[Vista-64]BSOD (met crashdump)
  • 45 views sinds 30-01-2008
  • miliomiliano
  • Laatst online: 16:55
Hey iedereen, ik krijg continue een bsod, en ik kan er niet wijzer uit worden. Zie de crashdump hieronder. Heeft iemand enig idee wat ik het beste kan doen?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck B8, {fffffa8002a2d8a0, fffff8000214eb80, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt!SwapContext+18c )
Followup: MachineOwner
kd> !analyze -v
ATTEMPTED_SWITCH_FROM_DPC (b8)
A wait operation, attach process, or yield was attempted from a DPC routine.
This is an illegal operation and the stack track will lead to the offending
code and original DPC routine.
Arguments:
Arg1: fffffa8002a2d8a0, Original thread which is the cause of the failure
Arg2: fffff8000214eb80, New thread
Arg3: 0000000000000000, Stack address of the original thread
Arg4: 0000000000000000
Debugging Details:
FAULTING_THREAD:  fffffa8002a2d8a0
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xB8
PROCESS_NAME:  Idle
CURRENT_IRQL:  c
LAST_CONTROL_TRANSFER:  from fffff800020507ac to fffff8000204e250
STACK_TEXT:
fffff800`031ead38 fffff800`020507ac : 00000000`000000b8 fffffa80`02a2d8a0 fffff800`0214eb80 00000000`00000000 : nt!KeBugCheckEx
fffff800`031ead40 00000000`000000b8 : fffffa80`02a2d8a0 fffff800`0214eb80 00000000`00000000 00000000`00000000 : nt!SwapContext+0x18c
fffff800`031ead48 fffffa80`02a2d8a0 : fffff800`0214eb80 00000000`00000000 00000000`00000000 fffffa80`02b6e401 : 0xb8
fffff800`031ead50 fffff800`0214eb80 : 00000000`00000000 00000000`00000000 fffffa80`02b6e401 00000000`00000001 : 0xfffffa80`02a2d8a0
fffff800`031ead58 00000000`00000000 : 00000000`00000000 fffffa80`02b6e401 00000000`00000001 fffff800`02050286 : nt!KiInitialThread
fffff800`031ead60 00000000`00000000 : fffffa80`02b6e401 00000000`00000001 fffff800`02050286 fffff980`046142e4 : 0x0
fffff800`031ead68 fffffa80`02b6e401 : 00000000`00000001 fffff800`02050286 fffff980`046142e4 fffff800`02149880 : 0x0
fffff800`031ead70 00000000`00000001 : fffff800`02050286 fffff980`046142e4 fffff800`02149880 00000000`00000001 : 0xfffffa80`02b6e401
fffff800`031ead78 fffff800`02050286 : fffff980`046142e4 fffff800`02149880 00000000`00000001 fffff800`0214eb80 : 0x1
fffff800`031ead80 fffff800`021ff724 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0xf6
fffff800`031eadb0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemStartup+0x1d4
STACK_COMMAND:  .thread 0xfffffa8002a2d8a0 ; kb
FOLLOWUP_IP:
nt!SwapContext+18c
fffff800`020507ac c3              ret
SYMBOL_STACK_INDEX:  1
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4549b6c6
SYMBOL_NAME:  nt!SwapContext+18c
FAILURE_BUCKET_ID:  X64_0xB8_nt!SwapContext+18c
Gigabyte B550 Aorus Pro, AMD Ryzen 5900X, Gigabyte RTX 3080 Gaming OC 10G, G.Skill DDR4 3600C16D-32GTZNC (2x16GB), Samsung 980 Pro
  • alt-92
alt-92
ye olde farte
miliomiliano,
Het is niet de bedoeling dat je hier een crashdump neerplant en het daarbij laat.
Neem de Windows Clients - FAQ en Windows Clients - Howto's and Guides door, en laat ook zien wat je zelf hebt gedaan om je probleem te achterhalen.
Als je mogelijke oplossingen bent tegengekomen die bij jou niet werken, meldt dat dan.
Ook over de gebruikte hardware missen we de informatie, en dat kan best nog wel eens heel belangrijk zijn.
Je huidige topicstart is in ieder geval véél te beperkt, daarom gaat deze dicht.
Je mag een nieuw topic openen, maar dan wel met de gewenste informatie, zie ook de Windows Clients - Policy over wat we hier verwachten.
