standard instellingen van BIOS gaan we starten.
Nu wil ik die 1002a eens gaan uit proberen, want zoals ik hier boven lees, zijn er twiekers die hem geimplementeerd hebben op een A7V ipv een A7V-133 waar hij eigenlijk voor bedoeld is.
Maar als ik flashtool gebruik van Asus, dan roept deze vrolijk NEEN, gaan we NIE doen.
Hoe hebben jullie hem geflest?
  • ezwizard
  • Laatst online: 12-05 15:20
kan er iemand ook ervaringen vertellen van die A7V 133 bios (1002) met 3D games enzo? Want daar heb ik juist hele slechte dingen over gehoord... dat DAT juist voor geen meter meer wil draaien...
  • Jake
Op vrijdag 16 februari 2001 09:39 schreef Windhoosje het volgende:
mmm... vaag, zal wel een specefiek probleempje zijn (netwerk-kaart met bepaalde IRQ ofzo, echt van die zaken die liever niet wil oplossen), als andere bios werkt is dat natuurlijk ook oplossing :)
Op vrijdag 16 februari 2001 10:00 schreef ezwizard het volgende:
Heb idd ook iets over gelezen, vooral dat 3DMark niet meer wou draaien, en meeste gasten hier houden dan op met testen, vraag me niet waarom (:?)
  • wildhagen
wildhagen
Blablabla
Dat ligt aan de drivers van je Ultra100-controller.. dan heb je vermoedelijk build 19 of build 32 geinstalleerd. Je kan het beste build 25 of build 33 nemen, die hebben dit niet meer.
Virussen? Scan ze hier!
  • Smarron
Smarron
The bend
Ik heb ook de 1002a geinstalleerd, maar mijn PC Probe van Asus geeft geen temperatuurmeter meer aan :'(
Misschien niet heel erg, maar hoe krijg ik die weer terug ?
  • Jake
Waarom installeer je niet gewoon de aangepaste (goeie) BIOS voor A7V ?
In deze thread dus, maar dat weet je al, want heb je al in replied.
(edit: typo)
  • Smarron
Smarron
The bend
Ok, vooruit dan maar. DAn heb ik tenminste wel een echte A7V biosupdate ..
  • NiMu83
NiMu83
AFCA
Op vrijdag 16 februari 2001 11:28 schreef wildhagen het volgende:
Klopt...Ik had 25, toen kreeg ik dat ook...maar het ken ook te maken hebben met Windows ME hoor...want ik gebruik ook sinds kort weer 98SE en nu is het probleem weg...maarja...1002a-1 RULES
