Taal van je x500 naar Nederlands (of andere taal)
  • 59 views sinds 30-01-2008
Hi ,
Today I try to put an Dutch version on the X500 (it was English).
I got success.
How to do!
*download the wwe 220 version
*download the dutch 3.54 vesion ( or other language roms)
1st Start the ROM you want until Installshield wizard is completed.
2nd Go to your windows temp folder (C:\Documents and Settings\XXX\Local Settings\Temp) and copy the temp.dat to your Desktop.
3rd Cancel the Installation of the ROM.
4th Install the WWE 220 ROM until Installshield wizard is completed.
5th Continue with the ROM update until your PDA has booted and it saiys Waiting for download.
6th When you see on your pc the message update lighted change the temp.dat on you desktop.
Go to your windows temp folder (C:\Documents and Settings\XXX\Local Settings\Temp) and replace the temp.dat file with this one you copied to your Desktop. ( temp.dat you can fid sometime in the C:\Windows\Temp, or you can search with the filebrowser (hidden files on) to tep.dat
7th Choose Update in the Pc software updater.
That's what I make and it's working 100%
  • DaannO
  • Laatst online: 06-10 11:06
Gathering of Tweakers is a Dutch forum, so we speak dutch here. :)
Verder kan dit topic prima in: E-ten X500 (TelefoonPDA/GPS)
  • Canaria
Canaria
4313-3581-4704
Ik sluit me aan bij de tweede zin van DaannO :)
Apparticle SharePoint | Apps | Articles
