[PS3/360] GOTSent, MKV naar MP4 converter
Pagina: 1 ... 10 ... 13 Laatste
  • 158.313 views sinds 30-01-2008
Matched: mkv
Update werkt nog steeds perfect met HDTV rips. Lost net gekeken. Super gewoon. MKV's van bluray rips daarentegen wil hij nog steeds eerst omzetten naar mpeg2. Ik krijg de volgende meldingen:
MEncoder 1.0rc2-4.2.1 (C) 2000-2007 MPlayer Team
CPU: Intel(R) Pentium(R) D CPU 2.80GHz (Family: 15, Model: 4, Stepping: 7)
CPUflags: Type: 15 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
success: format: 0 data: 0x0 - 0x8b6370b6
[mkv] Track ID 1: video (V_MPEG4/ISO/AVC), -vid 0
[mkv] Track ID 2: audio (A_AC3), -aid 0, -alang jpn
[mkv] Track ID 3: subtitles (S_TEXT/ASS), -sid 0, -slang eng
[mkv] Will play video track 1.
[mkv] No audio track found/wanted.
Matroska file format detected.
VIDEO: [avc1] 1280x688 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
libavformat file format detected.
[lavf] Audio stream found, -aid 0
[V] filefmt:65536 fourcc:0x31637661 size:1280x688 fps:23.98 ftime:=0.0417
PACKET SIZE: 2048 bytes, deltascr: 245760
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [harddup]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
audiocodec: framecopy (format=2000 chans=6 rate=48000 bits=0 B/s=80000 sample-0)
Limiting audio preload to 0.4s.
Increasing audio density to 4.
VDec: vo config request - 1280 x 688 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.86:1 - prescaling to correct movie aspect.
videocodec: libavcodec (1280x688 fourcc=3267706d [mpg2])
[mpeg2video @ 00D299C0]impossible bitrate constraints, this will fail
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
Writing header...
INITV: 0.200, 0.158, fps: 23.976
Pos: 2.8s 70f ( 0%) 36.10fps Trem: 0min 0mb A-V:0.000 [986:639]
BUFFER UNDEFLOW at stream 0, raising muxrate to 1980 kb/s, delta_scr: 223418
BUFFER UNDEFLOW at stream 1, raising muxrate to 2178 kb/s, delta_scr: 203107
ERROR: scr 2.789, dts 2.786, pts 2.828
BUFFER UNDEFLOW at stream 0, raising muxrate to 2395 kb/s, delta_scr: 184643
BUFFER UNDEFLOW at stream 1, raising muxrate to 2635 kb/s, delta_scr: 167857
BUFFER UNDEFLOW at stream 0, raising muxrate to 2898 kb/s, delta_scr: 152597
ERROR: scr 2.859, dts 0.000, pts 2.834
BUFFER UNDEFLOW at stream 1, raising muxrate to 3188 kb/s, delta_scr: 138725
ERROR: scr 2.921, dts 0.000, pts 2.866
ERROR: scr 2.926, dts 0.000, pts 2.898
ERROR: scr 2.978, dts 0.000, pts 2.930
ERROR: scr 3.024, dts 0.000, pts 2.962
BUFFER UNDEFLOW at stream 1, raising muxrate to 3507 kb/s, delta_scr: 126114
ERROR: scr 3.071, dts 0.000, pts 2.994
ERROR: scr 3.076, dts 0.000, pts 3.026
ERROR: scr 3.113, dts 0.000, pts 3.058
ERROR: scr 3.118, dts 3.036, pts 3.078
BUFFER UNDEFLOW at stream 0, raising muxrate to 3858 kb/s, delta_scr: 114649
Pos: 3.5s 85f ( 0%) 32.31fps Trem: 0min 0mb A-V:0.000 [1503:640]
ERROR: scr 3.173, dts 0.000, pts 3.090
BUFFER UNDEFLOW at stream 1, raising muxrate to 4244 kb/s, delta_scr: 104226
ERROR: scr 3.212, dts 0.000, pts 3.122
ERROR: scr 3.247, dts 0.000, pts 3.154
ERROR: scr 3.251, dts 0.000, pts 3.186
BUFFER UNDEFLOW at stream 0, raising muxrate to 4668 kb/s, delta_scr: 94751
ERROR: scr 3.293, dts 0.000, pts 3.218
ERROR: scr 3.335, dts 0.000, pts 3.250
ERROR: scr 3.370, dts 0.000, pts 3.282
ERROR: scr 3.374, dts 0.000, pts 3.314
ERROR: scr 3.413, dts 0.000, pts 3.346
ERROR: scr 3.448, dts 0.000, pts 3.378
ERROR: scr 3.483, dts 3.412, pts 3.453
BUFFER UNDEFLOW at stream 0, raising muxrate to 5135 kb/s, delta_scr: 86137
ERROR: scr 3.486, dts 0.000, pts 3.410
ERROR: scr 3.489, dts 0.000, pts 3.442
BUFFER UNDEFLOW at stream 0, raising muxrate to 5649 kb/s, delta_scr: 78307
ERROR: scr 3.531, dts 0.000, pts 3.474
BUFFER UNDEFLOW at stream 0, raising muxrate to 6214 kb/s, delta_scr: 71188
ERROR: scr 3.565, dts 0.000, pts 3.506
ERROR: scr 3.600, dts 0.000, pts 3.538
ERROR: scr 3.631, dts 0.000, pts 3.570
BUFFER UNDEFLOW at stream 1, raising muxrate to 6835 kb/s, delta_scr: 64716
ERROR: scr 3.636, dts 0.000, pts 3.602
ERROR: scr 3.663, dts 0.000, pts 3.634
ERROR: scr 3.689, dts 0.000, pts 3.666
ERROR: scr 3.691, dts 3.662, pts 3.704
BUFFER UNDEFLOW at stream 0, raising muxrate to 7518 kb/s, delta_scr: 58833
Pos: 4.1s 100f ( 0%) 29.27fps Trem: 0min 0mb A-V:0.000 [2212:639]
ERROR: scr 3.731, dts 0.000, pts 3.698
ERROR: scr 3.733, dts 0.000, pts 3.730
BUFFER UNDEFLOW at stream 0, raising muxrate to 8270 kb/s, delta_scr: 53484
Pos: 4.7s 115f ( 0%) 26.13fps Trem: 0min 0mb A-V:0.000 [2935:640]
BUFFER UNDEFLOW at stream 0, raising muxrate to 9097 kb/s, delta_scr: 48622
ERROR: scr 4.372, dts 0.000, pts 4.370
Pos: 5.3s 130f ( 0%) 23.42fps Trem: 0min 0mb A-V:0.000 [3617:640]
BUFFER UNDEFLOW at stream 0, raising muxrate to 10007 kb/s, delta_scr: 44202
ERROR: scr 5.076, dts 0.000, pts 5.074
BUFFER UNDEFLOW at stream 0, raising muxrate to 11008 kb/s, delta_scr: 40184
Pos: 44.3s 1064f ( 0%) 13.32fps Trem: 0min 0mb A-V:0.000 [2155:640]
Op de laatste bufferunderflow melding blijft hij nu doorlopen, staat nu op Pos: 278 (and counting) 6900f (5%) 22.64fps Trem: 92 2660mb......
  • Leedbek
  • Laatst online: 06-07 15:31
Leedbek
Luuk Luchtloper
Matched: voor, mkv
Verwijderd schreef op zaterdag 08 maart 2008 @ 00:24:
Dezelfde foutmeldingen die ik (en meerderen in dit topic kennelijk) ook kreeg. Bij mij heeft het een bestand zonder audio en zonder ondertitels opgeleverd. Ik probeer het nu met het tooltjes mkv2vob, al hoop ik natuurlijk op een oplossing voor dit probleem met GoTSent.
Klaar voor de steroorlogen?
  • Sentry23
  • Laatst online: 01-09 15:01
Geen matches
foutmeldingen zijn te negeren, met de audio ben ik bezig.
Waarschijnlijk moet sommige AC3 een re-encode krijgen om compatible te zijn met mencoder.
Subs wordt ook aan gewerkt om uit te zoeken waarom sommige subs niet goed werken.
[ Voor 25% gewijzigd door Sentry23 op 09-03-2008 20:34 ]
Gotsent: single click MKV to PS3 compatible MP4 conversion:http://sentry23.googlepages.com . PSN Sentry-23
  • DCFreak
  • Laatst online: 31-12-2022
DCFreak
If it aint broke, dont fix it.
Matched: voor, mkv
Hoi Sentry23
Ik probeer een 1080p mkv te re-encoden naar mpeg2 (remuxen zal niet gaan), maar de verwachte melding dat GOTSent niet kan remuxen komt niet. In plaats daarvan loopt GOTSent vast (crashed).
Het vreemde is dat de "sample" file van deze mkv wel gewoon te re-encoden is, dus het ligt voor de hand dat GOTSent crashed op de output van x264_checker?
Sample mkv (werkt prima):
mkv : sample.mkv
mkv parsing ----
found tracks @ 3E
found a track @ 40
found a track @ 10CF
found a track @ 10D3
found a video track @ 10E0
found codec private @ 1114
found h264 sps @ 111F
h264 parsing ----
profile: [64]
i_mb_width: [78]
i_mb_height: [32]
i_num_ref_frames: [6]
dpb usage: [13824000]
checks ----
level 4.1 dpb check: [FAILED]
Movie mkv (crashed GOTSent):
mkv : disk1.mkv
mkv parsing ----
found tracks @ 46
found a track @ 48
found a track @ 6E
found a track @ 236
found a track @ 241
found a video track @ 281
found codec private @ 2A0
found h264 sps @ 2AB
h264 parsing ----
profile: [64]
i_mb_width: [78]
i_mb_height: [32]
checks ----
Hopelijk kan je hier iets mee :)
  • Resinman
  • Laatst online: 20-09 10:17
Matched: mkv
Ik ben al een tijdje bezig om mijn mkv bestanden (anime 1280x720 H.264 AAC) om te zetten naar mp4 bestanden zodat ik ze via mijn Xbox360 kan bekijken. Nu gaat het omzetten goed alleen krijg ik de subs niet meer te zien in het mp4 bestand. Waar zou dit aan kunnen liggen?
  • Rayures
  • Laatst online: 25-08 15:12
Geen matches
Sentry, 0.23b12 blijkt correct te werken icm de 360. De mp4 files van terminator.the.sarah.connor.chronicles.s01e08.720p.hdtv.x264 en ep 9 zijn prima te bekijken op de 360.
verder heb ik met .23b12 een soortgelijke issue als Evil Hobbit; een buffer underflow met memcoder zodra ik een mpeg2 recode uitvoer van planet.earth.ep01.from.pole.to.pole.2006.dvd5.1080p.hddvd.x264 (avc high & ac3)
[ Voor 38% gewijzigd door Rayures op 10-03-2008 12:45 ]
  • Sentry23
Matched: voor
diversen: de errors en underflows kunnen genegeerd worden als dit geen problemen oplevert: de underflows zijn de aanpassing van de bitrate aan de kwaliteit, de andere errors een 'known issue' in mencoder, al ben ik druk bezig een andere versie door te testen. (mencoder wordt gebruikt om de subs te kunnen embedden, dit kan niet met ffmpeg, maar ik zal een fix maken die zonder subs gebruik maakt van ffmpeg)
<edit> een nieuwere versie die ik nu test van mencoder lijkt een stuk beter te werken met probleem files (voor geluid in ieder geval: overschrijf de mencoder directory met deze: http://www.mediafire.com/?lzmuiy1myyn </edit>
resinman: mp4 ondersteund geen subs helaas, alleen mpeg2 doet subs embedding.
[ Voor 21% gewijzigd door Sentry23 op 10-03-2008 19:28 ]
  • S1W
  • Laatst online: 06-10 16:49
S1W
Matched: voor, mkv, ps3
Ik heb een vreemd probleem wanneer een MKV opnieuw wordt encoded naar MPEG2 dan werkt ten eerste de split functie niet bij mij (ik krijg gewoon 1 groot bestand). En als ik handmatig split met bijvoorbeeld het tooltje TSsplitter dan werken beide bestanden op mijn pc prima, maar het tweede en volgende delen van de split werken niet op de PS3 via Twonkymedia (na een kopie naar de interne disk werken ze ook weer). Is er iets anders in de fileheaders van de opeenvolgende bestanden ofzo na een split?
  • Resinman
Geen matches
Sentry23 schreef op maandag 10 maart 2008 @ 16:48:
Ok, bedankt in ieder geval!
  • Sentry23
S1W schreef op dinsdag 11 maart 2008 @ 19:43:
De meeste TS splitters werken eigenlijk gewoon door een harde knip in een bestand te doen (transport streams zou je altijd zou moeten kunnen knippen en plakken) dus waarschijnlijk gaat dat met de headers niet helemaal lekker in twonky/tversity etc.
(dat is ook de reden dat mpeg splitting nog bekeken wordt, of dat toch op een andere manier goed te zetten is door zelf de split te maken, en properties ook goed te zetten).
  • S1W
S1W
Geen matches
Sentry23 schreef op woensdag 12 maart 2008 @ 10:20:
Ja precies, dus iets van header uit part 1 een beetje aanpassen en in de plaats van header 2 zetten met de juiste parameters? Ik zal er eens mee spelen...
  • DarkShadow
  • Laatst online: 08-10 09:10
Geen matches
Rayures schreef op maandag 10 maart 2008 @ 12:36:
Ik heb het laatst uitgeprobeert bij de terminator files. Het werkte goed, maar het geluid was daarna heel zacht, moest mijn hele set opendraaien wilde ik nog een beetje acceptabel geluid eruit krijgen. Instellingen waren niet veranderd.
  • Sentry23
Matched: voor
DarkShadow schreef op woensdag 12 maart 2008 @ 10:55:
Was dat met een mp4/m2ts of een mpeg2 bestand ?
het klinkt als een mp4 mux, waar de ac3filter instellingen goed gezet moeten worden, aangezien andere conversies niets aan het geluid doen (behalve eventueel 1 op 1 overzetten naar ac3).
Mocht het om een mp4 gaan, kijk dan op mijn site naar de audio settings pagina, met als kleine opmerking dat het vinkje 'normalize matrix' in het mixer screen het beste uit kan staan voor goede volume settings.
http://sentry23.googlepages.com/audio
(misschien moet de main gain hierna naar beneden staan, ergens van 0 - 3)
  • S1W
S1W
Matched: voor
Ben een beetje aan het stoeien met die gesplitte mpeg2 bestanden, en ik zie dat in het tweede bestand de eerste 2048 bytes missen, daarna volgt de standaard mpeg2 header met de mpeg parameters.
Ik heb met dd (voor Windows) even de eerste 2KB van bestand 1 geknipt en aan bestand 2 geplakt:
dd bs=2048 count=1 if=eerstdeelsplit.mpg of=header
copy /B header+tweededeelsplit.mpg test.mpg
Het bestandje test.mpg speelt nog steeds onder Windows, ben benieuwd of Twonky hem nu wel als legitieme mpeg2 ziet (zit nu op werk dus kan pas straks testen).
[ Voor 92% gewijzigd door S1W op 12-03-2008 14:25 ]
  • DarkShadow
Matched: voor
Sentry23 schreef op woensdag 12 maart 2008 @ 11:19:
Bedankt voor je reactie, ik ga nu kijken. Is 5.1 geluid niet mogelijk (voor de xbox360)?
  • Sentry23
Matched: voor
DarkShadow schreef op woensdag 12 maart 2008 @ 15:09:
5.1 Audio op de 360 kan alleen in een mpeg2 of in een WMV bestand.
Mocht er stiekem toch een manier zijn om 5.1 audio en h264 video bij elkaar op de 360 af te spelen, dan zal ik het er direct in bakken.
  • Seraphus-Y
  • Laatst online: 22:42
Seraphus-Y
Scientific progress goes Boink
Matched: mkv
Ik gebruik nu 0,23b12 in Win XP (Home sp2) op m'n iMac via VMWare Fusion en op zich werkt dat wel goed. Het vreemde is alleen wel dat de .mkv eerst naar Windows gecopieerd moet worden anders is er na de conversie (die op zich prima verloopt) geen output.
Wat ik eerst had was:
Z:\Harddisk\Users\Sera\Downloads\file.mkv (dus vanuit Windows XP naar lokale iMac folder) = source
C:\ (gewoon c:\ dus in Windows XP) = output
De conversie verloopt zonder fouten, wordt ook netjes een split folder aangemaakt (met losse mkv's), audio extract & encoding verlopen ook allemaal goed. Alleen als GOTSent klaar is, blijft er niks over.
Oplossing is gewoon de .mkv naar de desktop te copieren en dan de conversie te starten. Dat werkt dan weer prima. Is alleen even omslachtig.
1x Marstek Venus E V2 v158 -*- 1x Marstek Venus V3 v147 - Omnibattery in HA via HW P1
  • Sentry23
Matched: voor, mkv
Seraphus-Y schreef op woensdag 12 maart 2008 @ 15:43:
Als dit voor het maken van een MP4 is, dan kan het eventueel liggen aan de lokatie van de temp file (ondertussen aangepast) maar voor een m2ts zou ik even geen oorzaak weten.
  • DarkShadow
Geen matches
Sentry23 schreef op woensdag 12 maart 2008 @ 15:28:
Overigens blijft het geluid aan de lage kant, ik zie wel dat ik nog beta 10 heb. Misschien maakt dat uit. Ik heb +13 db, vinkje uit zoals je zei en verder exact dezelfde instellingen
  • S1W
S1W
Matched: mkv, ps3
S1W schreef op woensdag 12 maart 2008 @ 14:07:
Tja, het bestand wordt nu wel door Twonky herkend en afgespeeld op de PS3, dus er mist idd iets in de header na de split, alleen nu is er geen geluid te horen... 8)7 De PS3 ziet de audio stream ook niet, helaas niet zo simpel dus.
Ik heb nu wel mkvmerge GUI versie 2.2 getest om de bron MKV's te splitten in maximale grootte van 3900MB bestanden. Dat lijkt te werken; in deze tool kan ik ook al eventuele .srt files in de container mee muxen. Ik ga nu proberen de losse bestanden met GOTsent te re-coden... ben benieuwd :)
Matched: mkv, ps3
Heb zojuist Paprika omgezet van MKV naar mpeg2 inclusief subs. Hij deed er zo'n 77 minuten over. Zoals vermeld door Sentry heb ik ditmaal de errors gewoon genegeerd en een werkend mpeg bestand was het resultaat. Direct winamp remote gestart en jawel, hij streamed nu naar de PS3. Vloeiend, zonder haperingen. Na 8 minuten stopt de film echter. Toen de film maar naar de hard disk van mijn PS3 gekopieerd. En ook dan speelt hij slechts 8 minuten. Op de pc speelt de mpeg gewoon in zijn geheel af. Ik denk dat het met het netwerk te maken heeft. Ik ga het morgen of zo even via een usb stick proberen. Moet er alleen even eentje halen die groter is dan 1gb ;)
[ Voor 44% gewijzigd door Verwijderd op 12-03-2008 23:49 ]
  • WiXX
  • Laatst online: 31-08 12:44
WiXX
Kijk uit malloot een...
Geen matches
Welke instellingen moet ik nu eigenlijk hebben bij AC3 filter als ik 5.1 sound wil hebben bij een mpeg2 zodat ik hem met 5.1 sound kan kijken op mijn xbox 360?
Als ik namelijk no change doe blijf ik maar foutmeldingen krijgen.
Matched: ps3
Hallo allemaal,
Kan ik ook hier terecht over het streamen van bespaalde bestanden via mediaservers?
want ik snap er niks meer van nu.
Ik heb een bestand .WMVHD (1.12 gb) deze kan ik dus sharen met Winamp Live ORB mediaserver. Zodra ik hem share naar mijn PS3 dan wordt dit gezien als 314 mb slecht beeldmaar wel met geluid.
Share ik deze met Tversity dan heb ik super beeld zoals hij hoort maar dan heb ik weer geen geluid.
Nou word er gezegd dat de PS3 het WMVHD bestand het geluid niet van kan afspelen. Maar waarom speelt hij deze dan wel af met Winamp ORB ?
kan iemand mij helpen hierbij ?
GreetZ,
DeZ
  • Sentry23
Matched: voor, ps3
Verwijderd schreef op vrijdag 14 maart 2008 @ 09:31:
Hallo allemaal,
Het is inderdaad niet echt de plek (beter in het PS3 als mediacenter forum) maar zo te horen zorgt ORB voor transcoding van beeld en geluid (met alle kwaliteitsverlies vandien) en stuurt Tversity het bestand netjes raw door, zodat het geluid het niet doet.
Geen matches
ok thx ga ik hem daar ff posten.
Matched: mkv, ps3
Hoi allemaal ,
ik heb met gotsent 0.23 b12 me eerste .mkv file omgezet met subs en dit is succesvol gegaan.
maar deze wordt .mpg ipv .mp4 klopt dat ?
Nu nog ff op me ps3 testen doormiddel het ff:
= Op een dvdtje te branden. <-== Werkt
= Streamen via Winamp remote (ORB) <-=== Werkt
= Streamen via Windows Media Server <-=== Werkt
= Streamen via Tversity <-=== Werkt
alles ging vlekkeloos.
groetjes
[ Voor 11% gewijzigd door Verwijderd op 15-03-2008 00:37 ]
  • Mr.MarQuez
  • Laatst online: 23:27
Heey,
Ik heb een vraagje over het gebruik van dit proggie..
Ik heb er nu al een aantal films wil mee willen omzetten voor op mijn ps3 te bekijken maar het lukt toch niet helemaal zoals het hoort!!
Het omzetten van mkv naar vob gaat opzich goed zij het zonder ondertiteling (omdat dit niet ondersteund word). Als ik die zelfde film ga omzetten naar .vob maar dan met ondertiteling en dan mpeg2 recode aanklik, dan heb ik als het omzetten klaar is alleen beeld zonder geluid.
Als ik file in media info bekijk zie ik inderdaad dat er alleen maar video beschikbaar is in de film. Het bestand dat ik probeer om te zetten heeft als video codec AVC en audio DTS
nu is de vraag waar kan dit aan liggen?
vind het verder top proggie en hoop dat ik dit ook nog werkend krijg zodat ik deze film ook kan omzetten. goed werk sentry
greetz
Ik heb nog 4 stukken van verschillende films omgezet van mkv naar .vob met mpeg 2 recode aangevinkt. daarvan waren er 3 met DTS geluid en 1 met AC3.
1 van de DTS files die had na recoden wel geluid en de andere 3 niet.
Ik heb zelf waarschijnlijk al het probleem zo goed als verholpen, dit door GOTSent even te verwijderen en opnieuw uit te pakken in nieuwe map, meteen de mencoder te vervangen door de nieuwe versie en ook nog even neroaac files toe te voegen in de map.
Hierna dezelfde films omgezet en nu doe 4 van de 5 films het, maar er is nog altijd 1 met DTS geluid die het niet doet. Ligt dit misschien aan de film zelf of waar kan het anders nog aan liggen?
zo nu ben ik ff uitgetypt :)
[ Voor 41% gewijzigd door Mr.MarQuez op 16-03-2008 03:29 ]
  • King_Tech
  • Laatst online: 04-10 12:29
Matched: voor, mkv
Ik heb vandaag voor het eerst geprobeerd om een mkv file om te zetten naar mpeg2 met Gotsent (om subtitles toe te voegen). Maar mijn Xbox 360 kan het mpeg bestand niet zien. Na wat zoeken op Google kwam ik erachter dat je mpeg bestanden alleen af kan spelen via Media Center. Ik maak zelf gebruik van Windows XP.
Maar is het toch mogelijk om mpeg2 bestanden af te spelen op de Xbox 360 (met Windows XP zonder Media Center)?
  • EdwinB
  • Registratie: September 1999
  • Laatst online: 19:30
Matched: mkv
Klopt het dat als ik een .mkv bestand (lost s04e01) van ca 1GB omzet met MPEG2 Recode + .srt subtitle dat het uiteindelijke .mpeg bestand 2,7GB wordt?
Zo ja kan ik dat .mpeg bestand weer kleiner krijgen op een bepaalde manier?
  • Sentry23
Matched: voor
ehmm.. tijd voor wat antwoorden.. even geduld, ik ben redelijk druk op het ogenblik, maar ik zal vanavond weer wat vragen proberen te beantwoorden.
  • DakuGosuto
  • Laatst online: 07-08 19:37
(jarig!)
Matched: voor, mkv
King_Tech schreef op zondag 16 maart 2008 @ 12:56:
renamen naar .avi werkt dan kan je hem wel gewoon kijken
Matched: voor, ps3
Het converteren van bijvoorbeeld Lost met GotSent (laatste beta), werkt bij mij goed en ik kan hem goed afspelen op de PS3. Heb idd ook dat 1GB wordt omgezet naar 2,7GB en de speciale karakters( ë etc.) in een .srt file worden niet herkend en vervangen door _.
  • Sentry23
Matched: voor, ps3
Verwijderd schreef op maandag 17 maart 2008 @ 16:12:
Heb je de srt wel via notepad op UTF8 formaat gezet ?
<edit>UTF-8 is nodig voor speciale karakters. Er zijn nogal wat character encoding options, en ik hoop dit in de toekomst automatisch te gaan doen, maar voor nu moet het even met de hand</edit>
[ Voor 18% gewijzigd door Sentry23 op 18-03-2008 13:03 ]
Geen matches
Nee, heb ik niet gedaan. Bedankt ik zal het van de week eens proberen. (zal vast wel werken)
  • King_Tech
Geen matches
DakuGosuto schreef op maandag 17 maart 2008 @ 13:06:
Dat heb ik geprobeerd maar het werkt nog steeds niet? Enig idee waar dat door zou kunnen komen?
  • Seraphus-Y
Seraphus-Y
Matched: voor
Sentry23 schreef op woensdag 12 maart 2008 @ 15:53:
Was inderdaad naar MP4.
Is dit aangepast in nieuw beschikbare versies of aangepast in een "besloten bèta" ? ;)
En wat zijn de (nieuwe) features / verbeteringen waaraan nu gewerkt wordt? Ben wel benieuwd naar de voortgang. :*)
  • Sentry23
Matched: voor, mkv
Seraphus-Y schreef op woensdag 19 maart 2008 @ 14:15:
Je bent altijd vrij om te testen :) (mail maar ff)
Verder veel werk om betrouwbaar non-playable 264 om te zetten naar 4.1 compliant h264, en dan de mux naar mp4/vob afhankelijk van voorkeur. Veel met settings spelen om de juiste resultaten te krijgen, binnen acceptabele tijd, met de beste kwaliteit.
en dus nog steeds druk bezig met splits.. (ellende van sommige files met mkvmerge, en een eigen gebakken mpeg2 splitter)
en werk..
Matched: mkv
zojuist een mkv van 4.2 gb omgezet naar mpeg2. Alleen de resultaten zijn verdwenen, als in, niet opgeslagen :D
  • S1W
S1W
Matched: mkv
Sentry23 schreef op woensdag 19 maart 2008 @ 14:38:
en werk..
Toch headers fixen ofzo met je eigen mpeg2 splitter?
  • Seraphus-Y
Seraphus-Y
Matched: voor, ps3
Nieuwe firmware update voor PS3 (nog niet beschikbaar):
Hi again everyone. Here’s a quick preview of the next PLAYSTATION 3 system software update coming up in the next few days. Firmware v2.20, introduces a number of features to further enhance your PLAYSTATION 3 as the hub of your entertainment center.
Most notably, the update enables the PS3 to support Blu-ray Disc Profile 2.0, also known as BD-Live. You can connect now to the Internet while playing discs that support BD-Live to obtain additional content and special features. These features vary from disc to disc, and will keep your BD discs fresh with new content and in some cases exclusive content only accessible to owners of BD-Live enabled discs. On April 8th Sony Pictures Home Entertainment will release The 6th Day and Walk Hard on Blu-ray; these titles will be among the first to take advantage of BD-Live. With this update, the PLAYSTATION 3 becomes the first Blu-ray player on the market with BD-Live functionality.
Here are some of the other new features/enhancements that will be included in Firmware v2.20:
  • The ability to copy PS3 Music and Photo playlists to a PSP system. We introduced the ability to create Music and Photo playlists on the PS3 in firmware update v2.0. Now you can easily export your playlists to your PSP.
  • You can now play DivX and WMV format files that are over 2 GB.
  • Resume Play - begin playing a DVD or BD disc from the point where you previously stopped it, even if you eject the disc and insert a different movie or game.
  • Use your PSP as a remote control to play back your music files on your PS3 without turning on your TV.
  • The Internet browser now displays some web pages faster. In addition [Save Target] has been added as an option under file. This option lets you save a file that is linked to a web page to your PS3 hard drive or storage media.
There are a few other tweaks and upgrades included in v2.20 - we’ll provide more specifics as the update is about to go live.
bron: http://blog.us.playstatio...-bringing-bd-live-to-ps3/
Vraag is natuurlijk of MP4's ook groter dan 2GB mogen zijn, maar lijkt me wel.
  • m4yall
  • Laatst online: 05-10 22:59
Matched: voor, ps3
Seraphus-Y schreef op donderdag 20 maart 2008 @ 10:46:
MP4's mochten toch al groter dan 2GB zijn, zolang ze maar kleiner waren dan 4GB. Ik kijk vooral TV series en geen films, maar MP4's hadden zich volgens mij gewoon aan de FAT32 restrictie te houden dacht ik.
  • Seraphus-Y
Seraphus-Y
Matched: voor
m4yall schreef op donderdag 20 maart 2008 @ 11:19:
euh... euh... is dat zo? :$
Nouja, ehm, *kuch* dus euh... gaaf toch die nieuwe aankomende firmware? O-)
Matched: mkv
Hmm, op een of andere manier wil hij van deze mkv maar niet het geluid meeconverten naar mpeg. Ik kan trouwens gewoon mkv's, omgzet naar mpeg, van 4gb of groter streamen via winamp remote.
  • m4yall
Matched: voor
Seraphus-Y schreef op donderdag 20 maart 2008 @ 11:21:
Zitten wel weer leuke features in! Resume play is er bijvoorbeeld 1 die ik wel kan waarderen!
  • woutertje6
  • Laatst online: 17-07 06:48
Matched: ps3
Over dit: You can now play DivX and WMV format files that are over 2 GB.
Geld nu dan ook dat wij gewoon alle .wmv bestanden op de ps3 kunnen kijken net zoals die op de xbox360 kunnen. Op usenet zijn heel veel releases van woutje_nl die HD films met NL subs ingebakken direct op usenet zet als .wmv bestand. Dit is de postinfo, nou was mijn vraag of de ps3 deze straks ook af kan spelen:
Formaat : WMVHD
Video Codec............: WVC1
Video Bitrate...........: Rambo 1: 5,2, Rambo 2: 5,0, Rambo 3: 4,7 Mbit/sec
Video Aspect Ratio....: 1280x544 (720p)
Audio Codec............: WMA 10 Pro
Audio Bitrate...........: 768 kbit/sec (CBR)
Audio kanalen...........: 5.1 kanalen
Ondertiteling...........: Nederlands (meegeëncodeerd) (retail subs)
Geëncodeerd door.....: Woutje_nl
  • Sentry23
Verwijderd schreef op donderdag 20 maart 2008 @ 11:26:
Heb je toevallig een aantal berichten terug de fix meegekregen van een nieuwere Mencoder ?
Die heeft voor de meeste mensen missing audio opgelost.
En inderdaad, mpg en m2ts is gewoon zonder problemen te streamen > 4 GB. De Mp4 beperking zit (voor zover ik heb kunnen uitvinden) in een 32 bit header limiet van de gebruikte mp4 standaard op de PS3 en 360.
[ Voor 18% gewijzigd door Sentry23 op 20-03-2008 15:52 ]
  • Sentry23
Matched: voor, ps3
woutertje6 schreef op donderdag 20 maart 2008 @ 14:07:
Dat is het probleem..
WMA Pro speelt (nog?) niet op PS3. Wie weet is dit ook aangepast, maar voor zover ik kan zien niet.
Ik ben met de re-coding met WMA 9 nu zo ver dat ik zonder problemen een VC1 en een WMA9 stream over hou, alleen is het nog een beetje hakken in encoders dus om de mux goed te laten verlopen. (gelukkig geen split op 2 GB meer nodig :D)
Matched: voor, ps3
Sentry23 schreef op donderdag 20 maart 2008 @ 15:10:
En inderdaad, mpg en m2ts is gewoon zonder problemen te streamen > 4 GB. De Mp4 beperking zit (voor zover ik heb kunnen uitvinden) in een 32 bit header limiet van de geruikte mp4 standaard op de PS3 en 360.
Tx, ik ga het gelijk even proberen. :*)
  • Sentry23
Matched: voor
S1W schreef op donderdag 20 maart 2008 @ 08:46:
Yep.. Ik krijg andere splitters niet betrouwbaar aan de gang, dus dan moet ik het zelf maar doen ;)
(eerste tests met lomp knippen en plakken, en gewoon een goeie header er voor zetten zijn trouwens best aardig..) 't is een stuk sneller iig dan alle frames parsen.
[ Voor 23% gewijzigd door Sentry23 op 20-03-2008 16:00 ]
  • Mr.MarQuez
Matched: mkv, ps3
dit probleem heb ik ook nog steeds met 1 bestand, de nieuwe versie van mencoder heeft dit ook niet doen oplossen.. is gewoon dts audio dus zou toch geen probleem moeten zijn, waar zou dat aan liggen?
en dan nog een vraagje als ik de mpeg file op pc probeer af te spelen met wmp11 of vlc krijg ik geen geluid, de mkv doet het wel gewoon.. op ps3 doet hij het perfect (gestreamd).
Matched: mkv, ps3
Mr.MarQuez schreef op donderdag 20 maart 2008 @ 20:40:
Misschien geen dts decoder in je geluidskaart?
Bij mij werkte het updaten van de memcoder trouwens. 8)
Ik probeer nu een andere MKV om te zetten en daar krijg ik de volgende foutmelding te zien:
Error during audio extraction. Temp files not deleted.
Hierna crashed hij.
[ Voor 13% gewijzigd door Verwijderd op 20-03-2008 21:45 ]
  • Tiduz
  • Laatst online: 06-10 17:43
Matched: ps3
Tof tooltje, aangezien me laptop 1080P net niet trekt maar 720P wel, kan ik deze mooi gebruiken om 1080P films naar PS3 formaat om te zetten, thanks :D
CPU: I5 6600K - Cooler: Noctua NH-D15S - RAM: 8GB Kingston HyperX Fury Black - GFX: GFX: MSI RTX 2070 Super - SSD: 250GB Samsung 850 Evo - Case: CoolerMaster CM Storm Stryker - PSU: Corsair RM750i
  • Leedbek
Leedbek
Luuk Luchtloper
Geen matches
Ik heb hetzelfde probleem, geen audio, ook niet met de nieuwe versie van mencoder. Ik krijg overigens nog steeds dezelfde foutmeldingen: ERROR: scr 3.118, dts 3.036, pts 3.078 enz. tijdens het encoderen, weet niet of dat van belang is.
  • Mr.MarQuez
Matched: mkv
Verwijderd schreef op donderdag 20 maart 2008 @ 21:33:misschien geen dts decoder in je geluidskaart?
ik denk dat dat niet het probleem is want als ik de mkv met vlc afspeel dan heb ik wel gewoon geluid, zowel met dts als ac3 als codec in de mkv. maar na omzetten naar mpeg met de tool krijg ik bij afspelen via wmp 11 geen geluid. bij vlc stopt hij altijd na paar seconden met afspelen maar geeft hij wel geluid in die paar seconden.
Luuk-Online schreef op donderdag 20 maart 2008 @ 22:28:
[...]Ik krijg overigens nog steeds dezelfde foutmeldingen: ERROR: scr 3.118, dts 3.036, pts 3.078 enz. tijdens het encoderen, weet niet of dat van belang is.
bij het omzetten heb ik verder niet op de foutmeldingen gelet aangezien dat niet nodig was.
[ Voor 27% gewijzigd door Mr.MarQuez op 20-03-2008 23:40 ]
  • Sentry23
Matched: mkv, ps3
DTS zou gewoon via de ac3tools en aften naar 5.1 ac3 moeten worden omgezet. Kan je zien of er tijdens conversie wel een ac3 wordt aangemaakt ?
Die error scr.. dts .. pts.. zijn gewoon te ignoren.
b.t.w. Nu ook PS3 netjes lange Divx/Xvid gaat doen.. willen jullie ook 2 pass Xvid/divx encoding hebben ?
(volgens mij doet de 360 alleen niet hoger dan 720p divx/xvid.. kan iemand dat verifieren ?)
[ Voor 16% gewijzigd door Sentry23 op 21-03-2008 09:42 ]
  • S1W
S1W
Matched: voor, mkv
Sentry23 schreef op donderdag 20 maart 2008 @ 15:59:
Haha, ja ik kwam helaas niet verder dan alleen beeld op een tweede deeltje van een 1080p 5.1 MPEG2 split; miste toch nog wat in de header om ook de audio te fixen, maar het moet wel te doen zijn zo denk ik... Kan je niet toch gewoon mkvtoolnix gebruiken om dan maar vooraf een grove split te doen van de originele MKV?
  • Mr.MarQuez
Matched: voor
Sentry23 schreef op vrijdag 21 maart 2008 @ 09:38:
[...]DTS zou gewoon via de ac3tools en aften naar 5.1 ac3 moeten worden omgezet. Kan je zien of er tijdens conversie wel een ac3 wordt aangemaakt ?
hoop dat ik die file nog heb en zal hem dan nog eens omzetten en erop letten wat gebeurd.
weet je trouwens waar het aan ligt dat ik geen geluid bij mpeg files op pc heb? geldt trouwens voor alle omgezette files...
[ Voor 4% gewijzigd door Mr.MarQuez op 21-03-2008 14:06 ]
  • Sentry23
Matched: voor, mkv
S1W schreef op vrijdag 21 maart 2008 @ 11:42:
Dat laatste is ook een optie.. ik ben nu toch bezig om in de mkv header te zoeken naar de encoding bitrate e.d. voor de h264 info. dan kan ik ook wel de playlength en bitrate er uit halen en een 'rough estimate' maken van de mpeg2 grootte. (if 1080p {15Mbps} else {10Mbps}, ongeveer)
<edit> play length is niet eens echt nodig.. gewoon ((target bitrate/bitrate) * filesize) om final size ongeveer vast te stellen en die dan te delen </edit>
[ Voor 9% gewijzigd door Sentry23 op 21-03-2008 16:21 ]
  • Sentry23
Matched: voor
Mr.MarQuez schreef op vrijdag 21 maart 2008 @ 14:03:
Hmm. op PC werkt het bij mij wel. Waarschijnlijk heeft het iets te maken met een directshow filter/splitter filter.
Ik gebruik zelf ook meestal mplayer classic, die vaak wat makkelijker om gaat met bepaalde bestanden.
  • Mr.MarQuez
Geen matches
Sentry23 schreef op vrijdag 21 maart 2008 @ 15:05:
dan ga ik die vanaaf eens even proberen, kijken of die wel de files afspeelt.
  • King_Tech
Matched: mkv
Sentry, heb jij enig idee waarom ik mkv bestanden die ik geconverteerd heb naar mpeg2 niet kan afspelen op mijn Xbox 360. Ik hernoem het bestand naar .avi maar mijn Xbox ziet het bestand gewoon niet. Komt dat misschien omdat het geconverteerde bestand 6 gb is? Volgens mij zou die dat gewoon moeten kunnen afspelen.
  • Mr.MarQuez
Matched: mkv
ik krijg maar geen geluid bij afspelen van die files.. mplayer classic geeft helaas ook geen geluid!!heb nu al van allerlei instellingen geprobeert maar geen geluid uit te krijgen. wat me wel nog is opgevallen dat mkv files met ac3 als codec erin wel gewoon geluid geven.
vind het maar erg vaag..
  • Sentry23
Matched: mkv
Mr.MarQuez schreef op zaterdag 22 maart 2008 @ 18:01:
Stuur ff mailtje, dan zal ik wat testen inbakken in een debug versie om er achter te komen wat fout gaat..
Geen matches
Ik ben ten einde raad. Ik heb een filmpje met 2 audio sporen. Met Gotsent heb ik dus het filmpje met succes omgezet. Alleen pakt hij de verkeerde taal.
Hoe kan ik bij het omzetten de taal wijzigen. Wat ik begrijp is dat je "Haali Media Splitter" nodig hebt. Ik heb "Haali Media Splitter" geïnstalleerd, maar hij doet helemaal niks. Ik zie ook geen geen icoontje in de "system tray". Kan iemand mij hiermee helpen?!!
Weet iemand een website die uitlegd hoe je "Haali Media Splitter" moet gebruiken?!! Ik kan het zelf namelijk nergens vinden.
  • Sentry23
Matched: voor, mkv
bloodstrike: geen paniek.. we regelen het wel :)
1) heb je misschien vista 64 ? Zo niet, dan gaat het snel lukken, anders ben je verantwoordelijk voor een update ;)
2) mail ff, dan gaat het een stuk sneller. Maar anders, pak graphedit, en zie veel eerder in deze thread hoe je een audio extract kan testen met graphedit, dan kan je in ieder geval de properties van haali instellen voor de taal (welke taal moet je hebben ? je hebt namelijk de 3 letterige ISO codes nodig in Haali)
(graphedit openen, starten, filter inserten, en haali selecteren, dan kom je ook bij de properties)
3) eventueel kan je ook met mkvextract de video en audio track die je wil extracten, mergen naar een nieuwe MKV, en die weer bij GOTSent voorleggen voor conversie.
[ Voor 21% gewijzigd door Sentry23 op 23-03-2008 00:16 ]
Matched: ps3
Misschien handig om te weten dat de PS3 met de 2.20 firmware nu ook divx ondertiteling ondersteunt, en bestanden groter dan 2GB.
  • Sentry23
Matched: voor, ps3
Verwijderd schreef op dinsdag 25 maart 2008 @ 12:37:
Yep.. was al aan het wachten met wat zaken (hardsubbing van xvid/divx) om te zien hoe en wat, maar de methode is nog niet 100% (imho). Je moet subs embedded in een Divx file om ze te kunnen zien.
De 2 GB limiet is wel fijn.
Eerste release zal voor VC1 zal alleen nog wel een manual stap op het einde hebben om de final mux te doen naar WMV, maar het scheelt al een hele partij werk voor PS3 users..
  • woutertje6
Matched: voor
Hoeveel hebben we aan die update van die 2 gb ?
Kunnen we nu ook zelf makkelijker releases vinden op het net? Zodat we zelf niets hoeven om te zetten en dan bedoel ik vooral met de subs ;)
  • xxACxx
  • Laatst online: 22-08 23:37
Matched: ps3
Wil dit nu zeggen dat de ps3 srt/ass/saa subtitles ondersteund??
  • woutertje6
Matched: ps3
xxACxx schreef op dinsdag 25 maart 2008 @ 16:42:
Ik weet ook niet echt hoeveel wie aan die nieuwe update hebben, ik hoop dat iemand me het kan vertellen ;)
  • Willy-Jan Prijs
  • Laatst online: 27-02 20:46
Matched: mkv
GOTSent is idd een fijne tool en werkt super.
Ik ben nu bezig met AVCHD's te maken van MKV bestanden.
Ik extract de video en audio track met MKVextractGUI wat binnen een minuut o.i.d gedaan is.
Nu heb ik de video track .h264 en de audio track .ac3 of .dts en laad ik de .h264 track in met tsMuxerGUI en verander ik de lvl van de .h264 track van 5.1 naar 4.1 met tsMuxerGUI en vervolgens kies ik als output m2ts.
Nadat dit gedaan is voeg ik de .m2ts samen met de .ac3/.dts en eventueel zet ik .srt ondertitels om naar .sup met SUPread en voeg ik deze toe met tsMuxerGUI en kies ik als output blu-ray disk.
Dit gaat allemaal vrij snel maar krijg naderhand geen ondertitels.
Ik kan wel ondertitels selecteren maar krijg ze gewoon niet te zien.
SUP files zijn toch echt ondertitels welke blu-ray compatibel zijn zover ik lees op het internet.
Geen matches
Ik ben nog niet zo bekend op dit forum,
ook weet ik nog niet veel over Gotsent dus misschien vragen die al 100 keer gesteld zijn.
maar ik kan mpeg2 niet afspelen op de xbox 360 ook niet als DVD gebrand als UDF.
MP4 doet het perfect.
dit alles met gotsent versie 023 b12
alvast bedankt
  • Sentry23
Matched: voor, ps3
Richard R: renamen naar AVi in media servers lijkt voor veel mensen goed te werken, of dat op DVD goed werkt, weet ik even niet.
boven: wat betreft subs op Divx op PS3, deze moeten in de stream gemuxed worden via bijv deze tool: http://userxp.tripod.com/sub2divx.htm (volgens divx spec dus: bitmap based subs, die als alternate stream in de divx zitten, maar die tool zet ook srt om naar het juiste formaat).
Verder.. Ik ben nu aan het testen met VC-1, en heb in aardig wat gevallen nog een apart probleem, misschien heeft iemand een idee. de PS3 geeft een play icon, alles lijkt goed te staan (audio en video herkent) maar de PS3 blijft lege bitrates aangeven.. (en nix spelen). Heeft iemand al eens zoeits gezien/oplossing gevonden ?
(muxen met diverse tools, van avi -> wmv, vc-1 -> wmv, etc etc)
Matched: voor, ps3
Sentry,
Bedankt voor het snelle antwoord.
Ga ik gelijk proberen.
Helaas weet ik niets van de PS3.
Ik speel af op een XBOX 360.
Dus ik wacht af met de subs op mp4
nogmaals bedankt
  • Sjaak_Trekhaak
Sentry23 schreef op vrijdag 01 februari 2008 @ 10:29:
GOTSent 0.23 Beta 10
5.1 Audio in mpeg2 files, on both the PS3 as on the 360.
Als ik het dus goed begrijp, kan ik mijn MKV's nu omzetten naar 720p mét 5.1 geluid voor de X360, indien ik MPEG2 Recode aanvink? _/-\o_
Ik gebruik al B12, heb me net weer even ingelezen in het topic. Super tooltje, bedankt voor het beschikbaar maken ervan :)
[ Voor 15% gewijzigd door Sjaak_Trekhaak op 27-03-2008 19:56 ]
Geen matches
Hej Sentry23 weet jij dit misschien?,
Ik krijg bij Sub2DivX (op vista) een foutmelding:
Component 'comctl32.ocx' or one of its dependencies not correctly registered: a file is missing or invalid.
weet je misschien hoe dit komt?
Matched: voor
Verwijderd schreef op donderdag 27 maart 2008 @ 21:39:
Ik had deze zelfde melding, je moet even comctl32.ocx hiervandaan downloaden
COMCTL32.OCX
Nu moet je de command prompt in administrator mode opstarten en het volgende intypen.
regsvr32 c:\windows\system32\comctl32.ocx
Zorg er natuurlijk wel voor dat comctl32.ocx in de system32 dir staat. Dit heeft het voor mij opgelost.
[ Voor 69% gewijzigd door Verwijderd op 28-03-2008 08:55 ]
Matched: voor, mkv
rippance schreef op donderdag 27 maart 2008 @ 19:50:
MPEG2 Recode is alleen nodig als het programma het ook aangeeft, met "mux to vob" krijg je ook 5.1 geluid.
  • Sentry23
Matched: ps3
Verwijderd schreef op vrijdag 28 maart 2008 @ 08:56:
Helaas werkt mux to vob niet op de 360, alleen op de PS3.
PS. ik was eigenlijk van plan deze week een update te doen, maar door drukte ben ik er niet aan toe gekomen helaas :-/ (komende features, afhankelijk van tests: h264 recode, meer sub options, meer audio selection options, ps3/360 preferences en ik hoop toch nog op de VC-1 support)
[ Voor 33% gewijzigd door Sentry23 op 28-03-2008 09:12 ]
  • Sjaak_Trekhaak
Geen matches
Geeft VC-1 en h264 dan toevallig wel de mogelijkheid tot 5.1 op de X360?
Geen matches
misschien een domme vraag:
maar hoe start ik: Nu moet je de command prompt in administrator mode opstarten en het volgende intypen.
dat op?
waar kan'k dat intypen?
alvast bedankt
Matched: voor
Verwijderd schreef op zaterdag 29 maart 2008 @ 12:04:
dat op?
alvast bedankt
Eerst kopieer je dat comctl32.ocx naar de C:\Windows\System32 directory, dan ga je via het start menu naar "Command Prompt", deze vind je terug bij "Accessoires" en klik je hier met je rechtermuisknop op, dan kies je voor "Uitvoeren als Administrator".
Daarna type je die regel in (regsvr32 c:\windows\system32\comctl32.ocx)
  • TheZeroorez
Matched: mkv, ps3
Op de valreep:
[PS3] GOTSent, PS3 compatible MKV to MP4 converter → [PS3/360] GOTSent, MKV naar MP4 converter
Geen matches
het is gelukt in zoverre dat er een divx bestand uit rolt met een srt ingebakken.
probleem is echter dat als ik hem stream met windows media player dat hij het bestand niet ziet.. (je kunt hem niet aanklikken, laat staan zien staan)
en ja ik heb al bij windows media player; media delen/aan media toevoegen/wijzigingen in mediagegevens toepassen gedaan.
nou heb ik hem op cd gebrand, als databestand (de divx) hij speelt gewoon af, maar als ik de ondertitels met het driehoekje probeer te selecteren kan ik kiezen uit: (uit, engels1, engels 2) en alle 3 werken ze niet... dus geen subs.
wat nu?
[ Voor 82% gewijzigd door Verwijderd op 29-03-2008 15:28 ]
Matched: voor, mkv
is het ook mogelijk dit te gebruiken om mkv files om te zetten naar mp4 zodat ze speelbaar zijn op apple tv? Iemand had een opmerking gemaakt dat het niet nodig is de 4Gb limiet op te zetten voor apple tv, dus heeft iemand dit al kunnen gebruiken?
Mvg, Tamara
Geen matches
Verwijderd schreef op zaterdag 29 maart 2008 @ 14:29:
wat nu?
Verander de extensie naar avi ipv divx, mischien dat dit helpt, bij mij in ieder geval wel.
Matched: voor, mkv
Sentry23 schreef op vrijdag 21 maart 2008 @ 15:04:
Voor het splitten van de mpeg2 bestanden kan je het programma "TMPGEnc MPEG Editor 2.0 PREMIUM" gebruiken. Hiermee kan je heel simpel (HD) mpeg2 sources laden en knippen op de door jou aangegeven tijdstippen. Dit gaat super snel. Binnen 10 minuten heb je een complete film in bijvoorbeeld 3 delen geknipt.
De trail-versie werkt 14 dagen en kan 30 minuten aan video per keer splitten/cutten. Voor een film van 2,5 uur betekend dit dus helaas 5 parts. De complete versie kost $65.
  • Sentry23
Matched: voor
Verwijderd schreef op zondag 30 maart 2008 @ 18:52:
Dat is bekend :)
Ook met virtualdubmod kom je een eind trouwens. Het liefts heb ik toch iets simpels om te splitten dat ik zo vanuit de tool aan kan roepen.
Anyway.. ;k ben weer terug, na te veel dagen druk te zijn geweest met werk, zodat ik weer aan de slag kan met code en antwoorden van vragen.
mods: bedankt voor de topic aanpassing :)
  • Sentry23
Matched: voor, mkv
Verwijderd schreef op zaterdag 29 maart 2008 @ 16:48:
Mvg, Tamara
Dit lijkt gewoon te werken (ook op andere media boxen die mpeg4 willen streamen)
Matched: mkv, ps3
Sentry23: Gebruik Gotsent nu al best een tijdje en geen probleem met Beta 10. Nu blijkt vanaf versie beta 12 als ik een mkv omzet met mux to vob en alles lijkt correct te verlopen ik met een file (of meerder als er een split nodig is) blijf zitten die incompatible data geeft op mijn ps3. Vreemd probleem, dus gebruik ik nu beta 10 maar weer.
Probleem iets aan te doen?
  • Sentry23
Matched: mkv, ps3
Verwijderd schreef op dinsdag 01 april 2008 @ 17:06:
Bekend probleem zelfs.. Een kwestie van iets te optimistisch optimaliseren.
Als er een level 4.1 bestand wordt gevonden in 23b12, dan haalt hij hem niet door h264info heen. (scheelde meer dan de helft van de conversie tijd)
De PS3 is er picky met m2ts bestanden, en pakt veel van deze bestanden niet als ze niet door h264info heen gaan. (toevallig mijn 4.1 test bestanden dus wel :-/)
Wordt opgelost :)
  • Sentry23
Geen matches
rippance schreef op vrijdag 28 maart 2008 @ 19:42:
VC1 wel.
VC-1 extract, WMApro extract, en mux naar WMV.
  • Sjaak_Trekhaak
Matched: voor, mkv
Sentry23 schreef op dinsdag 01 april 2008 @ 17:34:
VC1 wel.
Wat voor audio encoding zit over de meeste 720p MKV films dan? Ik zou zeggen, AC-3, maar ik weet niet als dat een geëncodeerd formaat is of de raw audio zelf.
  • Seraphus-Y
Seraphus-Y
Matched: voor
hmzz.. ik ga deze mencoder ook even proberen.
Heb nu met .12b met het omzetten van Nigh at the Museum best wat problemen gehad.
Hopelijk gaat het hier een stuk beter mee.
Ik meld me weer met de resultaten.
Resultaat: Geen verbetering. Na een (verplichte) conversie naar mpg, een procedure van dik 2 uur (!?) en een sloot foutmeldingen van mencoder, nog steeds de film die na 1 seconde vastloopt en verder niks.
Ga nog even verder klooien met een andere titel.
[ Voor 11% gewijzigd door Seraphus-Y op 02-04-2008 09:59 ]
  • Sentry23
Matched: voor, mkv
rippance schreef op dinsdag 01 april 2008 @ 20:27:
Audio is extreem divers in MKV :)
h264 komt over het algemeen met ac3 en dts, maar 5.1 AAC, 2.0 AAC, Ogg en mp3 komen ook regelmatig voor. (veel anime komt met mp3)
Vc-1 komt meestal ook met ac3 of dts.
raw pcm ben ik nog niet tegengekomen in mkv's, maar het zou zo kunnen.
@seraph: ik zal een andere versie sturen die wat workarounds bevat voor mpeg2 en minder problemen zou moeten geven. (3 traps conversie i.p.v alles in 1 keer te doen)
  • Sorcerer8472
  • Laatst online: 18:31
Sorcerer8472
Mens sana?
Matched: voor, mkv
AC3 is net als MP3 een audiocodec :)
Wikipedia: Dolby Digital
  • Seraphus-Y
Seraphus-Y
Matched: voor, mkv
Sentry23 schreef op woensdag 02 april 2008 @ 10:44:
Helemaal top! En misschien iets wat ook niet moeilijk doet over bestanden die op een andere locatie staan of in elk geval de temp-bestanden lokaal neer zet?
Heb nu een 12GB mkv'tje staan, maar m'n VMWare Fusion Win XP disk is maar 20GB, dus er is geen plek voor de output. Als ik de mkv van een mac disk wil lezen, dan werkt het dus (nog steeds) niet.
P.s. Heb je al een datum vrij??
  • Crowbar
  • Laatst online: 08-11-2025
Matched: mkv
Pff ik dacht dat ik lekker wat mkv'tjes goed had omgezet, blijkt het tegendeel waar te zijn. Films zoals Pearl Harbor, American Beauty, Eastern Promises (met srt ingebakken dus mpeg2) stoppen allemaal na ong 50/60 minuten. Ook merk ik nu dat enkele omzettingen naar vob (Remember the titans. Dead Or Alive en King Of California) dezelfde filesize hebben (4.294.956.248) en ook maar een beperkte duur hebben.
Wellicht heeft dit te maken dat mijn output dir de externe schijf is (fat32) waardoor de max data bereikt is en het bestand niet groter mag worden. Het rare is dat ik altijd de optie 'split >4 gig' aanvink.
  • xxACxx
Matched: mkv
Crowbar schreef op donderdag 03 april 2008 @ 11:58:
kun je wel aanklikken maar een mpeg valt meestal wat groter uit.
Je kunt het beste van te voren splitten bv met mkvmerg naar 2250M en daarna pas omzetten naar mpeg...
  • Sentry23
Matched: mkv
xxACxx schreef op donderdag 03 april 2008 @ 13:08:
Zo'n soort optie ben ik ook aan het inbouwen om dit automatisch goed te zetten trouwens.. goed mpeg splitten blijft lastig.
