Nieuwe ForceWare Beta's
  • 93 views sinds 30-01-2008
  • Tiduz
  • Laatst online: 20-06 19:12
http://www.nvidia.com/con...invista_32bit_english.exe
New Features
Adds support for GeForce 8600 GTS, GeForce 8600 GT, and GeForce 8500 GT, GeForce 8400 GS, and GeForce 8300 GS GPUs.
Increased performance in 3D applications.
PureVideo™ HD support.
Add support for forcing Vertical Sync in DirectX applications.
Updated NVIDIA Control Panel with improved user interface (Please see the Release Notes for more details).
Numerous game and application compatibility fixes (see below for some of the top issues).
Key Bug Fixes
Fixed numerous "Display driver has stopped responding" error messages.
"This is not Vista" error message appears when installing Windows Vista 32‐bit drivers on a Windows Vista 64‐bit operating system. The error message did not indicate which operating system (32‐bit or 64‐bit) is installed. NVIDIA has fixed the installer error message to better tell the end user which version of Windows Vista drivers and operating system are running.
Warhammer 40k Dawn of War (all versions) has driver error message and does not run.
The gamma and brightness controls in the NVIDIA Control Panel Adjust Desktop Color Settings page do not function or affect the desktop appearance consistently.
GeForce 8800 GTX/GTS, Windows Vista Ultimate Edition: Text in the Ultimate Game:Hold'em flashes at the start of the game.
GeForce 8800 GTX: Elder Scrolls: Oblivion–NVIDIA Control Panel antialiasing does not work when HDR is enabled.
GeForce 8800 GTX: Half Life 2–fog is broken or misapplied. This fix requires the user to update their Valve Source‐based games to the latest versions of the game engines.
GeForce 8800 GTX: Splinter Cell Double Agent–there is corruption in the game.
GeForce 8800 SLI: The system does not resume from S3 mode when SLI mode is enabled.
GeForce 8600/GeForce 7900 GTX SLI: "Display driver has stopped responding" error message appears when changing the resolution, or when resuming from Standby\Hibernate.
GeForce 8800 GTX: The Windows Experience Index tool crashes when trying to refresh the system score in Windows Vista 64-bit.
Please view the driver Release Notes for a list of all of the fixed issues in this driver release.
Draaien hier goed op vista 32bit home premium, en een Geforce 7900GTO
CPU: I5 6600K - Cooler: Noctua NH-D15S - RAM: 8GB Kingston HyperX Fury Black - GFX: GFX: MSI RTX 2070 Super - SSD: 250GB Samsung 850 Evo - Case: CoolerMaster CM Storm Stryker - PSU: Corsair RM750i
  • CodeCaster
CodeCaster
Stop AI Slop
Kan denk ik beter hier :)
Waar is de brand, meester?
  • Tiduz
bedankt voor de notice, wist niet dat die daar gepost moesten worden
  • Tiduz
done, thx
  • Ultraman
  • Laatst online: 28-08 07:58
Ultraman
Boefje
Dit is, zoals The_Zeroorez al zegt, meer iets voor de meuktracker. ;)
